commit f2c4db1bd80720cd8cb2a5aa220d9bc9f374f04e upstream.
Going primarily by:
https://en.wikipedia.org/wiki/List_of_Intel_Atom_microprocessors
with additional information gleaned from other related pages; notably:
- Bonnell shrink was called Saltwell
- Moorefield is the Merriefield refresh which makes it Airmont
The general naming scheme is: FAM6_ATOM_UARCH_SOCTYPE
for i in `git grep -l FAM6_ATOM` ; do
sed -i -e 's/ATOM_PINEVIEW/ATOM_BONNELL/g' \
-e 's/ATOM_LINCROFT/ATOM_BONNELL_MID/' \
-e 's/ATOM_PENWELL/ATOM_SALTWELL_MID/g' \
-e 's/ATOM_CLOVERVIEW/ATOM_SALTWELL_TABLET/g' \
-e 's/ATOM_CEDARVIEW/ATOM_SALTWELL/g' \
-e 's/ATOM_SILVERMONT1/ATOM_SILVERMONT/g' \
-e 's/ATOM_SILVERMONT2/ATOM_SILVERMONT_X/g' \
-e 's/ATOM_MERRIFIELD/ATOM_SILVERMONT_MID/g' \
-e 's/ATOM_MOOREFIELD/ATOM_AIRMONT_MID/g' \
-e 's/ATOM_DENVERTON/ATOM_GOLDMONT_X/g' \
-e 's/ATOM_GEMINI_LAKE/ATOM_GOLDMONT_PLUS/g' ${i}
done
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: dave.hansen@linux.intel.com
Cc: len.brown@intel.com
[bwh: Backported to 4.9:
- Drop changes to CPU IDs that weren't already included
- Adjust context]
[ Upstream commit 216c4e9db4c9d1d2a382b42880442dc632cd47d9 ]
In the current code we accidentally return the successful result from
idr_alloc() instead of a negative error pointer. The caller is looking
for an error pointer and so it treats the returned value as a valid
pointer.
This one might be a bit serious because if it lets people get around the
kernel's protection for remapping NULL. I'm not sure.
Fixes: 75d2364ea0ca (PowerCap: Add class driver)
Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
commit cb43f81b8489dcb87555e16c17453f0a9fa690f2 upstream.
Commit e1399ba20eee ("powercap / RAPL: handle missing MSRs") added
contraint_to_pl() function to return index into an array. But it
can potentially return -EINVAL if powercap layer sends an out of
range constraint ID. This patch adds sanity check.
Unnecessary RAPL domain pointer check is removed since it must be
initialized before calling rapl_unit_xlate().
Fixes: e1399ba20eee ("powercap / RAPL: handle missing MSRs")
Reported-by: Odzioba, Lukasz <lukasz.odzioba@intel.com>
Reported-by: Koss, Marcin <marcin.koss@intel.com>
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Merrifield2 is actually Moorefield.
Rename it accordingly and drop tail digit from Merrifield1.
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Link: http://lkml.kernel.org/r/20160906184254.94440-1-andriy.shevchenko@linux.intel.com
It's confirmed that RAPL works as expected on Ivy Bridge servers.
Tested against processor: Intel(R) Xeon(R) CPU E5-2697 v2 @2.70GHz
Signed-off-by: Xiaolong Wang <xiaolong.wang@linux.intel.com>
Denverton micro server is Atom-based, but its RAPL interface
is compatible with Core-based CPUs.
Some RAPL MSRs may not exist on some CPUs, we need to continue
the topology detection and enumerate what is available.
This patch handles the missing MSRs, then reports to the powercap
layer only the features available.
Since the RAPL interface is not architectual, its enumeration depends
on poking MSRs instead of using the CPUID method.
In KVM guests, the RAPL driver probe will fail and emit the following
message for every CPU: "no valid rapl domains found in package"
This patch converts the warning to a debug message only (still return
-ENODEV so that RAPL does not run in KVM guests).
[ rjw: Subject & changelog ]
SKX uses similar RAPL interface as Broadwell server according to
Jacob Pan.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Jacob Pan <jacob.jun.pan@linux.intel.com>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: jacob.jun.pan@intel.com
Cc: linux-pm@vger.kernel.org
Link: http://lkml.kernel.org/r/20160603001955.38E1E684@viggo.jf.intel.com
Let's make an effort to group these things by microarchitecture
name. It makes it easier to see if something got missed.
