[ Upstream commit 67fd71ba16a37c663d139f5ba5296f344d80d072 ]
Apple Magic Keyboard(JIS)'s Logical Maximum and Usage Maximum are wrong.
Below is a report descriptor.
0x05, 0x01, /* Usage Page (Desktop), */
0x09, 0x06, /* Usage (Keyboard), */
0xA1, 0x01, /* Collection (Application), */
0x85, 0x01, /* Report ID (1), */
0x05, 0x07, /* Usage Page (Keyboard), */
0x15, 0x00, /* Logical Minimum (0), */
0x25, 0x01, /* Logical Maximum (1), */
0x19, 0xE0, /* Usage Minimum (KB Leftcontrol), */
0x29, 0xE7, /* Usage Maximum (KB Right GUI), */
0x75, 0x01, /* Report Size (1), */
0x95, 0x08, /* Report Count (8), */
0x81, 0x02, /* Input (Variable), */
0x95, 0x05, /* Report Count (5), */
0x05, 0x08, /* Usage Page (LED), */
0x19, 0x01, /* Usage Minimum (01h), */
0x29, 0x05, /* Usage Maximum (05h), */
0x91, 0x02, /* Output (Variable), */
0x95, 0x01, /* Report Count (1), */
0x75, 0x03, /* Report Size (3), */
0x91, 0x03, /* Output (Constant, Variable), */
here is a report descriptor which is parsed one in kernel.
see sys/kernel/debug/hid/<dev>/rdesc
05 01 09 06 a1 01 85 01 05 07
15 00 25 01 19 e0 29 e7 75 01
95 08 81 02 95 05 75 01 05 08
19 01 29 05 91 02 95 01 75 03
91 03 95 08 75 01 15 00 25 01
06 00 ff 09 03 81 03 95 06 75
08 15 00 25 [65] 05 07 19 00 29
[65] 81 00 95 01 75 01 15 00 25
01 05 0c 09 b8 81 02 95 01 75
01 06 01 ff 09 03 81 02 95 01
75 06 81 03 06 02 ff 09 55 85
55 15 00 26 ff 00 75 08 95 40
b1 a2 c0 06 00 ff 09 14 a1 01
85 90 05 84 75 01 95 03 15 00
25 01 09 61 05 85 09 44 09 46
81 02 95 05 81 01 75 08 95 01
15 00 26 ff 00 09 65 81 02 c0
00
Position 64(Logical Maximum) and 70(Usage Maximum) are 101.
Both should be 0xE7 to support JIS specific keys(ろ, Eisu, Kana, |) support.
position 117 is also 101 but not related(it is Usage 65h).
There are no difference of product id between JIS and ANSI.
They are same 0x0267.
Signed-off-by: Mizuho Mori <morimolymoly@gmail.com>
[ Upstream commit aec256d0ecd561036f188dbc8fa7924c47a9edfd ]
This fixes an issue in which key down events for function keys would be
repeatedly emitted even after the user has raised the physical key. For
example, the driver fails to emit the F5 key up event when going through
the following steps:
- fnmode=1: hold FN, hold F5, release FN, release F5
- fnmode=2: hold F5, hold FN, release F5, release FN
The repeated F5 key down events can be easily verified using xev.
Signed-off-by: Joao Moreno <mail@joaomoreno.com>
Co-developed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
This patch adds keyboard support for MacbookPro12,1 as WELLSPRING9
(0x0272, 0x0273, 0x0274). The touchpad is handled in a separate
bcm5974 patch, as usual.
Tested-by: John Horan <knasher@gmail.com>
Tested-by: Jochen Radmacher <jradmacher@gmx.de>
Tested-by: Yang Hongyang <burnef@gmail.com>
Tested-by: Yen-Chin, Lee <coldnew.tw@gmail.com>
Tested-by: George Hilios <ghilios@gmail.com>
Tested-by: Janez Urevc <janez@janezurevc.name>
Signed-off-by: Henrik Rydberg <rydberg@bitmath.org>
Acked-by: Jiri Kosina <jkosina@suse.com>
Add Apple wireless keyboard 2011 JIS model (05ac:0257).
