path: root/drivers/clocksource
2014-06-30drivers: clocksource: add CPU PM notifier for ARM architected timerSudeep KarkadaNagesha
Few control settings done in architected timer as part of initialisation can be lost when CPU enters deeper power states. They need to be restored when the CPU is (warm)reset again. This patch adds CPU PM notifiers to save the counter control register when entering low power modes and restore it when CPU exits low power. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Reviewed-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com> Change-Id: I0bad683961e4b72835ad40edf2c9ac9e0f78fad0 Reviewed-on: http://git-master/r/350844 Reviewed-by: Bo Yan <byan@nvidia.com> Tested-by: Bo Yan <byan@nvidia.com> Reviewed-on: http://git-master/r/427526 Tested-by: Andrey Trachenko <atrachenko@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2014-04-30clocksource: arch_timer: Push the read/write wrappers deeperStephen Boyd
We're going to introduce support to read and write the memory mapped timer registers in the next patch, so push the cp15 read/write functions one level deeper. This simplifies the next patch and makes it clearer what's going on. (cherry picked from commit 60faddf6eb3aba16068032bdcf35e18ace4bfb21) Change-Id: I8b7a55ba7d9919fc0ec512f64fe1ed7ac9dd227d Cc: Mark Rutland <mark.rutland@arm.com> Cc: Marc Zyngier <Marc.Zyngier@arm.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Mark Rutland <mark.rutland@arm.com>
2014-04-30clocksource: arch_timer: Make register accessors less error-proneStephen Boyd
Using an enum for the register we wish to access allows newer compilers to determine if we've forgotten a case in our switch statement. This allows us to remove the BUILD_BUG() instances in the arm64 port, avoiding problems where optimizations may not happen. To try and force better code generation we're currently marking the accessor functions as inline, but newer compilers can ignore the inline keyword unless it's marked __always_inline. Luckily on arm and arm64 inline is __always_inline, but let's make everything __always_inline to be explicit. (cherry picked from commit e09f3cc0184d6b5c3816f921b7ffb67623e5e834) Change-Id: I8e8e8bcd3d1c05001553ebfebc7dfd8a561c40e4 Suggested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Marc Zyngier <Marc.Zyngier@arm.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Mark Rutland <mark.rutland@arm.com>
2014-03-14clocksource: tegra: remove CONFIG_TEGRA_USE_SECURE_KERNELVarun Wadekar
Instead, use tegra_cpu_is_secure() to find out if we have a secure firmware on the device. Bug 1475528 Change-Id: I60d168e3302dbfeb79932af0f6eac83bda7b2baa Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/377617
2014-03-13Merge branch 'linux-3.10.33' into dev-kernel-3.10Deepak Nibade
Bug 1456092 Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
2014-02-25ARM: tegra: move timerinfo to drivers/misc/Sumit Singh
Bug 1380001 Change-Id: I0cb9a887ad85b67ba14626e3ab5543525cf26a00 Signed-off-by: Sumit Singh <sumsingh@nvidia.com> Reviewed-on: http://git-master/r/354930 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com> Reviewed-by: Sachin Nikam <snikam@nvidia.com>
2014-02-09Revert "ARM: tegra: trustzone: Single kernel to work in both secure and ↵Varun Wadekar
non-secure mode." This reverts commit 7f93a0dddf39f372c064f772f9af6903e91aaacf as the t132ref builds break with the following errors - <android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:45: undefined reference to `is_secure_mode' <android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:57: undefined reference to `is_secure_mode' <android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:58: undefined reference to `tegra_generic_smc' Change-Id: I4e44c2ffba4e1c013213e543b67f2d49a928b764 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/365347
2014-02-09ARM: tegra: trustzone: Single kernel to work in both secure and non-secure mode.Nitin Sehgal
- Remove CONFIG_TEGRA_USE_SECURE_KERNEL config option - Use DBGDSCR.NS bit to dynamically get secure/non-secure mode - Replace ifdefs with dynamic code. - Keep CONFIG_TRUSTED_LITTLE_KERNEL to enable secure os bug 1411345 Change-Id: I75ddfed7a35fcb30e2772bb43057ae022bcf09b3 Signed-off-by: Nitin Sehgal <nsehgal@nvidia.com> Reviewed-on: http://git-master/r/353155 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2014-01-21drivers: clocksource: fix Tegra timers for ARM64Peng Du
