Configure Apalis MMC1 D6 GPIO on SDMMC3_CLK_LB_IN as reserved function
without any pull-up/down.
Configure GPIO_PV2 as SD1_CD# according to latest V1.1 HW.
Leave SDMMC3_CLK_LB_OUT muxed as SDMMC3 with output driver enabled aka
not tristated and input driver enabled as well as it features some
magic properties even though the external loopback is disabled and the
internal loopback used as per SDMMC_VENDOR_MISC_CNTRL_0 register's
SDMMC_SPARE1 bits being set to 0xfffd according to the TRM! This pin is
now a not-connect on V1.1 HW in order to avoid any interference.
Pull-up GPIO_PI6 connected to TMP451's ALERT#/THERM2#.
While at it improve some comments.
Fix PCIe clock and reset not conforming to specification by moving PCIe
reset handling including the PLX PEX 8605 errata 5 workaround from the
board platform data into the right places timing wise in the PCIe driver
itself.
Also add a kernel command line argument to allow using the Apalis GPIO7
as a regular GPIO rather than for above mentioned PLX PEX 8605
workaround:
pex_perst=0
(cherry picked from tegra-next commit
a2f63805703b43d55d91ae17f10d0049bf0f625e)
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Integrate SoC camera support for the following CSI-2 codecs/sensors:
- Analog Devices ADV7280-M, analog camera decoder with deinterlacer,
PAL/NTSC@60fps
- ON Semiconductor (formerly Aptina) AP1302 ISP + AR1820 image sensor,
13Mpx, 1080p@30fps
- OmniVision OV5640, 5Mpx sensor, 1080p@30fps
- Toshiba TC358743 HDMI to CSI-2 bridge, 1080p@60fps
Connected to CSI CIL-E. Cameras doesn't work simultaneously.
A major part of the driver has been rewritten in order to avoid
writing binary blobs to the chip.
This version also adds support for more video modes.
Input video modes supported:
- 1920x1080 @ 60
- 1280x1024 @ 75
- 1280x720 @ 60
- 1024x768 @ 75
- 800x600 @ 75
- 640x480 @ 75
known issues:
- decoder outputs PAL (720x576), but the image
looks fine only when streamed in 640x576 mode,
- vertical synchronisation glitches,
- setting queue-size in gstreamer greater than 1
results in blinking image,
- every start of streaming requires reloading of
the modules
known issues:
- HDMI input works only in 640x480 mode, 720p only in
test pattern mode, any 4-lane mode doesn't work
- set HDMI transmitter to VGA mode before
starting the stream
known issues:
- works only in 1080p mode,
the modules
Re-add SoC camera platform data from Ardbeg/Jetson TK1 board files.
Integrate optional eDP support (e.g. uncomment define of APALIS_TK1_EDP
as found in the platform data header file.
Tested using a prototype Apalis TK1 mezzanine connecting to a Samsung
LTN156FL02-L01 panel featuring a 4K aka UHD resolution of 3840 by 2160.
Select dp pinmux function for Apalis GPIO2 aka DP_HPD to allow it to be used as
eDP hot-plug detect. From user space customer may still configure and use it as
a regular GPIO if desired.
Remove default GPIO functionality from Apalis GPIO1 aka GPIO_PFF2 and Apalis
GPIO2 aka DP_HPD as if later trying to use resp. pins as special function (e.g.
the former for eDP hot-plug detect and the later for SATA data activity) there
is currently no sane way of removing the GPIO functionality again.
Uncomment UART4 device tree node and enable support in machfile
arch/arm/mach-tegra/board-ardbeg.c: In function 'ardbeg_touch_init':
arch/arm/mach-tegra/board-ardbeg.c:1159:6: error: this 'else' clause
does not guard... [-Werror=misleading-indentation]
} else
arch/arm/mach-tegra/board-ardbeg.c:1161:5: note: ...this statement, but
the latter is misleadingly indented as if it is guarded by the 'else'
rm31080a_ardbeg_spi_board[0].irq =
arch/arm/mach-tegra/board-ardbeg.c: In function 'tegra_ardbeg_late_init':
arch/arm/mach-tegra/board-ardbeg.c:1470:2: error: this 'else' clause
else
arch/arm/mach-tegra/board-ardbeg.c:1474:3: note: ...this statement, but
tegra_io_dpd_enable(&pexbias_io);
At top level:
arch/arm/mach-tegra/board-ardbeg.c:1608:27: error:
'loki_dt_board_compat' defined but not used
[-Werror=unused-const-variable=]
static const char * const loki_dt_board_compat[] = {
Optimized DVFS table for Apalis TK1 boards.
This patch adds support for the Toradex Apalis TK1 acomputer on module
which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality which is not yet
supported.
