path: root/drivers/firewire
2014-03-23firewire: don't use PREPARE_DELAYED_WORKTejun Heo
commit 70044d71d31d6973665ced5be04ef39ac1c09a48 upstream. PREPARE_[DELAYED_]WORK() are being phased out. They have few users and a nasty surprise in terms of reentrancy guarantee as workqueue considers work items to be different if they don't have the same work function. firewire core-device and sbp2 have been been multiplexing work items with multiple work functions. Introduce fw_device_workfn() and sbp2_lu_workfn() which invoke fw_device->workfn and sbp2_logical_unit->workfn respectively and always use the two functions as the work functions and update the users to set the ->workfn fields instead of overriding work functions using PREPARE_DELAYED_WORK(). This fixes a variety of possible regressions since a2c1c57be8d9 "workqueue: consider work function when searching for busy work items" due to which fw_workqueue lost its required non-reentrancy property. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: linux1394-devel@lists.sourceforge.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23firewire: net: fix use after freeStefan Richter
commit 8987583366ae9e03c306c2b7d73bdb952df1d08d upstream. Commit 8408dc1c14c1 "firewire: net: use dev_printk API" introduced a use-after-free in a failure path. fwnet_transmit_packet_failed(ptask) may free ptask, then the dev_err() call dereferenced it. The fix is straightforward; simply reorder the two calls. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09firewire: sbp2: bring back WRITE SAME supportStefan Richter
commit ce027ed98fd176710fb14be9d6015697b62436f0 upstream. Commit 54b2b50c20a6 "[SCSI] Disable WRITE SAME for RAID and virtual host adapter drivers" disabled WRITE SAME support for all SBP-2 attached targets. But as described in the changelog of commit b0ea5f19d3d8 "firewire: sbp2: allow WRITE SAME and REPORT SUPPORTED OPERATION CODES", it is not required to blacklist WRITE SAME. Bring the feature back by reverting the sbp2.c hunk of commit 54b2b50c20a6. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11SCSI: Disable WRITE SAME for RAID and virtual host adapter driversMartin K. Petersen
commit 54b2b50c20a61b51199bedb6e5d2f8ec2568fb43 upstream. Some host adapters do not pass commands through to the target disk directly. Instead they provide an emulated target which may or may not accurately report its capabilities. In some cases the physical device characteristics are reported even when the host adapter is processing commands on the device's behalf. This can lead to adapter firmware hangs or excessive I/O errors. This patch disables WRITE SAME for devices connected to host adapters that provide an emulated target. Driver writers can disable WRITE SAME by setting the no_write_same flag in the host adapter template. [jejb: fix up rejections due to eh_deadline patch] Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04firewire: fix libdc1394/FlyCap2 iso event regressionClemens Ladisch
commit 0699a73af3811b66b1ab5650575acee5eea841ab upstream. Commit 18d627113b83 (firewire: prevent dropping of completed iso packet header data) was intended to be an obvious bug fix, but libdc1394 and FlyCap2 depend on the old behaviour by ignoring all returned information and thus not noticing that not all packets have been received yet. The result was that the video frame buffers would be saved before they contained the correct data. Reintroduce the old behaviour for old clients. Tested-by: Stepan Salenikovich <stepan.salenikovich@gmail.com> Tested-by: Josep Bosch <jep250@gmail.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-09Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewure updates from Stefan Richter: - fix controller removal when controller is in suspended state - fix video reception on VIA VT6306 with gstreamer, MythTV, and maybe dv4l - fix a startup issue with Agere/LSI FW643-e2 - error logging improvements and other small updates * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: ohci: dump_stack() for PHY regs read/write failures firewire: ohci: Improve bus reset error messages firewire: ohci: Alias dev_* log functions firewire: ohci: Fix 'failed to read phy reg' on FW643 rev8 firewire: ohci: fix VIA VT6306 video reception firewire: ohci: Check LPS before register access on pci removal firewire: ohci: Fix double free_irq() firewire: remove unnecessary alloc/OOM messages firewire: sbp2: replace BUG_ON by WARN_ON firewire: core: remove an always false test firewire: Remove two unneeded checks for macros
