Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit 97c3557c3e0413efb1f021f582d1459760e22727 upstream.
The gate clocks for the MFC sysmmus appear to be flipped, i.e.
GATE_IP_MFC[2] gates sysmmu_mfcl and GATE_IP_MFC[1] gates sysmmu_mfcr.
Fix this so that the MFC will start up.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Acked-by: Mike Turquette <mturquette@linaro.org>
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
commit 2feed5aecf5f367b92bd6b6e92afe9e3de466907 upstream.
The sysreg (system register) generates control signals for various blocks
like disp1blk, i2c, mipi, usb etc. However, it gets disabled as an unused
clock at boot-up. This can lead to failures in operation of above blocks,
because they can not be configured properly if this clock is disabled.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
[t.figa: Updated patch description.]
commit 5fdd1b56be51b1ec4dbde5b213d649ac717442da upstream.
The SRC_MFC register offset was incorrect, which could cause have caused
wrong calculation of rate of sclk_mfc clock, that could in turn lead to
incorrect operation of MFC. This patch corrects it.
Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
[t.figa: Updated patch description]
commit 778037e1ccb75609846deca9e419449c1dc137fa upstream.
Commit 6d9252bd9a4bb (clk: Add support for power of two type dividers)
merged in v3.6 added the _get_val function to convert a divisor value to
a register field value depending on the flags. However it used the type
u8 for the div field, causing divisors larger than 255 to be masked
and the resultant clock rate to be too high.
E.g. in my case an 11bit divider was supposed to divide 24.576 MHz down
to 32.768KHz. The divisor was correctly calculated as 750 (0x2ee). This
was masked to 238 (0xee) resulting in a frequency of 103.26KHz.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
This is the 3.10.24 stable release
Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
commit 1022c75f5abd3a3b25e679bc8793d21bedd009b4 upstream.
This patch fixes the tclk frequency array for the Armada-370 SoC.
This bug has been introduced by commit 6b72333d
("clk: mvebu: add Armada 370 SoC-centric clock init").
A wrong tclk frequency affects the following drivers: mvsdio, mvneta,
i2c-mv64xxx and mvebu-devbus. This list may be incomplete.
About the mvneta Ethernet driver, note that the tclk frequency is used
to compute the Rx time coalescence. Then, this bug harms the coalescence
configuration and also degrades the networking performances with the
default values.
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Signed-off-by: Michael Turquette <mturquette@deferred.io>
commit 2f9f64bc5aa31836810cd25301aa4772ad73ebab upstream.
The order of arguments in the call to vco_set() for the ICST clocks appears to
have been switched in error, which results in the VCO not being initialised
correctly. This in turn stops the integrated LCD on things like Integrator/CP
from working correctly.
This patch fixes the order and restores the expected functionality.
Signed-off-by: Jonathan Austin <jonathan.austin@arm.com>
Modify AS3722 clock driver to work with non-common clock framework
and add following support:
- enable/disable on boot.
- Selection of enable or disable clock through platform data and DT.
Change-Id: I3629396d51b389ea8d425bf4a2ae7af915ec950a
Reviewed-on: http://git-master/r/328282
GVS: Gerrit_Virtual_Submit
Device ams AS3722 supports the one 32KHz clock output. The clock
control support is provided through clock driver.
Add clock driver as mfd sub device to probe the clock driver.
Change-Id: I5e3b34de4db9f0bdf4a0a2b6b1f5d4a66c309bb2
Reviewed-on: http://git-master/r/328281
This is the 3.10.17 stable release
drivers/usb/host/xhci.c
Change-Id: I6bd3b15ff92a0b94568b9d02e9bb1036becfca20
Register the Palmas clock driver even if there is no clock platform
data.
bug 1379983
Change-Id: I29bdeff6fa2b21a8ead231429624b6da5fe70f29
Reviewed-on: http://git-master/r/280536
(cherry picked from commit e7d9d97174c0376baf02a923f6cdb9aaf39e1e74)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
Add Palmas clock driver to control 32KHz clock from Palmas
device.
Change-Id: I4f684e17da0c96f3fba0cd52b35c995ef7c86930
Reviewed-on: http://git-master/r/279802
(cherry picked from commit b092feb064baf85bc238bfbb57c476e7e31b3f93)
commit 08442ce993deeb15a070c14cc3f3459e87d111e0 upstream.
Otherwise any attempt to interact with the hardware will crash. This is
what happens when drivers get written blind.