Change-Id: Ie719ad8337d22e23377ce5f283af755802f60de4 Signed-off-by: Peng Du <pdu@nvidia.com>
2014-01-21FIXUP: ARM: tegra: fix arch header includes for ARM64Alex Van Brunt
Change-Id: I0326b9e22688f236ee961b6c8e6670e322be4d7c
2014-01-15clocksource: em_sti: Set cpu_possible_mask to fix SMP broadcastMagnus Damm
commit 2199a5574b6d94b9ca26c6345356f45ec60fef8b upstream. Update the STI driver by setting cpu_possible_mask to make EMEV2 SMP work as expected together with the ARM broadcast timer. This breakage was introduced by: f7db706 ARM: 7674/1: smp: Avoid dummy clockevent being preferred over real hardware clock-event Without this fix SMP operation is broken on EMEV2 since no broadcast timer interrupts trigger on the secondary CPU cores. Signed-off-by: Magnus Damm <damm@opensource.se> Tested-by: Simon Horman <horms+renesas@verge.net.au> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-13arch_timer: Move to generic sched_clock frameworkStephen Boyd
Register with the generic sched_clock framework now that it supports 64 bits. This fixes two problems with the current sched_clock support for machines using the architected timers. First off, we don't subtract the start value from subsequent sched_clock calls so we can potentially start off with sched_clock returning gigantic numbers. Second, there is no support for suspend/resume handling so problems such as discussed in 6a4dae5 (ARM: 7565/1: sched: stop sched_clock() during suspend, 2012-10-23) can happen without this patch. Finally, it allows us to move the sched_clock setup into drivers clocksource out of the arch ports. Bug 1399318 Cc: Christopher Covington <cov@codeaurora.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: John Stultz <john.stultz@linaro.org> (cherry picked from commit 65cd4f6c99c1170bd0114dbd71b978012ea44d28) Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com> Change-Id: I77dde73ba0c325c67275e72220419fd47faf4206
2014-01-13sched_clock: Make ARM's sched_clock generic for all architecturesStephen Boyd
Nothing about the sched_clock implementation in the ARM port is specific to the architecture. Generalize the code so that other architectures can use it by selecting GENERIC_SCHED_CLOCK. Bug 1399318 Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> [jstultz: Merge minor collisions with other patches in my tree] Signed-off-by: John Stultz <john.stultz@linaro.org> (cherry picked from commit 38ff87f77af0b5a93fc8581cff1d6e5692ab8970) Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com> Change-Id: Iaac325635344ef4adee8fa0f9ca11aee089bce0f
2014-01-09clocksource: arch_timer: use virtual countersMark Rutland
commit 0d651e4e65e96989f72236bf83bd4c6e55eb6ce4 upstream. Switching between reading the virtual or physical counters is problematic, as some core code wants a view of time before we're fully set up. Using a function pointer and switching the source after the first read can make time appear to go backwards, and having a check in the read function is an unfortunate block on what we want to be a fast path. Instead, this patch makes us always use the virtual counters. If we're a guest, or don't have hyp mode, we'll use the virtual timers, and as such don't care about CNTVOFF as long as it doesn't change in such a way as to make time appear to travel backwards. As the guest will use the virtual timers, a (potential) KVM host must use the physical timers (which can wake up the host even if they fire while a guest is executing), and hence a host must have CNTVOFF set to zero so as to have a consistent view of time between the physical timers and virtual counters. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09clocksource: dw_apb_timer_of: Fix read_sched_clockDinh Nguyen
commit 85dc6ee1237c8a4a7742e6abab96a20389b7d682 upstream. The read_sched_clock should return the ~value because the clock is a countdown implementation. read_sched_clock() should be the same as __apbt_read_clocksource(). Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04arm: tegra: add rtc timer to wake from lp0Prashant Gaikwad
