Plugging a Logitech DJ receiver with KASAN activated raises a bunch of
out-of-bound readings.
The fields are allocated up to MAX_USAGE, meaning that potentially, we do
not have enough fields to fit the incoming values.
Add checks and silence KASAN.
Bug 1823317
Bug 1935735
Change-Id: Ib3ba92572acbdd4c9ec265e54a45f92606107700
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Signed-off-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/1259928
(cherry picked from commit fbc389a39540e177bfa4d49b9214dfe408ef2d4a)
Reviewed-on: https://git-master.nvidia.com/r/1690285
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
into promotion_build
Bug 200004122
Bug 1511804
This merge takes AOSP commits from android-3.10 branch
Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
Even though device exist bit is set the underlying
HW device should be closed when the last reader
of the device is closed i.e. open count drops to zero.
bug 1307434
bug 200004331
Change-Id: Ibdbf0cac829135b8bf1c462197f3a24a69cd69e1
Signed-off-by: Manoj Chourasia <mchourasia@nvidia.com>
Reviewed-on: http://git-master/r/376328
(cherry picked from commit c2dadc835dab7a3e05810ec8e666b195f3df8e08)
Reviewed-on: http://git-master/r/408781
Reviewed-by: Mark Kuo <mkuo@nvidia.com>
Tested-by: Mark Kuo <mkuo@nvidia.com>
Reviewed-by: BH Hsieh <bhsieh@nvidia.com>
Reviewed-by: WK Tsai <wtsai@nvidia.com>
Integrate several new definitions (not code) that
add additional hid mappings from the HID HUT 1.12
and approved additional requests.
Additions are taken from the commits in the
linux-input upstream: f362e69, 2a4d815, 3b5a7ab,
358f247, 701ba53, d09bbfd, af8036d, 5820e4d, a443255
Change-Id: Id0e1cff5828062009b4f94c987ac91f88f14652e
Signed-off-by: Mathieu Meisser <mmeisser@logitech.com>
Signed-off-by: Olivier Gay <ogay@logitech.com>
return type of input_configured in hid_driver struct (include/linux/hid.h) is
changed from void to int with change 5925993fe56e1a4ddb26d2085fdd16f6a6153365
and due to that magicmouse is broken.
Bug 1437341
Change-Id: Ia8e1dc181624dd8a3520e3aad00f77918549d3cf
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/390712
(cherry picked from commit e38628e8e14e919c0ffd8b18b8b77376ff93d3e9)
Reviewed-on: http://git-master/r/391814
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
This change will disable the autosuspend for KBs.
This is to avoid the lag observed on the screen
while we type the characters.
Bug 1390065
Change-Id: Ic6f2247bf4e4fa2332329cd3e8dac15aad56354c
Signed-off-by: Petlozu Pravareshwar <petlozup@nvidia.com>
Reviewed-on: http://git-master/r/358743
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
commit c63e0e370028d7e4033bd40165f18499872b5183 upstream.
This reverts commit 8af6c08830b1ae114d1a8b548b1f8b056e068887.
This patch re-adds the workaround introduced by 596264082f10dd4
which was reverted by 8af6c08830b1ae114.
The original patch 596264 was needed to overcome a situation where
the hid-core would drop incoming reports while probe() was being
executed.
This issue was solved by c849a6143bec520af which added
hid_device_io_start() and hid_device_io_stop() that enable a specific
hid driver to opt-in for input reports while its probe() is being
executed.
Commit a9dd22b730857347 modified hid-logitech-dj so as to use the
functionality added to hid-core. Having done that, workaround 596264
was no longer necessary and was reverted by 8af6c08.
We now encounter a different problem that ends up 'again' thwarting
the Unifying receiver enumeration. The problem is time and usb controller
dependent. Ocasionally the reports sent to the usb receiver to start
the paired devices enumeration fail with -EPIPE and the receiver never
gets to enumerate the paired devices.
With dcd9006b1b053c7b1c the problem was "hidden" as the call to the usb
driver became asynchronous and none was catching the error from the
failing URB.