Signed-off-by: Mark Brown <broonie@linaro.org>
This moved upstream, do the equivalent change here.
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Change-Id: I2de76e5c6487ed4513b6d070e0c515a27a881fff
This reverts commit e4bcda28344cc4762c57ad7333f0472a39e83479.
Registering pciex as peripheral clock instead of fixed clock
as tegra_perih_reset_assert(deassert) api of this clock api
gives warning and ultimately does not succeed to assert(deassert)
Signed-off-by: Jay Agarwal <jagarwal@nvidia.com>
Currently 'pmu' clock is not handled by any of the drivers.
Also before the introduction of CCF, this clock was not defined,
hence was left enabled always.
When this clock is disabled, software reset register becomes
inaccessible and system reboot doesn't work.
Upon restoring the default behaviour, system reboot starts working.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
This patch is required to be able to disable spear320 support
after the spear320_clk_init() prototype changed for the real
function but not for the dummy.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
The KDIV value is often listed as unsigned but it needs to be treated
as a 16-bit signed value when using it in calculations. Fix our rate
recalculation to do this correctly.
Before doing this, I tried setting EPLL on exynos5250 to:
rate, m, p, s, k = 80000000, 107, 2, 4, 43691
This rate is exactly from the table in the exynos5250 user manual.
I read this back as 80750003 with:
cat /sys/kernel/debug/clk/fin_pll/fout_epll/clk_rate
After this patch, it reads back as 80000003
Signed-off-by: Doug Anderson <dianders@chromium.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Reviewed-by: Vikas Sajjan <vikas.sajjan@linaro.org>
'mout_mpll' is added the list of parent clocks for 'mout_cpu'.
'mout_mpll' is an alias to the clock 'sclk_mpll'. Hence 'sclk_mpll'
should be added to the list of parent clocks.
This results in an error when cpufreq driver for EXYNOS5250 tries to
set 'mout_mpll' as a parent for 'mout_cpu'.
clk_set_parent: clk sclk_mpll can not be parent of clk mout_cpu
cpufreq driver for EXYNOS5250 is not a platform driver, hence we cannot
currently pass the clock names through a device tree node. Instead, we
need to make them available through a global alias.
cpufreq driver for EXYNOS5250 requires four clocks - 'armclk',
'mout_cpu', 'mout_mpll' and 'mout_apll'.
'armclk' has already been defined with an alias, 'mout_cpu', 'mout_mpll'
and 'mout_apll' are now defined with an alias.
The @cn is stay in @clk_notifier_list after it is freed, it cause
memory corruption.
Example, if @clk is registered(first), unregistered(first),
registered(second), unregistered(second).
The freed @cn will be used when @clk is registered(second),
and the bug will be happened when @clk is unregistered(second):
[ 517.040000] clk_notif_dbg clk_notif_dbg.1: clk_notifier_unregister()
[ 517.040000] Unable to handle kernel paging request at virtual address 00df3008
[ 517.050000] pgd = ed858000
[ 517.050000] [00df3008] *pgd=00000000
[ 517.060000] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 517.060000] Modules linked in: clk_notif_dbg(O-) [last unloaded: clk_notif_dbg]
[ 517.060000] CPU: 1 PID: 499 Comm: modprobe Tainted: G O 3.10.0-rc3-00119-ga93cb29-dirty #85
[ 517.060000] task: ee1e0180 ti: ee3e6000 task.ti: ee3e6000
[ 517.060000] PC is at srcu_readers_seq_idx+0x48/0x84
[ 517.060000] LR is at srcu_readers_seq_idx+0x60/0x84
[ 517.060000] pc : [<c0052720>] lr : [<c0052738>] psr: 80070013
[ 517.060000] sp : ee3e7d48 ip : 00000000 fp : ee3e7d6c
[ 517.060000] r10: 00000000 r9 : ee3e6000 r8 : 00000000
[ 517.060000] r7 : ed84fe4c r6 : c068ec90 r5 : c068e430 r4 : 00000000
