path: root/drivers/char
2014-06-05Merge branch 'linux-3.10.40' into rel-21Ishan Mittal
Bug 200004122 Conflicts: drivers/cpufreq/cpufreq.c drivers/regulator/core.c sound/soc/codecs/max98090.c Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-04-26Char: ipmi_bt_sm, fix infinite loopJiri Slaby
commit a94cdd1f4d30f12904ab528152731fb13a812a16 upstream. In read_all_bytes, we do unsigned char i; ... bt->read_data[0] = BMC2HOST; bt->read_count = bt->read_data[0]; ... for (i = 1; i <= bt->read_count; i++) bt->read_data[i] = BMC2HOST; If bt->read_data[0] == bt->read_count == 255, we loop infinitely in the 'for' loop. Make 'i' an 'int' instead of 'char' to get rid of the overflow and finish the loop after 255 iterations every time. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Reported-and-debugged-by: Rui Hui Dian <rhdian@novell.com> Cc: Tomas Cech <tcech@suse.cz> Cc: Corey Minyard <minyard@acm.org> Cc: <openipmi-developer@lists.sourceforge.net> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-13Merge branch 'linux-3.10.33' into dev-kernel-3.10Deepak Nibade
Bug 1456092 Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
2014-02-22raw: test against runtime value of max_raw_minorsPaul Bolle
commit 5bbb2ae3d6f896f8d2082d1eceb6131c2420b7cf upstream. bind_get() checks the device number it is called with. It uses MAX_RAW_MINORS for the upper bound. But MAX_RAW_MINORS is set at compile time while the actual number of raw devices can be set at runtime. This means the test can either be too strict or too lenient. And if the test ends up being too lenient bind_get() might try to access memory beyond what was allocated for "raw_devices". So check against the runtime value (max_raw_minors) in this function. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06tpm/tpm_ppi: Do not compare strcmp(a,b) == -1Peter Huewe
commit 747d35bd9bb4ae6bd74b19baa5bbe32f3e0cee11 upstream. Depending on the implementation strcmp might return the difference between two strings not only -1,0,1 consequently if (strcmp (a,b) == -1) might lead to taking the wrong branch -> compare with < 0 instead, which in any case is more canonical. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06tpm/tpm_i2c_stm_st33: Check return code of get_burstcountPeter Huewe
commit 85c5e0d451125c6ddb78663972e40af810b83644 upstream. The 'get_burstcount' function can in some circumstances 'return -EBUSY' which in tpm_stm_i2c_send is stored in an 'u32 burstcnt' thus converting the signed value into an unsigned value, resulting in 'burstcnt' being huge. Changing the type to u32 only does not solve the problem as the signed value is converted to an unsigned in I2C_WRITE_DATA, resulting in the same effect. Thus -> Change type of burstcnt to u32 (the return type of get_burstcount) -> Add a check for the return value of 'get_burstcount' and propagate a potential error. This makes also sense in the 'I2C_READ_DATA' case, where the there is no signed/unsigned conversion. found by coverity Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15ACPI / TPM: fix memory leak when walking ACPI namespaceJiang Liu
commit df45c712d1f4ef37714245fb75de726f4ca2bf8d upstream. In function ppi_callback(), memory allocated by acpi_get_name() will get leaked when current device isn't the desired TPM device, so fix the memory leak. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-16Merge tag 'v3.10.24' into HEADAjay Nandakumar
This is the 3.10.24 stable release Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
2013-12-11drivers/char/i8k.c: add Dell XPLS L421XAlan Cox
commit 9aa5b0181bdf335f0b731d8502e128a862884bcd upstream. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=60772 Signed-off-by: Alan Cox <alan@linux.intel.com> Reported-by: Leho Kraav <leho@kraav.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-31Merge tag 'v3.10.17' into dev-kernel-3.10Ajay Nandakumar
This is the 3.10.17 stable release Conflicts: drivers/usb/host/xhci.c Change-Id: I6bd3b15ff92a0b94568b9d02e9bb1036becfca20
2013-10-18random: run random_int_secret_init() run after all late_initcallsTheodore Ts'o
commit 47d06e532e95b71c0db3839ebdef3fe8812fca2c upstream. The some platforms (e.g., ARM) initializes their clocks as late_initcalls for some unknown reason. So make sure random_int_secret_init() is run after all of the late_initcalls are run. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14efshlp:Corrected remaining pdma size logicAshutosh Patel