2013-04-30firewire: ohci: dump_stack() for PHY regs read/write failuresPeter Hurley
A stack trace is an invaluable tool in determining the basis and cause of PHY regs read/write failures. Include PHY reg addr (and value for writes) in the diagnostic. [Stefan R: changed whitespace] Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-30firewire: ohci: Improve bus reset error messagesPeter Hurley
Many of the error messages possible from bus_reset_work() do not contain enough information to distinguish which error condition occurred nor enough information to evaluate the error afterwards. Differentiate all error conditions in bus_reset_work(); add additional information to make error diagnosis possible. [Stefan R: fixed self-ID endian conversion] Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-30firewire: ohci: Alias dev_* log functionsPeter Hurley
Convert dev_xxxx(ohci->card.device, ...) log functions to ohci_xxxx(ohci, ...). [Stefan R: Peter argues that this increases readability of the code.] [Stefan R: changed whitespace] Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-30firewire: ohci: Fix 'failed to read phy reg' on FW643 rev8Peter Hurley
With the LSI FW643 rev 8 [1], the first commanded bus reset at the conclusion of ohci_enable() has been observed to fail with the following messages: [ 4.884015] firewire_ohci 0000:01:00.0: failed to read phy reg .... [ 5.684012] firewire_ohci 0000:01:00.0: failed to read phy reg With drivers/firewire/ohci.c instrumented, the error condition [2] indicates the PHY arbitration state machine has timed out prior to enabling PHY LCtrl. Furthermore, instrumenting ohci_enable() shows that LPS has been enabled within 1 ms. Test LPS latching every 1 ms rather than every 50ms. [1] lspci -v 01:00.0 FireWire (IEEE 1394): LSI Corporation FW643 [TrueFire] PCIe 1394b Controller (rev 08) (prog-if 10 [OHCI]) Subsystem: LSI Corporation FW643 [TrueFire] PCIe 1394b Controller Flags: bus master, fast devsel, latency 0, IRQ 92 Memory at fbeff000 (64-bit, non-prefetchable) [size=4K] Capabilities: [44] Power Management version 3 Capabilities: [4c] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [140] Virtual Channel Capabilities: [170] Device Serial Number 08-14-43-82-00-00-41-fc Kernel driver in use: firewire_ohci Kernel modules: firewire-ohci [2] instrumented WARNING in read_phy_reg() [ 4.576010] ------------[ cut here ]------------ [ 4.576035] WARNING: at ./drivers/firewire/ohci.c:570 read_phy_reg+0x93/0xe0 [firewire_ohci]() [ 4.576050] Hardware name: Precision WorkStation T5400 [ 4.576058] failed to read phy reg:1 (phy(5) @ config enhance:19) [ 4.576068] Modules linked in: hid_logitech_dj hid_generic(+) usbhid <...snip...> [ 4.576140] Pid: 61, comm: kworker/2:1 Not tainted 3.8.0-2+fwtest-xeon #2+fwtest [ 4.576149] Call Trace: [ 4.576160] [<ffffffff8105468f>] warn_slowpath_common+0x7f/0xc0 [ 4.576168] [<ffffffff81054786>] warn_slowpath_fmt+0x46/0x50 [ 4.576178] [<ffffffffa00caca3>] read_phy_reg+0x93/0xe0 [firewire_ohci] [ 4.576188] [<ffffffffa00cae19>] ohci_read_phy_reg+0x39/0x60 [firewire_ohci] [ 4.576203] [<ffffffffa00731ff>] fw_send_phy_config+0xbf/0xe0 [firewire_core] [ 4.576214] [<ffffffffa006b2d6>] br_work+0x46/0xb0 [firewire_core] [ 4.576225] [<ffffffff81071e0c>] process_one_work+0x13c/0x500 [ 4.576238] [<ffffffffa006b290>] ? fw_card_initialize+0x180/0x180 [firewire_core] [ 4.576248] [<ffffffff810737ed>] worker_thread+0x16d/0x470 [ 