commit 269f979467cf49f2ea8132316c1f00f8c9678f7c upstream.
When the guest attempts to connect with the host when there may already be a
connection with the host (as would be the case during the kdump/kexec path),
it is difficult to guarantee timely response from the host. Starting with
WS2012 R2, the host supports this ability to re-connect with the host
(explicitly to support kexec). Prior to responding to the guest, the host
needs to ensure that device states based on the previous connection to
the host have been properly torn down. This may introduce unbounded delays.
To deal with this issue, don't do a timed wait during the initial connect
with the host.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit c5e2254f8d63a6654149aa32ac5f2b7dd66a976d upstream.
When we are posting pressure status, we may get interrupted and handle
the un-balloon operation. In this case just don't post the status as we
know the pressure status is stale.
commit ed07ec93e83ec471d365ce084e43ad90fd205903 upstream.
As we hot-add 128 MB chunks of memory, we wait to ensure that the memory
is onlined before attempting to hot-add the next chunk. If the udev rule for
memory hot-add is not executed within the allowed time, we would rollback the
state and abort further hot-add. Since the hot-add has succeeded and the only
failure is that the memory is not onlined within the allowed time, we should not
be rolling back the state. Fix this bug.
Acked-by: Jason Wang <jasowang@redhat.com>
commit 35848f68b07df3f917cb13fc3c134718669f569b upstream.
Even if guest were compiled without SMP support, it could not assume that host
wasn't. So switch to use mb() instead of smp_mb() to force memory barriers for
UP guest.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Linux' notion of cpuid is different from the Host's notion of CPUID. In the
call to bind the channel interrupts, we should use the host's notion of
CPU Ids. Fix this bug.
Cc: Stable <stable@vger.kernel.org> (V3.9)
Pull x86 paravirt update from Ingo Molnar:
"Various paravirtualization related changes - the biggest one makes
guest support optional via CONFIG_HYPERVISOR_GUEST"
* 'x86-paravirt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, wakeup, sleep: Use pvops functions for changing GDT entries
x86, xen, gdt: Remove the pvops variant of store_gdt.
x86-32, gdt: Store/load GDT for ACPI S3 or hibernation/resume path is not needed
x86-64, gdt: Store/load GDT for ACPI S3 or hibernate/resume path is not needed.
x86: Make Linux guest support optional
x86, Kconfig: Move PARAVIRT_DEBUG into the paravirt menu
As part of updating the vmbus protocol, the function hv_need_to_signal()
was introduced. This functions helps optimize signalling from guest to
host. The newly added memory barrier is needed to ensure that we correctly
decide when to signal the host.
Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com>
Reported-by: Olaf Hering <olh@suse.de>
Cc: Stable <stable@vger.kernel.org> (V3.8+)
If memory hot-add fails with the error -EEXIST, then this is a permanent
failure. Notify the host of this information, so the host will not attempt
hot-add again. If the failure were a transient failure, host will attempt
a hot-add after some delay.
In this version of the patch, I have added some additional comments
to clarify how the host treats different failure conditions.
On Hyper-V it will be very efficient to use 2M allocations in the guest as this
makes the ballooning protocol with the host that much more efficient. Hyper-V
uses page ranges (start pfn : number of pages) to specify memory being moved
around and with 2M pages this encoding can be very efficient. However, when
memory is returned to the guest, the host does not guarantee any granularity.
To deal with this issue, split the page soon after a successful 2M allocation
so that this memory can potentially be freed as 4K pages.
If 2M allocations fail, we revert to 4K allocations.
In this version of the patch, based on the feedback from Michal Hocko
<mhocko@suse.cz>, I have added some additional commentary to the patch
description.
Some Windows hosts permit the guest to specify memory hot-add alignment
requirements (if any). Linux currently requires a 128MB alignment on memory
segments that can be hot-added. Specify this alignment requirement to the
host.
local functions that could be static.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This driver supports host initiated backup of the guest. On Windows guests,
the host can generate application consistent backups using the Windows VSS
framework. On Linux, we ensure that the backup will be file system consistent.
