[ Upstream commit 6510e80a0b81b5d814e3aea6297ba42f5e76f73c ]
The driver can call card->isac.release() function from an atomic
context.
Fix this by calling this function after releasing the lock.
The following log reveals it:
[ 44.168226 ] BUG: sleeping function called from invalid context at kernel/workqueue.c:3018
[ 44.168941 ] in_atomic(): 1, irqs_disabled(): 1, non_block: 0, pid: 5475, name: modprobe
[ 44.169574 ] INFO: lockdep is turned off.
[ 44.169899 ] irq event stamp: 0
[ 44.170160 ] hardirqs last enabled at (0): [<0000000000000000>] 0x0
[ 44.170627 ] hardirqs last disabled at (0): [<ffffffff814209ed>] copy_process+0x132d/0x3e00
[ 44.171240 ] softirqs last enabled at (0): [<ffffffff81420a1a>] copy_process+0x135a/0x3e00
[ 44.171852 ] softirqs last disabled at (0): [<0000000000000000>] 0x0
[ 44.172318 ] Preemption disabled at:
[ 44.172320 ] [<ffffffffa009b0a9>] nj_release+0x69/0x500 [netjet]
[ 44.174441 ] Call Trace:
[ 44.174630 ] dump_stack_lvl+0xa8/0xd1
[ 44.174912 ] dump_stack+0x15/0x17
[ 44.175166 ] ___might_sleep+0x3a2/0x510
[ 44.175459 ] ? nj_release+0x69/0x500 [netjet]
[ 44.175791 ] __might_sleep+0x82/0xe0
[ 44.176063 ] ? start_flush_work+0x20/0x7b0
[ 44.176375 ] start_flush_work+0x33/0x7b0
[ 44.176672 ] ? trace_irq_enable_rcuidle+0x85/0x170
[ 44.177034 ] ? kasan_quarantine_put+0xaa/0x1f0
[ 44.177372 ] ? kasan_quarantine_put+0xaa/0x1f0
[ 44.177711 ] __flush_work+0x11a/0x1a0
[ 44.177991 ] ? flush_work+0x20/0x20
[ 44.178257 ] ? lock_release+0x13c/0x8f0
[ 44.178550 ] ? __kasan_check_write+0x14/0x20
[ 44.178872 ] ? do_raw_spin_lock+0x148/0x360
[ 44.179187 ] ? read_lock_is_recursive+0x20/0x20
[ 44.179530 ] ? __kasan_check_read+0x11/0x20
[ 44.179846 ] ? do_raw_spin_unlock+0x55/0x900
[ 44.180168 ] ? ____kasan_slab_free+0x116/0x140
[ 44.180505 ] ? _raw_spin_unlock_irqrestore+0x41/0x60
[ 44.180878 ] ? skb_queue_purge+0x1a3/0x1c0
[ 44.181189 ] ? kfree+0x13e/0x290
[ 44.181438 ] flush_work+0x17/0x20
[ 44.181695 ] mISDN_freedchannel+0xe8/0x100
[ 44.182006 ] isac_release+0x210/0x260 [mISDNipac]
[ 44.182366 ] nj_release+0xf6/0x500 [netjet]
[ 44.182685 ] nj_remove+0x48/0x70 [netjet]
[ 44.182989 ] pci_device_remove+0xa9/0x250
Signed-off-by: Zheyu Ma <zheyuma97@gmail.com>
[ Upstream commit 9f6f852550d0e1b7735651228116ae9d300f69b3 ]
'nj_setup' in netjet.c might fail with -EIO and in this case
'card->irq' is initialized and is bigger than zero. A subsequent call to
'nj_release' will free the irq that has not been requested.
Fix this bug by deleting the previous assignment to 'card->irq' and just
keep the assignment before 'request_irq'.
