[ Upstream commit 884f0e84f1e3195b801319c8ec3d5774e9bf2710 ]
The pending timer has been set up in blk_throtl_init(). However, the
timer is not deleted in blk_throtl_exit(). This means that the timer
handler may still be running after freeing the timer, which would
result in a use-after-free.
Fix by calling del_timer_sync() to delete the timer in blk_throtl_exit().
Signed-off-by: Li Jinlin <lijinlin3@huawei.com>
Link: https://lore.kernel.org/r/20210907121242.2885564-1-lijinlin3@huawei.com
commit 97f433c3601a24d3513d06f575a389a2ca4e11e4 upstream.
We get I/O errors when we run md-raid1 on the top of dm-integrity on the
top of ramdisk.
device-mapper: integrity: Bio not aligned on 8 sectors: 0xff00, 0xff
device-mapper: integrity: Bio not aligned on 8 sectors: 0xffff, 0x1
device-mapper: integrity: Bio not aligned on 8 sectors: 0x8048, 0xff
device-mapper: integrity: Bio not aligned on 8 sectors: 0x8147, 0xff
device-mapper: integrity: Bio not aligned on 8 sectors: 0x8246, 0xff
device-mapper: integrity: Bio not aligned on 8 sectors: 0x8345, 0xbb
The ramdisk device has logical_block_size 512 and max_sectors 255. The
dm-integrity device uses logical_block_size 4096 and it doesn't affect the
"max_sectors" value - thus, it inherits 255 from the ramdisk. So, we have
a device with max_sectors not aligned on logical_block_size.
The md-raid device sees that the underlying leg has max_sectors 255 and it
will split the bios on 255-sector boundary, making the bios unaligned on
logical_block_size.
In order to fix the bug, we round down max_sectors to logical_block_size.
Cc: stable@vger.kernel.org
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit aebf5db917055b38f4945ed6d621d9f07a44ff30 upstream.
Make sure that bdgrab() is done on the 'block_device' instance before
referring to it for avoiding use-after-free.
Cc: <stable@vger.kernel.org>
Reported-by: syzbot+825f0f9657d4e528046e@syzkaller.appspotmail.com
Signed-off-by: Ming Lei <ming.lei@redhat.com>
commit 530ca2c9bd6949c72c9b5cfc330cb3dbccaa3f5b upstream.
A recent commit runs tag iterator callbacks under the rcu read lock,
but existing callbacks do not satisfy the non-blocking requirement.
The commit intended to prevent an iterator from accessing a queue that's
being modified. This patch fixes the original issue by taking a queue
reference instead of reading it, which allows callbacks to make blocking
calls.
Fixes: f5bbbbe4d6357 ("blk-mq: sync the update nr_hw_queues with blk_mq_queue_tag_busy_iter")
Acked-by: Jianchao Wang <jianchao.w.wang@oracle.com>
Signed-off-by: Keith Busch <keith.busch@intel.com>
Signed-off-by: Giuliano Procida <gprocida@google.com>
commit f5bbbbe4d63577026f908a809f22f5fd5a90ea1f upstream.
For blk-mq, part_in_flight/rw will invoke blk_mq_in_flight/rw to
account the inflight requests. It will access the queue_hw_ctx and
nr_hw_queues w/o any protection. When updating nr_hw_queues and
blk_mq_in_flight/rw occur concurrently, panic comes up.
Before update nr_hw_queues, the q will be frozen. So we could use
q_usage_counter to avoid the race. percpu_ref_is_zero is used here
so that we will not miss any in-flight request. The access to
nr_hw_queues and queue_hw_ctx in blk_mq_queue_tag_busy_iter are
under rcu critical section, __blk_mq_update_nr_hw_queues could use
synchronize_rcu to ensure the zeroed q_usage_counter to be globally
visible.
NOTE: Back-ported to 4.4.y.
The upstream commit was intended to prevent concurrent manipulation of
nr_hw_queues and iteration over queues. The former doesn't happen in
this in 4.4.7 (as __blk_mq_update_nr_hw_queues doesn't exist). The
extra locking is also buggy in this commit but fixed in a follow-up.
It may protect against other concurrent accesses such as queue removal
by synchronising RCU locking around q_usage_counter.
Signed-off-by: Jianchao Wang <jianchao.w.wang@oracle.com>
commit 71f79fb3179e69b0c1448a2101a866d871c66e7f upstream.
In case a submitted request gets stuck for some reason, the block layer
can prevent the request starvation by starting the scheduled timeout work.
If this stuck request occurs at the same time another thread has started
a queue freeze, the blk_mq_timeout_work will not be able to acquire the
queue reference and will return silently, thus not issuing the timeout.
But since the request is already holding a q_usage_counter reference and
is unable to complete, it will never release its reference, preventing
the queue from completing the freeze started by first thread. This puts
the request_queue in a hung state, forever waiting for the freeze
completion.
This was observed while running IO to a NVMe device at the same time we
toggled the CPU hotplug code. Eventually, once a request got stuck
requiring a timeout during a queue freeze, we saw the CPU Hotplug
notification code get stuck inside blk_mq_freeze_queue_wait, as shown in
the trace below.
[c000000deaf13690] [c000000deaf13738] 0xc000000deaf13738 (unreliable)
[c000000deaf13860] [c000000000015ce8] __switch_to+0x1f8/0x350
[c000000deaf138b0] [c000000000ade0e4] __schedule+0x314/0x990
[c000000deaf13940] [c000000000ade7a8] schedule+0x48/0xc0
[c000000deaf13970] [c0000000005492a4] blk_mq_freeze_queue_wait+0x74/0x110
[c000000deaf139e0] [c00000000054b6a8] blk_mq_queue_reinit_notify+0x1a8/0x2e0
[c000000deaf13a40] [c0000000000e7878] notifier_call_chain+0x98/0x100
[c000000deaf13a90] [c0000000000b8e08] cpu_notify_nofail+0x48/0xa0
[c000000deaf13ac0] [c0000000000b92f0] _cpu_down+0x2a0/0x400
[c000000deaf13b90] [c0000000000b94a8] cpu_down+0x58/0xa0
[c000000deaf13bc0] [c0000000006d5dcc] cpu_subsys_offline+0x2c/0x50
[c000000deaf13bf0] [c0000000006cd244] device_offline+0x104/0x140
[c000000deaf13c30] [c0000000006cd40c] online_store+0x6c/0xc0
[c000000deaf13c80] [c0000000006c8c78] dev_attr_store+0x68/0xa0
[c000000deaf13cc0] [c0000000003974d0] sysfs_kf_write+0x80/0xb0
[c000000deaf13d00] [c0000000003963e8] kernfs_fop_write+0x188/0x200
[c000000deaf13d50] [c0000000002e0f6c] __vfs_write+0x6c/0xe0
[c000000deaf13d90] [c0000000002e1ca0] vfs_write+0xc0/0x230
[c000000deaf13de0] [c0000000002e2cdc] SyS_write+0x6c/0x110
[c000000deaf13e30] [c000000000009204] system_call+0x38/0xb4
The fix is to allow the timeout work to execute in the window between
dropping the initial refcount reference and the release of the last
reference, which actually marks the freeze completion. This can be
achieved with percpu_refcount_tryget, which does not require the counter
to be alive. This way the timeout work can do it's job and terminate a
stuck request even during a freeze, returning its reference and avoiding
the deadlock.
