path: root/block/elevator.c
2013-12-08elevator: acquire q->sysfs_lock in elevator_change()Tomoki Sekiyama
commit 7c8a3679e3d8e9d92d58f282161760a0e247df97 upstream. Add locking of q->sysfs_lock into elevator_change() (an exported function) to ensure it is held to protect q->elevator from elevator_init(), even if elevator_change() is called from non-sysfs paths. sysfs path (elv_iosched_store) uses __elevator_change(), non-locking version, as the lock is already taken by elv_iosched_store(). Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@hds.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Cc: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08elevator: Fix a race in elevator switching and md device initializationTomoki Sekiyama
commit eb1c160b22655fd4ec44be732d6594fd1b1e44f4 upstream. The soft lockup below happens at the boot time of the system using dm multipath and the udev rules to switch scheduler. [ 356.127001] BUG: soft lockup - CPU#3 stuck for 22s! [sh:483] [ 356.127001] RIP: 0010:[<ffffffff81072a7d>] [<ffffffff81072a7d>] lock_timer_base.isra.35+0x1d/0x50 ... [ 356.127001] Call Trace: [ 356.127001] [<ffffffff81073810>] try_to_del_timer_sync+0x20/0x70 [ 356.127001] [<ffffffff8118b08a>] ? kmem_cache_alloc_node_trace+0x20a/0x230 [ 356.127001] [<ffffffff810738b2>] del_timer_sync+0x52/0x60 [ 356.127001] [<ffffffff812ece22>] cfq_exit_queue+0x32/0xf0 [ 356.127001] [<ffffffff812c98df>] elevator_exit+0x2f/0x50 [ 356.127001] [<ffffffff812c9f21>] elevator_change+0xf1/0x1c0 [ 356.127001] [<ffffffff812caa50>] elv_iosched_store+0x20/0x50 [ 356.127001] [<ffffffff812d1d09>] queue_attr_store+0x59/0xb0 [ 356.127001] [<ffffffff812143f6>] sysfs_write_file+0xc6/0x140 [ 356.127001] [<ffffffff811a326d>] vfs_write+0xbd/0x1e0 [ 356.127001] [<ffffffff811a3ca9>] SyS_write+0x49/0xa0 [ 356.127001] [<ffffffff8164e899>] system_call_fastpath+0x16/0x1b This is caused by a race between md device initialization by multipathd and shell script to switch the scheduler using sysfs. - multipathd: SyS_ioctl -> do_vfs_ioctl -> dm_ctl_ioctl -> ctl_ioctl -> table_load -> dm_setup_md_queue -> blk_init_allocated_queue -> elevator_init q->elevator = elevator_alloc(q, e); // not yet initialized - sh -c 'echo deadline > /sys/$DEVPATH/queue/scheduler': elevator_switch (in the call trace above) struct elevator_queue *old = q->elevator; q->elevator = elevator_alloc(q, new_e); elevator_exit(old); // lockup! (*) - multipathd: (cont.) err = e->ops.elevator_init_fn(q); // init fails; q->elevator is modified (*) When del_timer_sync() is called, lock_timer_base() will loop infinitely while timer->base == NULL. In this case, as timer will never initialized, it results in lockup. This patch introduces acquisition of q->sysfs_lock around elevator_init() into blk_init_allocated_queue(), to provide mutual exclusion between initialization of the q->scheduler and switching of the scheduler. This should fix this bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=902012 Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@hds.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20elevator: Fix a race in elevator switchingJianpeng Ma
commit d50235b7bc3ee0a0427984d763ea7534149531b4 upstream. There's a race between elevator switching and normal io operation. Because the allocation of struct elevator_queue and struct elevator_data don't in a atomic operation.So there are have chance to use NULL ->elevator_data. For example: Thread A: Thread B blk_queu_bio elevator_switch spin_lock_irq(q->queue_block) elevator_alloc elv_merge elevator_init_fn Because call elevator_alloc, it can't hold queue_lock and the ->elevator_data is NULL.So at the same time, threadA call elv_merge and nedd some info of elevator_data.So the crash happened. Move the elevator_alloc into func elevator_init_fn, it make the operations in a atomic operation. Using the follow method can easy reproduce this bug 1:dd if=/dev/sdb of=/dev/null 2:while true;do echo noop > scheduler;echo deadline > scheduler;done The test method also use this method. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Cc: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-22block: implement runtime pm strategyLin Ming
When a request is added: If device is suspended or is suspending and the request is not a PM request, resume the device. When the last request finishes: Call pm_runtime_mark_last_busy(). When pick a request: If device is resuming/suspending, then only PM request is allowed to go. The idea and API is designed by Alan Stern and described here: http://marc.info/?l=linux-scsi&m=133727953625963&w=2 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-02-28Merge branch 'for-3.9/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO core bits from Jens Axboe: "Below are the core block IO bits for 3.9. It was delayed a few days since my workstation kept crashing every 2-8h after pulling it into current -git, but turns out it is a bug in the new pstate code (divide by zero, will report separately). In any case, it contains: - The big cfq/blkcg update from Tejun and and Vivek. - Additional block and writeback tracepoints from Tejun. - Improvement of the should sort (based on queues) logic in the plug flushing. - _io() variants of the wait_for_completion() interface, using io_schedule() instead of schedule() to contribute to io wait properly. - Various little fixes. You'll get two trivial merge conflicts, which should be easy enough to fix up" Fix up the trivial conflicts due to hlist traversal cleanups (commit b67bfe0d42ca: "hlist: drop the node parameter from