Fixes the following checkpatch warnings:
WARNING: unnecessary whitespace before a quoted newline
WARNING: please, no space before tabs
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
The commit 39793c6 "[media] mx2_camera: Convert it to platform driver"
used module_platform_driver() to make code smaller,
but since the driver used platform_driver_probe is more appropriate
to use module_platform_driver_probe().
Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com>
Not all drivers use monotonic timestamps. This patch adds a way to set the
timestamp type per every queue.
In addition, set proper timestamp type in drivers that I am sure that use
either MONOTONIC or COPY timestamps. Other drivers will correctly report
UNKNOWN timestamp type instead of assuming that all drivers use monotonic
timestamps.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Some cleanups at V4L2 documentation
- new drivers: ts2020 frontend, ov9650 sensor, s5c73m3 sensor,
sh-mobile veu mem2mem driver, radio-ma901, davinci_vpfe staging
driver
- Lots of missing MAINTAINERS entries added
- several em28xx driver improvements, including its conversion to
videobuf2
- several fixups on drivers to make them to better comply with the API
- DVB core: add support for DVBv5 stats, allowing the implementation of
statistics for new standards like ISDB
- mb86a20s: add statistics to the driver
- lots of new board additions, cleanups, and driver improvements.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (596 commits)
[media] media: Add 0x3009 USB PID to ttusb2 driver (fixed diff)
[media] rtl28xxu: Add USB IDs for Compro VideoMate U620F
[media] em28xx: add usb id for terratec h5 rev. 3
[media] media: rc: gpio-ir-recv: add support for device tree parsing
[media] mceusb: move check earlier to make smatch happy
[media] radio-si470x doc: add info about v4l2-ctl and sox+alsa
[media] staging: media: Remove unnecessary OOM messages
[media] sh_vou: Use vou_dev instead of vou_file wherever possible
[media] sh_vou: Use video_drvdata()
[media] drivers/media/platform/soc_camera/pxa_camera.c: use devm_ functions
[media] mt9t112: mt9t111 format set up differs from mt9t112
[media] sh-mobile-ceu-camera: fix SHARPNESS control default
Revert "[media] fc0011: Return early, if the frequency is already tuned"
[media] cx18/ivtv: fix regression: remove __init from a non-init function
[media] em28xx: fix analog streaming with USB bulk transfers
[media] stv0900: remove unnecessary null pointer check
[media] fc0011: Add some sanity checks and cleanups
[media] fc0011: Fix xin value clamping
Revert "[media] [PATH,1/2] mxl5007 move reset to attach"
Pull trivial tree from Jiri Kosina:
"Assorted tiny fixes queued in trivial tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits)
DocBook: update EXPORT_SYMBOL entry to point at export.h
Documentation: update top level 00-INDEX file with new additions
ARM: at91/ide: remove unsused at91-ide Kconfig entry
percpu_counter.h: comment code for better readability
x86, efi: fix comment typo in head_32.S
IB: cxgb3: delay freeing mem untill entirely done with it
net: mvneta: remove unneeded version.h include
time: x86: report_lost_ticks doesn't exist any more
pcmcia: avoid static analysis complaint about use-after-free
fs/jfs: Fix typo in comment : 'how may' -> 'how many'
of: add missing documentation for of_platform_populate()
btrfs: remove unnecessary cur_trans set before goto loop in join_transaction
sound: soc: Fix typo in sound/codecs
treewide: Fix typo in various drivers
btrfs: fix comment typos
Update ibmvscsi module name in Kconfig.
powerpc: fix typo (utilties -> utilities)
of: fix spelling mistake in comment
h8300: Fix home page URL in h8300/README
xtensa: Fix home page URL in Kconfig
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
drivers/devfreq/exynos4_bus.c
Sync with Linus' tree to be able to apply patches that are
against newer code (mvneta).
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
* v4l_for_linus: (464 commits)
[media] uvcvideo: Set error_idx properly for S_EXT_CTRLS failures
[media] uvcvideo: Cleanup leftovers of partial revert
[media] uvcvideo: Return -EACCES when trying to set a read-only control
Linux 3.8-rc3
mm: reinstante dropped pmd_trans_splitting() check
cred: Remove tgcred pointer from struct cred
drm/ttm: fix fence locking in ttm_buffer_object_transfer
ARM: clps711x: Fix bad merge of clockevents setup
ARM: highbank: save and restore L2 cache and GIC on suspend
ARM: highbank: add a power request clear
ARM: highbank: fix secondary boot and hotplug
ARM: highbank: fix typos with hignbank in power request functions
ARM: dts: fix highbank cpu mpidr values
ARM: dts: add device_type prop to cpu nodes on Calxeda platforms
drm/prime: drop reference on imported dma-buf come from gem
xen/netfront: improve truesize tracking
ARM: mx5: Fix MX53 flexcan2 clock
ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array
sctp: fix Kconfig bug in default cookie hmac selection
EDAC: Cleanup device deregistering path
drivers/media/pci/dm1105/dm1105.c
drivers/media/platform/soc_camera/mx2_camera.c
Converting it to platform code can make the code smaller.