Allowing the timeout to run is just a part of the fix, since for some
devices, we might get stuck again inside the device driver's timeout
handler, should it attempt to allocate a new request in that path -
which is a quite common action for Abort commands, which need to be sent
after a timeout. In NVMe, for instance, we call blk_mq_alloc_request
from inside the timeout handler, which will fail during a freeze, since
it also tries to acquire a queue reference.
I considered a similar change to blk_mq_alloc_request as a generic
solution for further device driver hangs, but we can't do that, since it
would allow new requests to disturb the freeze process. I thought about
creating a new function in the block layer to support unfreezable
requests for these occasions, but after working on it for a while, I
feel like this should be handled in a per-driver basis. I'm now
experimenting with changes to the NVMe timeout path, but I'm open to
suggestions of ways to make this generic.
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Cc: Brian King <brking@linux.vnet.ibm.com>
Cc: Keith Busch <keith.busch@intel.com>
Cc: linux-nvme@lists.infradead.org
Cc: linux-block@vger.kernel.org
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 287922eb0b186e2a5bf54fdd04b734c25c90035c upstream.
Timer context is not very useful for drivers to perform any meaningful abort
action from. So instead of calling the driver from this useless context
defer it to a workqueue as soon as possible.
Note that while a delayed_work item would seem the right thing here I didn't
dare to use it due to the magic in blk_add_timer that pokes deep into timer
internals. But maybe this encourages Tejun to add a sensible API for that to
the workqueue API and we'll all be fine in the end :)
Contains a major update from Keith Bush:
"This patch removes synchronizing the timeout work so that the timer can
start a freeze on its own queue. The timer enters the queue, so timer
context can only start a freeze, but not wait for frozen."
The only parts of the upstream commit that have been kept are various
locking changes, none of which were mentioned in the original commit
message which therefore describes this change not at all.
Timeout callbacks continue to be run via a timer. Both blk_mq_rq_timer
and blk_rq_timed_out_timer will return without without doing any work
if they cannot acquire the queue (without waiting).
Acked-by: Keith Busch <keith.busch@intel.com>
commit 5acb3cc2c2e9d3020a4fee43763c6463767f1572 upstream.
The lockdep code had reported the following unsafe locking scenario:
CPU0 CPU1
lock(s_active#228);
lock(&bdev->bd_mutex/1);
lock(s_active#228);
lock(&bdev->bd_mutex);
*** DEADLOCK ***
The deadlock may happen when one task (CPU1) is trying to delete a
partition in a block device and another task (CPU0) is accessing
tracing sysfs file (e.g. /sys/block/dm-1/trace/act_mask) in that
partition.
The s_active isn't an actual lock. It is a reference count (kn->count)
on the sysfs (kernfs) file. Removal of a sysfs file, however, require
a wait until all the references are gone. The reference count is
treated like a rwsem using lockdep instrumentation code.
The fact that a thread is in the sysfs callback method or in the
ioctl call means there is a reference to the opended sysfs or device
file. That should prevent the underlying block structure from being
removed.
Instead of using bd_mutex in the block_device structure, a new
blk_trace_mutex is now added to the request_queue structure to protect
access to the blk_trace structure.
Suggested-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Waiman Long <longman@redhat.com>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Fix typo in patch subject line, and prune a comment detailing how
the code used to work.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit b3a834b1596ac668df206aa2bb1f191c31f5f5e4 upstream.
When this_order variable in blk_mq_init_rq_map() becomes zero
the code incorrectly decrements the variable and passes the result
to order_to_size() helper causing undefined behaviour:
UBSAN: Undefined behaviour in block/blk-mq.c:1459:27
shift exponent 4294967295 is too large for 32-bit type 'unsigned int'
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.6.0-rc6-00072-g33656a1 #22
Fix the code by checking this_order variable for not having the zero
value first.
Reported-by: Meelis Roos <mroos@linux.ee>
Fixes: 320ae51feed5 ("blk-mq: new multi-queue block IO queueing mechanism")
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[ Upstream commit 1a67356e9a4829da2935dd338630a550c59c8489 ]
It is wrong to use bio->bi_vcnt to figure out how many segments
there are in the bio even though CLONED flag isn't set on this bio,
because this bio may be splitted or advanced.
So always use bio_segments() in blk_recount_segments(), and it shouldn't
cause any performance loss now because the physical segment number is figured
out in blk_queue_split() and BIO_SEG_VALID is set meantime since
bdced438acd83ad83a6c ("block: setup bi_phys_segments after splitting").
Reviewed-by: Omar Sandoval <osandov@fb.com>
Fixes: 76d8137a3113 ("blk-merge: recaculate segment if it isn't less than max segments")
commit ad6bf88a6c19a39fb3b0045d78ea880325dfcf15 upstream.
Logical block size has type unsigned short. That means that it can be at
most 32768. However, there are architectures that can run with 64k pages
(for example arm64) and on these architectures, it may be possible to
create block devices with 64k block size.
For exmaple (run this on an architecture with 64k pages):
Mount will fail with this error because it tries to read the superblock using 2-sector
access:
device-mapper: writecache: I/O is not aligned, sector 2, size 1024, block size 65536
EXT4-fs (dm-0): unable to read superblock
This patch changes the logical block size from unsigned short to unsigned
int to avoid the overflow.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
commit b2c0fcd28772f99236d261509bcd242135677965 upstream.
These were added to blkdev_ioctl() in linux-5.5 but not
blkdev_compat_ioctl, so add them now.
Cc: <stable@vger.kernel.org> # v4.4+
Fixes: bbd3e064362e ("block: add an API for Persistent Reservations")
Fold in followup patch from Arnd with missing pr.h header include.
commit d2c9be89f8ebe7ebcc97676ac40f8dec1cf9b43a upstream.
8962842ca5ab ("blk-mq: avoid sysfs buffer overflow with too many CPU cores")
avoids sysfs buffer overflow, and reserves one character for line break.
However, the last snprintf() doesn't get correct 'size' parameter passed
in, so fixed it.