[ 517.060000] r3 : 00df3000 r2 : 00000000 r1 : 00000002 r0 : 00000000
[ 517.060000] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 517.060000] Control: 18c5387d Table: 2d85804a DAC: 00000015
[ 517.060000] Process modprobe (pid: 499, stack limit = 0xee3e6238)
[ 517.060000] Stack: (0xee3e7d48 to 0xee3e8000)
[ 517.060000] [<c0052720>] (srcu_readers_seq_idx+0x48/0x84) from [<c0052790>] (try_check_zero+0x34/0xfc)
[ 517.060000] [<c0052790>] (try_check_zero+0x34/0xfc) from [<c00528b0>] (srcu_advance_batches+0x58/0x114)
[ 517.060000] [<c00528b0>] (srcu_advance_batches+0x58/0x114) from [<c0052c30>] (__synchronize_srcu+0x114/0x1ac)
[ 517.060000] [<c0052c30>] (__synchronize_srcu+0x114/0x1ac) from [<c0052d14>] (synchronize_srcu+0x2c/0x34)
[ 517.060000] [<c0052d14>] (synchronize_srcu+0x2c/0x34) from [<c0053a08>] (srcu_notifier_chain_unregister+0x68/0x74)
[ 517.060000] [<c0053a08>] (srcu_notifier_chain_unregister+0x68/0x74) from [<c0375a78>] (clk_notifier_unregister+0x7c/0xc0)
[ 517.060000] [<c0375a78>] (clk_notifier_unregister+0x7c/0xc0) from [<bf008034>] (clk_notif_dbg_remove+0x34/0x9c [clk_notif_dbg])
[ 517.060000] [<bf008034>] (clk_notif_dbg_remove+0x34/0x9c [clk_notif_dbg]) from [<c02bb974>] (platform_drv_remove+0x24/0x28)
[ 517.060000] [<c02bb974>] (platform_drv_remove+0x24/0x28) from [<c02b9bf8>] (__device_release_driver+0x8c/0xd4)
[ 517.060000] [<c02b9bf8>] (__device_release_driver+0x8c/0xd4) from [<c02ba680>] (driver_detach+0x9c/0xc4)
[ 517.060000] [<c02ba680>] (driver_detach+0x9c/0xc4) from [<c02b99c4>] (bus_remove_driver+0xcc/0xfc)
[ 517.060000] [<c02b99c4>] (bus_remove_driver+0xcc/0xfc) from [<c02bace4>] (driver_unregister+0x54/0x78)
[ 517.060000] [<c02bace4>] (driver_unregister+0x54/0x78) from [<c02bbb44>] (platform_driver_unregister+0x1c/0x20)
[ 517.060000] [<c02bbb44>] (platform_driver_unregister+0x1c/0x20) from [<bf0081f8>] (clk_notif_dbg_driver_exit+0x14/0x1c [clk_notif_dbg])
[ 517.060000] [<bf0081f8>] (clk_notif_dbg_driver_exit+0x14/0x1c [clk_notif_dbg]) from [<c00835e4>] (SyS_delete_module+0x200/0x28c)
[ 517.060000] [<c00835e4>] (SyS_delete_module+0x200/0x28c) from [<c000edc0>] (ret_fast_syscall+0x0/0x48)
[ 517.060000] Code: e5973004 e7911102 e0833001 e2881002 (e7933101)
Cc: stable@kernel.org
Reported-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Tested-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
[mturquette@linaro.org: shortened $SUBJECT]
Fix the following sparse warnings:
drivers/clk/mxs/clk-imx28.c:72:5: warning: symbol 'mxs_saif_clkmux_select' was not declared. Should it be static?
drivers/clk/mxs/clk-imx28.c:156:12: warning: symbol 'mx28_clocks_init' was not declared. Should it be static?
Acked-by: Shawn Guo <shawn.guo@linaro.org>
[mturquette@linaro.org: fixed $SUBJECT line]
With the addition of a DVO clock, a bug is now evident in the vt8500
clock code:
[ 0.290000] WARNING: at init/main.c:698 do_one_initcall+0x158/0x18c()
[ 0.300000] initcall wm8505fb_driver_init+0x0/0xc returned with disabled int
This is caused by an unbalanced spinlock in vt8500_dclk_set_rate().
Replace the second call to spin_lock_irqsave() with spin_unlock_irqrestore().
Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
clock-frequency property from platform data was read but never used.
Apply defined rate when clock is registered.
Signed-off-by: Marek Belisko <marek.belisko@streamunlimited.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
[mturquette@linaro.org: add missing changelog]
Rate was incorrectly computed because we read from wrong divider register.
Currently no driver *) handles the sysreg clock, with an assumption
that this clock is always left in its default state (enabled).
