path: root/block/blk-tag.c
2012-09-12block/blk-tag.c: Remove useless kfreePeter Senna Tschudin
Remove useless kfree() and clean up code related to the removal. The semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ position p1,p2; expression x; @@ if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; } @unchanged exists@ position r.p1,r.p2; expression e <= r.x,x,e1; iterator I; statement S; @@ if (x@p1 == NULL) { ... when != I(x,...) S when != e = e1 when != e += e1 when != e -= e1 when != ++e when != --e when != e++ when != e-- when != &e kfree@p2(x); ... return ...; } @ok depends on unchanged exists@ position any r.p1; position r.p2; expression x; @@ ... when != true x@p1 == NULL kfree@p2(x); @depends on !ok && unchanged@ position r.p2; expression x; @@ *kfree@p2(x); // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-29block: fix blk_queue_end_tag()Dan Williams
Commit 5e081591 "block: warn if tag is greater than real_max_depth" cleaned up blk_queue_end_tag() to warn when the tag is truly invalid (greater than real_max_depth). However, it changed behavior in the tag < max_depth case to not end the request. Leading to triggering of BUG_ON(blk_queued_rq(rq)) in the request completion path: http://marc.info/?l=linux-kernel&m=132204370518629&w=2 In order to allow blk_queue_resize_tags() to shrink the tag space blk_queue_end_tag() must always complete tags with a value less than real_max_depth regardless of the current max_depth. The comment about "handling the shrink case" seems to be what prompted changes in this space, so remove it and BUG on all invalid tags (made even simpler by Matthew's suggestion to use an unsigned compare). Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: Tao Ma <boyu.mt@taobao.com> Cc: Matthew Wilcox <matthew@wil.cx> Reported-by: Meelis Roos <mroos@ut.ee> Reported-by: Ed Nadolski <edmund.nadolski@intel.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-25block: warn if tag is greater than real_max_depth.Tao Ma
In case tag depth is reduced, it is max_depth not real_max_depth. So we should allow a request with tag >= max_depth, but for a tag >= real_max_depth, there really should be some problem. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-10-06block: use proper BLK_RW_ASYNC in blk_queue_start_tag()Jens Axboe
Makes it easier to read than the 0. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-20block: change the tag sync vs async restriction logicJens Axboe
Make them fully share the tag space, but disallow async requests using the last any two slots. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29block/blk-tag.c: cleanup kernel-docQinghuang Feng
There is no argument named @tags in blk_init_tags, remove its' comment. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: reserve some tags just for sync IOJens Axboe
By only allowing async IO to consume 3/4 ths of the tag depth, we always have slots free to serve sync IO. This is important to avoid having writes fill the entire tag queue, thus starving reads. Original patch and idea from Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Add some block/ source files to the kernel-api docbook. Fix kernel-doc ↵Randy Dunlap
notation in them as needed. Fix changed function parameter names. Fix typos/spellos. In comments, change REQ_SPECIAL to REQ_TYPE_SPECIAL and REQ_BLOCK_PC to REQ_TYPE_BLOCK_PC. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-27block: remove unused ->busy part of the block queue tag mapMatthew Wilcox
It's not used for anything. On top of that, it's racy and can thus trigger a faulty BUG_ON() in __blk_free_tags() on queue exit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07block: adjust tagging function queue bit lockingJens Axboe
For most initialization purposes, calling blk_queue_init_tags() without the queue lock held is OK. Only if called for resizing an existing map must the lock be held. Ditto for tag cleanup, the maps are reference counted. So switch the general queue flag setting to the unlocked variant, but retain the locked variant for resizing. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-01block: remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29block: make queue flags non-atomicNick Piggin
We can save some atomic ops in the IO path, if we clearly define the rules of how to modify the queue flags. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block/blk-tag.c should #include "blk.h"Adrian Bunk
Every file should include the headers containing the externs for its global functions (in this case for __blk_queue_free_tags()). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01block: make core bits checkpatch compliantJens Axboe
2008-01-29block: split tag and sysfs handling from blk-core.cJens Axboe
Seperates the tag and sysfs handling from ll_rw_blk. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
