Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Causes build failures with gcc 8.
Merge NVIDIA's latest Linux for Tegra aka L4T R21.7 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
e78bb38b883c42edf81766a1d557aed74458e08f
Conflicts involved missing 24-bit LVDS support and a single whitespace
aka tab difference in drivers/video/tegra/dc/sor.c.
Data can be speculatively loaded from memory and stay in cache even
when bound check fails. This can lead to unintended information
disclosure via side-channel analysis.
To mitigate this problem insert a speculation barrier.
bug 2039126
CVE-2017-5753
Change-Id: Ib6c4b2f99b85af3119cce3882fe35ab47509c76f
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1640500
Signed-off-by: James Huang <jamehuang@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1650050
(cherry picked from commit f293fa670fd2f4fbe170f1e372e9aa237283c67a)
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1682715
Reviewed-on: https://git-master.nvidia.com/r/1698610
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Bibek Basu <bbasu@nvidia.com>
Make sure that the VM owned by a channel lives for at least
as long as that channel does. If the channel's VM is cleaned
up before the channel then use-after-free bugs can occur.
Bug: 31680980
NvBug 1825464
Bug: 1885921
Change-Id: I0711781492a764b643c2ed1da1b3ba87fda72744
Reviewed-on: https://git-psac.nvidia.com/r/#/c/9261
Signed-off-by: Debarshi Dutta <ddutta@nvidia.com>
(cherry picked from commit e205f2720fcee61886e7979e9588602d691507ea)
Reviewed-on: https://git-master.nvidia.com/r/1681801
Validate the mapping_size argument in the VM mapping IOCTL before
attempting to use the argument for anything.
Manual Cherry pick - https://git-master.nvidia.com/r/1547046
Bug 1954931
Bug 1965443
Change-Id: I81b22dc566c6c6f89e5e62604ce996376b33a343
Reviewed-on: https://git-master.nvidia.com/r/1547046
(cherry picked from commit e68391690cfcc23b77c68aec3f9605badea226ed in
dev-kernel)
Reviewed-on: https://git-master.nvidia.com/r/1671883
Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes
b271e8fa67a6d9c4600274a25636cfe00fdd1b68
Bug 200336148
This reverts commit 2db040946ff8340485b2b33fe5a46f3166fa96f6.
Change-Id: I8a80a7bd1bd8b1a949fba26b683ac1c9bebc0c04
Reviewed-on: https://git-master.nvidia.com/r/1534941
We have never used the IOCTL FREE_OBJ_CTX. Using it leads to context being
only partially available, and can lead to use-after-free.
Bug 1885775
Change-Id: I9d2b632ab79760f8186d02e0f35861b3a6aae649
Reviewed-on: https://git-master.nvidia.com/r/1506479
Use the correct page size index for pgsz_idx in gk20a_vm_alloc_space().
Previously the page size itself was used, not the page size index.
Bug 1837624
Change-Id: I652f5af5321c1c49dc8eb170d3f92f00c23d2b6f
(cherry picked from commit fd13e0e1c4e397335c24497a0f92c85934d6185f)
Reviewed-on: http://git-master/r/1503371
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
gk20a_channel_release() should bail if filp->private_data is
NULL. This can happen as a result of gk20a_channel_release()
being called when __gk20a_channel_open() fails in
NVHOST_IOCTL_CHANNEL_OPEN.
Bug 200014898
Change-Id: I32cc957aca46fcd4265a8052ac5be355b644b9f7
Signed-off-by: Aingara Paramakuru <aparamakuru@nvidia.com>
Reviewed-on: http://git-master/r/496138
(cherry picked from commit cb0db6618c42ab4c33574f09f212ab1ee9a0438a)
Reviewed-on: http://git-master/r/1258588
Tested-by: Winnie Hsu <whsu@nvidia.com>
The size here comes from the user via the ioctl, it is a number between
1-u32max so the addition here could overflow on 32 bit systems.
This patch fixes a security vulnerability reported here:
https://code.google.com/p/android/issues/detail?id=228947
Change-Id: I17ed8c6e30826074cfc6dd833deb423be9bd89c5
Fixes: f453ba046074 ('DRM: add mode setting support')
Reviewed-by: Daniel Stone <daniels@collabora.com>
Cc: stable@kernel.org # v4.2
Signed-off-by: Dave Airlie <airlied@gmail.com>
Bug 1846814
Signed-off-by: Shreshtha SAHU <ssahu@nvidia.com>
Change-Id: I308e65797972a0a0650bd96bd130dfd2fbe9c993
Reviewed-on: http://git-master/r/1262503
dma_buf_get() return value is now validated before
passed down for further process.