4.576257] [<ffffffff81073680>] ? busy_worker_rebind_fn+0x100/0x100 [ 4.576266] [<ffffffff8107d160>] kthread+0xc0/0xd0 [ 4.576275] [<ffffffff816a0000>] ? pcpu_dump_alloc_info+0x1cb/0x2c4 [ 4.576284] [<ffffffff8107d0a0>] ? kthread_create_on_node+0x130/0x130 [ 4.576297] [<ffffffff816b2f6c>] ret_from_fork+0x7c/0xb0 [ 4.576305] [<ffffffff8107d0a0>] ? kthread_create_on_node+0x130/0x130 [ 4.576313] ---[ end trace cbc940994b300302 ]--- [Stefan R: Peter also reports a change of behavior with LSI FW323. Before the patch, there would often occur a lock transaction failure during firewire-core startup: [ 6.056022] firewire_core 0000:07:06.0: BM lock failed (timeout), making local node (ffc0) root This failure no longer happens after the patch, without an obvious reason for the failure or the fix.] [Stefan R: Added quirk flag, quirk table entry, and comment.] Reported-by: Tim Jordan <tim@insipid.org.uk> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: ohci: fix VIA VT6306 video receptionAndy Leiserson
Add quirk for VT6306 wake bit behavior. VT6306 seems to reread the wrong descriptor when the wake bit is written. work around by putting a copy of the branch address in the first descriptor of the block. [Stefan R: This fixes the known broken video reception via gstreamer on VIA VT6306. 100% repeatable testcase: $ gst-launch-0.10 dv1394src \! dvdemux \! dvdec \! xvimagesink with a camcorder or other DV source connected. Likewise for MPEG2-TS reception via gstreamer, e.g. from TV settop boxes. Perhaps this also fixes dv4l on VT6306, but this is as yet untested. Kino, dvgrab or FFADO had not been affected by this chip quirk. Additional comments from Andy:] I've looked into some problems with the wake bit on a vt6306 family chip (1106:3044, rev 46). I used this firewire card in a mythtv setup (ISO receive MPEG2 stream) with Debian 2.6.32 kernels for ~2 years without problems. Since upgrading to 3.2, I've been having problems with the input stream freezing -- input data stops until I restart mythtv (I expect closing and reopening the device would be sufficient). This happens infrequently, maybe one out of 20 recordings. I eventually determined that the problem is more likely to occur if the system is loaded. I isolated the kernel version as the triggering SW factor and then specifically the change from dualbuffer back to packet-per-buffer DMA mode. The possibility that the controller does not properly respond to the wake bit was suggested in https://bugzilla.redhat.com/show_bug.cgi?id=415841, but not proven. Based on the fact that dualbuffer mode worked while packet-per-buffer has trouble, I guessed that upon seeing the wake bit written, the vt6306 controller only checks the branch address in the first descriptor of the block, even if that is not the correct place to look (because the block has multiple descriptors). This theory seems to be correct. When the ISO reception is hung, I am able to resume it by manually writing the branch address to the first descriptor in the block, and then writing the wake bit. I've had luck so far with the attached patch, so I'm including it. It's probably not a complete solution -- I haven't tested transmit modes to see whether they have a similar issue. I doubt that the quirk test is any cheaper than just writing the extra branch address in all cases, but it does reduce the risk of breaking other hardware. [Stefan R: omitted QUIRK_NO_MSI from VT6306 quirks table entry, changed whitespace] Signed-off-by: Andy Leiserson <andy@leiserson.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: ohci: Check LPS before register access on pci removalPeter Hurley
A pci device can be removed while in its suspended state. If the ohci host controller is suspended, the PHY is also in low-power mode and LPS is disabled. If LPS is disabled, most of the host registers aren't accessible, including IntMaskClear. Furthermore, access to these registers when LPS is disabled can cause hard lockups on some hardware. Since interrupts are already disabled in this mode, further action is unnecessary. Test LPS before attempting to write IntMaskClear to disable interrupts. [Stefan R: whitespace changes] Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: ohci: Fix double free_irq()Peter Hurley