Signed-off-by: Huei-Horng Yo <hiroshi@ghostsinthelab.org>
Global static variable is already zero-initialized.
Use case: people who use both Apple and PC keyboards regularly, and desire to
keep&use their PC muscle memory.
A particular use case: an Apple compact external keyboard connected to a PC
laptop. (This use case can't be covered well by X.org key remappings etc.)
Signed-off-by: Nanno Langstraat <langstr@gmail.com>
'for-3.12/logitech', 'for-3.12/multitouch-win8', 'for-3.12/trasnport-driver-cleanup', 'for-3.12/uhid', 'for-3.12/upstream' and 'for-3.12/wiimote' into for-linus
It is safe to use devres allocation within the hid subsystem:
- the devres release is called _after_ the call to .remove(), meaning
that no freed pointers will exists while removing the device
- if a .probe() fails, devres releases all the allocated ressources
before going to the next driver: there will not be ghost ressources
attached to a hid device if several drivers are probed.
Given that, we can clean up a little some of the HID drivers. These ones
are trivial:
- there is only one kzalloc in the driver
- the .remove() callback contains only one kfree on top of hid_hw_stop()
- the error path in the probe is easy enough to be manually checked
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
This patch adds keyboard support for MacbookAir6,2 as WELLSPRING8
(0x0291, 0x0292, 0x0293). The touchpad is handled in a separate
Cc: stable@vger.kernel.org
Reported-and-tested-by: Brad Ford <plymouthffl@gmail.com>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
'for-3.10/hid-driver-transport-cleanups', 'for-3.10/i2c-hid' and 'for-3.10/logitech' into for-linus
This driver was originally written by James McKenzie, updated by
Greg Kroah-Hartman, further updated by Bastien Nocera, with suspend
support added.
I ported it to the HID subsystem, in order to simplify it a litle
and allow lirc to use it through hiddev.
More recent versions of the IR receiver are also supported through
a patch by Alex Karpenko. The patch also adds support for the 2nd
and 5th generation of the controller, and the menu key on newer
brushed metal remotes.
Tested-by: Fabien André <fabien.andre@gmail.com>
Most HID drivers (rightfully) only depend on the HID bus, not the
specific transport layer. Remove such dependencies where applicable.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Use the new module_hid_driver macro in all HID drivers that have
a simple register/unregister init/exit.
This also converts the hid drivers that test for a failure of
hid_register_driver() and report the failure. Using module_hid_driver
in those drivers removes the failure message.
'for-3.8/i2c-hid', 'for-3.8/multitouch', 'for-3.8/roccat', 'for-3.8/sensors' and 'for-3.8/upstream' into for-linus
drivers/hid/hid-core.c
Set APPLE_ISO_KEYBOARD flag on USB_DEVICE_ID_APPLE_GEYSER4_HF_ISO so we get
the ISO translation on German keyboards for the MacBook4,1 as well.
Signed-off-by: Johannes Thumshirn <morbidrsa@googlemail.com>
This enables the existing drivers for keyboard and touchpad with the new
USB IDs found on the MBP 13" Reasonable Resolution (also known as the
Retina Display).
Added entries to both keyboard and mouse ignore lists.
Signed-off-by: Dirk Hohndel <dirk@hohndel.org>
Paul Walmsley has implemented dynamic quirk handling back in 2007 through
commits:
2eb5dc30eb ("USB HID: encapsulate quirk handling into hid-quirks.c")
8222fbe67c ("USB HID: clarify static quirk handling as squirks")
8cef908235 ("USB HID: add support for dynamically-created quirks")
876b9276b9 ("USB HID: add 'quirks' module parameter")
and as such, his copyright rightly belongs to
drivers/hid/usbhid/hid-quirks.c file.
However when generic HID code has been converted to bus and individual
quirks separated out to individual drivers on the bus, the copyright has
been blindly transfered into all the tiny drivers, which actually don't
contain any of Pauls' copyrighted code.
Remove the copyright from those sub-drivers.
