(cherry picked from commit 0a8984655b5239833a3e6e0d54c7c867dbc7ea63)
This fixes the dual camera use case.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Kernel hangs if camera capture errors are not handled to allow for a way
out of the the capture thread.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
b271e8fa67a6d9c4600274a25636cfe00fdd1b68
Use locking to protect generated fd, so that it can't be
freed before channel open completes. Also add null value checks
in release call.
CVE-2016-8449 (A-31798848)
Bug 1830023
Bug 1849492
Change-Id: Ie6e2b29c7132fdfdff6b0bfa75440bd43afffd5f
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Reviewed-on: http://git-master/r/1285817
(cherry picked from commit 2ff0fdedfd65f269359d6540df4662e958681aa7)
Reviewed-on: http://git-master/r/1299505
(cherry picked from commit ea1af2ce5a746bda36205357c9e0adaf527026bb)
Reviewed-on: http://git-master/r/1489467
(cherry picked from commit 89559abb25f82dc333eafa26391be0a50d6e9e0a)
Reviewed-on: http://git-master/r/1504674
GVS: Gerrit_Virtual_Submit
Tested-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Fix UAF (use-after-free) security issue in
camera.pcl driver
Bug 1832830
Change-Id: Ie0f8a58a7bb9d1b4949e0f68d25d6da108f06e76
Signed-off-by: Frank Chen <frankc@nvidia.com>
Reviewed-on: http://git-master/r/1271371
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
- Add mutex_lock(cam_desc.d_mutex) around ioctl access functions.
- Check cam->cdev in PCLLK_IOCTL_DEV_DEL ioctl.
(Back ported from Nexus N9 project)
Bug 1832830
Signed-off-by: <tiangangpi@gmail.com>
Signed-off-by: Xiaya Hu <xiaya@nvidia.com>
Signed-off-by: Mark Salyzyn <salyzyn@google.com>
Bug: 28026625
Change-Id: I81fbab628fb6516afa2cf5d3e0adf333aa2eb003
Reviewed-on: http://git-master/r/1271370
Reviewed-by: Frank Chen <frankc@nvidia.com>
Tested-by: Frank Chen <frankc@nvidia.com>
Check a few input params to make sure there is
no potential for a heap overflow in the driver.
Bug 1757475 (nvidia)
Bug 1832830 (nvidia)
Bug 28193342 (google)
Change-Id: I979fa38c5f453cfad7070f0340ec04adde5bac13
Signed-off-by: Amey Asgaonkar <aasgaonkar@nvidia.com>
Reviewed-on: http://git-master/r/1271369
The driver expects the userspace-provided table to be terminated with
addr == CAMERA_TABLE_END. Reject tables that aren't.
(back ported from Nexus N9 project)
Bug 1832830
Change-Id: Id1e168e02fbf323d094fe8c36c6e4bd90cceee4f
Signed-off-by: Greg Hackmann <ghackmann@google.com>
Reviewed-on: http://git-master/r/1271368
Several places in the camera stack can hit integer overflows or cause
bad allocations if userspace passes in a bogus sizeofvalue parameter.
Protect against this by using appropriately-sized integer types, adding
range checks, replacing array-allocation calls with kcalloc(), and
checking for allocations returning ZERO_SIZE_PTR.
For one specific ioctl (PCLLK_IOCTL_UPDATE) sizeofvalue = 0 is fine,
since when that happens the subdrivers won't actually touch the returned
allocation. In fact the existing userspace camera driver makes calls
like these and expects them to succeed! Handle this special case by
adding a __camera_get_params variant that optionally treats zero-sized
inputs as valid.
Bug 1832830
Change-Id: Ie3250d8a4b814de5820fa0190b4cbd1af3ca4b3f
Reported-by: Jianqiang Zhao <zhaojianqiang1@gmail.com>
Reviewed-on: http://git-master/r/1271367
Signed-off-by: Wojciech Bieganski <wbieganski@antmicro.com>
This reverts commit b2f6b2abc791802631ff1c85488cdf3c1f0a97e2.