Fixes: 8962842ca5ab ("blk-mq: avoid sysfs buffer overflow with too many CPU cores")
Cc: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp>
commit 8962842ca5abdcf98e22ab3b2b45a103f0408b95 upstream.
It is reported that sysfs buffer overflow can be triggered if the system
has too many CPU cores(>841 on 4K PAGE_SIZE) when showing CPUs of
hctx via /sys/block/$DEV/mq/$N/cpu_list.
Use snprintf to avoid the potential buffer overflow.
This version doesn't change the attribute format, and simply stops
showing CPU numbers if the buffer is going to overflow.
Fixes: 676141e48af7("blk-mq: don't dump CPU -> hw queue map on driver load")
commit 54648cf1ec2d7f4b6a71767799c45676a138ca24 upstream.
We find the memory use-after-free issue in __blk_drain_queue()
on the kernel 4.14. After read the latest kernel 4.18-rc6 we
think it has the same problem.
Memory is allocated for q->fq in the blk_init_allocated_queue().
If the elevator init function called with error return, it will
run into the fail case to free the q->fq.
Then the __blk_drain_queue() uses the same memory after the free
of the q->fq, it will lead to the unpredictable event.
The patch is to set q->fq as NULL in the fail case of
Fixes: commit 7c94e1c157a2 ("block: introduce blk_flush_queue to drive flush machinery")
Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com>
Signed-off-by: xiao jin <jin.xiao@intel.com>
[groeck: backport to v4.4.y/v4.9.y (context change)]
Signed-off-by: Alessio Balsini <balsini@android.com>
[ Upstream commit 229b53c9bf4e1132a4aa6feb9632a7a1f1d08c5c ]
all other drivers recognizing those ioctls are very much *not*
biarch.
commit a3761c3c91209b58b6f33bf69dd8bb8ec0c9d925 upstream.
When bio_add_pc_page() fails in bio_copy_user_iov() we should free
the page we just allocated otherwise we are leaking it.
Reviewed-by: Chaitanya Kulkarni <chaitanya.kulkarni@wdc.com>
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
[ Upstream commit 14cb2c8a6c5dae57ee3e2da10fa3db2b9087e39e ]
The if-block that sets a successful return value in aix_partition()
uses 'lvip[].pps_per_lv' and 'n[].name' potentially uninitialized.
For example, if 'numlvs' is zero or alloc_lvn() fails, neither is
initialized, but are used anyway if alloc_pvd() succeeds after it.
So, make the alloc_pvd() call conditional on their initialization.
This has been hit when attaching an apparently corrupted/stressed
AIX LUN, misleading the kernel to pr_warn() invalid data and hang.
[...] partition (null) (11 pp's found) is not contiguous
[...] partition (null) (2 pp's found) is not contiguous
[...] partition (null) (3 pp's found) is not contiguous
[...] partition (null) (64 pp's found) is not contiguous
Fixes: 6ceea22bbbc8 ("partitions: add aix lvm partition support files")
Signed-off-by: Mauricio Faria de Oliveira <mfo@canonical.com>
[ Upstream commit d43fdae7bac2def8c4314b5a49822cb7f08a45f1 ]
Even if properly initialized, the lvname array (i.e., strings)
is read from disk, and might contain corrupt data (e.g., lack
the null terminating character for strings).
So, make sure the partition name string used in pr_warn() has
the null terminating character.
Suggested-by: Daniel J. Axtens <daniel.axtens@canonical.com>
commit e00f4f4d0ff7e13b9115428a245b49108d625f09 upstream.
blkcg allocates some per-cgroup data structures with GFP_NOWAIT and
when that fails falls back to operations which aren't specific to the
cgroup. Occassional failures are expected under pressure and falling
back to non-cgroup operation is the right thing to do.
Unfortunately, I forgot to add __GFP_NOWARN to these allocations and
these expected failures end up creating a lot of noise. Add
__GFP_NOWARN.
Reported-by: Marc MERLIN <marc@merlins.org>
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit b3193bc0dca9bb69c8ba1ec1a318105c76eb4172 upstream.
In below scenario blkio cgroup does not work as per their assigned
weights :-
1. When the underlying device is nonrotational with a single HW queue
with depth of >= CFQ_HW_QUEUE_MIN
2. When the use case is forming two blkio cgroups cg1(weight 1000) &
cg2(wight 100) and two processes(file1 and file2) doing sync IO in
their respective blkio cgroups.
For above usecase result of fio (without this patch):-
file1: (groupid=0, jobs=1): err= 0: pid=685: Thu Jan 1 19:41:49 1970
write: IOPS=1315, BW=41.1MiB/s (43.1MB/s)(1024MiB/24906msec)
file2: (groupid=0, jobs=1): err= 0: pid=686: Thu Jan 1 19:41:49 1970
write: IOPS=1295, BW=40.5MiB/s (42.5MB/s)(1024MiB/25293msec)
// both the process BW is equal even though they belong to diff.
cgroups with weight of 1000(cg1) and 100(cg2)
In above case (for non rotational NCQ devices),
as soon as the request from cg1 is completed and even
though it is provided with higher set_slice=10, because of CFQ
algorithm when the driver tries to fetch the request, CFQ expires
this group without providing any idle time nor weight priority
and schedules another cfq group (in this case cg2).
And thus both cfq groups(cg1 & cg2) keep alternating to get the
disk time and hence loses the cgroup weight based scheduling.
Below patch gives a chance to cfq algorithm (cfq_arm_slice_timer)
to arm the slice timer in case group_idle is enabled.
In case if group_idle is also not required (including for nonrotational
NCQ drives), we need to explicitly set group_idle = 0 from sysfs for
such cases.
With this patch result of fio(for above usecase) :-
file1: (groupid=0, jobs=1): err= 0: pid=690: Thu Jan 1 00:06:08 1970
write: IOPS=1706, BW=53.3MiB/s (55.9MB/s)(1024MiB/19197msec)
file2: (groupid=0, jobs=1): err= 0: pid=691: Thu Jan 1 00:06:08 1970
write: IOPS=1043, BW=32.6MiB/s (34.2MB/s)(1024MiB/31401msec)
// In this processes BW is as per their respective cgroups weight.
Signed-off-by: Ritesh Harjani <riteshh@codeaurora.org>
commit 1dc3039bc87ae7d19a990c3ee71cfd8a9068f428 upstream.
When blk_queue_enter() waits for a queue to unfreeze, or unset the
PREEMPT_ONLY flag, do not allow it to be interrupted by a signal.
The PREEMPT_ONLY flag was introduced later in commit 3a0a529971ec
("block, scsi: Make SCSI quiesce and resume work reliably"). Note the SCSI
device is resumed asynchronously, i.e. after un-freezing userspace tasks.
