path: root/drivers/regulator
2014-06-23regulator: as3722: adjust enable_time for regulatorsBibek Basu
According to measurement done, LDOs take a maximum of 100us to reach it max desired value.Thus this patch adjusts the default enable time for as3722 regulators Bug 1481647 Change-Id: Ia610e0a11f1001fdf76b2860b6e2b3d6ed0a1b1a Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/422152 (cherry picked from commit 21e2115f4021ec02a37e6ce03e14232306c633a9) Reviewed-on: http://git-master/r/423674 GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-06-10Merge commit 'refs/changes/82/419382/1' of ssh://git-master:12001/linux-3.10 ↵Mandar padmawar
into promotion_build Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
2014-06-05regulator: palams: add support for disabling pulldown of LDOsLaxman Dewangan
Add support for disabling pull down of the LDOs. this is configurable from platforms. bug 1494740 Change-Id: I8c3e02f36b3045fa25a8c881a10c686ab9c63967 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/418246 (cherry picked from commit 0894c40230017f0fbb0f463a0c5027738b1d2b1f) Reviewed-on: http://git-master/r/419339 Tested-by: Venkat Reddy Talla <vreddytalla@nvidia.com>
2014-06-05regulator: core: add support for disabling parent after enabling rail.Laxman Dewangan
Add support on core driver of regulator to disable parent once the regulator enable. This is needed for some specific purpose to handle overcurrent on parent rail due to enabling the rail. bug 1494740 Change-Id: I95084243975ca5298abbaa23a31007413bdca7a9 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/418143 (cherry picked from commit a65d4377c02067d8b6105c7fcd1931e20d9e8995) Reviewed-on: http://git-master/r/419335 Tested-by: Venkat Reddy Talla <vreddytalla@nvidia.com>
2014-06-05Merge branch 'linux-3.10.40' into rel-21Ishan Mittal
Bug 200004122 Conflicts: drivers/cpufreq/cpufreq.c drivers/regulator/core.c sound/soc/codecs/max98090.c Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-06-03regulator: as3722: add enable_time for regulatorsBibek Basu
Add enable time of sd2/3,sd4,sd5 regulator Bug 1481642 Change-Id: I73e8ff5c34e9db9f13a181e01a268c740ccfb410 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/409334 (cherry picked from commit 747aca06bdf06ea746cbf20fc39ff8f8204e6558) Reviewed-on: http://git-master/r/417651 Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com> Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
2014-05-28regulator: palams: disallow pmic access post shutdownSang-Hun Lee
- Once shutdown has been called against pmic, i2c bus is shutdown, so pmic cannot enable or disable regulators - As such, once shutdown has been called, reject regulator enable/disable calls Bug 1510778 Change-Id: I6eb26d4846ed5c51f882761568c1f9152a0ebb24 Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com> Reviewed-on: http://git-master/r/411684 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-05-08regulator: palams: implement active discharge configuration for idleLaxman Dewangan
Add support for disable active discharge configuration on idle state from platfrom configuration. The active disachrge will be active on suspend and shutdown. bug 1454238 Change-Id: Id22c446ef2ba4ac7db0daf5973bb56cad5e9c94c Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/406340 GVS: Gerrit_Virtual_Submit
2014-05-01regulator: palmas: Update SMPS ramp delayJinyoung Park
Updated SMPS ramp delay calculation. Bug 1446910 Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com> Reviewed-on: http://git-master/r/398133 (cherry picked from commit b38d41b8dfbb0f2a5c12b361466c19b15ac5f595) Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com> Reviewed-on: http://git-master/r/401294 (cherry picked from commit 47ffaea712692bc37d72a286e3fb0b0f6042ef45) Change-Id: If0b132724b6afe3986252bf886d1f15dbf1bb18f Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com> Reviewed-on: http://git-master/r/403572 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-04-10regulator: pwm: add support for setting voltage time selLaxman Dewangan
The pwm voltage ramp for each level is not linear in nature sometimes and it can be exponential. In this case, the voltage ramp time which is independent of amount of voltage levels need to be provided to calculate the proper ramp time. Change-Id: Idfa17b3bc0a565e66104091090f4fcdb32882be5 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/393889
2014-04-09regulator: core: print ramp delay when printing constraintsLaxman Dewangan
Print ramp delay when printing constraints of the regulator to provide more information on log. Change-Id: Iaef993a33754b7579598adb04209ab9bd6426cac Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/394049
2014-04-09regulator: palmas: prints ramp delay applied for railsLaxman Dewangan
Prints the ramp delay applied for rails voltage switching to help on debugging/analysing the issue. Change-Id: I1d6ac52d1c4c3712c5655df55f7b2253459a188d Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/394048
2014-04-08regulator: add support to scale ramp delayLaxman Dewangan
There is possibilty on a given platform where the ramp delay for rail can difer from datsheet due to baord design and it need to scale for more delay like 2x or 1.5x or 1.25x etc. Add support for scaling the ramp delay in core. Change-Id: I3e0d6f89225f5bb4ffc387f87087688d15f29907 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/393504 GVS: Gerrit_Virtual_Submit