Bug 1812180
Bug 1883864
Change-Id: I443d676af2948c924f187988ab1c64c72b3e9232
Signed-off-by: Xia Yang <xiay@nvidia.com>
Reviewed-on: http://git-master/r/1220869
(cherry picked from commit e6fe9437c609252cf28ac76d2e6b33e905eaa843 in rel-21)
Reviewed-on: http://git-master/r/1469135
Initialize character array buf in gk20a_channel_ioctl() to zero
Keeping it uninitialized can result in leaking kernel stack
info to user space since we pass this buffer to UMD
Bug 1793398
Change-Id: Iffd654dbaca3b4e3c8fd2ac270d0febd01c165b8
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/1195862
(cherry picked from commit 118809f4bd07af20df2b6c012828834695a5fccf from dev-kernel linux-nvgpu.git)
Reviewed-on: http://git-master/r/1269683
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Reviewed-by: Christian Gonzalez <christiang@nvidia.com>
Tested-by: Christian Gonzalez <christiang@nvidia.com>
A use-after-free scenario is possible where one thread in
gk20a_free_error_notifiers() is trying to free the error
notifier and another thread in gk20a_set_error_notifier()
is still using the error notifier
Fix this by introducing mutex error_notifier_mutex for
error notifier accesses
Take mutex in gk20a_free_error_notifiers() and in
gk20a_set_error_notifier() before accessing notifier
In gk20a_init_error_notifier(), set the pointer
ch->error_notifier_ref inside the mutex and only
after notifier is completely initialized
Bug 1824788
Change-Id: I47e1ab57d54f391799f5a0999840b663fd34585f
Reviewed-on: http://git-master/r/1233988
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Signed-off-by: Gaurav Singh <gaursingh@nvidia.com>
Reviewed-on: http://git-master/r/1236695
Reviewed-by: Deepak Nibade <dnibade@nvidia.com>
drivers/gpu/nvgpu/gk20a/mm_gk20a.c:124:18: error:
'gmmu_page_masks' defined but not used [-Werror=unused-const-variable=]
static const u64 gmmu_page_masks[gmmu_nr_page_sizes] = { ~0xfffLL,
~0x1ffffLL };
drivers/gpu/nvgpu/gk20a/regops_gk20a.c:344:40: error:
'gk20a_runcontrol_whitelist_ranges' defined but not used
static const struct regop_offset_range gk20a_runcontrol_whitelist_ranges[] = {
drivers/gpu/nvgpu/gk20a/regops_gk20a.c:350:18: error:
'gk20a_runcontrol_whitelist_ranges_count' defined but not used
static const u32 gk20a_runcontrol_whitelist_ranges_count =
drivers/gpu/nvgpu/gk20a/regops_gk20a.c:366:40: error:
'gk20a_qctl_whitelist_ranges' defined but not used
static const struct regop_offset_range gk20a_qctl_whitelist_ranges[] = {
drivers/gpu/nvgpu/gk20a/regops_gk20a.c:373:18: error:
'gk20a_qctl_whitelist_ranges_count' defined but not used
static const u32 gk20a_qctl_whitelist_ranges_count =
Make sure that the notification object fits within the supplied buffer.
Bug 1739182
Change-Id: Ifb66f848e3758438f37645be6f534f5b60260214
Signed-off-by: Konsta Holtta <kholtta@nvidia.com>
Reviewed-on: http://git-master/r/1026431
(cherry picked from commit 2484c47f123c717030aa00253446e8756e1a0807)
Reviewed-on: http://git-master/r/1030663
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Make sure that the notifier object fits within the supplied buffer.
Bug 1739183
Bug 1739932
Change-Id: I713574ce797ffc23cec10b5114f469dbadc68f1e
Reviewed-on: http://git-master/r/1026410
(cherry picked from commit f476b93eb19b962b8760457102448bd533efc54d)
Reviewed-on: http://git-master/r/1029379
re-order POWERGATE_ENABLE operations in opposite
order of POWERGATE_DISABLE
Bug 1679372
Change-Id: Ib72a0b80929e2dee2cf88a6d3d0f96d61c02307b
Reviewed-on: http://git-master/r/796459
(cherry picked from commit 7e2668f924a986d4bd7d1d2c383431a5e80d9968)
Reviewed-on: http://git-master/r/801977
Currently, while releasing the debug session we enable powergate
only if a channel is bound to session
If a session has no channel bound to it, and has powergate
disabled, then we do not enable powergate when that session
is closed
Fix this by calling dbg_set_powergate(POWERGATE_ENABLE) always
while releasing the session
Refcounting and sanity checks in dbg_set_powergate() will take
care of situation if powergate was not disabled by the session
in first place
Bug 1679372
Change-Id: I4e027393c611d3e8ab4f20e195f31871086da736
Reviewed-on: http://git-master/r/796999
cherry picked from commit 671dff8cb0605f865c5da32bd889e2a6fcf133fe)
Reviewed-on: http://git-master/r/801986
Initialize uninitialized variables to get the
build through
Bug 1640594
Change-Id: Ia0788c5852bb8d68a79004e3f2fa1b3d2b9ca2fe
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/772239
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
This reverts commit f69b7093accdacfa653b4bd45d78e04a2676dc2a.