So that commit exposed the bug as a regression in v4.15. A mysterious
SIGBUS (or -EIO) sometimes happened during the time the device was being
resumed. Most frequently, there was no kernel log message, and we saw Xorg
or Xwayland killed by SIGBUS.[1]
[1] E.g. https://bugzilla.redhat.com/show_bug.cgi?id=1553979
Without this fix, I get an IO error in this test:
# dd if=/dev/sda of=/dev/null iflag=direct & \
while killall -SIGUSR1 dd; do sleep 0.1; done & \
echo mem > /sys/power/state ; \
sleep 5; killall dd # stop after 5 seconds
The interruptible wait was added to blk_queue_enter in
commit 3ef28e83ab15 ("block: generic request_queue reference counting").
Before then, the interruptible wait was only in blk-mq, but I don't think
it could ever have been correct.
Signed-off-by: Alan Jenkins <alan.christopher.jenkins@gmail.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit 8ab0b7dc73e1b3e2987d42554b2bff503f692772 ]
HW queues may be unmapped in some cases, such as blk_mq_update_nr_hw_queues(),
then we need to check it before calling blk_mq_tag_idle(), otherwise
the following kernel oops can be triggered, so fix it by checking if
the hw queue is unmapped since it doesn't make sense to idle the tags
any more after hw queues are unmapped.
[ 440.771298] Workqueue: nvme-wq nvme_rdma_del_ctrl_work [nvme_rdma]
[ 440.779104] task: ffff894bae755ee0 ti: ffff893bf9bc8000 task.ti: ffff893bf9bc8000
[ 440.788359] RIP: 0010:[<ffffffffb730e2b4>] [<ffffffffb730e2b4>] __blk_mq_tag_idle+0x24/0x40
[ 440.798697] RSP: 0018:ffff893bf9bcbd10 EFLAGS: 00010286
[ 440.805538] RAX: 0000000000000000 RBX: ffff895bb131dc00 RCX: 000000000000011f
[ 440.814426] RDX: 00000000ffffffff RSI: 0000000000000120 RDI: ffff895bb131dc00
[ 440.823301] RBP: ffff893bf9bcbd10 R08: 000000000001b860 R09: 4a51d361c00c0000
[ 440.832193] R10: b5907f32b4cc7003 R11: ffffd6cabfb57000 R12: ffff894bafd1e008
[ 440.841091] R13: 0000000000000001 R14: ffff895baf770000 R15: 0000000000000080
[ 440.849988] FS: 0000000000000000(0000) GS:ffff894bbdcc0000(0000) knlGS:0000000000000000
[ 440.859955] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 440.867274] CR2: 0000000000000008 CR3: 000000103d098000 CR4: 00000000001407e0
[ 440.876169] Call Trace:
[ 440.879818] [<ffffffffb7309d68>] blk_mq_exit_hctx+0xd8/0xe0
[ 440.887051] [<ffffffffb730dc40>] blk_mq_free_queue+0xf0/0x160
[ 440.894465] [<ffffffffb72ff679>] blk_cleanup_queue+0xd9/0x150
[ 440.901881] [<ffffffffc08a802b>] nvme_ns_remove+0x5b/0xb0 [nvme_core]
[ 440.910068] [<ffffffffc08a811b>] nvme_remove_namespaces+0x3b/0x60 [nvme_core]
[ 440.919026] [<ffffffffc08b817b>] __nvme_rdma_remove_ctrl+0x2b/0xb0 [nvme_rdma]
[ 440.928079] [<ffffffffc08b8237>] nvme_rdma_del_ctrl_work+0x17/0x20 [nvme_rdma]
[ 440.937126] [<ffffffffb70ab58a>] process_one_work+0x17a/0x440
[ 440.944517] [<ffffffffb70ac3a8>] worker_thread+0x278/0x3c0
[ 440.951607] [<ffffffffb70ac130>] ? manage_workers.isra.24+0x2a0/0x2a0
[ 440.959760] [<ffffffffb70b352f>] kthread+0xcf/0xe0
[ 440.966055] [<ffffffffb70b3460>] ? insert_kthread_work+0x40/0x40
[ 440.973715] [<ffffffffb76d8658>] ret_from_fork+0x58/0x90
[ 440.980586] [<ffffffffb70b3460>] ? insert_kthread_work+0x40/0x40
[ 440.988229] Code: 5b 41 5c 5d c3 66 90 0f 1f 44 00 00 48 8b 87 20 01 00 00 f0 0f ba 77 40 01 19 d2 85 d2 75 08 c3 0f 1f 80 00 00 00 00 55 48 89 e5 <f0> ff 48 08 48 8d 78 10 e8 7f 0f 05 00 5d c3 0f 1f 00 66 2e 0f
[ 441.011620] RIP [<ffffffffb730e2b4>] __blk_mq_tag_idle+0x24/0x40
[ 441.019301] RSP <ffff893bf9bcbd10>
[ 441.024052] CR2: 0000000000000008
Reported-by: Zhang Yi <yizhan@redhat.com>
Tested-by: Zhang Yi <yizhan@redhat.com>
[ Upstream commit 3116a23bb30272d74ea81baf5d0ee23f602dd15b ]
If bio has no data, such as ones from blkdev_issue_flush(),
then we have nothing to protect.
This patch prevent bugon like follows:
kfree_debugcheck: out of range ptr ac1fa1d106742a5ah
kernel BUG at mm/slab.c:2773!
invalid opcode: 0000 [#1] SMP
Modules linked in: bcache
CPU: 0 PID: 4428 Comm: xfs_io Tainted: G W 4.11.0-rc4-ext4-00041-g2ef0043-dirty #43
Hardware name: Virtuozzo KVM, BIOS seabios-1.7.5-11.vz7.4 04/01/2014
task: ffff880137786440 task.stack: ffffc90000ba8000
RIP: 0010:kfree_debugcheck+0x25/0x2a
RSP: 0018:ffffc90000babde0 EFLAGS: 00010082
RAX: 0000000000000034 RBX: ac1fa1d106742a5a RCX: 0000000000000007
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88013f3ccb40
RBP: ffffc90000babde8 R08: 0000000000000000 R09: 0000000000000000
R10: 00000000fcb76420 R11: 00000000725172ed R12: 0000000000000282
R13: ffffffff8150e766 R14: ffff88013a145e00 R15: 0000000000000001
FS: 00007fb09384bf40(0000) GS:ffff88013f200000(0000) knlGS:0000000000000000
CR2: 00007fd0172f9e40 CR3: 0000000137fa9000 CR4: 00000000000006f0
Call Trace:
kfree+0xc8/0x1b3
bio_integrity_free+0xc3/0x16b
bio_free+0x25/0x66
bio_put+0x14/0x26
blkdev_issue_flush+0x7a/0x85
blkdev_fsync+0x35/0x42
vfs_fsync_range+0x8e/0x9f
vfs_fsync+0x1c/0x1e
do_fsync+0x31/0x4a
SyS_fsync+0x10/0x14
entry_SYSCALL_64_fastpath+0x1f/0xc2
Reviewed-by: Hannes Reinecke <hare@suse.com>
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
[ Upstream commit 7bd897cfce1eb373892d35d7f73201b0f9b221c4 ]
We don't set an error code on this path. It means that we return NULL
instead of an error pointer and the caller does a NULL dereference.