Acked-by: Rafael J. Wysocki <rjw@rjwysocki.net>
Link: http://lkml.kernel.org/r/20160603001937.B53A383A@viggo.jf.intel.com
Use the new macros to remove another large set of open-coded values.
Link: http://lkml.kernel.org/r/20160603001936.F474F9D8@viggo.jf.intel.com
Pull power management updates from Rafael Wysocki:
"The majority of changes go into the cpufreq subsystem this time.
To me, quite obviously, the biggest ticket item is the new "schedutil"
governor. Interestingly enough, it's the first new cpufreq governor
since the beginning of the git era (except for some out-of-the-tree
ones).
There are two main differences between it and the existing governors.
First, it uses the information provided by the scheduler directly for
making its decisions, so it doesn't have to track anything by itself.
Second, it can invoke drivers (supporting that feature) to adjust CPU
performance right away without having to spawn work items to be
executed in process context or similar. Currently, the acpi-cpufreq
driver is the only one supporting that mode of operation, but then it
is used on a large number of systems.
The "schedutil" governor as included here is very simple and mostly
regarded as a foundation for future work on the integration of the
scheduler with CPU power management (in fact, there is work in
progress on top of it already). Nevertheless it works and the
preliminary results obtained with it are encouraging.
There also is some consolidation of CPU frequency management for ARM
platforms that can add their machine IDs the the new stub dt-platdev
driver now and that will take care of creating the requisite platform
device for cpufreq-dt, so it is not necessary to do that in platform
code any more. Several ARM platforms are switched over to using this
generic mechanism.
In addition to that, the intel_pstate driver is now going to respect
CPU frequency limits set by the platform firmware (or a BMC) and
provided via the ACPI _PPC object.
The devfreq subsystem is getting a new "passive" governor for SoCs
subsystems that will depend on somebody else to manage their voltage
rails and its support for Samsung Exynos SoCs is consolidated.
The rest is support for new hardware (Intel Broxton support in
intel_idle for one example), bug fixes, optimizations and cleanups in
a number of places.
Specifics:
- New cpufreq "schedutil" governor (making decisions based on CPU
utilization information provided by the scheduler and capable of
switching CPU frequencies right away if the underlying driver
supports that) and support for fast frequency switching in the
acpi-cpufreq driver (Rafael Wysocki)
- Consolidation of CPU frequency management on ARM platforms allowing
them to get rid of some platform-specific boilerplate code if they
are going to use the cpufreq-dt driver (Viresh Kumar, Finley Xiao,
Marc Gonzalez)
- Support for ACPI _PPC and CPU frequency limits in the intel_pstate
driver (Srinivas Pandruvada)
- Fixes and cleanups in the cpufreq core and generic governor code
(Rafael Wysocki, Sai Gurrappadi)
- intel_pstate driver optimizations and cleanups (Rafael Wysocki,
Philippe Longepe, Chen Yu, Joe Perches)
- cpufreq powernv driver fixes and cleanups (Akshay Adiga, Shilpasri
Bhat)
- cpufreq qoriq driver fixes and cleanups (Jia Hongtao)
- ACPI cpufreq driver cleanups (Viresh Kumar)
- Assorted cpufreq driver updates (Ashwin Chaugule, Geliang Tang,
Javier Martinez Canillas, Paul Gortmaker, Sudeep Holla)
- Assorted cpufreq fixes and cleanups (Joe Perches, Arnd Bergmann)
- Fixes and cleanups in the OPP (Operating Performance Points)
framework, mostly related to OPP sharing, and reorganization of
OF-dependent code in it (Viresh Kumar, Arnd Bergmann, Sudeep Holla)
- New "passive" governor for devfreq (for SoC subsystems that will
rely on someone else for the management of their power resources)
and consolidation of devfreq support for Exynos platforms, coding
style and typo fixes for devfreq (Chanwoo Choi, MyungJoo Ham)
- PM core fixes and cleanups, mostly to make it work better with the
generic power domains (genpd) framework, and updates for that
framework (Ulf Hansson, Thierry Reding, Colin Ian King)
- Intel Broxton support for the intel_idle driver (Len Brown)
- cpuidle core optimization and fix (Daniel Lezcano, Dave Gerlach)
- ARM cpuidle cleanups (Jisheng Zhang)
- Intel Kabylake support for the RAPL power capping driver (Jacob
Pan)
