commit b3a72ca80351917cc23f9e24c35f3c3979d3c121 upstream.
Joe reports that using a statically allocated buffer for converting CPER
error records into human readable text is probably a bad idea. Even
though we are not aware of any actual issues, a stack buffer is clearly
a better choice here anyway, so let's move the buffer into the stack
frames of the two functions that refer to it.
Cc: <stable@vger.kernel.org>
Reported-by: Joe Perches <joe@perches.com>
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
[ Upstream commit 942859d969de7f6f7f2659a79237a758b42782da ]
snprintf() should be given the full buffer size, not one less. And it
guarantees nul-termination, so doing it manually afterwards is
pointless.
It's even potentially harmful (though probably not in practice because
CPER_REC_LEN is 256), due to the "return how much would have been
written had the buffer been big enough" semantics. I.e., if the bank
and/or device strings are long enough that the "DIMM location ..."
output gets truncated, writing to msg[n] is a buffer overflow.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Fixes: 3760cd20402d4 ("CPER: Adjust code flow of some functions")
[ Upstream commit 6fb9367a15d1a126d222d738b2702c7958594a5f ]
The CPER parser assumes that the class code is big endian, but at least
on this edk2-derived Intel Purley platform it's little endian:
efi: EFI v2.50 by EDK II BIOS ID:PLYDCRB1.86B.0119.R05.1701181843
DMI: Intel Corporation PURLEY/PURLEY, BIOS PLYDCRB1.86B.0119.R05.1701181843 01/18/2017
{1}[Hardware Error]: device_id: 0000:5d:00.0
{1}[Hardware Error]: slot: 0
{1}[Hardware Error]: secondary_bus: 0x5e
{1}[Hardware Error]: vendor_id: 0x8086, device_id: 0x2030
{1}[Hardware Error]: class_code: 000406
^^^^^^ (should be 060400)
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Ben Dooks <ben.dooks@codethink.co.uk>
Cc: Dave Young <dyoung@redhat.com>
Cc: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Cc: Jerry Snitselaar <jsnitsel@redhat.com>
Cc: Lyude Paul <lyude@redhat.com>
Cc: Matthew Garrett <mjg59@google.com>
Cc: Octavian Purdila <octavian.purdila@intel.com>
Cc: Peter Jones <pjones@redhat.com>
Cc: Scott Talbert <swt@techie.net>
Cc: linux-efi@vger.kernel.org
Cc: linux-integrity@vger.kernel.org
Link: https://lkml.kernel.org/r/20191002165904.8819-2-ard.biesheuvel@linaro.org
[ Upstream commit b194a77fcc4001dc40aecdd15d249648e8a436d1 ]
AER info of PCIe fatal error is not printed in the current driver.
Because APEI driver will panic directly for fatal error, and can't
run to the place of printing AER info.
An example log is as following:
{763}[Hardware Error]: Hardware error from APEI Generic Hardware Error Source: 11
{763}[Hardware Error]: event severity: fatal
{763}[Hardware Error]: Error 0, type: fatal
{763}[Hardware Error]: section_type: PCIe error
{763}[Hardware Error]: port_type: 0, PCIe end point
{763}[Hardware Error]: version: 4.0
{763}[Hardware Error]: command: 0x0000, status: 0x0010
{763}[Hardware Error]: device_id: 0000:82:00.0
{763}[Hardware Error]: slot: 0
{763}[Hardware Error]: secondary_bus: 0x00
{763}[Hardware Error]: vendor_id: 0x8086, device_id: 0x10fb
{763}[Hardware Error]: class_code: 000002
Kernel panic - not syncing: Fatal hardware error!
This issue was imported by the patch, '37448adfc7ce ("aerdrv: Move
cper_print_aer() call out of interrupt context")'. To fix this issue,
this patch adds print of AER info in cper_print_pcie() for fatal error.