The KASAN's log reveals it:
[ 3.354615 ] WARNING: CPU: 0 PID: 1 at kernel/irq/manage.c:1826
free_irq+0x100/0x480
[ 3.355112 ] Modules linked in:
[ 3.355310 ] CPU: 0 PID: 1 Comm: swapper/0 Not tainted
5.13.0-rc1-00144-g25a1298726e #13
[ 3.355816 ] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS
rel-1.12.0-59-gc9ba5276e321-prebuilt.qemu.org 04/01/2014
[ 3.356552 ] RIP: 0010:free_irq+0x100/0x480
[ 3.356820 ] Code: 6e 08 74 6f 4d 89 f4 e8 5e ac 09 00 4d 8b 74 24 18
4d 85 f6 75 e3 e8 4f ac 09 00 8b 75 c8 48 c7 c7 78 c1 2e 85 e8 e0 cf f5
ff <0f> 0b 48 8b 75 c0 4c 89 ff e8 72 33 0b 03 48 8b 43 40 4c 8b a0 80
[ 3.358012 ] RSP: 0000:ffffc90000017b48 EFLAGS: 00010082
[ 3.358357 ] RAX: 0000000000000000 RBX: ffff888104dc8000 RCX:
0000000000000000
[ 3.358814 ] RDX: ffff8881003c8000 RSI: ffffffff8124a9e6 RDI:
00000000ffffffff
[ 3.359272 ] RBP: ffffc90000017b88 R08: 0000000000000000 R09:
0000000000000000
[ 3.359732 ] R10: ffffc900000179f0 R11: 0000000000001d04 R12:
0000000000000000
[ 3.360195 ] R13: ffff888107dc6000 R14: ffff888107dc6928 R15:
ffff888104dc80a8
[ 3.360652 ] FS: 0000000000000000(0000) GS:ffff88817bc00000(0000)
knlGS:0000000000000000
[ 3.361170 ] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3.361538 ] CR2: 0000000000000000 CR3: 000000000582e000 CR4:
00000000000006f0
[ 3.362003 ] DR0: 0000000000000000 DR1: 0000000000000000 DR2:
0000000000000000
[ 3.362175 ] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7:
0000000000000400
[ 3.362175 ] Call Trace:
[ 3.362175 ] nj_release+0x51/0x1e0
[ 3.362175 ] nj_probe+0x450/0x950
[ 3.362175 ] ? pci_device_remove+0x110/0x110
[ 3.362175 ] local_pci_probe+0x45/0xa0
[ 3.362175 ] pci_device_probe+0x12b/0x1d0
[ 3.362175 ] really_probe+0x2a9/0x610
[ 3.362175 ] driver_probe_device+0x90/0x1d0
[ 3.362175 ] ? mutex_lock_nested+0x1b/0x20
[ 3.362175 ] device_driver_attach+0x68/0x70
[ 3.362175 ] __driver_attach+0x124/0x1b0
[ 3.362175 ] ? device_driver_attach+0x70/0x70
[ 3.362175 ] bus_for_each_dev+0xbb/0x110
[ 3.362175 ] ? rdinit_setup+0x45/0x45
[ 3.362175 ] driver_attach+0x27/0x30
[ 3.362175 ] bus_add_driver+0x1eb/0x2a0
[ 3.362175 ] driver_register+0xa9/0x180
[ 3.362175 ] __pci_register_driver+0x82/0x90
[ 3.362175 ] ? w6692_init+0x38/0x38
[ 3.362175 ] nj_init+0x36/0x38
[ 3.362175 ] do_one_initcall+0x7f/0x3d0
[ 3.362175 ] ? rcu_read_lock_sched_held+0x4f/0x80
[ 3.362175 ] kernel_init_freeable+0x2aa/0x301
[ 3.362175 ] ? rest_init+0x2c0/0x2c0
[ 3.362175 ] kernel_init+0x18/0x190
[ 3.362175 ] ret_from_fork+0x1f/0x30
[ 3.362175 ] Kernel panic - not syncing: panic_on_warn set ...
