In sg_common_write(), we free the block request and return -ENODEV if
the device is detached in the middle of the SG_IO ioctl().
Unfortunately, sg_finish_rem_req() also tries to free srp->rq, so we
end up freeing rq->cmd in the already free rq object, and then free
the object itself out from under the current user.
This ends up corrupting random memory via the list_head on the rq
object. The most common crash trace I saw is this:
kernel BUG at block/blk-core.c:1420!
Call Trace:
[<ffffffff81281eab>] blk_put_request+0x5b/0x80
[<ffffffffa0069e5b>] sg_finish_rem_req+0x6b/0x120 [sg]
[<ffffffffa006bcb9>] sg_common_write.isra.14+0x459/0x5a0 [sg]
[<ffffffff8125b328>] ? selinux_file_alloc_security+0x48/0x70
[<ffffffffa006bf95>] sg_new_write.isra.17+0x195/0x2d0 [sg]
[<ffffffffa006cef4>] sg_ioctl+0x644/0xdb0 [sg]
[<ffffffff81170f80>] do_vfs_ioctl+0x90/0x520
[<ffffffff81258967>] ? file_has_perm+0x97/0xb0
[<ffffffff811714a1>] SyS_ioctl+0x91/0xb0
[<ffffffff81602afb>] tracesys+0xdd/0xe2
RIP [<ffffffff81281e04>] __blk_put_request+0x154/0x1a0
The solution is straightforward: just set srp->rq to NULL in the
failure branch so that sg_finish_rem_req() doesn't attempt to re-free
it.
Additionally, since sg_rq_end_io() will never be called on the object
when this happens, we need to free memory backing ->cmd if it isn't
embedded in the object itself.
KASAN was extremely helpful in finding the root cause of this bug.
Bug 1823317
Bug 1935735
Change-Id: I883243dce583cd79e28facaa2cdd81157b293d74
Signed-off-by: Calvin Owens <calvinowens@fb.com>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Reviewed-on: http://git-master/r/1259958
(cherry picked from commit b49da4529988ca02bddaed8091a7f5e91105970a)
Reviewed-on: https://git-master.nvidia.com/r/1690295
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
commit af61e27c3f77c7623b5335590ae24b6a5c323e22 upstream.
On suspend, _scsih_suspend calls mpt2sas_base_free_resources, which
in turn calls pci_disable_device if the device is enabled prior to
suspending. However, _scsih_suspend also calls pci_disable_device
itself.
Thus, in the event that the device is enabled prior to suspending,
pci_disable_device will be called twice. This patch removes the
duplicate call to pci_disable_device in _scsi_suspend as it is both
unnecessary and results in a kernel oops.
Signed-off-by: Tyler Stachecki <tstache1@binghamton.edu>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 0c8482ac92db5ac15792caf23b7f7df9e4f48ae1 upstream.
virtscsi_init calls virtscsi_remove_vqs on err, even before initializing
the vqs. The latter calls virtscsi_set_affinity, so let's check the
pointer there before setting affinity on it.
This fixes a panic when setting device's num_queues=2 on RHEL 6.5:
qemu-system-x86_64 ... \
-device virtio-scsi-pci,id=scsi0,addr=0x13,...,num_queues=2 \
-drive file=/stor/vm/dummy.raw,id=drive-scsi-disk,... \
-device scsi-hd,drive=drive-scsi-disk,...
[ 0.354734] scsi0 : Virtio SCSI HBA
[ 0.379504] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
[ 0.380141] IP: [<ffffffff814741ef>] __virtscsi_set_affinity+0x4f/0x120
[ 0.380141] PGD 0
[ 0.380141] Oops: 0000 [#1] SMP
[ 0.380141] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.14.0+ #5
[ 0.380141] Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2007
[ 0.380141] task: ffff88003c9f0000 ti: ffff88003c9f8000 task.ti: ffff88003c9f8000
[ 0.380141] RIP: 0010:[<ffffffff814741ef>] [<ffffffff814741ef>] __virtscsi_set_affinity+0x4f/0x120
[ 0.380141] RSP: 0000:ffff88003c9f9c08 EFLAGS: 00010256
[ 0.380141] RAX: 0000000000000000 RBX: ffff88003c3a9d40 RCX: 0000000000001070
[ 0.380141] RDX: 0000000000000002 RSI: 0000000000000000 RDI: 0000000000000000
[ 0.380141] RBP: ffff88003c9f9c28 R08: 00000000000136c0 R09: ffff88003c801c00
[ 0.380141] R10: ffffffff81475229 R11: 0000000000000008 R12: 0000000000000000
[ 0.380141] R13: ffffffff81cc7ca8 R14: ffff88003cac3d40 R15: ffff88003cac37a0
[ 0.380141] FS: 0000000000000000(0000) GS:ffff88003e400000(0000) knlGS:0000000000000000
[ 0.380141] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 0.380141] CR2: 0000000000000020 CR3: 0000000001c0e000 CR4: 00000000000006f0
