Update model and compatibility nodes to be more in-line with mainline.
This automatically selects options for zone DMA and 64 bit DMA addresses
when LPAE is enabled on ARM Tegra platforms. These options are required
for proper operation with LPAE enabled.
The ZONE_DMA option is required to ensure that drivers that allocate DMA
memory get buffers from the first 4 GiB. This is necessary because a lot
of the controllers only support addressing 32 bits.
As for ARCH_DMA_ADDR_T_64BIT, there are situations where devices that do
support addresses of more than 32 bits (such as the display controller
or the GPU) can run without translating addresses through an IOMMU on a
device with more than 4 GiB of system memory.
Note that both of these options are stop-gap solutions required only
until the IOMMU can be properly integrated with the DMA mapping API and
drivers use that properly and consistently.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
[treding@nvidia.com: specify rationale for options]
Signed-off-by: Thierry Reding <treding@nvidia.com>
(backported from commit 6aa26c5d66595494e810c791602d87a572c78808)
With gcc 7 the following compile time error occurs:
| arch/arm/mach-tegra/tegra11_soctherm.c:2978:40: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses]
| s->sensor_enable = s->sensor_enable ?: therm->zone_enable;
| arch/arm/mach-tegra/powergate-t12x.c:814:10: error: statement will never be executed [-Werror=switch-unreachable]
| return true;
Activate PWM pin muxing for Apalis PWM3. Note that the same PWM3 is
already active on pu6 being Apalis BKL1_PWM as well. Therefore exporting
that one for raw sysfs access will fail and one has to revert to using
the pwm backlight.
Enable support for the Large Physical Address Extension aka LPAE.
It turns out that the current PCIe reset implementation is not quite
working reliably due to some Intel i210 errata. Fix this by making sure
the i210's +V3.3_ETH rail is properly disabled during its reset
sequence.
Also further improve on the bringing up the PCIe switch as found on the
Apalis Evaluation board.
Toradex Carrier boards use the ST M41T0 RTC (not M41T00). The RTC
is almost the same, but the M41T0 needs some special handling in
case the oscillator fails. Now that support for this difference is
available, using the new compatible string to make use of it.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Prepare for snapd integration.
Change SPI2 clock parent to clk_m being 12 MHz which is anyway the
maximum frequency the K20 micro controller's SPI peripheral can be run.
This further allows for the EzPort to be run at exactly 2 MHz which is
the maximum allowed as well.
(cherry picked from commit 15e73283a975a1b899d7f6807aa882ef885573dd)
This patch includes CAN driver and improvements in SPI communications
for Apalis TK1 k20 based MFD.
Requires firmware version 0.9.
This patch fixes pllx max value to 1530 and 1836Mhz
based on embedded clok settings considering aging factor
for CD575MI 24x7 and CD575MI 4/4/16 config
Bug 1900076
Change-Id: I9c6a769787fc04eac7ce4548e1a37a9a76972a6c
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/1464315
GVS: Gerrit_Virtual_Submit
Reviewed-by: Peter Chiang <pchiang@nvidia.com>
New emc table for samsung dram is added on JetsonTK1 target.
Based on tegra bct strap value it can be chosen dynamically.
Both emc table and embedded emc table has been updated accordingly.
Bug 1752744
Change-Id: Ifc577d925712690daec6c6f1121458f01f720846
Signed-off-by: Sandipan Patra <spatra@nvidia.com>
Reviewed-on: http://git-master/r/1312498
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Jetson TK1 doesn't support usb charging but the detection is still
running. Disable it to avoid unexpected behavior.
Bug 1861049
Change-Id: I13425d69e190a75084486ff1fc9afeb8aa7acb60
Signed-off-by: Roger Hsieh <rhsieh@nvidia.com>
Reviewed-on: http://git-master/r/1308015
Due to problems with LP0 sleep, make LP1 the default option.
Use modedb to set mode on Apalis TK1 frame buffer/display
controller.
Allow to specify framebuffer videomode using kernel command line
parameters. NVIDIAs binary X driver later on picks up those settings
and start X with current mode settings, if no EDID data are available.
Reused some of the implementation from Stefan's work for modedb
support[1] on Tegra20/30
[1] http://git.toradex.com/cgit/linux-toradex.git/commit/?h=tegra-next&id=1d3625dd9903bcc59e2df56836565ebb682948c1
Instead of providing revision, SKU and PID information
via soc_id pass SoC's unique ID.
Signed-off-by: Wojciech Bieganski <wbieganski@antmicro.com>
Configure GPIO connected to i210 wake-up pin
as a wake-up source in the device tree.
