path: root/drivers/media/dvb-core
2013-07-28media: dmxdev: remove dvb_ringbuffer_flush() on writer sideSoeren Moch
commit 414abbd2cd4c2618895f02ed3a76ec6647281436 upstream. In dvb_ringbuffer lock-less synchronizationof reader and writer threads is done with separateread and write pointers. Sincedvb_ringbuffer_flush() modifies the read pointer, this function must not be called from the writer thread. This patch removes the dvb_ringbuffer_flush() calls in the dmxdev ringbuffer write functions, this fixes Oopses "Unable to handle kernel paging request" I could observe for the call chaindvb_demux_read ->dvb_dmxdev_buffer_read -> dvb_ringbuffer_read_user -> __copy_to_user (the reader side of the ringbuffer). The flush calls at the write side are not necessary anyway since ringbuffer_flush is also called in dvb_dmxdev_buffer_read() when an error condition is set in the ringbuffer. This patch should also be applied to stable kernels. Signed-off-by: Soeren Moch <smoch@web.de> Reviewed-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-04-29dvb_frontend: don't mess with ->f_op in ->release()Al Viro
2013-04-29dvb_net: don't mess with ->f_op in ->release()Al Viro
2013-04-22[media] dib7090p: remove the support for the dib7090EOlivier Grenie
The intend of this patch is to remove the support for the dib7090E. The DiB7090E-package has never left prototype state and never made it to mass-prod-state. Signed-off-by: Olivier Grenie <olivier.grenie@parrot.com> Signed-off-by: Patrick Boettcher <patrick.boettcher@parrot.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-14[media] tuner-core/simple: get_rf_strength can be tuner mode specificHans Verkuil
The get_rf_strength op in tuner-simple is valid only for the radio mode. But due to the way get_signal in analog_demod_ops was designed it would overwrite the signal value with a bogus value when in TV mode. Pass a pointer to the signal value instead, and when not in radio mode leave it alone in the tuner-simple. This broke in commit 030755bde42bbed133182b0ece7c7a9c759478e8 (tuner-core: call has_signal for both TV and radio) in kernel 3.6. Before that this was working correctly. That commit did the right thing, but what wasn't realized at the time was that tuner-simple should have been updated as well to restrict setting the signal strength to the radio mode only. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-14[media] tuner-core/tda9887: get_afc can be tuner mode specificHans Verkuil
The get_afc op in tda9887 is valid only for the radio mode. But due to the way get_afc in analog_demod_ops was designed it would overwrite the afc value with a bogus value when in TV mode. Pass a pointer to the afc value instead, and when not in radio mode leave it alone in the tda9887. This broke a long time ago in 2.6.19 when the get_afc op was introduced. Before that the afc was only set for radio mode in the tda9887. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-08[media] demux.h: Remove duplicated enumMauro Carvalho Chehab
"enum dmx_ts_pes" and "typedef enum dmx_pes_type_t" are just the same enum declared twice, since Kernel (2.6.12). There's no reason to duplicate it there, and sparse complains about that: drivers/media/dvb-core/dmxdev.c:600:55: warning: mixing different enum types So, remove the internal define, keeping just the external one. Internally, use only "enum dmx_ts_pes", as it is too late to drop dmx_pes_type_t from the userspace API. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-28net: add ETH_P_802_3_MINSimon Horman
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for an 802.3 frame. Frames with a lower value in the ethernet type field are Ethernet II. Also update all the users of this value that David Miller and I could find to use the new constant. Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN should be >= not >. As suggested by Jesse Gross. Compile tested only. Cc: David Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: John W. Linville <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Bart De Schuymer <bart.de.schuymer@pandora.be> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: linux-bluetooth@vger.kernel.org Cc: netfilter-devel@vger.kernel.org Cc: bridge@lists.linux-foundation.org Cc: linux-wireless@vger.kernel.org Cc: linux1394-devel@lists.sourceforge.net Cc: linux-media@vger.kernel.org Cc: netdev@vger.kernel.org Cc: dev@openvswitch.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-21[media] dvb-core: don't clear stats at DTV_CLEARMauro Carvalho Chehab
