path: root/crypto
2020-07-06Merge branch 'imx_4.14.98_2.3.0' into toradex_4.14-2.3.x-imxOleksandr Suvorov
Fix conflicts after merging changes from the latest NXP branch. Conflicts: arch/arm64/boot/dts/freescale/fsl-imx8qm-device.dtsi drivers/pci/dwc/pci-imx6.c Related-to: ELB-1306 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-03-31MLK-21644 crypto: tcrypt - workaround for overlapping src, dst AADHoria Geantă
This is a temporary workround for the case when: -SWIOTLB is used for DMA bounce buffering AND -data to be DMA-ed is mapped DMA_FROM_DEVICE and device only partially overwrites the "original" data AND -it's expected that the "original" data that was not overwritten by the device to be untouched As discussed in upstream, the proper fix should be: -either an extension of the DMA API OR -a workaround in the device driver (considering these cases are rarely met in practice) Since both alternatives are not trivial (to say the least), add a workaround for the few cases matching the error conditions listed above. Link: https://lore.kernel.org/lkml/VI1PR0402MB348537CB86926B3E6D1DBE0A98070@VI1PR0402MB3485.eurprd04.prod.outlook.com/ Link: https://lore.kernel.org/lkml/20190522072018.10660-1-horia.geanta@nxp.com/ Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Reviewed-by: Valentin Ciocoi Radulescu <valentin.ciocoi@nxp.com> Reviewed-by: Iuliana Prodan <iuliana.prodan@nxp.com>
2020-03-08Merge tag 'v4.14.170' into 4.14-2.3.x-imxMarcel Ziswiler
This is the 4.14.170 stable release Conflicts: drivers/net/phy/phy_device.c drivers/tty/serial/imx.c include/linux/platform_data/dma-imx-sdma.h net/wireless/util.c
2020-02-07Merge tag 'v4.14.164' into 4.14-2.3.x-imxMarcel Ziswiler
This is the 4.14.164 stable release Conflicts: arch/arm/Kconfig.debug arch/arm/boot/dts/imx7s.dtsi arch/arm/mach-imx/cpuidle-imx6q.c arch/arm/mach-imx/cpuidle-imx6sx.c arch/arm64/kernel/cpu_errata.c arch/arm64/kvm/hyp/tlb.c drivers/crypto/caam/caamalg.c drivers/crypto/mxs-dcp.c drivers/dma/imx-sdma.c drivers/gpio/gpio-vf610.c drivers/gpu/drm/bridge/adv7511/adv7511_drv.c drivers/input/keyboard/imx_keypad.c drivers/input/keyboard/snvs_pwrkey.c drivers/mmc/core/block.c drivers/mmc/core/queue.h drivers/mmc/host/sdhci-esdhc-imx.c drivers/net/can/flexcan.c drivers/net/can/rx-offload.c drivers/net/ethernet/freescale/fec_main.c drivers/net/wireless/ath/ath10k/pci.c drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c drivers/pci/dwc/pci-imx6.c drivers/spi/spi-fsl-lpspi.c drivers/usb/dwc3/gadget.c include/net/tcp.h sound/soc/fsl/Kconfig sound/soc/fsl/fsl_esai.c
2020-02-05crypto: pcrypt - Fix user-after-free on module unloadHerbert Xu
[ Upstream commit 07bfd9bdf568a38d9440c607b72342036011f727 ] On module unload of pcrypt we must unregister the crypto algorithms first and then tear down the padata structure. As otherwise the crypto algorithms are still alive and can be used while the padata structure is being freed. Fixes: 5068c7a883d1 ("crypto: pcrypt - Add pcrypt crypto...") Cc: <stable@vger.kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-02-05crypto: af_alg - Use bh_lock_sock in sk_destructHerbert Xu
commit 37f96694cf73ba116993a9d2d99ad6a75fa7fdb0 upstream. As af_alg_release_parent may be called from BH context (most notably due to an async request that only completes after socket closure, or as reported here because of an RCU-delayed sk_destruct call), we must use bh_lock_sock instead of lock_sock. Reported-by: syzbot+c2f1558d49e25cc36e5e@syzkaller.appspotmail.com Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Fixes: c840ac6af3f8 ("crypto: af_alg - Disallow bind/setkey/...") Cc: <stable@vger.kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-27crypto: tgr192 - fix unaligned memory accessEric Biggers
[ Upstream commit f990f7fb58ac8ac9a43316f09a48cff1a49dda42 ] Fix an unaligned memory access in tgr192_transform() by using the unaligned access helpers. Fixes: 06ace7a9bafe ("[CRYPTO] Use standard byte order macros wherever possible") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-27pcrypt: use format specifier in kobject_addColin Ian King
[ Upstream commit b1e3874c75ab15288f573b3532e507c37e8e7656 ] Passing string 'name' as the format specifier is potentially hazardous because name could (although very unlikely to) have a format specifier embedded in it causing issues when parsing the non-existent arguments to these. Follow best practice by using the "%s" format string for the string 'name'. Cleans up clang warning: crypto/pcrypt.c:397:40: warning: format string is not a string literal (potentially insecure) [-Wformat-security] Fixes: a3fb1e330dd2 ("pcrypt: Added sysfs interface to pcrypt") Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17crypto: user - fix memory leak in crypto_reportNavid Emamdoost
commit ffdde5932042600c6807d46c1550b28b0db6a3bc upstream. In crypto_report, a new skb is created via nlmsg_new(). This skb should be released if crypto_report_alg() fails. Fixes: a38f7907b926 ("crypto: Add userspace configuration API") Cc: <stable@vger.kernel.org> Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17crypto: ecdh - fix big endian bug in ECC libraryArd Biesheuvel
