This is the 4.4.288 stable release
[ Upstream commit 22ca9f4aaf431a9413dcc115dd590123307f274f ]
crypto_shash_alg_has_setkey() is implemented by testing whether the
.setkey() member of a struct shash_alg points to the default version,
called shash_no_setkey(). As crypto_shash_alg_has_setkey() is a static
inline, this requires shash_no_setkey() to be exported to modules.
Unfortunately, when building with CFI, function pointers are routed
via CFI stubs which are private to each module (or to the kernel proper)
and so this function pointer comparison may fail spuriously.
Let's fix this by turning crypto_shash_alg_has_setkey() into an out of
line function.
Cc: Sami Tolvanen <samitolvanen@google.com>
Cc: Eric Biggers <ebiggers@kernel.org>
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
Reviewed-by: Eric Biggers <ebiggers@google.com>
Reviewed-by: Sami Tolvanen <samitolvanen@google.com>
This is the 4.4.237 stable release
commit 34c86f4c4a7be3b3e35aa48bd18299d4c756064d upstream.
The locking in af_alg_release_parent is broken as the BH socket
lock can only be taken if there is a code-path to handle the case
where the lock is owned by process-context. Instead of adding
such handling, we can fix this by changing the ref counts to
atomic_t.
This patch also modifies the main refcnt to include both normal
and nokey sockets. This way we don't have to fudge the nokey
ref count when a socket changes from nokey to normal.
Credits go to Mauricio Faria de Oliveira who diagnosed this bug
and sent a patch for it:
https://lore.kernel.org/linux-crypto/20200605161657.535043-1-mfo@canonical.com/
Reported-by: Brian Moyles <bmoyles@netflix.com>
Reported-by: Mauricio Faria de Oliveira <mfo@canonical.com>
Fixes: 37f96694cf73 ("crypto: af_alg - Use bh_lock_sock in...")
Cc: <stable@vger.kernel.org>
commit 77251e41f89a813b4090f5199442f217bbf11297 upstream.
When a crypto template needs to be instantiated, CRYPTO_MSG_ALG_REQUEST
is sent to crypto_chain. cryptomgr_schedule_probe() handles this by
starting a thread to instantiate the template, then waiting for this
thread to complete via crypto_larval::completion.
This can deadlock because instantiating the template may require loading
modules, and this (apparently depending on userspace) may need to wait
for the crc-t10dif module (lib/crc-t10dif.c) to be loaded. But
crc-t10dif's module_init function uses crypto_register_notifier() and
therefore takes crypto_chain.rwsem for write. That can't proceed until
the notifier callback has finished, as it holds this semaphore for read.
Fix this by removing the wait on crypto_larval::completion from within
cryptomgr_schedule_probe(). It's actually unnecessary because
crypto_alg_mod_lookup() calls crypto_larval_wait() itself after sending
CRYPTO_MSG_ALG_REQUEST.
This only actually became a problem in v4.20 due to commit b76377543b73
("crc-t10dif: Pick better transform if one becomes available"), but the
unnecessary wait was much older.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=207159
Reported-by: Mike Gerow <gerow@google.com>
Fixes: 398710379f51 ("crypto: algapi - Move larval completion into algboss")
Cc: <stable@vger.kernel.org> # v3.6+
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Reported-by: Kai Lüke <kai@kinvolk.io>
commit e68503bd6836ba765dc8e0ee77ea675fedc07e41 upstream
Generalise system_verify_data() to provide access to internal content
through a callback. This allows all the PKCS#7 stuff to be hidden inside
this function and removed from the PE file parser and the PKCS#7 test key.
If external content is not required, NULL should be passed as data to the
function. If the callback is not required, that can be set to NULL.
The function is now called verify_pkcs7_signature() to contrast with
verify_pefile_signature() and the definitions of both have been moved into
linux/verification.h along with the key_being_used_for enum.
commit 41c89b64d7184a780f12f2cccdabe65cb2408893 upstream
This option creates IMA MOK and blacklist keyrings. IMA MOK is an
intermediate keyring that sits between .system and .ima keyrings,
effectively forming a simple CA hierarchy. To successfully import a key
into .ima_mok it must be signed by a key which CA is in .system keyring.
On turn any key that needs to go in .ima keyring must be signed by CA in
either .system or .ima_mok keyrings. IMA MOK is empty at kernel boot.
IMA blacklist keyring contains all revoked IMA keys. It is consulted
before any other keyring. If the search is successful the requested
operation is rejected and error is returned to the caller.
Signed-off-by: Petko Manolov <petkan@mip-labs.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 1a263ae60b04de959d9ce9caea4889385eefcc7b upstream.
gcc-10 has started warning about conflicting types for a few new
built-in functions, particularly 'free()'.
This results in warnings like:
crypto/xts.c:325:13: warning: conflicting types for built-in function ‘free’; expected ‘void(void *)’ [-Wbuiltin-declaration-mismatch]
because the crypto layer had its local freeing functions called
'free()'.