As the root cause for this failing SET_REPORT is not understood yet,
-possibly a race on the usb controller drivers or a problem with the
Unifying receiver- reintroducing this workaround solves the problem.
Overall what this workaround does is: If an input report from an
unknown device is received, then a (re)enumeration is performed.
related bug:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1194649
Signed-off-by: Nestor Lopez Casado <nlopezcasad@logitech.com>
Bug 1434677
Change-Id: I019e492769495335041a336aef4de94a746efcee
Reviewed-on: http://git-master/r/352284
This is to support recovery kernel, where we
don't have Android keymapping but totally relying
on "real" KEY_HOME/KEY_BACK.
Bug 1431870
Change-Id: Ib3185bc230b65b5e25094caf3a61fa45ed2b835b
Signed-off-by: Jun Yan <juyan@nvidia.com>
Reviewed-on: http://git-master/r/350820
Reviewed-by: Raymond Poudrier <rapoudrier@nvidia.com>
Tested-by: Raymond Poudrier <rapoudrier@nvidia.com>
By default autosuspend is enabled for all the usb
devices. This change will disable the autosuspend
for mouses.
Bug 1417972
Change-Id: I904877afda1469b3e4a6d1111c5ccacd7c5a9816
Reviewed-on: http://git-master/r/345198
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-by: Rakesh Babu Bodla <rbodla@nvidia.com>
This is the 3.10.24 stable release
Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
commit 684524d35fe8d13be1f2649633e43bd02c96c695 upstream.
BugLink: http://bugs.launchpad.net/bugs/1180881
This device needs to be added to the quirks list with HID_QUIRK_NO_INIT_REPORTS,
otherwise it causes 10 seconds timeout during report initialization.
[12431.828467] hid-multitouch 0003:0457:1013.0475: usb_submit_urb(ctrl) failed: -1
[12431.828507] hid-multitouch 0003:0457:1013.0475: timeout initializing reports
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
commit 8171a67d587a09e14a4949a81e070345fedcf410 upstream.
Synaptics large touchscreen doesn't support some of the report request
while initializing. The unspoorted request will make the device unreachable,
and will lead to the following usb_submit_urb() function call timeout.
So, add the IDs into HID_QUIRK_NO_INIT_REPORTS quirk.
commit 348cbaa800f8161168b20f85f72abb541c145132 upstream.
By default the Logitech MOMO Force (Black) presents a combined accel/brake
axis ('Y'). This patch modifies the HID descriptor to present seperate
accel/brake axes ('Y' and 'Z').
Signed-off-by: Simon Wood <simon@mungewell.org>
In order to customize the flat and fuzz of the
joystick, create an separate hid driver for
Shield joystick. It does the same hid mapping
with hid-input.c but only changes the flat and
fuzz configurations.
Bug 1352488
Change-Id: Ide6d37eeeffac9a7150fb257d30f348599794c4c
Reviewed-on: http://git-master/r/335198
Reviewed-by: Anshul Jain (SW) <anshulj@nvidia.com>
commit 43c831468b3d26dbe8f2e061ccaf1abaf9cc1b8b upstream.
Use case: people who use both Apple and PC keyboards regularly, and desire to
keep&use their PC muscle memory.
A particular use case: an Apple compact external keyboard connected to a PC
laptop. (This use case can't be covered well by X.org key remappings etc.)
Signed-off-by: Nanno Langstraat <langstr@gmail.com>
commit e17f5d7667c5414b8f12a93ef14aae0824bd2beb upstream.
This is a patch that adds the new Mayflash Gamecube Controller to USB adapter
(ID 1a34:f705 ACRUX) to the ACRUX driver (drivers/hid/hid-axff.c) with full
force feedback support.
Signed-off-by: Tristan Rice <rice@outerearth.net>
commit e078809df5611600965f4d3420c3256260fc3e3d upstream.
Forgot two special driver declarations and sorted the list.
Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net>
commit 7be63f20b00840a6f1c718dcee00855688d64acd upstream.
Add missing switch breaks.
commit 14fc4290df2fb94a28f39dab9ed32feaa5527bef upstream.
Ryos uses a new return value for critical errors, others have been
confirmed.
commit 7f50547059bd55ac6a98c29fd1989421bdc36ec9 upstream.
By default the Logitech Formula Vibration presents a combined accel/brake
commit 114a55cf9dd1576e7ac56189832cd4d7dc56c218 upstream.
Re-arrange code slightly to ensure that device properties are configured
before calling auto-center command.
Reported-by: Michal Malý <madcatxster@prifuk.cz>
commit d2c02da549b468bbb28e67d269bd3c9e10683ff5 upstream.
When the autocenter is set to zero, this patch issues a command to
totally disable the autocenter - this results in less resistance
in the wheel.
Reported-by: Elias Vanderstuyft <elias.vds@gmail.com>
commit f8c231569a7a455dfa1907294a46ba52b3aa8859 upstream.
Adjust the scaling and lineartity to match that of the Windows
driver (from MOMO testing).
commit bf9d121efc18c30caa2caad85358cf9408eca117 upstream.
This patch adds PID VID to support for the Wistron Inc. Optical touch panel.
Signed-off-by: KaiChung Cheng <kenny_cheng@wistron.com>
commit d4b1bba76171cb783e32441b28462fe841073ed8 upstream.
Most of the hid sensor field size is reported in report_size field
in the report descriptor. For rotation fusion sensor the quaternion
data is 16 byte field, the report size was set to 4 and report
count field is set to 4. So the total size is 16 bytes. But the current
driver has a bug and not taking account for report count field. This
causes user space to see only 4 bytes of data sent via IIO interface.
The number of bytes in a field needs to take account of report_count
field. Need to multiply report_size and report_count to get total
number of bytes.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
commit a6802e008e19845fd9669511b895f7515ef9c48b upstream.
Add support for SiS multitouch panels.
Signed-off-by: Forest Bond <forest.bond@rapidrollout.com>
commit bd04363d3990c0727b7512a79a08c68436878bb0 upstream.
Add USB IDs for Logitech Formula Vibration Feedback Wheel (046d:ca04).
The lg2ff force feedback subdriver is used for vibration and
HID_GD_MULTIAXIS is set to avoid deadzone like other Logitech wheels.
Kconfig description etc are also updated accordingly.
Signed-off-by: Elias Vanderstuyft <Elias.vds@gmail.com>
[anssi.hannula@iki.fi: added description and CCs]
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
commit 7b2262920db2b98fe2cd32cde52141f02fd9eecf upstream.
GeneralTouch products should use the quirk SLOT_IS_CONTACTID
instead of SLOT_IS_CONTACTNUMBER.
Adding PIDs 0101,e100,0102,0106,010a from the new products.
Tested on new and older products by GeneralTouch engineers.
Signed-off-by: Luosong <android@generaltouch.com>
commit 95d50b6c5e18ff7351c5f2a6ff53afaed5f7e664 upstream.
Certain devices with class HID, protocol None did not work with the HID
driver at one point, and as a result were bound to usbtouchscreen
instead as of commit 139ebe8 ("Input: usbtouchscreen - fix eGalax HID
ignoring"). This change was prompted by the following report:
https://lkml.org/lkml/2009/1/25/127
Unfortunately, the device mentioned in this report is no longer
available for testing.
We've recently discovered that some devices with class HID, protocol
None do not work with usbtouchscreen, but do work with usbhid. Here is
the report that made this evident:
http://comments.gmane.org/gmane.linux.kernel.input/31710
Driver binding for these devices has flip-flopped a few times, so both
of the above reports were regressions.