Fixes: 6d1d8050b4bc ("block, partition: add partition_meta_info to hd_struct")
[ Upstream commit f36ea50ca0043e7b1204feaf1d2ba6bd68c08d36 ]
When formatting NVMe to 512B/4K + T10 DIf/DIX, dd with split op returns
"Input/output error". Looks block layer split the bio after calling
bio_integrity_prep(bio). This patch fixes the issue.
Below is how we debug this issue:
(1)format nvme to 4K block # size with type 2 DIF
(2)dd with block size bigger than 1024k.
oflag=direct
dd: error writing '/dev/nvme0n1': Input/output error
We added some debug code in nvme device driver. It showed us the first
op and the second op have the same bi and pi address. This is not
correct.
1st op: nvme0n1 Op:Wr slba 0x505 length 0x100, PI ctrl=0x1400,
dsmgmt=0x0, AT=0x0 & RT=0x505
Guard 0x00b1, AT 0x0000, RT physical 0x00000505 RT virtual 0x00002828
2nd op: nvme0n1 Op:Wr slba 0x605 length 0x1, PI ctrl=0x1400, dsmgmt=0x0,
AT=0x0 & RT=0x605 ==> This op fails and subsequent 5 retires..
Guard 0x00b1, AT 0x0000, RT physical 0x00000605 RT virtual 0x00002828
With the fix, It showed us both of the first op and the second op have
correct bi and pi address.
1st op: nvme2n1 Op:Wr slba 0x505 length 0x100, PI ctrl=0x1400,
Guard 0x5ccb, AT 0x0000, RT physical 0x00000505 RT virtual
0x00002828
2nd op: nvme2n1 Op:Wr slba 0x605 length 0x1, PI ctrl=0x1400, dsmgmt=0x0,
AT=0x0 & RT=0x605
Guard 0xab4c, AT 0x0000, RT physical 0x00000605 RT virtual
0x00003028
Signed-off-by: Wen Xiong <wenxiong@linux.vnet.ibm.com>
commit 5f15684bd5e5ef39d4337988864fec8012471dda upstream.
UFS partitions from newer versions of FreeBSD 10 and 11 use relative
addressing for their subpartitions. But older versions of FreeBSD still
use absolute addressing just like OpenBSD and NetBSD.
Instead of simply testing for a FreeBSD partition, the code needs to
also test if the starting offset of the C subpartition is zero.
https://bugzilla.kernel.org/show_bug.cgi?id=197733
Signed-off-by: Richard Narron <comet.berkeley@gmail.com>
[ Upstream commit 06cceedcca67a93ac7f7aa93bbd9980c7496d14e ]
cgroup could be throttled to a limit but when all cgroups cross high
limit, queue enters a higher state and so the group should be throttled
to a higher limit. It's possible the cgroup is sleeping because of
throttle and other cgroups don't dispatch IO any more. In this case,
nobody can trigger current downgrade/upgrade logic. To fix this issue,
we could either set up a timer to wakeup the cgroup if other cgroups are
idle or make sure this cgroup doesn't sleep too long. Setting up a timer
means we must change the timer very frequently. This patch chooses the
latter. Making cgroup sleep time not too big wouldn't change cgroup
bps/iops, but could make it wakeup more frequently, which isn't a big
issue because throtl_slice * 8 is already quite big.
Signed-off-by: Shaohua Li <shli@fb.com>
commit 9b54d816e00425c3a517514e0d677bb3cec49258 upstream.
If blkg_create fails, new_blkg passed as an argument will
be freed by blkg_create, so there is no need to free it again.
Signed-off-by: Hou Tao <houtao1@huawei.com>
commit 2b04e8f6bbb196cab4b232af0f8d48ff2c7a8058 upstream.
we need to take care of failure exit as well - pages already
in bio should be dropped by analogue of bio_unmap_pages(),
since their refcounts had been bumped only once per reference
in bio.
[ Upstream commit 34d9715ac1edd50285168dd8d80c972739a4f6a4 ]
Once blk_set_queue_dying() is done in blk_cleanup_queue(), we call
blk_freeze_queue() and wait for q->q_usage_counter becoming zero. But
if there are tasks blocked in get_request(), q->q_usage_counter can
never become zero. So we have to wake up all these tasks in
blk_set_queue_dying() first.
Fixes: 3ef28e83ab157997 ("block: generic request_queue reference counting")
This reverts commit 668cee82cd28d2c38a99f7cbddf3b3fd58f257b9 which was
commit f507b54dccfd8000c517d740bc45f20c74532d18 upstream.
Ben reports:
That function doesn't exist here (it was introduced in 4.13).
Instead, this backport has modified bsg_create_job(), creating a
leak. Please revert this on the 3.18, 4.4 and 4.9 stable
branches.
So I'm dropping it from here.
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Ming Lei <ming.lei@redhat.com>
Signed-off-by: Greg Kroah-Hartman gregkh@linuxfoundation.org
commit 95d78c28b5a85bacbc29b8dba7c04babb9b0d467 upstream.
bio_map_user_iov and bio_unmap_user do unbalanced pages refcounting if
IO vector has small consecutive buffers belonging to the same page.
bio_add_pc_page merges them into one, but the page reference is never
dropped.
Signed-off-by: Vitaly Mayatskikh <v.mayatskih@gmail.com>
[ Upstream commit c5082b70adfe8e1ea1cf4a8eff92c9f260e364d2 ]
If a GUID Partition Table claims to have more than 2**25 entries, the
calculation of the partition table size in alloc_read_gpt_entries() will
overflow a 32-bit integer and not enough space will be allocated for the
table.
Nothing seems to get written out of bounds, but later efi_partition() will
read up to 32768 bytes from a 128 byte buffer, possibly OOPSing or exposing
information to /proc/partitions and uevents.
The problem exists on both 64-bit and 32-bit platforms.
Fix the overflow and also print a meaningful debug message if the table
size is too large.
