in soc_camera_close(), if ici->ops->remove() removes device firstly,
and then call __soc_camera_power_off(), it has logic error. Since
if remove device, it should disable subdev clk. but in __soc_camera_
power_off(), it will callback v4l2 s_power function which will
read/write subdev registers to control power by i2c. and then
i2c read/write will fail because of clk disable.
So suggest to re-sequence two functions call.
Change-Id: Iee7a6d4fc7c7c1addb5d342621eb8dcd00fa2745
Signed-off-by: Wenbing Wang <wangwb@marvell.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
To protect against open() racing with rmmod, hold the list_lock also while
obtaining a reference to the camera host driver and check that the video
device hasn't been unregistered yet.
This ioctl is defined as IOW, so pass the argument as const.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
This ioctl is defined as IOW, so pass the argument by value instead of by
reference. I could have chosen to add const instead, but this is 1) easier
to handle in drivers and 2) consistent with the s_std subdev operation.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Jonathan Corbet <corbet@lwn.net>
* v4l_for_linus: (464 commits)
[media] uvcvideo: Set error_idx properly for S_EXT_CTRLS failures
[media] uvcvideo: Cleanup leftovers of partial revert
[media] uvcvideo: Return -EACCES when trying to set a read-only control
Linux 3.8-rc3
mm: reinstante dropped pmd_trans_splitting() check
cred: Remove tgcred pointer from struct cred
drm/ttm: fix fence locking in ttm_buffer_object_transfer
ARM: clps711x: Fix bad merge of clockevents setup
ARM: highbank: save and restore L2 cache and GIC on suspend
ARM: highbank: add a power request clear
ARM: highbank: fix secondary boot and hotplug
ARM: highbank: fix typos with hignbank in power request functions
ARM: dts: fix highbank cpu mpidr values
ARM: dts: add device_type prop to cpu nodes on Calxeda platforms
drm/prime: drop reference on imported dma-buf come from gem
xen/netfront: improve truesize tracking
ARM: mx5: Fix MX53 flexcan2 clock
ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array
sctp: fix Kconfig bug in default cookie hmac selection
EDAC: Cleanup device deregistering path
drivers/media/pci/dm1105/dm1105.c
drivers/media/platform/soc_camera/mx2_camera.c
struct soc_camera_link currently contains fields, used both by sensor and
bridge drivers. To make subdevice driver re-use simpler, split it into a
host and a subdevice parts.
Currently soc-camera has a per-device node lock, used for video operations
and a per-host lock for code paths, modifying host's pipeline. Manipulating
the two locks increases complexity and doesn't bring any advantages. This
patch removes the per-device lock and uses the per-host lock for all
operations.
Currently devm_regulator_bulk_get() is called by soc-camera during host
driver probing, but regulators are attached to the camera platform
device, that is staying, independent whether the host probed successfully
or not. This can lead to repeated regulator requesting, if the host
driver is re-probed. Move the call to platform device probing to avoid
this.
The recently introduced host_lock causes lockdep warnings, besides, list
enumeration in scan_add_host() must be protected by holdint the list_lock.
OTOH, holding .video_lock in soc_camera_open() isn't enough to protect
the host during its building of the pipeline, because .video_lock is per
soc-camera device. If, e.g. more than one sensor can be attached to a host
and the user tries to open both device nodes simultaneously, host's .add()
method can be called simultaneously for both sensors. Fix these problems
by holding list_lock instead of .host_lock in scan_add_host() and taking
it shortly at the beginning of soc_camera_open(), and using .host_lock to
protect host's .add() and .remove() operations only.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Using device-managed devm_regulator_bulk_get() eliminates the need to
release regulators explicitly.
Sometimes VIDIOC_S_CROP ioctl doesn't work, soc-camera driver reports:
soc-camera-pdrv soc-camera-pdrv.0: S_CROP denied: getting current crop failed
The VIDIOC_G_CROP documentation states that the type field needs to be
set to the respective buffer type when querying, so the check in .g_crop()
of the subdevices returns -EINVAL if the type is not set properly. Here the
uninitialized local variable 'current_crop' is passed to the .g_crop() and
this leads to the observed error. Initialize the type field of the local
'current_crop' before get_crop call.
Try reading on video device. If the camera bus driver supports reading
we can try it and return the result. Also add a debug line.
drivers/media/platform/soc_camera/soc_camera.c:1051:8: warning: variable 'ret' set but not used [-Wunused-but-set-variable]
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
[g.liakhovetski@gmx.de: follow the soc_camera.c style: check "ret < 0"]
devm_kzalloc() has been used to simplify error handling.
While at it, the soc_camera_device_register function has been moved to
save a few lines of code and a variable.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
[g.liakhovetski@gmx.de: remove a superfluous empty line]
module_platform_driver simplifies the code by eliminating
module_init and module_exit calls.
Replace the deprecated V4L2_SEL_TGT_*_ACTIVE selection target
names with their new unified counterparts.
Compatibility definitions are already in linux/v4l2-common.h.
Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com>
With a filter function you can control more precisely which controls
are added. This is useful in particular for radio device nodes for
combined TV/Radio cards where you want to show just the radio-specific
controls and not controls like brightness.
Write-only ioctls should have a const argument in the ioctl op.
Do this conversion for vidioc_s_crop.
Adding const for write-only ioctls was decided during the 2012 Media Workshop.
That helps to better organize the soc_camera items.
While here, cleanup Makefiles, removing uneeded include dirs.