A pci device can be removed while in its suspended state. Because the ohci driver freed the irq to suspend, free_irq() is called twice; once from pci_remove() and again from pci_suspend(), which issues the warning below [1]. Rather than allocate the irq in the .enable() path, move the allocation to .probe(). Consequently, the irq is not reallocated upon pci_resume() and thus is not freed upon pci_suspend(). [1] Warning reported by Mark Einon <mark.einon@gmail.com> when suspending an MSI MS-1727 GT740 laptop on Ubuntu 3.5.0-22-generic WARNING: at ./kernel/irq/manage.c:1198 __free_irq+0xa3/0x1e0() Hardware name: MS-1727 Trying to free already-free IRQ 16 Modules linked in: ip6table_filter ip6_tables ebtable_nat ebtables <...snip...> Pid: 4, comm: kworker/0:0 Tainted: P O 3.5.0-22-generic #34-Ubuntu Call Trace: [<ffffffff81051c1f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff81051d16>] warn_slowpath_fmt+0x46/0x50 [<ffffffff8103fa39>] ? default_spin_lock_flags+0x9/0x10 [<ffffffff810df6b3>] __free_irq+0xa3/0x1e0 [<ffffffff810df844>] free_irq+0x54/0xc0 [<ffffffffa005a27e>] pci_remove+0x6e/0x210 [firewire_ohci] [<ffffffff8135ae7f>] pci_device_remove+0x3f/0x110 [<ffffffff8141fdbc>] __device_release_driver+0x7c/0xe0 [<ffffffff8141fe4c>] device_release_driver+0x2c/0x40 [<ffffffff8141f5f1>] bus_remove_device+0xe1/0x120 [<ffffffff8141cd1a>] device_del+0x12a/0x1c0 [<ffffffff8141cdc6>] device_unregister+0x16/0x30 [<ffffffff81354784>] pci_stop_bus_device+0x94/0xa0 [<ffffffffa0091c67>] acpiphp_disable_slot+0xb7/0x1a0 [acpiphp] [<ffffffffa0090716>] ? get_slot_status+0x46/0xc0 [acpiphp] [<ffffffffa0091d7d>] acpiphp_check_bridge.isra.15+0x2d/0xf0 [acpiphp] [<ffffffffa0092442>] _handle_hotplug_event_bridge+0x372/0x4d0 [acpiphp] [<ffffffff81390f8c>] ? acpi_os_execute_deferred+0x2f/0x34 [<ffffffff8116e22d>] ? kfree+0xed/0x110 [<ffffffff8107086a>] process_one_work+0x12a/0x420 [<ffffffffa00920d0>] ? _handle_hotplug_event_func+0x1d0/0x1d0 [acpiphp] [<ffffffff8107141e>] worker_thread+0x12e/0x2f0 [<ffffffff810712f0>] ? manage_workers.isra.26+0x200/0x200 [<ffffffff81075f13>] kthread+0x93/0xa0 [<ffffffff8168d024>] kernel_thread_helper+0x4/0x10 [<ffffffff81075e80>] ? kthread_freezable_should_stop+0x70/0x70 [<ffffffff8168d020>] ? gs_change+0x13/0x13 Reported-by: Mark Einon <mark.einon@gmail.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: remove unnecessary alloc/OOM messagesStefan Richter
These are redundant to log messages from the mm core. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: sbp2: replace BUG_ON by WARN_ONStefan Richter
No need to crash and burn if S/G element sizes cannot be set to our liking; just leave a message in the log. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: core: remove an always false testStefan Richter
struct fw_cdev_allocate_iso_resource.bandwidth is unsigned. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: Remove two unneeded checks for macrosPaul Bolle
The old IEEE 1394 driver stack was removed in v2.6.37. That made the checks for two Kconfig (module) macros unneeded, since they will now always evaluate to true. Remove these two checks. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-03-28net: add ETH_P_802_3_MINSimon Horman