Here is the example log after this patch applied:
{24}[Hardware Error]: Hardware error from APEI Generic Hardware Error Source: 10
{24}[Hardware Error]: event severity: fatal
{24}[Hardware Error]: Error 0, type: fatal
{24}[Hardware Error]: section_type: PCIe error
{24}[Hardware Error]: port_type: 0, PCIe end point
{24}[Hardware Error]: version: 4.0
{24}[Hardware Error]: command: 0x0546, status: 0x4010
{24}[Hardware Error]: device_id: 0000:01:00.0
{24}[Hardware Error]: slot: 0
{24}[Hardware Error]: secondary_bus: 0x00
{24}[Hardware Error]: vendor_id: 0x15b3, device_id: 0x1019
{24}[Hardware Error]: class_code: 000002
{24}[Hardware Error]: aer_uncor_status: 0x00040000, aer_uncor_mask: 0x00000000
{24}[Hardware Error]: aer_uncor_severity: 0x00062010
{24}[Hardware Error]: TLP Header: 000000c0 01010000 00000001 00000000
Fixes: 37448adfc7ce ("aerdrv: Move cper_print_aer() call out of interrupt context")
Signed-off-by: Xiaofei Tan <tanxiaofei@huawei.com>
Reviewed-by: James Morse <james.morse@arm.com>
[ardb: put parens around terms of && operator]
The memory error record structure includes as its first field a
bitmask of which subsequent fields are valid. The allows new fields
to be added to the structure while keeping compatibility with older
software that parses these records. This mechanism was used between
versions 2.2 and 2.3 to add four new fields, growing the size of the
structure from 73 bytes to 80. But Linux just added all the new
fields so this test:
if (gdata->error_data_length >= sizeof(*mem_err))
cper_print_mem(newpfx, mem_err);
else
goto err_section_too_small;
now make Linux complain about old format records being too short.
Add a definition for the old format of the structure and use that
for the minimum size check. Pass the actual size to cper_print_mem()
so it can sanity check the validation_bits field to ensure that if
a BIOS using the old format sets bits as if it were new, we won't
access fields beyond the end of the structure.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Use the helper function trace_seq_buffer_ptr() to get the current location
of the next buffer write of a trace_seq object, instead of open coding
it.
This facilitates the conversion of trace_seq to use seq_buf.
Tested-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Borislav Petkov <bp@suse.de>
Reviewed-by: Petr Mladek <pmladek@suse.cz>
Cc: Chen Gong <gong.chen@linux.intel.com>
Pull ACPI and power management updates from Rafael Wysocki:
"Again, ACPICA leads the pack (47 commits), followed by cpufreq (18
commits) and system suspend/hibernation (9 commits).
From the new code perspective, the ACPICA update brings ACPI 5.1 to
the table, including a new device configuration object called _DSD
(Device Specific Data) that will hopefully help us to operate device
properties like Device Trees do (at least to some extent) and changes
related to supporting ACPI on ARM.
Apart from that we have hibernation changes making it use radix trees
to store memory bitmaps which should speed up some operations carried
out by it quite significantly. We also have some power management
changes related to suspend-to-idle (the "freeze" sleep state) support
and more preliminary changes needed to support ACPI on ARM (outside of
ACPICA).
The rest is fixes and cleanups pretty much everywhere.
Specifics:
- ACPICA update to upstream version 20140724. That includes ACPI 5.1
material (support for the _CCA and _DSD predefined names, changes
related to the DMAR and PCCT tables and ARM support among other
things) and cleanups related to using ACPICA's header files. A
major part of it is related to acpidump and the core code used by
that utility. Changes from Bob Moore, David E Box, Lv Zheng,
Sascha Wildner, Tomasz Nowicki, Hanjun Guo.
- Radix trees for memory bitmaps used by the hibernation core from
Joerg Roedel.
- Support for waking up the system from suspend-to-idle (also known
as the "freeze" sleep state) using ACPI-based PCI wakeup signaling
(Rafael J Wysocki).
- Fixes for issues related to ACPI button events (Rafael J Wysocki).
- New device ID for an ACPI-enumerated device included into the
Wildcat Point PCH from Jie Yang.
- ACPI video updates related to backlight handling from Hans de Goede
and Linus Torvalds.
