path: root/arch
2015-07-12Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "A fair number of 4.2 fixes also because Markos opened the flood gates. - Patch up the math used calculate the location for the page bitmap. - The FDC (Not what you think, FDC stands for Fast Debug Channel) IRQ around was causing issues on non-Malta platforms, so move the code to a Malta specific location. - A spelling fix replicated through several files. - Fix to the emulation of an R2 instruction for R6 cores. - Fix the JR emulation for R6. - Further patching of mindless 64 bit issues. - Ensure the kernel won't crash on CPUs with L2 caches with >= 8 ways. - Use compat_sys_getsockopt for O32 ABI on 64 bit kernels. - Fix cache flushing for multithreaded cores. - A build fix" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: O32: Use compat_sys_getsockopt. MIPS: c-r4k: Extend way_string array MIPS: Pistachio: Support CDMM & Fast Debug Channel MIPS: Malta: Make GIC FDC IRQ workaround Malta specific MIPS: c-r4k: Fix cache flushing for MT cores Revert "MIPS: Kconfig: Disable SMP/CPS for 64-bit" MIPS: cps-vec: Use macros for various arithmetics and memory operations MIPS: kernel: cps-vec: Replace KSEG0 with CKSEG0 MIPS: kernel: cps-vec: Use ta0-ta3 pseudo-registers for 64-bit MIPS: kernel: cps-vec: Replace mips32r2 ISA level with mips64r2 MIPS: kernel: cps-vec: Replace 'la' macro with PTR_LA MIPS: kernel: smp-cps: Fix 64-bit compatibility errors due to pointer casting MIPS: Fix erroneous JR emulation for MIPS R6 MIPS: Fix branch emulation for BLTC and BGEC instructions MIPS: kernel: traps: Fix broken indentation MIPS: bootmem: Don't use memory holes for page bitmap MIPS: O32: Do not handle require 32 bytes from the stack to be readable. MIPS, CPUFREQ: Fix spelling of Institute. MIPS: Lemote 2F: Fix build caused by recent mass rename.
2015-07-12Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Thomas Gleixner: - the high latency PIT detection fix, which slipped through the cracks for rc1 - a regression fix for the early printk mechanism - the x86 part to plug irq/vector related hotplug races - move the allocation of the espfix pages on cpu hotplug to non atomic context. The current code triggers a might_sleep() warning. - a series of KASAN fixes addressing boot crashes and usability - a trivial typo fix for Kconfig help text * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/kconfig: Fix typo in the CONFIG_CMDLINE_BOOL help text x86/irq: Retrieve irq data after locking irq_desc x86/irq: Use proper locking in check_irq_vectors_for_cpu_disable() x86/irq: Plug irq vector hotplug race x86/earlyprintk: Allow early_printk() to use console style parameters like '115200n8' x86/espfix: Init espfix on the boot CPU side x86/espfix: Add 'cpu' parameter to init_espfix_ap() x86/kasan: Move KASAN_SHADOW_OFFSET to the arch Kconfig x86/kasan: Add message about KASAN being initialized x86/kasan: Fix boot crash on AMD processors x86/kasan: Flush TLBs after switching CR3 x86/kasan: Fix KASAN shadow region page tables x86/init: Clear 'init_level4_pgt' earlier x86/tsc: Let high latency PIT fail fast in quick_pit_calibrate()
2015-07-12Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "This update from the timer departement contains: - A series of patches which address a shortcoming in the tick broadcast code. If the broadcast device is not available or an hrtimer emulated broadcast device, some of the original assumptions lead to boot failures. I rather plugged all of the corner cases instead of only addressing the issue reported, so the change got a little larger. Has been extensivly tested on x86 and arm. - Get rid of the last holdouts using do_posix_clock_monotonic_gettime() - A regression fix for the imx clocksource driver - An update to the new state callbacks mechanism for clockevents. This is required to simplify the conversion, which will take place in 4.3" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick/broadcast: Prevent NULL pointer dereference time: Get rid of do_posix_clock_monotonic_gettime cris: Replace do_posix_clock_monotonic_gettime() tick/broadcast: Unbreak CONFIG_GENERIC_CLOCKEVENTS=n build tick/broadcast: Handle spurious interrupts gracefully tick/broadcast: Check for hrtimer broadcast active early tick/broadcast: Return busy when IPI is pending tick/broadcast: Return busy if periodic mode and hrtimer broadcast tick/broadcast: Move the check for periodic mode inside state handling tick/broadcast: Prevent deep idle if no broadcast device available tick/broadcast: Make idle check independent from mode and config tick/broadcast: Sanity check the shutdown of the local clock_event tick/broadcast: Prevent hrtimer recursion clockevents: Allow set-state callbacks to be optional clocksource/imx: Define clocksource for mx27