iterators"). * 'for-3.9/core' of git://git.kernel.dk/linux-block: (39 commits) block: remove redundant check to bd_openers() block: use i_size_write() in bd_set_size() cfq: fix lock imbalance with failed allocations drivers/block/swim3.c: fix null pointer dereference block: don't select PERCPU_RWSEM block: account iowait time when waiting for completion of IO request sched: add wait_for_completion_io[_timeout] writeback: add more tracepoints block: add block_{touch|dirty}_buffer tracepoint buffer: make touch_buffer() an exported function block: add @req to bio_{front|back}_merge tracepoints block: add missing block_bio_complete() tracepoint block: Remove should_sort judgement when flush blk_plug block,elevator: use new hashtable implementation cfq-iosched: add hierarchical cfq_group statistics cfq-iosched: collect stats from dead cfqgs cfq-iosched: separate out cfqg_stats_reset() from cfq_pd_reset_stats() blkcg: make blkcg_print_blkgs() grab q locks instead of blkcg lock block: RCU free request_queue blkcg: implement blkg_[rw]stat_recursive_sum() and blkg_[rw]stat_merge() ...
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-22block: don't request module during elevator initTejun Heo
Block layer allows selecting an elevator which is built as a module to be selected as system default via kernel param "elevator=". This is achieved by automatically invoking request_module() whenever a new block device is initialized and the elevator is not available. This led to an interesting deadlock problem involving async and module init. Block device probing running off an async job invokes request_module(). While the module is being loaded, it performs async_synchronize_full() which ends up waiting for the async job which is already waiting for request_module() to finish, leading to deadlock. Invoking request_module() from deep in block device init path is already nasty in itself. It seems best to avoid these situations from the beginning by moving on-demand module loading out of block init path. The previous patch made sure that the default elevator module is loaded early during boot if available. This patch removes on-demand loading of the default elevator from elevator init path. As the module would have been loaded during boot, userland-visible behavior difference should be minimal. For more details, please refer to the following thread. http://thread.gmane.org/gmane.linux.kernel/1420814 v2: The bool parameter was named @request_module which conflicted with request_module(). This built okay w/ CONFIG_MODULES because request_module() was defined as a macro. W/o CONFIG_MODULES, it causes build breakage. Rename the parameter to @try_loading. Reported by Fengguang. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alex Riesen <raa.lkml@gmail.com> Cc: Fengguang Wu <fengguang.wu@intel.com>
2013-01-18init, block: try to load default elevator module early during bootTejun Heo
This patch adds default module loading and uses it to load the default block elevator. During boot, it's called right after initramfs or initrd is made available and right before control is passed to userland. This ensures that as long as the modules are available in the usual places in initramfs, initrd or the root filesystem, the default modules are loaded as soon as possible. This will replace the on-demand elevator module loading from elevator init path. v2: Fixed build breakage when !CONFIG_BLOCK. Reported by kbuild test robot. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alex Riesen <raa.lkml@gmail.com> Cc: Fengguang We <fengguang.wu@intel.com>
2013-01-11block,elevator: use new hashtable implementationSasha Levin
Switch elevator to use the new hashtable implementation. This reduces the amount of generic unrelated code in the elevator. This also removes the dymanic allocation of the hash table. The size of the table is constant so there's no point in paying the price of an extra dereference when accessing it. This patch depends on d9b482c ("hashtable: introduce a small and naive hashtable") which was merged in v3.6. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-11-09block: recursive merge requestsShaohua Li
In a workload, thread 1 accesses a, a+2, ..., thread 2 accesses a+1, a+3,.... When the requests are flushed to queue, a and a+1 are merged to (a, a+1), a+2 and a+3 too to (a+2, a+3), but (a, a+1) and (a+2, a+3) aren't merged. If we do recursive merge for such interleave access, some workloads throughput get improvement. A recent worload I'm checking on is swap, below change boostes the throughput around 5% ~ 10%. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-20block: Clean up special command handling logicMartin K. Petersen
Remove special-casing of non-rw fs style requests (discard). The nomerge flags are consolidated in blk_types.h, and rq_mergeable() and bio_mergeable() have been modified to use them. bio_is_rw() is used in place of bio_has_data() a few places. This is done to to distinguish true reads and writes from other fs type requests that carry a payload (e.g. write same). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: implement per-queue policy activationTejun Heo