- AVS (Adaptive Voltage Switching) rockchip-io driver update (Heiko
Stuebner)
- Updates for the cpupower tool (Arjun Sreedharan, Colin Ian King,
Mattia Dongili, Thomas Renninger)"
* tag 'pm-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (112 commits)
intel_pstate: Clean up get_target_pstate_use_performance()
intel_pstate: Use sample.core_avg_perf in get_avg_pstate()
intel_pstate: Clarify average performance computation
intel_pstate: Avoid unnecessary synchronize_sched() during initialization
cpufreq: schedutil: Make default depend on CONFIG_SMP
cpufreq: powernv: del_timer_sync when global and local pstate are equal
cpufreq: powernv: Move smp_call_function_any() out of irq safe block
intel_pstate: Clean up intel_pstate_get()
cpufreq: schedutil: Make it depend on CONFIG_SMP
cpufreq: governor: Fix handling of special cases in dbs_update()
PM / OPP: Move CONFIG_OF dependent code in a separate file
cpufreq: intel_pstate: Ignore _PPC processing under HWP
cpufreq: arm_big_little: use generic OPP functions for {init, free}_opp_table
PM / OPP: add non-OF versions of dev_pm_opp_{cpumask_, }remove_table
cpufreq: tango: Use generic platdev driver
PM / OPP: pass cpumask by reference
cpufreq: Fix GOV_LIMITS handling for the userspace governor
cpupower: fix potential memory leak
PM / devfreq: style/typo fixes
PM / devfreq: exynos: Add the detailed correlation for Exynos5422 bus
Skylake processor supports a new set of RAPL registers for controlling
entire SoC instead of just CPU package. This is useful for thermal
and power control when source of power/thermal is not just CPU/GPU.
This change adds a new platform domain (AKA PSys) to the current
power capping Intel RAPL driver.
PSys also supports PL1 (long term) and PL2 (short term) control like
package domain. This also follows same MSRs for energy and time
units as package domain.
Unlike package domain, PSys support requires more than just processor
level implementation. The other parts in the system need additional
implementation, which OEMs needs to support. So not all Skylake
systems will support PSys.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: bp@alien8.de
Cc: hpa@zytor.com
Cc: jacob.jun.pan@linux.intel.com
Cc: rjw@rjwysocki.net
Link: http://lkml.kernel.org/r/1460930581-29748-3-git-send-email-srinivas.pandruvada@linux.intel.com
Kabylake is similar to Skylake in terms of RAPL.
Added missing model 0x46.
Tested-and-reported-by: Piotr Maksymiuk <piotr.maksymiuk@movishell.pl>
RAPL driver operates on MSRs that are under package/socket
scope instead of core scope. However, the current code does not
keep track of which CPUs are available on each package for MSR
access. Therefore it has to search for an active CPU on a given
package each time.
This patch optimizes the package level operations by tracking a
per package lead CPU during initialization and CPU hotplug. The
runtime search for active CPU is avoided.
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
This patch adds to each rapl domain a reference of the package
it belongs to. At runtime, we can then avoid searching the package
data for each access. It simplifies the domain level operations
which depend on package level information.
Reduce remote CPU calls for MSR access by combining read
modify write into one function.
Suggested-by: Peter Zijlstra <peterz@infradead.org>
* powercap:
powercap: constify powercap_zone_ops and powercap_zone_constraint_ops structures
* acpi-soc:
PM / clk: don't leave clocks enabled when driver not bound
i2c: dw: Add APM X-Gene ACPI I2C device support
ACPI / APD: Add APM X-Gene ACPI I2C device support
ACPI / LPSS: change 'does not have' to 'has' in comment
Revert "dmaengine: dw: platform: provide platform data for Intel"
dmaengine: dw: return immediately from IRQ when DMA isn't in use
dmaengine: dw: platform: power on device on shutdown
ACPI / LPSS: override power state for LPSS DMA device
ACPI / LPSS: power on when probe() and otherwise when remove()
ACPI / LPSS: do delay for all LPSS devices when D3->D0
ACPI / LPSS: allow to use specific PM domain during ->probe()
Revert "ACPI / LPSS: allow to use specific PM domain during ->probe()"
device core: add BUS_NOTIFY_DRIVER_NOT_BOUND notification
x86/platform/iosf_mbi: Remove duplicate definitions
drivers/i2c/busses/i2c-designware-platdrv.c
The powercap_zone_ops and powercap_zone_constraint_ops structures are never
modified, so declare them as const.