Bug 200055546
Bug 200114503
Change-Id: I165a3da9f418657d86bf39fbe3db2adc13762c87
Signed-off-by: Winnie Hsu <whsu@nvidia.com>
Reviewed-on: http://git-master/r/759875
When updating SMPC WAR for channel, it needs to be kicked out. This
ensures that the updated information is re-read from context header.
Bug 1579548
Change-Id: Ieadc6b65b057d7f48dc16fbc786c881ab7e5fcd5
Signed-off-by: Sandarbh Jain <sanjain@nvidia.com>
Reviewed-on: http://git-master/r/756639
GR status disable mask was never set, so driver always disabled all
engines from status rollup.
Change-Id: I500a127be9253294f73d1f42ce89b886471a9117
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/719141
(cherry picked from commit 34a5ffe7e7dcc4df5f3a11848b828e96c43d2c4d)
Reviewed-on: http://git-master/r/752092
if vpr memory is carved out, then only call dma_alloc
for secure memory.
Bug 200057068
Change-Id: I12557cfaa48f7db729ccab17d3151916d35ce0f1
Reviewed-on: http://git-master/r/746153
This patch converts message of absence of vga device as a
debug print. This message comes when client tries to
access device on PCI which is absent, in this case DSI.
Bug 1481761
Change-Id: I7d83d39735e51bca8c789a86e517c0a040de57e8
Signed-off-by: Pankaj Dabade <pdabade@nvidia.com>
Reviewed-on: http://git-master/r/739571
-Moved bind fecs from work queue to init_gr_support.
-It makes all CPU->FECS communication to happen before
booting PMU, and after we boot PMU, only PMU talks to
FECS. So it removes possibility to race between CPU
and PMU talking to FECS.
Bug 200032923
Bug 1570774
Change-Id: I01d6d7f61f5e3c0e788d9d77fcabe5a91fe86c84
Reviewed-on: http://git-master/r/559733
Signed-off-by: Naveen Kumar S <nkumars@nvidia.com>
(cherry picked from commit 1e63d8ae4056dbde82e1788decf7552f0b0af640)
Reviewed-on: http://git-master/r/666712
bug 200040021
bug 200032923
bug 1570774
Change-Id: Ic162902bd2f05abab9ebd37392ed56dc4c164ba8
Reviewed-on: http://git-master/r/539995
(cherry picked from commit 62e9ba6c8fbabcb77e0ec6267463f51ae319a0b3)
Reviewed-on: http://git-master/r/666721
Add PMU state ELPG booting. Prevent ISR processing when PMU is in OFF
state.
Bug 200006956
Change-Id: Ibcf69a2d81965cc87f520bf864c4425681f04531
Reviewed-on: http://git-master/r/424769
(cherry picked from commit f9ce5a2cdf667f8e41f7ed4035678cc1198dc308)
Reviewed-on: http://git-master/r/657487
Invalidate TLB after PDE udpate and before freeing the Page
Table memory
Stale TLBs during unmap can lead us to access invalid PTEs
Bug 1577947
Change-Id: I46c6a7a9079570a8e2af8bb2a6687cfeec83a6f7
Reviewed-on: http://git-master/r/670324
(cherry-picked from commit e4cbdae09949d23ac338209924d35584c5d8d288)
Reviewed-on: http://git-master/r/671197
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
Current sequence :
- delete page tables memory
- update PDE entry and mark above page tables invalid
With this sequence, it is possible to have valid PDE entries
with already freed page table and this could lead us to
invalid memory accesses.
Fix this by switching the sequence as follows :
- update PDE entry and mark page tables invalid
Bug 1577947
Change-Id: Icc3a8c74bbf1bf59e41e0322cfc279d15690aa9d
Reviewed-on: http://git-master/r/670323
(cherry-picked from commit 56f738b4c4ee188ec1f69b91615cd9728ff18cf0)
Reviewed-on: http://git-master/r/671196
Allow suppressing WFI when submitting work and requesting a fence
back.
