path: root/block/blk-merge.c
2013-03-20scatterlist: introduce sg_unmark_endPaolo Bonzini
This is useful in places that recycle the same scatterlist multiple times, and do not want to incur the cost of sg_init_table every time in hot paths. Acked-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-20block: Implement support for WRITE SAMEMartin K. Petersen
The WRITE SAME command supported on some SCSI devices allows the same block to be efficiently replicated throughout a block range. Only a single logical block is transferred from the host and the storage device writes the same data to all blocks described by the I/O. This patch implements support for WRITE SAME in the block layer. The blkdev_issue_write_same() function can be used by filesystems and block drivers to replicate a buffer across a block range. This can be used to efficiently initialize software RAID devices, etc. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-20block: Consolidate command flag and queue limit checks for mergesMartin K. Petersen
- blk_check_merge_flags() verifies that cmd_flags / bi_rw are compatible. This function is called for both req-req and req-bio merging. - blk_rq_get_max_sectors() and blk_queue_get_max_sectors() can be used to query the maximum sector count for a given request or queue. The calls will return the right value from the queue limits given the type of command (RW, discard, write same, etc.) Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-20block: Clean up special command handling logicMartin K. Petersen
Remove special-casing of non-rw fs style requests (discard). The nomerge flags are consolidated in blk_types.h, and rq_mergeable() and bio_mergeable() have been modified to use them. bio_is_rw() is used in place of bio_has_data() a few places. This is done to to distinguish true reads and writes from other fs type requests that carry a payload (e.g. write same). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-08-02block: Add blk_bio_map_sg() helperAsias He
Add a helper to map a bio to a scatterlist, modelled after blk_rq_map_sg. This helper is useful for any driver that wants to create a scatterlist from its ->make_request_fn method. Changes in v2: - Use __blk_segment_map_sg to avoid duplicated code - Add cocbook style function comment Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Hellwig <hch@lst.de> Cc: Tejun Heo <tj@kernel.org> Cc: Shaohua Li <shli@kernel.org> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: kvm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: virtualization@lists.linux-foundation.org Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Asias He <asias@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-08-02block: Introduce __blk_segment_map_sg() helperAsias He
Split the mapping code in blk_rq_map_sg() to a helper __blk_segment_map_sg(), so that other mapping function, e.g. blk_bio_map_sg(), can share the code. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Hellwig <hch@lst.de> Cc: Tejun Heo <tj@kernel.org> Cc: Shaohua Li <shli@kernel.org> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: kvm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: virtualization@lists.linux-foundation.org Suggested-by: Jens Axboe <axboe@kernel.dk> Suggested-by: Tejun Heo <tj@kernel.org> Signed-off-by: Asias He <asias@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-08block: separate out blk_rq_merge_ok() and blk_try_merge() from elevator ↵Tejun Heo
functions blk_rq_merge_ok() is the elevator-neutral part of merge eligibility test. blk_try_merge() determines merge direction and expects the caller to have tested elv_rq_merge_ok() previously. elv_rq_merge_ok() now wraps blk_rq_merge_ok() and then calls elv_iosched_allow_merge(). elv_try_merge() is removed and the two callers are updated to call elv_rq_merge_ok() explicitly followed by blk_try_merge(). While at it, make rq_merge_ok() functions return bool. This is to prepare for plug merge update and doesn't introduce any behavior change. This is based on Jens' patch to skip elevator_allow_merge_fn() from plug merge. Signed-off-by: Tejun Heo <tj@kernel.org> LKML-Reference: <4F16F3CA.90904@kernel.dk> Original-patch-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-03-21block: attempt to merge with existing requests on plug flushJens Axboe
One of the disadvantages of on-stack plugging is that we potentially lose out on merging since all pending IO isn't always visible to everybody. When we flush the on-stack plugs, right now we don't do any checks to see if potential merge candidates could be utilized. Correct this by adding a new insert variant, ELEVATOR_INSERT_SORT_MERGE. It works just ELEVATOR_INSERT_SORT, but first checks whether we can merge with an existing request before doing the insertion (if we fail merging). This fixes a regression with multiple processes issuing IO that can be merged. Thanks to Shaohua Li <shaohua.li@intel.com> for testing and fixing an accounting bug. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-07block: add internal hd part table referencesJens Axboe