This is known to boot into either a basic Angstrom/OpenEmbedded/Yocto
or L4T/JetPack Ubuntu based image.
The following things are known to work to a certain extend:
- analogue/digital audio
- debug UART1
- DVFS power management incl. low power core migration
- eMMC
- gigabit Ethernet
- GPIOs
- HDMI (incl. HDA audio)
- I2C
- LVDS
- PCIe
- SATA
- SD/MMC cards
- temperature sensor
- USB host ports
The rest is untested.
Fix the backlight PWM instance used and add 800x600 and 1024x600 LVDS
panel timings.
This fixes the following GCC 5.2 built time error:
arch/arm/mach-tegra/tegra_cl_dvfs.c: In function 'monitor_get':
arch/arm/mach-tegra/tegra_cl_dvfs.c:372:8: error: 'v' may be used uninitialized in this function [-Werror=maybe-uninitialized]
*data &= CL_DVFS_MONITOR_DATA_MASK;
arch/arm/mach-tegra/tegra_cl_dvfs.c:2949:6: note: 'v' was declared here
u32 v, s;
arch/arm/mach-tegra/tegra_cl_dvfs.c: In function 'cl_dvfs_calibrate':
arch/arm/mach-tegra/tegra_cl_dvfs.c:372:8: error: 'data' may be used uninitialized in this function [-Werror=maybe-uninitialized]
arch/arm/mach-tegra/tegra_cl_dvfs.c:902:11: note: 'data' was declared here
u32 val, data;
newer compilers throw the following error:
arch/arm/mach-tegra/tegra12_clocks.c: In function 'tegra12_cpu_clk_init':
arch/arm/mach-tegra/tegra12_clocks.c:1334:31: error: logical not is only applied to the left hand side of comparison [-Werror=logical-not-parentheses]
c->state = (!is_lp_cluster() == (c->u.cpu.mode == MODE_G))? ON : OFF;
While working on the 32-bit ARM port of UEFI, I noticed a strange
corruption in the kernel log. The following snprintf() statement
(in drivers/firmware/efi/efi.c:efi_md_typeattr_format())
snprintf(pos, size, "|%3s|%2s|%2s|%2s|%3s|%2s|%2s|%2s|%2s]",
was producing the following output in the log:
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | |WB|WT|WC|UC]*
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | | | | |UC]
As it turns out, this is caused by incorrect code being emitted for
the string() function in lib/vsprintf.c. The following code
if (!(spec.flags & LEFT)) {
while (len < spec.field_width--) {
if (buf < end)
*buf = ' ';
++buf;
for (i = 0; i < len; ++i) {
if (buf < end)
*buf = *s;
++buf; ++s;
if (buf < end)
*buf = ' ';
++buf;
when called with len == 0, triggers an issue in the GCC SRA optimization
pass (Scalar Replacement of Aggregates), which handles promotion of signed
struct members incorrectly. This is a known but as yet unresolved issue.
(https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65932). In this particular
case, it is causing the second while loop to be executed erroneously a
single time, causing the additional space characters to be printed.
So disable the optimization by passing -fno-ipa-sra.
Cc: <stable@vger.kernel.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
(cherry picked from commit a077224fd35b2f7fbc93f14cf67074fc792fbac2)
With compilers which follow the C99 standard (like modern versions of gcc and
clang), "extern inline" does the wrong thing (emits code for an externally
linkable version of the inline function). In this case using static inline
and removing the NULL version of return_address in return_address.c does
the right thing.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Reviewed-by: Mark Charlebois <charlebm@gmail.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
(cherry picked from commit aeea3592a13bf12861943e44fc48f1f270941f8d)
Following support added
DVFS for Gauranteed freq considering aging
CPU freq limit at higher temperature
EDP max current limits for each SKU
Bug 200195229
Change-Id: If00f3fd6b891cf366047dda331bd7ab1c15b40f7
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/1146577
GVS: Gerrit_Virtual_Submit
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
select emc evfs table based on DDR present
using RAMCODE
Bug 200195279
Change-Id: I7fbc693383c9e231b2c2119020eebc7bba544c6e
Reviewed-on: http://git-master/r/1144528
Reviewed-by: Jimmy Zhang <jimmzhang@nvidia.com>
Added kernel configurations to support
systemd functionality
boot.img size is increased by 69632 bytes
Bug 1731796
Change-Id: I4209fee15843ac645600500ed8c9fc37b7ff0c04
Signed-off-by: Ninad Malwade <nmalwade@nvidia.com>
Reviewed-on: http://git-master/r/1134828
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Rajkumar Kasirajan <rkasirajan@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
enable TEGRA_WATCHDOG_ENABLE_ON_PROBE to set "timeout" in probe call
Bug 200160105
Change-Id: Ifcef77b3229acee821c5cdd2f31e449e010b9d2f
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: http://git-master/r/927464
change regulator-init-microvolt for ams-as3722.