Changes : - Corrected remaining pdma size logic in mmap_dma function bug 1308180 Change-Id: I69331783cb4d0b710c64ac4cd7e74175baa53e41 Reviewed-on: http://git-master/r/239672 Signed-off-by: Ashutosh Patel <ashutoshp@nvidia.com> (cherry picked from commit b3901d71865f4021c67b48055663d122a6f2319f) Reviewed-on: http://git-master/r/249069 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-09-14tegra_pflash: Increase erase and write delay timings of tegra-pflashAshutosh Patel
Change: - Increase erase and write delay timings of tegra-pflash bug 1292129 Change-Id: I6d3d904c5b40371a3f7f3847bca82e2fe02e8f33 Signed-off-by: Ashutosh Patel <ashutoshp@nvidia.com> Reviewed-on: http://git-master/r/235407 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Nitin Sehgal <nsehgal@nvidia.com> Tested-by: Nitin Sehgal <nsehgal@nvidia.com> Reviewed-by: Nate Huang <nhuang@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-09-14arm: tegra: gmi: Fix driver dependencies for devices on gmi bus.Nitin Sehgal
- nor mapping driver, pca gmi & sram driver could be selected independently. - efs & pflash should depend on nor mapping driver. bug 1294819 Change-Id: I8d201f6aad5ec742ff57d2c11a2507b2bc4f5a8d Signed-off-by: Nitin Sehgal <nsehgal@nvidia.com> Reviewed-on: http://git-master/r/235036 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-09-14pflash: tegra pflash driverAshutosh Patel
- Added support for tegra pflash driver bug 1182131 Change-Id: I67167057f288c3e661e8144021a1153985afe484 Signed-off-by: Ashutosh Patel <ashutoshp@nvidia.com> Reviewed-on: http://git-master/r/218099 Reviewed-by: Nitin Sehgal <nsehgal@nvidia.com> Tested-by: Nitin Sehgal <nsehgal@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-09-14chardev: Access control framework for Tegra gmi bus.Ashutosh Patel
-provide exclusive access to gmi bus. -provide priority based access. -support Asynchronous & synchronous requests. bug 1047323 Change-Id: I0a630a9120e5a2abd3b0ff6b1e3250005b1136e1 Signed-off-by: Nitin Sehgal <nsehgal@nvidia.com> Signed-off-by: Ashutosh Patel <ashutoshp@nvidia.com> Reviewed-on: http://git-master/r/189918 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-09-14char: tegra: Character device interface for tegra gmi busAshutosh Patel
Tegra gmi bus supports multiple devices to be connected to the bus. This drivers add character device interface for device connected on the bus. Change-Id:Ie1de58e5108e55b1e058f4871541c734ee70f4ff Signed-off-by: Nitin Sehgal <nsehgal@nvidia.com> Signed-off-by: Ashutosh Patel <ashutoshp@nvidia.com> Reviewed-on: http://git-master/r/191632 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
2013-09-14tegra: efs: m2601: Add EFS driver support for M2601Ashutosh Patel
Changes: - Added EFS driver support for M2601 board bug 1049391 Change-Id: I0637727136c88480203f9a6d3b437da7215630c1 Signed-off-by: Ashutosh Patel <ashutoshp@nvidia.com> Reviewed-on: http://git-master/r/190267 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-09-14char: agp: treat compile warning as errorschowdary
-enable warnings as errors compilation flag bug 949219 Change-Id: I47e2df835985f341ebccdad95f53b4e6f7763e39 Signed-off-by: schowdary <schowdary@nvidia.com> Reviewed-on: http://git-master/r/118017 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Rebase-Id: R6cebd3290fcdf2201acd6a232cc884b417bc4cfb
2013-09-14Merge commit 'a88f9e27498afaea615ad3e93af4f26df1f84987' into ↵Dan Willemsen
after-upstream-android Conflicts: arch/arm/common/Kconfig arch/arm/mm/Makefile arch/arm/mm/cache-l2x0.c arch/arm/mm/mmu.c drivers/input/Kconfig drivers/input/Makefile drivers/power/Kconfig kernel/futex.c
2013-08-14virtio: console: return -ENODEV on all read operations after unplugAmit Shah
commit 96f97a83910cdb9d89d127c5ee523f8fc040a804 upstream. If a port gets unplugged while a user is blocked on read(), -ENODEV is returned. However, subsequent read()s returned 0, indicating there's no host-side connection (but not indicating the device went away). This also happened when a port was unplugged and the user didn't have any blocking operation pending. If the user didn't monitor the SIGIO signal, they won't have a chance to find out if the port went away. Fix by returning -ENODEV on all read()s after the port gets unplugged. write() already behaves this way. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio: console: fix raising SIGIO after port unplugAmit Shah