After removing i.mx25 support and buf_cleanup() callback,
buffer states are not used in the code any longer.
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
All necessary tasks to end the streaming properly are
already implemented in mx2_stop_streaming() and nothing
remains to be done in this callback.
Furthermore, it only included debug messages so it can
be removed.
i.MX25 support has been broken for several releases
now and nobody seems to care about it.
[g.liakhovetski@gmx.de: rebased on top of cpu_is_mx27() removal]
Currently soc-camera has a per-device node lock, used for video operations
and a per-host lock for code paths, modifying host's pipeline. Manipulating
the two locks increases complexity and doesn't bring any advantages. This
patch removes the per-device lock and uses the per-host lock for all
operations.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Signed-off-by: Jorrit Schippers <jorrit@ncode.nl>
Linux 3.8-rc1
* tag 'v3.8-rc1': (10696 commits)
Linux 3.8-rc1
Revert "nfsd: warn on odd reply state in nfsd_vfs_read"
ARM: dts: fix duplicated build target and alphabetical sort out for exynos
dm stripe: add WRITE SAME support
dm: remove map_info
dm snapshot: do not use map_context
dm thin: dont use map_context
dm raid1: dont use map_context
dm flakey: dont use map_context
dm raid1: rename read_record to bio_record
dm: move target request nr to dm_target_io
dm snapshot: use per_bio_data
dm verity: use per_bio_data
dm raid1: use per_bio_data
dm: introduce per_bio_data
dm kcopyd: add WRITE SAME support to dm_kcopyd_zero
dm linear: add WRITE SAME support
dm: add WRITE SAME support
dm: prepare to support WRITE SAME
dm ioctl: use kmalloc if possible
MAINTAINERS
Convert drivers using wall clock time (CLOCK_REALTIME) to timestamp from the
monotonic timer (CLOCK_MONOTONIC).
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
The CSI on i.MX27 has some constraints regarding image width.
This patch makes sure those requirements are met in try_fmt().
[g.liakhovetski@gmx.de: make constraint i.MX27-specific]
Pull ARM SoC updates from Olof Johansson:
"This contains the bulk of new SoC development for this merge window.
Two new platforms have been added, the sunxi platforms (Allwinner A1x
SoCs) by Maxime Ripard, and a generic Broadcom platform for a new
series of ARMv7 platforms from them, where the hope is that we can
keep the platform code generic enough to have them all share one mach
directory. The new Broadcom platform is contributed by Christian
Daudt.
Highbank has grown support for Calxeda's next generation of hardware,
ECX-2000.
clps711x has seen a lot of cleanup from Alexander Shiyan, and he's
also taken on maintainership of the platform.
Beyond this there has been a bunch of work from a number of people on
converting more platforms to IRQ domains, pinctrl conversion, cleanup
and general feature enablement across most of the active platforms."
Fix up trivial conflicts as per Olof.
* tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (174 commits)
mfd: vexpress-sysreg: Remove LEDs code
irqchip: irq-sunxi: Add terminating entry for sunxi_irq_dt_ids
clocksource: sunxi_timer: Add terminating entry for sunxi_timer_dt_ids
irq: versatile: delete dangling variable
ARM: sunxi: add missing include for mdelay()
ARM: EXYNOS: Avoid early use of of_machine_is_compatible()
ARM: dts: add node for PL330 MDMA1 controller for exynos4
ARM: EXYNOS: Add support for secondary CPU bring-up on Exynos4412
ARM: EXYNOS: add UART3 to DEBUG_LL ports
ARM: S3C24XX: Add clkdev entry for camif-upll clock
ARM: SAMSUNG: Add s3c24xx/s3c64xx CAMIF GPIO setup helpers
ARM: sunxi: Add missing sun4i.dtsi file
pinctrl: samsung: Do not initialise statics to 0
ARM i.MX6: remove gate_mask from pllv3
ARM i.MX6: Fix ethernet PLL clocks
ARM i.MX6: rename PLLs according to datasheet
ARM i.MX6: Add pwm support
ARM i.MX51: Add pwm support
ARM i.MX53: Add pwm support
ARM: mx5: Replace clk_register_clkdev with clock DT lookup
Pull ARM SoC cleanups on various subarchitectures from Olof Johansson:
"Cleanup patches for various ARM platforms and some of their associated
drivers. There's also a branch in here that enables Freescale i.MX to
be part of the multiplatform support -- the first "big" SoC that is
moved over (more multiplatform work comes in a separate branch later
during the merge window)."