This driver allows the host to initiate a "Freeze" operation on all the mounted
file systems in the guest. Once the mounted file systems in the guest are frozen,
the host snapshots the guest's file systems. Once this is done, the guest's file
systems are "thawed".
This driver has a user-level component (daemon) that invokes the appropriate
operation on all the mounted file systems in response to the requests from
the host. The duration for which the guest is frozen is very short - a few seconds.
During this interval, the diff disk is comitted.
In this version of the patch I have addressed the feedback from Olaf Herring.
Also, some of the connector related issues have been fixed.
Cc: Evgeniy Polyakov <zbr@ioremap.net>
Properly cleanup the channel state on receipt of the "offer rescind" message.
Starting with ws2012, the host requires that the channel "relid" be properly
cleaned up when the offer is rescinded.
Implement the memory hot-add functionality. With this, Linux guests can fully
participate in the Dynamic Memory protocol implemented in the Windows hosts.
In this version of the patch, based Olaf Herring's feedback, I have gotten
rid of the module level dependency on MEMORY_HOTPLUG. Instead the code within
the driver that depends on MEMORY_HOTPLUG has the appropriate compilation
switches. This would allow this driver to support pure ballooning in cases
where the kernel does not support memory hotplug.
The balloon driver is stateful. For instance, it needs to keep track of pages
that have been ballooned out to properly post pressure reports. This state cannot
be re-constructed if the driver were to be unloaded and subsequently loaded.
Furthermore, as we support memory hot-add as part of this driver, this driver becomes
even more stateful and this state cannot be re-created. Make the balloon driver
unloadable to deal with this issue.
Execute the hot-add operation in a separate work context.
This allows us to decouple the pressure reporting activity from the
"hot-add" activity. Testing has shown that this makes the guest more
responsive to hot add requests.
Execute the balloon inflation operation in a separate work context.
ballooning activity. Testing has shown that this decoupling makes the
guest more reponsive.
There is no need to request completion notification; get rid of it.
remove cast for kmalloc return value.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Put all config options needed to run Linux as a guest behind a
CONFIG_HYPERVISOR_GUEST menu so that they don't get built-in by default
but be selectable by the user. Also, make all units which depend on
x86_hyper, depend on this new symbol so that compilation doesn't fail
when CONFIG_HYPERVISOR_GUEST is disabled but those units assume its
presence.
Sort options in the new HYPERVISOR_GUEST menu, adapt config text and
drop redundant select.
Link: http://lkml.kernel.org/r/1362428421-9244-3-git-send-email-bp@alien8.de
Cc: Dmitry Torokhov <dtor@vmware.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
Use the infrastructure for delivering VMBUS interrupts using a
special vector. With this patch, we can now properly handle
the VMBUS interrupts that can be delivered on any CPU. Also,
turn on interrupt load balancing as well.
This patch requires the infrastructure that was implemented in the patch:
X86: Handle Hyper-V vmbus interrupts as special hypervisor interrupts
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver patches from Greg Kroah-Hartman:
"Here's the big char/misc driver patches for 3.9-rc1.
Nothing major here, just lots of different driver updates (mei,
hyperv, ipack, extcon, vmci, etc.).
All of these have been in the linux-next tree for a while."
* tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits)
w1: w1_therm: Add force-pullup option for "broken" sensors
w1: ds2482: Added 1-Wire pull-up support to the driver
vme: add missing put_device() after device_register() fails
extcon: max8997: Use workqueue to check cable state after completing boot of platform
extcon: max8997: Set default UART/USB path on probe
extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type
extcon: max8997: Set default of ADC debounce time during initialization
extcon: max8997: Remove duplicate code related to set H/W line path
extcon: max8997: Move defined constant to header file
extcon: max77693: Make max77693_extcon_cable static
extcon: max8997: Remove unreachable code
extcon: max8997: Make max8997_extcon_cable static
extcon: max77693: Remove unnecessary goto statement to improve readability
extcon: max77693: Convert to devm_input_allocate_device()
extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style
CREDITS: update email and address of Harald Hoyer
extcon: arizona: Use MICDET for final microphone identification
extcon: arizona: Always take the first HPDET reading as the final one
extcon: arizona: Clear _trig_sts bits after jack detection
extcon: arizona: Don't HPDET magic when headphones are enabled
In order to compile in the special Hyper-V interrupt vector, we need
infrastructure in arch/x86/apic/apic.c. At least for now, simply
require CONFIG_X86_LOCAL_APIC in order to enable CONFIG_HYPERV.