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for an 802.3 frame. Frames with a lower value in the ethernet type field are Ethernet II. Also update all the users of this value that David Miller and I could find to use the new constant. Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN should be >= not >. As suggested by Jesse Gross. Compile tested only. Cc: David Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: John W. Linville <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Bart De Schuymer <bart.de.schuymer@pandora.be> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: linux-bluetooth@vger.kernel.org Cc: netfilter-devel@vger.kernel.org Cc: bridge@lists.linux-foundation.org Cc: linux-wireless@vger.kernel.org Cc: linux1394-devel@lists.sourceforge.net Cc: linux-media@vger.kernel.org Cc: netdev@vger.kernel.org Cc: dev@openvswitch.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net, ipv6: IPv6 over Firewire (RFC3146) support.YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net, ipv4 arp: Extend hardware address and remove driver-level ↵YOSHIFUJI Hideaki / 吉藤英明
packet inspection. Inspection of upper layer protocol is considered harmful, especially if it is about ARP or other stateful upper layer protocol; driver cannot (and should not) have full state of them. IPv4 over Firewire module used to inspect ARP (both in sending path and in receiving path), and record peer's GUID, max packet size, max speed and fifo address. This patch removes such inspection by extending our "hardware address" definition to include other information as well: max packet size, max speed and fifo. By doing this, The neighbour module in networking subsystem can cache them. Note: As we have started ignoring sspd and max_rec in ARP/NDP, those information will not be used in the driver when sending. When a packet is being sent, the IP layer fills our pseudo header with the extended "hardware address", including GUID and fifo. The driver can look-up node-id (the real but rather volatile low-level address) by GUID, and then the module can send the packet to the wire using parameters provided in the extendedn hardware address. This approach is realistic because IP over IEEE1394 (RFC2734) and IPv6 over IEEE1394 (RFC3146) share same "hardware address" format in their address resolution protocols. Here, extended "hardware address" is defined as follows: union fwnet_hwaddr { u8 u[16]; struct { __be64 uniq_id; /* EUI-64 */ u8 max_rec; /* max packet size */ u8 sspd; /* max speed */ __be16 fifo_hi; /* hi 16bits of FIFO addr */ __be32 fifo_lo; /* lo 32bits of FIFO addr */ } __packed uc; }; Note that Hardware address is declared as union, so that we can map full IP address into this, when implementing MCAP (Multicast Cannel Allocation Protocol) for IPv6, but IP and ARP subsystem do not need to know this format in detail. One difference between original ARP (RFC826) and 1394 ARP (RFC2734) is that 1394 ARP Request/Reply do not contain the target hardware address field (aka ar$tha). This difference is handled in the ARP subsystem. CC: Stephan Gatzka <stephan.gatzka@gmail.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net: Ignore spd and max_payload advertised by ARP.YOSHIFUJI Hideaki / 吉藤英明
Stefan Richter <stefanr@s5r6.in-berlin.de> says: | As far as I can tell, it would be best to ignore max_rec and sspd from ARP | and NDP but keep using the respective information from firewire-core | instead (handed over by fwnet_probe()). | | Why? As I noted earlier, RFC 2734:1999 and RFC 3146:2001 were apparently | written with a too simplistic notion of IEEE 1394 bus topology, resulting | in max_rec and sspd in ARP-1394 and NDP-1394 to be useless, IMO. | | Consider a bus like this: | | A ---- B ==== C | | A, B, C are all IP-over-1394 capable nodes. ---- is an S400 cable hop, | and ==== is an S800 cable hop. | | In case of unicasts or multicasts in which node A is involved as | transmitter or receiver, as well as in case of broadcasts, the speeds | S100, S200, S400 work and speed S400 is optimal. | | In case of anything else, IOW in case of unicasts or multicasts in which | only nodes B and C are involved, the speeds S100, S200, S400, S800 work | and speed S800 is optimal. | | Clearly, node A should indicate sspd = S400 in its ARP or NDP packets. | But which sspd should nodes B and C set there? Maybe they set S400, which | would work but would waste half of the available bandwidth in the second | case. Or maybe they set S800, which is OK in the second case but would | prohibit any communication with node A if blindly taken for correct. | | On the other hand, firewire-core *always* gives us the correct and optimum | peer-to-peer speed and asynchronous packet payload, no matter how simple | or complex the bus topology is and no matter in which temporal order nodes | join the bus and are discovered. CC: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net: Allocate address handler before registering net_device.YOSHIFUJI Hideaki / 吉藤英明