This situation would appear to leave us with no easy way to bind every
device to the right driver. However, in my own testing with several
devices I have not found a device with class HID that does not work with
the current HID driver. It is my belief that changes to the HID driver
since the original report have likely fixed the issue(s) that made it
unsuitable at the time, and that we should prefer it over usbtouchscreen
for these devices. In particular, HID quirks affecting these devices
were added/removed in the following commits since then:
fe6065d HID: add multi-input quirk for eGalax Touchcontroller
77933c3 Merge branch 'egalax' into for-linus
ebd11fe HID: Add quirk for eGalax touch controler.
d34c4aa HID: add no-get quirk for eGalax touch controller
This patch makes the HID driver no longer ignore eGalax/D-Wav/EETI
devices with class HID. If there are in fact devices with class HID
that still do not work with the HID driver, we will see another round of
regressions. In that case I propose we investigate why the device is
not working with the HID driver rather than re-introduce regressions for
functioning HID devices by again binding them to usbtouchscreen.
The corresponding change to usbtouchscreen will be made separately.
commit 80897aa787ecd58eabb29deab7cbec9249c9b7e6 upstream.
UHID allows short writes so user-space can omit unused fields. We
automatically set them to 0 in the kernel. However, the 64/32 bit
compat-handler didn't do that in the UHID_CREATE fallback. This will
reveal random kernel heap data (of random size, even) to user-space.
Fixes: befde0226a59 ('HID: uhid: make creating devices work on 64/32 systems')
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
According to specifications, HID over I2C devices
are not bound to respond to query for INPUT
REPORTS. Thus dropping the call during init
as many devices do not respond causing error
messages during boot.
Bug 1372332
Cherry-picked from http://www.spinics.net/lists/linux-input/msg27869.html
Change-Id: Id6fd0f07f8f94060c9e3fad7349a12452a31da23
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/325939
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
This is the 3.10.17 stable release
drivers/usb/host/xhci.c
Change-Id: I6bd3b15ff92a0b94568b9d02e9bb1036becfca20
commit 19872d20c890073c5207d9e02bb8f14d451a11eb upstream.
udev has this nice feature of creating "dead" /dev/<node> device-nodes if
it finds a devnode:<node> modalias. Once the node is accessed, the kernel
automatically loads the module that provides the node. However, this
requires udev to know the major:minor code to use for the node. This
feature was introduced by:
commit 578454ff7eab61d13a26b568f99a89a2c9edc881
Author: Kay Sievers <kay.sievers@vrfy.org>
Date: Thu May 20 18:07:20 2010 +0200
driver core: add devname module aliases to allow module on-demand auto-loading
However, uhid uses dynamic minor numbers so this doesn't actually work. We
need to load uhid to know which minor it's going to use.
Hence, allocate a static minor (just like uinput does) and we're good
to go.
Reported-by: Tom Gundersen <teg@jklm.no>
commit 60cbd53e4bf623fe978e6f23a6da642e730fde3a upstream.
For simple device node creation, add the devname module alias.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
commit a4be0ed39f2b1ea990804ea54e39bc42d17ed5a5 upstream.
KonePureOptical is a KonePure with different sensor.
commit 27ce405039bfe6d3f4143415c638f56a3df77dca upstream.
implement() is setting bytes in LE data stream. In case the data is not
aligned to 64bits, it reads past the allocated buffer. It doesn't really
change any value there (it's properly bitmasked), but in case that this
read past the boundary hits a page boundary, pagefault happens when
accessing 64bits of 'x' in implement(), and kernel oopses.
This happens much more often when numbered reports are in use, as the
initial 8bit skip in the buffer makes the whole process work on values
which are not aligned to 64bits.
This problem dates back to attempts in 2005 and 2006 to make implement()
and extract() as generic as possible, and even back then the problem
was realized by Adam Kroperlin, but falsely assumed to be impossible
to cause any harm:
http://www.mail-archive.com/linux-usb-devel@lists.sourceforge.net/msg47690.html
I have made several attempts at fixing it "on the spot" directly in
implement(), but the results were horrible; the special casing for processing
last 64bit chunk and switching to different math makes it unreadable mess.
