arch/avr32/include/asm/Kbuild
arch/c6x/include/asm/Kbuild
arch/cris/include/asm/Kbuild
arch/ia64/include/asm/Kbuild
arch/mips/include/asm/Kbuild
arch/openrisc/include/asm/Kbuild
arch/powerpc/include/asm/Kbuild
arch/score/include/asm/Kbuild
Change-Id: I6800e3f03dbc40e94de1495459dec4b29df4474e
(cherry picked from commit e3fec2f74f7f90d2149a24243a4d040caabe6f30)
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
In order to prepare to per-arch implementations of preempt_count move
the required bits into an asm-generic header and use this for all
archs.
(cherry picked from commit a787870924dbd6f321661e06d4ec1c7a408c9ccf)
arch/h8300/include/asm/Kbuild
include/linux/preempt.h
Change-Id: I544914d3c23cc50da658296a34f9f2796854e259
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
user-triggered faults.
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: azurIt <azurit@pobox.sk>
(cherry picked from commit 407c454cb0ac6e68ca66974da787a71118cfef84)
arch/arc/mm/fault.c
arch/arm64/mm/fault.c
arch/metag/mm/fault.c
arch/parisc/mm/fault.c
Change-Id: Iee53942737627be8dd8e2e325b5ba87fe85d6814
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/266410
GVS: Gerrit_Virtual_Submit
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
The memcg code can trap tasks in the context of the failing allocation
until an OOM situation is resolved. They can hold all kinds of locks (fs,
mm) at this point, which makes it prone to deadlocking.
This series converts memcg OOM handling into a two step process that is
started in the charge context, but any waiting is done after the fault
stack is fully unwound.
Patches 1-4 prepare architecture handlers to support the new memcg
requirements, but in doing so they also remove old cruft and unify
out-of-memory behavior across architectures.
Patch 5 disables the memcg OOM handling for syscalls, readahead, kernel
faults, because they can gracefully unwind the stack with -ENOMEM. OOM
handling is restricted to user triggered faults that have no other option.
Patch 6 reworks memcg's hierarchical OOM locking to make it a little more
obvious wth is going on in there: reduce locked regions, rename locking
functions, reorder and document.
Patch 7 implements the two-part OOM handling such that tasks are never
trapped with the full charge stack in an OOM situation.
This patch:
Back before smart OOM killing, when faulting tasks were killed directly on
allocation failures, the arch-specific fault handlers needed special
protection for the init process.
Now that all fault handlers call into the generic OOM killer (609838c "mm:
invoke oom-killer from remaining unconverted page fault handlers"), which
already provides init protection, the arch-specific leftovers can be
removed.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
(cherry picked from commit c5659bca566f8b4798a34c0bf19b7afd0bfa706e)
arch/arc/mm/fault.c
Change-Id: I8807370a955f5a730832db8a86eb8dade81be251
Reviewed-on: http://git-master/r/266409
A few remaining architectures directly kill the page faulting task in an
out of memory situation. This is usually not a good idea since that
task might not even use a significant amount of memory and so may not be
the optimal victim to resolve the situation.
Since 2.6.29's 1c0fe6e ("mm: invoke oom-killer from page fault") there
is a hook that architecture page fault handlers are supposed to call to
invoke the OOM killer and let it pick the right task to kill. Convert
the remaining architectures over to this hook.
To have the previous behavior of simply taking out the faulting task the
vm.oom_kill_allocating_task sysctl can be set to 1.
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits]
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
(cherry picked from commit 609838cfed972d49a65aac7923a9ff5cbe482e30)
arch/arc/mm/fault.c
Change-Id: I3a9435be0bd4b8ea43cefd87ca8d408201ae3bf1
Reviewed-on: http://git-master/r/266408
kcore_vmalloc is in fs/proc/kcore.c and kcore_mem is unused across
the tree. Noticed while grepping the tree for some other kcore stuff.
(score looks pretty unmaintained to me.)