We can't use krefs since it's apparently restricted to very basic reference counting. This reverts commit e4a683c8. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-05block: fix accounting bug on cross partition mergesJerome Marchand
/proc/diskstats would display a strange output as follows. $ cat /proc/diskstats |grep sda 8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089 8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691 ~~~~~~~~~~ 8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390 8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92 8 4 sda4 4 0 8 0 0 0 0 0 0 0 0 8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137 Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE. The detailed root cause is as follows. Assuming that there are two partition, sda1 and sda2. 1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight is 0 and sda2's one is 1. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 2. A bio belongs to sda1 is issued and is merged into the request mentioned on step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed from sda2 region to sda1 region. However the two partition's hd_struct->in_flight are not changed. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 3. The request is finished and blk_account_io_done() is called. In this case, sda2's hd_struct->in_flight, not a sda1's one, is decremented. | hd_struct->in_flight --------------------------- sda1 | -1 sda2 | 1 --------------------------- The patch fixes the problem by caching the partition lookup inside the request structure, hence making sure that the increment and decrement will always happen on the same partition struct. This also speeds up IO with accounting enabled, since it cuts down on the number of lookups we have to do. Also add a refcount to struct hd_struct to keep the partition in memory as long as users exist. We use kref_test_and_get() to ensure we don't add a reference to a partition which is going away. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-17block: Deprecate QUEUE_FLAG_CLUSTER and use queue_limits insteadMartin K. Petersen
When stacking devices, a request_queue is not always available. This forced us to have a no_cluster flag in the queue_limits that could be used as a carrier until the request_queue had been set up for a metadevice. There were several problems with that approach. First of all it was up to the stacking device to remember to set queue flag after stacking had completed. Also, the queue flag and the queue limits had to be kept in sync at all times. We got that wrong, which could lead to us issuing commands that went beyond the max scatterlist limit set by the driver. The proper fix is to avoid having two flags for tracking the same thing. We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the block layer merging functions. The queue_limit 'no_cluster' is turned into 'cluster' to avoid double negatives and to ease stacking. Clustering defaults to being enabled as before. The queue flag logic is removed from the stacking function, and explicitly setting the cluster flag is no longer necessary in DM and MD. Reported-by: Ed Lin <ed.lin@promise.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-24Revert "block: fix accounting bug on cross partition merges"Jens Axboe
This reverts commit 7681bfeeccff5efa9eb29bf09249a3c400b15327. Conflicts: include/linux/genhd.h It has numerous issues with the cleanup path and non-elevator devices. Revert it for now so we can come up with a clean version without rushing things. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22Merge branch 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits) cfq-iosched: Fix a gcc 4.5 warning and put some comments block: Turn bvec_k{un,}map_irq() into static inline functions block: fix accounting bug on cross partition merges block: Make the integrity mapped property a bio flag block: Fix double free in blk_integrity_unregister block: Ensure physical block size is unsigned int blkio-throttle: Fix possible multiplication overflow in iops calculations blkio-throttle: limit max iops value to UINT_MAX blkio-throttle: There is no need to convert jiffies to milli seconds blkio-throttle: Fix link failure failure on i386 blkio: Recalculate the throttled bio dispatch time upon throttle limit change blkio: Add root group to td->tg_list blkio: deletion of a cgroup was causes oops blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n block: set the bounce_pfn to the actual DMA limit rather than to max memory block: revert bad fix for memory hotplug causing bounces Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK block: set the bounce_pfn to the actual DMA limit rather than to max memory block: Prevent hang_check firing during long I/O cfq: improve fsync performance for small files ... Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
2010-10-19block: fix accounting bug on cross partition mergesYasuaki Ishimatsu
