path: root/block/blk-flush.c
2013-03-22Block: blk-flush: Fixed indent code styleAlice Ferrazzi
Fixed code indent should use tabs where possible. Signed-off-by: Alice Ferrazzi <alice.ferrazzi@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-02-15block: account iowait time when waiting for completion of IO requestVladimir Davydov
Using wait_for_completion() for waiting for a IO request to be executed results in wrong iowait time accounting. For example, a system having the only task doing write() and fdatasync() on a block device can be reported being idle instead of iowaiting as it should because blkdev_issue_flush() calls wait_for_completion() which in turn calls schedule() that does not increment the iowait proc counter and thus does not turn on iowait time accounting. The patch makes block layer use wait_for_completion_io() instead of wait_for_completion() where appropriate to account iowait time correctly. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-24blk-flush: move the queue kick intoJeff Moyer
A dm-multipath user reported[1] a problem when trying to boot a kernel with commit 4853abaae7e4a2af938115ce9071ef8684fb7af4 (block: fix flush machinery for stacking drivers with differring flush flags) applied. It turns out that an empty flush request can be sent into blk_insert_flush. When the BUG_ON was fixed to allow for this, I/O on the underlying device would stall. The reason is that blk_insert_cloned_request does not kick the queue. In the aforementioned commit, I had added a special case to kick the queue if data was sent down but the queue flags did not require a flush. A better solution is to push the queue kick up into blk_insert_cloned_request. This patch, along with a follow-on which fixes the BUG_ON, fixes the issue reported. [1] http://www.redhat.com/archives/dm-devel/2011-September/msg00154.html Reported-by: Christophe Saout <christophe@saout.de> Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Stable note: 3.1 Cc: stable@vger.kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-24blk-flush: fix invalid BUG_ON in blk_insert_flushJeff Moyer
A user reported a regression due to commit 4853abaae7e4a2af938115ce9071ef8684fb7af4 (block: fix flush machinery for stacking drivers with differring flush flags). Part of the problem is that blk_insert_flush required a single bio be attached to the request. In reality, having no attached bio is also a valid case, as can be observed with an empty flush. [1] http://www.redhat.com/archives/dm-devel/2011-September/msg00154.html Reported-by: Christophe Saout <christophe@saout.de> Signed-off-by: Jeff Moyer <jmoyer@redhat.com Acked-by: Tejun Heo <tj@kernel.org> Stable note: 3.1 Cc: stable@vger.kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-08-15block: fix flush machinery for stacking drivers with differring flush flagsJeff Moyer
Commit ae1b1539622fb46e51b4d13b3f9e5f4c713f86ae, block: reimplement FLUSH/FUA to support merge, introduced a performance regression when running any sort of fsyncing workload using dm-multipath and certain storage (in our case, an HP EVA). The test I ran was fs_mark, and it dropped from ~800 files/sec on ext4 to ~100 files/sec. It turns out that dm-multipath always advertised flush+fua support, and passed commands on down the stack, where those flags used to get stripped off. The above commit changed that behavior: static inline struct request *__elv_next_request(struct request_queue *q) { struct request *rq; while (1) { - while (!list_empty(&q->queue_head)) { + if (!list_empty(&q->queue_head)) { rq = list_entry_rq(q->queue_head.next); - if (!(rq->cmd_flags & (REQ_FLUSH | REQ_FUA)) || - (rq->cmd_flags & REQ_FLUSH_SEQ)) - return rq; - rq = blk_do_flush(q, rq); - if (rq) - return rq; + return rq; } Note that previously, a command would come in here, have REQ_FLUSH|REQ_FUA set, and then get handed off to blk_do_flush: struct request *blk_do_flush(struct request_queue *q, struct request *rq) { unsigned int fflags = q->flush_flags; /* may change, cache it */ bool has_flush = fflags & REQ_FLUSH, has_fua = fflags & REQ_FUA; bool do_preflush = has_flush && (rq->cmd_flags & REQ_FLUSH); bool do_postflush = has_flush && !has_fua && (rq->cmd_flags & REQ_FUA); unsigned skip = 0; ... if (blk_rq_sectors(rq) && !do_preflush && !do_postflush) { rq->cmd_flags &= ~REQ_FLUSH; if (!has_fua) rq->cmd_flags &= ~REQ_FUA; return rq; } So, the flush machinery was bypassed in such cases (q->flush_flags == 0 && rq->cmd_flags & (REQ_FLUSH|REQ_FUA)). Now, however, we don't get into the flush machinery at all. Instead, __elv_next_request just hands a request with flush and fua bits set to the scsi_request_fn, even if the underlying request_queue does not support flush or fua. The agreed upon approach