2015-07-11Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Kevin Hilman: "A fairly random colletion of fixes based on -rc1 for OMAP, sunxi and prima2 as well as a few arm64-specific DT fixes. This series also includes a late to support a new Allwinner (sunxi) SoC, but since it's rather simple and isolated to the platform-specific code, it's included it for this -rc" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arm64: dts: add device tree for ARM SMM-A53x2 on LogicTile Express 20MG arm: dts: vexpress: add missing CCI PMU device node to TC2 arm: dts: vexpress: describe all PMUs in TC2 dts GICv3: Add ITS entry to THUNDER dts arm64: dts: Add poweroff button device node for APM X-Gene platform ARM: dts: am4372.dtsi: disable rfbi ARM: dts: am57xx-beagle-x15: Provide supply for usb2_phy2 ARM: dts: am4372: Add emif node Revert "ARM: dts: am335x-boneblack: disable RTC-only sleep" ARM: sunxi: Enable simplefb in the defconfig ARM: Remove deprecated symbol from defconfig files ARM: sunxi: Add Machine support for A33 ARM: sunxi: Introduce Allwinner H3 support Documentation: sunxi: Update Allwinner SoC documentation ARM: prima2: move to use REGMAP APIs for rtciobrg ARM: dts: atlas7: add pinctrl and gpio descriptions ARM: OMAP2+: Remove unnessary return statement from the void function, omap2_show_dma_caps memory: omap-gpmc: Fix parsing of devices
2015-07-10Merge branch 'parisc-4.2-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc fixes from Helge Deller: "We have one important patch from Dave Anglin and myself which fixes PTE/TLB race conditions which caused random segmentation faults on our debian buildd servers, and one patch from Alex Ivanov which speeds up the graphical text console on the STI framebuffer driver" * 'parisc-4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Fix some PTE/TLB race conditions and optimize __flush_tlb_range based on timing results stifb: Implement hardware accelerated copyarea
2015-07-10Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes and clean-up from Catalin Marinas: - ACPI fix when checking the validity of the GICC MADT subtable - handle debug exceptions in the el*_inv exception entries - remove pointless register assignment in two compat syscall wrappers - unnecessary include path - defconfig update * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: entry32: remove pointless register assignment arm64: entry: handle debug exceptions in el*_inv arm64: Keep the ARM64 Kconfig selects sorted ACPI / ARM64 : use the new BAD_MADT_GICC_ENTRY macro ACPI / ARM64: add BAD_MADT_GICC_ENTRY() macro arm64: defconfig: Add Ceva ahci to the defconfig arm64: remove another unnecessary libfdt include path
2015-07-10parisc: Fix some PTE/TLB race conditions and optimize __flush_tlb_range ↵John David Anglin
based on timing results The increased use of pdtlb/pitlb instructions seemed to increase the frequency of random segmentation faults building packages. Further, we had a number of cases where TLB inserts would repeatedly fail and all forward progress would stop. The Haskell ghc package caused a lot of trouble in this area. The final indication of a race in pte handling was this syslog entry on sibaris (C8000): swap_free: Unused swap offset entry 00000004 BUG: Bad page map in process mysqld pte:00000100 pmd:019bbec5 addr:00000000ec464000 vm_flags:00100073 anon_vma:0000000221023828 mapping: (null) index:ec464 CPU: 1 PID: 9176 Comm: mysqld Not tainted 4.0.0-2-parisc64-smp #1 Debian 4.0.5-1 Backtrace: [<0000000040173eb0>] show_stack+0x20/0x38 [<0000000040444424>] dump_stack+0x9c/0x110 [<00000000402a0d38>] print_bad_pte+0x1a8/0x278 [<00000000402a28b8>] unmap_single_vma+0x3d8/0x770 [<00000000402a4090>] zap_page_range+0xf0/0x198 [<00000000402ba2a4>] SyS_madvise+0x404/0x8c0 Note that the pte value is 0 except for the accessed bit 0x100. This bit shouldn't be set without the present bit. It should be noted that the madvise system call is probably a trigger for many of the random segmentation faults. In looking at the kernel code, I found the following problems: 1) The pte_clear define didn't take TLB lock when clearing a pte. 2) We didn't test pte present bit inside lock in exception support. 