Gcc-10 is in the wrong here, since that function is marked 'static', and
thus there is no chance of confusion with any standard library function
namespace.
But the simplest thing to do is to just use a different name here, and
avoid this gcc mis-feature.
[ Side note: gcc knowing about 'free()' is in itself not the
mis-feature: the semantics of 'free()' are special enough that a
compiler can validly do special things when seeing it.
So the mis-feature here is that gcc thinks that 'free()' is some
restricted name, and you can't shadow it as a local static function.
Making the special 'free()' semantics be a function attribute rather
than tied to the name would be the much better model ]
Nowdays, we trigger a oops:
kasan: GPF could be caused by NULL-ptr deref or user memory accessgeneral protection fault: 0000 [#1] SMP KASAN
Call Trace:
[<ffffffff81a26fb1>] skcipher_recvmsg_async+0x3f1/0x1400 x86/../crypto/algif_skcipher.c:543
[<ffffffff81a28053>] skcipher_recvmsg+0x93/0x7f0 x86/../crypto/algif_skcipher.c:723
[<ffffffff823e43a4>] sock_recvmsg_nosec x86/../net/socket.c:702 [inline]
[<ffffffff823e43a4>] sock_recvmsg x86/../net/socket.c:710 [inline]
[<ffffffff823e43a4>] sock_recvmsg+0x94/0xc0 x86/../net/socket.c:705
[<ffffffff823e464b>] sock_read_iter+0x27b/0x3a0 x86/../net/socket.c:787
[<ffffffff817f479b>] aio_run_iocb+0x21b/0x7a0 x86/../fs/aio.c:1520
[<ffffffff817f57c9>] io_submit_one x86/../fs/aio.c:1630 [inline]
[<ffffffff817f57c9>] do_io_submit+0x6b9/0x10b0 x86/../fs/aio.c:1688
[<ffffffff817f902d>] SYSC_io_submit x86/../fs/aio.c:1713 [inline]
[<ffffffff817f902d>] SyS_io_submit+0x2d/0x40 x86/../fs/aio.c:1710
[<ffffffff828b33c3>] tracesys_phase2+0x90/0x95
In skcipher_recvmsg_async, we use '!sreq->tsg' to determine does we
calloc fail. However, kcalloc may return ZERO_SIZE_PTR, and with this,
the latter sg_init_table will trigger the bug. Fix it be use ZERO_OF_NULL_PTR.
This function was introduced with ' commit a596999b7ddf ("crypto:
algif - change algif_skcipher to be asynchronous")', and has been removed
with 'commit e870456d8e7c ("crypto: algif_skcipher - overhaul memory
management")'.
Signed-off-by: yangerkun <yangerkun@huawei.com>
commit 73669cc556462f4e50376538d77ee312142e8a8a upstream.
The function crypto_spawn_alg is racy because it drops the lock
before shooting the dying algorithm. The algorithm could disappear
altogether before we shoot it.
This patch fixes it by moving the shooting into the locked section.
Fixes: 6bfd48096ff8 ("[CRYPTO] api: Added spawns")
commit e8d998264bffade3cfe0536559f712ab9058d654 upstream.
We should not be modifying the original request's MAY_SLEEP flag
upon completion. It makes no sense to do so anyway.
Reported-by: Eric Biggers <ebiggers@kernel.org>
Fixes: 5068c7a883d1 ("crypto: pcrypt - Add pcrypt crypto...")
Tested-by: Eric Biggers <ebiggers@kernel.org>
commit 7db3b61b6bba4310f454588c2ca6faf2958ad79f upstream.
We need to check whether spawn->alg is NULL under lock as otherwise
the algorithm could be removed from under us after we have checked
it and found it to be non-NULL. This could cause us to remove the
spawn from a non-existent list.
Fixes: 7ede5a5ba55a ("crypto: api - Fix crypto_drop_spawn crash...")
[ Upstream commit 07bfd9bdf568a38d9440c607b72342036011f727 ]
On module unload of pcrypt we must unregister the crypto algorithms
first and then tear down the padata structure. As otherwise the
crypto algorithms are still alive and can be used while the padata
structure is being freed.
commit 37f96694cf73ba116993a9d2d99ad6a75fa7fdb0 upstream.
As af_alg_release_parent may be called from BH context (most notably
due to an async request that only completes after socket closure,
or as reported here because of an RCU-delayed sk_destruct call), we
must use bh_lock_sock instead of lock_sock.
Reported-by: syzbot+c2f1558d49e25cc36e5e@syzkaller.appspotmail.com
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Fixes: c840ac6af3f8 ("crypto: af_alg - Disallow bind/setkey/...")
[ Upstream commit f990f7fb58ac8ac9a43316f09a48cff1a49dda42 ]
Fix an unaligned memory access in tgr192_transform() by using the
unaligned access helpers.
Fixes: 06ace7a9bafe ("[CRYPTO] Use standard byte order macros wherever possible")
[ Upstream commit b1e3874c75ab15288f573b3532e507c37e8e7656 ]
Passing string 'name' as the format specifier is potentially hazardous
because name could (although very unlikely to) have a format specifier
embedded in it causing issues when parsing the non-existent arguments
to these. Follow best practice by using the "%s" format string for
the string 'name'.