Signed-off-by: Mariusz Glebocki <mglebocki@antmicro.com>
This reverts commit ff5bccb61c1f8da1f63451fda88bd1f65dbee5b2.
This makes Antmicro's OV5640 camera module work again as described on
their blog here:
http://antmicro.com/Blog/2015/09/jetson-tk1-cameras/
Further investigation pending.
Connected to CSI CIL-E. Cameras doesn't work simultaneously.
drivers/media/platform/tegra/ad5816.c: In function 'ad5816_param_wr':
drivers/media/platform/tegra/ad5816.c:682:6: error: this 'if' clause
does not guard... [-Werror=misleading-indentation]
if (info->s_mode != NVC_SYNC_STEREO)
drivers/media/platform/tegra/dw9718.c:627:6: error: this 'if' clause
Add missing mutex unlock for nvavp_submit.
bug 1775299
Change-Id: I1b525e192bfd9dd19bcd0211484400445eda7b2b
Signed-off-by: Soumen Kumar Dey <sdey@nvidia.com>
Reviewed-on: http://git-master/r/1221210
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Add mutex lock for nvavp_submit to avoid race condition.
bug 1775299
Change-Id: I11a66a58a1f048d6a0ee5aa949f852bfef56dc07
Reviewed-on: http://git-master/r/1164117
(cherry picked from commit 1faa6a739996fdacff3dbc85ad46235f42ad79c9)
Reviewed-on: http://git-master/r/1214643
Fixed possible buffer overflow issue in func
nvavp_pushbuffer_update().
Bug 1774401
Change-Id: Id0dec1cbf91d492335d0809c3c0bf146f6cb9d3d
Signed-off-by: Praveen Kumar Reddy M.V. <pkreddy@nvidia.com>
Reviewed-on: http://git-master/r/1163365
(cherry picked from commit 1e9ba50b225e841b52a93503fce818c1a21100f7)
Reviewed-on: http://git-master/r/1164130
Bug 1729847
Change-Id: Ie455b0469a1d4e35453ca9e36c5e90dfdc6f56a2
Signed-off-by: Bhushan Rupde <brupde@nvidia.com>
Reviewed-on: http://git-master/r/1147432
Reviewed-by: Mohan Nimaje <mnimaje@nvidia.com>
Reviewed-by: Soumen Dey <sdey@nvidia.com>
Deprecate outdated UPDATE_GPIO function in camera.pcl
driver. This function is not used by any code anymore
and is a security vulnerability since it is trying to
access user mode pointer directly.
Bug 1745102
Change-Id: I4e7e5f9c186f980dcadfe52ec4284102255f19cf
Reviewed-on: http://git-master/r/1115302
(cherry picked from commit 2e5c355c904a19d71456a04c70f3fb4fc7d918b0)
Reviewed-on: http://git-master/r/1123362
Tested-by: Matthew Pedro <mapedro@nvidia.com>
We need to validate power on/off function size passed
in from user mode in order to avoid integer overflow
or out of memory failures.
Bug 1745100
Change-Id: Idddd848f7dc1e864559ad219f9204325128484e5
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/1114354
(cherry picked from commit 8b3afcc132882f3102083f9a24de7f55476ca59b)
Reviewed-on: http://git-master/r/1150944
We are not checking a variable which is user
controlled. This can lead to reading of the
stack data. Adding a check to ensure it is
less than the max possible value of the variable.