commit f398243e9fd6a3a059c1ea7b380c40628dbf0c61 upstream. The elliptic curve arithmetic library used by the EC-DH KPP implementation assumes big endian byte order, and unconditionally reverses the byte and word order of multi-limb quantities. On big endian systems, the byte reordering is not necessary, while the word ordering needs to be retained. So replace the __swab64() invocation with a call to be64_to_cpu() which should do the right thing for both little and big endian builds. Fixes: 3c4b23901a0c ("crypto: ecdh - Add ECDH software support") Cc: <stable@vger.kernel.org> # v4.9+ Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17crypto: af_alg - cast ki_complete ternary op to intAyush Sawal
commit 64e7f852c47ce99f6c324c46d6a299a5a7ebead9 upstream. when libkcapi test is executed using HW accelerator, cipher operation return -74.Since af_alg_async_cb->ki_complete treat err as unsigned int, libkcapi receive 429467222 even though it expect -ve value. Hence its required to cast resultlen to int so that proper error is returned to libkcapi. AEAD one shot non-aligned test 2(libkcapi test) ./../bin/kcapi -x 10 -c "gcm(aes)" -i 7815d4b06ae50c9c56e87bd7 -k ea38ac0c9b9998c80e28fb496a2b88d9 -a "853f98a750098bec1aa7497e979e78098155c877879556bb51ddeb6374cbaefc" -t "c4ce58985b7203094be1d134c1b8ab0b" -q "b03692f86d1b8b39baf2abb255197c98" Fixes: d887c52d6ae4 ("crypto: algif_aead - overhaul memory management") Cc: <stable@vger.kernel.org> Signed-off-by: Ayush Sawal <ayush.sawal@chelsio.com> Signed-off-by: Atul Gupta <atul.gupta@chelsio.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Ayush Sawal <ayush.sawal@chelsio.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17crypto: ecc - check for invalid values in the key verification testVitaly Chikunov
[ Upstream commit 2eb4942b6609d35a4e835644a33203b0aef7443d ] Currently used scalar multiplication algorithm (Matthieu Rivain, 2011) have invalid values for scalar == 1, n-1, and for regularized version n-2, which was previously not checked. Verify that they are not used as private keys. Signed-off-by: Vitaly Chikunov <vt@altlinux.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-05crypto: user - support incremental algorithm dumpsEric Biggers
[ Upstream commit 0ac6b8fb23c724b015d9ca70a89126e8d1563166 ] CRYPTO_MSG_GETALG in NLM_F_DUMP mode sometimes doesn't return all registered crypto algorithms, because it doesn't support incremental dumps. crypto_dump_report() only permits itself to be called once, yet the netlink subsystem allocates at most ~64 KiB for the skb being dumped to. Thus only the first recvmsg() returns data, and it may only include a subset of the crypto algorithms even if the user buffer passed to recvmsg() is large enough to hold all of them. Fix this by using one of the arguments in the netlink_callback structure to keep track of the current position in the algorithm list. Then userspace can do multiple recvmsg() on the socket after sending the dump request. This is the way netlink dumps work elsewhere in the kernel; it's unclear why this was different (probably just an oversight). Also fix an integer overflow when calculating the dump buffer size hint. Fixes: a38f7907b926 ("crypto: Add userspace configuration API") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-20crypto: fix a memory leak in rsa-kcs1pad's encryption modeDan Aloni
[ Upstream commit 3944f139d5592790b70bc64f197162e643a8512b ] The encryption mode of pkcs1pad never uses out_sg and out_buf, so there's no need to allocate the buffer, which presently is not even being freed. CC: Herbert Xu <herbert@gondor.apana.org.au> CC: linux-crypto@vger.kernel.org CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Dan Aloni <dan@kernelim.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-10-11crypto: skcipher - Unmap pages after an external errorHerbert Xu
commit 0ba3c026e685573bd3534c17e27da7c505ac99c4 upstream. skcipher_walk_done may be called with an error by internal or external callers. For those internal callers we shouldn't unmap pages but for external callers we must unmap any pages that are in use. This patch distinguishes between the two cases by checking whether walk->nbytes is zero or not. For internal callers, we now set walk->nbytes to zero prior to the call. For external callers, walk->nbytes has always been non-zero (as zero is used to indicate the termination of a walk). Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Fixes: 5cde0af2a982 ("[CRYPTO] cipher: Added block cipher type") Cc: <stable@vger.kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-31crypto: chacha20poly1305 - fix atomic sleep when using async algorithmEric Biggers