commit 92d3453815fbe74d539c86b60dab39ecdf01bb99 upstream. SIGIO should be sent when a port gets unplugged. It should only be sent to prcesses that have the port opened, and have asked for SIGIO to be delivered. We were clearing out guest_connected before calling send_sigio_to_port(), resulting in a sigio not getting sent to processes. Fix by setting guest_connected to false after invoking the sigio function. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio: console: clean up port data immediately at time of unplugAmit Shah
commit ea3768b4386a8d1790f4cc9a35de4f55b92d6442 upstream. We used to keep the port's char device structs and the /sys entries around till the last reference to the port was dropped. This is actually unnecessary, and resulted in buggy behaviour: 1. Open port in guest 2. Hot-unplug port 3. Hot-plug a port with the same 'name' property as the unplugged one This resulted in hot-plug being unsuccessful, as a port with the same name already exists (even though it was unplugged). This behaviour resulted in a warning message like this one: -------------------8<--------------------------------------- WARNING: at fs/sysfs/dir.c:512 sysfs_add_one+0xc9/0x130() (Not tainted) Hardware name: KVM sysfs: cannot create duplicate filename '/devices/pci0000:00/0000:00:04.0/virtio0/virtio-ports/vport0p1' Call Trace: [<ffffffff8106b607>] ? warn_slowpath_common+0x87/0xc0 [<ffffffff8106b6f6>] ? warn_slowpath_fmt+0x46/0x50 [<ffffffff811f2319>] ? sysfs_add_one+0xc9/0x130 [<ffffffff811f23e8>] ? create_dir+0x68/0xb0 [<ffffffff811f2469>] ? sysfs_create_dir+0x39/0x50 [<ffffffff81273129>] ? kobject_add_internal+0xb9/0x260 [<ffffffff812733d8>] ? kobject_add_varg+0x38/0x60 [<ffffffff812734b4>] ? kobject_add+0x44/0x70 [<ffffffff81349de4>] ? get_device_parent+0xf4/0x1d0 [<ffffffff8134b389>] ? device_add+0xc9/0x650 -------------------8<--------------------------------------- Instead of relying on guest applications to release all references to the ports, we should go ahead and unregister the port from all the core layers. Any open/read calls on the port will then just return errors, and an unplug/plug operation on the host will succeed as expected. This also caused buggy behaviour in case of the device removal (not just a port): when the device was removed (which means all ports on that device are removed automatically as well), the ports with active users would clean up only when the last references were dropped -- and it would be too late then to be referencing char device pointers, resulting in oopses: -------------------8<--------------------------------------- PID: 6162 TASK: ffff8801147ad500 CPU: 0 COMMAND: "cat" #0 [ffff88011b9d5a90] machine_kexec at ffffffff8103232b #1 [ffff88011b9d5af0] crash_kexec at ffffffff810b9322 #2 [ffff88011b9d5bc0] oops_end at ffffffff814f4a50 #3 [ffff88011b9d5bf0] die at ffffffff8100f26b #4 [ffff88011b9d5c20] do_general_protection at ffffffff814f45e2 #5 [ffff88011b9d5c50] general_protection at ffffffff814f3db5 [exception RIP: strlen+2] RIP: ffffffff81272ae2 RSP: ffff88011b9d5d00 RFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff880118901c18 RCX: 0000000000000000 RDX: ffff88011799982c RSI: 00000000000000d0 RDI: 3a303030302f3030 RBP: ffff88011b9d5d38 R8: 0000000000000006 R9: ffffffffa0134500 R10: 0000000000001000 R11: 0000000000001000 R12: ffff880117a1cc10 R13: 00000000000000d0 R14: 0000000000000017 R15: ffffffff81aff700 ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018 #6 [ffff88011b9d5d00] kobject_get_path at ffffffff8126dc5d #7 [ffff88011b9d5d40] kobject_uevent_env at ffffffff8126e551 #8 [ffff88011b9d5dd0] kobject_uevent at ffffffff8126e9eb #9 [ffff88011b9d5de0] device_del at ffffffff813440c7 -------------------8<--------------------------------------- So clean up when we have all the context, and all that's left to do when the references to the port have dropped is to free up the port struct itself. Reported-by: chayang <chayang@redhat.com> Reported-by: YOGANANTH SUBRAMANIAN <anantyog@in.ibm.com> Reported-by: FuXiangChun <xfu@redhat.com> Reported-by: Qunfang Zhang <qzhang@redhat.com> Reported-by: Sibiao Luo <sluo@redhat.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio: console: fix race in port_fops_open() and port unplugAmit Shah
