path: root/drivers/iio
2017-10-06mfd: apalis-tk1-k20: clean-up and fix support for 0.10 k20 fwApalis-TK1_LXDE-Image_2.7b4-20171007Dominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11apalis_tk1: Support for K20 based MFDApalis_TK1_LinuxImageV2.7Beta1_20170112Dominik Sliwa
On Apalis TK1 boards K20 MCU is used for CAN, GPIO, ADC and touch screen. This patch includes support for core MFD device, GPIO, ADC and touch screen. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2014-06-05Merge branch 'linux-3.10.40' into rel-21Ishan Mittal
Bug 200004122 Conflicts: drivers/cpufreq/cpufreq.c drivers/regulator/core.c sound/soc/codecs/max98090.c Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-05-14iio: core: add protection to avoid race conditionLouis Li
Kernel panic at iio_read_channel_info during boot stress. It is supposed that iio_dev has been released while sensor service is reading sysfile. So add a protection here to avoid race condition. Bug 1501090 Change-Id: I24da6245f4473fdcc2e8e7bf9673fbd25c350820 Reviewed-on: http://git-master/r/398726 (cherry picked from commit 75155b5e80369feafc612a8c0f1ec44ed84dee10) Signed-off-by: Louis Li <louli@nvidia.com> Reviewed-on: http://git-master/r/408580 GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2014-05-06iio: querying buffer scan_mask should return 0/1Alec Berg
commit 2076a20fc1a06f7b0333c62a2bb4eeeac7ed1bcb upstream. Ensure that querying the IIO buffer scan_mask returns a value of 0 or 1. Currently querying the scan mask has the value returned by test_bit(), which returns either true or false. For some architectures test_bit() may return -1 for true, which will appear to return an error when returning from iio_scan_mask_query(). Additionally, it's important for the sysfs interface to consistently return the same thing when querying the scan_mask. Signed-off-by: Alec Berg <alecaberg@chromium.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-05iio: fix iio channel get issuewahsu
We should fall back to get the channel by consumer_dev_name, if there is no channel name on device node in device tree. Change-Id: I5ee9147c991f5812a97d676d78299a8fcc0205cc Signed-off-by: wahsu <wahsu@nvidia.com> Reviewed-on: http://git-master/r/385560 (cherry picked from commit d619ade02ecf1b1690aef934bd749c13083f092a) Reviewed-on: http://git-master/r/404471 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2014-04-04iio: core: add link file for iio_deviceLaxman Dewangan
When iio device get registered, the iio device name has the unique ID and all sysfs created under this device. The unique id depends on the order it is called and so does nto give the consistent deviceid for given device. Hence add the link to point the iio device with unique name. Change-Id: I0442de9fe27ba0c0e182b9469e5dc707dc31c850 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/391881 Reviewed-by: Timo Alho <talho@nvidia.com>
2014-03-13Merge branch 'linux-3.10.33' into dev-kernel-3.10Deepak Nibade
Bug 1456092 Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
2014-03-06iio:gyro: bug on L3GD20H gyroscope supportDenis CIOCCA
commit a0657716416f834ef7710a9044614d50a36c3bdc upstream. The driver was not able to manage the sensor: during probe function and wai check, the driver stops and writes: "device name and WhoAmI mismatch." The correct value of L3GD20H wai is 0xd7 instead of 0xd4. Dropped support for the sensor. Signed-off-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22iio: adis16400: Set timestamp as the last element in chan_specMarcus Folkesson
commit c76782d151dab7ecfdcdf9a01561c2d61d9b490f upstream. This is necessary since timestamp is calculated as the last element in iio_compute_scan_bytes(). Without this fix any userspace code reading the layout of the buffer via sysfs will incorrectly interpret the data leading some nasty corruption. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-16iio: core: Implement devm_iio_device_{register,unregister}Sachin Kamat
Add device managed devm_iio_device_{register,unregister}() to automatically unregister IIO drivers thus leading to simplified IIO driver code. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Lars-Peter Clausen <lars@metafoo.de> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org> (cherry picked from commit 8caa07c0e565a15f49f290ca4c6a3adf968ddd38) Conflicts: Documentation/driver-model/devres.txt Change-Id: I3ccfa11be374b150b3bb6a45defcf6fb5955a258 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/368084
2014-02-16iio: core: implement devm_iio_device_alloc/devm_iio_device_freeGrygorii Strashko