commit 7545b6c2087f4ef0287c8c9b7eba6a728c67ff8e upstream. Clear the CRYPTO_TFM_REQ_MAY_SLEEP flag when the chacha20poly1305 operation is being continued from an async completion callback, since sleeping may not be allowed in that context. This is basically the same bug that was recently fixed in the xts and lrw templates. But, it's always been broken in chacha20poly1305 too. This was found using syzkaller in combination with the updated crypto self-tests which actually test the MAY_SLEEP flag now. Reproducer: python -c 'import socket; socket.socket(socket.AF_ALG, 5, 0).bind( ("aead", "rfc7539(cryptd(chacha20-generic),poly1305-generic)"))' Kernel output: BUG: sleeping function called from invalid context at include/crypto/algapi.h:426 in_atomic(): 1, irqs_disabled(): 0, pid: 1001, name: kworker/2:2 [...] CPU: 2 PID: 1001 Comm: kworker/2:2 Not tainted 5.2.0-rc2 #5 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-20181126_142135-anatol 04/01/2014 Workqueue: crypto cryptd_queue_worker Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x4d/0x6a lib/dump_stack.c:113 ___might_sleep kernel/sched/core.c:6138 [inline] ___might_sleep.cold.19+0x8e/0x9f kernel/sched/core.c:6095 crypto_yield include/crypto/algapi.h:426 [inline] crypto_hash_walk_done+0xd6/0x100 crypto/ahash.c:113 shash_ahash_update+0x41/0x60 crypto/shash.c:251 shash_async_update+0xd/0x10 crypto/shash.c:260 crypto_ahash_update include/crypto/hash.h:539 [inline] poly_setkey+0xf6/0x130 crypto/chacha20poly1305.c:337 poly_init+0x51/0x60 crypto/chacha20poly1305.c:364 async_done_continue crypto/chacha20poly1305.c:78 [inline] poly_genkey_done+0x15/0x30 crypto/chacha20poly1305.c:369 cryptd_skcipher_complete+0x29/0x70 crypto/cryptd.c:279 cryptd_skcipher_decrypt+0xcd/0x110 crypto/cryptd.c:339 cryptd_queue_worker+0x70/0xa0 crypto/cryptd.c:184 process_one_work+0x1ed/0x420 kernel/workqueue.c:2269 worker_thread+0x3e/0x3a0 kernel/workqueue.c:2415 kthread+0x11f/0x140 kernel/kthread.c:255 ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:352 Fixes: 71ebc4d1b27d ("crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539") Cc: <stable@vger.kernel.org> # v4.2+ Cc: Martin Willi <martin@strongswan.org> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-31crypto: ghash - fix unaligned memory access in ghash_setkey()Eric Biggers
commit 5c6bc4dfa515738149998bb0db2481a4fdead979 upstream. Changing ghash_mod_init() to be subsys_initcall made it start running before the alignment fault handler has been installed on ARM. In kernel builds where the keys in the ghash test vectors happened to be misaligned in the kernel image, this exposed the longstanding bug that ghash_setkey() is incorrectly casting the key buffer (which can have any alignment) to be128 for passing to gf128mul_init_4k_lle(). Fix this by memcpy()ing the key to a temporary buffer. Don't fix it by setting an alignmask on the algorithm instead because that would unnecessarily force alignment of the data too. Fixes: 2cdc6899a88e ("crypto: ghash - Add GHASH digest algorithm for GCM") Reported-by: Peter Robinson <pbrobinson@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Tested-by: Peter Robinson <pbrobinson@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-31crypto: asymmetric_keys - select CRYPTO_HASH where neededArnd Bergmann
[ Upstream commit 90acc0653d2bee203174e66d519fbaaa513502de ] Build testing with some core crypto options disabled revealed a few modules that are missing CRYPTO_HASH: crypto/asymmetric_keys/x509_public_key.o: In function `x509_get_sig_params': x509_public_key.c:(.text+0x4c7): undefined reference to `crypto_alloc_shash' x509_public_key.c:(.text+0x5e5): undefined reference to `crypto_shash_digest' crypto/asymmetric_keys/pkcs7_verify.o: In function `pkcs7_digest.isra.0': pkcs7_verify.c:(.text+0xab): undefined reference to `crypto_alloc_shash' pkcs7_verify.c:(.text+0x1b2): undefined reference to `crypto_shash_digest' pkcs7_verify.c:(.text+0x3c1): undefined reference to `crypto_shash_update' pkcs7_verify.c:(.text+0x411): undefined reference to `crypto_shash_finup' This normally doesn't show up in randconfig tests because there is a large number of other options that select CRYPTO_HASH. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-31crypto: serpent - mark __serpent_setkey_sbox noinlineArnd Bergmann
[ Upstream commit 473971187d6727609951858c63bf12b0307ef015 ] The same bug that gcc hit in the past is apparently now showing up with clang, which decides to inline __serpent_setkey_sbox: crypto/serpent_generic.c:268:5: error: stack frame size of 2112 bytes in function '__serpent_setkey' [-Werror,-Wframe-larger-than=] Marking it 'noinline' reduces the stack usage from 2112 bytes to 192 and 96 bytes, respectively, and seems to generate more useful object code. Fixes: c871c10e4ea7 ("crypto: serpent - improve __serpent_setkey with UBSAN") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Eric Biggers <ebiggers@kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-10crypto: cryptd - Fix skcipher instance memory leakVincent Whitchurch
commit 1a0fad630e0b7cff38e7691b28b0517cfbb0633f upstream. cryptd_skcipher_free() fails to free the struct skcipher_instance allocated in cryptd_create_skcipher(), leading to a memory leak. This is detected by kmemleak on bootup on ARM64 platforms: unreferenced object 0xffff80003377b180 (size 1024): comm "cryptomgr_probe", pid 822, jiffies 4294894830 (age 52.760s) backtrace: kmem_cache_alloc_trace+0x270/0x2d0 cryptd_create+0x990/0x124c cryptomgr_probe+0x5c/0x1e8 kthread+0x258/0x318 ret_from_fork+0x10/0x1c Fixes: 4e0958d19bd8 ("crypto: cryptd - Add support for skcipher") Cc: <stable@vger.kernel.org> Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-10crypto: user - prevent operating on larval algorithmsEric Biggers