The stats are cleared by the frontend. Don't do it at DTV_CLEAR. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-19[media] dvb_demux: Transport stream continuity check fixJohn Smith
This patch avoids incrementing continuity counter demux->cnt_storage[pid] for TS packets without payload in accordance with ISO /IEC 13818-1. [mchehab@redhat.com: unmangle whitespacing and fix CodingStyle. Also checked ISO/IEC spec: patch is according with it] Reviewed-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: John Smith <johns90812@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-18[media] dvb_frontend: Simplify the emulation logicMauro Carvalho Chehab
The current logic was broken and too complex; while it works fine for DVB-S2/DVB-S, it is broken for ISDB-T. Make the logic simpler, fixes it for ISDB-T and make it clearer. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-18[media] dvb-frontend: split set_delivery_system()Mauro Carvalho Chehab
This function is complex, and has different workflows, one for DVBv3 calls, and another one for DVBv5 calls. Break it into 3 functions, in order to make easier to understand what each block does. No functional changes so far. A few comments got improved. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-04[media] mb86a20s: change AGC tuning parametersMauro Carvalho Chehab
Use the AGC settings present on a newer device. The initial settings were taken from one of the first devices with mb86a20s, and there are several reports that this is not working properly on some places. So, instead of keeping using it, get the parameters taken from a newer device. Tests are welcomed. Tested also with cx231xx PixelView SBTVD Hybrid with no regressions noticed so far. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Some cleanups at V4L2 documentation - new drivers: ts2020 frontend, ov9650 sensor, s5c73m3 sensor, sh-mobile veu mem2mem driver, radio-ma901, davinci_vpfe staging driver - Lots of missing MAINTAINERS entries added - several em28xx driver improvements, including its conversion to videobuf2 - several fixups on drivers to make them to better comply with the API - DVB core: add support for DVBv5 stats, allowing the implementation of statistics for new standards like ISDB - mb86a20s: add statistics to the driver - lots of new board additions, cleanups, and driver improvements. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (596 commits) [media] media: Add 0x3009 USB PID to ttusb2 driver (fixed diff) [media] rtl28xxu: Add USB IDs for Compro VideoMate U620F [media] em28xx: add usb id for terratec h5 rev. 3 [media] media: rc: gpio-ir-recv: add support for device tree parsing [media] mceusb: move check earlier to make smatch happy [media] radio-si470x doc: add info about v4l2-ctl and sox+alsa [media] staging: media: Remove unnecessary OOM messages [media] sh_vou: Use vou_dev instead of vou_file wherever possible [media] sh_vou: Use video_drvdata() [media] drivers/media/platform/soc_camera/pxa_camera.c: use devm_ functions [media] mt9t112: mt9t111 format set up differs from mt9t112 [media] sh-mobile-ceu-camera: fix SHARPNESS control default Revert "[media] fc0011: Return early, if the frequency is already tuned" [media] cx18/ivtv: fix regression: remove __init from a non-init function [media] em28xx: fix analog streaming with USB bulk transfers [media] stv0900: remove unnecessary null pointer check [media] fc0011: Return early, if the frequency is already tuned [media] fc0011: Add some sanity checks and cleanups [media] fc0011: Fix xin value clamping Revert "[media] [PATH,1/2] mxl5007 move reset to attach" ...