Add a resource managed devm_iio_device_alloc()/devm_iio_device_free() to automatically clean up any allocations made by IIO drivers, thus leading to simplified IIO drivers code. In addition, this will allow IIO drivers to use other devm_*() API (like devm_request_irq) and don't care about the race between iio_device_free() and the release of resources by Device core during driver removing. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com> Tested-by: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org> (cherry picked from commit 9dabaf5eddbafa21aded7c063cb38d2e8936c237) Change-Id: Ia761b80971ed58d735e39b93f32db4b510368363 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/368083
2014-01-09Build Change for Invensense V5.2.0 code dropXiaohui Tao
Change-Id: I9b613be7f9939440e106fcab9929867878c0ce52 Signed-off-by: Xiaohui Tao <xtao@nvidia.com> Reviewed-on: http://git-master/r/353462 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Mitch Luban <mluban@nvidia.com>
2014-01-09Invensense V5.2.0 code drop for K310/KKXiaohui Tao
Change-Id: I166b0dc65bb90edd582bb0121a59683a9ce2a4af Signed-off-by: Xiaohui Tao <xtao@nvidia.com> Reviewed-on: http://git-master/r/353453 GVS: Gerrit_Virtual_Submit Reviewed-by: Mitch Luban <mluban@nvidia.com>
2014-01-09iio:adc:ad7887 Fix channel reported endianness from cpu to big endianJonathan Cameron
commit e39d99059ad7f75d7ae2d3c59055d3c476cdb0d9 upstream. Note this also sets the endianness to big endian whereas it would previously have defaulted to the cpu endian. Hence technically this is a bug fix on LE platforms. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09iio:imu:adis16400 fix pressure channel scan typeJonathan Cameron
commit 3425c0f7ac61f2fcfb7f2728e9b7ba7e27aec429 upstream. A single channel in this driver was using the IIO_ST macro. This does not provide a parameter for setting the endianness of the channel. Thus this channel will have been reported as whatever is the native endianness of the cpu rather than big endian. This means it would be incorrect on little endian platforms. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-16Merge tag 'v3.10.24' into HEADAjay Nandakumar
This is the 3.10.24 stable release Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
2013-12-04iio:accel:kxsd9 fix missing mutex unlockFrank Zago
commit 0ee005c7dc2803125275e24598f0fb37775a6af3 upstream. This will leave a lock held after reading from the device, preventing any further reads. Signed-off-by: Frank Zago <frank@zago.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-16iio: inkern: Add functions to read channel with dual modeJinyoung Park
Added functions to read channel with dual mode. The functions check a channel info attribute and the channel supports dual mode then read channel. If the channel doesn't support dual mode, return error value. Bug 1287901 Bug 1356128 Change-Id: Ia2ffdf8eb6d05f95f763939dc413be5b06b7c605 Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com> Reviewed-on: http://git-master/r/273636 GVS: Gerrit_Virtual_Submit Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-09-14unknown changes from android-tegra-nv-3.4Dan Willemsen
Rebase-Id: R940fad74c7e91ef3d1d3d589a48064ccb7335541
2013-09-14Merge commit 'a88f9e27498afaea615ad3e93af4f26df1f84987' into ↵Dan Willemsen
after-upstream-android Conflicts: arch/arm/common/Kconfig arch/arm/mm/Makefile arch/arm/mm/cache-l2x0.c arch/arm/mm/mmu.c drivers/input/Kconfig drivers/input/Makefile drivers/power/Kconfig kernel/futex.c
2013-07-25iio: inkern: fix iio_convert_raw_to_processed_unlockedAlexandre Belloni
commit f91d1b63a4e096d3023aaaafec9d9d3aff25997f upstream. When reading IIO_CHAN_INFO_OFFSET, the return value of iio_channel_read() for success will be IIO_VAL*, checking for 0 is not correct. Without this fix the offset applied by iio drivers will be ignored when converting a raw value to one in appropriate base units (e.g mV) in a IIO client drivers that use iio_convert_raw_to_processed including iio-hwmon. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-01staging:iio:events: Don't copy data to user-space with a locked spinlock.Arve Hjønnevåg
iio_event_chrdev_read would return -EFAULT if the user-space page was not resident. Change-Id: I4ac5d3bc791bb503d014d9db576b9d6d522505b2 Signed-off-by: Arve Hjønnevåg <arve@android.com>
2013-06-04iio:inkern: Fix typo/bug in convert raw to processed.iio-fixes-for-3.10bMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-06-04iio: frequency: ad4350: Fix bug / typo in maskMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-06-04inkern: iio_device_put after incorrect return/gotoJoe Perches
The code uses return foo; goto err_type; when instead the form should have been ret = foo; goto err_type; Here this causes a useful iio_device_put to be skipped. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-06-04iio:callback buffer: free the scan_maskJonathan Cameron
Reported-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-05-22iio: exynos_adc: fix wrong structure extration in suspend and resumeiio-fixes-for-3.10aNaveen Krishna Chatradhi