commit 21d4120ec6f5b5992b01b96ac484701163917b63 upstream. Michal Suchanek reported [1] that running the pcrypt_aead01 test from LTP [2] in a loop and holding Ctrl-C causes a NULL dereference of alg->cra_users.next in crypto_remove_spawns(), via crypto_del_alg(). The test repeatedly uses CRYPTO_MSG_NEWALG and CRYPTO_MSG_DELALG. The crash occurs when the instance that CRYPTO_MSG_DELALG is trying to unregister isn't a real registered algorithm, but rather is a "test larval", which is a special "algorithm" added to the algorithms list while the real algorithm is still being tested. Larvals don't have initialized cra_users, so that causes the crash. Normally pcrypt_aead01 doesn't trigger this because CRYPTO_MSG_NEWALG waits for the algorithm to be tested; however, CRYPTO_MSG_NEWALG returns early when interrupted. Everything else in the "crypto user configuration" API has this same bug too, i.e. it inappropriately allows operating on larval algorithms (though it doesn't look like the other cases can cause a crash). Fix this by making crypto_alg_match() exclude larval algorithms. [1] https://lkml.kernel.org/r/20190625071624.27039-1-msuchanek@suse.de [2] https://github.com/linux-test-project/ltp/blob/20190517/testcases/kernel/crypto/pcrypt_aead01.c Reported-by: Michal Suchanek <msuchanek@suse.de> Fixes: a38f7907b926 ("crypto: Add userspace configuration API") Cc: <stable@vger.kernel.org> # v3.2+ Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21crypto: ccm - fix incompatibility between "ccm" and "ccm_base"Eric Biggers
commit 6a1faa4a43f5fabf9cbeaa742d916e7b5e73120f upstream. CCM instances can be created by either the "ccm" template, which only allows choosing the block cipher, e.g. "ccm(aes)"; or by "ccm_base", which allows choosing the ctr and cbcmac implementations, e.g. "ccm_base(ctr(aes-generic),cbcmac(aes-generic))". However, a "ccm_base" instance prevents a "ccm" instance from being registered using the same implementations. Nor will the instance be found by lookups of "ccm". This can be used as a denial of service. Moreover, "ccm_base" instances are never tested by the crypto self-tests, even if there are compatible "ccm" tests. The root cause of these problems is that instances of the two templates use different cra_names. Therefore, fix these problems by making "ccm_base" instances set the same cra_name as "ccm" instances, e.g. "ccm(aes)" instead of "ccm_base(ctr(aes-generic),cbcmac(aes-generic))". This requires extracting the block cipher name from the name of the ctr and cbcmac algorithms. It also requires starting to verify that the algorithms are really ctr and cbcmac using the same block cipher, not something else entirely. But it would be bizarre if anyone were actually using non-ccm-compatible algorithms with ccm_base, so this shouldn't break anyone in practice. Fixes: 4a49b499dfa0 ("[CRYPTO] ccm: Added CCM mode") Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21crypto: salsa20 - don't access already-freed walk.ivEric Biggers
commit edaf28e996af69222b2cb40455dbb5459c2b875a upstream. If the user-provided IV needs to be aligned to the algorithm's alignmask, then skcipher_walk_virt() copies the IV into a new aligned buffer walk.iv. But skcipher_walk_virt() can fail afterwards, and then if the caller unconditionally accesses walk.iv, it's a use-after-free. salsa20-generic doesn't set an alignmask, so currently it isn't affected by this despite unconditionally accessing walk.iv. However this is more subtle than desired, and it was actually broken prior to the alignmask being removed by commit b62b3db76f73 ("crypto: salsa20-generic - cleanup and convert to skcipher API"). Since salsa20-generic does not update the IV and does not need any IV alignment, update it to use req->iv instead of walk.iv. Fixes: 2407d60872dd ("[CRYPTO] salsa20: Salsa20 stream cipher") Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21crypto: gcm - fix incompatibility between "gcm" and "gcm_base"Eric Biggers
commit f699594d436960160f6d5ba84ed4a222f20d11cd upstream. GCM instances can be created by either the "gcm" template, which only allows choosing the block cipher, e.g. "gcm(aes)"; or by "gcm_base", which allows choosing the ctr and ghash implementations, e.g. "gcm_base(ctr(aes-generic),ghash-generic)". However, a "gcm_base" instance prevents a "gcm" instance from being registered using the same implementations. Nor will the instance be found by lookups of "gcm". This can be used as a denial of service. Moreover, "gcm_base" instances are never tested by the crypto self-tests, even if there are compatible "gcm" tests. The root cause of these problems is that instances of the two templates use different cra_names. Therefore, fix these problems by making "gcm_base" instances set the same cra_name as "gcm" instances, e.g. "gcm(aes)" instead of "gcm_base(ctr(aes-generic),ghash-generic)". This requires extracting the block cipher name from the name of the ctr algorithm. It also requires starting to verify that the algorithms are really ctr and ghash, not something else entirely. But it would be bizarre if anyone were actually using non-gcm-compatible algorithms with gcm_base, so this shouldn't break anyone in practice. Fixes: d00aa19b507b ("[CRYPTO] gcm: Allow block cipher parameter") Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21crypto: crct10dif-generic - fix use via crypto_shash_digest()Eric Biggers