Bug 1491545
Change-Id: Ic3d061bb4f116cf7ea68dbd6a1b2ace9f11d0ab5
Reviewed-on: http://git-master/r/390457
Reviewed-on: http://git-master/r/671029
Reviewed-by: Sibashis Mohapatra <sibashism@nvidia.com>
Tested-by: Sibashis Mohapatra <sibashism@nvidia.com>
Reviewed-by: Yogesh Kini <ykini@nvidia.com>
Shader informs user about context switch wait time.
This doesn't affect any functionality. Hence changing print to info.
bug 200015967
Change-Id: I7fbb562e43ee6ec1bc8ac01a51d3c9f19d5cb4cf
Reviewed-on: http://git-master/r/662657
Implement support for partial buffer mappings.
Whitelist gr_pri_bes_crop_hww_esr accessed by
fec during sparse texture initialization.
bug 1456562
bug 1369014
bug 1361532
Change-Id: Ib0d1ec6438257ac14b40c8466b37856b67e7e34d
Signed-off-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-on: http://git-master/r/375012
(cherry picked from commit a24470f69961508412402b9b06d5b71fbf6f7549)
Reviewed-on: http://git-master/r/601754
Tested-by: Rajkumar Kasirajan <rkasirajan@nvidia.com>
GPU PMU booting is in a separate thread(workqueue) and currently
there is a race condition that PMU booting doesn't finish when
"nvhost_gk20a_finalize_power_on" is returning.
If the GPU starts to runtime powergate(nvhost_gk20a_prepare_poweroff)
at that time, we left a unfinished PMU booting workqueue task there.
So next time when this task starts running, GPU will be put into
a bad state which causes lots of GPU errors.
This patch adds a wait at the end of "nvhost_gk20a_finalize_power_on"
, so that the race condition can be avoided.
Bug 200055546
Change-Id: I4f2d0798fcadb4effc555a66f3c3e3061b18d246
Signed-off-by: Mark Zhang <markz@nvidia.com>
Signed-off-by: sujeet baranwal <sbaranwal@nvidia.com>
Reviewed-on: http://git-master/r/494065
(cherry picked from commit 3b9866a952ba0a1dea05d20bf32b6bcc9113f38b)
Reviewed-on: http://git-master/r/655952
Workaround for GPU hang if boost turns GPU on before it is
initialized.
Bug 1435870
Change-Id: I07d0617049612344ca7c494da8cb8d75789984e5
Reviewed-on: http://git-master/r/453375
(cherry picked from commit 260cf3d3fab941126eebf4bc977cb408587492eb)
Reviewed-on: http://git-master/r/655951
gk20a_pmu_disable_elpg can be called before the PMU driver has
received and processed the INIT message from the PMU. If change
ensures that the ELPG ref-count has been initialized to zero
before that can happen.
Bug 200016313
Bug 200055546
Change-Id: Ic80ec1ee69b1eb0499effb1abf556f78cb041f5e
Signed-off-by: Neil Gabriel <ngabriel@nvidia.com>
Reviewed-on: http://git-master/r/431927
Reviewed-on: http://git-master/r/436302
(cherry picked from commit dad127648262a76180259525ac660ffa8307f69b)
Reviewed-on: http://git-master/r/655950
Remove an undesired register from the regops whitelist.
Bug 1589712
Change-Id: I76e8ff1f4b68d6d5ce2c11adc08d984df7883e5e
Signed-off-by: Matt Craighead <mcraighead@nvidia.com>
Reviewed-on: http://git-master/r/663371
(cherry picked from commit 573a71d052ac18d34b5f4e984f8684cedea0396d)
Reviewed-on: http://git-master/r/663998
Reviewed-by: Eric Brower <ebrower@nvidia.com>
Updated aelpg parameter APCTRL_CYCLES_PER_SAMPLE_MAX_DEFAULT
default value to 200
Bug 1536384
Bug 200043556
Change-Id: I090e50d0025f16c006429455d161bee26fc64173
Signed-off-by: Mahantesh Kumbar <mkumbar@nvidia.com>
Reviewed-on: http://git-master/r/455440
(cherry picked from commit 4442b73ba0a9fb9d9d6c9c19b319146365ebfa96)
Reviewed-on: http://git-master/r/553687
When determining the chid for the current context, first check
the ctx valid bit.