is to fix the flush machinery to allow stacking. While this isn't used in practice (since there is only one request-based dm target, and that target will now reflect the flush flags of the underlying device), it does future-proof the solution, and make it function as designed. In order to make this work, I had to add a field to the struct request, inside the flush structure (to store the original req->end_io). Shaohua had suggested overloading the union with rb_node and completion_data, but the completion data is used by device mapper and can also be used by other drivers. So, I didn't see a way around the additional field. I tested this patch on an HP EVA with both ext4 and xfs, and it recovers the lost performance. Comments and other testers, as always, are appreciated. Cheers, Jeff Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-09allow blk_flush_policy to return REQ_FSEQ_DATA independent of *FLUSHJeff Moyer
blk_insert_flush has the following check: /* * If there's data but flush is not necessary, the request can be * processed directly without going through flush machinery. Queue * for normal execution. */ if ((policy & REQ_FSEQ_DATA) && !(policy & (REQ_FSEQ_PREFLUSH | REQ_FSEQ_POSTFLUSH))) { list_add_tail(&rq->queuelist, &q->queue_head); return; } However, blk_flush_policy will not return with policy set to only REQ_FSEQ_DATA: static unsigned int blk_flush_policy(unsigned int fflags, struct request *rq) { unsigned int policy = 0; if (fflags & REQ_FLUSH) { if (rq->cmd_flags & REQ_FLUSH) policy |= REQ_FSEQ_PREFLUSH; if (blk_rq_sectors(rq)) policy |= REQ_FSEQ_DATA; if (!(fflags & REQ_FUA) && (rq->cmd_flags & REQ_FUA)) policy |= REQ_FSEQ_POSTFLUSH; } return policy; } Notice that REQ_FSEQ_DATA is only set if REQ_FLUSH is set. Fix this mismatch by moving the setting of REQ_FSEQ_DATA outside of the REQ_FLUSH check. Tejun notes: Hmmm... yes, this can become a correctness issue if (and only if) blk_queue_flush() is called to change q->flush_flags while requests are in-flight; otherwise, requests wouldn't reach the function at all. Also, I think it would be a generally good idea to always set FSEQ_DATA if the request has data. Cheers, Jeff Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06block: hold queue if flush is running for non-queueable flush driveshaohua.li@intel.com
In some drives, flush requests are non-queueable. When flush request is running, normal read/write requests can't run. If block layer dispatches such request, driver can't handle it and requeue it. Tejun suggested we can hold the queue when flush is running. This can avoid unnecessary requeue. Also this can improve performance. For example, we have request flush1, write1, flush 2. flush1 is dispatched, then queue is hold, write1 isn't inserted to queue. After flush1 is finished, flush2 will be dispatched. Since disk cache is already clean, flush2 will be finished very soon, so looks like flush2 is folded to flush1. In my test, the queue holding completely solves a regression introduced by commit 53d63e6b0dfb95882ec0219ba6bbd50cde423794: block: make the flush insertion use the tail of the dispatch list It's not a preempt type request, in fact we have to insert it behind requests that do specify INSERT_FRONT. which causes about 20% regression running a sysbench fileio workload. Stable: 2.6.39 only Cc: stable@kernel.org Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-18block: add blk_run_queue_asyncChristoph Hellwig
Instead of overloading __blk_run_queue to force an offload to kblockd add a new blk_run_queue_async helper to do it explicitly. I've kept the blk_queue_stopped check for now, but I suspect it's not needed as the check we do when the workqueue items runs should be enough. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-05block: make the flush insertion use the tail of the dispatch listJens Axboe
It's not a preempt type request, in fact we have to insert it behind requests that do specify INSERT_FRONT. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-05block: get rid of elv_insert() interfaceJens Axboe
Merge it with __elv_add_request(), it's pretty pointless to have a function with only two callers. The main interface is elv_add_request()/__elv_add_request(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: initial patch for on-stack per-task pluggingJens Axboe
