commit bbcf40816b547b3c37af49168950491d20d81ce1 upstream.
A successful 'regulator_enable()' call should be balanced by a
corresponding 'regulator_disable()' call in the error handling path of the
probe, as already done in the remove function.
Update the error handling path accordingly.
Fixes: 913b86468674 ("iio: adc: Add TI ADC128S052")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Reviewed-by: Alexandru Ardelean <ardeleanalex@gmail.com>
Link: https://lore.kernel.org/r/85189f1cfcf6f5f7b42d8730966f2a074b07b5f5.1629542160.git.christophe.jaillet@wanadoo.fr
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi updates from Mark Brown:
"Quite a lot of activity in SPI this cycle, almost all of it in drivers
with a few minor improvements and tweaks in the core.
- Updates to pxa2xx to support Intel Broxton and multiple chip selects.
- Support for big endian in the bcm63xx driver.
- Multiple slave support for the mt8173
- New driver for the auxiliary SPI controller in bcm2835 SoCs.
- Support for Layerscale SoCs in the Freescale DSPI driver"
* tag 'spi-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (87 commits)
spi: pxa2xx: Rework self-initiated platform data creation for non-ACPI
spi: pxa2xx: Add support for Intel Broxton
spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals
spi: pxa2xx: Add output control for multiple Intel LPSS chip selects
spi: pxa2xx: Use LPSS prefix for defines that are Intel LPSS specific
spi: Add DSPI support for layerscape family
spi: ti-qspi: improve ->remove() callback
spi/spi-xilinx: Fix race condition on last word read
spi: Drop owner assignment from spi_drivers
spi: Add THIS_MODULE to spi_driver in SPI core
spi: Setup the master controller driver before setting the chipselect
spi: dw: replace magic constant by DW_SPI_DR
spi: mediatek: mt8173 spi multiple devices support
spi: mediatek: handle controller_data in mtk_spi_setup
spi: mediatek: remove mtk_spi_config
spi: mediatek: Update document devicetree bindings to support multiple devices
spi: fix kernel-doc warnings about missing return desc in spi.c
spi: fix kernel-doc warnings about missing return desc in spi.h
spi: pxa2xx: Align a few defines
spi: pxa2xx: Save other reg_cs_ctrl bits when configuring chip select
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
The Documentation/devicetree/bindings/iio/adc/ti-adc128s052.txt DT binding
doc lists "ti,adc128s052" or "ti,adc122s021" as compatible strings but the
corresponding driver does not have an OF match table. Add the table to the
driver so the SPI core can do an OF style match.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Urs Fässler <urs.fassler@bytesatwork.ch>
This patch adds support for ADC128S052 from TI.
Signed-off-by: Angelo Compagnucci <angelo.compagnucci@gmail.com>