3) The pte and tlb locks needed to merged in order to ensure consistency between page table and TLB. This also has the effect of serializing TLB broadcasts on SMP systems. The attached change implements the above and a few other tweaks to try to improve performance. Based on the timing code, TLB purges are very slow (e.g., ~ 209 cycles per page on rp3440). Thus, I think it beneficial to test the split_tlb variable to avoid duplicate purges. Probably, all PA 2.0 machines have combined TLBs. I dropped using __flush_tlb_range in flush_tlb_mm as I realized all applications and most threads have a stack size that is too large to make this useful. I added some comments to this effect. Since implementing 1 through 3, I haven't had any random segmentation faults on mx3210 (rp3440) in about one week of building code and running as a Debian buildd. Signed-off-by: John David Anglin <dave.anglin@bell.net> Cc: stable@vger.kernel.org # v3.18+ Signed-off-by: Helge Deller <deller@gmx.de>
2015-07-10Merge tag 'powerpc-4.2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: - opal-prd mmap fix from Vaidy - set kernel taint for MCEs from Daniel - alignment exception description from Anton - ppc4xx_hsta_msi build fix from Daniel - opal-elog interrupt fix from Alistair - core_idle_state race fix from Shreyas - hv-24x7 lockdep fix from Sukadev - multiple cxl fixes from Daniel, Ian, Mikey & Maninder - update MAINTAINERS to point at shared tree * tag 'powerpc-4.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: cxl: Check if afu is not null in cxl_slbia powerpc: Update MAINTAINERS to point at shared tree powerpc/perf/24x7: Fix lockdep warning cxl: Fix off by one error allowing subsequent mmap page to be accessed cxl: Fail mmap if requested mapping is larger than assigned problem state area cxl: Fix refcounting in kernel API powerpc/powernv: Fix race in updating core_idle_state powerpc/powernv: Fix opal-elog interrupt handler powerpc/ppc4xx_hsta_msi: Include ppc-pci.h to fix reference to hose_list powerpc: Add plain English description for alignment exception oopses cxl: Test the correct mmio space before unmapping powerpc: Set the correct kernel taint on machine check errors cxl/vphb.c: Use phb pointer after NULL check powerpc/powernv: Fix vma page prot flags in opal-prd driver
2015-07-10arm64: entry32: remove pointless register assignmentMark Rutland
We currently set x27 in compat_sys_sigreturn_wrapper and compat_sys_rt_sigreturn_wrapper, similarly to what we do with r8/why on 32-bit ARM, in an attempt to prevent sigreturns from being restarted. However, on arm64 we have always used pt_regs::syscallno for syscall restarting (for both native and compat tasks), and x27 is never inspected again before being overwritten in kernel_exit. This patch removes the pointless register assignments. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-07-10MIPS: O32: Use compat_sys_getsockopt.Ralf Baechle
We were using the native syscall and that results in subtle breakage. This is the same issue as fixed in 077d0e65618f27b2199d622e12ada6d8f3dbd862 (MIPS: N32: Use compat getsockopt syscall) but that commit did fix it only for N32. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Link: https://bugzilla.kernel.org/show_bug.cgi?id=100291
2015-07-10MIPS: c-r4k: Extend way_string arrayPaul Burton
The L2 cache in the I6400 core has 16 ways, so extend the way_string array to take such caches into account. [ralf@linux-mips.org: Other already supported CPUs are free to support more than 8 ways of cache as well.] Signed-off-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/10640/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-10MIPS: Pistachio: Support CDMM & Fast Debug ChannelJames Hogan
Implement the mips_cdmm_phys_base() platform callback to provide a default Common Device Memory Map (CDMM) physical base address for the Pistachio SoC. This allows the CDMM in each VPE to be configured and probed for devices, such as the Fast Debug Channel (FDC). The physical address chosen is just below the default CPC address, which appears to also be unallocated. The FDC IRQ is also usable on Pistachio, and is routed through the GIC, so implement the get_c0_fdc_int() platform callback using gic_get_c0_fdc_int(), so the FDC driver doesn't have to fall back to polling. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Bresticker <abrestic@chromium.org> Cc: James Hartley <james.hartley@imgtec.com> Cc: linux-mips@linux-mips.org Reviewed-by: Andrew Bresticker <abrestic@chromium.org> Patchwork: http://patchwork.linux-mips.org/patch/9749/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-10MIPS: Malta: Make GIC FDC IRQ workaround Malta specificJames Hogan