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
show_regs() is inherently arch-dependent but it does make sense to print
generic debug information and some archs already do albeit in slightly
different forms. This patch introduces a generic function to print debug
information from show_regs() so that different archs print out the same
information and it's much easier to modify what's printed.
show_regs_print_info() prints out the same debug info as dump_stack()
does plus task and thread_info pointers.
* Archs which didn't print debug info now do.
alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r,
metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc,
um, xtensa
* Already prints debug info. Replaced with show_regs_print_info().
The printed information is superset of what used to be there.
arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86
* s390 is special in that it used to print arch-specific information
along with generic debug info. Heiko and Martin think that the
arch-specific extra isn't worth keeping s390 specfic implementation.
Converted to use the generic version.
Note that now all archs print the debug info before actual register
dumps.
An example BUG() dump follows.
kernel BUG at /work/os/work/kernel/workqueue.c:4841!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7
Hardware name: empty empty/S3992, BIOS 080011 10/26/2007
task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000
RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6
RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246
RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001
RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a
RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0
Stack:
ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650
0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d
ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760
Call Trace:
[<ffffffff81000312>] do_one_initcall+0x122/0x170
[<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8
[<ffffffff81c47760>] ? rest_init+0x140/0x140
[<ffffffff81c4776e>] kernel_init+0xe/0xf0
[<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0
v2: Typo fix in x86-32.
v3: CPU number dropped from show_regs_print_info() as
dump_stack_print_info() has been updated to print it. s390
specific implementation dropped as requested by s390 maintainers.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Both dump_stack() and show_stack() are currently implemented by each
architecture. show_stack(NULL, NULL) dumps the backtrace for the
current task as does dump_stack(). On some archs, dump_stack() prints
extra information - pid, utsname and so on - in addition to the
backtrace while the two are identical on other archs.
The usages in arch-independent code of the two functions indicate
show_stack(NULL, NULL) should print out bare backtrace while
dump_stack() is used for debugging purposes when something went wrong,
so it does make sense to print additional information on the task which
triggered dump_stack().
There's no reason to require archs to implement two separate but mostly
identical functions. It leads to unnecessary subtle information.
This patch expands the dummy fallback dump_stack() implementation in
lib/dump_stack.c such that it prints out debug information (taken from
x86) and invokes show_stack(NULL, NULL) and drops arch-specific
dump_stack() implementations in all archs except blackfin. Blackfin's
dump_stack() does something wonky that I don't understand.
Debug information can be printed separately by calling
dump_stack_print_info() so that arch-specific dump_stack()
implementation can still emit the same debug information. This is used
in blackfin.
This patch brings the following behavior changes.
* On some archs, an extra level in backtrace for show_stack() could be
printed. This is because the top frame was determined in
dump_stack() on those archs while generic dump_stack() can't do that
reliably. It can be compensated by inlining dump_stack() but not
sure whether that'd be necessary.
* Most archs didn't use to print debug info on dump_stack(). They do
now.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a071>] init_workqueues+0x35/0x505
v2: CPU number added to the generic debug info as requested by s390
folks and dropped the s390 specific dump_stack(). This loses %ksp
from the debug message which the maintainers think isn't important
enough to keep the s390-specific dump_stack() implementation.
dump_stack_print_info() is moved to kernel/printk.c from
lib/dump_stack.c. Because linkage is per objecct file,
dump_stack_print_info() living in the same lib file as generic
dump_stack() means that archs which implement custom dump_stack()
- at this point, only blackfin - can't use dump_stack_print_info()
as that will bring in the generic version of dump_stack() too. v1
The v1 patch broke build on blackfin due to this issue. The build
breakage was reported by Fengguang Wu.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
Pull SMP/hotplug changes from Ingo Molnar:
"This is a pretty large, multi-arch series unifying and generalizing
the various disjunct pieces of idle routines that architectures have
historically copied from each other and have grown in random, wildly
inconsistent and sometimes buggy directions:
101 files changed, 455 insertions(+), 1328 deletions(-)
this went through a number of review and test iterations before it was
committed, it was tested on various architectures, was exposed to
linux-next for quite some time - nevertheless it might cause problems
on architectures that don't read the mailing lists and don't regularly
test linux-next.
