path: root/drivers/char/agp/sgi-agp.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-08-03agp: kill phys_to_gart() and gart_to_phys()David Woodhouse
There seems to be no reason for these -- they're a 1:1 mapping on all platforms. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Switch mask_memory() method to take address argument again, not pageDavid Woodhouse
In commit 07613ba2 ("agp: switch AGP to use page array instead of unsigned long array") we switched the mask_memory() method to take a 'struct page *' instead of an address. This is painful, because in some cases it has to be an IOMMU-mapped virtual bus address (in fact, shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and we just happen to get lucky most of the time?) Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-19agp: switch AGP to use page array instead of unsigned long arrayDave Airlie
This switches AGP to use an array of pages for tracking the pages allocated to the GART. This should enable GEM on PAE to work a lot better as we can pass highmem pages to the PAT code and it will do the right thing with them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-07-27agp: don't lock pagesNick Piggin
AGP should not need to lock pages. They are not protecting any race because there is no lock_page calls, only SetPageLocked. This is causing hangs with d00806b183152af6d24f46f0c33f14162ca1262a. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-04-26[AGPGART] Fix sparse warning in sgi-agp.cDave Jones
drivers/char/agp/sgi-agp.c:51:10: warning: Using plain integer as NULL pointer Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-27[AGPGART] fix compile errorsRyusuke Konishi
This fixes the following compile failures of agpgart drivers. These errors were inserted by the recent AGPGART constification patch. drivers/char/agp/uninorth-agp.c:492: error: expected '{' before 'const' drivers/char/agp/uninorth-agp.c:517: error: expected '{' before 'const' drivers/char/agp/uninorth-agp.c: In function 'agp_uninorth_probe': drivers/char/agp/uninorth-agp.c:634: error: 'u3_agp_driver' undeclared (first use in this function) drivers/char/agp/uninorth-agp.c:634: error: (Each undeclared identifier is reported only once drivers/char/agp/uninorth-agp.c:634: error: for each function it appears in.) drivers/char/agp/uninorth-agp.c:636: error: 'uninorth_agp_driver' undeclared (first use in this function) Signed-off-by: Ryusuke Konishi <ryusuke@osrg.net> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-01-02[AGPGART] drivers/char/agp/sgi-agp.c: check kmalloc() return valueakpm@osdl.org
drivers/char/agp/sgi-agp.c: check kmalloc() return value Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-06-27[PATCH] Remove redundant NULL checks before [kv]free - in drivers/Jesper Juhl
Remove redundant NULL chck before kfree + tiny CodingStyle cleanup for drivers/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
2005-11-04[AGPGART] Fix up sgi-agp bug with no devices on bus.Dave Jones
Signed-off-by: Eric Kunze <ekunze@sgi.com> Signed-off-by: Dave Jones <davej@redhat.com>
2005-09-09[IA64] Need to include <asm/sn/io.h> in a few more places.Tony Luck
Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-07[PATCH] sgi-agp: fixes a problem with accessing GART memory in ↵Michael Werner
sgi_tioca_insert_memory and sgi_tioca_remove_memory This patch fixes a problem with accessing GART memory in sgi_tioca_insert_memory and sgi_tioca_remove_memory. sgi-agp.c | 12 +++++++++--- 1 files changed, 9 insertions(+), 3 deletions(-) Signed-off-by: Mike Werner <werner@sgi.com> Signed-off-by: Dave Jones <davej@redhat.com>