When device is in LP0 all timers are off except RTC. Use this timer when we enter LP0 from cpuidle. Bug 1254633 Change-Id: I6887aae221b27be095ea213bac70a110081d3d64 Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Reviewed-on: http://git-master/r/303230 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-10-17clocksource: tegra: Disable for wakeup timers for non-smp platformsAjay Nandakumar
Disabling wakeup timers for non-smp platforms Change-Id: Ie309a9157440795c82cfb525316d24036ee57191 Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com> Reviewed-on: http://git-master/r/300614 Reviewed-by: Matt Craighead <mcraighead@nvidia.com> Tested-by: Matt Craighead <mcraighead@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-10-17Revert "Revert "clocksource: tegra: use the device_node pointer passed to init""Ajay Nandakumar
This reverts commit 0e653907ac1d0be9172419c884b820c11864b567. We've already matched the node, so use the node pointer passed in. The rtc init was intermingled with the timer init, so split this out to a separate init function. Bug 1379817 Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com> Change-Id: I239269bacad3c7e7f0c3fdc63e4d018d53b542a4 Reviewed-on: http://git-master/r/299023 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-10-17Revert "Revert "clocksource: pass DT node pointer to init functions""Ajay Nandakumar
This reverts commit 06139bf5f233c03ce1aad929e0adf75fc5fb5898. In cases where we have multiple nodes of the same type, we may need the node pointer to know which node was matched. Passing the node pointer also keeps the init function from having to match the node a 2nd time. Update bcm2835, vt8500, and tegra20 init functions for the new function prototype. Further tegra20 clean-ups are in follow-up commit. Bug 1379817 Change-Id: Icb37a7bbe4e8f673ce1bcd4ecc92de52d12195eb Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com> Reviewed-on: http://git-master/r/299022 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-10-17ARM: tegra: move tsc timers to drivers/clocksourceAjay Nandakumar
Moving tegra tsc timer to drivers/clocksource Bug 1379817 Change-Id: Ifa1b1b1638960c390f3fca4ba2261a5692cc8f61 Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com> Reviewed-on: http://git-master/r/299021 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-10-17ARM: tegra: move nv timers to drivers/clocksource/Ajay Nandakumar
Moving nvidia timers to drivers/clocksource/ Bug 1379817 Change-Id: I1412fa18d0fbc7f1106d98934f3faf7975dea7cb Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com> Reviewed-on: http://git-master/r/299020 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-09-14Partial Revert "Revert "clocksource: pass DT node pointer to init functions""Dan Willemsen
This reverts commit 58f23560b5f0bfe4801c76a7f6b0908d87edfc2c. Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
2013-09-13Revert "ARM: tegra: move timer.c to drivers/clocksource/"Dan Willemsen
This reverts commit 1711b1e10224dbebc885b7bf7ca2f03f51ff9f4a. Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
2013-08-30Revert "clocksource: pass DT node pointer to init functions"Dan Willemsen
This reverts commit effbfdd7baf7babc73154b87a5ff940969cf6559. Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
2013-08-30Revert "clocksource: tegra20: use the device_node pointer passed to init"Dan Willemsen
This reverts commit 1d16cfb3aeba71bc6ecf2d19ccbabed0426e5c22. Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
2013-08-30Revert "ARM: smp_twd: convert to use CLKSRC_OF init"Dan Willemsen
This reverts commit da4a686a2cfb077a8bfc1697f597e7f86235b822. Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
2013-08-30Revert "clocksource: tegra: move to of_clk_get"Dan Willemsen
This reverts commit 6f88fb8af6c67f281b8e2cd607f08e0089c8ccbe. Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
2013-07-25clocksource: dw_apb: Fix error checkBaruch Siach