This patch adds support for creating a queuing context outside of the queue itself. This enables us to batch up pieces of IO before grabbing the block device queue lock and submitting them to the IO scheduler. The context is created on the stack of the process and assigned in the task structure, so that we can auto-unplug it if we hit a schedule event. The current queue plugging happens implicitly if IO is submitted to an empty device, yet callers have to remember to unplug that IO when they are going to wait for it. This is an ugly API and has caused bugs in the past. Additionally, it requires hacks in the vm (->sync_page() callback) to handle that logic. By switching to an explicit plugging scheme we make the API a lot nicer and can get rid of the ->sync_page() hack in the vm. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-04Merge branch 'for-linus' of ../linux-2.6-block into block-for-2.6.39/coreTejun Heo
This merge creates two set of conflicts. One is simple context conflicts caused by removal of throtl_scheduled_delayed_work() in for-linus and removal of throtl_shutdown_timer_wq() in for-2.6.39/core. The other is caused by commit 255bb490c8 (block: blk-flush shouldn't call directly into q->request_fn() __blk_run_queue()) in for-linus crashing with FLUSH reimplementation in for-2.6.39/core. The conflict isn't trivial but the resolution is straight-forward. * __blk_run_queue() calls in flush_end_io() and flush_data_end_io() should be called with @force_kblockd set to %true. * elv_insert() in blk_kick_flush() should use %ELEVATOR_INSERT_REQUEUE. Both changes are to avoid invoking ->request_fn() directly from request completion path and closely match the changes in the commit 255bb490c8. Signed-off-by: Tejun Heo <tj@kernel.org>
2011-03-02block: blk-flush shouldn't call directly into q->request_fn() __blk_run_queue()Tejun Heo
blk-flush decomposes a flush into sequence of multiple requests. On completion of a request, the next one is queued; however, block layer must not implicitly call into q->request_fn() directly from completion path. This makes the queue behave unexpectedly when seen from the drivers and violates the assumption that q->request_fn() is called with process context + queue_lock. This patch makes blk-flush the following two changes to make sure q->request_fn() is not called directly from request completion path. - blk_flush_complete_seq_end_io() now asks __blk_run_queue() to always use kblockd instead of calling directly into q->request_fn(). - queue_next_fseq() uses ELEVATOR_INSERT_REQUEUE instead of ELEVATOR_INSERT_FRONT so that elv_insert() doesn't try to unplug the request queue directly. Reported by Jan in the following threads. http://thread.gmane.org/gmane.linux.ide/48778 http://thread.gmane.org/gmane.linux.ide/48786 stable: applicable to v2.6.37. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jan Beulich <JBeulich@novell.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-02block: add @force_kblockd to __blk_run_queue()Tejun Heo
__blk_run_queue() automatically either calls q->request_fn() directly or schedules kblockd depending on whether the function is recursed. blk-flush implementation needs to be able to explicitly choose kblockd. Add @force_kblockd. All the current users are converted to specify %false for the parameter and this patch doesn't introduce any behavior change. stable: This is prerequisite for fixing ide oops caused by the new blk-flush implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-25block: reimplement FLUSH/FUA to support mergeTejun Heo
The current FLUSH/FUA support has evolved from the implementation which had to perform queue draining. As such, sequencing is done queue-wide one flush request after another. However, with the draining requirement gone, there's no reason to keep the queue-wide sequential approach. This patch reimplements FLUSH/FUA support such that each FLUSH/FUA request is sequenced individually. The actual FLUSH execution is double buffered and whenever a request wants to execute one for either PRE or POSTFLUSH, it queues on the pending queue. Once certain conditions are met, a flush request is issued and on its completion all pending requests proceed to the next sequence. This allows arbitrary merging of different type of flushes. How they are merged can be primarily controlled and tuned by adjusting the above said 'conditions' used to determine when to issue the next flush. This is inspired by Darrick's patches to merge multiple zero-data flushes which helps workloads with highly concurrent fsync requests. * As flush requests are never put on the IO scheduler, request fields used for flush share space with rq->rb_node. rq->completion_data is moved out of the union. This increases the request size by one pointer. As rq->elevator_private* are used only by the iosched too, it is possible to reduce the request size further. However, to do that, we need to modify request allocation path such that iosched data is not allocated for flush requests. * FLUSH/FUA processing happens on insertion now instead of dispatch. - Comments updated as per Vivek and Mike. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "Darrick J. Wong" <djwong@us.ibm.com> Cc: Shaohua Li <shli@kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-25block: add REQ_FLUSH_SEQTejun Heo