Acked-by: Paul Walmsley <paul@pwsan.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input layer fixes from Dmitry Torokhov:
"The changes are limited to adding new VID/PID combinations to drivers
to enable support for new versions of hardware, most notably hardware
found in new MacBook Pro Retina boxes."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: xpad - add Andamiro Pump It Up pad
Input: xpad - add signature for Razer Onza Tournament Edition
Input: xpad - handle all variations of Mad Catz Beat Pad
Input: bcm5974 - Add support for 2012 MacBook Pro Retina
HID: add support for 2012 MacBook Pro Retina
Add support for the 15'' MacBook Pro Retina. The keyboard is
the same as recent models.
The patch needs to be synchronized with the bcm5974 patch for
the trackpad - as usual.
Patch originally written by clipcarl (forums.opensuse.org).
[rydberg@euromail.se: Amended mouse ignore lines]
Signed-off-by: Ryan Bourgeois <bluedragonx@gmail.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: Alexey Kaminsky <me@akaminsky.net>
Fixed a style issue.
Signed-off-by: Benedikt Bergenthal <benedikt@kdrennert.de>
This removes the use of the special "macbookair_fn_keys" keyboard
translation table for the MacBookAir4,x models (ie the 2011 refresh).
They use the standard apple_fn_keys[] translation. Apparently only the
old MacBook Air's need a different translation table.
This mirrors the change that commit da617c7cb915 ("HID: consolidate
MacbookAir 4,1 mappings") did for the WELLSPRING6A ones, but does it for
the WELLSPRING6 model used on the MacBookAir4,2.
Reported-and-tested-by: Dirk Hohndel <hohndel@infradead.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Joshua V Dillon <jvdillon@gmail.com>
Cc: Chase Douglas <chase.douglas@canonical.com>
I've recently bought a Apple wireless aluminum keyboard (model 2011) which is
not yet supported by the kernel - it seems they just changed the device id.
After applying the attached patch, the device is fully functional.
Signed-off-by: Andreas Krist <andreas.krist@gmail.com>
This patch adds keyboard support for Macbook Pro 8 models which has
WELLSPRING5A model name and 0x0252, 0x0253 and 0x0254 USB IDs. Trackpad
support for those models are added to bcm5974 in
c331eb580a0a7906c0cdb8dbae3cfe99e3c0e555 ("Input: bcm5974 - Add
support for newer MacBookPro8,2).
Signed-off-by: Gökçen Eraslan <gokcen@pardus.org.tr>
drivers/hid/hid-ids.h
MacbookAir 4,1 doesn't require extra mapping table, as the mappings
are identical to apple_fn_keys[].
Added USB device IDs and keyboard map for MacBookAir 4,1 keyboard.
Added USB device IDs for MacBookAir4,2 keyboard. Device constants were
copied from the MacBookAir3,2 constants. The 4,2 device specification is
reportedly unchanged from the 3,2 predecessor and seems to work well.
Signed-off-by: Joshua V Dillon <jvdillon@gmail.com>
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
Add USB device ids for the new revision (MB110LL/B) of Apple's wired aluminum
keyboard. I have only confirmed that the ANSI version is correct - it is
assumed that the ISO and JIS versions follow the standard numbering convention.
Signed-off-by: Dan Bastone <dan@pwienterprises.com>
This patch add multitouch support for the MacBookPro8,1 and
MacBookPro8,2 models.
Cc: stable@kernel.org
Signed-off-by: Andy Botting <andy@andybotting.com>
Neaten current uses of dev_<level> by adding and using
hid specific hid_<level> macros.
Convert existing uses of dev_<level> uses to hid_<level>.
Convert hid-pidff printk uses to hid_<level>.
Remove err_hid and use hid_err instead.
Add missing newlines to logging messages where necessary.
Coalesce format strings.
Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Other miscellaneous changes:
Add const struct hid_device * argument to hid-core functions
extract() and implement() so hid_<level> can be used by them.
Fix bad indentation in hid-core hid_input_field function
that calls extract() function above.