All blkcg policies were assumed to be enabled on all request_queues. Due to various implementation obstacles, during the recent blkcg core updates, this was temporarily implemented as shooting down all !root blkgs on elevator switch and policy [de]registration combined with half-broken in-place root blkg updates. In addition to being buggy and racy, this meant losing all blkcg configurations across those events. Now that blkcg is cleaned up enough, this patch replaces the temporary implementation with proper per-queue policy activation. Each blkcg policy should call the new blkcg_[de]activate_policy() to enable and disable the policy on a specific queue. blkcg_activate_policy() allocates and installs policy data for the policy for all existing blkgs. blkcg_deactivate_policy() does the reverse. If a policy is not enabled for a given queue, blkg printing / config functions skip the respective blkg for the queue. blkcg_activate_policy() also takes care of root blkg creation, and cfq_init_queue() and blk_throtl_init() are updated accordingly. This replaces blkcg_bypass_{start|end}() and update_root_blkg_pd() unnecessary. Dropped. v2: cfq_init_queue() was returning uninitialized @ret on root_group alloc failure if !CONFIG_CFQ_GROUP_IOSCHED. Fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-06block: implement bio_associate_current()Tejun Heo
IO scheduling and cgroup are tied to the issuing task via io_context and cgroup of %current. Unfortunately, there are cases where IOs need to be routed via a different task which makes scheduling and cgroup limit enforcement applied completely incorrectly. For example, all bios delayed by blk-throttle end up being issued by a delayed work item and get assigned the io_context of the worker task which happens to serve the work item and dumped to the default block cgroup. This is double confusing as bios which aren't delayed end up in the correct cgroup and makes using blk-throttle and cfq propio together impossible. Any code which punts IO issuing to another task is affected which is getting more and more common (e.g. btrfs). As both io_context and cgroup are firmly tied to task including userland visible APIs to manipulate them, it makes a lot of sense to match up tasks to bios. This patch implements bio_associate_current() which associates the specified bio with %current. The bio will record the associated ioc and blkcg at that point and block layer will use the recorded ones regardless of which task actually ends up issuing the bio. bio release puts the associated ioc and blkcg. It grabs and remembers ioc and blkcg instead of the task itself because task may already be dead by the time the bio is issued making ioc and blkcg inaccessible and those are all block layer cares about. elevator_set_req_fn() is updated such that the bio elvdata is being allocated for is available to the elevator. This doesn't update block cgroup policies yet. Further patches will implement the support. -v2: #ifdef CONFIG_BLK_CGROUP added around bio->bi_ioc dereference in rq_ioc() to fix build breakage. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Kent Overstreet <koverstreet@google.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-06blkcg: unify blkg's for blkcg policiesTejun Heo
Currently, blkg is per cgroup-queue-policy combination. This is unnatural and leads to various convolutions in partially used duplicate fields in blkg, config / stat access, and general management of blkgs. This patch make blkg's per cgroup-queue and let them serve all policies. blkgs are now created and destroyed by blkcg core proper. This will allow further consolidation of common management logic into blkcg core and API with better defined semantics and layering. As a transitional step to untangle blkg management, elvswitch and policy [de]registration, all blkgs except the root blkg are being shot down during elvswitch and bypass. This patch adds blkg_root_update() to update root blkg in place on policy change. This is hacky and racy but should be good enough as interim step until we get locking simplified and switch over to proper in-place update for all blkgs. -v2: Root blkgs need to be updated on elvswitch too and blkg_alloc() comment wasn't updated according to the function change. Fixed. Both pointed out by Vivek. -v3: v2 updated blkg_destroy_all() to invoke update_root_blkg_pd() for all policies. This freed root pd during elvswitch before the last queue finished exiting and led to oops. Directly invoke update_root_blkg_pd() only on BLKIO_POLICY_PROP from cfq_exit_queue(). This also is closer to what will be done with proper in-place blkg update. Reported by Vivek. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-06blkcg: let blkcg core manage per-queue blkg list and counterTejun Heo
With the previous patch to move blkg list heads and counters to request_queue and blkg, logic to manage them in both policies are almost identical and can be moved to blkcg core. This patch moves blkg link logic into blkg_lookup_create(), implements common blkg unlink code in blkg_destroy(), and updates blkg_destory_all() so that it's policy specific and can skip root group. The updated blkg_destroy_all() is now used to both clear queue for bypassing and elv switching, and release all blkgs on q exit. This patch introduces a race window where policy [de]registration may race against queue blkg clearing. This can only be a problem on cfq unload and shouldn't be a real problem in practice (and we have many other places where this race already exists). Future patches will remove these unlikely races. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-06blkcg: shoot down blkio_groups on elevator switchTejun Heo
