Prioritize CAN TX trafic, and move from edge to level triggered
interrupts.
Previously fw was not released when K20 was flashed successfully
Parameter fw_ignore disables fw version check.
Parameter fw_reload forces k20 firmware reflash via EzPort.
This change also modifies SPI clock for ezPort mode.
Increased SPI speed for transfers and peripheral speed.
Switch to cleaning IRQ flags on read, instead of separate write.
Switched to zero-copy on SPI reads.
Tegra spi driver was using devm_kzalloc before dev
was bound.
This patch includes CAN driver and improvements in SPI communications
for Apalis TK1 k20 based MFD.
Requires firmware version 0.9.
On Apalis TK1 boards K20 MCU is used
for CAN, GPIO, ADC and touch screen.
This patch includes support for core MFD device, GPIO, ADC
and touch screen.
Based on DT or pdata for the board used, add support
to mask oc_pg_ctrl and oc_pg_ctrl2 signal
Bug 1518725
Bug 1419425
Change-Id: Ie69c1de37b9f428e23268dad009dfff36cb1463d
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/423036
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
GVS: Gerrit_Virtual_Submit
Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
Initialize the backup battery charging state based on
device tree or platform provided data
Bug 1508216
Change-Id: I2bc7c0778b466bb61cd984bfeece97cd9c0059e4
Reviewed-on: http://git-master/r/403344
regmap_add_irq_chip fail
commit 483e2dfdbc94751430e41db9973985f5b054d322 upstream.
Fixes: 4aab3fadad32 ("mfd: tps65910: Move interrupt implementation code to mfd file")
tps65910_irq_init() sets 'tps65910->chip_irq' before calling
regmap_add_irq_chip(). If the regmap_add_irq_chip() call fails in
memory allocation of regmap_irq_chip_data members then:
1. The 'tps65910->chip_irq' will still hold some value
2. 'tps65910->irq_data' will be pointing to already freed memory
(because regmap_add_irq_chip() will free it on error)
This results in invalid memory access during driver remove because the
tps65910_irq_exit() tests whether 'tps65910->chip_irq' is not zero.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 97dc4ed3fa377ec91bb60ba98b70d645c2099384 upstream.
During probe the driver allocates dummy I2C devices for RTC, haptic and
MUIC with i2c_new_dummy() but it does not check the return value of this
calls.
In case of error (i2c_new_device(): memory allocation failure or I2C
address cannot be used) this function returns NULL which is later used
by i2c_unregister_device().
If i2c_new_dummy() fails for RTC, haptic or MUIC devices, fail also the
probe for main MFD driver.
commit ed26f87b9f71693a1d1ee85f5e6209601505080f upstream.
During probe the driver allocates dummy I2C device for RTC with i2c_new_dummy() but it does not check the return value of this call.
If i2c_new_dummy() fails for RTC device, fail also the probe for
main MFD driver.
commit 96cf3dedc491d2f1f66cc26217f2b06b0c7b6797 upstream.
During probe the driver allocates dummy I2C devices for RTC and ADC
calls.
If i2c_new_dummy() fails for RTC or ADC devices, fail also the probe
commit ad09dd6a1f5d6244bd89314015af506ba7f9810a upstream.
During probe the driver allocates dummy I2C devices for MUIC and haptic
calls.
by devm_regmap_init_i2c() and i2c_unregister_device().
If i2c_new_dummy() fails for MUIC or haptic devices, fail also the probe
commit b9e183a1d495cd65412abe0f9df19b151716bfe7 upstream.
If i2c_new_dummy() fails for RTC device, fail also the probe for main
MFD driver.
commit a7ab1c8b261305af583ce26bb4a14f555fdaa73e upstream.
During probe the driver allocates dummy I2C device for companion chip
and then allocates a regmap for it. If regmap_init_i2c() fails then the
I2C driver (allocated with i2c_new_dummy()) is not freed and this
resource leaks.
commit 159ce52a6b777fc82fa0b51c7440e25f9e4c6feb upstream.
by regmap_init_i2c().
If i2c_new_dummy() fails for companion device, fail also the probe for
main MFD driver.
commit 65aba1e04916d72b30c028730a1e31860c225412 upstream.
During probe the sec-core driver allocates dummy I2C device for RTC with
i2c_new_dummy() but return value is not checked. In case of error
(i2c_new_device(): memory allocation failure or I2C address cannot be
used) this function returns NULL which is later used by
devm_regmap_init_i2c() or i2c_unregister_device().
MFD driver.
- Avoid waiting for the irqthread to complete
while holding a mutex lock irqthread needs
Bug 1463497
Change-Id: I6e9b948d9fca43a17d4badb37901ebb292d229ae
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/396765
(cherry picked from commit 786a717e885bf975012c2d76aac6ece89e258343)
Reviewed-on: http://git-master/r/403127
mask all interrupt and disable parent interrupt before shutdown to avoid
any interrupt during the power off sequence.
bug 1487336
Change-Id: If5829e325bef37201c3a0ebbeadb3aff4e7acd4f
Reviewed-on: http://git-master/r/387157
(cherry picked from commit 9173cd770a4bfc57e4000f2f7d923a586a3a9ad5)
Reviewed-on: http://git-master/r/400147
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
If system is resumed by the as3722 device then logs the sub-irq of
device which actually cause the wakeup of system. The logs are done
by regmap irq and hence calling the appropriate APIs to have logs.
Change-Id: Ie21f9db809f47745d837e9083b7d258e1a64b892
Reviewed-on: http://git-master/r/395694
If system is resumed by the Palmas device then prints the sub-irq of
This helps on finding the submodule which cause system resume.