commit 1a33bd2be705cbb3f57d7223b60baea441039307 upstream. irq_of_parse_and_map() returns 0 on error, while the code checks for NO_IRQ. This breaks on platforms that have NO_IRQ != 0. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07Merge tag 'multiplatform-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull late ARM Exynos multiplatform changes from Arnd Bergmann: "These continue the multiplatform support for exynos, adding support for building most of the essential drivers (clocksource, clk, irqchip) when combined with other platforms. As a result, it should become really easy to add full multiplatform exynos support in 3.11, although we don't yet enable it for 3.10. The changes were not included in the earlier multiplatform series in order to avoid clashes with the other Exynos updates. This also includes work from Tomasz Figa to fix the pwm clocksource code on Exynos, which is not strictly required for multiplatform, but related to the other patches in this set and needed as a bug fix for at least one board." * tag 'multiplatform-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (22 commits) ARM: dts: exynops4210: really add universal_c210 dts ARM: dts: exynos4210: Add basic dts file for universal_c210 board ARM: dts: exynos4: Add node for PWM device ARM: SAMSUNG: Do not register legacy timer interrupts on Exynos clocksource: samsung_pwm_timer: Work around rounding errors in clockevents core clocksource: samsung_pwm_timer: Correct programming of clock events clocksource: samsung_pwm_timer: Use proper clockevents max_delta clocksource: samsung_pwm_timer: Add support for non-DT platforms clocksource: samsung_pwm_timer: Drop unused samsung_pwm struct clocksource: samsung_pwm_timer: Keep all driver data in a structure clocksource: samsung_pwm_timer: Make PWM spinlock global clocksource: samsung_pwm_timer: Let platforms select the driver Documentation: Add device tree bindings for Samsung PWM timers clocksource: add samsung pwm timer driver irqchip: exynos: look up irq using irq_find_mapping irqchip: exynos: pass irq_base from platform irqchip: exynos: localize irq lookup for ATAGS irqchip: exynos: allocate combiner_data dynamically irqchip: exynos: pass max combiner number to combiner_init ARM: exynos: add missing properties for combiner IRQs ...
2013-05-07Merge tag 'cleanup-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late cleanups from Arnd Bergmann: "These are cleanups and smaller changes that either depend on earlier feature branches or came in late during the development cycle. We normally try to get all cleanups early, so these are the exceptions: - A follow-up on the clocksource reworks, hopefully the last time we need to merge clocksource subsystem changes through arm-soc. A first set of patches was part of the original 3.10 arm-soc cleanup series because of interdependencies with timer drivers now moved out of arch/arm. - Migrating the SPEAr13xx platform away from using auxdata for DMA channel descriptions towards using information in device tree, based on the earlier SPEAr multiplatform series - A few follow-ups on the Atmel SAMA5 support and other changes for Atmel at91 based on the larger at91 reworks. - Moving the armada irqchip implementation to drivers/irqchip - Several OMAP cleanups following up on the larger series already merged in 3.10." * tag 'cleanup-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits) ARM: OMAP4: change the device names in usb_bind_phy ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686a ARM: SPEAr: conditionalize SMP code ARM: arch_timer: Silence debug preempt warnings ARM: OMAP: remove unused variable serial: amba-pl011: fix !CONFIG_DMA_ENGINE case ata: arasan: remove the need for platform_data ARM: at91/sama5d34ek.dts: remove not needed compatibility string ARM: at91: dts: add MCI DMA support ARM: at91: dts: add i2c dma support ARM: at91: dts: set #dma-cells to the correct value ARM: at91: suspend both memory controllers on at91sam9263 irqchip: armada-370-xp: slightly cleanup irq controller driver irqchip: armada-370-xp: move IRQ handler to avoid forward declaration irqchip: move IRQ driver for Armada 370/XP ARM: mvebu: move L2 cache initialization in init_early() devtree: add binding documentation for sp804 ARM: integrator-cp: convert use CLKSRC_OF for timer init ARM: versatile: use OF init for sp804 timer ARM: versatile: add versatile dtbs to dtbs target ...