Allocate FIFO address before registering net_device. This is preparation to change the pseudo hardware address format for firewire devices to include the offset of the FIFO for receipt of unicast datagrams, instead of mangling ARP/NDP messages in the driver layer. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net: Send L2 multicast via GASP.YOSHIFUJI Hideaki / 吉藤英明
Send L2 multicast packet via GASP (Global asynchronous stream packet) by seeing the multicast bit in the L2 hardware address, not by seeing upper- layer protocol address. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net: Accept IPv4 and ARP only.YOSHIFUJI Hideaki / 吉藤英明
2013-03-13firewire net: Release broadcast/fifo resources on ifdown.YOSHIFUJI Hideaki
Since those resources are allocated on ifup, relsase them on ifdown. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-03-13firewire net: Introduce fwnet_broadcast_stop() to destroy broadcast resources.YOSHIFUJI Hideaki
2013-03-13firewire net: Allocate dev->broadcast_rcv_buffer_ptrs early.YOSHIFUJI Hideaki
2013-03-13firewire net: Fix leakage of kmap for broadcast receive buffer.YOSHIFUJI Hideaki
2013-03-13firewire net: Omit checking dev->broadcast_rcv_context in ↵YOSHIFUJI Hideaki
fwnet_broadcast_start(). dev->broadcast_rcv_context is always non-NULL if dev->broadcast_state is not FWNET_BROADCAST_ERROR. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-03-13firewire net: Clear dev->broadcast_rcv_context and dev->broadcast_state ↵YOSHIFUJI Hideaki
after destruction of context. Clear dev->broadcast_rcv_context to NULL and set dev->broadcast_state to FWNET_BROADCAST_ERROR after descruction of broadcast context. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-03-13firewire net: Fix memory leakage in fwnet_remove().YOSHIFUJI Hideaki
2013-03-13firewire net: Check dev->broadcast_state inside fwnet_broadcast_start().YOSHIFUJI Hideaki
2013-03-13firewire net: Setup broadcast and local fifo independently.YOSHIFUJI Hideaki
2013-03-13firewire net: Introduce fwnet_fifo_{start, stop}() helpers.YOSHIFUJI Hideaki
2013-03-13firewire net: No need to reset dev->local_fifo after failure of ↵YOSHIFUJI Hideaki
fw_core_add_address_handler(). fwnet_broadcast_start() try to register address handler at first if it was not registered yet; dev->local_fifo == FWNET_NO_FIFO_ADDR. Since dev->local_info not changed if fw_core_add_address_hander() has failed, we do not need to set dev->local_info to FWNET_NO_FIFO_ADDR. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-02-27firewire: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. v2: Stefan pointed out that add_client_resource() may be called from non-process context. Preload iff @gfp_mask contains __GFP_WAIT. Also updated to include minor upper limit check. [tim.gardner@canonical.com: fix accidentally orphaned 'minor'[ Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27firewire: add minor number range check to fw_device_init()Tejun Heo
fw_device_init() didn't check whether the allocated minor number isn't too large. Fail if it goes overflows MINORBITS. Signed-off-by: Tejun Heo <tj@kernel.org> Suggested-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27firewire: don't use idr_remove_all()Tejun Heo
idr_destroy() can destroy idr by itself and idr_remove_all() is being deprecated. Drop its usage. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-20firewire net: Use LL_RESERVED_SPACE(), HH_DATA_OFF().YOSHIFUJI Hideaki / 吉藤英明
2013-01-20firewire net: Ensure checksumming in upper layer.YOSHIFUJI Hideaki / 吉藤英明
