[ Upstream commit a39ee449f96a2cd44ce056d8a0a112211a9b1a1f ]
vhost fails to validate negative error code
from vhost_get_vq_desc causing
a crash: we are using -EFAULT which is 0xfffffff2
as vector size, which exceeds the allocated size.
The code in question was introduced in commit
8dd014adfea6f173c1ef6378f7e5e7924866c923
vhost-net: mergeable buffers support
CVE-2014-0055
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit d8316f3991d207fe32881a9ac20241be8fa2bad0 ]
When mergeable buffers are disabled, and the
incoming packet is too large for the rx buffer,
get_rx_bufs returns success.
This was intentional in order for make recvmsg
truncate the packet and then handle_rx would
detect err != sock_len and drop it.
Unfortunately we pass the original sock_len to
recvmsg - which means we use parts of iov not fully
validated.
Fix this up by detecting this overrun and doing packet drop
immediately.
CVE-2014-0077
commit 60a01f558af9c48b0bb31f303c479e32721add3f upstream.
This patch addresses a long-standing bug where the get_user_pages_fast()
write parameter used for setting the underlying page table entry permission
bits was incorrectly set to write=1 for data_direction=DMA_TO_DEVICE, and
passed into get_user_pages_fast() via vhost_scsi_map_iov_to_sgl().
However, this parameter is intended to signal WRITEs to pinned userspace
PTEs for the virtio-scsi DMA_FROM_DEVICE -> READ payload case, and *not*
for the virtio-scsi DMA_TO_DEVICE -> WRITE payload case.
This bug would manifest itself as random process segmentation faults on
KVM host after repeated vhost starts + stops and/or with lots of vhost
endpoints + LUNs.
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Asias He <asias@redhat.com>
[ Upstream commit 19c73b3e08d16ee923f3962df4abf6205127896a ]
We used to poll vhost queue before making DMA is done, this is racy if vhost
thread were waked up before marking DMA is done which can result the signal to
be missed. Fix this by always polling the vhost thread before DMA is done.
Signed-off-by: Jason Wang <jasowang@redhat.com>
[ Upstream commit c38e39c378f46f00ce922dd40a91043a9925c28d ]
vhost_net_ubuf_put_and_wait has a confusing name:
it will actually also free it's argument.
Thus since commit 1280c27f8e29acf4af2da914e80ec27c3dbd5c01
"vhost-net: flush outstanding DMAs on memory change"
vhost_net_flush tries to use the argument after passing it
to vhost_net_ubuf_put_and_wait, this results
in use after free.
To fix, don't free the argument in vhost_net_ubuf_put_and_wait,
add an new API for callers that want to free ubufs.
Acked-by: Asias He <asias@redhat.com>
Acked-by: Jason Wang <jasowang@redhat.com>
vhost_net_clear_ubuf_info didn't clear ubuf_info
after kfree, this could trigger double free.
Fix this and simplify this code to make it more robust: make sure
ubuf info is always freed through vhost_net_clear_ubuf_info.
Reported-by: Tommi Rantala <tt.rantala@gmail.com>
If device has an owner, we shouldn't touch ubuf_info
since it might be in use.
When we decide not use zero-copy, msg.control should be set to NULL otherwise
macvtap/tap may set zerocopy callbacks which may decrease the kref of ubufs
wrongly.
Bug were introduced by commit cedb9bdce099206290a2bdd02ce47a7b253b6a84
(vhost-net: skip head management if no outstanding).
This solves the following warnings:
WARNING: at include/linux/kref.h:47 handle_tx+0x477/0x4b0 [vhost_net]()
Modules linked in: vhost_net macvtap macvlan tun nfsd exportfs bridge stp llc openvswitch kvm_amd kvm bnx2 megaraid_sas [last unloaded: tun]
CPU: 5 PID: 8670 Comm: vhost-8668 Not tainted 3.10.0-rc2+ #1566
Hardware name: Dell Inc. PowerEdge R715/00XHKG, BIOS 1.5.2 04/19/2011
ffffffffa0198323 ffff88007c9ebd08 ffffffff81796b73 ffff88007c9ebd48
ffffffff8103d66b 000000007b773e20 ffff8800779f0000 ffff8800779f43f0
ffff8800779f8418 000000000000015c 0000000000000062 ffff88007c9ebd58
Call Trace:
[<ffffffff81796b73>] dump_stack+0x19/0x1e
[<ffffffff8103d66b>] warn_slowpath_common+0x6b/0xa0
[<ffffffff8103d6b5>] warn_slowpath_null+0x15/0x20
[<ffffffffa0197627>] handle_tx+0x477/0x4b0 [vhost_net]
[<ffffffffa0197690>] handle_tx_kick+0x10/0x20 [vhost_net]
[<ffffffffa019541e>] vhost_worker+0xfe/0x1a0 [vhost_net]
[<ffffffffa0195320>] ? vhost_attach_cgroups_work+0x30/0x30 [vhost_net]
[<ffffffff81061f46>] kthread+0xc6/0xd0
[<ffffffff81061e80>] ? kthread_freezable_should_stop+0x70/0x70
[<ffffffff817a1aec>] ret_from_fork+0x7c/0xb0
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ 624.286653] vringh: module license 'unspecified' taints kernel.
