path: root/drivers/media/platform/omap24xxcam.c
2013-01-24Merge branch 'v4l_for_linus' into staging/for_v3.9Mauro Carvalho Chehab
* v4l_for_linus: (464 commits) [media] uvcvideo: Set error_idx properly for S_EXT_CTRLS failures [media] uvcvideo: Cleanup leftovers of partial revert [media] uvcvideo: Return -EACCES when trying to set a read-only control Linux 3.8-rc3 mm: reinstante dropped pmd_trans_splitting() check cred: Remove tgcred pointer from struct cred drm/ttm: fix fence locking in ttm_buffer_object_transfer ARM: clps711x: Fix bad merge of clockevents setup ARM: highbank: save and restore L2 cache and GIC on suspend ARM: highbank: add a power request clear ARM: highbank: fix secondary boot and hotplug ARM: highbank: fix typos with hignbank in power request functions ARM: dts: fix highbank cpu mpidr values ARM: dts: add device_type prop to cpu nodes on Calxeda platforms drm/prime: drop reference on imported dma-buf come from gem xen/netfront: improve truesize tracking ARM: mx5: Fix MX53 flexcan2 clock ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array sctp: fix Kconfig bug in default cookie hmac selection EDAC: Cleanup device deregistering path ... Conflicts: drivers/media/pci/dm1105/dm1105.c drivers/media/platform/soc_camera/mx2_camera.c
2013-01-03Drivers: media: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-21[media] v4l: Convert drivers to use monotonic timestampsSakari Ailus
Convert drivers using wall clock time (CLOCK_REALTIME) to timestamp from the monotonic timer (CLOCK_MONOTONIC). Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-07Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "The first part of the media updates for Kernel 3.7. This series contain: - A major tree renaming patch series: now, drivers are organized internally by their used bus, instead of by V4L2 and/or DVB API, providing a cleaner driver location for hybrid drivers that implement both APIs, and allowing to cleanup the Kconfig items and make them more intuitive for the end user; - Media Kernel developers are typically very lazy with their duties of keeping the MAINTAINERS entries for their drivers updated. As now the tree is more organized, we're doing an effort to add/update those entries for the drivers that aren't currently orphan; - Several DVB USB drivers got moved to a new DVB USB v2 core; the new core fixes several bugs (as the existing one that got bitroted). Now, suspend/resume finally started to work fine (at least with some devices - we should expect more work with regards to it); - added multistream support for DVB-T2, and unified the API for DVB-S2 and ISDB-S. Backward binary support is preserved; - as usual, a few new drivers, some V4L2 core improvements and lots of drivers improvements and fixes. There are some points to notice on this series: 1) you should expect a trivial merge conflict on your tree, with the removal of Documentation/feature-removal-schedule.txt: this series would be adding two additional entries there. I opted to not rebase it due to this recent change; 2) With regards to the PCTV 520e udev-related breakage, I opted to fix it in a way that the patches can be backported to 3.5 even without your firmware fix patch. This way, Greg doesn't need to rush backporting your patch (as there are still the firmware cache and firmware path customization issues to be addressed there). I'll send later a patch (likely after the end of the merge window) reverting the rest of the DRX-K async firmware request, fully restoring its original behaviour to allow media drivers to initialize everything serialized as before for 3.7 and upper. 3) I'm planning to work on this weekend to test the DMABUF patches for V4L2. The patches are on my queue for several Kernel cycles, but, up to now, there is/was no way to test the series locally. I have some concerns about this particular changeset with regards to security issues, and with regards to the replacement of the old VIDIOC_OVERLAY ioctl's that is broken on modern systems, due to GPU drivers change. The Overlay API allows direct PCI2PCI transfers from a media capture card into the GPU framebuffer, but its API is crappy. Also, the only existing X11 driver that implements it requires a XV extension that is not available anymore on modern drivers. The DMABUF can do the same thing, but with it is promising to be a properly-designed API. If I can successfully test this series and be happy with it, I should be asking you to pull them next week." * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (717 commits) em28xx: regression fix: use DRX-K sync firmware requests on em28xx drxk: allow loading firmware synchrousnously em28xx: Make all em28xx extensions to be initialized asynchronously [media] tda18271: properly report read errors in tda18271_get_id [media] tda18271: delay IR & RF calibration until init() if delay_cal is set [media] MAINTAINERS: add Michael Krufky as tda827x maintainer [media] MAINTAINERS: add Michael Krufky as tda8290 maintainer [media] MAINTAINERS: add Michael Krufky as cxusb maintainer [media] MAINTAINERS: add Michael Krufky as lg2160 maintainer [media] MAINTAINERS: add Michael Krufky as lgdt3305 maintainer [media] MAINTAINERS: add Michael Krufky as mxl111sf maintainer [media] MAINTAINERS: add Michael Krufky as mxl5007t maintainer [media] MAINTAINERS: add Michael Krufky as tda18271 maintainer [media] s5p-tv: Report only multi-plane capabilities in vidioc_querycap [media] s5p-mfc: Fix misplaced return statement in s5p_mfc_suspend() [media] exynos-gsc: Add missing static storage class specifiers [media] exynos-gsc: Remove <linux/version.h> header file inclusion [media] s5p-fimc: Fix incorrect condition in fimc_lite_reqbufs() [media] s5p-tv: Fix potential NULL pointer dereference error [media] s5k6aa: Fix possible NULL pointer dereference ...
2012-08-15[media] rename drivers/media/video as .../platformMauro Carvalho Chehab
The remaining drivers are mostly platform drivers. Name the dir to reflect it. It makes sense to latter break it into a few other dirs. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