commit 671bdea2b9f210566610603ecbb6584c8a201c8c upstream. Between open() being called and processed, the port can be unplugged. Check if this happened, and bail out. A simple test script to reproduce this is: while true; do for i in $(seq 1 100); do echo $i > /dev/vport0p3; done; done; This opens and closes the port a lot of times; unplugging the port while this is happening triggers the bug. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio: console: fix race with port unplug and open/closeAmit Shah
commit 057b82be3ca3d066478e43b162fc082930a746c9 upstream. There's a window between find_port_by_devt() returning a port and us taking a kref on the port, where the port could get unplugged. Fix it by taking the reference in find_port_by_devt() itself. Problem reported and analyzed by Mateusz Guzik. Reported-by: Mateusz Guzik <mguzik@redhat.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio/console: Add pipe_lock/unlock for splice_writeYoshihiro YUNOMAE
commit 2b4fbf029dff5a28d9bf646346dea891ec43398a upstream. Add pipe_lock/unlock for splice_write to avoid oops by following competition: (1) An application gets fds of a trace buffer, virtio-serial, pipe. (2) The application does fork() (3) The processes execute splice_read(trace buffer) and splice_write(virtio-serial) via same pipe. <parent> <child> get fds of a trace buffer, virtio-serial, pipe | fork()----------create--------+ | | splice(read) | ---+ splice(write) | +-- no competition | splice(read) | | splice(write) ---+ | | splice(read) | splice(write) splice(read) ------ competition | splice(write) Two processes share a pipe_inode_info structure. If the child execute splice(read) when the parent tries to execute splice(write), the structure can be broken. Existing virtio-serial driver does not get lock for the structure in splice_write, so this competition will induce oops. <oops messages> BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: [<ffffffff811a6b5f>] splice_from_pipe_feed+0x6f/0x130 PGD 7223e067 PUD 72391067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: lockd bnep bluetooth rfkill sunrpc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_timer snd soundcore pcspkr virtio_net virtio_balloon i2c_piix4 i2c_core microcode uinput floppy CPU: 0 PID: 1072 Comm: compete-test Not tainted 3.10.0ws+ #55 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 task: ffff880071b98000 ti: ffff88007b55e000 task.ti: ffff88007b55e000 RIP: 0010:[<ffffffff811a6b5f>] [<ffffffff811a6b5f>] splice_from_pipe_feed+0x6f/0x130 RSP: 0018:ffff88007b55fd78 EFLAGS: 00010287 RAX: 0000000000000000 RBX: ffff88007b55fe20 RCX: 0000000000000000 RDX: 0000000000001000 RSI: ffff88007a95ba30 RDI: ffff880036f9e6c0 RBP: ffff88007b55fda8 R08: 00000000000006ec R09: ffff880077626708 R10: 0000000000000003 R11: ffffffff8139ca59 R12: ffff88007a95ba30 R13: 0000000000000000 R14: ffffffff8139dd00 R15: ffff880036f9e6c0 FS: 00007f2e2e3a0740(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000018 CR3: 0000000071bd1000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffffffff8139ca59 ffff88007b55fe20 ffff880036f9e6c0 ffffffff8139dd00 ffff8800776266c0 ffff880077626708 ffff88007b55fde8 ffffffff811a6e8e ffff88007b55fde8 ffffffff8139ca59 ffff880036f9e6c0 ffff88007b55fe20 Call Trace: [<ffffffff8139ca59>] ? alloc_buf.isra.13+0x39/0xb0 [<ffffffff8139dd00>] ? virtcons_restore+0x100/0x100 [<ffffffff811a6e8e>] __splice_from_pipe+0x7e/0x90 [<ffffffff8139ca59>] ? alloc_buf.isra.13+0x39/0xb0 [<ffffffff8139d739>] port_fops_splice_write+0xe9/0x140 [<ffffffff8127a3f4>] ? selinux_file_permission+0xc4/0x120 [<ffffffff8139d650>] ? wait_port_writable+0x1b0/0x1b0 [<ffffffff811a6fe0>] do_splice_from+0xa0/0x110 [<ffffffff811a951f>] SyS_splice+0x5ff/0x6b0 [<ffffffff8161facf>] tracesys+0xdd/0xe2 Code: 49 8b 87 80 00 00 00 4c 8d 24 d0 8b 53 04 41 8b 44 24 0c 4d 8b 6c 24 10 39 d0 89 03 76 02 89 13 49 8b 44 24 10 4c 89 e6 4c 89 ff <ff> 50 18 85 c0 0f 85 aa 00 00 00 48 89 da 4c 89 e6 4c 89 ff 41 RIP [<ffffffff811a6b5f>] splice_from_pipe_feed+0x6f/0x130 RSP <ffff88007b55fd78> CR2: 0000000000000018 ---[ end trace 24572beb7764de59 ]--- V2: Fix a locking problem for error V3: Add Reviewed-by lines and stable@ line in sign-off area Signed-off-by: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com> Reviewed-by: Amit Shah <amit.shah@redhat.com> Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Amit Shah <amit.shah@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio/console: Quit from splice_write if pipe->nrbufs is 0Yoshihiro YUNOMAE