Change-Id: I8a089baa77fbcd259c8ffeb8825f4de8446df6ed
Reviewed-on: http://git-master/r/395693
Palmas ldousb rail has two input, ldousb-in1 and ldousb-in2. Add
driver name in list of palmas subdriver to have the in1 or in2
to be selected dynamically.
Bug 1451748
Change-Id: I4c45431d97cb8f7989f0a6a8fdf5058952de1d4f
Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-on: http://git-master/r/394187
Bug 1466403
Change-Id: I0c29790e00e004a060ac4bae8234faa64db88f52
Reviewed-on: http://git-master/r/382008
Bug 1456092
Change-Id: Ic563f451abb08754fea0e2bbf0ce065ca2e6e770
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Implement the otp version detection from the AMS PMIC device.
Chip Revision ASCI_ID1 (90h) ASIC_ID2 (91h) ASIC_ID3 (CCh[7:4])
1v0 0Ch 0h 0h
1v1 0Ch 1h 0h
1v2 0Ch 1h 0h
1v21 0Ch 1h 1h
The detection of 1v1 and 1v2 is done using the platform data which
sets as per the board-id.
Change-Id: I3ca24206a48f3fc5101943627edbec42f0de9de2
Reviewed-on: http://git-master/r/379813
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Bibek Basu <bbasu@nvidia.com>
- Added an option to mark VSEL registers as volatile by default.
This option should be set either in board platform data, or in device
tree node of the regulator controlled by hardware mechanism underneath
s/w driver.
- Replaced volatile registers table with callback that checks access
attribute at run-time. Added another callback to switch VSEL registers
attributes between volatile and cached.
- Set persistent property for VSEL of all SD regulators (persistent
value is zero). This would allow to use direct write for setting the
voltage selector instead of read-modify-write.
Bug 1454969
Change-Id: I9a434fa8568dc2717a81ae6ecf3891abb903befa
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/367357
Added callback to set SMPS voltage selector registers access attribute
as volatile or cached.
Bug 1454969
Change-Id: I9e98d2822a247d4009d4664b77b7f296a79414ea
Reviewed-on: http://git-master/r/365779
commit 283aae8ab88e695a660c610d6535ca44bc5b8835 upstream.
This patch adds the LPC Controller DeviceIDs for iTCO Watchdog for
the Intel Coleto Creek PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
Cc: "Chan, Wei Sern" <wei.sern.chan@intel.com>
commit 8477128fe0c3c455e9dfb1ba7ad7e6d09489d33c upstream.
This patch adds the LPC Controller Device IDs for Watchdog and GPIO for
Intel Avoton SoC, to the lpc_ich driver.
Signed-off-by: James Ralston <james.d.ralston@intel.com>
Currently all Palmas SMPS regulators voltage selection registers are
always cached. Added a regulator configuration flag to mark volatile
VSEL register. This flag can be set either in board platform data or
in device tree node for the regulator that is controlled by hardware
mechanism underneath s/w driver.
Change-Id: I733de6e2e9d42bbcc2359f033bfb8ddccdaf7202
Reviewed-on: http://git-master/r/363635
commit 74142ffc0b52cfe6f9d2f6f34a5f3eedbfe3ce51 upstream.
The regmap used by max77686 MFD driver was not freed with regmap_exit()
on driver exit. This lead to leak of resources.
Replace regmap_init_i2c() call in driver probe with initialization of
managed register map so the regmap will be properly freed by the device
management code.
Add customized locking mechanism for register access
of as3722 device through regmap.
This will help to bypass the locking mechanism when as3722
device get accessed in the atomic context.
Bug 1443347
Change-Id: I43bd44554759387135e1e03741655ebd6472631f
Reviewed-on: http://git-master/r/363719
of palmas device address config 0.
This will help to bypass the locking mechanism when palmas
Bug 1443347
Change-Id: I3739b88e1b15a15da010f7f850c980c2a4809c4e
Reviewed-on: http://git-master/r/362875
(cherry picked from commit 55ccf8025ec4787bc75991a1a292979ac9bbb64c)
Change-Id: I2e93dc6e919571b92fbebe7361518c85f3d05f16
Reviewed-on: http://git-master/r/363717
commit 73beb63d290f961c299526852884846b0d868840 upstream.
This fixes a kernel panic when resuming from suspend to RAM.
Without this fix an interrupt hits after the delayed work is canceled
and thus requeues it. So we end up freeing an armed timer.
On ams AS3722, power on when AC OK is enabled by default.
Making this option as disable by default and enable only
when platform need this explicitly.
Change-Id: I103d62ab9170c96b00ce8b58235afb8d24ba5e63
Reviewed-on: http://git-master/r/349290
This change is for adding GPLv2 license header for few files.
Bug 1415426
Change-Id: I1c0b7e9a0fc5dc4e19ac644e4a2c43ceb99088fd
Signed-off-by: Tejas Sonchhatra <tmanoj@nvidia.com>
Reviewed-on: http://git-master/r/348944
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Decide the PMIC version based on board id as
AMS PMIC rev id is not correct in silicon.
Add DT support also.
Bug 1425474
Change-Id: Ia51462980da582c958a26e156b48a1e5d655559f
Signed-off-by: Prabhu Kuttiyam <pkuttiyam@nvidia.com>
Reviewed-on: http://git-master/r/347241
Add watchdog support fo as3722
Bug 1396052
Change-Id: I7bd16a8f7316c039800dd5c823067c6b53d0667d
Reviewed-on: http://git-master/r/328825