Wider testing reveals that the Fast Debug Channel (FDC) interrupt is routed through the GIC just fine on Pistachio SoC, even though it contains interAptiv cores. Clearly the FDC interrupt routing problems previously observed on interAptiv and proAptiv cores are specific to the Malta FPGA bitstreams. Move the workaround for interAptiv and proAptiv out of gic_get_c0_fdc_int() in the GIC irqchip driver into Malta's get_c0_fdc_int() platform callback, to allow the Pistachio SoC to use the FDC interrupt. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Bresticker <abrestic@chromium.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: linux-mips@linux-mips.org Reviewed-by: Andrew Bresticker <abrestic@chromium.org> Cc: James Hartley <james.hartley@imgtec.com> Patchwork: http://patchwork.linux-mips.org/patch/9748/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-10MIPS: c-r4k: Fix cache flushing for MT coresMarkos Chandras
MT_SMP is not the only SMP option for MT cores. The MT_SMP option allows more than one VPE per core to appear as a secondary CPU in the system. Because of how CM works, it propagates the address-based cache ops to the secondary cores but not the index-based ones. Because of that, the code does not use IPIs to flush the L1 caches on secondary cores because the CM would have done that already. However, the CM functionality is independent of the type of SMP kernel so even in non-MT kernels, IPIs are not necessary. As a result of which, we change the conditional to depend on the CM presence. Moreover, since VPEs on the same core share the same L1 caches, there is no need to send an IPI on all of them so we calculate a suitable cpumask with only one VPE per core. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: <stable@vger.kernel.org> # 3.15+ Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/10654/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09Merge tag 'omap-for-v4.2/fixes-rc1' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Merge "omap fixes against v4.2-rc1" from Tony Lindgren: Minor fixes for omaps against v4.2-rc1. Mostly just minor dts changes except for a GPMC fix to not use names for probing devices. Also a one liner clean-up to remove unecessary return from a void function. The summary for the changes being: - Fix probe for GPMC devices by reoving limitations based on device name - Remove unnecessary return from a void function - Revert beaglebone RTC sleep fix, we now have a better fix merged - Add am4372 EMIF node to fix a warning - Add am57xx-beagle-x15 power supply to fix USB2 if USB1 is disabled - Disable rfbi for am4372 as it does not have a driver * tag 'omap-for-v4.2/fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: dts: am4372.dtsi: disable rfbi ARM: dts: am57xx-beagle-x15: Provide supply for usb2_phy2 ARM: dts: am4372: Add emif node Revert "ARM: dts: am335x-boneblack: disable RTC-only sleep" ARM: OMAP2+: Remove unnessary return statement from the void function, omap2_show_dma_caps memory: omap-gpmc: Fix parsing of devices
2015-07-09Merge tag 'sunxi-late-for-4.2' of ↵Kevin Hilman
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into fixes Merge "Allwinner late changes for 4.2" from Maxime Ripard: Allwinner late changes for 4.2 A bunch of defconfig changes, and some patches to make the Allwinner H3 and A33 boot properly. * tag 'sunxi-late-for-4.2' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux: ARM: sunxi: Enable simplefb in the defconfig ARM: Remove deprecated symbol from defconfig files ARM: sunxi: Add Machine support for A33 ARM: sunxi: Introduce Allwinner H3 support Documentation: sunxi: Update Allwinner SoC documentation
2015-07-09Revert "MIPS: Kconfig: Disable SMP/CPS for 64-bit"Markos Chandras
This reverts commit 6ca716f2e5571d25a3899c6c5c91ff72ea6d6f5e. SMP/CPS is now supported on 64bit cores. Cc: <stable@vger.kernel.org> # 4.1 Reviewed-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10592/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: cps-vec: Use macros for various arithmetics and memory operationsMarkos Chandras
Replace lw/sw and various arithmetic instructions with macros so the code can work on 64-bit kernels as well. Cc: <stable@vger.kernel.org> # 3.16+ Reviewed-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10591/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: kernel: cps-vec: Replace KSEG0 with CKSEG0Markos Chandras
In preparation for 64-bit CPS support, we replace KSEG0 with CKSEG0 so 64-bit kernels can be supported. Cc: <stable@vger.kernel.org> # 3.16+ Reviewed-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10590/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: kernel: cps-vec: Use ta0-ta3 pseudo-registers for 64-bitMarkos Chandras
