path: root/drivers/media/platform/blackfin
2013-03-24[media] v4l2: add const to argument of write-only s_register ioctlHans Verkuil
This ioctl is defined as IOW, so pass the argument as const. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-24[media] v4l2: pass std by value to the write-only s_std ioctlHans Verkuil
This ioctl is defined as IOW, so pass the argument by value instead of by reference. I could have chosen to add const instead, but this is 1) easier to handle in drivers and 2) consistent with the s_std subdev operation. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-19[media] blackfin: replace V4L2_IN/OUT_CAP_CUSTOM_TIMINGS by DV_TIMINGSHans Verkuil
The use of V4L2_IN/OUT_CAP_CUSTOM_TIMINGS is obsolete, use DV_TIMINGS instead. Note that V4L2_IN/OUT_CAP_CUSTOM_TIMINGS is just a #define for V4L2_IN/OUT_CAP_DV_TIMINGS. At some point in the future these CUSTOM_TIMINGS defines might be removed. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-05[media] vb2: Add support for non monotonic timestampsKamil Debski
Not all drivers use monotonic timestamps. This patch adds a way to set the timestamp type per every queue. In addition, set proper timestamp type in drivers that I am sure that use either MONOTONIC or COPY timestamps. Other drivers will correctly report UNKNOWN timestamp type instead of assuming that all drivers use monotonic timestamps. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-06[media] blackfin: add error frame supportScott Jiang
Mark current frame as error frame when ppi error interrupt report fifo error. Member next_frm in struct bcap_device can be optimized out. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-24Merge branch 'v4l_for_linus' into staging/for_v3.9Mauro Carvalho Chehab
* v4l_for_linus: (464 commits) [media] uvcvideo: Set error_idx properly for S_EXT_CTRLS failures [media] uvcvideo: Cleanup leftovers of partial revert [media] uvcvideo: Return -EACCES when trying to set a read-only control Linux 3.8-rc3 mm: reinstante dropped pmd_trans_splitting() check cred: Remove tgcred pointer from struct cred drm/ttm: fix fence locking in ttm_buffer_object_transfer ARM: clps711x: Fix bad merge of clockevents setup ARM: highbank: save and restore L2 cache and GIC on suspend ARM: highbank: add a power request clear ARM: highbank: fix secondary boot and hotplug ARM: highbank: fix typos with hignbank in power request functions ARM: dts: fix highbank cpu mpidr values ARM: dts: add device_type prop to cpu nodes on Calxeda platforms drm/prime: drop reference on imported dma-buf come from gem xen/netfront: improve truesize tracking ARM: mx5: Fix MX53 flexcan2 clock ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array sctp: fix Kconfig bug in default cookie hmac selection EDAC: Cleanup device deregistering path ... Conflicts: drivers/media/pci/dm1105/dm1105.c drivers/media/platform/soc_camera/mx2_camera.c
2013-01-03Drivers: media: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-27[media] blackfin Kconfig: select is evil; use, instead depends onMauro Carvalho Chehab
Select is evil as it has issues with dependencies. Better to convert it to use depends on. That fixes a breakage with out-of-tree compilation of the media tree. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-26[media] v4l2: blackfin: add EPPI3 supportScott Jiang
Bf60x soc has a new PPI called Enhanced PPI version 3. HD video is supported now. To achieve this, we redesign ppi params and add dv timings feature. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-26[media] v4l2: blackfin: convert ppi driver to a moduleScott Jiang
Other drivers can make use of it. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-21[media] v4l: Convert drivers to use monotonic timestampsSakari Ailus
Convert drivers using wall clock time (CLOCK_REALTIME) to timestamp from the monotonic timer (CLOCK_MONOTONIC). Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-27[media] media/bfin: use module_platform_driver macroSrinivas Kandagatla
This patch removes some code duplication by using module_platform_driver. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-23[media] drivers/media/platform/blackfin/bfin_capture.c: fix error return codePeter Senna Tschudin
Convert a nonnegative error return code to a negative one, as returned elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Cc: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] rename drivers/media/video as .../platformMauro Carvalho Chehab
The remaining drivers are mostly platform drivers. Name the dir to reflect it. It makes sense to latter break it into a few other dirs. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