2014-03-31regulator: core: Replace direct ops->disable usageMarkus Pargmann
commit 66fda75f47dc583f1c187556e9a2c082dd64f8c6 upstream. There are many places where ops->disable is called directly. Instead we should use _regulator_do_disable() which also handles gpio regulators. To be able to use the wrapper function from _regulator_force_disable(), I moved the _notifier_call_chain() call from _regulator_do_disable() to _regulator_disable(). This way, _regulator_force_disable() can use different flags for _notifier_call_chain() without calling it twice. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-27regulator: as3722: increase max current limitBibek Basu
Increase max ov current limit to 4A.Actual limit will come from Device tree based on the configuration of PMIC on board Bug 1488211 Change-Id: I9dac0d4c83c077684b1eed23089d986ddc2484e2 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/387636 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-03-23regulator: core: Replace direct ops->enable usageMarkus Pargmann
commit 30c219710358c5cca2f8bd2e9e547c6aadf7cf8b upstream. There are some direct ops->enable in the regulator core driver. This is a potential issue as the function _regulator_do_enable() handles gpio regulators and the normal ops->enable calls. These gpio regulators are simply ignored when ops->enable is called directly. One possible bug is that boot-on and always-on gpio regulators are not enabled on registration. This patch replaces all ops->enable calls by _regulator_do_enable. [Handle missing enable operations -- broonie] Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23regulator: add support to disable regualtor consumer node from DTLaxman Dewangan
Sometimes it is require to disable consumer list for some of the board configuration from top level DTS file when using the common power tree file across different boards/configuration. Add support to have status property in the condumer node to ignore the consumer supply from DT. Change-Id: I1a42a1feaf0ae816833d43dffd1b1da29eb09d33 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/385002
2014-03-21regulator: use correct data typeMallikarjun Kasoju
Bug 1466403 Change-Id: If9f1ea244989b82c042fa05f21587635cf457530 Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com> Reviewed-on: http://git-master/r/382007 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-03-17regulator: add support to get initial voltage from DTLaxman Dewangan
Add support to get initial voltage from DT as part of regulator constraints. Change-Id: Idc4593efbd7b2fe2fb01289687e92ba38f1067e6 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/382070 GVS: Gerrit_Virtual_Submit
2014-03-12regulator: as3722: set minimum voltage based on device versionLaxman Dewangan
Support the AS3722 otp version 1V2 and later. Set the SD0 minimum voltage based on OTP version as 610mV for 1V0 and 1V1 else 410mV. bug 1435338 Change-Id: Ieb9c21cb5b6f0126ac27325a5b14403445c94ccb Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/379902 Reviewed-by: Bibek Basu <bbasu@nvidia.com> Tested-by: Bibek Basu <bbasu@nvidia.com>
2014-02-24regulator: DFLL bypass: Add Tegra13 PWM compatibilityAlex Frid
Added DFLL bypass driver compatibility with DFLL PWM in Tegra132 SoC. Bug 1442709 Change-Id: I4b2b4a2c6e969051b0aa695446205d6fbc2eab5c Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/373258 Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2014-02-18mfd: as3722 Update VSEL access controlAlex Frid
- Added an option to mark VSEL registers as volatile by default. This option should be set either in board platform data, or in device tree node of the regulator controlled by hardware mechanism underneath s/w driver. - Replaced volatile registers table with callback that checks access attribute at run-time. Added another callback to switch VSEL registers attributes between volatile and cached. - Set persistent property for VSEL of all SD regulators (persistent value is zero). This would allow to use direct write for setting the voltage selector instead of read-modify-write. Bug 1454969 Change-Id: I9a434fa8568dc2717a81ae6ecf3891abb903befa Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/367357 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-02-16regulator: tps51632 Add VSEL access attribute callbackAlex Frid
Added callback to set voltage selector registers access attribute as volatile or cached. Bug 1454969 Change-Id: If246f7fe8d35cb99f28f1c07f4653646a141287b Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/367562 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-02-14regulator: Add VSEL attribute callback to DFLL bypassAlex Frid
Added callback to set DFLL bypass voltage selector registers access attribute as volatile (cached access is not supported). Bug 1454969 Change-Id: I3800f72bd6196a54bc3b34b71a274fa344c2f0f5 Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/367356 Reviewed-by: Seshendra Gadagottu <sgadagottu@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2014-02-13regulator: Add interface to change VSEL volatile attributeAlex Frid