Before commit 6e6aac7590f902d14d90bace3fd499
ARM: EXYNOS: Migrate clock support to common clock framework
the sysreg clock was not even defined and hence wasn't handled
explicitly in the kernel.
To restore the previous behaviour disable masking the sysreg clock
off in the clock core by default.
*) Except the Exynos4x12 FIMC-IS driver, which will be modified
to not touch the sysreg clock.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Fix clk_reg_sysctrl() to set main clock registers of new struct
clk_sysctrl even if the registered clock has no parents.
This fixes an issue where "ulpclk" was registered with all clk->reg_*
fields uninitialized, causing a -EINVAL error from clk_prepare().
Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
First Ethernet device has a ".0" appended onto the device name. It
appears that we need this in order to obtain the correct clock.
Without this fix Ethernet does not function on Ux500 devices, which is a
regression.
Cc: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
[mturquette@linaro.org: improved changelog]
Pull slave-dma fixes from Vinod Koul:
"We have two patches from Andy & Rafael fixing the Lynxpoint dma"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
ACPI / LPSS: register clock device for Lynxpoint DMA properly
dma: acpi-dma: parse CSRT to extract additional resources
AC97 controller clock is hardwired to pll_a_out0.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Acked-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
The USB clocks are just clock gates, so no need to set a specific clock.
In fact trying to set a specific clock is just a NOP if the requested
clockrate is the same as those of the parent (clk_m) or will trigger a
WARN_ON() if rates don't match up.
As we are not setting a specific rate, nor activating the clocks at
init, there is no point in keeping the the usb entries in the clock init
table.
The DMA controller in Lynxpoint is enumerated as a regular ACPI device now. To
work properly it is using the LPSS root clock as a functional clock. That's why
we have to register the clock device accordingly to the ACPI ID of the DMA
controller. The acpi_lpss.c module is responsible to do the job.
This patch also removes hardcoded name of the DMA device in clk-lpt.c and the
name of the root clock in acpi_lpss.c.
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Pull late ARM Exynos multiplatform changes from Arnd Bergmann:
"These continue the multiplatform support for exynos, adding support
for building most of the essential drivers (clocksource, clk, irqchip)
when combined with other platforms. As a result, it should become
really easy to add full multiplatform exynos support in 3.11, although
we don't yet enable it for 3.10.
The changes were not included in the earlier multiplatform series in
order to avoid clashes with the other Exynos updates.
This also includes work from Tomasz Figa to fix the pwm clocksource
code on Exynos, which is not strictly required for multiplatform, but
related to the other patches in this set and needed as a bug fix for
at least one board."
* tag 'multiplatform-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (22 commits)
ARM: dts: exynops4210: really add universal_c210 dts
ARM: dts: exynos4210: Add basic dts file for universal_c210 board
ARM: dts: exynos4: Add node for PWM device
ARM: SAMSUNG: Do not register legacy timer interrupts on Exynos
clocksource: samsung_pwm_timer: Work around rounding errors in clockevents core
clocksource: samsung_pwm_timer: Correct programming of clock events
clocksource: samsung_pwm_timer: Use proper clockevents max_delta
clocksource: samsung_pwm_timer: Add support for non-DT platforms
clocksource: samsung_pwm_timer: Drop unused samsung_pwm struct
clocksource: samsung_pwm_timer: Keep all driver data in a structure
clocksource: samsung_pwm_timer: Make PWM spinlock global
clocksource: samsung_pwm_timer: Let platforms select the driver
Documentation: Add device tree bindings for Samsung PWM timers
clocksource: add samsung pwm timer driver
irqchip: exynos: look up irq using irq_find_mapping
irqchip: exynos: pass irq_base from platform
irqchip: exynos: localize irq lookup for ATAGS
irqchip: exynos: allocate combiner_data dynamically
irqchip: exynos: pass max combiner number to combiner_init
ARM: exynos: add missing properties for combiner IRQs
Pull ARM SoC board specific changes (part 1) from Olof Johansson:
"These changes are all for board specific files. These used to make up
a large portion of the ARM changes in the past, but as we are
generalizing the support and moving to device tree probing, this has
gotten significantly smaller.
The only platform actually adding new code here at the moment is
Renesas shmobile, as they are still busy converting their code to
device tree and have not come far enough to not need it."
* tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits)
ARM: msm: USB_MSM_OTG needs USB_PHY
ARM: davinci: da850 evm: fix const qualifier placement
ARM: davinci: da850 board: add remoteproc support
ARM: pxa: move debug uart code
ARM: pxa: select PXA935 on saar & tavorevb
ARM: mmp: add more compatible names in gpio driver
ARM: pxa: move PXA_GPIO_TO_IRQ macro
ARM: pxa: remove cpu_is_xxx in gpio driver
ARM: Kirkwood: update Network Space Mini v2 description
ARM: Kirkwood: DT board setup for CloudBox
ARM: Kirkwood: sort board entries by ASCII-code order
ARM: OMAP: board-4430sdp: Provide regulator to pwm-backlight
ARM: OMAP: zoom: Use pwm stack for lcd and keyboard backlight
ARM: OMAP2+: omap2plus_defconfig: Add support for BMP085 pressure sensor
omap2+: Remove useless Makefile line
ARM: OMAP: RX-51: add missing regulator supply definitions for lis3lv02d
ARM: OMAP1: fix omap_udc registration
ARM: davinci: use is IS_ENABLED macro
ARM: kirkwood: add MACH_GURUPLUG_DT to defconfig
Pull ARM SoC driver changes from Olof Johansson:
"This is a rather large set of patches for device drivers that for one
reason or another the subsystem maintainer preferred to get merged
through the arm-soc tree. There are both new drivers as well as
existing drivers that are getting converted from platform-specific
code into standalone drivers using the appropriate subsystem specific
interfaces.
In particular, we can now have pinctrl, clk, clksource and irqchip
drivers in one file per driver, without the need to call into platform
specific interface, or to get called from platform specific code, as
long as all information about the hardware is provided through a
device tree.
Most of the drivers we touch this time are for clocksource. Since now
most of them are part of drivers/clocksource, I expect that we won't
have to touch these again from arm-soc and can let the clocksource
maintainers take care of these in the future.
Another larger part of this series is specific to the exynos platform,
which is seeing some significant effort in upstreaming and
modernization of its device drivers this time around, which
unfortunately is also the cause for the churn and a lot of the merge
conflicts.
There is one new subsystem that gets merged as part of this series:
the reset controller interface, which is a very simple interface for
taking devices on the SoC out of reset or back into reset. Patches to
use this interface on i.MX follow later in this merge window, and we
are going to have other platforms (at least tegra and sirf) get
converted in 3.11. This will let us get rid of platform specific
callbacks in a number of platform independent device drivers."
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits)
irqchip: s3c24xx: add missing __init annotations
ARM: dts: Disable the RTC by default on exynos5
clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3}
ARM: exynos: restore mach/regs-clock.h for exynos5
clocksource: exynos_mct: fix build error on non-DT
pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register()
irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure
reset: NULL deref on allocation failure
reset: Add reset controller API
dt: describe base reset signal binding
ARM: EXYNOS: Add arm-pmu DT binding for exynos421x
ARM: EXYNOS: Add arm-pmu DT binding for exynos5250
ARM: EXYNOS: Enable PMUs for exynos4
irqchip: exynos-combiner: Correct combined IRQs for exynos4
irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq
ARM: EXYNOS: fix compilation error introduced due to common clock migration
clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3}
clk: exynos4: export clocks required for fimc-is
clk: samsung: Fix compilation error
clk: tegra: fix enum tegra114_clk to match binding
Pull ARM SoC multiplatform updates from Olof Johansson:
"More multiplatform enablement for ARM platforms. The ones converted
in this branch are:
- bcm2835
- cns3xxx
- sirf
- nomadik
- msx
- spear
- tegra
- ux500
We're getting close to having most of them converted!