Signed-off-by: Alden Tondettar <alden.tondettar@gmail.com>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
The job structure is allocated as part of the request, so we should not
free it in the error path of bsg_prepare_job.
commit 4ddd56b003f251091a67c15ae3fe4a5c5c5e390a upstream.
Calling blk_start_queue() from interrupt context with the queue
lock held and without disabling IRQs, as the skd driver does, is
safe. This patch avoids that loading the skd driver triggers the
following warning:
WARNING: CPU: 11 PID: 1348 at block/blk-core.c:283 blk_start_queue+0x84/0xa0
RIP: 0010:blk_start_queue+0x84/0xa0
Call Trace:
skd_unquiesce_dev+0x12a/0x1d0 [skd]
skd_complete_internal+0x1e7/0x5a0 [skd]
skd_complete_other+0xc2/0xd0 [skd]
skd_isr_completion_posted.isra.30+0x2a5/0x470 [skd]
skd_isr+0x14f/0x180 [skd]
irq_forced_thread_fn+0x2a/0x70
irq_thread+0x144/0x1a0
kthread+0x125/0x140
ret_from_fork+0x2a/0x40
Fixes: commit a038e2536472 ("[PATCH] blk_start_queue() must be called with irq disabled - add warning")
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Andrew Morton <akpm@osdl.org>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
commit 39a169b62b415390398291080dafe63aec751e0a upstream.
get_disk(),get_gendisk() calls have non explicit side effect: they
increase the reference on the disk owner module.
The following is the correct sequence how to get a disk reference and
to put it:
disk = get_gendisk(...);
/* use disk */
owner = disk->fops->owner;
put_disk(disk);
module_put(owner);
fs/block_dev.c is aware of this required module_put() call, but f.e.
blkg_conf_finish(), which is located in block/blk-cgroup.c, does not put
a module reference. To see a leakage in action cgroups throttle config
can be used. In the following script I'm removing throttle for /dev/ram0
(actually this is NOP, because throttle was never set for this device):
# lsmod | grep brd
brd 5175 0
# i=100; while [ $i -gt 0 ]; do echo "1:0 0" > \
/sys/fs/cgroup/blkio/blkio.throttle.read_bps_device; i=$(($i - 1)); \
done
# lsmod | grep brd
brd 5175 100
Now brd module has 100 references.
The issue is fixed by calling module_put() just right away put_disk().
Signed-off-by: Roman Pen <roman.penyaev@profitbricks.com>
Cc: Gi-Oh Kim <gi-oh.kim@profitbricks.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
commit 223220356d5ebc05ead9a8d697abb0c0a906fc81 upstream.
The code in block/partitions/msdos.c recognizes FreeBSD, OpenBSD
and NetBSD partitions and does a reasonable job picking out OpenBSD
and NetBSD UFS subpartitions.
But for FreeBSD the subpartitions are always "bad".
Kernel: <bsd:bad subpartition - ignored
Though all 3 of these BSD systems use UFS as a file system, only
FreeBSD uses relative start addresses in the subpartition
declarations.
The following patch fixes this for FreeBSD partitions and leaves
the code for OpenBSD and NetBSD intact:
commit 2859323e35ab5fc42f351fbda23ab544eaa85945 upstream.
When registering an integrity profile: if the template's interval_exp is
not 0 use it, otherwise use the ilog2() of logical block size of the
provided gendisk.
This fixes a long-standing DM linear target bug where it cannot pass
integrity data to the underlying device if its logical block size
conflicts with the underlying device's logical block size.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
commit 19b7ccf8651df09d274671b53039c672a52ad84d upstream.
Commit 25520d55cdb6 ("block: Inline blk_integrity in struct gendisk")
introduced blk_integrity_revalidate(), which seems to assume ownership
of the stable pages flag and unilaterally clears it if no blk_integrity
profile is registered:
if (bi->profile)
disk->queue->backing_dev_info->capabilities |=
BDI_CAP_STABLE_WRITES;
else
disk->queue->backing_dev_info->capabilities &=
~BDI_CAP_STABLE_WRITES;
It's called from revalidate_disk() and rescan_partitions(), making it
impossible to enable stable pages for drivers that support partitions
and don't use blk_integrity: while the call in revalidate_disk() can be
trivially worked around (see zram, which doesn't support partitions and
hence gets away with zram_revalidate_disk()), rescan_partitions() can
be triggered from userspace at any time. This breaks rbd, where the
ceph messenger is responsible for generating/verifying CRCs.
Since blk_integrity_{un,}register() "must" be used for (un)registering
the integrity profile with the block layer, move BDI_CAP_STABLE_WRITES
setting there. This way drivers that call blk_integrity_register() and
use integrity infrastructure won't interfere with drivers that don't
but still want stable pages.
Fixes: 25520d55cdb6 ("block: Inline blk_integrity in struct gendisk")
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Tested-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
[idryomov@gmail.com: backport to < 4.11: bdi is embedded in queue]
commit ac34f15e0c6d2fd58480052b6985f6991fb53bcc upstream.
When tearing down a block device early in its lifetime, userspace may
still be performing discovery actions like blkdev_ioctl() to re-read
partitions.
The nvdimm_revalidate_disk() implementation depends on
disk->driverfs_dev to be valid at entry. However, it is set to NULL in
del_gendisk() and fatally this is happening *before* the disk device is
deleted from userspace view.
There's no reason for del_gendisk() to clear ->driverfs_dev. That
device is the parent of the disk. It is guaranteed to not be freed
until the disk, as a child, drops its ->parent reference.
We could also fix this issue locally in nvdimm_revalidate_disk() by
using disk_to_dev(disk)->parent, but lets fix it globally since
->driverfs_dev follows the lifetime of the parent. Longer term we
should probably just add a @parent parameter to add_disk(), and stop
carrying this pointer in the gendisk.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffffa00340a8>] nvdimm_revalidate_disk+0x18/0x90 [libnvdimm]
CPU: 2 PID: 538 Comm: systemd-udevd Tainted: G O 4.4.0-rc5 #2257
Call Trace:
[<ffffffff8143e5c7>] rescan_partitions+0x87/0x2c0
[<ffffffff810f37f9>] ? __lock_is_held+0x49/0x70
[<ffffffff81438c62>] __blkdev_reread_part+0x72/0xb0
[<ffffffff81438cc5>] blkdev_reread_part+0x25/0x40
[<ffffffff8143982d>] blkdev_ioctl+0x4fd/0x9c0
[<ffffffff811246c9>] ? current_kernel_time64+0x69/0xd0
[<ffffffff812916dd>] block_ioctl+0x3d/0x50
[<ffffffff81264c38>] do_vfs_ioctl+0x308/0x560
[<ffffffff8115dbd1>] ? __audit_syscall_entry+0xb1/0x100
[<ffffffff810031d6>] ? do_audit_syscall_entry+0x66/0x70
[<ffffffff81264f09>] SyS_ioctl+0x79/0x90
[<ffffffff81902672>] entry_SYSCALL_64_fastpath+0x12/0x76
Cc: Jan Kara <jack@suse.cz>
Cc: Jens Axboe <axboe@fb.com>
Reported-by: Robert Hu <robert.hu@intel.com>
commit 36e1f3d107867b25c616c2fd294f5a1c9d4e5d09 upstream.