2013-02-15Revert "[media] dvb_frontend: return -ENOTTY for unimplement IOCTL"Mauro Carvalho Chehab
As reported by Klaus Schmidinger: "In VDR I use an ioctl() call with FE_READ_UNCORRECTED_BLOCKS on a device (using stb0899). After this call I check 'errno' for EOPNOTSUPP to determine whether this device supports this call. This used to work just fine, until a few months ago I noticed that my devices using stb0899 didn't display their signal quality in VDR's OSD any more. After further investigation I found that ioctl(FE_READ_UNCORRECTED_BLOCKS) no longer returns EOPNOTSUPP, but rather ENOTTY. And since I stop getting the signal quality in case any unknown errno value appears, this broke my signal quality query function." While the changes reflect what is there at: http://comments.gmane.org/gmane.linux.kernel/1235728 it does cause regression on userspace. So, revert it to stop the damage. This reverts commit 177ffe506cf8 ("[media] dvb_frontend: return -ENOTTY for unimplement IOCTL"). Reported-by: Klaus Schmidinger <Klaus.Schmidinger@tvdr.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-13[media] media: Add 0x3009 USB PID to ttusb2 driver (fixed diff)Christoph Nuscheler
The "Technisat SkyStar USB plus" is a TT-connect S-2400 clone, which the V4L-DVB drivers already support. However, some of these devices (like mine) come with a different USB PID 0x3009 instead of 0x3006. There have already been patches simply overwriting the USB PID in dvb-usb-ids.h. Of course these patches were rejected because they would have disabled the 0x3006 PID. This new patch adds the 0x3009 PID to dvb-usb-ids.h, and adds references to it within the ttusb2.c driver. PID 0x3006 devices will continue to work. The only difference between the two hardware models seems to be the EEPROM chip. In fact, Windows BDA driver names the 0x3009 device with a "(8 kB EEPROM)" suffix. In spite of that, the 0x3009 device works absolutely flawlessly using the existing ttusb2 driver. Signed-off-by: Christoph Nuscheler <christoph.nuscheler@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-23[media] dvb_frontend: print a msg if a property doesn't existMauro Carvalho Chehab
If userspace calls a property that doesn't exist, it currently just returns -EINVAL. However, this is more likely a problem at the userspace application, calling it with a non-existing property. So, add a debug message to help tracking it. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-23[media] dvb: the core logic to handle the DVBv5 QoS propertiesMauro Carvalho Chehab
Add the logic to poll, reset counters and report the QoS stats to the end user. The idea is that the core will periodically poll the frontend for the stats. The frontend may return -EBUSY, if the previous collect didn't finish, or it may fill the cached data. The value returned to the end user is always the cached data. Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-06[media] dvb: unlock on error in dvb_ca_en50221_io_do_ioctl()Dan Carpenter
We recently pushed the locking down into this function, but there was an error path where the unlock was missed. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-27[media] it913x: add support for Avermedia A835BEddi De Pieri
Add support for Avermedia A835B and variants. Signed-off-by: Eddi De Pieri <eddi@depieri.net> Cc: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-27[media] dvb-core: Replace memcpy with struct assignmentEzequiel Garcia
This kind of memcpy() is error-prone. Its replacement with a struct assignment is prefered because it's type-safe and much easier to read. Found by coccinelle. Hand patched and reviewed. Tested by compilation only. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier struct_name; struct struct_name to; struct struct_name from; expression E; @@ -memcpy(&(to), &(from), E); +to = from; // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-27[media] m920x: add support for the VP-7049 Twinhan DVB-T USB StickAntonio Ospite
This device was originally made by Twinhan/Azurewave[1] and sometimes named DTV-DVB UDTT7049, it could be also found in Italy under the name of Digicom Digitune-S[2], or Think Xtra Hollywood DVB-T USB2.0[3]. Components: Usb bridge: ULi M9206 Frontend: MT352CG Tuner: MT2060F The firmware can be downloaded with: $ ./Documentation/dvb/get_dvb_firmware vp7049 [1] http://www.azurewave.com/Support_Utility_Driver.asp [2] http://www.digicom.it/digisit/driver_link.nsf/driverprodotto?openform&prodotto=DigiTuneS [3] http://www.txitalia.it/prodotto.asp?prodotto=txhollywooddvttv Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-27[media] dvb: push down ioctl lock in dvb_usercopyNikolaus Schulz
Since most dvb ioctls wrap their real work with dvb_usercopy, the static mutex used in dvb_usercopy effectively is a global lock for dvb ioctls. Unfortunately, frontend ioctls can be blocked by the frontend thread for several seconds; this leads to unacceptable lock contention. Mitigate that by pushing the mutex from dvb_usercopy down to the individual, device specific ioctls. There are 10 such ioctl functions using dvb_usercopy, either calling it directly, or via the trivial wrapper dvb_generic_ioctl. The following already employ their own locking and look safe: • dvb_demux_ioctl (as per dvb_demux_do_ioctl) • dvb_dvr_ioctl (as per dvb_dvr_do_ioctl) • dvb_osd_ioctl (as per single non-trivial callee) • fdtv_ca_ioctl (as per callees) • dvb_frontend_ioctl The following functions do not, and are thus changed to use a device specific mutex: • dvb_net_ioctl (as per dvb_net_do_ioctl) • dvb_ca_en50221_io_ioctl (as per dvb_ca_en50221_io_do_ioctl) • dvb_video_ioctl • dvb_audio_ioctl • dvb_ca_ioctl Signed-off-by: Nikolaus Schulz <schulz@macnetix.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-27[media] dvb_frontend: fix ioctls failing if frontend open/closed too fastJuergen Lock