[ 0.380141] Stack:
[ 0.380141] ffff88003c3a9d40 0000000000000000 ffff88003cac3d80 ffff88003cac3d40
[ 0.380141] ffff88003c9f9c48 ffffffff814742e8 ffff88003c26d000 ffff88003c26d000
[ 0.380141] ffff88003c9f9c68 ffffffff81474321 ffff88003c26d000 ffff88003c3a9d40
[ 0.380141] Call Trace:
[ 0.380141] [<ffffffff814742e8>] virtscsi_set_affinity+0x28/0x40
[ 0.380141] [<ffffffff81474321>] virtscsi_remove_vqs+0x21/0x50
[ 0.380141] [<ffffffff81475231>] virtscsi_init+0x91/0x240
[ 0.380141] [<ffffffff81365290>] ? vp_get+0x50/0x70
[ 0.380141] [<ffffffff81475544>] virtscsi_probe+0xf4/0x280
[ 0.380141] [<ffffffff81363ea5>] virtio_dev_probe+0xe5/0x140
[ 0.380141] [<ffffffff8144c669>] driver_probe_device+0x89/0x230
[ 0.380141] [<ffffffff8144c8ab>] __driver_attach+0x9b/0xa0
[ 0.380141] [<ffffffff8144c810>] ? driver_probe_device+0x230/0x230
[ 0.380141] [<ffffffff8144ac1c>] bus_for_each_dev+0x8c/0xb0
[ 0.380141] [<ffffffff8144c499>] driver_attach+0x19/0x20
[ 0.380141] [<ffffffff8144bf28>] bus_add_driver+0x198/0x220
[ 0.380141] [<ffffffff8144ce9f>] driver_register+0x5f/0xf0
[ 0.380141] [<ffffffff81d27c91>] ? spi_transport_init+0x79/0x79
[ 0.380141] [<ffffffff8136403b>] register_virtio_driver+0x1b/0x30
[ 0.380141] [<ffffffff81d27d19>] init+0x88/0xd6
[ 0.380141] [<ffffffff81d27c18>] ? scsi_init_procfs+0x5b/0x5b
[ 0.380141] [<ffffffff81ce88a7>] do_one_initcall+0x7f/0x10a
[ 0.380141] [<ffffffff81ce8aa7>] kernel_init_freeable+0x14a/0x1de
[ 0.380141] [<ffffffff81ce8b3b>] ? kernel_init_freeable+0x1de/0x1de
[ 0.380141] [<ffffffff817dec20>] ? rest_init+0x80/0x80
[ 0.380141] [<ffffffff817dec29>] kernel_init+0x9/0xf0
[ 0.380141] [<ffffffff817e68fc>] ret_from_fork+0x7c/0xb0
[ 0.380141] RIP [<ffffffff814741ef>] __virtscsi_set_affinity+0x4f/0x120
[ 0.380141] RSP <ffff88003c9f9c08>
[ 0.380141] ---[ end trace 8074b70c3d5e1d73 ]---
[ 0.475018] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000009
[ 0.475018]
[ 0.475068] Kernel Offset: 0x0 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffff9fffffff)
[ 0.475068] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000009
[jejb: checkpatch fixes]
Signed-off-by: Fam Zheng <famz@redhat.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
commit e2c70425f05219b142b3a8a9489a622c736db39d upstream.
The original code always set the upper 32 bits to zero because it was
doing a shift of the wrong variable.
Fixes: 1a4f550a09f8 ('[SCSI] arcmsr: 1.20.00.15: add SATA RAID plus other fixes')
commit b2a72ec32d0f499aaadf41264232517a12326df0 upstream.
qla2x00_mem_alloc() returns 1 on success and -ENOMEM on failure. On the
one hand the caller assumes non-zero is success but on the other hand
the caller also assumes that it returns an error code.
I've fixed it to return zero on success and a negative error code on
failure. This matches the documentation as well.
[jejb: checkpatch fix]
Fixes: e315cd28b9ef ('[SCSI] qla2xxx: Code changes for qla data structure refactoring')
Acked-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
commit b12bb60d6c350b348a4e1460cd68f97ccae9822e upstream.
If the initialization of storvsc fails, the storvsc_device_destroy()
causes NULL pointer dereference.
storvsc_bus_scan()
scsi_scan_target()
__scsi_scan_target()
scsi_probe_and_add_lun(hostdata=NULL)
scsi_alloc_sdev(hostdata=NULL)
sdev->hostdata = hostdata
now the host allocation fails
__scsi_remove_device(sdev)
calls sdev->host->hostt->slave_destroy() ==
storvsc_device_destroy(sdev)
access of sdev->hostdata->request_mempool
Signed-off-by: Ales Novak <alnovak@suse.cz>
Signed-off-by: Thomas Abraham <tabraham@suse.com>
Reviewed-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
commit b77ed25c9f8402e8b3e49e220edb4ef09ecfbb53 upstream.
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
commit c59053a23d586675c25d789a7494adfdc02fba57 upstream.
In the first place, the loop 'for' in the macro 'for_each_isci_host'
(drivers/scsi/isci/host.h:314) is incorrect, because it accesses
the 3rd element of 2 element array. After the 2nd iteration it executes
the instruction:
ihost = to_pci_info(pdev)->hosts[2]
(while the size of the 'hosts' array equals 2) and reads an
out of range element.
