path: root/drivers/net/sky2.c
2011-07-08sky2: version 1.29stephen hemminger
Since new hardware chip support was added bump version. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-08sky2: support for new Optima chipsets (EXPERIMENTAL)stephen hemminger
This is a backport from the vendor driver of support for the newer Optima (Prime and 2) chipsets. It also includes some setup changes for the current Optima chip as well. The code and comments intentionally mirror the vendor sk98lin driver to allow for easier maintenance. Although this adds support for new chip id's, these chip id's are not used by any of the current PCI device id's listed in the driver. The patch is just to get initial infrastructure in place to handle them when they come. I don't have access to any of this hardware to actually test it yet. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-08sky2: use correct Inter Packet Gap at 10/100mbitstephen hemminger
This is another fix picked out of the vendor driver. The IPG value in the serial mode register is supposed to be programmed differently at lower speeds. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-08sky2: force receive checksum when using RSS on some hardware (v2)stephen hemminger
Found when reviewing the vendor driver. Apparently some chip versions require receive checksumming to be enabled in order for RSS to work. Also, if fix_features has to change some settings; put in message in log in similar manner to netdev_fix_features. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07sky2: use GFP_KERNEL allocations at device setupEric Dumazet
In process and sleep allowed context, favor GFP_KERNEL allocations over GFP_ATOMIC ones. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-27sky2: remove unnecessary reads of PCI_CAP_ID_EXPJon Mason
The PCIE capability offset is saved during PCI bus walking. It will remove an unnecessary search in the PCI configuration space if this value is referenced instead of reacquiring it. Also, pci_is_pcie is a better way of determining if the device is PCIE or not (as it uses the same saved PCIE capability offset). Signed-off-by: Jon Mason <jdmason@kudzu.us> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: Use full 32 bit speed range in ethtool's set_settingsDavid Decotigny
This makes sure the ethtool's set_settings() callback of network drivers don't ignore the 16 most significant bits when ethtool calls their set_settings(). All drivers compiled with make allyesconfig on x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14ethtool: allow custom interval for physical identificationAllan, Bruce W
When physical identification of an adapter is done by toggling the mechanism on and off through software utilizing the set_phys_id operation, it is done with a fixed duration for both on and off states. Some drivers may want to set a custom duration for the on/off intervals. This patch changes the API so the return code from the driver's entry point when it is called with ETHTOOL_ID_ACTIVE can specify the frequency at which to cycle the on/off states, and updates the drivers that have already been converted to use the new set_phys_id and use the synchronous method for identifying an adapter. The physical identification frequency set in the updated drivers is based on how it was done prior to the introduction of set_phys_id. Compile tested only. Also fixes a compiler warning in sfc. v2: drivers do not return -EINVAL for ETHOOL_ID_ACTIVE v3: fold patchset into single patch and cleanup per Ben's feedback Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Sathya Perla <sathya.perla@emulex.com> Cc: Subbu Seetharaman <subbu.seetharaman@emulex.com> Cc: Ajit Khaparde <ajit.khaparde@emulex.com> Cc: Michael Chan <mchan@broadcom.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: Don Fry <pcnet32@frontier.com> Cc: Jon Mason <jdmason@kudzu.us> Cc: Solarflare linux maintainers <linux-net-drivers@solarflare.com> Cc: Steve Hodgson <shodgson@solarflare.com> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Matt Carlson <mcarlson@broadcom.com> Acked-by: Jon Mason <jdmason@kudzu.us> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12net: sky2: convert to hw_featuresMichał Mirosław
Caveats: - driver modifies vlan_features on HW VLAN TX changes - broken RX checksum will be reenabled on features change Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-06sky2: support ethtool set_phys_idstephen hemminger
Use ethtool set_phys_id to control LED. Fixes issues with RTNL being held for extended periods. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14drivers/net: fix build warnings with CONFIG_PM_SLEEP disabledMichel Lespinasse
This fixes a couple of build warnings when CONFIG_PM is enabled but CONFIG_PM_SLEEP is disabled. Applies on top of v2.6.38-rc7 - I know it's late, but it would be great if v2.6.38 could compile without warnings! Signed-off-by: Michel Lespinasse <walken@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-09sky2: convert to new VLAN model (v0.2)Stephen Hemminger