One of the larger platforms remaining is Samsung Exynos, and there are
a bunch of supporting patches in this merge window for it. There was
a patch in this branch to a early version of multiplatform conversion,
but it ended up being reverted due to need of more bake time. The
revert commit is part of the branch since it would have required
rebasing multiple dependent branches and they were stable by then"
* tag 'multiplatform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits)
mmc: sdhci-s3c: Fix operation on non-single image Samsung platforms
clocksource: nomadik-mtu: fix up clocksource/timer
Revert "ARM: exynos: enable multiplatform support"
ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ"
rtc: s3c: make header file local
mtd: onenand/samsung: make regs-onenand.h file local
thermal/exynos: remove unnecessary header inclusions
mmc: sdhci-s3c: remove platform dependencies
ARM: samsung: move mfc device definition to s5p-dev-mfc.c
ARM: exynos: move debug-macro.S to include/debug/
ARM: exynos: prepare for sparse IRQ
ARM: exynos: introduce EXYNOS_ATAGS symbol
ARM: tegra: build assembly files with -march=armv7-a
ARM: Push selects for TWD/SCU into machine entries
ARM: ux500: build hotplug.o for ARMv7-a
ARM: ux500: move to multiplatform
ARM: ux500: make remaining headers local
ARM: ux500: make irqs.h local to platform
ARM: ux500: get rid of <mach/[hardware|db8500-regs].h>
Pull ARM SoC platform updates from Olof Johansson:
"This branch contains part 1 of the platform updates for 3.10. Among
the highlights:
- Support for the new Atmel Cortex-A5 based platforms (SAMA5D3)
- New support for CSR SiRFatlas6 SoCs
- A handful of updates for NVidia T114 (a.k.a. Tegra 4)
- A bunch of updates for the shmobile platforms
- A handful of updates for davinci
- A few updates for Qualcomm MSM
- Plus a handful of other patches, defconfig updates, etc."
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (135 commits)
ARM: tegra: pm: fix build error w/o PM_SLEEP
ARM: davinci: ensure global variables are declared
ARM: davinci: sram.c: fix incorrect type in assignment
ARM: davinci: da8xx dt: make file local symbols static
ARM: davinci: da8xx: add remoteproc support
ARM: socfpga: Upgrade clk driver for socfpga to make use of dts clock entries
ARM: socfpga: Add clock entries into device tree
ARM: socfpga: Enable soft reset
ARM: EXYNOS: replace cpumask by the corresponding macro
ARM: EXYNOS: handle properly the return values
ARM: EXYNOS: factor out the idle states
ARM: OMAP4: Enable fix for Cortex-A9 erratas
ARM: OMAP2+: Export SoC information to userspace
ARM: OMAP2+: SoC name and revision unification
ARM: OMAP2+: Move common part of late init into common function
ARM: tegra: pm: remove duplicated include from pm.c
ARM: davinci: da850: override mmc DT node device name
ARM: davinci: da850: add mmc DT entries
mmc: davinci_mmc: add DT support
ARM: SAMSUNG: check processor type before cache restoration in resume
Pull ARM SoC cleanup from Olof Johansson:
"Here is a collection of cleanup patches. Among the pieces that stand
out are:
- The deletion of h720x platforms
- Split of at91 non-dt platforms to their own Kconfig file to keep
them separate
- General cleanups and refactoring of i.MX and MXS platforms
- Some restructuring of clock tables for OMAP
- Convertion of PMC driver for Tegra to dt-only
- Some renames of sunxi -> sun4i (Allwinner A10)
- ... plus a bunch of other stuff that I haven't mentioned"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits)
ARM: i.MX: remove unused ARCH_* configs
ARM i.MX53: remove platform ahci support
ARM: sunxi: Rework the restart code
irqchip: sunxi: Rename sunxi to sun4i
irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro
clocksource: sunxi: Rename sunxi to sun4i
clocksource: sunxi: make use of CLKSRC_OF
clocksource: sunxi: Cleanup the timer code
ARM: at91: remove trailing semicolon from macros
ARM: at91/setup: fix trivial typos
ARM: EXYNOS: remove "config EXYNOS_DEV_DRM"
ARM: EXYNOS: change the name of USB ohci header
ARM: SAMSUNG: Remove unnecessary code for dma
ARM: S3C24XX: Remove unused GPIO drive strength register definitions
ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410
ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards
ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC"
ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI"
Pull ARM SoC non-critical fixes from Olof Johansson:
"Here is a collection of fixes (and some intermixed cleanups) that were
considered less important and thus not included in the later parts of
the 3.9-rc cycle.
It's a bit all over the map, contents wise. A series of ux500 fixes
and cleanups, a bunch of various fixes for OMAP and tegra, and some
for Freescale i.MX and even Qualcomm MSM.
Note that there's also a patch on this branch to globally turn off
-Wmaybe-uninitialized when building with -Os. It's been posted
several times by Arnd and no dissent was raised, but nobody seemed
interested to pick it up. So here it is, as the topmost patch."
* tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits)
Turn off -Wmaybe-uninitialized when building with -Os
ARM: orion5x: include linux/cpu.h
ARM: tegra: call cpu_do_idle from C code
ARM: u300: fix ages old copy/paste bug
ARM: OMAP2+: add dependencies on ARCH_MULTI_V6/V7
ARM: tegra: solve adr range issue with THUMB2_KERNEL enabled
ARM: tegra: fix relocation truncated error when THUMB2_KERNEL enabled
ARM: tegra: fix build error when THUMB2_KERNEL enabled
ARM: msm: Fix uncompess.h tx underrun check
ARM: vexpress: Remove A9 PMU compatible values for non-A9 platforms
ARM: cpuimx27 and mbimx27: prepend CONFIG_ to Kconfig macro
ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS"
ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD"
ARM: mach-imx: mach-imx6q: Fix sparse warnings
ARM: mach-imx: src: Include "common.h
ARM: mach-imx: gpc: Include "common.h"
ARM: mach-imx: avic: Staticize *avic_base
ARM: mach-imx: tzic: Staticize *tzic_base
ARM: mach-imx: clk: Include "clk.h"
ARM: mach-imx: clk-busy: Staticize clk_busy_mux_ops
Pull power management and ACPI updates from Rafael J Wysocki:
- ARM big.LITTLE cpufreq driver from Viresh Kumar.
- exynos5440 cpufreq driver from Amit Daniel Kachhap.
- cpufreq core cleanup and code consolidation from Viresh Kumar and
Stratos Karafotis.
- cpufreq scalability improvement from Nathan Zimmer.
- AMD "frequency sensitivity feedback" powersave bias for the ondemand
cpufreq governor from Jacob Shin.
- cpuidle code consolidation and cleanups from Daniel Lezcano.
- ARM OMAP cpuidle fixes from Santosh Shilimkar and Daniel Lezcano.
- ACPICA fixes and other improvements from Bob Moore, Jung-uk Kim, Lv
Zheng, Yinghai Lu, Tang Chen, Colin Ian King, and Linn Crosetto.
- ACPI core updates related to hotplug from Toshi Kani, Paul Bolle,
Yasuaki Ishimatsu, and Rafael J Wysocki.
- Intel Lynxpoint LPSS (Low-Power Subsystem) support improvements from
Rafael J Wysocki and Andy Shevchenko.
* tag 'pm+acpi-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (192 commits)
cpufreq: Revert incorrect commit 5800043
cpufreq: MAINTAINERS: Add co-maintainer
cpuidle: add maintainer entry
ACPI / thermal: do not always return THERMAL_TREND_RAISING for active trip points
ARM: s3c64xx: cpuidle: use init/exit common routine
cpufreq: pxa2xx: initialize variables
ACPI: video: correct acpi_video_bus_add error processing
SH: cpuidle: use init/exit common routine
ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y
ACPI: Fix wrong parameter passed to memblock_reserve
cpuidle: fix comment format
pnp: use %*phC to dump small buffers
isapnp: remove debug leftovers
ARM: imx: cpuidle: use init/exit common routine
ARM: davinci: cpuidle: use init/exit common routine
ARM: kirkwood: cpuidle: use init/exit common routine
ARM: calxeda: cpuidle: use init/exit common routine
ARM: tegra: cpuidle: use init/exit common routine for tegra3
ARM: tegra: cpuidle: use init/exit common routine for tegra2
ARM: OMAP4: cpuidle: use init/exit common routine
Pull trivial tree updates from Jiri Kosina:
"Usual stuff, mostly comment fixes, typo fixes, printk fixes and small
code cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits)
mm: Convert print_symbol to %pSR
gfs2: Convert print_symbol to %pSR
m32r: Convert print_symbol to %pSR
iostats.txt: add easy-to-find description for field 6
x86 cmpxchg.h: fix wrong comment
treewide: Fix typo in printk and comments
doc: devicetree: Fix various typos
docbook: fix 8250 naming in device-drivers
pata_pdc2027x: Fix compiler warning
treewide: Fix typo in printks
mei: Fix comments in drivers/misc/mei
treewide: Fix typos in kernel messages
pm44xx: Fix comment for "CONFIG_CPU_IDLE"
doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP"
mmzone: correct "pags" to "pages" in comment.
kernel-parameters: remove outdated 'noresidual' parameter
Remove spurious _H suffixes from ifdef comments
sound: Remove stray pluses from Kconfig file
radio-shark: Fix printk "CONFIG_LED_CLASS"
doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE
Pull clock framework update from Michael Turquette:
"The common clock framework changes for 3.10 include many fixes for
existing platforms, as well as adoption of the framework by new
platforms and devices.