In the second place, this loop is incorrectly optimized by GCC v4.8
(see http://marc.info/?l=linux-kernel&m=138998871911336&w=2).
As a result, on platforms with two SCU controllers,
the loop is executed more times than it can be (for i=0,1 and 2).
It causes kernel panic during entering the S3 state
and the following oops after 'rmmod isci':
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8131360b>] __list_add+0x1b/0xc0
Oops: 0000 [#1] SMP
RIP: 0010:[<ffffffff8131360b>] [<ffffffff8131360b>] __list_add+0x1b/0xc0
Call Trace:
[<ffffffff81661b84>] __mutex_lock_slowpath+0x114/0x1b0
[<ffffffff81661c3f>] mutex_lock+0x1f/0x30
[<ffffffffa03e97cb>] sas_disable_events+0x1b/0x50 [libsas]
[<ffffffffa03e9818>] sas_unregister_ha+0x18/0x60 [libsas]
[<ffffffffa040316e>] isci_unregister+0x1e/0x40 [isci]
[<ffffffffa0403efd>] isci_pci_remove+0x5d/0x100 [isci]
[<ffffffff813391cb>] pci_device_remove+0x3b/0xb0
[<ffffffff813fbf7f>] __device_release_driver+0x7f/0xf0
[<ffffffff813fc8f8>] driver_detach+0xa8/0xb0
[<ffffffff813fbb8b>] bus_remove_driver+0x9b/0x120
[<ffffffff813fcf2c>] driver_unregister+0x2c/0x50
[<ffffffff813381f3>] pci_unregister_driver+0x23/0x80
[<ffffffffa04152f8>] isci_exit+0x10/0x1e [isci]
[<ffffffff810d199b>] SyS_delete_module+0x16b/0x2d0
[<ffffffff81012a21>] ? do_notify_resume+0x61/0xa0
[<ffffffff8166ce29>] system_call_fastpath+0x16/0x1b
The loop has been corrected.
This patch fixes kernel panic during entering the S3 state
and the above oops.
Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com>
Reviewed-by: Maciej Patelczyk <maciej.patelczyk@intel.com>
Tested-by: Lukasz Dorau <lukasz.dorau@intel.com>
commit ddfadd7736b677de2d4ca2cd5b4b655368c85a7a upstream.
Remove an erroneous BUG_ON() in the case of a hard reset timeout. The
reset timeout handler puts the port into the "awaiting link-up" state.
The timeout causes the device to be disconnected and we need to be in
the awaiting link-up state to re-connect the port. The BUG_ON() made
the incorrect assumption that resets never timeout and we always
complete the reset in the "resetting" state.
Testing this patch also uncovered that libata continues to attempt to
reset the port long after the driver has torn down the context. Once
the driver has committed to abandoning the link it must indicate to
libata that recovery ends by returning -ENODEV from
->lldd_I_T_nexus_reset().
Acked-by: Lukasz Dorau <lukasz.dorau@intel.com>
Reported-by: David Milburn <dmilburn@redhat.com>
Reported-by: Xun Ni <xun.ni@intel.com>
Tested-by: Xun Ni <xun.ni@intel.com>
commit 6f58c780e5a5b43a6d2121e0d43cdcba1d3cc5fc upstream.
A selective retransmission request (SRR) is a fibre-channel
protocol control request which provides support for requesting
retransmission of a data sequence in response to an issue such as
frame loss or corruption. These events are experienced
infrequently in fibre-channel based networks which makes
it difficult to test and assess codepaths which handle these
events.
We were fortunate enough, for some definition of fortunate, to
have a metro-area single-mode SAN link which, at 10 GBPS
sustained load levels, would consistently generate SRR's in
a SCST based target implementation using our SCST/in-kernel
Qlogic target interface driver. In response to an SRR the
in-kernel Qlogic target driver immediately panics resulting
in a catastrophic storage failure for serviced initiators.
The culprit was a debug statement in the qla_target.c file which
does not verify that a pointer to the SCSI CDB is not null.
The unchecked pointer dereference results in the kernel panic
and resultant system failure.
The other two references to the SCSI CDB by the SRR handling code
use a ternary operator to verify a non-null pointer is being
acted on. This patch simply adds a similar test to the implicated
debug statement.
This patch is a candidate for any stable kernel being maintained
since it addresses a potentially catastrophic event with
minimal downside.
Signed-off-by: Dr. Greg Wettstein <greg@enjellic.com>
commit f466f75385369a181409e46da272db3de6f5c5cb upstream.
vqs are freed in virtscsi_freeze but the hotcpu_notifier is not
unregistered. We will have a use-after-free usage when the notifier
callback is called after virtscsi_freeze.
Fixes: 285e71ea6f3583a85e27cb2b9a7d8c35d4c0d558
("virtio-scsi: reset virtqueue affinity when doing cpu hotplug")
Signed-off-by: Asias He <asias.hejun@gmail.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Jason Wang <jasowang@redhat.com>
commit dcaf9aed995c2b2a49fb86bbbcfa2f92c797ab5d upstream.
Bfa driver crash is observed while pushing the firmware on to chinook
quad port card due to uninitialized bfi_image_ct2 access which gets
initialized only for CT2 ASIC based cards after request_firmware().