The cps-vec code assumes O32 ABI and uses t4-t7 in quite a few places. This breaks the build on 64-bit. As a result of which, use the pseudo-registers ta0-ta3 to make the code compatible with 64-bit. Cc: <stable@vger.kernel.org> # 3.16+ Reviewed-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10589/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: kernel: cps-vec: Replace mips32r2 ISA level with mips64r2Markos Chandras
mips32r2 is a subset of mips64r2, so we replace mips32r2 with mips64r2 in preparation for 64-bit CPS support. Cc: <stable@vger.kernel.org> # 3.16+ Reviewed-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10588/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: kernel: cps-vec: Replace 'la' macro with PTR_LAMarkos Chandras
The PTR_LA macro will pick the correct "la" or "dla" macro to load an address to a register. This gets rids of the following warnings (and others) when building a 64-bit CPS kernel: arch/mips/kernel/cps-vec.S:63: Warning: la used to load 64-bit address arch/mips/kernel/cps-vec.S:159: Warning: la used to load 64-bit address arch/mips/kernel/cps-vec.S:220: Warning: la used to load 64-bit address arch/mips/kernel/cps-vec.S:240: Warning: la used to load 64-bit address [...] Cc: <stable@vger.kernel.org> # 3.16+ Reviewed-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10587/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: kernel: smp-cps: Fix 64-bit compatibility errors due to pointer castingMarkos Chandras
Commit 1d8f1f5a780a ("MIPS: smp-cps: hotplug support") added hotplug support in the SMP/CPS implementation but it introduced a few build problems on 64-bit kernels due to pointer being casted to and from 'int' C types. We fix this problem by using 'unsigned long' instead which should match the size of the pointers in 32/64-bit kernels. Finally, we fix the comment since the CM base address is loaded to v1($3) instead of v0. Fixes the following build problems: arch/mips/kernel/smp-cps.c: In function 'wait_for_sibling_halt': arch/mips/kernel/smp-cps.c:366:17: error: cast from pointer to integer of different size [-Werror=pointer-to-int-cast] [...] arch/mips/kernel/smp-cps.c: In function 'cps_cpu_die': arch/mips/kernel/smp-cps.c:427:13: error: cast to pointer from integer of different size [-Werror=int-to-pointer-cast] cc1: all warnings being treated as errors Fixes: 1d8f1f5a780a ("MIPS: smp-cps: hotplug support") Cc: <stable@vger.kernel.org> # 3.16+ Reviewed-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10586/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: Fix erroneous JR emulation for MIPS R6Markos Chandras
Commit 5f9f41c474befb4ebbc40b27f65bb7d649241581 ("MIPS: kernel: Prepare the JR instruction for emulation on MIPS R6") added support for emulating the JR instruction on MIPS R6 cores but that introduced a bug which could be triggered when hitting a JALR opcode because the code used the wrong field in the 'r_format' struct to determine the instruction opcode. This lead to crashes because an emulated JALR instruction was treated as a JR one when the R6 emulator was turned off. Fixes: 5f9f41c474be ("MIPS: kernel: Prepare the JR instruction for emulation on MIPS R6") Cc: <stable@vger.kernel.org> # 4.0+ Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10583/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: Fix branch emulation for BLTC and BGEC instructionsMarkos Chandras
Commits f1b44067c19258b7614e3cd09dfe8d8e12ff5895 ("MIPS: Emulate the new MIPS R6 B{L,G}T{Z,}{AL,}C instructions") and commit a8ff66f52d3f17b5ae793955270675c197f73d6c ("MIPS: Emulate the new MIPS R6 B{L,G}E{Z,}{AL,}C instructions") added support for emulating various branch compact instructions. However, it missed the case for those which use the old BLEZL and BGTZL opcodes leading to random crashes when the R6 emulator is disabled. We fix this by ensuring that the 'rt' field is not zero which is always true for these branch compact instructions. Fixes: f1b44067c192 ("MIPS: Emulate the new MIPS R6 B{L,G}T{Z,}{AL,}C instructions") Fixes: a8ff66f52d3f ("MIPS: Emulate the new MIPS R6 B{L,G}E{Z,}{AL,}C instructions") Cc: <stable@vger.kernel.org> # 4.0+ Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Markos Chandras <markos.chandras@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/10582/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: kernel: traps: Fix broken indentationMarkos Chandras