Cleans up clang warning:
crypto/pcrypt.c:397:40: warning: format string is not a string literal
(potentially insecure) [-Wformat-security]
Fixes: a3fb1e330dd2 ("pcrypt: Added sysfs interface to pcrypt")
commit ffdde5932042600c6807d46c1550b28b0db6a3bc upstream.
In crypto_report, a new skb is created via nlmsg_new(). This skb should
be released if crypto_report_alg() fails.
Fixes: a38f7907b926 ("crypto: Add userspace configuration API")
Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com>
[ Upstream commit 0ac6b8fb23c724b015d9ca70a89126e8d1563166 ]
CRYPTO_MSG_GETALG in NLM_F_DUMP mode sometimes doesn't return all
registered crypto algorithms, because it doesn't support incremental
dumps. crypto_dump_report() only permits itself to be called once, yet
the netlink subsystem allocates at most ~64 KiB for the skb being dumped
to. Thus only the first recvmsg() returns data, and it may only include
a subset of the crypto algorithms even if the user buffer passed to
recvmsg() is large enough to hold all of them.
Fix this by using one of the arguments in the netlink_callback structure
to keep track of the current position in the algorithm list. Then
userspace can do multiple recvmsg() on the socket after sending the dump
request. This is the way netlink dumps work elsewhere in the kernel;
it's unclear why this was different (probably just an oversight).
Also fix an integer overflow when calculating the dump buffer size hint.
commit 5c6bc4dfa515738149998bb0db2481a4fdead979 upstream.
Changing ghash_mod_init() to be subsys_initcall made it start running
before the alignment fault handler has been installed on ARM. In kernel
builds where the keys in the ghash test vectors happened to be
misaligned in the kernel image, this exposed the longstanding bug that
ghash_setkey() is incorrectly casting the key buffer (which can have any
alignment) to be128 for passing to gf128mul_init_4k_lle().
Fix this by memcpy()ing the key to a temporary buffer.
Don't fix it by setting an alignmask on the algorithm instead because
that would unnecessarily force alignment of the data too.
Fixes: 2cdc6899a88e ("crypto: ghash - Add GHASH digest algorithm for GCM")
Reported-by: Peter Robinson <pbrobinson@gmail.com>
Cc: stable@vger.kernel.org
Tested-by: Peter Robinson <pbrobinson@gmail.com>
commit 21d4120ec6f5b5992b01b96ac484701163917b63 upstream.
Michal Suchanek reported [1] that running the pcrypt_aead01 test from
LTP [2] in a loop and holding Ctrl-C causes a NULL dereference of
alg->cra_users.next in crypto_remove_spawns(), via crypto_del_alg().
The test repeatedly uses CRYPTO_MSG_NEWALG and CRYPTO_MSG_DELALG.
The crash occurs when the instance that CRYPTO_MSG_DELALG is trying to
unregister isn't a real registered algorithm, but rather is a "test
larval", which is a special "algorithm" added to the algorithms list
while the real algorithm is still being tested. Larvals don't have
initialized cra_users, so that causes the crash. Normally pcrypt_aead01
doesn't trigger this because CRYPTO_MSG_NEWALG waits for the algorithm
to be tested; however, CRYPTO_MSG_NEWALG returns early when interrupted.
Everything else in the "crypto user configuration" API has this same bug
too, i.e. it inappropriately allows operating on larval algorithms
(though it doesn't look like the other cases can cause a crash).
Fix this by making crypto_alg_match() exclude larval algorithms.
[1] https://lkml.kernel.org/r/20190625071624.27039-1-msuchanek@suse.de
[2] https://github.com/linux-test-project/ltp/blob/20190517/testcases/kernel/crypto/pcrypt_aead01.c
Reported-by: Michal Suchanek <msuchanek@suse.de>
Cc: <stable@vger.kernel.org> # v3.2+
Cc: Steffen Klassert <steffen.klassert@secunet.com>
commit edaf28e996af69222b2cb40455dbb5459c2b875a upstream.
If the user-provided IV needs to be aligned to the algorithm's
alignmask, then skcipher_walk_virt() copies the IV into a new aligned
buffer walk.iv. But skcipher_walk_virt() can fail afterwards, and then
if the caller unconditionally accesses walk.iv, it's a use-after-free.
salsa20-generic doesn't set an alignmask, so currently it isn't affected
by this despite unconditionally accessing walk.iv. However this is more
subtle than desired, and it was actually broken prior to the alignmask
being removed by commit b62b3db76f73 ("crypto: salsa20-generic - cleanup
and convert to skcipher API").
Since salsa20-generic does not update the IV and does not need any IV
alignment, update it to use req->iv instead of walk.iv.
Fixes: 2407d60872dd ("[CRYPTO] salsa20: Salsa20 stream cipher")
commit 5e27f38f1f3f45a0c938299c3a34a2d2db77165a upstream.