For quard port chinook (CT2 ASIC based), bfi_image_ct2 is not getting
initialized as there is no check for chinook PCI device ID before
request_firmware and instead bfi_image_cb is initialized as it is the
default case for card type check.
This patch includes changes to read the right firmware for quad port chinook.
Signed-off-by: Vijaya Mohan Guvva <vmohan@brocade.com>
commit af73623f5f10eb3832c87a169b28f7df040a875b upstream.
Somehow older areca firmware versions have issues with
scsi_get_vpd_page() and a large buffer, the firmware
seems to crash and the scsi error-handler will start endless
recovery retries.
Limiting the buf-size to 64-bytes fixes this issue with older
firmware versions (<1.49 for my controller).
Fixes a regression with areca controllers and older firmware versions
introduced by commit: 66c28f97120e8a621afd5aa7a31c4b85c547d33d
Reported-by: Nix <nix@esperi.org.uk>
Tested-by: Nix <nix@esperi.org.uk>
Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
commit 54b2b50c20a61b51199bedb6e5d2f8ec2568fb43 upstream.
Some host adapters do not pass commands through to the target disk
directly. Instead they provide an emulated target which may or may not
accurately report its capabilities. In some cases the physical device
characteristics are reported even when the host adapter is processing
commands on the device's behalf. This can lead to adapter firmware hangs
or excessive I/O errors.
This patch disables WRITE SAME for devices connected to host adapters
that provide an emulated target. Driver writers can disable WRITE SAME
by setting the no_write_same flag in the host adapter template.
[jejb: fix up rejections due to eh_deadline patch]
commit 88bf6d62db4393fa03a58bada9d746312d5b496f upstream.
A return value of 1 is interpreted as an error. See pci_driver.
in local_pci_probe(). If you're wondering how this ever could
have worked, it's because it used to be the case that only return
values less than zero were interpreted as failure. But even in
the current kernel if the driver registers its various entry
points with the kernel, and then returns a value which is
interpreted as failure, those registrations aren't undone, so
the driver still mostly works. However, the driver's remove
function wouldn't be called on rmmod, and pci power management
functions wouldn't work. In the case of Smart Array, since it
has a battery backed cache (or else no cache) even if the driver
is not shut down properly as long as there is no outstanding
i/o, nothing too bad happens, which is why it took so long to
notice.
Requesting backport to stable because the change to pci-driver.c
which requires driver probe functions to return 0 occurred between
2.6.35 and 2.6.36 (the pci power management breakage) and again
between 3.7 and 3.8 (pci_dev->driver getting set to NULL in
local_pci_probe() preventing driver remove function from being
called on rmmod.)
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
commit 2e311fbabdc23b7eaec77313dc3b9a151a5407b5 upstream.
We inadvertantly discarded the scsi status for aborted commands.
For some commands (e.g. reads from tape drives) these can't be retried,
and if we discarded the scsi status, the scsi mid layer couldn't notice
anything was wrong and the error was not reported.
commit ae5fbae0ccd982dfca0ce363036ed92f5b13f150 upstream.
Since commit 110dd8f19df5 "[SCSI] libsas: fix scr_read/write users and
update the libata documentation" we have been passing pmp=1 and is_cmd=0
to ata_tf_to_fis(). Praveen reports that eSATA attached drives do not
discover correctly. His investigation found that the BIOS was passing
pmp=0 while Linux was passing pmp=1 and failing to discover the drives.
Update libsas to follow the libata example of pulling the pmp setting
from the ata_link and correct is_cmd to be 1 since all tf's submitted
through ->qc_issue are commands. Presumably libsas lldds do not care
about is_cmd as they have sideband mechanisms to perform link
management.
http://marc.info/?l=linux-scsi&m=138179681726990
Reported-by: Praveen Murali <pmurali@logicube.com>
Tested-by: Praveen Murali <pmurali@logicube.com>
commit 22a08538dca5c0630226f1c0c58dccd12e463d22 upstream.
This patch fixes a crash when tried setting symbolic name for an offline
vport through sysfs. Crash is due to uninitialized pointer lport->ns,
which gets initialized only on linkup (port online).
commit b4789b8e6be3151a955ade74872822f30e8cd914 upstream.
It appears that driver runs into a problem here if fibsize is too small
because we allocate user_srbcmd with fibsize size only but later we
access it until user_srbcmd->sg.count to copy it over to srbcmd.
It is not correct to test (fibsize < sizeof(*user_srbcmd)) because this
structure already includes one sg element and this is not needed for
commands without data. So, we would recommend to add the following
(instead of test for fibsize == 0).
Signed-off-by: Mahesh Rajashekhara <Mahesh.Rajashekhara@pmcs.com>
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
commit f856567b930dfcdbc3323261bf77240ccdde01f5 upstream.
In commit d496f94d22d1 ('[SCSI] aacraid: fix security weakness') we
added a check on CAP_SYS_RAWIO to the ioctl. The compat ioctls need the
check as well.
commit 10c580e4239df5c3344ca00322eca86ab2de880b upstream.