That likely fixes this MythTV ticket: http://code.mythtv.org/trac/ticket/10830 (which btw affects all usb tuners I tested as well, pctv452e, dib0700, af9015) pctv452e is still possibly broken with MythTV even after this fix; it does work with VDR here tho despite I2C errors. Reduced testcase: http://people.freebsd.org/~nox/tmp/ioctltst.c Thanx to devinheitmueller and crope from #linuxtv for helping with this fix! :) Signed-off-by: Juergen Lock <nox@jelal.kn-bremen.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-11-28[media] rtl28xxu: add NOXON DAB/DAB+ USB dongle rev 2Juergen Lock
This just adds the usbid to the rtl28xxu driver, that's all that's needed to make the stick work for DVB. Signed-off-by: Juergen Lock <nox@jelal.kn-bremen.de> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-28[media] dmxdev: fix a comparition of unsigned expression warningMauro Carvalho Chehab
drivers/media/dvb-core/dmxdev.c: In function 'dvb_dmxdev_pes_filter_set': drivers/media/dvb-core/dmxdev.c:880:2: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-28[media] dvb_frontend: Don't declare values twice at a tableMauro Carvalho Chehab
drivers/media/dvb-core/dvb_frontend.c:1032:2: warning: initialized field overwritten [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1032:2: warning: (near initialization for 'dtv_cmds[36]') [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1033:2: warning: initialized field overwritten [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1033:2: warning: (near initialization for 'dtv_cmds[37]') [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1034:2: warning: initialized field overwritten [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1034:2: warning: (near initialization for 'dtv_cmds[38]') [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1035:2: warning: initialized field overwritten [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1035:2: warning: (near initialization for 'dtv_cmds[39]') [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1036:2: warning: initialized field overwritten [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1036:2: warning: (near initialization for 'dtv_cmds[40]') [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1037:2: warning: initialized field overwritten [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1037:2: warning: (near initialization for 'dtv_cmds[60]') [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1045:2: warning: initialized field overwritten [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1045:2: warning: (near initialization for 'dtv_cmds[46]') [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1051:2: warning: initialized field overwritten [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1051:2: warning: (near initialization for 'dtv_cmds[52]') [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1060:2: warning: initialized field overwritten [-Woverride-init] drivers/media/dvb-core/dvb_frontend.c:1060:2: warning: (near initialization for 'dtv_cmds[61]') [-Woverride-init] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-19[media] remove include/linux/dvb/dmx.hMauro Carvalho Chehab
The only reason for this header is to make sure that include linux/time.h were added before uapi/*/dmx.h. Just push down the time.h header on the few places where this is used, and drop this new header. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-11Merge branch 'staging/for_v3.7' into v4l_for_linusMauro Carvalho Chehab
Applied on the top of changeset 782cd9e, as some of those patches depend on some fixes that went via -arm tree. * staging/for_v3.7: (109 commits) [media] m5mols: Add missing #include <linux/sizes.h> [media] stk1160: Add support for S-Video input Revert "[media] omap3isp: Replace cpu_is_omap3630() with ISP revision check" [media] dvb: LNA implementation changes [media] v4l2-ioctl: fix W=1 warnings [media] v4l2-ioctl: add blocks check for VIDIOC_SUBDEV_G/S_EDID [media] omap3isp: Fix compilation error in ispreg.h [media] rc-msi-digivox-ii: Add full scan keycodes [media] cx25821: testing the wrong variable [media] tda18271-common: hold the I2C adapter during write transfers [media] ds3000: add module parameter to force firmware upload [media] drivers/media: Remove unnecessary semicolon [media] winbond: remove space from driver name [media] iguanair: cannot send data from the stack [media] omap3isp: Replace cpu_is_omap3630() with ISP revision check [media] dvb-usb: print small buffers via %*ph [media] uvc: Add return code check at vb2_queue_init() [media] em28xx: Replace memcpy with struct assignment [media] bt8xx: Add video4linux control V4L2_CID_COLOR_KILLER [media] mem2mem_testdev: Use devm_kzalloc() in probe ...