Fix suspend and resume for LP1 sleep.
On Apalis TK1 boards K20 MCU is used
for CAN, GPIO, ADC and touch screen.
This patch includes support for core MFD device, GPIO, ADC
and touch screen.
Integrate support for the carrier board level I2C RTC.
for UCM1 CD575M, check for cpu speedo 5 to
apply edp contraints
Bug 200195229
Bug 200199079
Change-Id: I704dd64f32c82c7499b6c5f0c96c04fdc062cf71
Reviewed-on: http://git-master/r/1271709
Bug 1783583
Change-Id: I8b0e865db02c00f741dafb473d4bd39c5075f23f
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/1173469
(cherry picked from commit 453a77c5cd9a1316307458203365f9eb5bda62de)
Reviewed-on: http://git-master/r/1174714
(cherry picked from commit f2ce702f49c5631e8a7cbda6fbf09140f8fb55d9)
Reviewed-on: http://git-master/r/1239794
(cherry picked from commit f62bd56958ca743d512f757555e4a3b66f4c9cff)
Reviewed-on: http://git-master/r/1251020
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Now with the working card detect pin in place on the latest V1.1 HW
polling is no longer required. Therefore make it an optional define for
V1.0 samples.
Add sd card detect SD1_CD# applicable for V1.1 modules using GPIO_PV2.
Configure Apalis MMC1 D6 GPIO on SDMMC3_CLK_LB_IN as reserved function
without any pull-up/down.
Configure GPIO_PV2 as SD1_CD# according to latest V1.1 HW.
Leave SDMMC3_CLK_LB_OUT muxed as SDMMC3 with output driver enabled aka
not tristated and input driver enabled as well as it features some
magic properties even though the external loopback is disabled and the
internal loopback used as per SDMMC_VENDOR_MISC_CNTRL_0 register's
SDMMC_SPARE1 bits being set to 0xfffd according to the TRM! This pin is
now a not-connect on V1.1 HW in order to avoid any interference.
Pull-up GPIO_PI6 connected to TMP451's ALERT#/THERM2#.
While at it improve some comments.
Fix PCIe clock and reset not conforming to specification by moving PCIe
reset handling including the PLX PEX 8605 errata 5 workaround from the
board platform data into the right places timing wise in the PCIe driver
itself.
Also add a kernel command line argument to allow using the Apalis GPIO7
as a regular GPIO rather than for above mentioned PLX PEX 8605
workaround:
pex_perst=0
(cherry picked from tegra-next commit
a2f63805703b43d55d91ae17f10d0049bf0f625e)
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Integrate SoC camera support for the following CSI-2 codecs/sensors:
- Analog Devices ADV7280-M, analog camera decoder with deinterlacer,
PAL/NTSC@60fps
- ON Semiconductor (formerly Aptina) AP1302 ISP + AR1820 image sensor,
13Mpx, 1080p@30fps
- OmniVision OV5640, 5Mpx sensor, 1080p@30fps
- Toshiba TC358743 HDMI to CSI-2 bridge, 1080p@60fps
Connected to CSI CIL-E. Cameras doesn't work simultaneously.
A major part of the driver has been rewritten in order to avoid
writing binary blobs to the chip.
This version also adds support for more video modes.
Input video modes supported:
- 1920x1080 @ 60
- 1280x1024 @ 75
- 1280x720 @ 60
- 1024x768 @ 75
- 800x600 @ 75
- 640x480 @ 75
known issues:
- decoder outputs PAL (720x576), but the image
looks fine only when streamed in 640x576 mode,
- vertical synchronisation glitches,
- setting queue-size in gstreamer greater than 1
results in blinking image,
- every start of streaming requires reloading of
the modules
known issues:
- HDMI input works only in 640x480 mode, 720p only in
test pattern mode, any 4-lane mode doesn't work
- set HDMI transmitter to VGA mode before
starting the stream
known issues:
- works only in 1080p mode,
the modules
Re-add SoC camera platform data from Ardbeg/Jetson TK1 board files.
Integrate optional eDP support (e.g. uncomment define of APALIS_TK1_EDP
as found in the platform data header file.
Tested using a prototype Apalis TK1 mezzanine connecting to a Samsung
LTN156FL02-L01 panel featuring a 4K aka UHD resolution of 3840 by 2160.
Select dp pinmux function for Apalis GPIO2 aka DP_HPD to allow it to be used as
eDP hot-plug detect. From user space customer may still configure and use it as
a regular GPIO if desired.