[ 3.362175 ] CPU: 0 PID: 1 Comm: swapper/0 Not tainted
[ 3.362175 ] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS
[ 3.362175 ] dump_stack+0xba/0xf5
[ 3.362175 ] ? free_irq+0x100/0x480
[ 3.362175 ] panic+0x15a/0x3f2
[ 3.362175 ] ? __warn+0xf2/0x150
[ 3.362175 ] __warn+0x108/0x150
[ 3.362175 ] report_bug+0x119/0x1c0
[ 3.362175 ] handle_bug+0x3b/0x80
[ 3.362175 ] exc_invalid_op+0x18/0x70
[ 3.362175 ] asm_exc_invalid_op+0x12/0x20
[ 3.362175 ] RIP: 0010:free_irq+0x100/0x480
[ 3.362175 ] Code: 6e 08 74 6f 4d 89 f4 e8 5e ac 09 00 4d 8b 74 24 18
[ 3.362175 ] RSP: 0000:ffffc90000017b48 EFLAGS: 00010082
[ 3.362175 ] RAX: 0000000000000000 RBX: ffff888104dc8000 RCX:
0000000000000000
[ 3.362175 ] RDX: ffff8881003c8000 RSI: ffffffff8124a9e6 RDI:
00000000ffffffff
[ 3.362175 ] RBP: ffffc90000017b88 R08: 0000000000000000 R09:
0000000000000000
[ 3.362175 ] R10: ffffc900000179f0 R11: 0000000000001d04 R12:
0000000000000000
[ 3.362175 ] R13: ffff888107dc6000 R14: ffff888107dc6928 R15:
ffff888104dc80a8
[ 3.362175 ] ? vprintk+0x76/0x150
[ 3.362175 ] Dumping ftrace buffer:
[ 3.362175 ] (ftrace buffer empty)
[ 3.362175 ] Kernel Offset: disabled
[ 3.362175 ] Rebooting in 1 seconds..
Reported-by: Zheyu Ma <zheyuma97@gmail.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Karsten Keil <isdn@linux-pingi.de>
It is a bad idea to hold a spinlock and call flush_work_sync.
Move the workqueue cleanup outside the spinlock and use cancel_work_sync,
on closing the channel this seems to be the more correct function.
Remove the never used and constant return value of mISDN_freebchannel.
Signed-off-by: Karsten Keil <keil@b1-systems.de>
Cc: <stable@kernel.org>
MISDN_CTRL_RX_OFF is a meachanism to discard RX data in the driver if
the data is not needed by the application. It can be used when playing
mesages, but not recording or with unidirectional protocols.
Signed-off-by: Karsten Keil <kkeil@linux-pingi.de>
MISDN_CTRL_FILL_EMPTY is a meachanism to send a fixed value (normally silence)
as long no data from upper layers is available. It can be used when recording
voice messages or with unidirectional protocols.
If the FIFO of the card is small, many short messages are queued up to
the upper layers and the userspace. This change allows the applications
to set a minimum datalen they want from the drivers.
Create a common control function to avoid code duplication in each
driver.
We did allways allocate maxsize buffers, but for transparent data we know
the actual size.
Use a common function to calculate size and detect overflows.
It is better to send a confirm for transparent data early as possible
to avoid TX underuns.
If a channel was closed after it was deactivated it could happen that
something was not proper resetted. The test if a channel is still activ
was wrong, so remove it and always do the cleanup.
For certification test it is very useful to change the layer1
timer3 value on runtime.
There are two channels here. User space starts counting channels at one
but in the kernel we start at zero. If the user passes in a zero
channel that's invalid and could lead to memory corruption.
isdn source code uses a not-current coding style.
Update the coding style used on a per-line basis
so that git diff -w shows only elided blank lines
at EOF.
Done with emacs and some scripts and some typing.
Built x86 allyesconfig.
No detected change in objdump -d or size.
* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
[2nd try ... 1st attempt didn't make it to netdev mailing list]
A quick google search reveals that people with this card are blacklisting it
in the initramfs and in the module blacklist based on a statement that it
is unsupported. Since the older Digium is also unsupported I'm pretty
confident that this newer card is also not supported.
lspci -xxx -vv shows
04:07.0 Communication controller: Tiger Jet Network Inc. Tiger3XX Modem/ISDN interface
Subsystem: Device b100:0003
P.
----8<----
The Asterisk Voice Card, DIGIUM TDM400P is unsupported by the netjet driver.
Blacklist it like the Digium X100P/X101P card.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
The function inittiger is only called from nj_init_card, where a lock is held.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@gfp exists@
identifier fn;
position p;
fn(...) {
... when != spin_unlock_irqrestore
when any
GFP_KERNEL@p
... when any
@locked@
identifier gfp.fn;
spin_lock_irqsave(...)
fn(...)
@depends on locked@
position gfp.p;
- GFP_KERNEL@p
+ GFP_ATOMIC
// </smpl>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Add support for cards based on the Tiger 300 and Tiger 320
ISDN PCI chip.
Currently only the ISAC ISDN line interface is supported.