2012-10-07[media] dvb: LNA implementation changesAntti Palosaari
* use dvb property cache * implement get (thus API minor++) * PCTV 290e: 1=LNA ON, all the other values LNA OFF Also fix PCTV 290e LNA comment, it is disabled by default Hans and Mauro proposed use of cache implementation of get as they were planning to extend LNA usage for analog side too. Reported-by: Hans Verkuil <hverkuil@xs4all.nl> Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Antti Palosaari <crope@iki.fi> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-07[media] drivers/media: Remove unnecessary semicolonPeter Senna Tschudin
A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r1@ statement S; position p,p1; @@ S@p1;@p @script:python r2@ p << r1.p; p1 << r1.p1; @@ if p[0].line != p1[0].line_end: cocci.include_match(False) @@ position r1.p; @@ -;@p // </smpl> [mchehab@redhat.com: some hunks got bitroted; applied only the ones that succeeds] Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> [crope@iki.fi: For my drivers a8293, af9013, af9015, af9035] Acked-by: Antti Palosaari <crope@iki.fi> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-07Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "The first part of the media updates for Kernel 3.7. This series contain: - A major tree renaming patch series: now, drivers are organized internally by their used bus, instead of by V4L2 and/or DVB API, providing a cleaner driver location for hybrid drivers that implement both APIs, and allowing to cleanup the Kconfig items and make them more intuitive for the end user; - Media Kernel developers are typically very lazy with their duties of keeping the MAINTAINERS entries for their drivers updated. As now the tree is more organized, we're doing an effort to add/update those entries for the drivers that aren't currently orphan; - Several DVB USB drivers got moved to a new DVB USB v2 core; the new core fixes several bugs (as the existing one that got bitroted). Now, suspend/resume finally started to work fine (at least with some devices - we should expect more work with regards to it); - added multistream support for DVB-T2, and unified the API for DVB-S2 and ISDB-S. Backward binary support is preserved; - as usual, a few new drivers, some V4L2 core improvements and lots of drivers improvements and fixes. There are some points to notice on this series: 1) you should expect a trivial merge conflict on your tree, with the removal of Documentation/feature-removal-schedule.txt: this series would be adding two additional entries there. I opted to not rebase it due to this recent change; 2) With regards to the PCTV 520e udev-related breakage, I opted to fix it in a way that the patches can be backported to 3.5 even without your firmware fix patch. This way, Greg doesn't need to rush backporting your patch (as there are still the firmware cache and firmware path customization issues to be addressed there). I'll send later a patch (likely after the end of the merge window) reverting the rest of the DRX-K async firmware request, fully restoring its original behaviour to allow media drivers to initialize everything serialized as before for 3.7 and upper. 3) I'm planning to work on this weekend to test the DMABUF patches for V4L2. The patches are on my queue for several Kernel cycles, but, up to now, there is/was no way to test the series locally. I have some concerns about this particular changeset with regards to security issues, and with regards to the replacement of the old VIDIOC_OVERLAY ioctl's that is broken on modern systems, due to GPU drivers change. The Overlay API allows direct PCI2PCI transfers from a media capture card into the GPU framebuffer, but its API is crappy. Also, the only existing X11 driver that implements it requires a XV extension that is not available anymore on modern drivers. The DMABUF can do the same thing, but with it is promising to be a properly-designed API. If I can successfully test this series and be happy with it, I should be asking you to pull them next week." * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (717 commits) em28xx: regression fix: use DRX-K sync firmware requests on em28xx drxk: allow loading firmware synchrousnously em28xx: Make all em28xx