This cat herding excercise was motivated by the -rt kernel, and was
brought to you by Thomas "the Whip" Gleixner."
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits)
idle: Remove GENERIC_IDLE_LOOP config switch
um: Use generic idle loop
ia64: Make sure interrupts enabled when we "safe_halt()"
sparc: Use generic idle loop
idle: Remove unused ARCH_HAS_DEFAULT_IDLE
bfin: Fix typo in arch_cpu_idle()
xtensa: Use generic idle loop
x86: Use generic idle loop
unicore: Use generic idle loop
tile: Use generic idle loop
tile: Enter idle with preemption disabled
sh: Use generic idle loop
score: Use generic idle loop
s390: Use generic idle loop
powerpc: Use generic idle loop
parisc: Use generic idle loop
openrisc: Use generic idle loop
mn10300: Use generic idle loop
mips: Use generic idle loop
microblaze: Use generic idle loop
Use common help functions to free reserved pages.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Split kcore bits from linux/procfs.h into linux/kcore.h.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
cc: linux-mips@linux-mips.org
cc: sparclinux@vger.kernel.org
cc: x86@kernel.org
cc: linux-mm@kvack.org
All archs are converted over. Remove the config switch and the
fallback code.
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Link: http://lkml.kernel.org/r/20130321215235.147909863@linutronix.de
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS")
I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where
needed. I am not sure what I was thinking. Instead, just directly
select VIRT_TO_BUS where it is needed.
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures
that already provide virt_to_bus().
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Cc: H Hartley Sweeten <hartleys@visionengravers.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: <linux-arch@vger.kernel.org>
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
__ARCH_WANT_SYS_RT_SIGACTION,
__ARCH_WANT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore
CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} -
can be assumed always set.
This fixes up all of the smaller arches that had __dev* markings for
their platform-specific drivers.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Bob Liu <lliubbo@gmail.com>
Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Cc: Myron Stowe <myron.stowe@redhat.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Yong Zhang <yong.zhang0@gmail.com>
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Cc: Jan Glauber <jang@linux.vnet.ibm.com>
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull signal handling cleanups from Al Viro:
"sigaltstack infrastructure + conversion for x86, alpha and um,
COMPAT_SYSCALL_DEFINE infrastructure.
Note that there are several conflicts between "unify
SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline;
resolution is trivial - just remove definitions of SS_ONSTACK and
SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and
include/uapi/linux/signal.h contains the unified variant."
Fixed up conflicts as per Al.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
alpha: switch to generic sigaltstack
new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those
generic compat_sys_sigaltstack()
introduce generic sys_sigaltstack(), switch x86 and um to it
new helper: compat_user_stack_pointer()
new helper: restore_altstack()
unify SS_ONSTACK/SS_DISABLE definitions
new helper: current_user_stack_pointer()
missing user_stack_pointer() instances
Bury the conditionals from kernel_thread/kernel_execve series
COMPAT_SYSCALL_DEFINE: infrastructure
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Acked-by: Lennox Wu <lennox.wu@gmail.com>
Acked-by: Liqin Chen <liqin299@gmail.com>
for the architectures that have usp in pt_regs and do not have
user_stack_pointer() already defined.
All architectures have
CONFIG_GENERIC_KERNEL_THREAD
CONFIG_GENERIC_KERNEL_EXECVE
__ARCH_WANT_SYS_EXECVE
None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers
of kernel_execve() (which is a trivial wrapper for do_execve() now) left.
Kill the conditionals and make both callers use do_execve().
Pull big execve/kernel_thread/fork unification series from Al Viro:
"All architectures are converted to new model. Quite a bit of that
stuff is actually shared with architecture trees; in such cases it's
literally shared branch pulled by both, not a cherry-pick.