commit 307508d1072979f4435416f87936f87eaeb82054 upstream. The ->digest() method of crct10dif-generic reads the current CRC value from the shash_desc context. But this value is uninitialized, causing crypto_shash_digest() to compute the wrong result. Fix it. Probably this wasn't noticed before because lib/crc-t10dif.c only uses crypto_shash_update(), not crypto_shash_digest(). Likewise, crypto_shash_digest() is not yet tested by the crypto self-tests because those only test the ahash API which only uses shash init/update/final. This bug was detected by my patches that improve testmgr to fuzz algorithms against their generic implementation. Fixes: 2d31e518a428 ("crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework") Cc: <stable@vger.kernel.org> # v3.11+ Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21crypto: skcipher - don't WARN on unprocessed data after slow walk stepEric Biggers
commit dcaca01a42cc2c425154a13412b4124293a6e11e upstream. skcipher_walk_done() assumes it's a bug if, after the "slow" path is executed where the next chunk of data is processed via a bounce buffer, the algorithm says it didn't process all bytes. Thus it WARNs on this. However, this can happen legitimately when the message needs to be evenly divisible into "blocks" but isn't, and the algorithm has a 'walksize' greater than the block size. For example, ecb-aes-neonbs sets 'walksize' to 128 bytes and only supports messages evenly divisible into 16-byte blocks. If, say, 17 message bytes remain but they straddle scatterlist elements, the skcipher_walk code will take the "slow" path and pass the algorithm all 17 bytes in the bounce buffer. But the algorithm will only be able to process 16 bytes, triggering the WARN. Fix this by just removing the WARN_ON(). Returning -EINVAL, as the code already does, is the right behavior. This bug was detected by my patches that improve testmgr to fuzz algorithms against their generic implementation. Fixes: b286d8b1a690 ("crypto: skcipher - Add skcipher walk interface") Cc: <stable@vger.kernel.org> # v4.10+ Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21crypto: chacha20poly1305 - set cra_name correctlyEric Biggers
commit 5e27f38f1f3f45a0c938299c3a34a2d2db77165a upstream. If the rfc7539 template is instantiated with specific implementations, e.g. "rfc7539(chacha20-generic,poly1305-generic)" rather than "rfc7539(chacha20,poly1305)", then the implementation names end up included in the instance's cra_name. This is incorrect because it then prevents all users from allocating "rfc7539(chacha20,poly1305)", if the highest priority implementations of chacha20 and poly1305 were selected. Also, the self-tests aren't run on an instance allocated in this way. Fix it by setting the instance's cra_name from the underlying algorithms' actual cra_names, rather than from the requested names. This matches what other templates do. Fixes: 71ebc4d1b27d ("crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539") Cc: <stable@vger.kernel.org> # v4.2+ Cc: Martin Willi <martin@strongswan.org> Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-14crypto: tcrypt - add multibuf skcipher speed testGilad Ben-Yossef
The performance of some skcipher tfm providers is affected by the amount of parallelism possible with the processing. Introduce an async skcipher concurrent multiple buffer processing speed test to be able to test performance of such tfm providers. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit e161c5930c150abab95d2ccad428d68ce1780ea1)
2019-05-14crypto: tcrypt - add multi buf ahash jiffies testGilad Ben-Yossef
The multi buffer concurrent requests ahash speed test only supported the cycles mode. Add support for the so called jiffies mode that test performance of bytes/sec. We only add support for digest mode at the moment. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit b34a0f67ba62027394598e3c47fd3549c5c8e294)
2019-05-14crypto: tcrypt - allow setting num of bufsMircea Pop
For multiple buffers speed tests, the number of buffers, or requests, used actually sets the level of parallelism a tfm provider may utilize to hide latency. The existing number (of 8) is good for some software based providers but not enough for many HW providers with deep FIFOs. Add a module parameter that allows setting the number of multiple buffers/requests used, leaving the default at 8. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 8fcdc86856b24d3f76b4d70665f2cbbe5102d8de) Removed SM3 changes Signed-off-by: Mircea Pop <mircea.pop@nxp.com>
2019-05-14crypto: tcrypt - fix AEAD decryption speed testGilad Ben-Yossef