Elevator switch may involve changes to blkcg policies. Implement shoot down of blkio_groups. Combined with the previous bypass updates, the end goal is updating blkcg core such that it can ensure that blkcg's being affected become quiescent and don't have any per-blkg data hanging around before commencing any policy updates. Until queues are made aware of the policies that applies to them, as an interim step, all per-policy blkg data will be shot down. * blk-throtl doesn't need this change as it can't be disabled for a live queue; however, update it anyway as the scheduled blkg unification requires this behavior change. This means that blk-throtl configuration will be unnecessarily lost over elevator switch. This oddity will be removed after blkcg learns to associate individual policies with request_queues. * blk-throtl dosen't shoot down root_tg. This is to ease transition. Unified blkg will always have persistent root group and not shooting down root_tg for now eases transition to that point by avoiding having to update td->root_tg and is safe as blk-throtl can never be disabled -v2: Vivek pointed out that group list is not guaranteed to be empty on return from clear function if it raced cgroup removal and lost. Fix it by waiting a bit and retrying. This kludge will soon be removed once locking is updated such that blkg is never in limbo state between blkcg and request_queue locks. blk-throtl no longer shoots down root_tg to avoid breaking td->root_tg. Also, Nest queue_lock inside blkio_list_lock not the other way around to avoid introduce possible deadlock via blkcg lock. -v3: blkcg_clear_queue() repositioned and renamed to blkg_destroy_all() to increase consistency with later changes. cfq_clear_queue() updated to check q->elevator before dereferencing it to avoid NULL dereference on not fully initialized queues (used by later change). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-06block: implement blk_queue_bypass_start/end()Tejun Heo
Rename and extend elv_queisce_start/end() to blk_queue_bypass_start/end() which are exported and supports nesting via @q->bypass_depth. Also add blk_queue_bypass() to test bypass state. This will be further extended and used for blkio_group management. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-06elevator: make elevator_init_fn() return 0/-errnoTejun Heo
elevator_ops->elevator_init_fn() has a weird return value. It returns a void * which the caller should assign to q->elevator->elevator_data and %NULL return denotes init failure. Update such that it returns integer 0/-errno and sets elevator_data directly as necessary. This makes the interface more conventional and eases further cleanup. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-06elevator: clear auxiliary data earlier during elevator switchTejun Heo
Elevator switch tries hard to keep as much as context until new elevator is ready so that it can revert to the original state if initializing the new elevator fails for some reason. Unfortunately, with more auxiliary contexts to manage, this makes elevator init and exit paths too complex and fragile. This patch makes elevator_switch() unregister the current elevator and flush icq's before start initializing the new one. As we still keep the old elevator itself, the only difference is that we lose icq's on rare occassions of switching failure, which isn't critical at all. Note that this makes explicit elevator parameter to elevator_init_queue() and __elv_register_queue() unnecessary as they always can use the current elevator. This patch enables block cgroup cleanups. -v2: blk_add_trace_msg() prints elevator name from @new_e instead of @e->type as the local variable no longer exists. This caused build failure on CONFIG_BLK_DEV_IO_TRACE. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-08block: separate out blk_rq_merge_ok() and blk_try_merge() from elevator ↵Tejun Heo
functions blk_rq_merge_ok() is the elevator-neutral part of merge eligibility test. blk_try_merge() determines merge direction and expects the caller to have tested elv_rq_merge_ok() previously. elv_rq_merge_ok() now wraps blk_rq_merge_ok() and then calls elv_iosched_allow_merge(). elv_try_merge() is removed and the two callers are updated to call elv_rq_merge_ok() explicitly followed by blk_try_merge(). While at it, make rq_merge_ok() functions return bool. This is to prepare for plug merge update and doesn't introduce any behavior change. This is based on Jens' patch to skip elevator_allow_merge_fn() from plug merge. Signed-off-by: Tejun Heo <tj@kernel.org> LKML-Reference: <4F16F3CA.90904@kernel.dk> Original-patch-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-01-15Revert "block: recursive merge requests"Jens Axboe
This reverts commit 274193224cdabd687d804a26e0150bb20f2dd52c. We have some problems related to selection of empty queues that need to be resolved, evidence so far points to the recursive merge logic making either being the cause or at least the accelerator for this. So revert it for now, until we figure this out. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-16block: recursive merge requestsShaohua Li
In my workload, thread 1 accesses a, a+2, ..., thread 2 accesses a+1, a+3,.... When the requests are flushed to queue, a and a+1 are merged to (a, a+1), a+2 and a+3 too to (a+2, a+3), but (a, a+1) and (a+2, a+3) aren't merged. With recursive merge below, the workload throughput gets improved 20% and context switch drops 60%. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: move io_cq exit/release to blk-ioc.cTejun Heo