Bug 1763649
Change-Id: I395e882d030199bdd7684837906a9b5d60741650
Reviewed-on: http://git-master/r/1150943
- Check whether command buffer data offset is 32-bit
aligned
- Check whether relocation offset is 32-bit aligned
and calculated offset is within command buffer size
- Check whether target offset is 32-bit aligned
and derived address is within target buffer size
Bug 1741516
Change-Id: Ie5370bc1538c8cf9a702904fb88eb850baeb063d
Signed-off-by: Somu Sundaram <somasundaram@nvidia.com>
Reviewed-on: http://git-master/r/1113949
Tested-by: Somu Sundaram <somasundarams@nvidia.com>
Add checks for command buffer offset, relocation
offset in command buffer and target offset for patching
relocation to prevent aritrary kernel write
Bug 1741516
Change-Id: Ia6183ca75f983c0ede23606be9e5d824aa5fa41d
Reviewed-on: http://git-master/r/1111699
Increase NVAVP_MAX_RELOCATION_COUNT to max. possible value
and add check to return error if num_relocs in
nvavp_pushbuffer_submit_ioctl exceeds
Bug 1739930
Change-Id: Ief36cedd692aa53135fc6a0039b19f18609259dd
Signed-off-by: Somasundaram S <somasundaram@nvidia.com>
Reviewed-on: http://git-master/r/1030885
Use one kthread to start capture a frame and wait for next frame start.
Before waiting, it will move the current buffer to another queue which
will be handled another kthread.
The second kthread (capture_done) will wait for memory output done sync
point event and handle the buffer to videobuffer2 framework as capture
done.
Bug 1686911
Change-Id: Ia092c708ecca3b2e7cbc657a96fd247ea4a00d2f
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/819177
Use kthread instead of workqueue, which will create a dedicated kernel
thread for capture.
Remove useless mutex and convert spin_lock_irq() to normal spin_lock().
Bug 1686911
Change-Id: Ib236a7ebbdd0359f2705774a979825f1f9e9d82a
Reviewed-on: http://git-master/r/819176
bytes_per_line should be 64 bytes aligned in Tegra. Add a function to
check that and return the right value for LINE_STRIDE register.
Bug 1694764
Change-Id: I1bb926a416719d19cad509f9a9a7c4fce06b851a
Reviewed-on: http://git-master/r/816975
Based on latest info from Aptina, change 720p settings.
Bug 1643556
Change-Id: Ia1ea066ebf265670bb8e0503e9502ac9f24a27ff
Signed-off-by: Arun Kannan <akannan@nvidia.com>
Reviewed-on: http://git-master/r/748499
Tested-by: Winnie Hsu <whsu@nvidia.com>
bug 1655159
Change-Id: I5c09cb63075f3465e90aee4f3619df02c34bca95
Signed-off-by: Ming Wong <miwong@nvidia.com>
Reviewed-on: http://git-master/r/757527
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Queueing buffer might happen before starting streaming. So any queueing
buffer operation before starting streaming shouldn't trigger real
capture but just queue the buffer. After starting streaming, it will
wake up kernel workqueue to start real capture.
Bug 1639982
Change-Id: I66fd527bbd12790b2d688f320214976e70a658f3
Reviewed-on: http://git-master/r/754710
Reviewed-by: David Wang (SW-TEGRA) <davidw@nvidia.com>
Current single shot mode, pixel parser is disabled after capture one
frame and software waits for memory write ack done syncpoint, which
only gives us half the frame rate.
Optimized single shot mode:
- during capture setup, set single shot mode
- for each frame, wait for FRAME_START syncpoint
- arm single shot bit to start capture
- for the last frame, wait for MWA_DONE syncpoint to make sure capture
finished.
With optimized single shot mode, frame rate is about 4208x3120 @ 24fps
for IMX135 and 1920x1080 @ 30fps for AR0261.
Bug 1639982
Change-Id: I0b15d02c2853647d03f5b2d38a7fe5c145174bd5
Reviewed-on: http://git-master/r/754709
Bug 1648875
Change-Id: I970a3eafcd7ec10f217f4c1cb13db9193dc037f6
Reviewed-on: http://git-master/r/752761
Reviewed-by: Arun Kannan <akannan@nvidia.com>
MIPI calibration should be done when power on the VI/CSI hardware. So
clear the MIPI_CAL flag to trigger MIPI calibration for next power on
operation.