/proc/diskstats would display a strange output as follows. $ cat /proc/diskstats |grep sda 8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089 8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691 ~~~~~~~~~~ 8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390 8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92 8 4 sda4 4 0 8 0 0 0 0 0 0 0 0 8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137 Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE. The detailed root cause is as follows. Assuming that there are two partition, sda1 and sda2. 1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight is 0 and sda2's one is 1. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 2. A bio belongs to sda1 is issued and is merged into the request mentioned on step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed from sda2 region to sda1 region. However the two partition's hd_struct->in_flight are not changed. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 3. The request is finished and blk_account_io_done() is called. In this case, sda2's hd_struct->in_flight, not a sda1's one, is decremented. | hd_struct->in_flight --------------------------- sda1 | -1 sda2 | 1 --------------------------- The patch fixes the problem by caching the partition lookup inside the request structure, hence making sure that the increment and decrement will always happen on the same partition struct. This also speeds up IO with accounting enabled, since it cuts down on the number of lookups we have to do. When reloading partition tables, quiesce IO to ensure that no request references to the partition struct exists. When it is safe to free the partition table, the IO for that device is restarted again. Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-25block: prevent merges of discard and write requestsAdrian Hunter
Add logic to prevent two I/O requests being merged if only one of them is a discard. Ditto secure discard. Without this fix, it is possible for write requests to transform into discard requests. For example: Submit bio 1 to discard 8 sectors from sector n Submit bio 2 to write 8 sectors from sector n + 16 Submit bio 3 to write 8 sectors from sector n + 8 Bio 1 becomes request 1. Bio 2 becomes request 2. Bio 3 is merged with request 2, and then subsequently request 2 is merged with request 1 resulting in just one I/O request which discards all 24 sectors. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> (Moved the checks above the position checks /Jens) Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block/scsi: Provide a limit on the number of integrity segmentsMartin K. Petersen
Some controllers have a hardware limit on the number of protection information scatter-gather list segments they can handle. Introduce a max_integrity_segments limit in the block layer and provide a new scsi_host_template setting that allows HBA drivers to provide a value suitable for the hardware. Add support for honoring the integrity segment limit when merging both bios and requests. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2010-08-07gcc-4.6: block: fix unused but set variables in blk-mergeAndi Kleen
Just some dead code. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-06block: Seperate read and write statistics of in_flight requests v2Nikanth Karthikesan
Commit a9327cac440be4d8333bba975cbbf76045096275 added seperate read and write statistics of in_flight requests. And exported the number of read and write requests in progress seperately through sysfs. But Corrado Zoccolo <czoccolo@gmail.com> reported getting strange output from "iostat -kx 2". Global values for service time and utilization were garbage. For interval values, utilization was always 100%, and service time is higher than normal. So this was reverted by commit 0f78ab9899e9d6acb09d5465def618704255963b The problem was in part_round_stats_single(), I missed the following: if (now == part->stamp) return; - if (part->in_flight) { + if (part_in_flight(part)) { __part_stat_add(cpu, part, time_in_queue, part_in_flight(part) * (now - part->stamp)); __part_stat_add(cpu, part, io_ticks, (now - part->stamp)); With this chunk included, the reported regression gets fixed. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> -- Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-04Revert "Seperate read and write statistics of in_flight requests"Jens Axboe