With kmem_cache managed by blk-ioc, io_cq exit/release can be moved to blk-ioc too. The odd ->io_cq->exit/release() callbacks are replaced with elevator_ops->elevator_exit_icq_fn() with unlinking from both ioc and q, and freeing automatically handled by blk-ioc. The elevator operation only need to perform exit operation specific to the elevator - in cfq's case, exiting the cfqq's. Also, clearing of io_cq's on q detach is moved to block core and automatically performed on elevator switch and q release. Because the q io_cq points to might be freed before RCU callback for the io_cq runs, blk-ioc code should remember to which cache the io_cq needs to be freed when the io_cq is released. New field io_cq->__rcu_icq_cache is added for this purpose. As both the new field and rcu_head are used only after io_cq is released and the q/ioc_node fields aren't, they are put into unions. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: move icq cache management to block coreTejun Heo
Let elevators set ->icq_size and ->icq_align in elevator_type and elv_register() and elv_unregister() respectively create and destroy kmem_cache for icq. * elv_register() now can return failure. All callers updated. * icq caches are automatically named "ELVNAME_io_cq". * cfq_slab_setup/kill() are collapsed into cfq_init/exit(). * While at it, minor indentation change for iosched_cfq.elevator_name for consistency. This will help moving icq management to block core. This doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: move cfqd->icq_list to request_queue and add request->elv.icqTejun Heo
Most of icq management is about to be moved out of cfq into blk-ioc. This patch prepares for it. * Move cfqd->icq_list to request_queue->icq_list * Make request explicitly point to icq instead of through elevator private data. ->elevator_private[3] is replaced with sub struct elv which contains icq pointer and priv[2]. cfq is updated accordingly. * Meaningless clearing of ->elevator_private[0] removed from elv_set_request(). At that point in code, the field was guaranteed to be %NULL anyway. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block: remove elevator_queue->opsTejun Heo
elevator_queue->ops points to the same ops struct ->elevator_type.ops is pointing to. The only effect of caching it in elevator_queue is shorter notation - it doesn't save any indirect derefence. Relocate elevator_type->list which used only during module init/exit to the end of the structure, rename elevator_queue->elevator_type to ->type, and replace elevator_queue->ops with elevator_queue->type.ops. This doesn't introduce any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block: reorder elevator switch sequenceTejun Heo
Elevator switch sequence first attached the new elevator, then tried registering it (sysfs) and if that failed attached back the old elevator. However, sysfs registration doesn't require the elevator to be attached, so there is no reason to do the "detach, attach new, register, maybe re-attach old" sequence. It can just do "register, detach, attach". * elevator_init_queue() is updated to set ->elevator_data directly and return 0 / -errno. This allows elevator_exit() on an unattached elevator. * __elv_unregister_queue() which was necessary to unregister unattached q is removed in favor of __elv_register_queue() which can register unattached q. * elevator_attach() becomes a single assignment and obscures more then it helps. Dropped. This will help cleaning up io_context handling across elevator switch. This patch doesn't introduce visible behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: remove delayed unlinkTejun Heo
Now that all cic's are immediately unlinked from both ioc and queue, lazy dropping from lookup path and trimming on elevator unregister are unnecessary. Kill them and remove now unused elevator_ops->trim(). This also leaves call_for_each_cic() without any user. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: fix request_queue lifetime handling by making blk_queue_cleanup() ↵Tejun Heo
properly shutdown request_queue is refcounted but actually depdends on lifetime management from the queue owner - on blk_cleanup_queue(), block layer expects that there's no request passing through request_queue and no new one will. This is fundamentally broken. The queue owner (e.g. SCSI layer) doesn't have a way to know whether there are other active users before calling blk_cleanup_queue() and other users (e.g. bsg) don't have any guarantee that the queue is and would stay valid while it's holding a reference. With delay added in blk_queue_bio() before queue_lock is grabbed, the following oops can be easily triggered when a device is removed with in-flight IOs. sd 0:0:1:0: [sdb] Stopping disk ata1.01: disabled general protection fault: 0000 [#1] PREEMPT SMP CPU 2 Modules linked in: Pid: 648, comm: test_rawio Not tainted 3.1.0-rc3-work+ #56 Bochs Bochs RIP: 0010:[<ffffffff8137d651>] [<ffffffff8137d651>] elv_rqhash_find+0x61/0x100 ... Process test_rawio (pid: 648, threadinfo ffff880019efa000, task ffff880019ef8a80) ... Call Trace: [<ffffffff8137d774>] elv_merge+0x84/0xe0 [<ffffffff81385b54>] blk_queue_bio+0xf4/0x400 [<ffffffff813838ea>] generic_make_request+0xca/0x100 [<ffffffff81383994>] submit_bio+0x74/0x100 [<ffffffff811c53ec>] dio_bio_submit+0xbc/0xc0 [<ffffffff811c610e>] __blockdev_direct_IO+0x92e/0xb40 [<ffffffff811c39f7>] blkdev_direct_IO+0x57/0x60 [<ffffffff8113b1c5>] generic_file_aio_read+0x6d5/0x760 [<ffffffff8118c1ca>] do_sync_read+0xda/0x120 [<ffffffff8118ce55>] vfs_read+0xc5/0x180 [<ffffffff8118cfaa>] sys_pread64+0x9a/0xb0 [<ffffffff81afaf6b>] system_call_fastpath+0x16/0x1b This happens because blk_queue_cleanup() destroys the queue and elevator whether IOs are in progress or not and DEAD tests are sprinkled in the request processing path without proper