Sujit has found a race condition that would make q->nr_pending
unbalanced, it occurs as Sujit explained:
sd_probe_async() ->
add_disk() ->
disk_add_event() ->
schedule(disk_events_workfn)
sd_revalidate_disk()
blk_pm_runtime_init()
return;
Let's say the disk_events_workfn() calls sd_check_events() which tries
to send test_unit_ready() and because of sd_revalidate_disk() trying to
send another commands the test_unit_ready() might be re-queued as the
tagged command queuing is disabled.
So the race condition is -
Thread 1 | Thread 2
sd_revalidate_disk() | sd_check_events()
...nr_pending = 0 as q->dev = NULL| scsi_queue_insert()
blk_runtime_pm_init() | blk_pm_requeue_request() ->
| nr_pending = -1 since
| q->dev != NULL
The problem is, the test_unit_ready request doesn't get counted the
first time it is queued, so the later decrement of q->nr_pending in
blk_pm_requeue_request makes it unbalanced.
Fix this by calling blk_pm_runtime_init before add_disk so that all
requests initiated there will all be counted.
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Reported-and-tested-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
[ Upstream commit 21af8107f27878813d0364733c0b08813c2c192a ]
Meelis Roos reports a crash in esp_free_lun_tag() in the presense
of a disk which has died.
The issue is that when we issue an autosense command, we do so by
hijacking the original command that caused the check-condition.
When we do so we clear out the ent->tag[] array when we issue it via
find_and_prep_issuable_command(). This is so that the autosense
command is forced to be issued non-tagged.
That is problematic, because it is the value of ent->tag[] which
determines whether we issued the original scsi command as tagged
vs. non-tagged (see esp_alloc_lun_tag()).
And that, in turn, is what trips up the sanity checks in
esp_free_lun_tag(). That function needs the original ->tag[] values
in order to free up the tag slot properly.
Fix this by remembering the original command's tag values, and
having esp_alloc_lun_tag() and esp_free_lun_tag() use them.
Reported-by: Meelis Roos <mroos@linux.ee>
Tested-by: Meelis Roos <mroos@linux.ee>
commit 984f1733fcee3fbc78d47e26c5096921c5d9946a upstream.
This patch fixes an out-of-bounds error in sd_read_cache_type(), found
by Google's AddressSanitizer tool. When the loop ends, we know that
"offset" lies beyond the end of the data in the buffer, so no Caching
mode page was found. In theory it may be present, but the buffer size
is limited to 512 bytes.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit 9807b4d94911be4e4efb9a08481b24292a9edf8a upstream.
Right now the Makefile for the mpt3sas driver does not even allow the
driver to be built into the kernel. So fix that up, as there doesn't
seem to be any obvious reason why this shouldn't be done.
Acked-by: Sreekanth Reddy <Sreekanth.Reddy@lsi.com>
commit 9504a923924d663e1953f872f0a828e6454a6cfc upstream.
The IO command size is 128 bytes for these new controllers as opposed to 64
for the old 8001 controller.
The Adaptec out-of-tree driver did this correctly. After comparing the two
this turned out to be the crucial difference.
So don't hardcode the IO command size, instead use pm8001_ha->iomb_size as
that is the correct value for both old and new controllers.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Anand Kumar Santhanam <AnandKumar.Santhanam@pmcs.com>
Acked-by: Jack Wang <xjtuwjp@gmail.com>
commit f5944daa0a72316077435c18a6571e73ed338332 upstream.
We want ppc64 to be able to select between optimised assembly
checksum routines in big endian and the generic lib/checksum.c
routines in little endian.
The lpfc driver is forcing CONFIG_GENERIC_CSUM on which means
we are unable to make the decision to enable it in the arch
Kconfig. If the option exists it is always forced on.
This got introduced in 3.10 via commit 6a7252fdb0c3 ([SCSI] lpfc:
fix up Kconfig dependencies). I spoke to Randy about it and
the original issue was with CRC_T10DIF not being defined.
As such, remove the select of CONFIG_GENERIC_CSUM.
commit b497ceb964a80ebada3b9b3cea4261409039e25a upstream.
ARM cannot handle udelay for more than 2 miliseconds, so we
should use mdelay instead for those.
Acked-by: GOTO Masanori <gotom@debian.or.jp>
Cc: YOKOTA Hiroshi <yokota@netlab.is.tsukuba.ac.jp>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
commit aa52aeea2725839bdd3dcce394486e9a043065e0 upstream.
vscsi->num_queues counts the number of request virtqueue which does not
include the control and event virtqueue. It is wrong to subtract
VIRTIO_SCSI_VQ_BASE from vscsi->num_queues.
This patch fixes the following panic.