While stressing memory and IO at the same time we changed SMT settings,
we were able to consistently trigger deadlocks in the mm system, which
froze the entire machine.
I think that under memory stress conditions, the large allocations
performed by blk_mq_init_rq_map may trigger a reclaim, which stalls
waiting on the block layer remmaping completion, thus deadlocking the
system. The trace below was collected after the machine stalled,
waiting for the hotplug event completion.
The simplest fix for this is to make allocations in this path
non-reclaimable, with GFP_NOIO. With this patch, We couldn't hit the
issue anymore.
This should apply on top of Jens's for-next branch cleanly.
Changes since v1:
- Use GFP_NOIO instead of GFP_NOWAIT.
Call Trace:
[c000000f0160aaf0] [c000000f0160ab50] 0xc000000f0160ab50 (unreliable)
[c000000f0160acc0] [c000000000016624] __switch_to+0x2e4/0x430
[c000000f0160ad20] [c000000000b1a880] __schedule+0x310/0x9b0
[c000000f0160ae00] [c000000000b1af68] schedule+0x48/0xc0
[c000000f0160ae30] [c000000000b1b4b0] schedule_preempt_disabled+0x20/0x30
[c000000f0160ae50] [c000000000b1d4fc] __mutex_lock_slowpath+0xec/0x1f0
[c000000f0160aed0] [c000000000b1d678] mutex_lock+0x78/0xa0
[c000000f0160af00] [d000000019413cac] xfs_reclaim_inodes_ag+0x33c/0x380 [xfs]
[c000000f0160b0b0] [d000000019415164] xfs_reclaim_inodes_nr+0x54/0x70 [xfs]
[c000000f0160b0f0] [d0000000194297f8] xfs_fs_free_cached_objects+0x38/0x60 [xfs]
[c000000f0160b120] [c0000000003172c8] super_cache_scan+0x1f8/0x210
[c000000f0160b190] [c00000000026301c] shrink_slab.part.13+0x21c/0x4c0
[c000000f0160b2d0] [c000000000268088] shrink_zone+0x2d8/0x3c0
[c000000f0160b380] [c00000000026834c] do_try_to_free_pages+0x1dc/0x520
[c000000f0160b450] [c00000000026876c] try_to_free_pages+0xdc/0x250
[c000000f0160b4e0] [c000000000251978] __alloc_pages_nodemask+0x868/0x10d0
[c000000f0160b6f0] [c000000000567030] blk_mq_init_rq_map+0x160/0x380
[c000000f0160b7a0] [c00000000056758c] blk_mq_map_swqueue+0x33c/0x360
[c000000f0160b820] [c000000000567904] blk_mq_queue_reinit+0x64/0xb0
[c000000f0160b850] [c00000000056a16c] blk_mq_queue_reinit_notify+0x19c/0x250
[c000000f0160b8a0] [c0000000000f5d38] notifier_call_chain+0x98/0x100
[c000000f0160b8f0] [c0000000000c5fb0] __cpu_notify+0x70/0xe0
[c000000f0160b930] [c0000000000c63c4] notify_prepare+0x44/0xb0
[c000000f0160b9b0] [c0000000000c52f4] cpuhp_invoke_callback+0x84/0x250
[c000000f0160ba10] [c0000000000c570c] cpuhp_up_callbacks+0x5c/0x120
[c000000f0160ba60] [c0000000000c7cb8] _cpu_up+0xf8/0x1d0
[c000000f0160bac0] [c0000000000c7eb0] do_cpu_up+0x120/0x150
[c000000f0160bb40] [c0000000006fe024] cpu_subsys_online+0x64/0xe0
[c000000f0160bb90] [c0000000006f5124] device_online+0xb4/0x120
[c000000f0160bbd0] [c0000000006f5244] online_store+0xb4/0xc0
[c000000f0160bc20] [c0000000006f0a68] dev_attr_store+0x68/0xa0
[c000000f0160bc60] [c0000000003ccc30] sysfs_kf_write+0x80/0xb0
[c000000f0160bca0] [c0000000003cbabc] kernfs_fop_write+0x17c/0x250
[c000000f0160bcf0] [c00000000030fe6c] __vfs_write+0x6c/0x1e0
[c000000f0160bd90] [c000000000311490] vfs_write+0xd0/0x270
[c000000f0160bde0] [c0000000003131fc] SyS_write+0x6c/0x110
[c000000f0160be30] [c000000000009204] system_call+0x38/0xec
Cc: Douglas Miller <dougmill@linux.vnet.ibm.com>
Cc: linux-scsi@vger.kernel.org
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
commit f5fe1b51905df7cfe4fdfd85c5fb7bc5b71a094f upstream.
Commit 79bd99596b73 ("blk: improve order of bio handling in generic_make_request()")
changed current->bio_list so that it did not contain *all* of the
queued bios, but only those submitted by the currently running
make_request_fn.
There are two places which walk the list and requeue selected bios,
and others that check if the list is empty. These are no longer
correct.
So redefine current->bio_list to point to an array of two lists, which
contain all queued bios, and adjust various code to test or walk both
lists.
Signed-off-by: NeilBrown <neilb@suse.com>
Fixes: 79bd99596b73 ("blk: improve order of bio handling in generic_make_request()")
[jwang: backport to 4.4]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
[bwh: Restore changes in device-mapper from upstream version]
commit 79bd99596b7305ab08109a8bf44a6a4511dbf1cd upstream.
To avoid recursion on the kernel stack when stacked block devices
are in use, generic_make_request() will, when called recursively,
queue new requests for later handling. They will be handled when the
make_request_fn for the current bio completes.
If any bios are submitted by a make_request_fn, these will ultimately
be handled seqeuntially. If the handling of one of those generates
further requests, they will be added to the end of the queue.
This strict first-in-first-out behaviour can lead to deadlocks in
various ways, normally because a request might need to wait for a
previous request to the same device to complete. This can happen when
they share a mempool, and can happen due to interdependencies
particular to the device. Both md and dm have examples where this happens.
These deadlocks can be erradicated by more selective ordering of bios.