synchronization. Similar problem exists for blk-throtl. On queue cleanup, blk-throtl is shutdown whether it has requests in it or not. Depending on timing, it either oopses or throttled bios are lost putting tasks which are waiting for bio completion into eternal D state. The way it should work is having the usual clear distinction between shutdown and release. Shutdown drains all currently pending requests, marks the queue dead, and performs partial teardown of the now unnecessary part of the queue. Even after shutdown is complete, reference holders are still allowed to issue requests to the queue although they will be immmediately failed. The rest of teardown happens on release. This patch makes the following changes to make blk_queue_cleanup() behave as proper shutdown. * QUEUE_FLAG_DEAD is now set while holding both q->exit_mutex and queue_lock. * Unsynchronized DEAD check in generic_make_request_checks() removed. This couldn't make any meaningful difference as the queue could die after the check. * blk_drain_queue() updated such that it can drain all requests and is now called during cleanup. * blk_throtl updated such that it checks DEAD on grabbing queue_lock, drains all throttled bios during cleanup and free td when queue is released. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: reorganize queue drainingTejun Heo
Reorganize queue draining related code in preparation of queue exit changes. * Factor out actual draining from elv_quiesce_start() to blk_drain_queue(). * Make elv_quiesce_start/end() responsible for their own locking. * Replace open-coded ELVSWITCH clearing in elevator_switch() with elv_quiesce_end(). This patch doesn't cause any visible functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-09-12elevator: use ELV_NAME_MAX instead of magic number 16 for chosen_elevatorWang Sheng-Hui
We have ELV_NAME_MAX defined to 16, and hence we should use it instead of the magic nubmer 16 for elevator's name string. Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-02iosched: prevent aliased requests from starving other I/OJeff Moyer
Hi, Jens, If you recall, I posted an RFC patch for this back in July of last year: http://lkml.org/lkml/2010/7/13/279 The basic problem is that a process can issue a never-ending stream of async direct I/Os to the same sector on a device, thus starving out other I/O in the system (due to the way the alias handling works in both cfq and deadline). The solution I proposed back then was to start dispatching from the fifo after a certain number of aliases had been dispatched. Vivek asked why we had to treat aliases differently at all, and I never had a good answer. So, I put together a simple patch which allows aliases to be added to the rb tree (it adds them to the right, though that doesn't matter as the order isn't guaranteed anyway). I think this is the preferred solution, as it doesn't break up time slices in CFQ or batches in deadline. I've tested it, and it does solve the starvation issue. Let me know what you think. Cheers, Jeff Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-20block: get rid of on-stack plugging debug checksJens Axboe
We don't need them anymore, so kill: - REQ_ON_PLUG checks in various places - !rq_mergeable() check in plug merging Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-20Merge commit 'v2.6.39' into for-2.6.40/coreJens Axboe
Since for-2.6.40/core was forked off the 2.6.39 devel tree, we've had churn in the core area that makes it difficult to handle patches for eg cfq or blk-throttle. Instead of requiring that they be based in older versions with bugs that have been fixed later in the rc cycle, merge in 2.6.39 final. Also fixes up conflicts in the below files. Conflicts: drivers/block/paride/pcd.c drivers/cdrom/viocd.c drivers/ide/ide-cd.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-05iosched: remove redundant sprintfKees Cook
After the anticipatory scheduler was dropped, there was no need to special-case the request_module string. As such, drop the redundant sprintf and stack variable. Signed-off-by: Kees Cook <kees.cook@canonical.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-21elevator: check for ELEVATOR_INSERT_SORT_MERGE in !elvpriv case tooJens Axboe
The sort insert is the one that goes to the IO scheduler. With the SORT_MERGE addition, we could bypass IO scheduler setup but still ask the IO scheduler to insert the request. This would cause an oops on switching IO schedulers through the sysfs interface, unless the disk just happened to be idle while it occured. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-18block: add blk_run_queue_asyncChristoph Hellwig
Instead of overloading __blk_run_queue to force an offload to kblockd add a new blk_run_queue_async helper to do it explicitly. I've kept the blk_queue_stopped check for now, but I suspect it's not needed as the check we do when the workqueue items runs should be enough. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-05block: get rid of elv_insert() interfaceJens Axboe
Merge it with __elv_add_request(), it's pretty pointless to have a function with only two callers. The main interface is elv_add_request()/__elv_add_request(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-21block: attempt to merge with existing requests on plug flushJens Axboe
