path: root/crypto/blowfish_generic.c
2012-08-01crypto: cleanup - remove unneeded crypto_alg.cra_list initializationsJussi Kivilinna
Initialization of cra_list is currently mixed, most ciphers initialize this field and most shashes do not. Initialization however is not needed at all since cra_list is initialized/overwritten in __crypto_register_alg() with list_add(). Therefore perform cleanup to remove all unneeded initializations of this field in 'crypto/'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-09-22crypto: blowfish - rename C-version to blowfish_genericJussi Kivilinna
Rename blowfish to blowfish_generic so that assembler versions of blowfish cipher can autoload. Module alias 'blowfish' is added. Also fix checkpatch warnings. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