Defined regulator device driver callback to specify access attribute for the voltage selector register as either volatile or cached. Implemented the respective public interface that uses the callback if it is present, or updates regmap cache layer if the VSEL access is based on regmap framework. Bug 1454969 Change-Id: I2bb955d1c67d480ec20fdd783e37fd576fb88313 Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/365705 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-02-10regulator: palmas: Specify VSEL persistent valueAlex Frid
Populated vsel_persist fields for Palmas VSEL register if it is marked as volatile on the particular platform. This would allow to use direct write for setting the register instead of read-modify-write. Bug 1454969 Change-Id: I07f973b3d79f452be8280e0ee0e7ea170f80435f Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/364698 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-02-10regulator: Optimize set voltage for regmap usersAlex Frid
If regulator voltage selection register includes bits other than selector itself, it is pretty common to program those bits once, and keep them unchanged after initialization. In this case value of the entire VSEL register can be constructed by combining persistent and variable selector bits, and then directly written to the register without extra read access required for read-modify-write update. This commit has added persistency fields to the regulator descriptor. If VSEL is persistent, regulator_set_voltage_sel_regmap() interface calls regmap_write() instead of regmap_update_bits(). As a result for volatile VSEL register number of bytes transferred over the regmap bus is reduced at least by 50% (commonly read transaction is longer than its write counterpart). No significant saving for cached VSEL register. If any non-selector bit is not persistent, VSEL persistency fields must be cleared. Bug 1454969 Change-Id: Ib37d661f8929984ea642b8983c1fad84f61360b4 Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/364697 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-02-07mfd: palmas: Add SMPS VSEL volatile optionAlex Frid
Currently all Palmas SMPS regulators voltage selection registers are always cached. Added a regulator configuration flag to mark volatile VSEL register. This flag can be set either in board platform data or in device tree node for the regulator that is controlled by hardware mechanism underneath s/w driver. Change-Id: I733de6e2e9d42bbcc2359f033bfb8ddccdaf7202 Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/363635 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> GVS: Gerrit_Virtual_Submit
2014-01-31regulator: Add regulator_can_set_mode() interfaceAlex Frid
Added a regulator_can_set_mode() interface so that the drivers are able to differentiate between no support for mode control and set mode interface failures. Change-Id: I4c1715ad2580ac97fb4d8eff964cda8edfec21de Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/362272 Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2014-01-31regulator: Parse DT in DFLL bypass regulator probeAlex Frid
Added parsing of pwm regulator data in DFLL bypass driver probe. Implementation is backward compatible with the specification of DFLL bypass platform data in board files - if the latter is present, DT data is ignored. Bug 1442709 Change-Id: I8127d5804ad3b10d9ae529885babf85e4d3ee2c1 Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/361880 GVS: Gerrit_Virtual_Submit Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2014-01-30regulator: core: set min/max constraint with configured voltageLaxman Dewangan
If min/max voltage of rail is not provided through constraints then set this with the already configured voltage. The motivation is that, if PMIC default is require rail voltage and do not want to change this voltage then it is not require to pass the min/max through constraints to avoid mis-configuration of rail voltage. In this case, update the min/max voltage on constraints by reading the rail voltage from device directly. Change-Id: I82befa7ee1fc466569512ad4382246444d0bbb29 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/362009
2014-01-30regulator: pwm: Separate defer message from failAlex Frid
Change-Id: I52c3b694d787318677bb250a607eb2aebd99ba6b Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/361857 Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2014-01-29regulator: pwm: add support for enable and mode gpioLaxman Dewangan
Add supports for: - enable gpio which enable/disable the regulator. - idle gpio which is require to set the regulator mode. Change-Id: I9b31514542462bf2a3dd024cf799fbbe18ef86f4 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/361549
2014-01-29regulator: Move DFLL bypass regulator driver initAlex Frid
DFLL bypass regulator suppplies fixed volatge initially, until DFLL is up. For consistency with other fixed regulators initialized DFLL bypass driver in subsys_initcall_sync (instead of postcore_initcall). Bug 1442709 Change-Id: I9a3004b52bd82fe381259757d235f813af983e09 Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/358585 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2014-01-29regulator: Move checks for DFLL bypass callbacksAlex Frid
Moved checking for bypass callbacks initialization from DFLL bypass regulator probe to the get/set voltage interfaces entry. If callbacks are not installed get_voltage interface returns initial fixed voltage, and set_voltage succeeds only when requested voltage is the same as initial one. Bug 1442709 Change-Id: Ia5239a3e19d7dc34d68394b3717fc7ff28860248 Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/358584 Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2014-01-29regulator: Change DFLL bypass voltage interfacesAlex Frid