I therefore took a path to allocate a few bytes more which will never make
it into final report, but are there as a cushion for all the 64bit math
operations happening in implement() and extract().
All callers of hid_output_report() are converted at the same time to allocate
the buffer by newly introduced hid_alloc_report_buf() helper.
Bruno noticed that the whole raw_size test can be dropped as well, as
hid_alloc_report_buf() makes sure that the buffer is always of a proper
size.
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Acked-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 297502abb32e225fb23801fcdb0e4f6f8e17099a upstream.
A HID device could send a malicious output report that would cause the
logitech-dj HID driver to leak kernel memory contents to the device, or
trigger a NULL dereference during initialization:
[ 304.424553] usb 1-1: New USB device found, idVendor=046d, idProduct=c52b
[ 304.780467] BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
[ 304.781409] IP: [<ffffffff815d50aa>] logi_dj_recv_send_report.isra.11+0x1a/0x90
CVE-2013-2895
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
commit 0a9cd0a80ac559357c6a90d26c55270ed752aa26 upstream.
lenovo-tpkbd HID driver to write just beyond the output report allocation
during initialization, causing a heap overflow:
[ 76.109807] usb 1-1: New USB device found, idVendor=17ef, idProduct=6009
[ 80.462540] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten
CVE-2013-2894
commit 41df7f6d43723deb7364340b44bc5d94bf717456 upstream.
steelseries HID driver to write beyond the output report allocation
[ 167.981534] usb 1-1: New USB device found, idVendor=1038, idProduct=1410
[ 182.050547] BUG kmalloc-256 (Tainted: G W ): Redzone overwritten
CVE-2013-2891
commit 0ccdd9e7476680c16113131264ad6597bd10299d upstream.
If tpkbd_probe_tp() bails out, the probe() function return an error,
but hid_hw_stop() is never called.
fixes:
https://bugzilla.redhat.com/show_bug.cgi?id=1003998
commit 78214e81a1bf43740ce89bb5efda78eac2f8ef83 upstream.
The zeroplus HID driver was not checking the size of allocated values
in fields it used. A HID device could send a malicious output report
that would cause the driver to write beyond the output report allocation
[ 1442.728680] usb 1-1: New USB device found, idVendor=0c12, idProduct=0005
[ 1466.243173] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten
CVE-2013-2889
commit 0fb6bd06e06792469acc15bbe427361b56ada528 upstream.
lg, lg3, and lg4 HID drivers to write beyond the output report allocation
during an event, causing a heap overflow:
[ 325.245240] usb 1-1: New USB device found, idVendor=046d, idProduct=c287
[ 414.518960] BUG kmalloc-4096 (Not tainted): Redzone overwritten
Additionally, while lg2 did correctly validate the report details, it was
cleaned up and shortened.
CVE-2013-2893
commit 8821f5dc187bdf16cfb32ef5aa8c3035273fa79a upstream.
When working on report indexes, always validate that they are in bounds.
Without this, a HID device could report a malicious feature report that
could trick the driver into a heap overflow:
[ 634.885003] usb 1-1: New USB device found, idVendor=0596, idProduct=0500
[ 676.469629] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten
Note that we need to change the indexes from s8 to s16 as they can
be between -1 and 255.
CVE-2013-2897
commit cc6b54aa54bf40b762cab45a9fc8aa81653146eb upstream.
When dealing with usage_index, be sure to properly use unsigned instead of
int to avoid overflows.
When working on report fields, always validate that their report_counts are
in bounds.
CVE-2013-2897
commit 331415ff16a12147d57d5c953f3a961b7ede348b upstream.
Many drivers need to validate the characteristics of their HID report
during initialization to avoid misusing the reports. This adds a common
helper to perform validation of the report exisitng, the field existing,
and the expected number of values within the field.
commit 9e0bf92c223dabe0789714f8f85f6e26f8f9cda4 upstream.
The DuoSense touchscreen device causes a 10 second timeout. This fix
removes the delay.
Signed-off-by: Vasily Titskiy <qehgt0@gmail.com>