This reverts commit a9327cac440be4d8333bba975cbbf76045096275. Corrado Zoccolo <czoccolo@gmail.com> reports: "with 2.6.32-rc1 I started getting the following strange output from "iostat -kx 2": Linux 2.6.31bisect (et2) 04/10/2009 _i686_ (2 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 10,70 0,00 3,16 15,75 0,00 70,38 Device: rrqm/s wrqm/s r/s w/s rkB/s wkB/s avgrq-sz avgqu-sz await svctm %util sda 18,22 0,00 0,67 0,01 14,77 0,02 43,94 0,01 10,53 39043915,03 2629219,87 sdb 60,89 9,68 50,79 3,04 1724,43 50,52 65,95 0,70 13,06 488437,47 2629219,87 avg-cpu: %user %nice %system %iowait %steal %idle 2,72 0,00 0,74 0,00 0,00 96,53 Device: rrqm/s wrqm/s r/s w/s rkB/s wkB/s avgrq-sz avgqu-sz await svctm %util sda 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 sdb 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 avg-cpu: %user %nice %system %iowait %steal %idle 6,68 0,00 0,99 0,00 0,00 92,33 Device: rrqm/s wrqm/s r/s w/s rkB/s wkB/s avgrq-sz avgqu-sz await svctm %util sda 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 sdb 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 avg-cpu: %user %nice %system %iowait %steal %idle 4,40 0,00 0,73 1,47 0,00 93,40 Device: rrqm/s wrqm/s r/s w/s rkB/s wkB/s avgrq-sz avgqu-sz await svctm %util sda 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 sdb 0,00 4,00 0,00 3,00 0,00 28,00 18,67 0,06 19,50 333,33 100,00 Global values for service time and utilization are garbage. For interval values, utilization is always 100%, and service time is higher than normal. I bisected it down to: [a9327cac440be4d8333bba975cbbf76045096275] Seperate read and write statistics of in_flight requests and verified that reverting just that commit indeed solves the issue on 2.6.32-rc1." So until this is debugged, revert the bad commit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-14Seperate read and write statistics of in_flight requestsNikanth Karthikesan
Currently, there is a single in_flight counter measuring the number of requests in the request_queue. But some monitoring tools would like to know how many read requests and write requests are in progress. Split the current in_flight counter into two seperate counters for read and write. This information is exported as a sysfs attribute, as changing the currently available stat files would break the existing tools. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11scsi,block: update SCSI to handle mixed merge failuresTejun Heo
Update scsi_io_completion() such that it only fails requests till the next error boundary and retry the leftover. This enables block layer to merge requests with different failfast settings and still behave correctly on errors. Allow merge of requests of different failfast settings. As SCSI is currently the only subsystem which follows failfast status, there's no need to worry about other block drivers for now. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Niel Lambrechts <niel.lambrechts@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11block: implement mixed merge of different failfast requestsTejun Heo
Failfast has characteristics from other attributes. When issuing, executing and successuflly completing requests, failfast doesn't make any difference. It only affects how a request is handled on failure. Allowing requests with different failfast settings to be merged cause normal IOs to fail prematurely while not allowing has performance penalties as failfast is used for read aheads which are likely to be located near in-flight or to-be-issued normal IOs. This patch introduces the concept of 'mixed merge'. A request is a mixed merge if it is merge of segments which require different handling on failure. Currently the only mixable attributes are failfast ones (or lack thereof). When a bio with different failfast settings is added to an existing request or requests of different failfast settings are merged, the merged request is marked mixed. Each bio carries failfast settings and the request always tracks failfast state of the first bio. When the request fails, blk_rq_err_bytes() can be used to determine how many bytes can be safely failed without crossing into an area which requires further retrials. This allows request merging regardless of failfast settings while keeping the failure handling correct. This patch only implements mixed merge but doesn't enable it. The next one will update SCSI to make use of mixed merge. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Niel Lambrechts <niel.lambrechts@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-03block: don't merge requests of different failfast settingsTejun Heo
Block layer used to merge requests and bios with different failfast settings. This caused regular IOs to fail prematurely when they were merged into failfast requests for readahead. Niel Lambrechts could trigger the problem semi-reliably on ext4 when resuming from STR. ext4 uses readahead when reading inodes and combined with the deterministic extra SATA PHY exception cycle during resume on the specific configuration, non-readahead inode read would fail causing ext4 errors. Please read the following thread for details. http://lkml.org/lkml/2009/5/23/21 This patch makes block layer reject merging if the failfast settings don't match. This is correct but likely to lower IO performance by preventing regular IOs from mingling into surrounding readahead requests. Changes to allow such mixed merges and handle errors correctly will be added later. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Niel Lambrechts <niel.lambrechts@gmail.com> Cc: Theodore Tso <tytso@mit.edu> Signed-off-by: Jens Axboe <axboe@carl.(none)>
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: hide request sector and data_lenTejun Heo