(qemu) device_del scsi0
IP: [<ffffffff8179b29f>] __virtscsi_set_affinity+0x6f/0x120
PGD 0
Oops: 0000 [#1] SMP
Modules linked in:
CPU: 0 PID: 659 Comm: kworker/0:1 Not tainted 3.11.0-rc2+ #1172
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Workqueue: kacpi_hotplug _handle_hotplug_event_func
task: ffff88007bee1cc0 ti: ffff88007bfe4000 task.ti: ffff88007bfe4000
RIP: 0010:[<ffffffff8179b29f>] [<ffffffff8179b29f>] __virtscsi_set_affinity+0x6f/0x120
RSP: 0018:ffff88007bfe5a38 EFLAGS: 00010202
RAX: 0000000000000010 RBX: ffff880077fd0d28 RCX: 0000000000000050
RDX: 0000000000000000 RSI: 0000000000000246 RDI: 0000000000000000
RBP: ffff88007bfe5a58 R08: ffff880077f6ff00 R09: 0000000000000001
R10: ffffffff8143e673 R11: 0000000000000001 R12: 0000000000000001
R13: ffff880077fd0800 R14: 0000000000000000 R15: ffff88007bf489b0
FS: 0000000000000000(0000) GS:ffff88007ea00000(0000) knlGS:0000000000000000
CR2: 0000000000000020 CR3: 0000000079f8b000 CR4: 00000000000006f0
Stack:
ffff880077fd0d28 0000000000000000 ffff880077fd0800 0000000000000008
ffff88007bfe5a78 ffffffff8179b37d ffff88007bccc800 ffff88007bccc800
ffff88007bfe5a98 ffffffff8179b3b6 ffff88007bccc800 ffff880077fd0d28
Call Trace:
[<ffffffff8179b37d>] virtscsi_set_affinity+0x2d/0x40
[<ffffffff8179b3b6>] virtscsi_remove_vqs+0x26/0x50
[<ffffffff8179c7d2>] virtscsi_remove+0x82/0xa0
[<ffffffff814cb6b2>] virtio_dev_remove+0x22/0x70
[<ffffffff8167ca49>] __device_release_driver+0x69/0xd0
[<ffffffff8167cb9d>] device_release_driver+0x2d/0x40
[<ffffffff8167bb96>] bus_remove_device+0x116/0x150
[<ffffffff81679936>] device_del+0x126/0x1e0
[<ffffffff81679a06>] device_unregister+0x16/0x30
[<ffffffff814cb889>] unregister_virtio_device+0x19/0x30
[<ffffffff814cdad6>] virtio_pci_remove+0x36/0x80
[<ffffffff81464ae7>] pci_device_remove+0x37/0x70
[<ffffffff8145edfc>] pci_stop_bus_device+0x9c/0xb0
[<ffffffff8145f036>] pci_stop_and_remove_bus_device+0x16/0x30
[<ffffffff81474a9e>] acpiphp_disable_slot+0x8e/0x150
[<ffffffff81474f6a>] hotplug_event_func+0xba/0x1a0
[<ffffffff814906c8>] ? acpi_os_release_object+0xe/0x12
[<ffffffff81475911>] _handle_hotplug_event_func+0x31/0x70
[<ffffffff810b5333>] process_one_work+0x183/0x500
[<ffffffff810b66e2>] worker_thread+0x122/0x400
[<ffffffff810b65c0>] ? manage_workers+0x2d0/0x2d0
[<ffffffff810bc5de>] kthread+0xce/0xe0
[<ffffffff810bc510>] ? kthread_freezable_should_stop+0x70/0x70
[<ffffffff81ca045c>] ret_from_fork+0x7c/0xb0
Code: 01 00 00 00 74 59 45 31 e4 83 bb c8 01 00 00 02 74 46 66 2e 0f 1f 84 00 00 00 00 00 49 63 c4 48 c1 e0 04 48 8b bc 0
3 10 02 00 00 <48> 8b 47 20 48 8b 80 d0 01 00 00 48 8b 40 50 48 85 c0 74 07 be
RIP [<ffffffff8179b29f>] __virtscsi_set_affinity+0x6f/0x120
RSP <ffff88007bfe5a38>
---[ end trace 99679331a3775f48 ]---
Signed-off-by: Asias He <asias@redhat.com>
Reviewed-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
commit 6431f5d7c6025f8b007af06ea090de308f7e6881 upstream.
Problem: When Hardware IOMMU is on, megaraid_sas driver initialization fails
in kdump kernel with LSI MegaRAID controller(device id-0x73).
Actually this issue needs fix in firmware, but for firmware running in field,
this driver fix is proposed to resolve the issue. At firmware initialization
time, if firmware does not come to ready state, driver will reset the adapter
and retry for firmware transition to ready state unconditionally(not only
executed for kdump kernel).
Signed-off-by: Sumit Saxena <sumit.saxena@lsi.com>
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com>
commit 7562523e84ddc742fe1f9db8bd76b01acca89f6b upstream.
If a device has the skip_vpd_pages flag set we should simply fail the
scsi_get_vpd_page() call.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Stuart Foster <smf.linux@ntlworld.com>
commit c3ccb1d7cf4c4549151876dd37c0944a682fd9e1 upstream.
This fixes a regression where Xyratex controllers and disks were lost by the
driver:
https://bugzilla.kernel.org/show_bug.cgi?id=59601
Reported-by: Jack Hill <jackhill@jackhill.us>
commit 085b513f97d8d799d28491239be4b451bcd8c2c5 upstream.
sd_prep_fn will allocate a larger CDB for the command via mempool_alloc
for devices using DIF type 2 protection. This CDB was being freed
in sd_done, which results in a kernel crash if the command is retried
due to a UNIT ATTENTION. This change moves the code to free the larger
CDB into sd_unprep_fn instead, which is invoked after the request is
complete.