commit 68c034fefe20eaf7d5569aae84584b07987ce50a upstream. Quit from splice_write if pipe->nrbufs is 0 for avoiding oops in virtio-serial. When an application was doing splice from a kernel buffer to virtio-serial on a guest, the application received signal(SIGINT). This situation will normally happen, but the kernel executed a kernel panic by oops as follows: BUG: unable to handle kernel paging request at ffff882071c8ef28 IP: [<ffffffff812de48f>] sg_init_table+0x2f/0x50 PGD 1fac067 PUD 0 Oops: 0000 [#1] SMP Modules linked in: lockd sunrpc bnep bluetooth rfkill ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_timer snd microcode virtio_balloon virtio_net pcspkr soundcore i2c_piix4 i2c_core uinput floppy CPU: 1 PID: 908 Comm: trace-cmd Not tainted 3.10.0+ #49 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 task: ffff880071c64650 ti: ffff88007bf24000 task.ti: ffff88007bf24000 RIP: 0010:[<ffffffff812de48f>] [<ffffffff812de48f>] sg_init_table+0x2f/0x50 RSP: 0018:ffff88007bf25dd8 EFLAGS: 00010286 RAX: 0000001fffffffe0 RBX: ffff882071c8ef28 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff880071c8ef48 RBP: ffff88007bf25de8 R08: ffff88007fd15d40 R09: ffff880071c8ef48 R10: ffffea0001c71040 R11: ffffffff8139c555 R12: 0000000000000000 R13: ffff88007506a3c0 R14: ffff88007c862500 R15: ffff880071c8ef00 FS: 00007f0a3646c740(0000) GS:ffff88007fd00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffff882071c8ef28 CR3: 000000007acbb000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff880071c8ef48 ffff88007bf25e20 ffff88007bf25e88 ffffffff8139d6fa ffff88007bf25e28 ffffffff8127a3f4 0000000000000000 0000000000000000 ffff880071c8ef48 0000100000000000 0000000000000003 ffff88007bf25e08 Call Trace: [<ffffffff8139d6fa>] port_fops_splice_write+0xaa/0x130 [<ffffffff8127a3f4>] ? selinux_file_permission+0xc4/0x120 [<ffffffff8139d650>] ? wait_port_writable+0x1b0/0x1b0 [<ffffffff811a6fe0>] do_splice_from+0xa0/0x110 [<ffffffff811a951f>] SyS_splice+0x5ff/0x6b0 [<ffffffff8161f8c2>] system_call_fastpath+0x16/0x1b Code: c1 e2 05 48 89 e5 48 83 ec 10 4c 89 65 f8 41 89 f4 31 f6 48 89 5d f0 48 89 fb e8 8d ce ff ff 41 8d 44 24 ff 48 c1 e0 05 48 01 c3 <48> 8b 03 48 83 e0 fe 48 83 c8 02 48 89 03 48 8b 5d f0 4c 8b 65 RIP [<ffffffff812de48f>] sg_init_table+0x2f/0x50 RSP <ffff88007bf25dd8> CR2: ffff882071c8ef28 ---[ end trace 86323505eb42ea8f ]--- It seems to induce pagefault in sg_init_tabel() when pipe->nrbufs is equal to zero. This may happen in a following situation: (1) The application normally does splice(read) from a kernel buffer, then does splice(write) to virtio-serial. (2) The application receives SIGINT when is doing splice(read), so splice(read) is failed by EINTR. However, the application does not finish the operation. (3) The application tries to do splice(write) without pipe->nrbufs. (4) The virtio-console driver tries to touch scatterlist structure sgl in sg_init_table(), but the region is out of bound. To avoid the case, a kernel should check whether pipe->nrbufs is empty or not when splice_write is executed in the virtio-console driver. V3: Add Reviewed-by lines and stable@ line in sign-off area. Signed-off-by: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com> Reviewed-by: Amit Shah <amit.shah@redhat.com> Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Amit Shah <amit.shah@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11hwrng: bcm2835: fix MODULE_LICENSE tagArnd Bergmann
commit 22e8099f4f6621b8d165e238cdef2a1cf655e159 upstream. The MODULE_LICENSE macro invocation must use either "GPL" or "GPL v2", but not "GPLv2" in order to be detected by the module loader. This fixes the allmodconfig build error: FATAL: modpost: GPL-incompatible module bcm2835-rng.ko uses GPL-only symbol 'platform_driver_unregister' Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Lubomir Rintel <lkundrak@v3.sk> Cc: Dom Cobley <popcornmix@gmail.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Matt Mackall <mpm@selenic.com> Cc: linux-rpi-kernel@lists.infradead.org Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11parisc: agp/parisc-agp: allow binding of user memory to the AGP GARTAlex Ivanov
commit 06f0cce43a32bd2357cea1d8733bba48693d556b upstream. Allow binding of user memory to the AGP GART on systems with HP Quicksilver AGP bus. This resolves 'bind memory failed' error seen in dmesg: [29.365973] [TTM] AGP Bind memory failed. … [29.367030] [drm] Forcing AGP to PCI mode The system doesn't more fail to bind the memory, and hence not falling back to the PCI mode (if other failures aren't detected). This is just a simple write down from the following patches: agp/amd-k7: Allow binding user memory to the AGP GART agp/hp-agp: Allow binding user memory to the AGP GART Signed-off-by: Alex Ivanov <gnidorah@p0n4ik.tk> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-01[ARM] armv6 dcc tty driverArve Hjønnevåg