- Preliminary changes needed to support ACPI on ARM from Hanjun Guo
and Graeme Gregory.
- ACPI PNP core cleanups from Arjun Sreedharan and Zhang Rui.
- Cleanups related to ACPI_COMPANION() and ACPI_HANDLE() macros
(Rafael J Wysocki).
- ACPI-based device hotplug cleanups from Wei Yongjun and Rafael J
Wysocki.
- Cleanups and improvements related to system suspend from Lan
Tianyu, Randy Dunlap and Rafael J Wysocki.
- ACPI battery cleanup from Wei Yongjun.
- cpufreq core fixes from Viresh Kumar.
- Elimination of a deadband effect from the cpufreq ondemand governor
and intel_pstate driver cleanups from Stratos Karafotis.
- 350MHz CPU support for the powernow-k6 cpufreq driver from Mikulas
Patocka.
- Fix for the imx6 cpufreq driver from Anson Huang.
- cpuidle core and governor cleanups from Daniel Lezcano, Sandeep
Tripathy and Mohammad Merajul Islam Molla.
- Build fix for the big_little cpuidle driver from Sachin Kamat.
- Configuration fix for the Operation Performance Points (OPP)
framework from Mark Brown.
- APM cleanup from Jean Delvare.
- cpupower utility fixes and cleanups from Peter Senna Tschudin,
Andrey Utkin, Himangi Saraogi, Rickard Strandqvist, Thomas
Renninger"
* tag 'pm+acpi-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (118 commits)
ACPI / LPSS: add LPSS device for Wildcat Point PCH
ACPI / PNP: Replace faulty is_hex_digit() by isxdigit()
ACPICA: Update version to 20140724.
ACPICA: ACPI 5.1: Update for PCCT table changes.
ACPICA/ARM: ACPI 5.1: Update for GTDT table changes.
ACPICA/ARM: ACPI 5.1: Update for MADT changes.
ACPICA/ARM: ACPI 5.1: Update for FADT changes.
ACPICA: ACPI 5.1: Support for the _CCA predifined name.
ACPICA: ACPI 5.1: New notify value for System Affinity Update.
ACPICA: ACPI 5.1: Support for the _DSD predefined name.
ACPICA: Debug object: Add current value of Timer() to debug line prefix.
ACPICA: acpihelp: Add UUID support, restructure some existing files.
ACPICA: Utilities: Fix local printf issue.
ACPICA: Tables: Update for DMAR table changes.
ACPICA: Remove some extraneous printf arguments.
ACPICA: Update for comments/formatting. No functional changes.
ACPICA: Disassembler: Add support for the ToUUID opererator (macro).
ACPICA: Remove a redundant cast to acpi_size for ACPI_OFFSET() macro.
ACPICA: Work around an ancient GCC bug.
ACPI / processor: Make it possible to get local x2apic id via _MAT
Add trace interface to elaborate all H/W error related information.
Signed-off-by: Chen, Gong <gong.chen@linux.intel.com>
Some codes can be reorganzied as a common function for other usages.
Linux and ACPICA upstream.
The following commit has changed ACPICA table header definitions:
Commit: 88f074f4871a8c212b212b725e4dcdcdb09613c1
Subject: ACPI, CPER: Update cper info
While such definitions are currently maintained in ACPICA. As the
modifications applying to the table definitions affect other OSPMs'
drivers, it is very difficult for ACPICA to initiate a process to
complete the merge. Thus this commit finally only leaves us divergences.
Revert such naming modifications to reduce the source code differecnes
between Linux and ACPICA upstream. No functional changes.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Cc: Bob Moore <robert.moore@intel.com>
Cc: Chen, Gong <gong.chen@linux.intel.com>
cper.c contains code to decode and print "Common Platform Error Records".
Originally added under drivers/acpi/apei because the only user was in that
same directory - but now we have another consumer, and we shouldn't have
to force CONFIG_ACPI_APEI get access to this code.
Since CPER is defined in the UEFI specification - the logical home for
this code is under drivers/firmware/efi/
Acked-by: Matt Fleming <matt.fleming@intel.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