The AEAD speed test pretended to support decryption, however that support was broken as decryption requires a valid auth field which the test did not provide. Fix this by running the encryption path once with inout/output sgls switched to calculate the auth field prior to performing decryption speed tests. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 4431bd49530c7379dffaf0963d69bdab7fbead05)
2019-05-14crypto: tcrypt - use multi buf for ahash mb testGilad Ben-Yossef
The multi buffer ahash speed test was allocating multiple buffers for use with the multiple outstanding requests it was starting but never actually using them (except to free them), instead using a different single statically allocated buffer for all requests. Fix this by actually using the allocated buffers for the test. It is noted that it may seem tempting to instead remove the allocation and free of the multiple buffers and leave things as they are since this is a hash test where the input is read only. However, after consideration I believe that multiple buffers better reflect real life scenario with regard to data cache and TLB behaviours etc. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 7c3f13238992884abf3782dcc8e97e0862e5c23e)
2019-05-14crypto: tcrypt - set assoc in sg_init_aead()Tudor-Dan Ambarus
Results better code readability. Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com> Reviewed-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 5601e014fe7229dae405c9ad72081d65ac102962)
2019-05-14crypto: tcrypt - move to generic async completionGilad Ben-Yossef
tcrypt starts several async crypto ops and waits for their completions. Move it over to generic code doing the same. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 646710419a978c6f82342a2ad5eb28adb5f47bc4)
2019-05-14crypto: testmgr - move to generic async completionGilad Ben-Yossef
testmgr is starting async. crypto ops and waiting for them to complete. Move it over to generic code doing the same. This also provides a test of the generic crypto async. wait code. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 7f39713684acb2745506be195d31f73ce410fb24)
2019-05-14crypto: gcm - move to generic async completionMircea Pop
gcm is starting an async. crypto op and waiting for it complete. Move it over to generic code doing the same. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 76c6739477fa9e16a75633d1f57c62a8a57388ad) fix merge conflict with MLK-19365 Signed-off-by: Mircea Pop <mircea.pop@nxp.com>
2019-05-14crypto: drbg - move to generic async completionGilad Ben-Yossef
DRBG is starting an async. crypto op and waiting for it complete. Move it over to generic code doing the same. The code now also passes CRYPTO_TFM_REQ_MAY_SLEEP flag indicating crypto request memory allocation may use GFP_KERNEL which should be perfectly fine as the code is obviously sleeping for the completion of the request any way. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 85a2dea4bdbfa7565818ca094d08e838cf62da77)
2019-05-14crypto: move pub key to generic async completionGilad Ben-Yossef
public_key_verify_signature() is starting an async crypto op and waiting for it to complete. Move it over to generic code doing the same. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 0ca2a04ac398a71e49b0b093f365d1188cc13e01)
2019-05-14crypto: algif - move to generic async completionGilad Ben-Yossef
algif starts several async crypto ops and waits for their completion. Move it over to generic code doing the same. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 2c3f8b162106a7d12097d02eb22459f57fab8247)
2019-05-14crypto: introduce crypto wait for async opGilad Ben-Yossef
Invoking a possibly async. crypto op and waiting for completion while correctly handling backlog processing is a common task in the crypto API implementation and outside users of it. This patch adds a generic implementation for doing so in preparation for using it across the board instead of hand rolled versions. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> CC: Eric Biggers <ebiggers3@gmail.com> CC: Jonathan Cameron <Jonathan.Cameron@huawei.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit ada69a1639eca54ff74d839a6513c43db8d57d70)
2019-05-14crypto: remove redundant backlog checks on EBUSYGilad Ben-Yossef
Now that -EBUSY return code only indicates backlog queueing we can safely remove the now redundant check for the CRYPTO_TFM_REQ_MAY_BACKLOG flag when -EBUSY is returned. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 4e5b0ad5827163bd8e57ea595be2681cad12e5c2)
2019-05-14crypto: change transient busy return code to -ENOSPCGilad Ben-Yossef
The crypto API was using the -EBUSY return value to indicate both a hard failure to submit a crypto operation into a transformation provider when the latter was busy and the backlog mechanism was not enabled as well as a notification that the operation was queued into the backlog when the backlog mechanism was enabled. Having the same return code indicate two very different conditions depending on a flag is both error prone and requires extra runtime check like the following to discern between the cases: if (err == -EINPROGRESS || (err == -EBUSY && (ahash_request_flags(req) & CRYPTO_TFM_REQ_MAY_BACKLOG))) This patch changes the return code used to indicate a crypto op failed due to the transformation provider being transiently busy to -ENOSPC. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 6b80ea389a0bceee6a0a801474b78ad0a8cd034d)