One of the disadvantages of on-stack plugging is that we potentially lose out on merging since all pending IO isn't always visible to everybody. When we flush the on-stack plugs, right now we don't do any checks to see if potential merge candidates could be utilized. Correct this by adding a new insert variant, ELEVATOR_INSERT_SORT_MERGE. It works just ELEVATOR_INSERT_SORT, but first checks whether we can merge with an existing request before doing the insertion (if we fail merging). This fixes a regression with multiple processes issuing IO that can be merged. Thanks to Shaohua Li <shaohua.li@intel.com> for testing and fixing an accounting bug. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: initial patch for on-stack per-task pluggingJens Axboe
This patch adds support for creating a queuing context outside of the queue itself. This enables us to batch up pieces of IO before grabbing the block device queue lock and submitting them to the IO scheduler. The context is created on the stack of the process and assigned in the task structure, so that we can auto-unplug it if we hit a schedule event. The current queue plugging happens implicitly if IO is submitted to an empty device, yet callers have to remember to unplug that IO when they are going to wait for it. This is an ugly API and has caused bugs in the past. Additionally, it requires hacks in the vm (->sync_page() callback) to handle that logic. By switching to an explicit plugging scheme we make the API a lot nicer and can get rid of the ->sync_page() hack in the vm. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-04Merge branch 'for-linus' of ../linux-2.6-block into block-for-2.6.39/coreTejun Heo
This merge creates two set of conflicts. One is simple context conflicts caused by removal of throtl_scheduled_delayed_work() in for-linus and removal of throtl_shutdown_timer_wq() in for-2.6.39/core. The other is caused by commit 255bb490c8 (block: blk-flush shouldn't call directly into q->request_fn() __blk_run_queue()) in for-linus crashing with FLUSH reimplementation in for-2.6.39/core. The conflict isn't trivial but the resolution is straight-forward. * __blk_run_queue() calls in flush_end_io() and flush_data_end_io() should be called with @force_kblockd set to %true. * elv_insert() in blk_kick_flush() should use %ELEVATOR_INSERT_REQUEUE. Both changes are to avoid invoking ->request_fn() directly from request completion path and closely match the changes in the commit 255bb490c8. Signed-off-by: Tejun Heo <tj@kernel.org>
2011-03-02block: add @force_kblockd to __blk_run_queue()Tejun Heo
__blk_run_queue() automatically either calls q->request_fn() directly or schedules kblockd depending on whether the function is recursed. blk-flush implementation needs to be able to explicitly choose kblockd. Add @force_kblockd. All the current users are converted to specify %false for the parameter and this patch doesn't introduce any behavior change. stable: This is prerequisite for fixing ide oops caused by the new blk-flush implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-11block: share request flush fields with elevator_privateMike Snitzer
Flush requests are never put on the IO scheduler. Convert request structure's elevator_private* into an array and have the flush fields share a union with it. Reclaim the space lost in 'struct request' by moving 'completion_data' back in the union with 'rb_node'. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-25block: reimplement FLUSH/FUA to support mergeTejun Heo
The current FLUSH/FUA support has evolved from the implementation which had to perform queue draining. As such, sequencing is done queue-wide one flush request after another. However, with the draining requirement gone, there's no reason to keep the queue-wide sequential approach. This patch reimplements FLUSH/FUA support such that each FLUSH/FUA request is sequenced individually. The actual FLUSH execution is double buffered and whenever a request wants to execute one for either PRE or POSTFLUSH, it queues on the pending queue. Once certain conditions are met, a flush request is issued and on its completion all pending requests proceed to the next sequence. This allows arbitrary merging of different type of flushes. How they are merged can be primarily controlled and tuned by adjusting the above said 'conditions' used to determine when to issue the next flush. This is inspired by Darrick's patches to merge multiple zero-data flushes which helps workloads with highly concurrent fsync requests. * As flush requests are never put on the IO scheduler, request fields used for flush share space with rq->rb_node. rq->completion_data is moved out of the union. This increases the request size by one pointer. As rq->elevator_private* are used only by the iosched too, it is possible to reduce the request size further. However, to do that, we need to modify request allocation path such that iosched data is not allocated for flush requests. * FLUSH/FUA processing happens on insertion now instead of dispatch. - Comments updated as per Vivek and Mike. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "Darrick J. Wong" <djwong@us.ibm.com> Cc: Shaohua Li <shli@kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: remove REQ_HARDBARRIERChristoph Hellwig
REQ_HARDBARRIER is dead now, so remove the leftovers. What's left at this point is: - various checks inside the block layer. - sanity checks in bio based drivers. - now unused bio_empty_barrier helper. - Xen blockfront use of BLKIF_OP_WRITE_BARRIER - it's dead for a while, but Xen really needs to sort out it's barrier situaton. - setting of ordered tags in uas - dead code copied from old scsi drivers. - scsi different retry for barriers - it's dead and should have been removed when flushes were converted to FS requests. - blktrace handling of barriers - removed. Someone who knows blktrace better should add support for REQ_FLUSH and REQ_FUA, though. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-19Merge branch 'v2.6.36-rc8' into for-2.6.37/barrierJens Axboe