Bug 1634862
Change-Id: Ie4b9d1976fca9f8bdebfb039ef2c0337e1b55dfd
Reviewed-on: http://git-master/r/794739
Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Reviewed-by: R Raj Kumar <rrajk@nvidia.com>
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
In case tegra_dc_sync_windows is interrupted by signal,
return the error to caller application
Bug 200090492
Change-Id: Id69fbe38d0abe0b3e71eb5a413db241ebcf0a0ae
Reviewed-on: http://git-master/r/784754
Bug 1643556
Change-Id: I7330bd3ec33e2309577c75bac79e120167b0f81e
Signed-off-by: Arun Kannan <akannan@nvidia.com>
Reviewed-on: http://git-master/r/748395
Tested-by: Winnie Hsu <whsu@nvidia.com>
drop support for USB_NET_RAW_IP as its unused
Bug 200092344
Change-Id: I085330c2ed8a83f83c027d91a03d13d1ce23e4f0
Reviewed-on: http://git-master/r/780277
dap2_sclk direction should be input to
take care of the bidirectional nature of the clk
for codec as master and interface as master
Bug 1643925
Change-Id: Iab4f1a30edd3542fbfc0e1f53dd6ea9f604ed42f
Reviewed-on: http://git-master/r/778298
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
enable shared memory config
Bug 1632724
Change-Id: I629eaa63ea54063dc713e21a848768378b3354a3
Reviewed-on: http://git-master/r/774295
There are places during the CPU resume path where we access this variable
with MMU off. In such scenarios we should use the physical address for this
variable.
This fixes the virtualisation team's issue, since they were the ones who
reported it in the first place. Fix a case where the code running from
iRAM was accessing the variable from DRAM instead of the one cached in
iRAM.
Bug 1411345
Change-Id: I9005c30329d38bae305a4a7b31ae7e2ca83e8a5d
Reviewed-on: http://git-master/r/412540
(cherry picked from commit a0553bb8f3fa7c76c2c0a6528d0c106ee22c7a59)
Reviewed-on: http://git-master/r/771679
Tested-by: Bibek Basu <bbasu@nvidia.com>
psci status node should also be checked along with
compatible node to enable secure fimrware
Bug 200124907
Change-Id: Ieb336bc7d1cc2c68d94157222770a6da6a8dcfd1
Reviewed-on: http://git-master/r/772755
Initialize uninitialized variables to get the
build through
Bug 1640594
Change-Id: Ia0788c5852bb8d68a79004e3f2fa1b3d2b9ca2fe
Reviewed-on: http://git-master/r/772239
CONFIG_UID_STAT is buggy and not needed
Bug 200115637
Change-Id: I105a46e91cba63508115be6fdd1c2e49962d25e8
Reviewed-on: http://git-master/r/764550
This reverts commit 28c9354b7cbade8813e0e5dbe9937300219fbeb9.
Change-Id: I4a809d75523513c939fa17a6dbeebee292aec77b
Reviewed-on: http://git-master/r/759472
Using Tegra WDT to trigger FIQ when system is in soft lockup.
Bug 1581432
Change-Id: I853a88a3f6e9402c978db18c5a63e903c582040a
Signed-off-by: Renn Wu <rewu@nvidia.com>
Reviewed-on: http://git-master/r/265871
(cherry picked from commit f115f435d471af22ddec5e9d969662f79193f846)
Reviewed-on: http://git-master/r/680353
if vpr memory is carved out, then only call dma_alloc
for secure memory.
Bug 200057068
Change-Id: I12557cfaa48f7db729ccab17d3151916d35ce0f1
Reviewed-on: http://git-master/r/746153
Added AR0261 sensor support
Bug 200089114
Signed-off-by: Tushar Khinvasara <tkhinvasara@nvidia.com>
Change-Id: I8f6d6c6ea4905d9087fd6281bc8b215ec0a73fdb
Reviewed-on: http://git-master/r/741716
Reviewed-by: Ming Wong <miwong@nvidia.com>
Enable CONFIG_DNOTIFY for L4T kernel config
Bug 1627091
Bug 200097847
Change-Id: I30d53089df825a776f03e1f0f08f1d6d8b1c9bb0
Reviewed-on: http://git-master/r/741517
This allows perform L1 cache clean alone.
Bug 200077334
Change-Id: I776de6e6726862e330b626fd19f8ae8f70055538
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/742254
Bug 200077334
Change-Id: I7a6106ed53755df33e09e3fa32a9e2524eb98649
Reviewed-on: http://git-master/r/742252