Specifically by handling them in depth-first order. That is: when the
handling of one bio generates one or more further bios, they are
handled immediately after the parent, before any siblings of the
parent. That way, when generic_make_request() calls make_request_fn
for some particular device, we can be certain that all previously
submited requests for that device have been completely handled and are
not waiting for anything in the queue of requests maintained in
generic_make_request().
An easy way to achieve this would be to use a last-in-first-out stack
instead of a queue. However this will change the order of consecutive
bios submitted by a make_request_fn, which could have unexpected consequences.
Instead we take a slightly more complex approach.
A fresh queue is created for each call to a make_request_fn. After it completes,
any bios for a different device are placed on the front of the main queue, followed
by any bios for the same device, followed by all bios that were already on
the queue before the make_request_fn was called.
This provides the depth-first approach without reordering bios on the same level.
This, by itself, it not enough to remove all deadlocks. It just makes
it possible for drivers to take the extra step required themselves.
To avoid deadlocks, drivers must never risk waiting for a request
after submitting one to generic_make_request. This includes never
allocing from a mempool twice in the one call to a make_request_fn.
A common pattern in drivers is to call bio_split() in a loop, handling
the first part and then looping around to possibly split the next part.
Instead, a driver that finds it needs to split a bio should queue
(with generic_make_request) the second part, handle the first part,
and then return. The new code in generic_make_request will ensure the
requests to underlying bios are processed first, then the second bio
that was split off. If it splits again, the same process happens. In
each case one bio will be completely handled before the next one is attempted.
With this is place, it should be possible to disable the
punt_bios_to_recover() recovery thread for many block devices, and
eventually it may be possible to remove it completely.
Ref: http://www.spinics.net/lists/raid/msg54680.html
Tested-by: Jinpu Wang <jinpu.wang@profitbricks.com>
Inspired-by: Lars Ellenberg <lars.ellenberg@linbit.com>
From: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com>
[ Upstream commit 25cdb64510644f3e854d502d69c73f21c6df88a9 ]
The WRITE_SAME commands are not present in the blk_default_cmd_filter
write_ok list, and thus are failed with -EPERM when the SG_IO ioctl()
is executed without CAP_SYS_RAWIO capability (e.g., unprivileged users).
[ sg_io() -> blk_fill_sghdr_rq() > blk_verify_command() -> -EPERM ]
The problem can be reproduced with the sg_write_same command
# sg_write_same --num 1 --xferlen 512 /dev/sda
# capsh --drop=cap_sys_rawio -- -c \
'sg_write_same --num 1 --xferlen 512 /dev/sda'
Write same: pass through os error: Operation not permitted
For comparison, the WRITE_VERIFY command does not observe this problem,
since it is in that list:
'sg_write_verify --num 1 --ilen 512 --lba 0 /dev/sda'
So, this patch adds the WRITE_SAME commands to the list, in order
for the SG_IO ioctl to finish successfully:
That case happens to be exercised by QEMU KVM guests with 'scsi-block' devices
(qemu "-device scsi-block" [1], libvirt "<disk type='block' device='lun'>" [2]),
which employs the SG_IO ioctl() and runs as an unprivileged user (libvirt-qemu).
In that scenario, when a filesystem (e.g., ext4) performs its zero-out calls,
which are translated to write-same calls in the guest kernel, and then into
SG_IO ioctls to the host kernel, SCSI I/O errors may be observed in the guest:
[...] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[...] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[...] sd 0:0:0:0: [sda] tag#0 Add. Sense: I/O process terminated
[...] sd 0:0:0:0: [sda] tag#0 CDB: Write Same(10) 41 00 01 04 e0 78 00 00 08 00
[...] blk_update_request: I/O error, dev sda, sector 17096824
Links:
[1] http://git.qemu.org/?p=qemu.git;a=commit;h=336a6915bc7089fb20fea4ba99972ad9a97c5f52
[2] https://libvirt.org/formatdomain.html#elementsDisks (see 'disk' -> 'device')
Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com>
Signed-off-by: Brahadambal Srinivasan <latha@linux.vnet.ibm.com>
Reported-by: Manjunatha H R <manjuhr1@in.ibm.com>
commit 87c279e613f848c691111b29d49de8df3f4f56da upstream.
Commit 0809e3ac6231 ("block: fix plug list flushing for nomerge queues")
updated blk_mq_make_request() to set request_count even when
blk_queue_nomerges() returns true. However, blk_mq_make_request() only
does limited plugging and doesn't use request_count;
blk_sq_make_request() is the one that should have been fixed. Do that
and get rid of the unnecessary work in the mq version.
Fixes: 0809e3ac6231 ("block: fix plug list flushing for nomerge queues")
Signed-off-by: Omar Sandoval <osandov@fb.com>
Reviewed-by: Ming Lei <tom.leiming@gmail.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
commit c02ebfdddbafa9a6a0f52fbd715e6bfa229af9d3 upstream.
Commit 0e87e58bf60e ("blk-mq: improve warning for running a queue on the
wrong CPU") attempts to avoid triggering the WARN_ON in
__blk_mq_run_hw_queue when the expected CPU is dead. Problem is, in the
last batch execution before round robin, blk_mq_hctx_next_cpu can
schedule a dead CPU and also update next_cpu to the next alive CPU in
the mask, which will trigger the WARN_ON despite the previous
workaround.
The following patch fixes this scenario by always scheduling the value
in hctx->next_cpu. This changes the moment when we round-robin the CPU
running the hctx, but it really doesn't matter, since it still executes
BLK_MQ_CPU_WORK_BATCH times in a row before switching to another CPU.
Fixes: 0e87e58bf60e ("blk-mq: improve warning for running a queue on the wrong CPU")
commit ebc4ff661fbe76781c6b16dfb7b754a5d5073f8e upstream.
cfq_cpd_alloc() which is the cpd_alloc_fn implementation for cfq was
incorrectly hard coding GFP_KERNEL instead of using the mask specified
through the @gfp parameter. This currently doesn't cause any actual
issues because all current callers specify GFP_KERNEL. Fix it.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: e4a9bde9589f ("blkcg: replace blkcg_policy->cpd_size with ->cpd_alloc/free_fn() methods")
commit 128394eff343fc6d2f32172f03e24829539c5835 upstream.
Both damn things interpret userland pointers embedded into the payload;
worse, they are actually traversing those. Leaving aside the bad
API design, this is very much _not_ safe to call with KERNEL_DS.
Bail out early if that happens.
commit bc27c01b5c46d3bfec42c96537c7a3fae0bb2cc4 upstream.
The meaning of the BLK_MQ_S_STOPPED flag is "do not call
.queue_rq()". Hence modify blk_mq_make_request() such that requests
are queued instead of issued if a queue has been stopped.
Reported-by: Ming Lei <tom.leiming@gmail.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