It is wrong to set skb->ip_summed to CHECKSUM_UNNECESSARY unless the device has already checked it. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-09treewide: Fix typo in various driversMasanari Iida
Correct spelling typo in printk within various drivers. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-13Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull IEEE 1394 (FireWire) subsystem updates from Stefan Richter: - IPv4-over-1394: fixes for broadcast and multicast - SBP-2: allow thin-provisioning related commands - trivia * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: net: remove unused variable in fwnet_receive_broadcast() firewire: net: Fix handling of fragmented multicast/broadcast packets. firewire: sbp2: allow WRITE SAME and REPORT SUPPORTED OPERATION CODES tools/firewire: nosy-dump: check for allocation failure
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-12-03firewire: net: remove unused variable in fwnet_receive_broadcast()Wei Yongjun
The variable card is initialized but never used otherwise, so remove the unused variable. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2012-12-02firewire: net: Fix handling of fragmented multicast/broadcast packets.Stephan Gatzka
This patch fixes both the transmit and receive portion of sending fragmented mutlicast and broadcast packets. The transmit section was broken because the offset for INTFRAG and LASTFRAG packets were just miscalculated by IEEE1394_GASP_HDR_SIZE (which was reserved with skb_push() in fwnet_send_packet). The receive section was broken because in fwnet_incoming_packet is a call to fwnet_peer_find_by_node_id(). Called with generation == -1 it will not find a peer and the partial datagrams are associated to a peer. [Stefan R: The fix to use context->card->generation is not perfect. It relies on the IR tasklet which processes packets from the prior bus generation to run before the self-ID-complete worklet which sets the current card generation. Alas, there is no simple way of a race-free implementation. Let's do it this way for now.] Signed-off-by: Stephan Gatzka <stephan.gatzka@gmail.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2012-12-02firewire: sbp2: allow WRITE SAME and REPORT SUPPORTED OPERATION CODESStefan Richter
The commits 3c6bdaeab4fd "[SCSI] Add a report opcode helper" 5db44863b6eb "[SCSI] sd: Implement support for WRITE SAME" introduced in-kernel uses of the mentioned commands but cautiously blacklisted them for any IEEE 1394 (SBP-2/3) targets and some other transports. I looked through a range of SBP devices and found that the blacklist flags can be removed: The kernel never attempts these commands if the device's INQUIRY data claim a SCSI revision of less than 0x05. This is the case with all SBP devices that I checked, except for three more recent devices which claimed a revision of 0x05 i.e. conformance with SPC-3 (two devices based on the OXUF936QSE chip but having different firmwares, one based on OXUF934DSB.) I tried "sg_opcodes" from sg3_utils on several older and newer devices and did not encounter any apparent firmware bugs with it. All devices returned Illegal Request/ Invalid command operation code and carried on. I furthermore tried "sg_write_same -U" on the OXUF934DSB device with the same result. Alas I did not have a TRIM enabled SSD available for these tests. All of the bridges were correctly identified by the kernel as "fully provisioned", CD-ROM devices aside. The kernel won't issue WRITE SAME to fully provisioned devices, nor would it attempt REPORT SUPPORTED OPERATION CODES or WRITE SAME with UNMAP bit on devices which do not claim conformance to SPC-3 or later. Hence let's remove the no_report_opcodes and no_write_same blacklist flags so that these commands can be used on newer targets with respective capabilities. I guess the Linux sbp-target could be such a target. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2012-11-28firewire: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