If the rfc7539 template is instantiated with specific implementations,
e.g. "rfc7539(chacha20-generic,poly1305-generic)" rather than
"rfc7539(chacha20,poly1305)", then the implementation names end up
included in the instance's cra_name. This is incorrect because it then
prevents all users from allocating "rfc7539(chacha20,poly1305)", if the
highest priority implementations of chacha20 and poly1305 were selected.
Also, the self-tests aren't run on an instance allocated in this way.
Fix it by setting the instance's cra_name from the underlying
algorithms' actual cra_names, rather than from the requested names.
This matches what other templates do.
Fixes: 71ebc4d1b27d ("crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539")
Cc: <stable@vger.kernel.org> # v4.2+
Cc: Martin Willi <martin@strongswan.org>
Reviewed-by: Martin Willi <martin@strongswan.org>
commit f699594d436960160f6d5ba84ed4a222f20d11cd upstream.
GCM instances can be created by either the "gcm" template, which only
allows choosing the block cipher, e.g. "gcm(aes)"; or by "gcm_base",
which allows choosing the ctr and ghash implementations, e.g.
"gcm_base(ctr(aes-generic),ghash-generic)".
However, a "gcm_base" instance prevents a "gcm" instance from being
registered using the same implementations. Nor will the instance be
found by lookups of "gcm". This can be used as a denial of service.
Moreover, "gcm_base" instances are never tested by the crypto
self-tests, even if there are compatible "gcm" tests.
The root cause of these problems is that instances of the two templates
use different cra_names. Therefore, fix these problems by making
"gcm_base" instances set the same cra_name as "gcm" instances, e.g.
"gcm(aes)" instead of "gcm_base(ctr(aes-generic),ghash-generic)".
This requires extracting the block cipher name from the name of the ctr
algorithm. It also requires starting to verify that the algorithms are
really ctr and ghash, not something else entirely. But it would be
bizarre if anyone were actually using non-gcm-compatible algorithms with
gcm_base, so this shouldn't break anyone in practice.
Fixes: d00aa19b507b ("[CRYPTO] gcm: Allow block cipher parameter")
commit 9b40f79c08e81234d759f188b233980d7e81df6c upstream.
Fix to return error code -EINVAL from the invalid alg ivsize error
handling case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
commit 307508d1072979f4435416f87936f87eaeb82054 upstream.
The ->digest() method of crct10dif-generic reads the current CRC value
from the shash_desc context. But this value is uninitialized, causing
crypto_shash_digest() to compute the wrong result. Fix it.
Probably this wasn't noticed before because lib/crc-t10dif.c only uses
crypto_shash_update(), not crypto_shash_digest(). Likewise,
crypto_shash_digest() is not yet tested by the crypto self-tests because
those only test the ahash API which only uses shash init/update/final.
This bug was detected by my patches that improve testmgr to fuzz
algorithms against their generic implementation.
Fixes: 2d31e518a428 ("crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework")
Cc: <stable@vger.kernel.org> # v3.11+
Cc: Tim Chen <tim.c.chen@linux.intel.com>
commit 678cce4019d746da6c680c48ba9e6d417803e127 upstream.
The x86_64 implementation of Poly1305 produces the wrong result on some
inputs because poly1305_4block_avx2() incorrectly assumes that when
partially reducing the accumulator, the bits carried from limb 'd4' to
limb 'h0' fit in a 32-bit integer. This is true for poly1305-generic
which processes only one block at a time. However, it's not true for
the AVX2 implementation, which processes 4 blocks at a time and
therefore can produce intermediate limbs about 4x larger.
Fix it by making the relevant calculations use 64-bit arithmetic rather
than 32-bit. Note that most of the carries already used 64-bit
arithmetic, but the d4 -> h0 carry was different for some reason.
To be safe I also made the same change to the corresponding SSE2 code,
though that only operates on 1 or 2 blocks at a time. I don't think
it's really needed for poly1305_block_sse2(), but it doesn't hurt
because it's already x86_64 code. It *might* be needed for
poly1305_2block_sse2(), but overflows aren't easy to reproduce there.
This bug was originally detected by my patches that improve testmgr to
fuzz algorithms against their generic implementation. But also add a
test vector which reproduces it directly (in the AVX2 case).
Fixes: b1ccc8f4b631 ("crypto: poly1305 - Add a four block AVX2 variant for x86_64")
Fixes: c70f4abef07a ("crypto: poly1305 - Add a SSE2 SIMD variant for x86_64")
Cc: <stable@vger.kernel.org> # v4.3+
Cc: Jason A. Donenfeld <Jason@zx2c4.com>
commit 251b7aea34ba3c4d4fdfa9447695642eb8b8b098 upstream.
The memcpy()s in the PCBC implementation use walk->iv as both the source
and destination, which has undefined behavior. These memcpy()'s are
actually unneeded, because walk->iv is already used to hold the previous
plaintext block XOR'd with the previous ciphertext block. Thus,
walk->iv is already updated to its final value.
So remove the broken and unnecessary memcpy()s.