Fix broken indentation caused by the SMTC removal commit b633648c5ad3cfbda0b3daea50d2135d44899259 ("MIPS: MT: Remove SMTC support") Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Fixes: b633648c5ad3c ("MIPS: MT: Remove SMTC support") Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/10581/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09MIPS: bootmem: Don't use memory holes for page bitmapAlexander Sverdlin
Commit f9a7febd leads to a fact that mapstart and therefore a page bitmap for bootmem allocator immediately follows initrd_end. This doesn't always work well on Octeon, where there are holes in PFN ranges (refer to 5b3b1688 and 4MB-aligned PFN allocation). Depending on the inird location it could happen, that mapstart would be in an area not allocated by plat_mem_setup() in arch/mips/cavium-octeon/setup.c, but in the alignment hole between initrd and the next PFN area. Later on this memory will be unconditionally made available to buddy allocator at the end of free_all_bootmem_core() (mm/bootmem.c). All of this results in Linux using the memory not designated for Linux in Octeon's plat_mem_setup(), which in turn means corruption of the memory used by another OS/baremetal code on the same SoC. It doesn't look to me as a problem of Octeon platform code, but rather as an inability of f9a7febd to deal correctly with the fragmented memory-mappings. Proposed fix moves the check for initrd address to the same calculation-loop in bootmem_init() (arch/mips/kernel/setup.c), which also accounts for kernel code location. This should result in mapstart located starting from the first PFN area after kernel code AND initrd. Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com> Cc: linux-mips@linux-mips.org Cc: David Daney <david.daney@cavium.com> Cc: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com> Cc: Huacai Chen <chenhc@lemote.com> Cc: Andreas Herrmann <andreas.herrmann@caviumnetworks.com> Cc: Joe Perches <joe@perches.com> Cc: Steven J. Hill <Steven.Hill@imgtec.com> Cc: Yusuf Khan <yusuf.khan@nokia.com> Cc: Michael Kreuzer <michael.kreuzer@nokia.com> Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Patchwork: https://patchwork.linux-mips.org/patch/10594/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-09cris: Replace do_posix_clock_monotonic_gettime()Thomas Gleixner
ktime_get_ts() is the proper interface today. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jesper Nilsson <jesper.nilsson@axis.com>
2015-07-08Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull arch/tile fix from Chris Metcalf: "This fix eliminates a "section mismatch" warning caused by the new __ex_table checking code in modpost" * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: modpost: work correctly with tile coldtext sections
2015-07-08modpost: work correctly with tile coldtext sectionsChris Metcalf
The tilegx and tilepro compilers use .coldtext for their unlikely executed text section name, so an __attribute__((cold)) function will (when compiled with higher optimization levels) land in the .coldtext section. Modify modpost to add .coldtext to the set of OTHER_TEXT_SECTIONS so we don't get warnings about referencing such a section in an __ex_table block, and then also modify arch/tile/lib/memcpy_user_64.c so that it uses plain ".coldtext" instead of ".coldtext.memcpy". The latter naming is a relic of an earlier use of -ffunction-sections, which we no longer use by default. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au>
2015-07-08arm64: dts: add device tree for ARM SMM-A53x2 on LogicTile Express 20MGKristina Martsenko
Add a DTS file for the MP2 Cortex-A53 Soft Macrocell Model implemented on a LogicTile Express 20MG (V2F-1XV7) daughterboard. This is based on the version that's currently available from the ARM DTS repository [1]. [1] git://linux-arm.org/arm-dts.git Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com> Acked-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2015-07-08arm: dts: vexpress: add missing CCI PMU device node to TC2Sudeep Holla
The CCI device node was added to vexpress CA15_A7(i.e. TC2) much before the CCI PMU support and binding was added. This patch adds the missing PMU node so that CCI PMUs can be used on TC2. Cc: Liviu Dudau <liviu.dudau@arm.com> Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2015-07-08arm: dts: vexpress: describe all PMUs in TC2 dtsMark Rutland
