commit d50235b7bc3ee0a0427984d763ea7534149531b4 upstream.
There's a race between elevator switching and normal io operation.
Because the allocation of struct elevator_queue and struct elevator_data
don't in a atomic operation.So there are have chance to use NULL
->elevator_data.
For example:
Thread A: Thread B
blk_queu_bio elevator_switch
spin_lock_irq(q->queue_block) elevator_alloc
elv_merge elevator_init_fn
Because call elevator_alloc, it can't hold queue_lock and the
->elevator_data is NULL.So at the same time, threadA call elv_merge and
nedd some info of elevator_data.So the crash happened.
Move the elevator_alloc into func elevator_init_fn, it make the
operations in a atomic operation.
Using the follow method can easy reproduce this bug
1:dd if=/dev/sdb of=/dev/null
2:while true;do echo noop > scheduler;echo deadline > scheduler;done
The test method also use this method.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
elevator_ops->elevator_init_fn() has a weird return value. It returns
a void * which the caller should assign to q->elevator->elevator_data
and %NULL return denotes init failure.
Update such that it returns integer 0/-errno and sets elevator_data
directly as necessary.
This makes the interface more conventional and eases further cleanup.
Cc: Vivek Goyal <vgoyal@redhat.com>
Let elevators set ->icq_size and ->icq_align in elevator_type and
elv_register() and elv_unregister() respectively create and destroy
kmem_cache for icq.
* elv_register() now can return failure. All callers updated.
* icq caches are automatically named "ELVNAME_io_cq".
* cfq_slab_setup/kill() are collapsed into cfq_init/exit().
* While at it, minor indentation change for iosched_cfq.elevator_name
for consistency.
This will help moving icq management to block core. This doesn't
introduce any functional change.
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Just use struct elevator_queue everywhere instead.
elv_register() always returns 0, and there isn't anything it does where
it should return an error (the only error condition is so grave that
it's handled with a BUG_ON).
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Some of the code has been gradually transitioned to using the proper
struct request_queue, but there's lots left. So do a full sweet of
the kernel and get rid of this typedef and replace its uses with
the proper type.
- ->init_queue() does not need the elevator passed in
- ->put_request() is a hot path and need not have the queue passed in
- cfq_update_io_seektime() does not need cfqd passed in
Some were kmalloc_node(), some were still kmalloc(). Change them all to
kmalloc_node().
Signed-off-by: Jens Axboe <axboe@suse.de>
There's a race between shutting down one io scheduler and firing up the
next, in which a new io could enter and cause the io scheduler to be
invoked with bad or NULL data.
To fix this, we need to maintain the queue lock for a bit longer.
Unfortunately we cannot do that, since the elevator init requires to be
run without the lock held. This isn't easily fixable, without also
changing the mempool API. So split the initialization into two parts,
and alloc-init operation and an attach operation. Then we can
preallocate the io scheduler and related structures, and run the attach
inside the lock after we detach the old one.
This patch has survived 30 minutes of 1 second io scheduler switching
with a very busy io load.
The original implementation directly used dispatch queue. As new
generic dispatch queue imposes stricter rules over ioscheds and
dispatch queue usage, this direct use becomes somewhat problematic.
This patch reimplements noop-iosched such that it complies to generic
iosched model better. Request merging with q->last_merge and
rq->queuelist.prev/next work again now.
Signed-off-by: Tejun Heo <htejun@gmail.com>
drivers/block/ is right now a mix of core and driver parts. Lets move
the core parts to a new top level directory. Al will move the fs/
related block parts to block/ next.
