commit 4170d3dd1467e9d78cb9af374b19357dc324b328 upstream.
The ssp_print_mcu_debug() function should return negative error codes on
error. Returning "length" is meaningless. This change does not affect
runtime because the callers only care about zero/non-zero.
Reported-by: Jonathan Cameron <jic23@kernel.org>
Fixes: 50dd64d57eee ("iio: common: ssp_sensors: Add sensorhub driver")
Link: https://lore.kernel.org/r/20210914105333.GA11657@kili
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit 8167c9a375ccceed19048ad9d68cb2d02ed276e0 upstream.
The "idx" is validated at the start of the loop but it gets incremented
during the iteration so it needs to be checked again.
Link: https://lore.kernel.org/r/20210909091336.GA26312@kili
Sensorhub is MCU dedicated to collect data and manage several sensors.
Sensorhub is a spi device which provides a layer for IIO devices. It provides
some data parsing and common mechanism for sensorhub sensors.
Adds common sensorhub library for sensorhub driver and iio drivers
which uses sensorhub MCU to communicate with sensors.
Signed-off-by: Karol Wrona <k.wrona@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