The dts for the CoreTile Express A15x2 A7x3 (TC2) only describes the PMUs of the Cortex-A15 CPUs, and not the Cortex-A7 CPUs. Now that we have a mechanism for describing disparate PMUs and their interrupts in device tree, this patch makes use of these to describe the PMUs for all CPUs in the system. For consistency, the existing A15 PMU interrupt-affinity property is reflowed across two lines. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Sudeep Holla <sudeep.holla@arm.com> Cc: Liviu Dudau <liviu.dudau@arm.com> Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2015-07-08GICv3: Add ITS entry to THUNDER dtsTirumalesh Chalamarla
The PCIe host controller uses MSIs provided by GICv3 ITS. Enable it on Thunder SoCs by adding an entry to DT. Signed-off-by: Tirumalesh Chalamarla <tchalamarla@cavium.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2015-07-08Merge tag 'sirf-iobrg2regmap-for-4.2' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux into fixes Merge "CSR SiRFSoC rtc iobrg move to regmap for 4.2" from Barry Song: move CSR rtc iobrg read/write API to be regmap this moves to general APIs, and all drivers will be changed based on it. * tag 'sirf-iobrg2regmap-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux: ARM: prima2: move to use REGMAP APIs for rtciobrg
2015-07-08Merge tag 'atlas7-pinctrl-dts-for-4.2' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux into fixes Merge "CSR atlas7 pinctrl descriptions for 4.2" from Barry Song: add atlas7 pinctrl dts stuff add atlas7 pin groups and gpio/pin mapping descriptions * tag 'atlas7-pinctrl-dts-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux: ARM: dts: atlas7: add pinctrl and gpio descriptions
2015-07-08arm64: dts: Add poweroff button device node for APM X-Gene platformY Vo
This patch adds poweroff button device node to support poweroff feature on APM X-Gene Mustang platform. Signed-off-by: Y Vo <yvo@apm.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2015-07-08arm64: entry: handle debug exceptions in el*_invMark Rutland
Currently we enable debug exceptions before reading ESR_EL1 in both el0_inv and el1_inv. If a debug exception is taken before we read ESR_EL1, the value will have been corrupted. As el*_inv is typically fatal, an intervening debug exception results in misleading debug information being logged to the console, but is not otherwise harmful. As with the other entry paths, we can use the ESR_EL1 value stashed earlier in the exception entry (in x25 for el0_sync{,_compat}, and x1 for el1_sync), giving us better error reporting in this case. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-07-08x86/kconfig: Fix typo in the CONFIG_CMDLINE_BOOL help textSébastien Hinderer
Signed-off-by: Sébastien Hinderer <Sebastien.Hinderer@ens-lyon.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Samuel Thibault <Samuel.Thibault@ens-lyon.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-08powerpc/perf/24x7: Fix lockdep warningSukadev Bhattiprolu
The sysfs attributes for the 24x7 counters are dynamically allocated. Initialize the attributes using sysfs_attr_init() to fix following warning which occurs when CONFIG_DEBUG_LOCK_VMALLOC=y. [ 0.346249] audit: initializing netlink subsys (disabled) [ 0.346284] audit: type=2000 audit(1436295254.340:1): initialized [ 0.346489] BUG: key c0000000efe90198 not in .data! [ 0.346491] DEBUG_LOCKS_WARN_ON(1) [ 0.346502] ------------[ cut here ]------------ [ 0.346504] WARNING: at ../kernel/locking/lockdep.c:3002 [ 0.346506] Modules linked in: Reported-by: Gustavo Luiz Duarte <gustavold@linux.vnet.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Gustavo Luiz Duarte <gustavold@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-07-08MIPS: O32: Do not handle require 32 bytes from the stack to be readable.Ralf Baechle
Commit 46e12c07b3b9603c60fc1d421ff18618241cb081 (MIPS: O32 / 32-bit: Always copy 4 stack arguments.) change the O32 syscall handler to always load four arguments from the userspace stack even for syscalls that require fewer or no arguments to be copied. This removes a large table from kernel space and need to maintain it. It appeared that it was ok the implementation chosen requires 16 bytes of readable stack space above the user stack pointer. Turned out a few threading implementations munmap the user stack before the thread exits resulting in errors due to the unreadable stack. We now treat any failed load as a if the loaded value was zero and let the actual syscall deal with the situation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-07Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "These are late by a week; they should have been merged during the merge window, but unfortunately, the ARM kernel build/boot farms were indicating random failures, and it wasn't clear whether the cause was