Conflicts: block/blk-core.c drivers/block/loop.c mm/swapfile.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-07elevator: fix oops on early call to elevator_change()Jens Axboe
2.6.36 introduces an API for drivers to switch the IO scheduler instead of manually calling the elevator exit and init functions. This API was added since q->elevator must be cleared in between those two calls. And since we already have this functionality directly from use by the sysfs interface to switch schedulers online, it was prudent to reuse it internally too. But this API needs the queue to be in a fully initialized state before it is called, or it will attempt to unregister elevator kobjects before they have been added. This results in an oops like this: BUG: unable to handle kernel NULL pointer dereference at 0000000000000051 IP: [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0 PGD 47ddfc067 PUD 47c6a1067 PMD 0 Oops: 0000 [#1] PREEMPT SMP last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/0000:04:00.1/irq CPU 2 Modules linked in: t(+) loop hid_apple usbhid ahci ehci_hcd uhci_hcd libahci usbcore nls_base igb Pid: 7319, comm: modprobe Not tainted 2.6.36-rc6+ #132 QSSC-S4R/QSSC-S4R RIP: 0010:[<ffffffff8116f15e>] [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0 RSP: 0018:ffff88027da25d08 EFLAGS: 00010246 RAX: ffff88047c68c528 RBX: 00000000fffffffe RCX: 0000000000000000 RDX: 000000000000002f RSI: 000000000000002f RDI: ffff88047e196c88 RBP: ffff88027da25d38 R08: 0000000000000000 R09: d84156c5635688c0 R10: d84156c5635688c0 R11: 0000000000000000 R12: ffff88047e196c88 R13: 0000000000000000 R14: 0000000000000000 R15: ffff88047c68c528 FS: 00007fcb0b26f6e0(0000) GS:ffff880287400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000051 CR3: 000000047e76e000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process modprobe (pid: 7319, threadinfo ffff88027da24000, task ffff88027d377090) Stack: ffff88027da25d58 ffff88047c68c528 00000000fffffffe ffff88047e196c88 <0> ffff88047c68c528 ffff88047e05bd90 ffff88027da25d78 ffffffff8123fb77 <0> ffff88047e05bd90 0000000000000000 ffff88047e196c88 ffff88047c68c528 Call Trace: [<ffffffff8123fb77>] kobject_add_internal+0xe7/0x1f0 [<ffffffff8123fd98>] kobject_add_varg+0x38/0x60 [<ffffffff8123feb9>] kobject_add+0x69/0x90 [<ffffffff8116efe0>] ? sysfs_remove_dir+0x20/0xa0 [<ffffffff8103d48d>] ? sub_preempt_count+0x9d/0xe0 [<ffffffff8143de20>] ? _raw_spin_unlock+0x30/0x50 [<ffffffff8116efe0>] ? sysfs_remove_dir+0x20/0xa0 [<ffffffff8116eff4>] ? sysfs_remove_dir+0x34/0xa0 [<ffffffff81224204>] elv_register_queue+0x34/0xa0 [<ffffffff81224aad>] elevator_change+0xfd/0x250 [<ffffffffa007e000>] ? t_init+0x0/0x361 [t] [<ffffffffa007e000>] ? t_init+0x0/0x361 [t] [<ffffffffa007e0a8>] t_init+0xa8/0x361 [t] [<ffffffff810001de>] do_one_initcall+0x3e/0x170 [<ffffffff8108c3fd>] sys_init_module+0xbd/0x220 [<ffffffff81002f2b>] system_call_fastpath+0x16/0x1b Code: e5 41 56 41 55 41 54 49 89 fc 53 48 83 ec 10 48 85 ff 74 52 48 8b 47 18 49 c7 c5 00 46 61 81 48 85 c0 74 04 4c 8b 68 30 45 31 f6 <41> 80 7d 51 00 74 0e 49 8b 44 24 28 4c 89 e7 ff 50 20 49 89 c6 RIP [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0 RSP <ffff88027da25d08> CR2: 0000000000000051 ---[ end trace a6541d3bf07945df ]--- Fix this by adding a registered bit to the elevator queue, which is set when the sysfs kobjects have been registered. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: drop barrier ordering by queue drainingTejun Heo
Filesystems will take all the responsibilities for ordering requests around commit writes and will only indicate how the commit writes themselves should be handled by block layers. This patch drops barrier ordering by queue draining from block layer. Ordering by draining implementation was somewhat invasive to request handling. List of notable changes follow. * Each queue has 1 bit color which is flipped on each barrier issue. This is used to track whether a given request is issued before the current barrier or not. REQ_ORDERED_COLOR flag and coloring implementation in __elv_add_request() are removed. * Requests which shouldn't be processed yet for draining were stalled by returning -EAGAIN from blk_do_ordered() according to the test result between blk_ordered_req_seq() and blk_blk_ordered_cur_seq(). This logic is removed. * Draining completion logic in elv_completed_request() removed. * All barrier sequence requests were queued to request queue and then trckled to lower layer according to progress and thus maintaining request orders during requeue was necessary. This is replaced by queueing the next request in the barrier sequence only after the current one is complete from blk_ordered_complete_seq(), which removes the need for multiple proxy requests in struct request_queue and the request sorting logic in the ELEVATOR_INSERT_REQUEUE path of elv_insert(). * As barriers no longer have ordering constraints, there's no need to dump the whole elevator onto the dispatch queue on each barrier. Insert barriers at the front instead. * If other barrier requests come to the front of the dispatch queue while one is already in progress, they are stored in q->pending_barriers and restored to dispatch queue one-by-one after each barrier completion from blk_ordered_complete_seq(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