Conflicts fixed as per Olof, including a silent semantic one in
arch/arm/mach-omap2/board-generic.c (omap_prcm_restart() was renamed to
omap3xxx_restart(), and a new user of the old name was added).
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (189 commits)
ARM: omap: fix typo on timer cleanup
ARM: EXYNOS: Remove unused regs-mem.h file
ARM: EXYNOS: Remove unused non-dt support for dwmci controller
ARM: Kirkwood: Use hw_pci.ops instead of hw_pci.scan
ARM: OMAP3: cm-t3517: use GPTIMER for system clock
ARM: OMAP2+: timer: remove CONFIG_OMAP_32K_TIMER
ARM: SAMSUNG: use devm_ functions for ADC driver
ARM: EXYNOS: no duplicate mask/unmask in eint0_15
ARM: S3C24XX: SPI clock channel setup is fixed for S3C2443
ARM: EXYNOS: Remove i2c0 resource information and setting of device names
ARM: Kirkwood: checkpatch cleanups
ARM: Kirkwood: Fix sparse warnings.
ARM: Kirkwood: Remove unused includes
ARM: kirkwood: cleanup lsxl board includes
ARM: integrator: use BUG_ON where possible
ARM: integrator: push down SC dependencies
ARM: integrator: delete static UART1 mapping
ARM: integrator: delete SC mapping on the CP
ARM: integrator: remove static CP syscon mapping
ARM: integrator: remove static AP syscon mapping
Found using the following semantic patch:
<spml>
spin_lock_irqsave(...);
... when != spin_unlock_irqrestore(...);
* GFP_KERNEL
</spml>
Signed-off-by: Cyril Roelandt <tipecaml@gmail.com>
Add the missing unlock on the error handle path in function
mx2_start_streaming().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
A recent commit "[media] v4l2: make vidioc_s_crop const" introduced
warnings in mx2_camera. Fix them by cleanly separating writable and
read-only variables in cropping operations.
Since mx27 transitioned to the commmon clock framework in 3.5, the correct way
to acquire the csi clock is to get csi_ahb and csi_per clocks separately.
By not doing so the camera sensor does not probe correctly:
soc-camera-pdrv soc-camera-pdrv.0: Probing soc-camera-pdrv.0
mx2-camera mx2-camera.0: Camera driver attached to camera 0
ov2640 0-0030: Product ID error fb:fb
mx2-camera mx2-camera.0: Camera driver detached from camera 0
mx2-camera mx2-camera.0: MX2 Camera (CSI) driver probed, clock frequency: 66500000
Adapt the mx2_camera driver to the new clock framework and make it functional
again.
Tested-by: Gaëtan Carlier <gcembed@gmail.com>
Tested-by: Javier Martin <javier.martin@vista-silicon.com>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
It changes the driver to use platform_device_id rather than cpu_is_xxx
to determine the controller type, and updates the platform code
accordingly.
As the result, mach/hardware.h inclusion gets removed from the driver.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: linux-media@vger.kernel.org
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
[mchehab@redhat.com: Second hunk removed, as it doesn't apply anymore,
due to a merge conflict]
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
[g.liakhovetski@gmx.de: also don't clear pcdev->resizing in .try_fmt()]
* samsung_platform_data:
ARM: samsung: move platform_data definitions
ARM: orion: move platform_data definitions
ARM: nomadik: move platform_data definitions
ARM: w90x900: move platform_data definitions
ARM: vt8500: move platform_data definitions
ARM: tegra: move sdhci platform_data definition
ARM: sa1100: move platform_data definitions
ARM: pxa: move platform_data definitions
ARM: netx: move platform_data definitions
ARM: msm: move platform_data definitions
ARM: imx: move platform_data definitions
ARM: ep93xx: move platform_data definitions
ARM: davinci: move platform_data definitions
ARM: at91: move platform_data definitions
Use managed functions to clean up the error handling code and function
mx2_camera_remove(). Along with the change, a few variables get removed
from struct mx2_camera_dev.
This is a piece of code becoming dead since commit 2c9ba37 ([media]
V4L: mx2_camera: remove unsupported i.MX27 DMA mode, make EMMA
mandatory). It should have been removed together with the commit.
Remove it now.
Acked-by: Javier Martin <javier.martin@vista-silicon.com>
That helps to better organize the soc_camera items.
While here, cleanup Makefiles, removing uneeded include dirs.