extensions to be initialized asynchronously [media] tda18271: properly report read errors in tda18271_get_id [media] tda18271: delay IR & RF calibration until init() if delay_cal is set [media] MAINTAINERS: add Michael Krufky as tda827x maintainer [media] MAINTAINERS: add Michael Krufky as tda8290 maintainer [media] MAINTAINERS: add Michael Krufky as cxusb maintainer [media] MAINTAINERS: add Michael Krufky as lg2160 maintainer [media] MAINTAINERS: add Michael Krufky as lgdt3305 maintainer [media] MAINTAINERS: add Michael Krufky as mxl111sf maintainer [media] MAINTAINERS: add Michael Krufky as mxl5007t maintainer [media] MAINTAINERS: add Michael Krufky as tda18271 maintainer [media] s5p-tv: Report only multi-plane capabilities in vidioc_querycap [media] s5p-mfc: Fix misplaced return statement in s5p_mfc_suspend() [media] exynos-gsc: Add missing static storage class specifiers [media] exynos-gsc: Remove <linux/version.h> header file inclusion [media] s5p-fimc: Fix incorrect condition in fimc_lite_reqbufs() [media] s5p-tv: Fix potential NULL pointer dereference error [media] s5k6aa: Fix possible NULL pointer dereference ...
2012-09-27[media] Support for Asus MyCinema U3100Mini PlusOliver Schinagl
This is initial support for the Asus MyCinema U3100Mini Plus. The driver in its current form gets detected and loads properly. Scanning using dvbscan works without problems, Locking onto a channel using tzap also works fine. Only playback using tzap -r + mplayer was tested and was fully functional. It uses the af9035 USB Bridge chip, with an af9033 demodulator. The tuner used is the FCI FC2580. Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-27[media] add LNA support for DVB APIAntti Palosaari
2012-09-27[media] dvb_frontend: do not allow statistic IOCTLs when sleepingAntti Palosaari
Demodulator cannot perform statistic IOCTLs when it is not tuned. Return -EAGAIN in such case. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-23[media] dvb_frontend: add multistream supportEvgeny Plehov
Unify multistream support at the DVBAPI: several delivery systems allow it. Yet, each one had its own name. So, instead of adding a third version of this field, remove the per-standard naming, unifying it into a common name. The legacy code number can still be used by old applications. Version increased to 5.8. [mchehab@redhat.com: joined the va1j5jf007s patch, in order to avoid compilation breakage] Signed-off-by: Evgeny Plehov <EvgenyPlehov@ukr.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-23[media] rtl28xxu: Dexatek DK DVB-T Dongle [1d19:1101]Antti Palosaari
It is RTL2832U + FC2580 reference design. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-23[media] drivers/media/dvb-core/dvb_demux.c: removes unnecessary semicolonPeter Senna Tschudin
removes unnecessary semicolon Found by Coccinelle: http://coccinelle.lip6.fr/ Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-18[media] Add the usb id of the Trekstor DVB-T Stick Terres 2.0Philipp Dreimann
It needs the e4000 tuner driver. Signed-off-by: Philipp Dreimann <philipp@dreimann.net> Acked-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-15[media] media:dvb:fix up ENOIOCTLCMD error handlingWanlong Gao
At commit 07d106d0, Linus pointed out that ENOIOCTLCMD should be translated as ENOTTY to user mode. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-10[media] dvb_frontend: return -ENOTTY for unimplement IOCTLAntti Palosaari
Earlier it was returning -EOPNOTSUPP. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-10[media] dvb_frontend: use Kernel dev_* loggingAntti Palosaari
2012-08-15[media] dvb_frontend: implement suspend / resumeAntti Palosaari
Move initial suspend / resume support from dvb_usb_v2 to dvb_frontend as it is dvb general feature that could be used all dvb devices. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] dvb_core: export function to perform retuneAntti Palosaari
We need to retune when resume from suspend. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] dvb: move the dvb core one level upMauro Carvalho Chehab
just like the V4L2 core, move the DVB core to drivers/media, as the intention is to get rid of both "video" and "dvb" directories. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