Most of the actual changes adjust indentation to accomodate the const
keyword.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Intel RAPL initialized on several systems where the BIOS lock bit (msr
0x610, bit 63) was set. This occured because the return value of
rapl_read_data_raw() was being checked, rather than the value of the variable
passed in, locked.
This patch properly implments the rapl_read_data_raw() call to check the
variable locked, and now the Intel RAPL driver outputs the warning:
intel_rapl: RAPL package 0 domain package locked by BIOS
and does not initialize for the package.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Acked-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Cc: All applicable <stable@vger.kernel.org>
The read and write opcodes are global for all units on SoC and even across
Intel SoCs. Remove duplication of corresponding constants. At the same time
convert all current users.
No functional change.
Acked-by: Boon Leong Ong <boon.leong.ong@intel.com>
Broxton CPU ID for the RAPL driver.
Signed-off-by: Amy Wiles <amy.l.wiles@intel.com>
[ rjw: Subject and changelog. ]
Let rapl_unregister_powercap() disable the second power limit
only if it exists.
Intel64 SDM Vol.3 14.9 says that the package domain has it
but neither the power plane domain nor the DRAM domain has it.
Signed-off-by: Seiichi Ikarashi <s.ikarashi@jp.fujitsu.com>
This patch enabled RAPL to support Broadwell-H
Signed-off-by: Radivoje Jovanovic <radivoje.jovanovic@intel.com>
This patche enabled RAPL to support Intel Skylake H/S
This patch enables intel_rapl driver to run on the
next-generation Intel(R) Xeon Phi Microarchitecture
code named "Knights Landing"
Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com>
CPU Floor frequency is set in BIOS for newer Atom
SoCs. This patch handles configuration of floor
frequency for different variants of Atom SoCs
appropriately and ensures configuration of floor
frequency is not done from driver for these
newer Atom SoCs.
Since address of the register for configuring
floor frequency might change for different
Atom SoCs, this patch also prevents potential
overwriting of wrong registers.
Reviewed-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Signed-off-by: Ajay Thomas <ajay.thomas.david.rajamanickam@intel.com>
Signed-off-by: Brian Bian <brian.bian@intel.com>
The RAPL ids are only tested in rapl_init() which is itself an __init
function. For the MODULE_DEVICE_TABLE() file2alias doesn't care about
the section, just about the symbol name. Therefore it's safe to mark the
rapl_ids[] array as __initconst so its memory can be released after
initialization is done.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Validated RAPL functions on this platform. Add support to driver.
The current driver assumes all RAPL domains within a CPU package
have the same energy unit. This is no longer true for HSW server
CPUs since DRAM domain has is own fixed energy unit which can be
different than the package energy unit enumerated by package
power MSR. In fact, the default HSW EP package power unit is 61uJ
whereas DRAM domain unit is 15.3uJ. The result is that DRAM power
consumption is counted 4x more than real power reported by energy
counters, similarly for max_energy_range_uj of DRAM domain.
This patch adds domain specific energy unit per cpu type, it allows
domain energy unit to override package energy unit if non zero.
Please see this document for details.
"Intel Xeon Processor E5-1600 and E5-2600 v3 Product Families, Volume 2 of 2.
Datasheet, September 2014, Reference Number: 330784-001 "
Cc: 3.10+ <stable@vger.kernel.org> # 3.10+
Enable RAPL driver on Xeon cpu id 0x56.
RAPL on Atom depends on IOSF_MBI driver for setting
floor frequency. This patch adds explicit dependency on
CONFIG_IOSF_MB.
RAPL implementation on Atom has made some changes that are not compatible
with Core CPUs. Specifically, it is different in the way units are computed
as well as floor frequency is enforced.
This patch uses the per CPU model functions to handle the differences. Intel
Software Developers' Manual has also been updated to reflect the changes in
Table 35-7 V3C.
RAPL implementations may vary slightly between Core and Atom CPUs. There are
also potential differences among generations of CPUs within the family.
This patch adds a per model structure to abstract the differences such that
variations can be handled cleanly.
Many CPUs do not support complete set of RAPL domains, as a
result this detection failed message is very misleading and
can be annoying.
[ 5.082632] intel_rapl: RAPL domain core detection failed
[ 5.088370] intel_rapl: RAPL domain uncore detection failed
So lower the warning message to info and only print out the RAPL
domains that are supported.
I've confirmed that monitoring the package power usage as well as setting power
limits appear to be working as expected. Supports the package and dram domains.