This converts sky2 to new VLAN offload flags control via ethtool. It also allows for transmit offload of vlan tagged frames which was not possible before. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Reviewed-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-09sky2: fix limited auto negotiationStephen Hemminger
The sky2 driver would always try all possible supported speeds even if the user only asked for a limited set of speed/duplex combinations. Reported-by: Mohsen Hariri <m.hariri@gmail.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01sky2: implement 64 bit statsstephen hemminger
This implements 64 bit statistics support and fixes races when reading counter values. The PHY counters can only be accessed 16 bits at a time, so they are subject to carry races. NB: * TX/RX counters are maintained in software because the the hardware packet count is only a 32 bit value. * Error counters are really only 32 bit. * Old 32 bit counter fields in dev->stats still used for some software counters Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-31sky2: Do not use legacy PCI power managementRafael J. Wysocki
The sky2 driver uses the legacy PCI power management, so it has to do some PCI-specific things in its ->suspend() and ->resume() callbacks, which isn't necessary and should better be done by the PCI sybsystem-level power management code. Moreover, it uses device_set_wakeup_enable() incorrectly (that function should be used when the WoL setting is changed rather than during suspend). Convert sky2 to the new PCI power management framework and make it let the PCI subsystem take care of all the PCI-specific aspects of device handling during system power transitions. Tested on a desktop machine with a Marvell 88E8056 PCI-E adapter. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Don't check for vlan group before vlan_tx_tag_present.Jesse Gross
Many (but not all) drivers check to see whether there is a vlan group configured before using a tag stored in the skb. There's not much point in this check since it just throws away data that should only be present in the expected circumstances. However, it will soon be legal and expected to get a vlan tag when no vlan group is configured, so remove this check from all drivers to avoid dropping the tags. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15sky2: enable GRO by defaultstephen hemminger
The driver has supported GRO for a while, but it was not enabled by default. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-30sky2: Code style fixesMike McCormack
Fix selected style problems reported by checkpatch. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30ethtool: Change ethtool_op_set_flags to validate flagsBen Hutchings
ethtool_op_set_flags() does not check for unsupported flags, and has no way of doing so. This means it is not suitable for use as a default implementation of ethtool_ops::set_flags. Add a 'supported' parameter specifying the flags that the driver and hardware support, validate the requested flags against this, and change all current callers to pass this parameter. Change some other trivial implementations of ethtool_ops::set_flags to call ethtool_op_set_flags(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-23sky2: enable rx/tx in sky2_phy_reinit()Brandon Philips
sky2_phy_reinit is called by the ethtool helpers sky2_set_settings, sky2_nway_reset and sky2_set_pauseparam when netif_running. However, at the end of sky2_phy_init GM_GP_CTRL has GM_GPCR_RX_ENA and GM_GPCR_TX_ENA cleared. So, doing these commands causes the device to stop working: $ ethtool -r eth0 $ ethtool -A eth0 autoneg off Fix this issue by enabling Rx/Tx after running sky2_phy_init in sky2_phy_reinit. Signed-off-by: Brandon Philips <bphilips@suse.de> Tested-by: Brandon Philips <bphilips@suse.de> Cc: stable@kernel.org Tested-by: Mike McCormack <mikem@ring3k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14sky2: version 1.28stephen hemminger
Version 1.28 Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14sky2: Avoid allocating memory in sky2_resumeMike McCormack
Allocating memory can fail, and since we have the memory we need in sky2_resume when sky2_suspend is called, just stop the hardware without freeing the memory it's using. This avoids the possibility of failing because we can't allocate memory in sky2_resume(), and allows sharing code with sky2_restart(). Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14sky2: Refactor down/up code out of sky2_restart()Mike McCormack
Code to bring down all sky2 interfaces and bring it up again can be reused in sky2_suspend and sky2_resume. Factor the code to bring the interfaces down into sky2_all_down and the up code into sky2_all_up. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14sky2: Shut off interrupts before NAPIMike McCormack
Interrupts should be masked, then synchronized, and finally NAPI should be disabled. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14sky2: Avoid race in sky2_change_mtuMike McCormack
