Added ofb(aes) and cmac(aes) tests
Original-Change-Id: Ia79b0f979af88d337e91164f0b8b6d0eba18cd03
Reviewed-on: http://git-master/r/34701
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Rebase-Id: R383d7f642cab41350f54367687861615f9484cf3
Pull crypto update from Herbert Xu:
- XTS mode optimisation for twofish/cast6/camellia/aes on x86
- AVX2/x86_64 implementation for blowfish/twofish/serpent/camellia
- SSSE3/AVX/AVX2 optimisations for sha256/sha512
- Added driver for SAHARA2 crypto accelerator
- Fix for GMAC when used in non-IPsec secnarios
- Added generic CMAC implementation (including IPsec glue)
- IP update for crypto/atmel
- Support for more than one device in hwrng/timeriomem
- Added Broadcom BCM2835 RNG driver
- Misc fixes
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (59 commits)
crypto: caam - fix job ring cleanup code
crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of camellia cipher
crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipher
crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher
crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher
crypto: tcrypt - add async cipher speed tests for blowfish
crypto: testmgr - extend camellia test-vectors for camellia-aesni/avx2
crypto: aesni_intel - fix Kconfig problem with CRYPTO_GLUE_HELPER_X86
crypto: aesni_intel - add more optimized XTS mode for x86-64
crypto: x86/camellia-aesni-avx - add more optimized XTS code
crypto: cast6-avx: use new optimized XTS code
crypto: x86/twofish-avx - use optimized XTS code
crypto: x86 - add more optimized XTS-mode for serpent-avx
xfrm: add rfc4494 AES-CMAC-96 support
crypto: add CMAC support to CryptoAPI
crypto: testmgr - add empty test vectors for null ciphers
crypto: testmgr - add AES GMAC test vectors
crypto: gcm - fix rfc4543 to handle async crypto correctly
crypto: gcm - make GMAC work when dst and src are different
hwrng: timeriomem - added devicetree hooks
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI.
This work is based on Tom St Denis' earlier patch,
http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2
Cc: Tom St Denis <tstdenis@elliptictech.com>
Update the LZO compression test vectors according to the latest compressor
version.
Signed-off-by: Markus F.X.J. Oberhumer <markus@oberhumer.com>
The test vectors for 'xts(aes)' contain superfluous initializers.
Remove them.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Jarod Wilson <jarod@redhat.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Most DES3_EDE testvectors are short and do not test parallelised codepaths
well. Add larger testvectors to test large crypto operations and to test
multi-page crypto with DES3_EDE.
Most DES testvectors are short and do not test parallelised codepaths
multi-page crypto with DES.
Most AES testvectors are short and do not test parallelised codepaths
multi-page crypto with AES.
AVX2 implementation of serpent cipher processes 16 blocks parallel, so
we need to make test vectors larger to check parallel code paths.
AVX2 implementation of blowfish cipher processes 32 blocks parallel, so
AVX/AES-NI implementation of camellia cipher processes 16 blocks
parallel, so we need to make test vectors larger to check parallel
code paths.
VMAC implementation, as it is, does not work with blocks that
are not multiples of 128-bytes. Furthermore, this is a problem
when using the implementation on scatterlists, even
when the complete plain text is 128-byte multiple, as the pieces
that get passed to vmac_update can be pretty much any size.
I also added test cases for unaligned blocks.
Signed-off-by: Salman Qazi <sqazi@google.com>
More precisely, test 'long word' and 'long long word' overflow and carry
handling.
same test template
Allow non-multi page and multi page skcipher tests to be run on same test template, to avoid
duplicating data.
New ECB, CBC, CTR, LRW and XTS testvectors for cast6. We need larger
testvectors to check parallel code paths in the optimized implementation. Tests
have also been added to the tcrypt module.
Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de>
New ECB, CBC and CTR testvectors for cast5. We need larger testvectors to check
parallel code paths in the optimized implementation. Tests have also been added
Test vectors were generated starting from existing CBC(AES) test vectors
(RFC3602, NIST SP800-38A) and adding HMAC(SHA*) computed with Crypto++ and
double-checked with HashCalc.