Signed-off-by: Dave Jones <davej@redhat.com>
Pull more vhost fixes from Michael Tsirkin:
"This fixes some minor issues in the patches that have been merged.
We also finally drop the workaround disabling event_idx for scsi: it
was always questionable, and now we know it's not needed.
There's also a memory leak fix"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
vhost-scsi: Enable VIRTIO_RING_F_EVENT_IDX
vhost: drop virtio_net.h dependency
vhost-net: Cleanup vhost_ubuf and vhost_zcopy
vhost: Remove vhost_enable_zcopy in vhost.h
vhost: Remove comments for hdr in vhost.h
vhost: Move VHOST_NET_FEATURES to net.c
vhost-net: Free ubuf when vhost_dev_set_owner fails
vhost: Export vhost_dev_set_owner
It was disabled as a workaround. Now userspace bits work fine with it.
The broken version was not ever committed to QEMU, I guess the same is
true for nlkt.
So, let's enable it.
Signed-off-by: Asias He <asias@redhat.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
There's no net specific code in vhost.c anymore,
don't include the virtio_net.h header.
- Rename vhost_ubuf to vhost_net_ubuf
- Rename vhost_zcopy_mask to vhost_net_zcopy_mask
- Make funcs static
It is net.c specific.
It is supposed to be removed when hdr is moved into vhost_net_virtqueue.
vhost.h should not depend on device specific marcos like
VHOST_NET_F_VIRTIO_NET_HDR and VIRTIO_NET_F_MRG_RXBUF.
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio & lguest updates from Rusty Russell:
"Lots of virtio work which wasn't quite ready for last merge window.
Plus I dived into lguest again, reworking the pagetable code so we can
move the switcher page: our fixmaps sometimes take more than 2MB now..."
Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename.
Hopefully correctly resolved.
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits)
caif_virtio: Remove bouncing email addresses
lguest: improve code readability in lg_cpu_start.
virtio-net: fill only rx queues which are being used
lguest: map Switcher below fixmap.
lguest: cache last cpu we ran on.
lguest: map Switcher text whenever we allocate a new pagetable.
lguest: don't share Switcher PTE pages between guests.
lguest: expost switcher_pages array (as lg_switcher_pages).
lguest: extract shadow PTE walking / allocating.
lguest: make check_gpte et. al return bool.
lguest: assume Switcher text is a single page.
lguest: rename switcher_page to switcher_pages.
lguest: remove RESERVE_MEM constant.
lguest: check vaddr not pgd for Switcher protection.
lguest: prepare to make SWITCHER_ADDR a variable.
virtio: console: replace EMFILE with EBUSY for already-open port
virtio-scsi: reset virtqueue affinity when doing cpu hotplug
virtio-scsi: introduce multiqueue support
virtio-scsi: push vq lock/unlock into virtscsi_vq_done
virtio-scsi: pass struct virtio_scsi to virtqueue completion function
Rename module and update Kconfig and Makefile.
Add alias for compatibility with old userspace
scripts if any.
Reviewed-by: Asias He <asias@redhat.com>
Acked-by: Nicholas Bellinger <nab@linux-iscsi.org>
move uapi parts to vhost.h
move .c private parts to .c itself
Move tcm_vhost.c -> scsi.c
RESET_OWNER ioctl would leave the fd in a bad state if
memory allocation failed: device is stopped
but owner is not reset. Make state changes
after allocating memory, such that a failed
ioctl has no effect.
vhost.h only has generic bits now, so we can drop it
virtio-net.h in tcm_vhost.