something in these changes or something during the merge window. This is a set of merge window fixes with some documentation additions" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: avoid unwanted GCC memset()/memcpy() optimisations for IO variants ARM: pgtable: document mapping types ARM: io: convert ioremap*() to functions ARM: io: fix ioremap_wt() implementation ARM: io: document ARM specific behaviour of ioremap*() implementations ARM: fix lockdep unannotated irqs-off warning ARM: 8397/1: fix vdsomunge not to depend on glibc specific error.h ARM: add helpful message when truncating physical memory ARM: add help text for HIGHPTE configuration entry ARM: fix DEBUG_SET_MODULE_RONX build dependencies ARM: 8396/1: use phys_addr_t in pfn_to_kaddr() ARM: 8394/1: update memblock limit after mapping lowmem ARM: 8393/1: smp: Fix suspicious RCU usage with ipi tracepoints
2015-07-07MIPS, CPUFREQ: Fix spelling of Institute.Ralf Baechle
2015-07-07MIPS: Lemote 2F: Fix build caused by recent mass rename.Ralf Baechle
CC arch/mips/loongson64/lemote-2f/clock.o /home/ralf/src/linux/linux-mips/arch/mips/loongson64/lemote-2f/clock.c:18:40: fatal error: asm/mach-loongson/loongson.h: No such file or directory #include <asm/mach-loongson/loongson.h> ^ compilation terminated. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-07arm64: Keep the ARM64 Kconfig selects sortedCatalin Marinas
Move EDAC_SUPPORT to the right place. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-07-07ACPI / ARM64 : use the new BAD_MADT_GICC_ENTRY macroAl Stone
For those parts of the arm64 ACPI code that need to check GICC subtables in the MADT, use the new BAD_MADT_GICC_ENTRY macro instead of the previous BAD_MADT_ENTRY. The new macro takes into account differences in the size of the GICC subtable that the old macro did not; this caused failures even though the subtable entries are valid. Fixes: aeb823bbacc2 ("ACPICA: ACPI 6.0: Add changes for FADT table.") Signed-off-by: Al Stone <al.stone@linaro.org> Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-07-07ACPI / ARM64: add BAD_MADT_GICC_ENTRY() macroAl Stone
The BAD_MADT_ENTRY() macro is designed to work for all of the subtables of the MADT. In the ACPI 5.1 version of the spec, the struct for the GICC subtable (struct acpi_madt_generic_interrupt) is 76 bytes long; in ACPI 6.0, the struct is 80 bytes long. But, there is only one definition in ACPICA for this struct -- and that is the 6.0 version. Hence, when BAD_MADT_ENTRY() compares the struct size to the length in the GICC subtable, it fails if 5.1 structs are in use, and there are systems in the wild that have them. This patch adds the BAD_MADT_GICC_ENTRY() that checks the GICC subtable only, accounting for the difference in specification versions that are possible. The BAD_MADT_ENTRY() will continue to work as is for all other MADT subtables. This code is being added to an arm64 header file since that is currently the only architecture using the GICC subtable of the MADT. As a GIC is specific to ARM, it is also unlikely the subtable will be used elsewhere. Fixes: aeb823bbacc2 ("ACPICA: ACPI 6.0: Add changes for FADT table.") Signed-off-by: Al Stone <al.stone@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> [catalin.marinas@arm.com: extra brackets around macro arguments] Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-07-07Merge branches 'fixes' and 'ioremap' into for-linusRussell King
2015-07-07x86/irq: Retrieve irq data after locking irq_descThomas Gleixner
irq_data is protected by irq_desc->lock, so retrieving the irq chip from irq_data outside the lock is racy vs. an concurrent update. Move it into the lock held region. While at it add a comment why the vector walk does not require vector_lock. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: xiao jin <jin.xiao@intel.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Borislav Petkov <bp@suse.de> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Link: http://lkml.kernel.org/r/20150705171102.331320612@linutronix.de
2015-07-07x86/irq: Use proper locking in check_irq_vectors_for_cpu_disable()Thomas Gleixner
It's unsafe to examine fields in the irq descriptor w/o holding the descriptor lock. Add proper locking. While at it add a comment why the vector check can run lock less Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: xiao jin <jin.xiao@intel.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Borislav Petkov <bp@suse.de> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Link: http://lkml.kernel.org/r/20150705171102.236544164@linutronix.de