It is no longer necessary to call scsi_print_command separately for
this case as the ->cmnd will no longer be NULL in the normal code path.
Also removed conditional test for DIF type 2 when freeing the larger
CDB because the protection_type could have been changed via sysfs while
the command was executing.
Signed-off-by: Ewan D. Milne <emilne@redhat.com>
commit 96f15f29038e58e1b0a96483e2b369ff446becf1 upstream.
This commit fixes a race condition in the isci driver abort task and SSP
device task management path. The race is caused when an I/O termination
in the SCU hardware is necessary because of an SSP target timeout condition,
and the check of the I/O end state races against the HW-termination-driven
end state. The failure of the race meant that no TMF was sent to the device
to clean-up the pending I/O.
Signed-off-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com>
Reviewed-by: Lukasz Dorau <lukasz.dorau@intel.com>
commit 7a6a731bd00ca90d0e250867c3b9c05b5ff0fa49 upstream.
commit 98cb7e44 ([SCSI] megaraid_sas: Sanity check user
supplied length before passing it to dma_alloc_coherent())
introduced a memory leak. Memory allocated for entries
following zero length SGL entries will not be freed.
Reference: http://bugs.debian.org/688198
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Acked-by: Adam Radford <aradford@gmail.com>
non LUN 0 configured expander
commit b65cfedf4560af65305bd7b3b9f26c02c6fb3660 upstream.
With some enclosures when LUN 0 is not created but LUN 1 or LUN X is created
then SCSI scan procedure calls target_alloc, slave_alloc call back functions
for LUN 0 and slave_destory() for same LUN 0.
In these kind of cases within slave_destroy, pointer to scsi_target in
_sas_device structure is set to NULL, following which when slave_alloc for LUN
1 is called then starget would not be set properly for this LUN. So,
scsi_target pointer pointing to NULL value would lead to a crash later in the
discovery procedure.
To solve this issue set the sas_device's scsi_target pointer to scsi_device's
scsi_target if it is NULL earlier in slave_alloc callback function.
Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@lsi.com>
MPI2_IOCSTATUS_CONFIG_INVALID_PAGE is not returned
commit 14be49ac965ebd3f8561d57e01ddb22f93f9b454 upstream.
Infinite loop can occur if IOCStatus is not equal to
MPI2_IOCSTATUS_CONFIG_INVALID_PAGE value in the while loops in functions
_scsih_search_responding_sas_devices,
_scsih_search_responding_raid_devices and
_scsih_search_responding_expanders
So, Instead of checking for MPI2_IOCSTATUS_CONFIG_INVALID_PAGE value,
in this patch code is modified to check for IOCStatus not equals to
MPI2_IOCSTATUS_SUCCESS to break the while loop.
commit b0df96a0068daee4f9c2189c29b9053eb6e46b17 upstream.
Missing delay is not getting set properly. The reason is that it is not
defined in the same file from where it is being invoked. The fix is to move
the missing delay module parameter from mpt2sas_base.c to mpt2sas_scsh.c.
commit 48ba2efc382f94fae16ca8ca011e5961a81ad1ea upstream.
When SCSI command is received with task attribute not set, set it to SIMPLE.
Previously it is set to untagged. This causes the firmware to fail the commands.
commit c5bebd829dd95602c15f8da8cc50fa938b5e0254 upstream.
One of the customer had reported that the set of raid logical arrays will
become unavailable (I/O offline) after a long hours of IO stress test. The OS
wouldn`t be accessible afterwards and require a hard reset.
This driver patch has a fix for race condition between the doorbell and the
circular buffer. The driver is modified to do an extra read after clearing the
doorbell in case there had been a completion posted during the small timing
window.
With this fix, we ran IO stress for ~13 days. There were no IO failures.
commit 66c28f97120e8a621afd5aa7a31c4b85c547d33d upstream.
SATA drives located behind a SAS controller would incorrectly receive
WRITE SAME commands. Tweak the heuristics so that:
- If REPORT SUPPORTED OPERATION CODES is provided we will use that to
choose between WRITE SAME(16), WRITE SAME(10) and disabled. This also
fixes an issue with the old code which would issue WRITE SAME(10)
despite the command not being whitelisted in REPORT SUPPORTED
OPERATION CODES.
- If REPORT SUPPORTED OPERATION CODES is not provided we will fall back
to WRITE SAME(10) unless the device has an ATA Information VPD page.
The assumption is that a SATL which is smart enough to implement
WRITE SAME would also provide REPORT SUPPORTED OPERATION CODES.
To facilitate the new heuristics scsi_report_opcode() has been modified
to so we can distinguish between "operation not supported" and "RSOC not
supported".
Reported-by: H. Peter Anvin <hpa@zytor.com>
Tested-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
commit 2ee3e26c673e75c05ef8b914f54fadee3d7b9c88 upstream.
Commit 39c60a0948cc '[SCSI] sd: fix array cache flushing bug causing
performance problems' added temp as a pointer to "temporary " and used
sizeof(temp) - 1 as its length. But sizeof(temp) is the size of the
pointer, not the size of the string constant. Change temp to a static
array so that sizeof() does what was intended.
commit ffc8b30866879ed9ba62bd0a86fecdbd51cd3d19 upstream.