Bug 1648875
Change-Id: Ic0689a331a6058e4d54d5b41869f2e81feb4158c
Reviewed-on: http://git-master/r/752129
Tested-by: Arun Kannan <akannan@nvidia.com>
added 2304x1520 1 MIPI lane resolution
Bug 1552628
Change-Id: Ib2af3a77f9bede216e538a53d162839e9a249996
Reviewed-on: http://git-master/r/731521
Bug 200044433
Change-Id: I792062649c247229270678a44d10323d2744b569
Signed-off-by: Kassey Li <kasseyl@nvidia.com>
Reviewed-on: http://git-master/r/721561
Add calibration for T124 VI2.
Bug 1628147
Change-Id: If70b1562c1d6345b337e4a01236c392b79f14dad
Reviewed-on: http://git-master/r/678605
Bug 1598204
Change-Id: I453d18ce570e57c0feab8dc3b24cc2c957b95301
Reviewed-on: http://git-master/r/672147
Bug 1600299
Change-Id: I63f4d597bcc8b960407a7291fde6aa2ddb5bec25
Reviewed-on: http://git-master/r/674099
Change-Id: I3a358eb3f996917218798ae24eb1b0ef471a223f
Reviewed-on: http://git-master/r/591332
(cherry picked from commit 4011d6570ba8138348ccc45b2acb31526cb73863)
Reviewed-on: http://git-master/r/665998
Disable line timeout, since some sensor like IMX208 doesn't work with
line timeout enabled.
Bug 1560636
Change-Id: I38e9a03e04ca206cbb65c13829c567d0c0de1c6c
Reviewed-on: http://git-master/r/539004
(cherry picked from commit 8cca4a716c25cecbbc7455d5dd92f3e7fc074b07)
Reviewed-on: http://git-master/r/665997
Bug 1560636
Change-Id: I2d27c631da0f4b6540af9b4da9ba9e212a4a56c5
Reviewed-on: http://git-master/r/539003
(cherry picked from commit e9b82e8a6e6edf5fc00e88c8610b9c2bb67f3872)
Reviewed-on: http://git-master/r/665996
Change clks_init() internal API to use CSI port number to enable clks
instead of using dev_id which is incorrect sometime, since vi.0 might
also assigned to CSI_B/CSI_C port.
Bug 1560636
Change-Id: I0e26308ec885e2e34fe8faa63fca404c911912c4
Reviewed-on: http://git-master/r/539002
(cherry picked from commit c66d8e5880589b0d95dba63d10daff53e47e8628)
Reviewed-on: http://git-master/r/665995
This driver does not demosaic, so when we are working with a bayer sensor,
we can only report the various bayer formats. Similarly, we only support
rgba for test pattern generator right now, so only report rgba if we are in
test pattern mode.
When in test pattern mode, don't ever query the sensor subdev, since it's
not involved at all.
Also, made some miscellaneous cleanup to some debug prints, and the
conditionals around how CSI gets programmed.
Bug 1560636
Change-Id: I9022ec6a489b20d0847dd9d2a79af2307b7a4af1
Signed-off-by: Andrew Chew <achew@nvidia.com>
Reviewed-on: http://git-master/r/489066
(cherry picked from commit f211247b0151b926f21b989cc031dc928db61aaa)
Reviewed-on: http://git-master/r/665994
Bug 1552628
Change-Id: I90fdbb99bcfb2c20ed1fa0125af6a999bad7b4fc
Reviewed-on: http://git-master/r/658630
Reviewed-by: Kamal Balagopalan <kbalagopalan@nvidia.com>
Tested-by: Kamal Balagopalan <kbalagopalan@nvidia.com>
return the status of nvhost_syncpt_wait_timeout_ext
in vi2_capture_start.
Bug 1583009
Change-Id: I2b2ecaf868d0a05e2fa46b23e7eb40ee76aea380
Reviewed-on: http://git-master/r/655521
Reviewed-by: Bryan Wu <pengw@nvidia.com>
Tested-by: Bryan Wu <pengw@nvidia.com>