2019-04-27crypto: x86/poly1305 - fix overflow during partial reductionEric Biggers
commit 678cce4019d746da6c680c48ba9e6d417803e127 upstream. The x86_64 implementation of Poly1305 produces the wrong result on some inputs because poly1305_4block_avx2() incorrectly assumes that when partially reducing the accumulator, the bits carried from limb 'd4' to limb 'h0' fit in a 32-bit integer. This is true for poly1305-generic which processes only one block at a time. However, it's not true for the AVX2 implementation, which processes 4 blocks at a time and therefore can produce intermediate limbs about 4x larger. Fix it by making the relevant calculations use 64-bit arithmetic rather than 32-bit. Note that most of the carries already used 64-bit arithmetic, but the d4 -> h0 carry was different for some reason. To be safe I also made the same change to the corresponding SSE2 code, though that only operates on 1 or 2 blocks at a time. I don't think it's really needed for poly1305_block_sse2(), but it doesn't hurt because it's already x86_64 code. It *might* be needed for poly1305_2block_sse2(), but overflows aren't easy to reproduce there. This bug was originally detected by my patches that improve testmgr to fuzz algorithms against their generic implementation. But also add a test vector which reproduces it directly (in the AVX2 case). Fixes: b1ccc8f4b631 ("crypto: poly1305 - Add a four block AVX2 variant for x86_64") Fixes: c70f4abef07a ("crypto: poly1305 - Add a SSE2 SIMD variant for x86_64") Cc: <stable@vger.kernel.org> # v4.3+ Cc: Martin Willi <martin@strongswan.org> Cc: Jason A. Donenfeld <Jason@zx2c4.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23crypto: pcbc - remove bogus memcpy()s with src == destEric Biggers
commit 251b7aea34ba3c4d4fdfa9447695642eb8b8b098 upstream. The memcpy()s in the PCBC implementation use walk->iv as both the source and destination, which has undefined behavior. These memcpy()'s are actually unneeded, because walk->iv is already used to hold the previous plaintext block XOR'd with the previous ciphertext block. Thus, walk->iv is already updated to its final value. So remove the broken and unnecessary memcpy()s. Fixes: 91652be5d1b9 ("[CRYPTO] pcbc: Add Propagated CBC template") Cc: <stable@vger.kernel.org> # v2.6.21+ Cc: David Howells <dhowells@redhat.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Maxim Zhukov <mussitantesmortem@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23crypto: testmgr - skip crc32c context test for ahash algorithmsEric Biggers
commit eb5e6730db98fcc4b51148b4a819fa4bf864ae54 upstream. Instantiating "cryptd(crc32c)" causes a crypto self-test failure because the crypto_alloc_shash() in alg_test_crc32c() fails. This is because cryptd(crc32c) is an ahash algorithm, not a shash algorithm; so it can only be accessed through the ahash API, unlike shash algorithms which can be accessed through both the ahash and shash APIs. As the test is testing the shash descriptor format which is only applicable to shash algorithms, skip it for ahash algorithms. (Note that it's still important to fix crypto self-test failures even for weird algorithm instantiations like cryptd(crc32c) that no one would really use; in fips_enabled mode unprivileged users can use them to panic the kernel, and also they prevent treating a crypto self-test failure as a bug when fuzzing the kernel.) Fixes: 8e3ee85e68c5 ("crypto: crc32c - Test descriptor context format") Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23crypto: hash - set CRYPTO_TFM_NEED_KEY if ->setkey() failsEric Biggers
commit ba7d7433a0e998c902132bd47330e355a1eaa894 upstream. Some algorithms have a ->setkey() method that is not atomic, in the sense that setting a key can fail after changes were already made to the tfm context. In this case, if a key was already set the tfm can end up in a state that corresponds to neither the old key nor the new key. It's not feasible to make all ->setkey() methods atomic, especially ones that have to key multiple sub-tfms. Therefore, make the crypto API set CRYPTO_TFM_NEED_KEY if ->setkey() fails and the algorithm requires a key, to prevent the tfm from being used until a new key is set. Note: we can't set CRYPTO_TFM_NEED_KEY for OPTIONAL_KEY algorithms, so ->setkey() for those must nevertheless be atomic. That's fine for now since only the crc32 and crc32c algorithms set OPTIONAL_KEY, and it's not intended that OPTIONAL_KEY be used much. [Cc stable mainly because when introducing the NEED_KEY flag I changed AF_ALG to rely on it; and unlike in-kernel crypto API users, AF_ALG previously didn't have this problem. So these "incompletely keyed" states became theoretically accessible via AF_ALG -- though, the opportunities for causing real mischief seem pretty limited.] Fixes: 9fa68f620041 ("crypto: hash - prevent using keyed hashes without setting key") Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23crypto: ahash - fix another early termination in hash walkEric Biggers