rq == &q->flush_rq was used to determine whether a rq is part of a flush sequence, which worked because all requests in a flush sequence were sequenced using the single dedicated request. This is about to change, so introduce REQ_FLUSH_SEQ flag to distinguish flush sequence requests. This patch doesn't cause any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: use REQ_FLUSH in blkdev_issue_flush()Tejun Heo
Update blkdev_issue_flush() to use new REQ_FLUSH interface. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: make sure FSEQ_DATA request has the same rq_disk as the originalTejun Heo
rq->rq_disk and bio->bi_bdev->bd_disk may differ if a request has passed through remapping drivers. FSEQ_DATA request incorrectly followed bio->bi_bdev->bd_disk ending up being issued w/ mismatching rq_disk. Make it follow orig_rq->rq_disk. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Tested-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: kick queue after sequencing REQ_FLUSH/FUATejun Heo
While completing a request from a REQ_FLUSH/FUA sequence, another request can be pushed to the request queue. If a driver tests elv_queue_empty() before completing a request and runs the queue again only if the queue wasn't empty, this may lead to hang. Please note that most drivers either kick the queue unconditionally or test queue emptiness after completing the current request and don't have this problem. This patch removes this possibility by making REQ_FLUSH/FUA sequence code kick the queue if the queue was empty before completing a request from REQ_FLUSH/FUA sequence. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: initialize flush request with WRITE_FLUSH instead of REQ_FLUSHTejun Heo
init_flush_request() only set REQ_FLUSH when initializing flush requests making them READ requests. Use WRITE_FLUSH instead. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: simplify queue_next_fseqChristoph Hellwig
We need to call blk_rq_init and elv_insert for all cases in queue_next_fseq, so take these calls into common code. Also move the end_io initialization from queue_flush into queue_next_fseq and rename queue_flush to init_flush_request now that it's old name doesn't apply anymore. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: implement REQ_FLUSH/FUA based interface for FLUSH/FUA requestsTejun Heo
Now that the backend conversion is complete, export sequenced FLUSH/FUA capability through REQ_FLUSH/FUA flags. REQ_FLUSH means the device cache should be flushed before executing the request. REQ_FUA means that the data in the request should be on non-volatile media on completion. Block layer will choose the correct way of implementing the semantics and execute it. The request may be passed to the device directly if the device can handle it; otherwise, it will be sequenced using one or more proxy requests. Devices will never see REQ_FLUSH and/or FUA which it doesn't support. Also, unlike the original REQ_HARDBARRIER, REQ_FLUSH/FUA requests are never failed with -EOPNOTSUPP. If the underlying device doesn't support FLUSH/FUA, the block layer simply make those noop. IOW, it no longer distinguishes between writeback cache which doesn't support cache flush and writethrough/no cache. Devices which have WB cache w/o flush are very difficult to come by these days and there's nothing much we can do anyway, so it doesn't make sense to require everyone to implement -EOPNOTSUPP handling. This will simplify filesystems and block drivers as they can drop -EOPNOTSUPP retry logic for barriers. * QUEUE_ORDERED_* are removed and QUEUE_FSEQ_* are moved into blk-flush.c. * REQ_FLUSH w/o data can also be directly passed to drivers without sequencing but some drivers assume that zero length requests don't have rq->bio which isn't true for these requests requiring the use of proxy requests. * REQ_COMMON_MASK now includes REQ_FLUSH | REQ_FUA so that they are copied from bio to request. * WRITE_BARRIER is marked deprecated and WRITE_FLUSH, WRITE_FUA and WRITE_FLUSH_FUA are added. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: rename barrier/ordered to flushTejun Heo
With ordering requirements dropped, barrier and ordered are misnomers. Now all block layer does is sequencing FLUSH and FUA. Rename them to flush. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: rename blk-barrier.c to blk-flush.cTejun Heo
Without ordering requirements, barrier and ordering are minomers. Rename block/blk-barrier.c to block/blk-flush.c. Rename of symbols will follow. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