2013-05-06Merge branch 'exynos/pwm-clocksource' into late/multiplatformArnd Bergmann
This series from Tomasz Figa restores support for the pwm clocksource in Exynos, which was broken during the conversion of the platform to the common clk framework. The clocksource is only used in one board in the mainline kernel (universal_c210), and this makes it work for DT based probing as well as restoring the non-DT based case. * exynos/pwm-clocksource: ARM: dts: exynops4210: really add universal_c210 dts ARM: dts: exynos4210: Add basic dts file for universal_c210 board ARM: dts: exynos4: Add node for PWM device ARM: SAMSUNG: Do not register legacy timer interrupts on Exynos clocksource: samsung_pwm_timer: Work around rounding errors in clockevents core clocksource: samsung_pwm_timer: Correct programming of clock events clocksource: samsung_pwm_timer: Use proper clockevents max_delta clocksource: samsung_pwm_timer: Add support for non-DT platforms clocksource: samsung_pwm_timer: Drop unused samsung_pwm struct clocksource: samsung_pwm_timer: Keep all driver data in a structure clocksource: samsung_pwm_timer: Make PWM spinlock global clocksource: samsung_pwm_timer: Let platforms select the driver Documentation: Add device tree bindings for Samsung PWM timers clocksource: add samsung pwm timer driver Conflicts: arch/arm/boot/dts/Makefile arch/arm/mach-exynos/common.c drivers/clocksource/Kconfig drivers/clocksource/Makefile Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-05-04Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Olof Johansson: "This is a rather large set of patches for device drivers that for one reason or another the subsystem maintainer preferred to get merged through the arm-soc tree. There are both new drivers as well as existing drivers that are getting converted from platform-specific code into standalone drivers using the appropriate subsystem specific interfaces. In particular, we can now have pinctrl, clk, clksource and irqchip drivers in one file per driver, without the need to call into platform specific interface, or to get called from platform specific code, as long as all information about the hardware is provided through a device tree. Most of the drivers we touch this time are for clocksource. Since now most of them are part of drivers/clocksource, I expect that we won't have to touch these again from arm-soc and can let the clocksource maintainers take care of these in the future. Another larger part of this series is specific to the exynos platform, which is seeing some significant effort in upstreaming and modernization of its device drivers this time around, which unfortunately is also the cause for the churn and a lot of the merge conflicts. There is one new subsystem that gets merged as part of this series: the reset controller interface, which is a very simple interface for taking devices on the SoC out of reset or back into reset. Patches to use this interface on i.MX follow later in this merge window, and we are going to have other platforms (at least tegra and sirf) get converted in 3.11. This will let us get rid of platform specific callbacks in a number of platform independent device drivers." * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits) irqchip: s3c24xx: add missing __init annotations ARM: dts: Disable the RTC by default on exynos5 clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3} ARM: exynos: restore mach/regs-clock.h for exynos5 clocksource: exynos_mct: fix build error on non-DT pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register() irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure reset: NULL deref on allocation failure reset: Add reset controller API dt: describe base reset signal binding ARM: EXYNOS: Add arm-pmu DT binding for exynos421x ARM: EXYNOS: Add arm-pmu DT binding for exynos5250 ARM: EXYNOS: Enable PMUs for exynos4 irqchip: exynos-combiner: Correct combined IRQs for exynos4 irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq ARM: EXYNOS: fix compilation error introduced due to common clock migration clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3} clk: exynos4: export clocks required for fimc-is clk: samsung: Fix compilation error clk: tegra: fix enum tegra114_clk to match binding ...
2013-05-02Merge tag 'multiplatform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform updates from Olof Johansson: "More multiplatform enablement for ARM platforms. The ones converted in this branch are: - bcm2835 - cns3xxx - sirf - nomadik - msx - spear - tegra - ux500 We're getting close to having most of them converted! One of the larger platforms remaining is Samsung Exynos, and there are a bunch of supporting patches in this merge window for it. There was a patch in this branch to a early version of multiplatform conversion, but it ended up being reverted due to need of more bake time. The revert commit is part of the branch since it would have required rebasing multiple dependent branches and they were stable by then" * tag 'multiplatform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits) mmc: sdhci-s3c: Fix operation on non-single image Samsung platforms clocksource: nomadik-mtu: fix up clocksource/timer Revert "ARM: exynos: enable multiplatform support" ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ" ARM: exynos: enable multiplatform support rtc: s3c: make header file local mtd: onenand/samsung: make regs-onenand.h file local thermal/exynos: remove unnecessary header inclusions mmc: sdhci-s3c: remove platform dependencies ARM: samsung: move mfc device definition to s5p-dev-mfc.c ARM: exynos: move debug-macro.S to include/debug/ ARM: exynos: prepare for sparse IRQ ARM: exynos: introduce EXYNOS_ATAGS symbol ARM: tegra: build assembly files with -march=armv7-a ARM: Push selects for TWD/SCU into machine entries ARM: ux500: build hotplug.o for ARMv7-a ARM: ux500: move to multiplatform ARM: ux500: make remaining headers local ARM: ux500: make irqs.h local to platform ARM: ux500: get rid of <mach/[hardware|db8500-regs].h> ...