Bug 1485555
Change-Id: I6c3096d800a6cef38b656d525437a2c4f8b45774
Signed-off-by: Mayank Kaushik <mkaushik@nvidia.com>
Reviewed-on: http://git-master/r/496140
(cherry picked from commit 20a7a9635e9f969782da6695d99bc99c4ed8fa32)
Reviewed-on: http://git-master/r/555054
PBDMA timeout can cause stale data in FIFO. Default value equals 1ms.
Increase it to max.
Bug 1537636
Change-Id: I1c6c6b10abaece3a64b77b9b3ef77ff726ff67cf
Reviewed-on: http://git-master/r/457047
(cherry picked from commit f516652f567a44e2e1c6313dccd3dc80172a980f)
Reviewed-on: http://git-master/r/457067
(cherry picked from commit f5219cf5888502de3f6cabb2db3e8968b6d20b7c)
Reviewed-on: http://git-master/r/504534
The delay value used in gr usleep_range calls is
too high. We can start at a much lower value.
Bug 200032452
Change-Id: I7d196d0e3be0a5cd84e8c4dad537fae043da6274
Signed-off-by: Prashant Malani <pmalani@nvidia.com>
Reviewed-on: http://git-master/r/335234
(cherry picked from commit 49bb8436a534496c70e6238d3bc20ed280d5b654)
Reviewed-on: http://git-master/r/504632
Reviewed-by: Rajkumar Kasirajan <rkasirajan@nvidia.com>
Provide sysedp_dynamic_capping with the instantaneous GPU frequency
when notifying it of the GPU load. Modify the gpu/cpu priority
decision logic to choose CPU priority until GPU frequency gets "near"
the CPU-priority-limited-GPU-fmax. Introduce the priority_bias debugfs
parameter to facilitate tuning of "near". priority_bias takes a value
from 0 to 100.
Change-Id: I57df17d50cd8077a512b5932f4a304ca5e6992aa
Signed-off-by: Matt Longnecker <mlongnecker@nvidia.com>
Reviewed-on: http://git-master/r/481720
(cherry picked from commit b2ac745a45e273e849d7b190913ee97092fdebc2)
Reviewed-on: http://git-master/r/498901
Bug 1497928
Change-Id: Ic3a2923ae73792e87145b6211e45e5ace3651ddc
Reviewed-on: http://git-master/r/482492
Tested-by: Prabhu Kuttiyam <pkuttiyam@nvidia.com>
Currently if pmu_mutex_acquire() fails, we disable ELPG
and move ahead. But it is not clear why it is required
to disable ELPG in case where we fail to acquire mutex.
Hence skip disabling ELPG if mutex_acquire() fails
Bug 1533644
Change-Id: I7e8e99a701d0ba071eb31ac17582b04072ee55eb
Reviewed-on: http://git-master/r/448131
(cherry picked from commit 789c256dd74e2b2b0481e25b2af1b2202ea6f582)
Reviewed-on: http://git-master/r/450268
Reviewed-by: Naveen Kumar S <nkumars@nvidia.com>
In pmu_mutex_acquire(), we return zero (success) if
pmu->initialized is not set
Since mutex_acquire() was successful, we then call
pmu_mutex_release()
If now pmu->initialized is set in some other thread
then we proceed to validate the mutex owner and
end up causing below warning :
pmu_mutex_release: requester 0x00000000 NOT match owner 0x00000008
Hence to fix this return error from mutex_acquire()
and mutex_release() if pmu->initialized is not yet set
and in that case we proceed to call elpg enable/disable
Bug 1533644
Bug 200017082
Change-Id: Ifbb9e6a8e13f6478a13e3f9d98ced11792cc881f
Reviewed-on: http://git-master/r/439333
(cherry picked from commit 50497d4031103df1067f14ce4c1e14b15713efb9)
Reviewed-on: http://git-master/r/440747
Channel and gpfifo allocations are entirely separated from each
other, however, the code here assumes that active channel means
that the channel also has a gpfifo.
This reverts commit a24602f094380539788696d1b1567a4f4d914b17 which
added gpfifo dump. Changing debug dumping to be safe requires
refactoring the channel release code to use proper locking.
Bug 200017498
Bug 1530226
Change-Id: I2fb02542a17dd56a0a9ce732b327e34b85ade8b9
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
(cherry picked from commit 3d37815d7660affeb9a4f23b0d17f870ed12dd33)
Reviewed-on: http://git-master/r/434053
Reviewed-by: Emad Mir <emir@nvidia.com>
Tested-by: Emad Mir <emir@nvidia.com>