Signed-off-by: Brian Swetland <swetland@google.com> Signed-off-by: Arve Hjønnevåg <arve@android.com>
2013-07-01Make /dev/mem configurable, as we don't want it.Robert Love
2013-05-24random: fix accounting race condition with lockless irq entropy_count updateJiri Kosina
Commit 902c098a3663 ("random: use lockless techniques in the interrupt path") turned IRQ path from being spinlock protected into lockless cmpxchg-retry update. That commit removed r->lock serialization between crediting entropy bits from IRQ context and accounting when extracting entropy on userspace read path, but didn't turn the r->entropy_count reads/updates in account() to use cmpxchg as well. It has been observed, that under certain circumstances this leads to read() on /dev/urandom to return 0 (EOF), as r->entropy_count gets corrupted and becomes negative, which in turn results in propagating 0 all the way from account() to the actual read() call. Convert the accounting code to be the proper lockless counterpart of what has been partially done by 902c098a3663. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Greg KH <greg@kroah.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24drivers/char/random.c: fix priming of last_dataJarod Wilson
Commit ec8f02da9ea5 ("random: prime last_data value per fips requirements") added priming of last_data per fips requirements. Unfortuantely, it did so in a way that can lead to multiple threads all incrementing nbytes, but only one actually doing anything with the extra data, which leads to some fun random corruption and panics. The fix is to simply do everything needed to prime last_data in a single shot, so there's no window for multiple cpus to increment nbytes -- in fact, we won't even increment or decrement nbytes anymore, we'll just extract the needed EXTRACT_SIZE one time per pool and then carry on with the normal routine. All these changes have been tested across multiple hosts and architectures where panics were previously encoutered. The code changes are are strictly limited to areas only touched when when booted in fips mode. This change should also go into 3.8-stable, to make the myriads of fips users on 3.8.x happy. Signed-off-by: Jarod Wilson <jarod@redhat.com> Tested-by: Jan Stancek <jstancek@redhat.com> Tested-by: Jan Stodola <jstodola@redhat.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Matt Mackall <mpm@selenic.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-23Merge tag 'char-misc-3.10-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver fixes from Greg Kroah-Hartman: "Here are some small char/misc driver fixes for 3.10-rc2. Nothing major here, just a number of fixes for things that people have reported, and a MAINTAINERS update for the recent changes for the hyperv files that went into 3.10-rc1." * tag 'char-misc-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: ttyprintk: Fix NULL pointer deref by setting tty_port ops after initializing port uio: UIO_DMEM_GENIRQ should depend on HAS_DMA MAINTAINERS: update Hyper-V file list mei: bus: Reset event_cb when disabling a device Drivers: hv: Fix a bug in get_vp_index() mei: fix out of array access to me clients array Char: lp, protect LPGETSTATUS with port_mutex dummy-irq: require the user to specify an IRQ number
2013-05-21ttyprintk: Fix NULL pointer deref by setting tty_port ops after initializing ↵Darrick J. Wong
port tty_port_init() zeroes out the tty port, which means that we have to set the ops pointer /after/, not before this call. Otherwise, tty_port_open will crash when it tries to deref ops, which is now a NULL pointer. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-18Merge branch 'devm_no_resource_check' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull devm usage cleanup from Wolfram Sang: "Lately, I have been experimenting how to improve the devm interface to make writing device drivers easier and less error prone while also getting rid of its subtle issues. I think it has more potential but still needs work and definately conistency, especiall in its usage. The first thing I come up with is a low hanging fruit regarding devm_ioremap_resouce(). This function already checks if the passed resource is valid and gives an error message if not. So, we can remove similar checks from the drivers and get rid of a bit of code and a number of inconsistent error strings. This series only removes the unneeded check iff devm_ioremap_resource follows platform_get_resource directly. The previous version tried to shuffle code if needed, too, what lead to an embarrasing bug. It turned out to me that shuffling code for all cases found will make the automated script too complex, so I am unsure if an automated cleanup is the proper tool for this case. Removing the easy stuff seems worthwhile to me, though. Despite various architectures and platform dependencies, I managed to compile test 45 out of 57 modified files locally using heuristics and defconfigs." Pulled because: 296 deletions, 0 additions. * 'devm_no_resource_check' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (33 commits) sound/soc/kirkwood: don't check resource with devm_ioremap_resource sound/soc/fsl: don't check resource with devm_ioremap_resource arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource arch/arm/plat-samsung: don't check resource with devm_ioremap_resource arch/arm/mach-tegra: don't check resource with devm_ioremap_resource drivers/watchdog: don't check resource with devm_ioremap_resource drivers/w1/masters: don't check resource with devm_ioremap_resource drivers/video/omap2/dss: don't check resource with devm_ioremap_resource drivers/video/omap2: don't check resource with devm_ioremap_resource drivers/usb/phy: don't check resource with devm_ioremap_resource drivers/usb/host: don't check resource with devm_ioremap_resource drivers/usb/gadget: don't check resource with devm_ioremap_resource drivers/usb/chipidea: don't check resource with devm_ioremap_resource drivers/thermal: don't check resource with devm_ioremap_resource drivers/staging/nvec: don't check resource with devm_ioremap_resource drivers/staging/dwc2: don't check resource with devm_ioremap_resource drivers/spi: don't check resource with devm_ioremap_resource drivers/rtc: don't check resource with devm_ioremap_resource drivers/pwm: don't check resource with devm_ioremap_resource drivers/pinctrl: don't check resource with devm_ioremap_resource ...
2013-05-16Char: lp, protect LPGETSTATUS with port_mutexsalina@us.ibm.com
The patch fixes a problem in the lp driver that can cause oopses as follows: process A: calls lp_write, which in turn calls parport_ieee1284_write_compat, and that invokes parport_wait_peripheral process B: meanwhile does an ioctl(LPGETSTATUS), which call lp_release_parport when done. This function will set physport->cad = NULL. process A: parport_wait_peripheral tries to dereference physport->cad and dies So, protect that code with the port_mutex in order to protect against simultaneous calls to lp_read/lp_write. Similar protection is probably required for ioctl(LPRESET)... This patch was done by IBM a while back and we (at suse) have that since at least 2004 in our repos. Let's make it upstream. Signed-off-by: okir@suse.de Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-16ipmi: ipmi_devintf: compat_ioctl method fails to take ipmi_mutexBenjamin LaHaise
When a 32 bit version of ipmitool is used on a 64 bit kernel, the ipmi_devintf code fails to correctly acquire ipmi_mutex. This results in incomplete data being retrieved in some cases, or other possible failures. Add a wrapper around compat_ipmi_ioctl() to take ipmi_mutex to fix this. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-16ipmi: Improve error messages on failed irq enableCorey Minyard
When the interrupt enable message returns an error, the messages are not entirely accurate nor helpful. So improve them. Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-16drivers/char/ipmi: memcpy, need additional 2 bytes to avoid memory overflowChen Gang
When calling memcpy, read_data and write_data need additional 2 bytes. write_data: for checking: "if (size > IPMI_MAX_MSG_LENGTH)" for operating: "memcpy(bt->write_data + 3, data + 1, size - 1)" read_data: for checking: "if (msg_len < 3 || msg_len > IPMI_MAX_MSG_LENGTH)" for operating: "memcpy(data + 2, bt->read_data + 4, msg_len - 2)" Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-16drivers: char: ipmi: Replaced kmalloc and strcpy with kstrdupAlexandru Gheorghiu