Signed-off-by: Horia Geanta <horia.geanta@freescale.com>
The AVX implementation of the twofish cipher processes 8 blocks parallel, so we
need to make test vectors larger to check parallel code paths. Test vectors are
also large enough to deal with 16 block parallel implementations which may occur
in the future.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
New ECB, CBC, CTR, LRW and XTS test vectors for camellia. Larger ECB/CBC test
vectors needed for parallel 2-way camellia implementation.
Add test vectors for xts(twofish). These are generated from xts(twofish) test vectors.
Add test vectors for xts(serpent). These are generated from xts(aes) test vectors.
Add test vectors for lrw(twofish). These are generated from lrw(aes) test vectors.
Add test vectors for lrw(serpent). These are generated from lrw(aes) test vectors.
Add new serpent tests for serpent_sse2 x86_64/i586 8-way/4-way code paths.
Add tests for parallel twofish-x86_64-3way code paths.
Add tests for parallel blowfish-x86_64 code paths.
FIPS compliance requires a known-answer self-test for all approved
cipher and mode combinations, for all valid key sizes. Presently,
there are only self-tests for xts-aes-128. This adds a 256-bit one,
pulled from the same reference document, which should satisfy the
requirement.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
the fix add testcase for testing aes ofb mode.
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
In light of the recent discovery of the bug with partial block
processing on s390, we need best test coverage for that. This
patch adds a test vector for SHA1 that should catch such problems.
Updated RFC4106 AES-GCM testing. Some test vectors were taken from
http://csrc.nist.gov/groups/ST/toolkit/BCM/documents/proposedmodes/
gcm/gcm-test-vectors.tar.gz
Signed-off-by: Adrian Hoban <adrian.hoban@intel.com>
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com>
Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com>
This patch is to fix the vmac algorithm, add more test cases for vmac,
and fix the test failure on some big endian system like s390.
Signed-off-by: Shane Wang <shane.wang@intel.com>
Add ghash algorithm test before provide it to users
Signed-off-by: Youquan, Song <youquan.song@intel.com>
This patch adds VMAC (a fast MAC) support into crypto framework.
Signed-off-by: Joseph Cihula <joseph.cihula@intel.com>
Now with multi-block test vectors, all from SP800-38A, Appendix F.5.
Also added ctr(aes) to case 10 in tcrypt.
Add ANSI X9.31 Continuous Pseudo-Random Number Generator (AES mode),
aka 'ansi_cprng' test vectors, taken from Appendix B.2.9 and B.2.10
of the NIST RNGVS document, found here:
http://csrc.nist.gov/groups/STM/cavp/documents/rng/RNGVS.pdf
Successfully tested against both the cryptodev-2.6 tree and a Red
Hat Enterprise Linux 5.4 kernel, via 'modprobe tcrypt mode=150'.
The selection of 150 was semi-arbitrary, didn't seem like it should
go any place in particular, so I started a new range for rng tests.
Add some necessary infrastructure to make it possible to run
self-tests for ansi_cprng. The bits are likely very specific
to the ANSI X9.31 CPRNG in AES mode, and thus perhaps should
be named more specifically if/when we grow additional CPRNG
support...
Successfully tested against the cryptodev-2.6 tree and a
Red Hat Enterprise Linux 5.x kernel with the follow-on
patch that adds the actual test vectors.
Add an array of encryption and decryption + verification self-tests
for rfc4309(ccm(aes)).
Test vectors all come from sample FIPS CAVS files provided to
Red Hat by a testing lab. Unfortunately, all the published sample
vectors in RFC 3610 and NIST Special Publication 800-38C contain nonce
lengths that the kernel's rfc4309 implementation doesn't support, so
while using some public domain vectors would have been preferred, its
not possible at this time.
Add infrastructure to tcrypt/testmgr to support handling ccm decryption
test vectors that are expected to fail verification.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
The comment for the deflate test vectors says the winbits parameter is 11,
while the deflate module actually uses -11 (a negative window bits parameter
enables the raw deflate format instead of the zlib format).
Correct this, to avoid confusion about the format used.
This patch moves the newly created alg_test infrastructure into
cryptomgr. This shall allow us to use it for testing at algorithm
registrations.