A lot of ugliness and black magic is gone (-3KLoC total in this one):
- kernel_thread()/kernel_execve()/sys_execve() redesign.
We don't do syscalls from kernel anymore for either kernel_thread()
or kernel_execve():
kernel_thread() is essentially clone(2) with callback run before we
return to userland, the callbacks either never return or do
successful do_execve() before returning.
kernel_execve() is a wrapper for do_execve() - it doesn't need to
do transition to user mode anymore.
As a result kernel_thread() and kernel_execve() are
arch-independent now - they live in kernel/fork.c and fs/exec.c
resp. sys_execve() is also in fs/exec.c and it's completely
architecture-independent.
- daemonize() is gone, along with its parts in fs/*.c
- struct pt_regs * is no longer passed to do_fork/copy_process/
copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump.
- sys_fork()/sys_vfork()/sys_clone() unified; some architectures
still need wrappers (ones with callee-saved registers not saved in
pt_regs on syscall entry), but the main part of those suckers is in
kernel/fork.c now."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits)
do_coredump(): get rid of pt_regs argument
print_fatal_signal(): get rid of pt_regs argument
ptrace_signal(): get rid of unused arguments
get rid of ptrace_signal_deliver() arguments
new helper: signal_pt_regs()
unify default ptrace_signal_deliver
flagday: kill pt_regs argument of do_fork()
death to idle_regs()
don't pass regs to copy_process()
flagday: don't pass regs to copy_thread()
bfin: switch to generic vfork, get rid of pointless wrappers
xtensa: switch to generic clone()
openrisc: switch to use of generic fork and clone
unicore32: switch to generic clone(2)
score: switch to generic fork/vfork/clone
c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone()
take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h
mn10300: switch to generic fork/vfork/clone
h8300: switch to generic fork/vfork/clone
tile: switch to generic clone()
arch/microblaze/include/asm/Kbuild
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/core
Pull ftrace updates from Steve Rostedt.
'arch-h8300', 'arch-m32r', 'arch-mn10300', 'arch-score', 'arch-sh' and 'arch-powerpc' into for-next
In order to promote interoperability between userspace tracers and ftrace,
add a trace_clock that reports raw TSC values which will then be recorded
in the ring buffer. Userspace tracers that also record TSCs are then on
exactly the same time base as the kernel and events can be unambiguously
interlaced.
Tested: Enabled a tracepoint and the "tsc" trace_clock and saw very large
timestamp values.
v2:
Move arch-specific bits out of generic code.
v3:
Rename "x86-tsc", cleanups
v7:
Generic arch bits in Kbuild.
Google-Bug-Id: 6980623
Link: http://lkml.kernel.org/r/1352837903-32191-1-git-send-email-dhsharp@google.com
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
Signed-off-by: David Sharp <dhsharp@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module signing support from Rusty Russell:
"module signing is the highlight, but it's an all-over David Howells frenzy..."
Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG.
* 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits)
X.509: Fix indefinite length element skip error handling
X.509: Convert some printk calls to pr_devel
asymmetric keys: fix printk format warning
MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking
MODSIGN: Make mrproper should remove generated files.
MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs
MODSIGN: Use the same digest for the autogen key sig as for the module sig
MODSIGN: Sign modules during the build process
MODSIGN: Provide a script for generating a key ID from an X.509 cert
MODSIGN: Implement module signature checking
MODSIGN: Provide module signing public keys to the kernel
MODSIGN: Automatically generate module signing keys if missing
MODSIGN: Provide Kconfig options
MODSIGN: Provide gitignore and make clean rules for extra files
MODSIGN: Add FIPS policy
module: signature checking hook
X.509: Add a crypto key parser for binary (DER) X.509 certificates
MPILIB: Provide a function to read raw data into an MPI
X.509: Add an ASN.1 decoder
X.509: Add simple ASN.1 grammar compiler
getname() is intended to copy pathname strings from userspace into a
kernel buffer. The result is just a string in kernel space. It would
however be quite helpful to be able to attach some ancillary info to
the string.