This will remove the need for vhost scsi to pull
in virtio-net.h.
Add more comments so we remember not to break it
next time we change things.
On top of 'vhost: Allow device specific fields per vq', we can move device
specific fields to device virt queue from vhost virt queue.
Unlike tcm_vhost_evt requests, tcm_vhost_cmd requests are passed to the
target core system, we can not make sure all the pending requests will
be finished by flushing the virt queue.
In this patch, we do refcount for every tcm_vhost_cmd requests to make
vhost_scsi_flush() wait for all the pending requests issued before the
flush operation to be finished.
This is useful when we call vhost_scsi_clear_endpoint() to stop
tcm_vhost. No new requests will be passed to target core system because
we clear the endpoint by setting vs_tpg to NULL. And we wait for all the
old requests. These guarantee no requests will be leaked and existing
requests will be completed.
This is useful for any device who wants device specific fields per vq.
For example, tcm_vhost wants a per vq field to track requests which are
in flight on the vq. Also, on top of this we can add patches to move
things like ubufs from vhost.h out to net.c.
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending into vhost-net-next
Everything for hotplug is ready. Let's enable the feature bit.
In commit 365a7150094 ([SCSI] virtio-scsi: hotplug support for
virtio-scsi), hotplug support is added to virtio-scsi.
This patch adds hotplug and hotunplug support to tcm_vhost.
You can create or delete a LUN in targetcli to hotplug or hotunplug a
LUN in guest.
Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
We want to use tcm_vhost_mutex to make sure hotplug/hotunplug will not
happen when set_endpoint/clear_endpoint is in process.
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
Pull SCSI target fixes from Nicholas Bellinger:
"Here are remaining target-pending items for v3.9-rc7 code.
The tcm_vhost patches are more than I'd usually include in a -rc7
pull, but are changes required for v3.9 to work correctly with the
pending vhost-scsi-pci QEMU upstream series merge. (Paolo CC'ed)
Plus Asias's conversion to use vhost_virtqueue->private_data + RCU for
managing vhost-scsi endpoints has gotten alot of review + testing over
the past weeks, and MST has ACKed the full series.
Also, there is a target patch to fix a long-standing bug within
control CDB handling with Standby/Offline/Transition ALUA port access
states, that had been incorrectly rejecting the control CDBs required
for LUN scan to work during these port group states. CC'ing to
stable."
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
target: Fix incorrect fallthrough of ALUA Standby/Offline/Transition CDBs
tcm_vhost: Send bad target to guest when cmd fails
tcm_vhost: Add vhost_scsi_send_bad_target() helper
tcm_vhost: Fix tv_cmd leak in vhost_scsi_handle_vq
tcm_vhost: Remove double check of response
tcm_vhost: Initialize vq->last_used_idx when set endpoint
tcm_vhost: Use vq->private_data to indicate if the endpoint is setup
tcm_vhost: Use ACCESS_ONCE for vs->vs_tpg[target] access
After commit 2b8b328b61c799957a456a5a8dab8cc7dea68575 (vhost_net: handle polling
errors when setting backend), we in fact track the polling state through
poll->wqh, so there's no need to duplicate the work with an extra
vhost_net_polling_state. So this patch removes this and make the code simpler.
This patch also removes the all tx starting/stopping code in tx path according
to Michael's suggestion.
Netperf test shows almost the same result in stream test, but gets improvements
on TCP_RR tests (both zerocopy or copy) especially on low load cases.
Tested between multiqueue kvm guest and external host with two direct
connected 82599s.
zerocopy disabled:
sessions|transaction rates|normalize|
before/after/+improvements
1 | 9510.24/11727.29/+23.3% | 693.54/887.68/+28.0% |
25| 192931.50/241729.87/+25.3% | 2376.80/2771.70/+16.6% |
50| 277634.64/291905.76/+5% | 3118.36/3230.11/+3.6% |
zerocopy enabled:
1 | 7318.33/11929.76/+63.0% | 521.86/843.30/+61.6% |
25| 167264.88/242422.15/+44.9% | 2181.60/2788.16/+27.8% |
50| 272181.02/294347.04/+8.1% | 3071.56/3257.85/+6.1% |
Send bad target to guest in case:
1) we can not allocate the cmd
2) fail to submit the cmd
Share the send bad target code with other use cases.