Block low level drivers for some reason have been pretty good at abusing block layer API. Especially struct request's fields tend to get violated in all possible ways. Make it clear that low level drivers MUST NOT access or manipulate rq->sector and rq->data_len directly by prefixing them with double underscores. This change is also necessary to break build of out-of-tree codes which assume the previous block API where internal fields can be manipulated and rq->data_len carries residual count on completion. [ Impact: hide internal fields, block API change ] Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: drop request->hard_* and *nr_sectorsTejun Heo
struct request has had a few different ways to represent some properties of a request. ->hard_* represent block layer's view of the request progress (completion cursor) and the ones without the prefix are supposed to represent the issue cursor and allowed to be updated as necessary by the low level drivers. The thing is that as block layer supports partial completion, the two cursors really aren't necessary and only cause confusion. In addition, manual management of request detail from low level drivers is cumbersome and error-prone at the very least. Another interesting duplicate fields are rq->[hard_]nr_sectors and rq->{hard_cur|current}_nr_sectors against rq->data_len and rq->bio->bi_size. This is more convoluted than the hard_ case. rq->[hard_]nr_sectors are initialized for requests with bio but blk_rq_bytes() uses it only for !pc requests. rq->data_len is initialized for all request but blk_rq_bytes() uses it only for pc requests. This causes good amount of confusion throughout block layer and its drivers and determining the request length has been a bit of black magic which may or may not work depending on circumstances and what the specific LLD is actually doing. rq->{hard_cur|current}_nr_sectors represent the number of sectors in the contiguous data area at the front. This is mainly used by drivers which transfers data by walking request segment-by-segment. This value always equals rq->bio->bi_size >> 9. However, data length for pc requests may not be multiple of 512 bytes and using this field becomes a bit confusing. In general, having multiple fields to represent the same property leads only to confusion and subtle bugs. With recent block low level driver cleanups, no driver is accessing or manipulating these duplicate fields directly. Drop all the duplicates. Now rq->sector means the current sector, rq->data_len the current total length and rq->bio->bi_size the current segment length. Everything else is defined in terms of these three and available only through accessors. * blk_recalc_rq_sectors() is collapsed into blk_update_request() and now handles pc and fs requests equally other than rq->sector update. This means that now pc requests can use partial completion too (no in-kernel user yet tho). * bio_cur_sectors() is replaced with bio_cur_bytes() as block layer now uses byte count as the primary data length. * blk_rq_pos() is now guranteed to be always correct. In-block users converted. * blk_rq_bytes() is now guaranteed to be always valid as is blk_rq_sectors(). In-block users converted. * blk_rq_sectors() is now guaranteed to equal blk_rq_bytes() >> 9. More convenient one is used. * blk_rq_bytes() and blk_rq_cur_bytes() are now inlined and take const pointer to request. [ Impact: API cleanup, single way to represent one property of a request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-24block: simplify I/O stat accountingJerome Marchand
This simplifies I/O stat accounting switching code and separates it completely from I/O scheduler switch code. Requests are accounted according to the state of their request queue at the time of the request allocation. There is no need anymore to flush the request queue when switching I/O accounting state. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: fix inconsistency in I/O stat accounting codeJerome Marchand
This forces in_flight to be zero when turning off or on the I/O stat accounting and stops updating I/O stats in attempt_merge() when accounting is turned off. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-26block: WARN in __blk_put_request() for potential bio leakBoaz Harrosh
Put a WARN_ON in __blk_put_request if it is about to leak bio(s). This is a serious bug that can happen in error handling code paths. For this to work I have fixed a couple of places in block/ where request->bio != NULL ownership was not honored. And a small cleanup at sg_io() while at it. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-06block: fix missing bio back/front segment size setting in blk_recount_segments()Jens Axboe
Commit 1e42807918d17e8c93bf14fbb74be84b141334c1 introduced a bug where we don't get front/back segment sizes in the bio in blk_recount_segments(). Fix this by tracking the back bio as well as the front bio in __blk_recalc_rq_segments(), this also cleans up the interface by getting rid of the segment size pointer passing. Tested-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-26block: reduce stack footprint of blk_recount_segments()Jens Axboe