The exynos_adc device structure was wrongly extracted from the dev* correcting the same. Using the regular conversion of struct device* -> struct platform_device* -> struct exynos_adc* seems wrong. Instead we should be doing struct device* -> struct iio_dev* -> struct exynos_adc* Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-05-22iio:common:st: added disable function after read info raw dataDenis CIOCCA
2013-05-22iio: dac: Fix build error when CONFIG_SPI_MASTER=y && CONFIG_I2C=mAxel Lin
This patch fixes below build error when CONFIG_SPI_MASTER=y && CONFIG_I2C=m: drivers/built-in.o: In function `ad5064_i2c_write': drivers/iio/dac/ad5064.c:608: undefined reference to `i2c_master_send' drivers/built-in.o: In function `ad5064_i2c_register_driver': drivers/iio/dac/ad5064.c:646: undefined reference to `i2c_register_driver' drivers/built-in.o: In function `ad5064_i2c_unregister_driver': drivers/iio/dac/ad5064.c:651: undefined reference to `i2c_del_driver' make: *** [vmlinux] Error 1 When CONFIG_I2C=m, meaning we can't build the drivers in with I2C support. Thus don't allow the drivers to be compiled as built-in when CONFIG_I2C=m. The real fix though is to break the driver apart into a SPI part, an I2C part and a common part. But that's something for 3.11 while this is something for 3.10/stable. Reported-by: Wu Fengguang <fengguang.wu@intel.com> Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-04-02iio: at91_adc: fix missing Sample and Hold timeiio-for-3.10cJean-Christophe PLAGNIOL-VILLARD
On the at91_adc a minimal Sample and Hold Time is necessary for the ADC to guarantee the best converted final value between two channels selection. This time has to be programmed through the bitfield SHTIM in the Mode Register ADC_MR. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-04-02iio: at91_adc: add sleep mode supportJean-Christophe PLAGNIOL-VILLARD
The sleep mode will allow to put the adc in sleep between conversion. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-04-02iio: at91_adc: add low and high res supportLudovic Desroches
at91 adc offers the choice between two resolutions: low and high. The low and high resolution values depends on adc IP version, as many IP properties have been exposed through device tree, these settings have also been added to the dt bindings. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-04-02iio:magnetometer:ak8975 move driver out of stagingJonathan Cameron
Issues raised in last series to propose this have now been resolved so there should be no reason this driver cannot graduate from staging. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-03-29iio: exynos_adc: Remove redundant of_match_ptr macroSachin Kamat
exynos_adc is a DT only driver and exynos_adc_match table is always compiled in. Hence remove the macro. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-03-25iio:trigger: Introduce iio_tigger_{set,get}_drvdataLars-Peter Clausen
Introduce iio_tigger_{set,get}_drvdata which allows to attach driver specific data to a trigger. The functions wrap access to the triggers private_data field and all current users are updated to use iio_tigger_{set,get}_drvdata instead of directly accessing the private_data field. This is the first step towards removing the private_data field from the iio_trigger struct. The following coccinelle script has been used to update the drivers: <smpl> @@ struct iio_trigger *trigger; expression priv; @@ -trigger->private_data = priv +iio_trigger_set_drv_data(trigger, priv) @@ struct iio_trigger *trigger; @@ -trigger->private_data +iio_trigger_get_drv_data(trigger) </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-03-25Merge tag 'iio-for-3.10a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: First set of IIO new drivers and cleanup for the 3.10 cycle. New stuff 1) Add OF support for specifying mappings between iio devices and their in kernel consumers. 2) Driver for AD7923 (extra functionality and support for ad7904, ad7914 and ad7924 added later in series) 3) Driver for Exynos adc (dt suppor for phy added later in series). 4) Make iio_push_event save IRQ context - necessary if it is to be used within an interrupt handler. Users of this functionality to follow. 5) For iio use the device tree node name to provide the hwmon name attribute if available. Removal and moves out of staging 1) Drop the adt7410 driver from IIO now that there is a hmwon driver with equivalent support. This device is very much targeted at hardware monitoring so hwmon is a more appropriate host for the driver. 2) Move iio_hwmon driver to drivers/hwmon. Cleanups 1) Minor cleanup in ST common library. 2) Large set of patches to break the info_mask element which previously used odd and even bits to specify if a channel attribute was either shared across similar channels or specific to only one. Now we have two bitmaps, one for those parameters that are specific to this channel and one for those shared by all channels with the same type as this one. This has no effect on the userspace abi. It simplifies the core code and provides more space for new channel parameters. It has been on the todo list for a long time! Conflicts: drivers/iio/dac/ad5064.c
