path: root/drivers/media/firewire
2013-04-08[media] demux.h: Remove duplicated enumMauro Carvalho Chehab
"enum dmx_ts_pes" and "typedef enum dmx_pes_type_t" are just the same enum declared twice, since Kernel (2.6.12). There's no reason to duplicate it there, and sparse complains about that: drivers/media/dvb-core/dmxdev.c:600:55: warning: mixing different enum types So, remove the internal define, keeping just the external one. Internally, use only "enum dmx_ts_pes", as it is too late to drop dmx_pes_type_t from the userspace API. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-19[media] remove include/linux/dvb/dmx.hMauro Carvalho Chehab
The only reason for this header is to make sure that include linux/time.h were added before uapi/*/dmx.h. Just push down the time.h header on the few places where this is used, and drop this new header. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-16[media] Fix some Makefile rulesMauro Carvalho Chehab
On a few places, := were using instead of +=, causing drivers to not compile. While here, standardize the usage of += on all cases where multiple lines are needed, and for obj-y/obj-m targets, and := when just one line is needed, on <module>-obj rules. Reported-by: Hans Verkuil <hverkuil@xs4all.nl> Identified-by: Antti Polosaari <crope@iki.fi> Tested-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] firewire: move it one level upMauro Carvalho Chehab
Move firewire to one level up, as the dvb subdirectory will be removed. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