blk_recalc_rq_segments() requires a request structure passed in, which we don't have from blk_recount_segments(). So the latter allocates one on the stack, using > 400 bytes of stack for that. This can cause us to spill over one page of stack from ext4 at least: 0) 4560 400 blk_recount_segments+0x43/0x62 1) 4160 32 bio_phys_segments+0x1c/0x24 2) 4128 32 blk_rq_bio_prep+0x2a/0xf9 3) 4096 32 init_request_from_bio+0xf9/0xfe 4) 4064 112 __make_request+0x33c/0x3f6 5) 3952 144 generic_make_request+0x2d1/0x321 6) 3808 64 submit_bio+0xb9/0xc3 7) 3744 48 submit_bh+0xea/0x10e 8) 3696 368 ext4_mb_init_cache+0x257/0xa6a [ext4] 9) 3328 288 ext4_mb_regular_allocator+0x421/0xcd9 [ext4] 10) 3040 160 ext4_mb_new_blocks+0x211/0x4b4 [ext4] 11) 2880 336 ext4_ext_get_blocks+0xb61/0xd45 [ext4] 12) 2544 96 ext4_get_blocks_wrap+0xf2/0x200 [ext4] 13) 2448 80 ext4_da_get_block_write+0x6e/0x16b [ext4] 14) 2368 352 mpage_da_map_blocks+0x7e/0x4b3 [ext4] 15) 2016 352 ext4_da_writepages+0x2ce/0x43c [ext4] 16) 1664 32 do_writepages+0x2d/0x3c 17) 1632 144 __writeback_single_inode+0x162/0x2cd 18) 1488 96 generic_sync_sb_inodes+0x1e3/0x32b 19) 1392 16 sync_sb_inodes+0xe/0x10 20) 1376 48 writeback_inodes+0x69/0xb3 21) 1328 208 balance_dirty_pages_ratelimited_nr+0x187/0x2f9 22) 1120 224 generic_file_buffered_write+0x1d4/0x2c4 23) 896 176 __generic_file_aio_write_nolock+0x35f/0x393 24) 720 80 generic_file_aio_write+0x6c/0xc8 25) 640 80 ext4_file_write+0xa9/0x137 [ext4] 26) 560 320 do_sync_write+0xf0/0x137 27) 240 48 vfs_write+0xb3/0x13c 28) 192 64 sys_write+0x4c/0x74 29) 128 128 system_call_fastpath+0x16/0x1b Split the segment counting out into a __blk_recalc_rq_segments() helper to avoid allocating an onstack request just for checking the physical segment count. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-06block: remove unused ll_new_mergeable()FUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17block: fix nr_phys_segments miscalculation bugFUJITA Tomonori
This fixes the bug reported by Nikanth Karthikesan <knikanth@suse.de>: http://lkml.org/lkml/2008/10/2/203 The root cause of the bug is that blk_phys_contig_segment miscalculates q->max_segment_size. blk_phys_contig_segment checks: req->biotail->bi_size + next_req->bio->bi_size > q->max_segment_size But blk_recalc_rq_segments might expect that req->biotail and the previous bio in the req are supposed be merged into one segment. blk_recalc_rq_segments might also expect that next_req->bio and the next bio in the next_req are supposed be merged into one segment. In such case, we merge two requests that can't be merged here. Later, blk_rq_map_sg gives more segments than it should. We need to keep track of segment size in blk_recalc_rq_segments and use it to see if two requests can be merged. This patch implements it in the similar way that we used to do for hw merging (virtual merging). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: inherit CPU completion on bio->rq and rq->rq mergesJens Axboe
Somewhat incomplete, as we do allow merges of requests and bios that have different completion CPUs given. This is done on the assumption that a larger IO is still more beneficial than CPU locality. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: move stats from disk to part0Tejun Heo
Move stats related fields - stamp, in_flight, dkstats - from disk to part0 and unify stat handling such that... * part_stat_*() now updates part0 together if the specified partition is not part0. ie. part_stat_*() are now essentially all_stat_*(). * {disk|all}_stat_*() are gone. * part_round_stats() is updated similary. It handles part0 stats automatically and disk_round_stats() is killed. * part_{inc|dec}_in_fligh() is implemented which automatically updates part0 stats for parts other than part0. * disk_map_sector_rcu() is updated to return part0 if no part matches. Combined with the above changes, this makes NULL special case handling in callers unnecessary. * Separate stats show code paths for disk are collapsed into part stats show code paths. * Rename disk_stat_lock/unlock() to part_stat_lock/unlock() While at it, reposition stat handling macros a bit and add missing parentheses around macro parameters. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: fix diskstats accessTejun Heo
There are two variants of stat functions - ones prefixed with double underbars which don't care about preemption and ones without which disable preemption before manipulating per-cpu counters. It's unclear whether the underbarred ones assume that preemtion is disabled on entry as some callers don't do that. This patch unifies diskstats access by implementing disk_stat_lock() and disk_stat_unlock() which take care of both RCU (for partition access) and preemption (for per-cpu counter access). diskstats access should always be enclosed between the two functions. As such, there's no need for the versions which disables preemption. They're removed and double underbars ones are renamed to drop the underbars. As an extra argument is added, there's no danger of using the old version unconverted. disk_stat_lock() uses get_cpu() and returns the cpu index and all diskstat functions which access per-cpu counters now has @cpu argument to help RT. This change adds RCU or preemption operations at some places but also collapses several preemption ops into one at others. Overall, the performance difference should be negligible as all involved ops are very lightweight per-cpu ones. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: fix disk->part[] dereferencing raceTejun Heo