Fixes: 91652be5d1b9 ("[CRYPTO] pcbc: Add Propagated CBC template")
Cc: <stable@vger.kernel.org> # v2.6.21+
Signed-off-by: Maxim Zhukov <mussitantesmortem@gmail.com>
commit 77568e535af7c4f97eaef1e555bf0af83772456c upstream.
Hash algorithms with an alignmask set, e.g. "xcbc(aes-aesni)" and
"michael_mic", fail the improved hash tests because they sometimes
produce the wrong digest. The bug is that in the case where a
scatterlist element crosses pages, not all the data is actually hashed
because the scatterlist walk terminates too early. This happens because
the 'nbytes' variable in crypto_hash_walk_done() is assigned the number
of bytes remaining in the page, then later interpreted as the number of
bytes remaining in the scatterlist element. Fix it.
Fixes: 900a081f6912 ("crypto: ahash - Fix early termination in hash walk")
commit 8f9c469348487844328e162db57112f7d347c49f upstream.
Keys for "authenc" AEADs are formatted as an rtattr containing a 4-byte
'enckeylen', followed by an authentication key and an encryption key.
crypto_authenc_extractkeys() parses the key to find the inner keys.
However, it fails to consider the case where the rtattr's payload is
longer than 4 bytes but not 4-byte aligned, and where the key ends
before the next 4-byte aligned boundary. In this case, 'keylen -=
RTA_ALIGN(rta->rta_len);' underflows to a value near UINT_MAX. This
causes a buffer overread and crash during crypto_ahash_setkey().
Fix it by restricting the rtattr payload to the expected size.
Reproducer using AF_ALG:
#include <linux/if_alg.h>
#include <linux/rtnetlink.h>
#include <sys/socket.h>
int main()
int fd;
struct sockaddr_alg addr = {
.salg_type = "aead",
.salg_name = "authenc(hmac(sha256),cbc(aes))",
struct {
struct rtattr attr;
__be32 enckeylen;
char keys[1];
} __attribute__((packed)) key = {
.attr.rta_len = sizeof(key),
.attr.rta_type = 1 /* CRYPTO_AUTHENC_KEYA_PARAM */,
fd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(fd, (void *)&addr, sizeof(addr));
setsockopt(fd, SOL_ALG, ALG_SET_KEY, &key, sizeof(key));
It caused:
BUG: unable to handle kernel paging request at ffff88007ffdc000
PGD 2e01067 P4D 2e01067 PUD 2e04067 PMD 2e05067 PTE 0
Oops: 0000 [#1] SMP
CPU: 0 PID: 883 Comm: authenc Not tainted 4.20.0-rc1-00108-g00c9fe37a7f27 #13
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-20181126_142135-anatol 04/01/2014
RIP: 0010:sha256_ni_transform+0xb3/0x330 arch/x86/crypto/sha256_ni_asm.S:155
Call Trace:
sha256_ni_finup+0x10/0x20 arch/x86/crypto/sha256_ssse3_glue.c:321
crypto_shash_finup+0x1a/0x30 crypto/shash.c:178
shash_digest_unaligned+0x45/0x60 crypto/shash.c:186
crypto_shash_digest+0x24/0x40 crypto/shash.c:202
hmac_setkey+0x135/0x1e0 crypto/hmac.c:66
crypto_shash_setkey+0x2b/0xb0 crypto/shash.c:66
shash_async_setkey+0x10/0x20 crypto/shash.c:223
crypto_ahash_setkey+0x2d/0xa0 crypto/ahash.c:202
crypto_authenc_setkey+0x68/0x100 crypto/authenc.c:96
crypto_aead_setkey+0x2a/0xc0 crypto/aead.c:62
aead_setkey+0xc/0x10 crypto/algif_aead.c:526
alg_setkey crypto/af_alg.c:223 [inline]
alg_setsockopt+0xfe/0x130 crypto/af_alg.c:256
__sys_setsockopt+0x6d/0xd0 net/socket.c:1902
__do_sys_setsockopt net/socket.c:1913 [inline]
__se_sys_setsockopt net/socket.c:1910 [inline]
__x64_sys_setsockopt+0x1f/0x30 net/socket.c:1910
do_syscall_64+0x4a/0x180 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fixes: e236d4a89a2f ("[CRYPTO] authenc: Move enckeylen into key itself")
Cc: <stable@vger.kernel.org> # v2.6.25+
commit a7773363624b034ab198c738661253d20a8055c2 upstream.
Authencesn template in decrypt path unconditionally calls aead_request_complete
after ahash_verify which leads to following kernel panic in after decryption.