Disk names may contain arbitrary strings, so they must not be
interpreted as format strings. It seems that only md allows arbitrary
strings to be used for disk names, but this could allow for a local
memory corruption from uid 0 into ring 0.
CVE-2013-2851
This patch fixes a critical bug that was introduced in 3.9
related to VLAN tagging FCoE frames.
3.10 fixes
fcoe_xmit was coded such that it would skip the vlan net device/layer
and instead set some vlan flags and transmit on the real net device.
The real net device has code that would add the vlan tag for fcoe skbs.
This avoids some extra processing for data frames and provides a small
performance improvement.
Since fcoe_xmit was not using the vlan net device, __vlan_put_tag
within the real net device's xmit routine was ultimately being
called to set the vlan tag.
With the below change the behavior of __vlan_put_tag changed slightly,
it now sets the skb->protocol = vlan_proto. vlan_proto was not a field
being set by fcoe_xmit, so the skb->protocol is now not being set to
ETH_P_8021Q, as it should be.
This patch converts fcoe_xmit to use the vlan_put_tag routine which
will tag the skb and fcoe will continue to transmit fcoe skbs on the
real net device.
For reference, the below change was the one that altered the
__vlan_put_tag behavior.
commit 86a9bad3ab6b6f858fd4443b48738cabbb6d094c
Author: Patrick McHardy <kaber@trash.net>
Date: Fri Apr 19 02:04:30 2013 +0000
net: vlan: add protocol argument to packet tagging functions
Add a protocol argument to the VLAN packet tagging functions. In case of HW
tagging, we need that protocol available in the ndo_start_xmit functions,
so it is stored in a new field in the skb. The new field fits into a hole
(on 64 bit) and doesn't increase the sks's size.
Signed-off-by: Robert Love <robert.w.love@intel.com>
Acked-by: John Fastabend <john.r.fastabend@intel.com>
Pull SCSI target fixes from Nicholas Bellinger:
"Included is the recent tcm_qla2xxx residual underrun length fix from
Roland, along with Joern's iscsi-target patch for session_lock
breakage within iscsit_stop_time2retain_timer() code. Both are CC'ed
to stable.
The remaining two are specific to recent iscsi-target + iser
conversion changes. One drops some left-over debug noise, and Andy's
patch fixes configfs attribute handling during an explicit network
portal feature bit disable when iser-target is unsupported."
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iscsi-target: Remove left over v3.10-rc debug printks
target/iscsi: Fix op=disable + error handling cases in np_store_iser
tcm_qla2xxx: Fix residual for underrun commands that fail
target/iscsi: don't corrupt bh_count in iscsit_stop_time2retain_timer()
When you copy some code, you are supposed to read it. If nothing else,
there's a chance to spot and fix an obvious bug instead of sharing it...
X-Song: "I Got It From Agnes", by Tom Lehrer
[ Tom Lehrer? You're dating yourself, Al ]
Suppose an initiator sends a DATA IN command with an allocation length
shorter than the FC transfer length -- we get a target message like
TARGET_CORE[qla2xxx]: Expected Transfer Length: 256 does not match SCSI CDB Length: 0 for SAM Opcode: 0x12
In that case, the target core adjusts the data_length and sets
se_cmd->residual_count for the underrun. But now suppose that command
fails and we end up in tcm_qla2xxx_queue_status() -- that function
unconditionally overwrites residual_count with the already adjusted
data_length, and the initiator will burp with a message like
qla2xxx [0000:00:06.0]-301d:0: Dropped frame(s) detected (0x100 of 0x100 bytes).
Fix this by adding on to the existing underflow residual count instead.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
Cc: Chad Dupuis <chad.dupuis@qlogic.com>
Cc: stable <stable@vger.kernel.org>
Pull scsi target fixes from Nicholas Bellinger:
"The highlights include:
- Re-instate sess->wait_list in target_wait_for_sess_cmds() for
active I/O shutdown handling in fabrics using se_cmd->cmd_kref
- Make ib_srpt call target_sess_cmd_list_set_waiting() during session
shutdown
- Fix FILEIO off-by-one READ_CAPACITY bug for !S_ISBLK export
- Fix iscsi-target login error heap buffer overflow (Kees)
- Fix iscsi-target active I/O shutdown handling regression in
v3.10-rc1
A big thanks to Kees Cook for fixing a long standing login error
buffer overflow bug.
All patches are CC'ed to stable with the exception of the v3.10-rc1
specific regression + other minor target cleanup."
iscsi-target: Fix iscsit_free_cmd() se_cmd->cmd_kref shutdown handling
target: Propigate up ->cmd_kref put return via transport_generic_free_cmd
iscsi-target: fix heap buffer overflow on error
target/file: Fix off-by-one READ_CAPACITY bug for !S_ISBLK export
ib_srpt: Call target_sess_cmd_list_set_waiting during shutdown_session
target: Re-instate sess_wait_list for target_wait_for_sess_cmds
target: Remove unused wait_for_tasks bit in target_wait_for_sess_cmds
That patch failed to set proc_scsi_fops' .release method.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