Reshuffle the code a little bit so that the translation table selection
is more obvious and there is only one place performing the actual
translation using the selected table.
This patch add support for the MacBookAir3,1 and MacBookAir3,2 to the hid
driver.
Signed-off-by: Edgar (gimli) Hucek <gimli@dark-green.com>
Update hid_driver's report_fixup prototype to allow changing report
descriptor size and/or returning completely different report descriptor.
Update existing usage accordingly.
This is to give more freedom in descriptor fixup and to allow having a whole
fixed descriptor in the code for the sake of readability.
Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Added device IDs for the new model of the Apple Wireless Keyboard
(November 2009).
Signed-off-by: Christian Schuerer-Waldheim <csw@xray.at>
This patch adds a new option named "iso_layout" to the driver
"hid-apple.ko", to allow disabling of the hard-coded ISO-layout.
Disabling the hard-coded layout solves the problem that the kernel-module only
works perfectly for the english/american version of the Apple aluminum
keyboard. Other versions have swapped keys, e.g. the "<"-key is swapped with
"^"-key on the german keyboard. There is a very long bug-entry on Launchpad to
this problem:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/214786
Signed-off-by: Stefan Glasenhardt <stefan@glasen-hardt.de>
Trivial patch which adds the __init and __exit macros to the module_init /
module_exit functions of several HID drivers from drivers/hid/
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Bluetooth version of Apple Mighty mouse (0x05ac/0x030c) doesn't, according to
multiple reports on linux-input@, need the same quirk as the USB version of
this mouse (0x05ac/0x0304) does.
Quirks for the apple mini keyboard was recently added but keyboard
was recognized as a powerbook keyboard. Adjusted boundary to the lowest
product id for the apple mini keyboard to get the right translation.
Signed-off-by: Ulrich Dangel <uli@spamt.net>
This removal was scheduled and there is no problem with later
distros to adapt for the new bus, thanks to aliases.
module-init-tools map files are deprecated nowadays, so that
the patch which introduced hid ones into the m-i-t won't be
accepted and hence there is no reason for leaving compat stuff in.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Mark arrays of struct apple_key_translation const so that they may be placed in
.rodata, and adjust users to suit.
Signed-off-by: Paul Collins <paul@ondioline.org>
New USB device ids and quirks for the "mini" Apple USB aluminum
keyboards released Tuesday, model A1242. Note that while I own the ANSI
(0x021d) version and cannot verify that the ISO (0x021e) and JIS
(0x021f) versions exist, previous releases have followed the triple id
convention for awhile now, and the device ids fit perfectly between
USB_DEVICE_ID_APPLE_GEYSER4_* and USB_DEVICE_ID_APPLE_ALU_*.
Signed-off-by: Ryan Finnie <ryan@finnie.org>
While parsing 'hid_blacklist' in the apple alu wireless keyboard is not found.
This happens because in the blacklist it is declared with HID_USB_DEVICE
although the keyboards are really bluetooth devices. The same holds for
'apple_devices' list.
This patch fixes it by changing HID_USB_DEVICE to HID_BLUETOOTH_DEVICE in those
two lists.
Signed-off-by: Jan Scholz <Scholz@fias.uni-frankfurt.de>
On macbooks there are specific keys for the user-space functions Expose
and Dashboard, which currently has no counterpart in input.h. This patch
adds KEY_SCALE and KEY_DASHBOARD, and maps the keyboard accordingly.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
The unibody MacBook 5 and MacBook Pro 5 come with a new version of
the bcm5974 trackpad. This patch adds the USB device ids and all
the appropriate quirks, including hid_blacklist.
The appletouch mouse devices are grabbed by the hid bus and not
released even if apple driver says ENODEV (as expected) -- these
are composite USB devices, for which we only ignore the mouse
interface. This is currently not handled by hidbus code properly.
Move the ignoring one level upper to forbid the hid layer to grab the
device.
Reported-by: Justin Mattock <justinmattock@gmail.com>
Reported-by: Steven Noonan <steven@uplinklabs.net>
Similar to the existing IRCONTROL4 handling
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
