commit 2195f2062e4cc93870da8e71c318ef98a1c51cef upstream.
During probing, the driver tries to get a list (mask) of supported
command types in port100_get_command_type_mask() function. The value
is u64 and 0 is treated as invalid mask (no commands supported). The
function however returns also -ERRNO as u64 which will be interpret as
valid command mask.
Return 0 on every error case of port100_get_command_type_mask(), so the
probing will stop.
Cc: <stable@vger.kernel.org>
Fixes: 0347a6ab300a ("NFC: port100: Commands mechanism implementation")
Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com>
[ Upstream commit 718eae277e62a26e5862eb72a830b5e0fe37b04a ]
Convert cpu_to_le16(le16_to_cpu(frame->datalen) + len) to
use le16_add_cpu(), which is more concise and does the same thing.
Signed-off-by: Mao Wenan <maowenan@huawei.com>
Add missing terminating newlines to nfc_info and nfc_err
to avoid possible interleaving from other messages.
Miscellanea:
o typo fix of "unknonwn" in message
o remove unnecessary OOM messages as there's a generic dump_stack()
o realign arguments
This patch adds support for ISO-DEP protocol over NFC-B rf technology
by adding NFC_PROTO_ISO14443_B to the supported protocols and an entry
for framing configuration.
Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com>
Signed-off-by: Axel Lin <axel.lin@ingics.com>
This adds support for ISO-DEP protocol over NFC-A rf technology. The
port100 already supports NFC-A and ATS request and response for type 4A
tags are handled at digital level. This patch adds NFC_PROTO_ISO14443
to the supported protocols and an entry for framing configuration which
is the same as NFC-A standard frame with CRC handling.
The arrays for protocols and rf techs must define a number of entries
corresponding to their maximum possible index values.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
port100_probe() calls usb_get_dev(), but there is no usb_put_dev()
in port100_disconnect(). The patch adds one.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
This implements the target NFC digital operations tg_configure_hw(),
tg_listen(), tg_listen_mdaa(), and tg_send_cmd().
The target mode supports NFC-A technology at 106kbits/s and NFC-F
technologies at 212 and 424kbits/s.
Cc: Stephen Tiedemann <stephen.tiedemann@gmail.com>
Tested-by: Cho, Yu-Chen <acho@suse.com>
This patch implements the initiator NFC operations in_configure_hw()
and in_send_cmd(). It also implements the switch_rf() operation.
The initiator mode supports NFC-A technology at 106kbits/s and NFC-F
This patch implements the command handling mechanism. The digital stack
serializes all commands sent to the driver. This means that the digital
stack waits for the reply of the current command before sending a new
one. So there is no command queue managed at driver level.
All Port-100 commands are asynchronous. If the command has been sent
successfully to the device, it replies with an ACK frame. Then the
command response is received (or actually no-response in case of
timeout or error) and a command complete work on the system workqueue
is responsible for sending the response (or the error) back to the
digital stack.
The digital stack requires some commands to be synchronous, mainly
hardware configuration ones. These commands use the asynchronous
command path but are made synchronous by using a completion object.
This adds support for the Sony NFC USB dongle RC-S380, based on the
Port-100 chip. This dongle is an analog frontend and does not implement
the digital layer. This driver uses the nfc_digital module which is an
implementation of the NFC Digital Protocol stack.
This patch is a skeleton. It only registers the dongle against the NFC
digital protocol stack. All NFC digital operation functions are stubbed
out.