2013-03-17iio: adc: Add dt support for turning on the phy in exynos-adcDoug Anderson
Without this change the exynos adc controller needed to have its phy enabled in some out-of-driver C code. Add support for specifying the phy enable register by listing it in the reg list. Signed-off-by: Doug Anderson <dianders@chromium.org> Tested-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-03-17iio:adc:ad7923: Add support for the ad7904/ad7914/ad7924Lars-Peter Clausen
The ad7924 is software compatible with the ad7923. The ad7904 and ad7914 are the 8 and 10 bit version of the ad7924. While we are at it also drop the "with temperature sensor" from the Kconfig entry, since the chips do not have a temperature sensor. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Patrick Vasseur <patrick.vasseur@c-s.fr> Cc: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-03-17iio:ad7923: Implement scale reportingLars-Peter Clausen
The driver already claims to support scale reporting in its channel spec, but doesn't actually implement this yet. This patch uses the regulator API to get the reference voltage and calculates the scale based on that. The patch also moves the global configuration bits into a field in the ad7923_state struct, since depending on the RANGE bit, the range goes either from 0 to VREF or from 0 to 2 * VREF. So we need to know the setting of the RANGE bit when calculating the scale. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Patrick Vasseur <patrick.vasseur@c-s.fr> Cc: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-03-17iio:ad7923: Return error if we didn't get the expected resultLars-Peter Clausen
Instead of leaving 'val' uninitialized return an error if the result's address did not match that of the channel we were trying to read. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Patrick Vasseur <patrick.vasseur@c-s.fr> Cc: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-03-17using kfifo_in_spinlocked instead of separate code.Ge Gao
Signed-off-by: Ge Gao <ggao@invensense.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-03-17iio: adc: Kconfig: exynos_adc depends on CONFIG_OFNaveen Krishna Chatradhi
As the exynos_adc driver only supports device tree registration. Making driver depend on CONFIG_OF solves possible errors during probe. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Cc: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-03-17iio: events: Make iio_push_event() IRQ context saveLars-Peter Clausen
Currently it is not save to call iio_push_event() from hard IRQ context since the IIO event code uses spin_lock()/spin_unlock() and it is not save to mix calls to spin_lock()/spin_unlock() from different contexts on the same lock. E.g. if the lock is being held in iio_event_chrdev_read() and an interrupts kicks in and the interrupt handler calls iio_push_event() we end uo with a deadlock. This patch updates iio_push_event() to use spin_lock_irqsave()/ spin_unlock_irqstrestore(), since it can be called from both IRQ and non-IRQ context. All other other users of the lock, which are always run in non-IRQ context, are updated to spin_lock_irq()/spin_unlock_irq(). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-03-17iio:core drop info_mask from struct iio_infoJonathan Cameron
This has been replaced by the pair of masks info_mask_separate and info_mask_shared_by_type. Other variants may follow. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de>
2013-03-17iio:adc:ad7923 move to info_mask_(shared_by_type/separate)Jonathan Cameron
The original info_mask is going away in favour of the broken out versions. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de> cc: Patrick Vasseur <patrick.vasseur@c-s.fr> cc: Christophe Leroy <christophe.leroy@c-s.fr>
2013-03-17iio:adc:exynos move to info_mask_(shared_by_type/separate)Jonathan Cameron
The original info_mask is going away in favour of the broken out versions. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
2013-03-17iio:light:vcnl4000 move to info_mask_(shared_by_type/separate)Jonathan Cameron
The original info_mask is going away in favour of the broken out versions. Signed-off-by: Jonathan Cameron <jic23@kernel.org> cc: Peter Meerwald <pmeerw@pmeerw.net>
2013-03-17iio:light:tsl2563 move to info_mask_(shared_by_type/separate)Jonathan Cameron
The original info_mask is going away in favour of the broken out versions. Signed-off-by: Jonathan Cameron <jic23@kernel.org> cc: Jon Brenner <jbrenner@taosinc.com>
2013-03-17iio:light:lm3533 move to info_mask_(shared_by_type/separate)Jonathan Cameron
The original info_mask is going away in favour of the broken out versions. Signed-off-by: Jonathan Cameron <jic23@kernel.org> cc: Johan Hovold <jhovold@gmail.com>