commit 77568e535af7c4f97eaef1e555bf0af83772456c upstream. Hash algorithms with an alignmask set, e.g. "xcbc(aes-aesni)" and "michael_mic", fail the improved hash tests because they sometimes produce the wrong digest. The bug is that in the case where a scatterlist element crosses pages, not all the data is actually hashed because the scatterlist walk terminates too early. This happens because the 'nbytes' variable in crypto_hash_walk_done() is assigned the number of bytes remaining in the page, then later interpreted as the number of bytes remaining in the scatterlist element. Fix it. Fixes: 900a081f6912 ("crypto: ahash - Fix early termination in hash walk") Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-02-23net: crypto set sk to NULL when af_alg_release.Mao Wenan
[ Upstream commit 9060cb719e61b685ec0102574e10337fa5f445ea ] KASAN has found use-after-free in sockfs_setattr. The existed commit 6d8c50dcb029 ("socket: close race condition between sock_close() and sockfs_setattr()") is to fix this simillar issue, but it seems to ignore that crypto module forgets to set the sk to NULL after af_alg_release. KASAN report details as below: BUG: KASAN: use-after-free in sockfs_setattr+0x120/0x150 Write of size 4 at addr ffff88837b956128 by task syz-executor0/4186 CPU: 2 PID: 4186 Comm: syz-executor0 Not tainted xxx + #1 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 Call Trace: dump_stack+0xca/0x13e print_address_description+0x79/0x330 ? vprintk_func+0x5e/0xf0 kasan_report+0x18a/0x2e0 ? sockfs_setattr+0x120/0x150 sockfs_setattr+0x120/0x150 ? sock_register+0x2d0/0x2d0 notify_change+0x90c/0xd40 ? chown_common+0x2ef/0x510 chown_common+0x2ef/0x510 ? chmod_common+0x3b0/0x3b0 ? __lock_is_held+0xbc/0x160 ? __sb_start_write+0x13d/0x2b0 ? __mnt_want_write+0x19a/0x250 do_fchownat+0x15c/0x190 ? __ia32_sys_chmod+0x80/0x80 ? trace_hardirqs_on_thunk+0x1a/0x1c __x64_sys_fchownat+0xbf/0x160 ? lockdep_hardirqs_on+0x39a/0x5e0 do_syscall_64+0xc8/0x580 entry_SYSCALL_64_after_hwframe+0x49/0xbe RIP: 0033:0x462589 Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48 RSP: 002b:00007fb4b2c83c58 EFLAGS: 00000246 ORIG_RAX: 0000000000000104 RAX: ffffffffffffffda RBX: 000000000072bfa0 RCX: 0000000000462589 RDX: 0000000000000000 RSI: 00000000200000c0 RDI: 0000000000000007 RBP: 0000000000000005 R08: 0000000000001000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000246 R12: 00007fb4b2c846bc R13: 00000000004bc733 R14: 00000000006f5138 R15: 00000000ffffffff Allocated by task 4185: kasan_kmalloc+0xa0/0xd0 __kmalloc+0x14a/0x350 sk_prot_alloc+0xf6/0x290 sk_alloc+0x3d/0xc00 af_alg_accept+0x9e/0x670 hash_accept+0x4a3/0x650 __sys_accept4+0x306/0x5c0 __x64_sys_accept4+0x98/0x100 do_syscall_64+0xc8/0x580 entry_SYSCALL_64_after_hwframe+0x49/0xbe Freed by task 4184: __kasan_slab_free+0x12e/0x180 kfree+0xeb/0x2f0 __sk_destruct+0x4e6/0x6a0 sk_destruct+0x48/0x70 __sk_free+0xa9/0x270 sk_free+0x2a/0x30 af_alg_release+0x5c/0x70 __sock_release+0xd3/0x280 sock_close+0x1a/0x20 __fput+0x27f/0x7f0 task_work_run+0x136/0x1b0 exit_to_usermode_loop+0x1a7/0x1d0 do_syscall_64+0x461/0x580 entry_SYSCALL_64_after_hwframe+0x49/0xbe Syzkaller reproducer: r0 = perf_event_open(&(0x7f0000000000)={0x0, 0x70, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, @perf_config_ext}, 0x0, 0x0, 0xffffffffffffffff, 0x0) r1 = socket$alg(0x26, 0x5, 0x0) getrusage(0x0, 0x0) bind(r1, &(0x7f00000001c0)=@alg={0x26, 'hash\x00', 0x0, 0x0, 'sha256-ssse3\x00'}, 0x80) r2 = accept(r1, 0x0, 0x0) r3 = accept4$unix(r2, 0x0, 0x0, 0x0) r4 = dup3(r3, r0, 0x0) fchownat(r4, &(0x7f00000000c0)='\x00', 0x0, 0x0, 0x1000) Fixes: 6d8c50dcb029 ("socket: close race condition between sock_close() and sockfs_setattr()") Signed-off-by: Mao Wenan <maowenan@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-02-12crypto: aes_ti - disable interrupts while accessing S-boxEric Biggers
[ Upstream commit 0a6a40c2a8c184a2fb467efacfb1cd338d719e0b ] In the "aes-fixed-time" AES implementation, disable interrupts while accessing the S-box, in order to make cache-timing attacks more difficult. Previously it was possible for the CPU to be interrupted while the S-box was loaded into L1 cache, potentially evicting the cachelines and causing later table lookups to be time-variant. In tests I did on x86 and ARM, this doesn't affect performance significantly. Responsiveness is potentially a concern, but interrupts are only disabled for a single AES block. Note that even after this change, the implementation still isn't necessarily guaranteed to be constant-time; see https://cr.yp.to/antiforgery/cachetiming-20050414.pdf for a discussion of the many difficulties involved in writing truly constant-time AES software. But it's valuable to make such attacks more difficult. Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-02-12MLK-19826: crypto: ecdh - fix typo of P-192 b valueStephan Mueller
Fix the b value to be compliant with FIPS 186-4 D.1.2.1. This fix is required to make sure the SP800-56A public key test passes for P-192. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit aef66587f19c7ecc52717328a4c5484f1d2268e9)