[ 338.539800] BUG: unable to handle kernel NULL pointer dereference at 0000000000000004
[ 338.548372] PGD 0 P4D 0
[ 338.551157] Oops: 0000 [#1] SMP PTI
[ 338.554919] CPU: 0 PID: 0 Comm: swapper/0 Kdump: loaded Tainted: G W I 4.19.7+ #13
[ 338.564431] Hardware name: Supermicro X8ST3/X8ST3, BIOS 2.0 07/29/10
[ 338.572212] RIP: 0010:esp_input_done2+0x350/0x410 [esp4]
[ 338.578030] Code: ff 0f b6 68 10 48 8b 83 c8 00 00 00 e9 8e fe ff ff 8b 04 25 04 00 00 00 83 e8 01 48 98 48 8b 3c c5 10 00 00 00 e9 f7 fd ff ff <8b> 04 25 04 00 00 00 83 e8 01 48 98 4c 8b 24 c5 10 00 00 00 e9 3b
[ 338.598547] RSP: 0018:ffff911c97803c00 EFLAGS: 00010246
[ 338.604268] RAX: 0000000000000002 RBX: ffff911c4469ee00 RCX: 0000000000000000
[ 338.612090] RDX: 0000000000000000 RSI: 0000000000000130 RDI: ffff911b87c20400
[ 338.619874] RBP: 0000000000000000 R08: ffff911b87c20498 R09: 000000000000000a
[ 338.627610] R10: 0000000000000001 R11: 0000000000000004 R12: 0000000000000000
[ 338.635402] R13: ffff911c89590000 R14: ffff911c91730000 R15: 0000000000000000
[ 338.643234] FS: 0000000000000000(0000) GS:ffff911c97800000(0000) knlGS:0000000000000000
[ 338.652047] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 338.658299] CR2: 0000000000000004 CR3: 00000001ec20a000 CR4: 00000000000006f0
[ 338.666382] Call Trace:
[ 338.669051] <IRQ>
[ 338.671254] esp_input_done+0x12/0x20 [esp4]
[ 338.675922] chcr_handle_resp+0x3b5/0x790 [chcr]
[ 338.680949] cpl_fw6_pld_handler+0x37/0x60 [chcr]
[ 338.686080] chcr_uld_rx_handler+0x22/0x50 [chcr]
[ 338.691233] uldrx_handler+0x8c/0xc0 [cxgb4]
[ 338.695923] process_responses+0x2f0/0x5d0 [cxgb4]
[ 338.701177] ? bitmap_find_next_zero_area_off+0x3a/0x90
[ 338.706882] ? matrix_alloc_area.constprop.7+0x60/0x90
[ 338.712517] ? apic_update_irq_cfg+0x82/0xf0
[ 338.717177] napi_rx_handler+0x14/0xe0 [cxgb4]
[ 338.722015] net_rx_action+0x2aa/0x3e0
[ 338.726136] __do_softirq+0xcb/0x280
[ 338.730054] irq_exit+0xde/0xf0
[ 338.733504] do_IRQ+0x54/0xd0
[ 338.736745] common_interrupt+0xf/0xf
Fixes: 104880a6b470 ("crypto: authencesn - Convert to new AEAD...")
Signed-off-by: Harsh Jain <harsh@chelsio.com>
[It's a minimal fix for a bug that was fixed incidentally by a large
refactoring in v4.8.]
In the CTS template, when the input length is <= one block cipher block
(e.g. <= 16 bytes for AES) pass the correct length to the underlying CBC
transform rather than one block. This matches the upstream behavior and
makes the encryption/decryption operation correctly return -EINVAL when
1 <= nbytes < bsize or succeed when nbytes == 0, rather than crashing.
This was fixed upstream incidentally by a large refactoring,
commit 0605c41cc53c ("crypto: cts - Convert to skcipher"). But
syzkaller easily trips over this when running on older kernels, as it's
easily reachable via AF_ALG. Therefore, this patch makes the minimal
fix for older kernels.
Cc: linux-crypto@vger.kernel.org
Fixes: 76cb9521795a ("[CRYPTO] cts: Add CTS mode required for Kerberos AES support")
commit fbe1a850b3b1522e9fc22319ccbbcd2ab05328d2 upstream.
When the LRW block counter overflows, the current implementation returns
128 as the index to the precomputed multiplication table, which has 128
entries. This patch fixes it to return the correct value (127).
Fixes: 64470f1b8510 ("[CRYPTO] lrw: Liskov Rivest Wagner, a tweakable narrow block cipher mode")
Cc: <stable@vger.kernel.org> # 2.6.20+
Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com>
[ Upstream commit 9039f3ef446e9ffa200200c934f049add9e58426 ]
The SCTP program may sleep under a spinlock, and the function call path is:
sctp_generate_t3_rtx_event (acquire the spinlock)
sctp_do_sm
sctp_side_effects
sctp_cmd_interpreter
sctp_make_init_ack
sctp_pack_cookie
crypto_shash_setkey
shash_setkey_unaligned
kmalloc(GFP_KERNEL)
For the same reason, the orinoco driver may sleep in interrupt handler,
orinoco_rx_isr_tasklet
orinoco_rx
orinoco_mic
crypto_shash_setkey
kmalloc(GFP_KERNEL)
To fix it, GFP_KERNEL is replaced with GFP_ATOMIC.
This bug is found by my static analysis tool and my code review.
Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com>
[ Upstream commit cefd769fd0192c84d638f66da202459ed8ad63ba ]
As of GCC 9.0.0 the build is reporting warnings like:
crypto/ablkcipher.c: In function ‘crypto_ablkcipher_report’:
crypto/ablkcipher.c:374:2: warning: ‘strncpy’ specified bound 64 equals destination size [-Wstringop-truncation]
strncpy(rblkcipher.geniv, alg->cra_ablkcipher.geniv ?: "<default>",
sizeof(rblkcipher.geniv));
This means the strnycpy might create a non null terminated string. Fix this by
explicitly performing '\0' termination.
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Eric Biggers <ebiggers3@gmail.com>
Cc: Nick Desaulniers <nick.desaulniers@gmail.com>
Signed-off-by: Stafford Horne <shorne@gmail.com>
commit 318abdfbe708aaaa652c79fb500e9bd60521f9dc upstream.
Like the skcipher_walk and blkcipher_walk cases:
scatterwalk_done() is only meant to be called after a nonzero number of
bytes have been processed, since scatterwalk_pagedone() will flush the
dcache of the *previous* page. But in the error case of
ablkcipher_walk_done(), e.g. if the input wasn't an integer number of
blocks, scatterwalk_done() was actually called after advancing 0 bytes.
This caused a crash ("BUG: unable to handle kernel paging request")
during '!PageSlab(page)' on architectures like arm and arm64 that define
ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE, provided that the input was
page-aligned as in that case walk->offset == 0.
Fix it by reorganizing ablkcipher_walk_done() to skip the
scatterwalk_advance() and scatterwalk_done() if an error has occurred.
Reported-by: Liu Chao <liuchao741@huawei.com>
Fixes: bf06099db18a ("crypto: skcipher - Add ablkcipher_walk interfaces")
Cc: <stable@vger.kernel.org> # v2.6.35+
commit 0868def3e4100591e7a1fdbf3eed1439cc8f7ca3 upstream.
Like the skcipher_walk case:
Fix it by reorganizing blkcipher_walk_done() to skip the
This bug was found by syzkaller fuzzing.
Reproducer, assuming ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE:
#include <unistd.h>
int main()
.salg_type = "skcipher",
.salg_name = "ecb(aes-generic)",
char buffer[4096] __attribute__((aligned(4096))) = { 0 };
int fd;
setsockopt(fd, SOL_ALG, ALG_SET_KEY, buffer, 16);
fd = accept(fd, NULL, NULL);
write(fd, buffer, 15);
read(fd, buffer, 15);
Fixes: 5cde0af2a982 ("[CRYPTO] cipher: Added block cipher type")
Cc: <stable@vger.kernel.org> # v2.6.19+
commit bb29648102335586e9a66289a1d98a0cb392b6e5 upstream.
syzbot reported a crash in vmac_final() when multiple threads
concurrently use the same "vmac(aes)" transform through AF_ALG. The bug
is pretty fundamental: the VMAC template doesn't separate per-request
state from per-tfm (per-key) state like the other hash algorithms do,
but rather stores it all in the tfm context. That's wrong.
Also, vmac_final() incorrectly zeroes most of the state including the
derived keys and cached pseudorandom pad. Therefore, only the first
VMAC invocation with a given key calculates the correct digest.
Fix these bugs by splitting the per-tfm state from the per-request state
and using the proper init/update/final sequencing for requests.
Reproducer for the crash:
#include <unistd.h>
int main()
int fd;
.salg_type = "hash",
.salg_name = "vmac(aes)",
char buf[256] = { 0 };
setsockopt(fd, SOL_ALG, ALG_SET_KEY, buf, 16);
fork();
for (;;)
write(fd, buf, 256);
The immediate cause of the crash is that vmac_ctx_t.partial_size exceeds
VMAC_NHBYTES, causing vmac_final() to memset() a negative length.
Reported-by: syzbot+264bca3a6e8d645550d3@syzkaller.appspotmail.com
Fixes: f1939f7c5645 ("crypto: vmac - New hash algorithm for intel_txt support")
Cc: <stable@vger.kernel.org> # v2.6.32+
commit 73bf20ef3df262026c3470241ae4ac8196943ffa upstream.
The VMAC template assumes the block cipher has a 128-bit block size, but
it failed to check for that. Thus it was possible to instantiate it
using a 64-bit block size cipher, e.g. "vmac(cast5)", causing
uninitialized memory to be used.
Add the needed check when instantiating the template.
[ Upstream commit ad2fdcdf75d169e7a5aec6c7cb421c0bec8ec711 ]
In crypto_authenc_setkey we save pointers to the authenc keys in
a local variable of type struct crypto_authenc_keys and we don't
zeroize it after use. Fix this and don't leak pointers to the
authenc keys.