2013-05-02Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanup from Olof Johansson: "Here is a collection of cleanup patches. Among the pieces that stand out are: - The deletion of h720x platforms - Split of at91 non-dt platforms to their own Kconfig file to keep them separate - General cleanups and refactoring of i.MX and MXS platforms - Some restructuring of clock tables for OMAP - Convertion of PMC driver for Tegra to dt-only - Some renames of sunxi -> sun4i (Allwinner A10) - ... plus a bunch of other stuff that I haven't mentioned" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: i.MX: remove unused ARCH_* configs ARM i.MX53: remove platform ahci support ARM: sunxi: Rework the restart code irqchip: sunxi: Rename sunxi to sun4i irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro clocksource: sunxi: Rename sunxi to sun4i clocksource: sunxi: make use of CLKSRC_OF clocksource: sunxi: Cleanup the timer code ARM: at91: remove trailing semicolon from macros ARM: at91/setup: fix trivial typos ARM: EXYNOS: remove "config EXYNOS_DEV_DRM" ARM: EXYNOS: change the name of USB ohci header ARM: SAMSUNG: Remove unnecessary code for dma ARM: S3C24XX: Remove unused GPIO drive strength register definitions ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412 ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410 ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC" ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI" ...
2013-04-30Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core timer updates from Ingo Molnar: "The main changes in this cycle's merge are: - Implement shadow timekeeper to shorten in kernel reader side blocking, by Thomas Gleixner. - Posix timers enhancements by Pavel Emelyanov: - allocate timer ID per process, so that exact timer ID allocations can be re-created be checkpoint/restore code. - debuggability and tooling (/proc/PID/timers, etc.) improvements. - suspend/resume enhancements by Feng Tang: on certain new Intel Atom processors (Penwell and Cloverview), there is a feature that the TSC won't stop in S3 state, so the TSC value won't be reset to 0 after resume. This can be taken advantage of by the generic via the CLOCK_SOURCE_SUSPEND_NONSTOP flag: instead of using the RTC to recover/approximate sleep time, the main (and precise) clocksource can be used. - Fix /proc/timer_list for 4096 CPUs by Nathan Zimmer: on so many CPUs the file goes beyond 4MB of size and thus the current simplistic seqfile approach fails. Convert /proc/timer_list to a proper seq_file with its own iterator. - Cleanups and refactorings of the core timekeeping code by John Stultz. - International Atomic Clock time is managed by the NTP code internally currently but not exposed externally. Separate the TAI code out and add CLOCK_TAI support and TAI support to the hrtimer and posix-timer code, by John Stultz. - Add deep idle support enhacement to the broadcast clockevents core timer code, by Daniel Lezcano: add an opt-in CLOCK_EVT_FEAT_DYNIRQ clockevents feature (which will be utilized by future clockevents driver updates), which allows the use of IRQ affinities to avoid spurious wakeups of idle CPUs - the right CPU with an expiring timer will be woken. - Add new ARM bcm281xx clocksource driver, by Christian Daudt - ... various other fixes and cleanups" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits) clockevents: Set dummy handler on CPU_DEAD shutdown timekeeping: Update tk->cycle_last in resume posix-timers: Remove unused variable clockevents: Switch into oneshot mode even if broadcast registered late timer_list: Convert timer list to be a proper seq_file timer_list: Split timer_list_show_tickdevices posix-timers: Show sigevent info in proc file posix-timers: Introduce /proc/PID/timers file posix timers: Allocate timer id per process (v2) timekeeping: Make sure to notify hrtimers when TAI offset changes hrtimer: Fix ktime_add_ns() overflow on 32bit architectures hrtimer: Add expiry time overflow check in hrtimer_interrupt timekeeping: Shorten seq_count region timekeeping: Implement a shadow timekeeper timekeeping: Delay update of clock->cycle_last timekeeping: Store cycle_last value in timekeeper struct as well ntp: Remove ntp_lock, using the timekeeping locks to protect ntp state timekeeping: Simplify tai updating from do_adjtimex timekeeping: Hold timekeepering locks in do_adjtimex and hardpps timekeeping: Move ADJ_SETOFFSET to top level do_adjtimex() ...