Link: http://lkml.kernel.org/r/tip-bc2b0331e077f576369a2b6c75d15ed4de4ef91f@git.kernel.org
Based on the amount of memory being managed set a floor on how low the
guest can be ballooned.
Delay reporting memory pressure by a specified amount of time.
This addresses the problem where the host may take memory balancing
decisions based on incorrect memory pressure data that will be posted
as soon as the balloon driver is loaded.
The host expects that the pressure report includes the pressure due to the
pages that have been ballooned. Make necessary adjustments to reflect that.
Also, include the free memory information in the pressure report.
This pulls in all of the 3.8-rc5 fixes into this branch so we can test easier.
Execute the shutdown code in a thread context. With recent changes made to the
shutdown code, shutdown code cannot be invoked from an interrupt context.
Use the consolidated GUID definitions in the util and balloon drivers.
Consolidate all GUID definitions in hyperv.h and use these definitions in implementing
channel bindings (as far as interrupt delivery goes).
The default interrupt delivery model in Linux does not support the Hyper-V
vmbus delivery model when the guest is configured with multiple VCPUs. I have
sent a patch to address this - delivering the vmbus interrupt on a separate
IDT vector. Until this patch is applied, bind all vmbus interrupts to the boot
CPU.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
The send buffer was being leaked; fix it.
Reported-by: Jason Wang <jasowang@redhat.com>
There is bug in the definition of struct dm_info_msg. This patch fixes
the definition of this structure and makes the corresponding adjustments.
The variable userlen is initialized but never used
otherwise, so remove the unused variable.
Now, cleanup and consolidate reporting of host and vmbus version numbers.
Capture the host build information so it can be presented along with the
negotiated vmbus version information.
Implement flow management on the send side. When the sender is blocked, the reader
can potentially signal the sender to indicate there is now room to send.
Now that we have implemented all of the Win8 (WS2012) functionality, negotiate
Win8 protocol with the host.
We establish the handler before we have fully initialized the VMBUS state.
Deal with spurious interrupts.
Vmbus interrupts are unique in that while the interrupt is delivered on a
given vector, these can be handled concurrently on different CPUs. Handle the
vmbus interrupts concurrently on all the CPUs.
Now that we can potentially take vmbus interrupts on any CPU, make the
tasklets per-CPU.
This call to seek offers is not necessary and just adds unnecessary delay.
Get rid of it.
Now that we have implemented a per-connection signaling mechanism, get rid
of the global signaling state. For hosts that don't support per-connection
signaling handle, we have moved the global state to be a per-channel state.
Implement a simple policy for distributing incoming interrupt load.
We classify channels as (a) performance critical and (b) not
performance critical. All non-performance critical channels will
be bound to the boot cpu. Performance critical channels will be
bound to the remaining available CPUs on a round-robin basis.
Starting with Win8 (WS2012), the event page can be used to directly get the
channel ID that needs servicing. Modify the channel event handling code
to take advantage of this feature.
Add state to bind a channel to a specific VCPU. This will help us better
distribute incoming interrupt load.
On win8 (ws2012), incoming vmbus interrupt load can be spread across all
available VCPUs in the guest. On a per-channel basis, the interrupts can
be bound to specific CPUs. The Linux notion of cpu ID may be different
from that of the hypervisor's. Setup a mapping structure.
On win7 (ws2008 R2) and beyond, we have the notion of having dedicated interrupts on
a per-channel basis. When a channel has a dedicated interrupt assigned, there is no need
to set the interrupt bit in the shared page. Implement this optimization.
The current code has a global handle for supporting signaling of the host
from guest. Make this a per-channel attribute as on some versions of the
host we can signal on per-channel handle.