Replaced calls to kmalloc followed by strcpy with a sincle call to kstrdup. Patch found using coccinelle. Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-12drivers/char/hw_random: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07char: add aio_{read,write} to /dev/{null,zero}Zach Brown
These are handy for measuring the cost of the aio infrastructure with operations that do very little and complete immediately. Signed-off-by: Zach Brown <zab@redhat.com> Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-05rtc: single_open() leaksAl Viro
Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-05ds1620: single_open() leakAl Viro
2013-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - XTS mode optimisation for twofish/cast6/camellia/aes on x86 - AVX2/x86_64 implementation for blowfish/twofish/serpent/camellia - SSSE3/AVX/AVX2 optimisations for sha256/sha512 - Added driver for SAHARA2 crypto accelerator - Fix for GMAC when used in non-IPsec secnarios - Added generic CMAC implementation (including IPsec glue) - IP update for crypto/atmel - Support for more than one device in hwrng/timeriomem - Added Broadcom BCM2835 RNG driver - Misc fixes * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (59 commits) crypto: caam - fix job ring cleanup code crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of camellia cipher crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipher crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher crypto: tcrypt - add async cipher speed tests for blowfish crypto: testmgr - extend camellia test-vectors for camellia-aesni/avx2 crypto: aesni_intel - fix Kconfig problem with CRYPTO_GLUE_HELPER_X86 crypto: aesni_intel - add more optimized XTS mode for x86-64 crypto: x86/camellia-aesni-avx - add more optimized XTS code crypto: cast6-avx: use new optimized XTS code crypto: x86/twofish-avx - use optimized XTS code crypto: x86 - add more optimized XTS-mode for serpent-avx xfrm: add rfc4494 AES-CMAC-96 support crypto: add CMAC support to CryptoAPI crypto: testmgr - add empty test vectors for null ciphers crypto: testmgr - add AES GMAC test vectors crypto: gcm - fix rfc4543 to handle async crypto correctly crypto: gcm - make GMAC work when dst and src are different hwrng: timeriomem - added devicetree hooks ...
2013-05-02Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio & lguest updates from Rusty Russell: "Lots of virtio work which wasn't quite ready for last merge window. Plus I dived into lguest again, reworking the pagetable code so we can move the switcher page: our fixmaps sometimes take more than 2MB now..." Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename. Hopefully correctly resolved. * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits) caif_virtio: Remove bouncing email addresses lguest: improve code readability in lg_cpu_start. virtio-net: fill only rx queues which are being used lguest: map Switcher below fixmap. lguest: cache last cpu we ran on. lguest: map Switcher text whenever we allocate a new pagetable. lguest: don't share Switcher PTE pages between guests. lguest: expost switcher_pages array (as lg_switcher_pages). lguest: extract shadow PTE walking / allocating. lguest: make check_gpte et. al return bool. lguest: assume Switcher text is a single page. lguest: rename switcher_page to switcher_pages. lguest: remove RESERVE_MEM constant. lguest: check vaddr not pgd for Switcher protection. lguest: prepare to make SWITCHER_ADDR a variable. virtio: console: replace EMFILE with EBUSY for already-open port virtio-scsi: reset virtqueue affinity when doing cpu hotplug virtio-scsi: introduce multiqueue support virtio-scsi: push vq lock/unlock into virtscsi_vq_done virtio-scsi: pass struct virtio_scsi to virtqueue completion function ...
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01proc: Supply a function to remove a proc entry by PDEDavid Howells
Supply a function (proc_remove()) to remove a proc entry (and any subtree rooted there) by proc_dir_entry pointer rather than by name and (optionally) root dir entry pointer. This allows us to eliminate all remaining pde->name accesses outside of procfs. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Grant Likely <grant.likely@linaro.or> cc: linux-acpi@vger.kernel.org cc: openipmi-developer@lists.sourceforge.net cc: devicetree-discuss@lists.ozlabs.org cc: linux-pci@vger.kernel.org cc: netdev@vger.kernel.org cc: netfilter-devel@vger.kernel.org cc: alsa-devel@alsa-project.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