2013-04-28clocksource: samsung_pwm_timer: Work around rounding errors in clockevents coreTomasz Figa
Due to rounding errors in clockevents core (in conversions between ticks and nsecs), it might happen that the set_next_event callback gets called with cycles = 0, causing the code to incorrectly program the PWM timer. This patch modifies the callback to program the timer for 1 tick, if received tick count value is 0. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-28clocksource: samsung_pwm_timer: Correct programming of clock eventsTomasz Figa
In current code, the tick count value programmed to the hardware is always decremented by one. This is reasonable for periodic mode, since there is one extra tick between 0 and COUNT (after reloading), but it makes oneshot events happen 1 tick earlier than requested, because the interrupt is triggered on transition from 1 to 0. This patch removes the decrementation from PWM channel setup code and moves it instead to periodic timer setup, to make both periodic and oneshot modes work correctly. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-28clocksource: samsung_pwm_timer: Use proper clockevents max_deltaTomasz Figa
This patch replaces hardcoded -1 argument passed to clockevents_config_and_register() with tcnt_max calculated based on variant data. This fixes invalid max delta configuration for 16-bit timers of s3c24xx. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-28clocksource: samsung_pwm_timer: Add support for non-DT platformsTomasz Figa
This patch extends the driver to support platforms that still use legacy ATAGS-based boot, without device tree, by providing an exported function that can be used from platform code to initialize the clocksource. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-28clocksource: samsung_pwm_timer: Keep all driver data in a structureTomasz Figa
This patch modifies the driver to keep all its private data consistently in a single struct, instead of keeping part as separate variables. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-28clocksource: samsung_pwm_timer: Make PWM spinlock globalTomasz Figa
This patch makes the PWM spinlock global and exports it to allow using it in Samsung PWM driver (will be reworked to use proper synchronization in further patches). Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-28clocksource: samsung_pwm_timer: Let platforms select the driverTomasz Figa
This patch modifies the way of enabling the driver to let the platforms select it in their Kconfig instead of specifying particular platforms in Kconfig entry of the driver. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-26ARM: arch_timer: Silence debug preempt warningsStephen Boyd
Hot-plugging with CONFIG_DEBUG_PREEMPT=y on a device with arm architected timers causes a slew of "using smp_processor_id() in preemptible" warnings: BUG: using smp_processor_id() in preemptible [00000000] code: sh/111 caller is arch_timer_cpu_notify+0x14/0xc8 This happens because sometimes the cpu notifier, arch_timer_cpu_notify(), is called in preemptible context and other times in non-preemptible context but we use this_cpu_ptr() to retrieve the clockevent in all cases. We're only going to actually use the pointer in non-preemptible context though, so push the this_cpu_ptr() access down into the cases to force the checks to occur only in non-preemptible contexts. Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Mark Rutland <mark.rutland@arm.com> Acked-by: Marc Zyngier <Marc.Zyngier@arm.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-26clocksource: nomadik-mtu: fix up clocksource/timerLinus Walleij
The Nomadik clocksource driver has had a bad define making it impossible to use it for sched_clock() for a while. Fix this and also enable it for the Nomadik. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-21clocksource: add samsung pwm timer driverTomasz Figa