If we fail to submit the allocated tv_vmd to tcm_vhost_submission_work,
we will leak the tv_vmd. Free tv_vmd on fail path.
We did the length of response check twice.
This patch fixes guest hang when booting seabios and guest.
[ 0.576238] scsi0 : Virtio SCSI HBA
[ 0.616754] virtio_scsi virtio1: request:id 0 is not a head!
vq->last_used_idx is initialized only when /dev/vhost-scsi is
opened or closed.
vhost_scsi_open -> vhost_dev_init() -> vhost_vq_reset()
vhost_scsi_release() -> vhost_dev_cleanup -> vhost_vq_reset()
So, when guest talks to tcm_vhost after seabios does, vq->last_used_idx
still contains the old valule for seabios. This confuses guest.
Fix this by calling vhost_init_used() to init vq->last_used_idx when
we set endpoint.
Currently, vs->vs_endpoint is used indicate if the endpoint is setup or
not. It is set or cleared in vhost_scsi_set_endpoint() or
vhost_scsi_clear_endpoint() under the vs->dev.mutex lock. However, when
we check it in vhost_scsi_handle_vq(), we ignored the lock.
Instead of using the vs->vs_endpoint and the vs->dev.mutex lock to
indicate the status of the endpoint, we use per virtqueue
vq->private_data to indicate it. In this way, we can only take the
vq->mutex lock which is per queue and make the concurrent multiqueue
process having less lock contention. Further, in the read side of
vq->private_data, we can even do not take the lock if it is accessed in
the vhost worker thread, because it is protected by "vhost rcu".
(nab: Do s/VHOST_FEATURES/~VHOST_SCSI_FEATURES)
In vhost_scsi_handle_vq:
tv_tpg = vs->vs_tpg[target];
if (!tv_tpg) {
return
tv_cmd = vhost_scsi_allocate_cmd(tv_tpg, &v_req,
1) vs->vs_tpg[target] might change after the NULL check and 2) the above
line might access tv_tpg from vs->vs_tpg[target]. To prevent 2), use
ACCESS_ONCE. Thanks mst for catching this up!
"This includes the bug-fix for a >= v3.8-rc1 regression specific to
iscsi-target persistent reservation conflict handling (CC'ed to
stable), and a tcm_vhost patch to drop VIRTIO_RING_F_EVENT_IDX usage
so that in-flight qemu vhost-scsi-pci device code can detect the
proper vhost feature bits.
Also, there are two more tcm_vhost patches still being discussed by
MST and Asias for v3.9 that will be required for the in-flight qemu
vhost-scsi-pci device patch to function properly, and that should
(hopefully) be the last target fixes for this round."
target: Fix RESERVATION_CONFLICT status regression for iscsi-target special case
tcm_vhost: Avoid VIRTIO_RING_F_EVENT_IDX feature bit
This patch adds a VHOST_SCSI_FEATURES mask minus VIRTIO_RING_F_EVENT_IDX
so that vhost-scsi-pci userspace will strip this feature bit once
GET_FEATURES reports it as being unsupported on the host.
This is to avoid a bug where ->handle_kicks() are missed when EVENT_IDX
is enabled by default in userspace code.
(mst: Rename to VHOST_SCSI_FEATURES + add comment)
"These are mostly minor fixes this time around. The iscsi-target CHAP
big-endian bugfix and bump FD_MAX_SECTORS=2048 default patch to allow
1MB sized I/Os for FILEIO backends on >= v3.5 code are both CC'ed to
stable.
Also, there is a persistent reservations regression that has recently
been reported for >= v3.8.x code, that is currently being tracked down
for v3.9."
target/pscsi: Reject cross page boundary case in pscsi_map_sg
target/file: Bump FD_MAX_SECTORS to 2048 to handle 1M sized I/Os
tcm_vhost: Flush vhost_work in vhost_scsi_flush()
tcm_vhost: Add missed lock in vhost_scsi_clear_endpoint()
target: fix possible memory leak in core_tpg_register()
target/iscsi: Fix mutual CHAP auth on big-endian arches
target_core_sbc: use noop for SYNCHRONIZE_CACHE
Getting use of virtio rings correct is tricky, and a recent patch saw
an implementation of in-kernel rings (as separate from userspace).
This abstracts the business of dealing with the virtio ring layout
from the access (userspace or direct); to do this, we use function
pointers, which gcc inlines correctly.
We also need to flush the vhost_works. It is the completion vhost_work
currently.
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