Tested aginst cpu:
Intel(R) Xeon(R) CPU E5-2650 v3 @ 2.30GHz
Signed-off-by: Jason Baron <jbaron@akamai.com>
Add support for Broadwell model 0x3d and Haswell model (0x3c).
Energy counters may roll slowly for some RAPL domains, checking all
of them can be time consuming and takes unpredictable amount of time.
Therefore, we relax the sanity check by only checking availability of the
MSRs and non-zero value of the energy status counters. It has been shown
sufficient for all the platforms tested to filter out inactive domains.
Acked-by: Durgadoss R <durgadoss.r@intel.com>
Pull CPU hotplug notifiers registration fixes from Rafael Wysocki:
"The purpose of this single series of commits from Srivatsa S Bhat
(with a small piece from Gautham R Shenoy) touching multiple
subsystems that use CPU hotplug notifiers is to provide a way to
register them that will not lead to deadlocks with CPU online/offline
operations as described in the changelog of commit 93ae4f978ca7f ("CPU
hotplug: Provide lockless versions of callback registration
functions").
The first three commits in the series introduce the API and document
it and the rest simply goes through the users of CPU hotplug notifiers
and converts them to using the new method"
* tag 'cpu-hotplug-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (52 commits)
net/iucv/iucv.c: Fix CPU hotplug callback registration
net/core/flow.c: Fix CPU hotplug callback registration
mm, zswap: Fix CPU hotplug callback registration
mm, vmstat: Fix CPU hotplug callback registration
profile: Fix CPU hotplug callback registration
trace, ring-buffer: Fix CPU hotplug callback registration
xen, balloon: Fix CPU hotplug callback registration
hwmon, via-cputemp: Fix CPU hotplug callback registration
hwmon, coretemp: Fix CPU hotplug callback registration
thermal, x86-pkg-temp: Fix CPU hotplug callback registration
octeon, watchdog: Fix CPU hotplug callback registration
oprofile, nmi-timer: Fix CPU hotplug callback registration
intel-idle: Fix CPU hotplug callback registration
clocksource, dummy-timer: Fix CPU hotplug callback registration
drivers/base/topology.c: Fix CPU hotplug callback registration
acpi-cpufreq: Fix CPU hotplug callback registration
zsmalloc: Fix CPU hotplug callback registration
scsi, fcoe: Fix CPU hotplug callback registration
scsi, bnx2fc: Fix CPU hotplug callback registration
scsi, bnx2i: Fix CPU hotplug callback registration
Subsystems that want to register CPU hotplug callbacks, as well as perform
initialization for the CPUs that are already online, often do it as shown
below:
get_online_cpus();
for_each_online_cpu(cpu)
init_cpu(cpu);
register_cpu_notifier(&foobar_cpu_notifier);
put_online_cpus();
This is wrong, since it is prone to ABBA deadlocks involving the
cpu_add_remove_lock and the cpu_hotplug.lock (when running concurrently
with CPU hotplug operations).
Instead, the correct and race-free way of performing the callback
registration is:
cpu_notifier_register_begin();
init_cpu(cpu);
/* Note the use of the double underscored version of the API */
__register_cpu_notifier(&foobar_cpu_notifier);
cpu_notifier_register_done();
Fix the intel-rapl code in the powercap driver by using this latter form
of callback registration. But retain the calls to get/put_online_cpus(),
since they also protect the function rapl_cleanup_data(). By nesting
get/put_online_cpus() *inside* cpu_notifier_register_begin/done(), we avoid
the ABBA deadlock possibility mentioned above.
Cc: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Tested-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Spell out names for supported SoCs.
Some RAPL domains may not be active at the time driver is being
loaded. Checking energy counter increment may be too strict and
time consuming. So relax the sanity check on energy counters of
these domains.
Otherwise, they may be ignored and become unavailable to the
powercap framework.
This patch adds support for RAPL on Intel ValleyView based SoC
platforms, such as Baytrail.
Besides adding CPU ID, special energy unit encoding is handled
for ValleyView.
As per the documentation of powercap sysfs, energy_uj field is read only,
if it can't be reset. Currently it always allows write but will fail,
if there is no reset callback.
Changing mode field, to read only if there is no reset callback.
Reported-by: Dirk Brandewie <dirk.j.brandewie@intel.com>
Fix compile error with gcc option: -Werror=format-security for
dev_set_name(&control_type->dev, name).
Changed to dev_set_name(&control_type->dev, "%s", name).