Switched DFLL bypass regulator from set_voltage_sel/get_voltage_sel interfaces to set_voltage/get_voltage. This is done to avoid usage of stale selector value by regulator framework in set_voltage interface, since DFLL in closed loop mode changes voltage underneath regulator driver. Bug 1442709 Change-Id: I56f119399aeedfc794ebdbae65c91812179b74d4 Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/358583 Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2014-01-29regulator: add pwm based regulatorLaxman Dewangan
Add regulator driver which is controlled by the PWM signals. Change-Id: I6ecfda60747556eb10b1ab0740d940a3a1ba11ae Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/360434 GVS: Gerrit_Virtual_Submit
2014-01-27regulator: as3722: do not disable tracking on suspendLaxman Dewangan
If any regulator is enabled for tracking then it is not require to disable tracking before sleep as HW already take care of properly controlling the output voltage. Change-Id: Id3d45cabd1ae0f49eebe3f6b577bd39fdd5a7b7b Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/358754 GVS: Gerrit_Virtual_Submit
2014-01-27regulator: core: support for state change from sysfs for gpio regulatorsLaxman Dewangan
Add support to enable/disable from sysfs for gpio based fixed regulators. bug 1436543 Change-Id: Ic7d1d9fa73b40b1db8f7f824d4bb53624fae00dc Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/358749 GVS: Gerrit_Virtual_Submit Reviewed-by: Pankaj Dabade <pdabade@nvidia.com> Tested-by: Pankaj Dabade <pdabade@nvidia.com>
2014-01-23regulator: core: add support to ignore current constraint config on initLaxman Dewangan
Add provision to ignore the current constraint conifguration during regulator registration. This will provide opion to avoid configuration of maximum current when it is not require like from charger regulators. Change-Id: I7ec70db2c0660fbe8e57892d5474bafbb8c022ef Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/358766 GVS: Gerrit_Virtual_Submit
2014-01-19regulator: core: make warning as infoBibek Basu
Make warning as info for consumer device name not present message Bug 1423355 Change-Id: Ib31d0f10102c3e88f99d4b105ca3a77a55db73b1 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/357116 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-01-17regulator: as3722: dt support for tracking_suspendBibek Basu
add dt entry for disabling_tracking_suspend Bug 1423355 Change-Id: Ib9e253ba70b1ad8b652366dc517fe0c7f5a5fa06 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/356309 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-01-15regulator: max15569: Fix bug in driver initAshwin Joshi
Set base voltage only if it is passed for the board, else let the regulator be set at whatever voltage it was before. Bug 1410210 Change-Id: I09730afad4b11e99e60f45138e78871bf22746d1 Signed-off-by: Ashwin Joshi <asjoshi@nvidia.com> Reviewed-on: http://git-master/r/352689 Reviewed-by: Sumeet Gupta <sumeetg@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
2013-12-20regulator: core: prints error message when regulator_get() failedLaxman Dewangan
To help on debugging, prints the device name and id with error when regulator get failed. Change-Id: I4afa5ab4120c058fc77f7baf229866d6b3fbceed Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/347502
2013-12-18regulator: as3722 : SD0 init val based on boardidPrabhu Kuttiyam
Decide the PMIC version based on board id as AMS PMIC rev id is not correct in silicon. Add DT support also. Bug 1425474 Change-Id: Ia51462980da582c958a26e156b48a1e5d655559f Signed-off-by: Prabhu Kuttiyam <pkuttiyam@nvidia.com> Reviewed-on: http://git-master/r/347241 Reviewed-by: Bibek Basu <bbasu@nvidia.com> Tested-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-12-17regulator: Fix voltage level change notificationAlex Frid
- Do not sent pre-/post- change notification in case selector is equal to old_selector, and regulator control interface is not called - Pass voltage value (not selector) to post-change notification to be consistent with pre-change notification. Change-Id: I8fe6ee149f8f34f1818abf0b1cbcbd9c437cab7f Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/345608 GVS: Gerrit_Virtual_Submit Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2013-12-10regulator: as3722: set the correct current limitVince Hsu
[Resubmitting as it was reverted due to intermittent issue on GVS] Change-Id: I324d8b6a0c68a1d58458a0ce3a819453a6c86343 Signed-off-by: Vince Hsu <vinceh@nvidia.com> Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/340288 GVS: Gerrit_Virtual_Submit
2013-11-29Revert "regulator: as3722: set the correct current limit"Hiroshi Doyu
This reverts commit 3dee4d31723e7ecf44014ef4f96294b1ff3b4600.
2013-11-29regulator: as3722: set the correct current limitVince Hsu
Change-Id: I443987c8fc7c840d16bebf3bd24783bc51bab5be Signed-off-by: Vince Hsu <vinceh@nvidia.com> Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/336651
2013-11-29regulator: palmas: Set smps enable delay to 600usTerje Bergstrom
Enable time of 275us is not enough for all cases. Bump it to 600us. Bug 1404859 Change-Id: I786e7c80b2fce123346c2c88a01de3ca54728ca9 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/336129 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User
