Prioritize CAN TX trafic, and move from edge to level triggered
interrupts.
Previously fw was not released when K20 was flashed successfully
Parameter fw_ignore disables fw version check.
Parameter fw_reload forces k20 firmware reflash via EzPort.
This change also modifies SPI clock for ezPort mode.
Increased SPI speed for transfers and peripheral speed.
Switch to cleaning IRQ flags on read, instead of separate write.
Switched to zero-copy on SPI reads.
Tegra spi driver was using devm_kzalloc before dev
was bound.
This patch includes CAN driver and improvements in SPI communications
for Apalis TK1 k20 based MFD.
Requires firmware version 0.9.
On Apalis TK1 boards K20 MCU is used
for CAN, GPIO, ADC and touch screen.
This patch includes support for core MFD device, GPIO, ADC
and touch screen.