netif_stop_queue does not ensure all in-progress transmits are complete, so use netif_tx_disable() instead. Secondly, make sure NAPI polls are disabled before stopping the tx queue, otherwise sky2_status_intr might trigger a TX queue wakeup between when we stop the queue and NAPI is disabled. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14sky2: Restore multicast after restartMike McCormack
Multicast settings will be lost on reset, so restore them. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sky2: use the DMA state API instead of the pci equivalentsFUJITA Tomonori
This replace the PCI DMA state API (include/linux/pci-dma.h) with the DMA equivalents since the PCI DMA state API will be obsolete. No functional change. For further information about the background: http://marc.info/?l=linux-netdev&m=127037540020276&w=2 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-24sky2: add support for receive hashingStephen Hemminger
Sky2 hardware supports hardware receive hash calculation. Now that Receive Packet Steering is available, add support to enable it. This version does not depend on CONFIG_RPS. Also set_flags rejects all values except RXHASH, so driver won't have to change next time somebody adds a new one. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22sky2: size status ring based on Tx/Rx ringstephen hemminger
Sky2 status ring must be big enough to handle worst case number of status messages. It was being oversized (to handle dual port cards), and excessive number of tx ring entries were allowed. This patch reduces the footprint and makes sure the value is enough. Later patch to add RSS increases the number of possible Rx status elements. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30sky2: avoid duplicate link up on Optima chipstephen hemminger
The Optima version has feature to detect link quickly without PHY interrupt, but it causes duplicate link up events. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30sky2: add XL revisionsstephen hemminger
Add definitions for Yukon XL revisions. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30sky2: support Yukon EC_U rev B1 and laterstephen hemminger
Need to change logic to support later versions of Yukon 2 EC_U chip. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-13sky2: Avoid rtnl_unlock without rtnl_lockMike McCormack
Make sure we always call rtnl_lock before going down the error path in sky2_resume, which unlocks the rtnl lock. Signed-off-by: Mike McCormack <mikem@ring3k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18net: convert multiple drivers to use netdev_for_each_mc_addr, part2Jiri Pirko
2010-02-17drivers/net/sky2.c: Use (pr|netdev)_<level> macro helpersJoe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Remove #define PFX Use pr_<level> Use netdev_<level> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16drivers/net/sky2: Convert to use netif_printk macrosJoe Perches
Some unlikely(netif_msg_<foo>(sky2)) tests are also removed by this change. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12sky2: version 1.27stephen hemminger
2010-02-12sky2: Avoid down and up during sky2_resetMike McCormack
Rewrite sky2_reset to work with interrupts disabled and avoid freeing and reallocing memory. The old code used sky2_down and sky2_up to implement sky2_reset, which meant interrupts could not be disabled, and the transmit and receive ring buffers would be free'd and reallocated. To avoid the interrupt handler waking the transmit queue while we're doing a reset, it's better to have interrupts and NAPI polls disabled. Note: Modified Mike's patch to do IRQ disable in sky2_down before calling sky2_hw_down - Stephen Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12sky2: Refactor sky2_down into two functionsMike McCormack
Create a sky2_hw_down that brings the hardware down. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminber <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12sky2: Refactor sky2_up into two functionsMike McCormack
Move hardware initialization into sky2_hw_up. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12sky2: Allocate initial skbs in sky2_alloc_buffersMike McCormack
Allocate everything in one place so there's a single point of failure in sky2_up, and sky2_rx_start can no longer fail. Don't leave the hardware in a partially initialized state in the case rx ring allocation fails. As with the old code, the rx ring still needs to be fully allocated for sky2_up to succeed. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12sky2: Factor out code to calculate packet sizesMike McCormack
Move code to calculate receive threshold and packet size out of sky2_rx_start() so that is can be called from elsewhere easily. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12sky2: jumbo packet changesstephen hemminger
Change how FIFO is programmed in jumbo mode (to match vendor driver). Mostly cosmetic, the only register change is that the bits 22,23 are not programemd used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