disk->part[] is protected by its matching bdev's lock. However, non-critical accesses like collecting stats and printing out sysfs and proc information used to be performed without any locking. As partitions can come and go dynamically, partitions can go away underneath those non-critical accesses. As some of those accesses are writes, this theoretically can lead to silent corruption. This patch fixes the race by using RCU for the partition array and dev reference counter to hold partitions. * Rename disk->part[] to disk->__part[] to make sure no one outside genhd layer proper accesses it directly. * Use RCU for disk->__part[] dereferencing. * Implement disk_{get|put}_part() which can be used to get and put partitions from gendisk respectively. * Iterators are implemented to help iterate through all partitions safely. * Functions which require RCU readlock are marked with _rcu suffix. * Use disk_put_part() in __blkdev_put() instead of directly putting the contained kobject. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: misc updatesTejun Heo
This patch makes the following misc updates in preparation for disk->part dereference fix and extended block devt support. * implment part_to_disk() * fix comment about gendisk->part indexing * rename get_part() to disk_map_sector() * don't use n which is always zero while printing disk information in diskstats_show() Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09drop vmerge accountingMikulas Patocka
Remove hw_segments field from struct bio and struct request. Without virtual merge accounting they have no purpose. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: drop virtual merging accountingMikulas Patocka
Remove virtual merge accounting. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Allow elevators to sort/merge discard requestsDavid Woodhouse
But blkdev_issue_discard() still emits requests which are interpreted as soft barriers, because naïve callers might otherwise issue subsequent writes to those same sectors, which might cross on the queue (if they're reallocated quickly enough). Callers still _can_ issue non-barrier discard requests, but they have to take care of queue ordering for themselves. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: Block layer data integrity supportMartin K. Petersen
Some block devices support verifying the integrity of requests by way of checksums or other protection information that is submitted along with the I/O. This patch implements support for generating and verifying integrity metadata, as well as correctly merging, splitting and cloning bios and requests that have this extra information attached. See Documentation/block/data-integrity.txt for more information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07block: get rid of likely/unlikely predictions in merge logicJens Axboe
They tend to depend a lot on the workload, so not a clear-cut likely or unlikely fit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: make queue flags non-atomicNick Piggin
We can save some atomic ops in the IO path, if we clearly define the rules of how to modify the queue flags. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21block: move the padding adjustment to blk_rq_map_sgFUJITA Tomonori
blk_rq_map_user adjusts bi_size of the last bio. It breaks the rule that req->data_len (the true data length) is equal to sum(bio). It broke the scsi command completion code. commit e97a294ef6938512b655b1abf17656cf2b26f709 was introduced to fix the above issue. However, the partial completion code doesn't work with it. The commit is also a layer violation (scsi mid-layer should not know about the block layer's padding). This patch moves the padding adjustment to blk_rq_map_sg (suggested by James). The padding works like the drain buffer. This patch breaks the rule that req->data_len is equal to sum(sg), however, the drain buffer already broke it. So this patch just restores the rule that req->data_len is equal to sub(bio) without breaking anything new. Now when a low level driver needs padding, blk_rq_map_user and blk_rq_map_user_iov guarantee there's enough room for padding. blk_rq_map_sg can safely extend the last entry of a scatter list. blk_rq_map_sg must extend the last entry of a scatter list only for a request that got through bio_copy_user_iov. This patches introduces new REQ_COPY_USER flag. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