For instance, we could attach some audit-related info to reduce the
amount of audit-related processing needed. When auditing is enabled,
we could also call getname() on the string more than once and not
need to recopy it from userspace.
This patchset converts the getname()/putname() interfaces to return
a struct instead of a string. For now, the struct just tracks the
string in kernel space and the original userland pointer for it.
Later, we'll add other information to the struct as it becomes
convenient.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Pull pile 2 of execve and kernel_thread unification work from Al Viro:
"Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for
several more architectures plus assorted signal fixes and cleanups.
There'll be more (in particular, real fixes for the alpha
do_notify_resume() irq mess)..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits)
alpha: don't open-code trace_report_syscall_{enter,exit}
Uninclude linux/freezer.h
m32r: trim masks
avr32: trim masks
tile: don't bother with SIGTRAP in setup_frame
microblaze: don't bother with SIGTRAP in setup_rt_frame()
mn10300: don't bother with SIGTRAP in setup_frame()
frv: no need to raise SIGTRAP in setup_frame()
x86: get rid of duplicate code in case of CONFIG_VM86
unicore32: remove pointless test
h8300: trim _TIF_WORK_MASK
parisc: decide whether to go to slow path (tracesys) based on thread flags
parisc: don't bother looping in do_signal()
parisc: fix double restarts
bury the rest of TIF_IRET
sanitize tsk_is_polling()
bury _TIF_RESTORE_SIGMASK
unicore32: unobfuscate _TIF_WORK_MASK
mips: NOTIFY_RESUME is not needed in TIF masks
mips: merge the identical "return from syscall" per-ABI code
arch/arm/include/asm/thread_info.h
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic updates from Arnd Bergmann:
"This has three changes for asm-generic that did not really fit into
any other branch as normal asm-generic changes do. One is a fix for a
build warning, the other two are more interesting:
* A patch from Mark Brown to allow using the common clock
infrastructure on all architectures, so we can use the clock API in
architecture independent device drivers.
* The UAPI split patches from David Howells for the asm-generic
files. There are other architecture specific series that are going
through the arch maintainer tree and that depend on this one.
There may be a few small merge conflicts between Mark's patch and the
following arch header file split patches. In each case the solution
will be to keep the new "generic-y += clkdev.h" line, even if it ends
up being the only line in the Kbuild file."
* tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
UAPI: (Scripted) Disintegrate include/asm-generic
asm-generic: Add default clkdev.h
asm-generic: xor: mark static functions as __maybe_unused
Pull UAPI disintegration fixes from David Howells:
"There are three main parts:
(1) I found I needed some more fixups in the wake of testing Arm64
(some asm/unistd.h files had weird guards that caused problems -
mostly in arches for which I don't have a compiler) and some
__KERNEL__ splitting needed to take place in Arm64.
(2) I found that c6x was missing some __KERNEL__ guards in its
asm/signal.h. Mark Salter pointed me at a tree with a patch to
remove that file entirely and use the asm-generic variant instead.
(3) Lastly, m68k turned out to have a header installation problem due
to it lacking a kvm_para.h file.
The conditional installation bits for linux/kvm_para.h, linux/kvm.h
and linux/a.out.h weren't very well specified - and didn't work if
an arch didn't have the asm/ version of that file, but there *was*
an asm-generic/ version.
It seems the "ifneq $((wildcard ...),)" for each of those three
headers in include/kernel/Kbuild is invoked twice during header
installation, and the second time it matches on the just installed
asm-generic/kvm_para.h file and thus incorrectly installs
linux/kvm_para.h as well.
Most arches actually have an asm/kvm_para.h, so this wasn't
detectable in those."