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
[ Upstream commit 31545df391d58a3bb60e29b1192644a6f2b5a8dd ]
In crypto_authenc_esn_setkey we save pointers to the authenc keys
in a local variable of type struct crypto_authenc_keys and we don't
authenc keys.
commit a466856e0b7ab269cdf9461886d007e88ff575b0 upstream.
syzbot reported :
BUG: KMSAN: uninit-value in alg_bind+0xe3/0xd90 crypto/af_alg.c:162
We need to check addr_len before dereferencing sa (or uaddr)
Fixes: bb30b8848c85 ("crypto: af_alg - whitelist mask and type")
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Stephan Mueller <smueller@chronox.de>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit baae03a0e2497f49704628fd0aaf993cf98e1b99 ]
The DMA_PREP_FENCE is to be used when preparing Tx descriptor if output
of Tx descriptor is to be used by next/dependent Tx descriptor.
The DMA_PREP_FENSE will not be set correctly in do_async_gen_syndrome()
when calling dma->device_prep_dma_pq() under following conditions:
1. ASYNC_TX_FENCE not set in submit->flags
2. DMA_PREP_FENCE not set in dma_flags
3. src_cnt (= (disks - 2)) is greater than dma_maxpq(dma, dma_flags)
This patch fixes DMA_PREP_FENCE usage in do_async_gen_syndrome() taking
inspiration from do_async_xor() implementation.
Signed-off-by: Anup Patel <anup.patel@broadcom.com>
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
Reviewed-by: Scott Branden <scott.branden@broadcom.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 900a081f6912a8985dc15380ec912752cb66025a upstream.
When we have an unaligned SG list entry where there is no leftover
aligned data, the hash walk code will incorrectly return zero as if
the entire SG list has been processed.
This patch fixes it by moving onto the next page instead.
Reported-by: Eli Cooper <elicooper@gmx.com>
commit a16e772e664b9a261424107784804cffc8894977 upstream.
Since Poly1305 requires a nonce per invocation, the Linux kernel
implementations of Poly1305 don't use the crypto API's keying mechanism
and instead expect the key and nonce as the first 32 bytes of the data.
But ->setkey() is still defined as a stub returning an error code. This
prevents Poly1305 from being used through AF_ALG and will also break it
completely once we start enforcing that all crypto API users (not just
AF_ALG) call ->setkey() if present.
Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL.
commit 841a3ff329713f796a63356fef6e2f72e4a3f6a3 upstream.
When the cryptd template is used to wrap an unkeyed hash algorithm,
don't install a ->setkey() method to the cryptd instance. This change
is necessary for cryptd to keep working with unkeyed hash algorithms
once we start enforcing that ->setkey() is called when present.
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream.
Templates that use an shash spawn can use crypto_shash_alg_has_setkey()
to determine whether the underlying algorithm requires a key or not.
But there was no corresponding function for ahash spawns. Add it.
Note that the new function actually has to support both shash and ahash
algorithms, since the ahash API can be used with either.
commit 5c6ac1d4f8fbdbed65dbeb8cf149d736409d16a1 upstream.
In case buffer length is a multiple of PAGE_SIZE,
the S/G table is incorrectly generated.
Fix this by handling buflen = k * PAGE_SIZE separately.
Signed-off-by: Robert Baronescu <robert.baronescu@nxp.com>
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit bb30b8848c85e18ca7e371d0a869e94b3e383bdf upstream.
The user space interface allows specifying the type and mask field used
to allocate the cipher. Only a subset of the possible flags are intended
for user space. Therefore, white-list the allowed flags.
In case the user space caller uses at least one non-allowed flag, EINVAL
is returned.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
commit 9a00674213a3f00394f4e3221b88f2d21fc05789 upstream.
syzkaller triggered a NULL pointer dereference in crypto_remove_spawns()
via a program that repeatedly and concurrently requests AEADs
"authenc(cmac(des3_ede-asm),pcbc-aes-aesni)" and hashes "cmac(des3_ede)"
through AF_ALG, where the hashes are requested as "untested"
(CRYPTO_ALG_TESTED is set in ->salg_mask but clear in ->salg_feat; this
causes the template to be instantiated for every request).
Although AF_ALG users really shouldn't be able to request an "untested"
algorithm, the NULL pointer dereference is actually caused by a
longstanding race condition where crypto_remove_spawns() can encounter
an instance which has had spawn(s) "grabbed" but hasn't yet been
registered, resulting in ->cra_users still being NULL.
We probably should properly initialize ->cra_users earlier, but that
would require updating many templates individually. For now just fix
the bug in a simple way that can easily be backported: make
crypto_remove_spawns() treat a NULL ->cra_users list as empty.
commit d76c68109f37cb85b243a1cf0f40313afd2bae68 upstream.
pcrypt is using the old way of freeing instances, where the ->free()
method specified in the 'struct crypto_template' is passed a pointer to
the 'struct crypto_instance'. But the crypto_instance is being
kfree()'d directly, which is incorrect because the memory was actually
allocated as an aead_instance, which contains the crypto_instance at a
nonzero offset. Thus, the wrong pointer was being kfree()'d.
Fix it by switching to the new way to free aead_instance's where the
->free() method is specified in the aead_instance itself.
Fixes: 0496f56065e0 ("crypto: pcrypt - Add support for new AEAD interface")