This adds a new clocksource driver for the PWM timer that is present in most Samsung SoCs, based on the existing driver in arch/arm/plat-samsung/samsung-time.c and many changes implemented by Tomasz Figa. Originally, the conversion of all Samsung machines to the new driver was planned for 3.10, but that work ended up being too late and too invasive just before the merge window. Unfortunately, other changes in the Exynos platform resulted in some Exynos4 setups, particularly the Universal C210 board to be broken. In order to fix that with minimum risk, so we now leave the existing pwm clocksource driver in place for all older platforms and use the new driver only for device tree enabled boards. This way, we can get the broken machines running again using DT descriptions. All clocksource changes were implemented by Tomasz, while the DT registration was rewritten by Arnd. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-04-19clocksource: exynos_mct: remove platform header dependencyArnd Bergmann
For the non-DT case, the mct_init() function requires access to a couple of platform specific constants, but cannot include the header files in case we are building for multiplatform. This changes the interface to the platform so we pass all the necessary data as arguments to mct_init. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org>
2013-04-19clocksource: exynos_mct: fix build error on non-DTArnd Bergmann
There is currently no alternative implementation for of_irq_count when the function is not defined, and the declaration is hidden, so this works around calling an undeclared function. It should really not be needed. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-04-17Merge tag 'clksrc-cleanup-for-3.10-part2' of ↵Olof Johansson
git://sources.calxeda.com/kernel/linux into late/clksrc This is the 2nd part of ARM timer clean-ups for 3.10. This series has the following changes: - Add sched_clock selection logic to select the highest frequency clock - Use full 64-bit arch timer counter for sched_clock - Convert arch timer, sp804 and integrator-cp timers to CLKSRC_OF and adapt all users to use clocksource_of_init * tag 'clksrc-cleanup-for-3.10-part2' of git://sources.calxeda.com/kernel/linux: devtree: add binding documentation for sp804 ARM: integrator-cp: convert use CLKSRC_OF for timer init ARM: versatile: use OF init for sp804 timer ARM: versatile: add versatile dtbs to dtbs target ARM: vexpress: remove extra timer-sp control register clearing ARM: dts: vexpress: disable CA9 core tile sp804 timer ARM: vexpress: remove sp804 OF init ARM: highbank: use OF init for sp804 timer ARM: timer-sp: convert to use CLKSRC_OF init OF: add empty of_device_is_available for !OF ARM: convert arm/arm64 arch timer to use CLKSRC_OF init ARM: make machine_desc->init_time default to clocksource_of_init ARM: arch_timer: use full 64-bit counter for sched_clock ARM: make sched_clock just call a function pointer ARM: sched_clock: allow changing to higher frequency counter Signed-off-by: Olof Johansson <olof@lixom.net> This has a nasty set of conflicts with the exynos MCT code, which was moved in a separate branch, and then fixed up when merged in, but still conflicts a bit here. It should have been sorted out by this merge though.
2013-04-11ARM: convert arm/arm64 arch timer to use CLKSRC_OF initRob Herring
This converts arm and arm64 to use CLKSRC_OF DT based initialization for the arch timer. A new function arch_timer_arch_init is added to allow for arch specific setup. This has a side effect of enabling sched_clock on omap5 and exynos5. There should not be any reason not to use the arch timers for sched_clock. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Simon Horman <horms@verge.net.au> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-samsung-soc@vger.kernel.org Cc: linux-omap@vger.kernel.org Cc: linux-sh@vger.kernel.org Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2013-04-11Merge tag 'sunxi-cleanup-for-3.10' of git://github.com/mripard/linux into ↵Olof Johansson
next/cleanup From Maxime Ripard: Cleanups for Allwinner sunXi architecture: - Remove sunxi.dtsi - Switch to clocksource/irqchip device tree handlers - Cleanup the watchdog code * tag 'sunxi-cleanup-for-3.10' of git://github.com/mripard/linux: ARM: sunxi: Rework the restart code irqchip: sunxi: Rename sunxi to sun4i irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro clocksource: sunxi: Rename sunxi to sun4i clocksource: sunxi: make use of CLKSRC_OF clocksource: sunxi: Cleanup the timer code clocksource: make CLOCKSOURCE_OF_DECLARE type safe Signed-off-by: Olof Johansson <olof@lixom.net> Add/change conflict in drivers/clocksource/Makefile resolved.