Some long-needed fixes to the core framework are here as well as new
features such as improved initialization of clocks from DT as well as
framework reentrancy for nested clock operations."
* tag 'clk-for-linus-3.10' of git://git.linaro.org/people/mturquette/linux: (44 commits)
clk: add clk_ignore_unused option to keep boot clocks on
clk: ux500: fix mismatched types
clk: vexpress: Add separate SP810 driver
clk: si5351: make clk-si5351 depend on CONFIG_OF
clk: export __clk_get_flags for modular clock providers
clk: vt8500: Missing breaks in vtwm_pll_round_rate/_set_rate.
clk: sunxi: Unify oscillator clock
clk: composite: allow fixed rates & fixed dividers
clk: composite: rename 'div' references to 'rate'
clk: add si5351 i2c common clock driver
clk: add device tree fixed-factor-clock binding support
clk: Properly handle notifier return values
clk: ux500: abx500: Define clock tree for ab850x
clk: ux500: Add support for sysctrl clocks
clk: mvebu: Fix valid value range checking for cpu_freq_select
clk: Fixup locking issues for clk_set_parent
clk: Fixup errorhandling for clk_set_parent
clk: Restructure code for __clk_reparent
clk: sunxi: drop an unnecesary kmalloc
clk: sunxi: drop CLK_IGNORE_UNUSED
Merging in fixes since there's a conflict in the omap4 clock tables caused by
it.
* fixes: (245 commits)
ARM: highbank: fix cache flush ordering for cpu hotplug
ARM: OMAP4: hwmod data: make 'ocp2scp_usb_phy_phy_48m" as the main clock
arm: mvebu: Fix the irq map function in SMP mode
Fix GE0/GE1 init on ix2-200 as GE0 has no PHY
ARM: S3C24XX: Fix interrupt pending register offset of the EINT controller
ARM: S3C24XX: Correct NR_IRQS definition for s3c2440
ARM i.MX6: Fix ldb_di clock selection
ARM: imx: provide twd clock lookup from device tree
ARM: imx35 Bugfix admux clock
ARM: clk-imx35: Bugfix iomux clock
+ Linux 3.9-rc6
arch/arm/mach-omap2/cclock44xx_data.c
This is primarily useful when there's a driver that doesn't claim clocks
properly, but the bootloader leaves them on. It's not expected to be used
in normal cases, but for bringup and debug it's very useful to have the
option to not gate unclaimed clocks that are still on.
[mturquette@linaro.org: fixed up trivial merge issue]
* acpi-lpss:
ACPI / LPSS: make code less confusing for reader
ACPI / LPSS: Add support for exposing LTR registers to user space
ACPI / scan: Add special handler for Intel Lynxpoint LPSS devices
commit 688f7d8c9fef ("clk: exynos5250: Fix divider values for
sclk_mmc{0,1,2,3}") incorrectly sets the divider for sclk_mmc{0,1,2,3}
to fix the wrong clock value. Though this fixed issue with Arndale,
it created regressions for other boards like Snow.
On Exynos5250, sclk_mmc<n> is generated like below (as per the clock
names in drivers/clk/samsung/clk-exynos5250.c)
mout_group1_p ==> mout_mmc<n> ==>
div_mmc<n> ==> div_mmc_pre<n> => sclk_mmc<n>
Earlier div_mmc<n> was set as the parent for sclk_mmc<n>, hence
div_mmc_pre<n> was not getting referred in kernel code and depending
on its value set during preboot, sclk_mmc<n> value was different for
various boards.
Setting the correct clock generation path should fix the issues
reported in above referenced commit. The changes committed during the
earlier patch has also been reverted here.
Reported-by: Doug Anderson <dianders@chromium.org>
Tested-by: Doug Anderson <dianders@chromium.org>
As reported by Rob Herring[1] there were some mismatched types between
drivers/clk/ux500/clk.h and the corresponding function definitions:
drivers/clk/ux500/clk-prcc.c:145:13: error: conflicting types for 'clk_reg_prcc_pclk'
drivers/clk/ux500/clk-prcc.c:155:13: error: conflicting types for 'clk_reg_prcc_kclk'
[1] http://article.gmane.org/gmane.linux.ports.arm.kernel/232246
Cc: Rob Herring <robherring2@gmail.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