* 'uapi-prep' of git://git.infradead.org/users/dhowells/linux-headers:
UAPI: Fix conditional header installation handling (notably kvm_para.h on m68k)
c6x: remove c6x signal.h
UAPI: Split compound conditionals containing __KERNEL__ in Arm64
UAPI: Fix the guards on various asm/unistd.h files
c6x: make dsk6455 the default config
Historically, the top three bytes of personality have been used for
things such as ADDR_NO_RANDOMIZE, which made sense only for specific
architectures.
We now however have a flag there that is general no matter the
architecture (UNAME26); generally we have to be careful to preserve the
personality flags across exec().
This patch tries to fix all architectures that forcefully overwrite
personality flags during exec() (ppc32 and s390 have been fixed recently
by commits f9783ec862ea ("[S390] Do not clobber personality flags on
exec") and 59e4c3a2fe9c ("powerpc/32: Don't clobber personality flags on
exec") in a similar way already).
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Chris Zankel <chris@zankel.net>
It's required for the core fs/namespace.c and many other basic features.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
git://git.infradead.org/users/dhowells/linux-headers into asm-generic
Patches from David Howells <dhowells@redhat.com>:
This is to complete part of the UAPI disintegration for which the
preparatory patches were pulled recently.
Note that there are some fixup patches which are at the base of the
branch aimed at you, plus all arches get the asm-generic branch merged in too.
* 'disintegrate-asm-generic' of git://git.infradead.org/users/dhowells/linux-headers:
asm-generic/unistd.h and a number of asm/unistd.h files have been given
reinclusion guards that allow the guard to be overridden if __SYSCALL is
defined. Unfortunately, these files define __SYSCALL and don't undefine it
when they've finished with it, thus rendering the guard ineffective.
The reason for this override is to allow the file to be #included multiple
times with different settings on __SYSCALL for purposes like generating syscall
tables.
The following guards are problematic:
arch/arm64/include/asm/unistd.h:#if !defined(__ASM_UNISTD_H) || defined(__SYSCALL)
arch/arm64/include/asm/unistd32.h:#if !defined(__ASM_UNISTD32_H) || defined(__SYSCALL)
arch/c6x/include/asm/unistd.h:#if !defined(_ASM_C6X_UNISTD_H) || defined(__SYSCALL)
arch/hexagon/include/asm/unistd.h:#if !defined(_ASM_HEXAGON_UNISTD_H) || defined(__SYSCALL)
arch/openrisc/include/asm/unistd.h:#if !defined(__ASM_OPENRISC_UNISTD_H) || defined(__SYSCALL)
arch/score/include/asm/unistd.h:#if !defined(_ASM_SCORE_UNISTD_H) || defined(__SYSCALL)
arch/tile/include/asm/unistd.h:#if !defined(_ASM_TILE_UNISTD_H) || defined(__SYSCALL)
arch/unicore32/include/asm/unistd.h:#if !defined(__UNICORE_UNISTD_H__) || defined(__SYSCALL)
include/asm-generic/unistd.h:#if !defined(_ASM_GENERIC_UNISTD_H) || defined(__SYSCALL)
On the assumption that the guards' ineffectiveness has passed unnoticed, just
remove these guards entirely.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Ease the deployment of clkdev by providing a default asm/clkdev.h for
use if the arch does not have an include/asm/clkdev.h.
Due to limitations in Kbuild we manually add clkdev.h to all
architectures that don't have one rather than having the header appear
by default.
Reviewed-by: Stephen Rothwell <sfr@canb.auug.org.au>
Set up empty UAPI Kbuild files to be populated by the header splitter.
Make default just return 0. The current default (checking
TIF_POLLING_NRFLAG) is taken to architectures that need it;
ones that don't do polling in their idle threads don't need
to defined TIF_POLLING_NRFLAG at all.
ia64 defined both TS_POLLING (used by its tsk_is_polling())
and TIF_POLLING_NRFLAG (not used at all). Killed the latter...
never used...
we *really* don't want to have restart logics hit when we are returning from
sigreturn() - random replacement of %r4 with -4 just because a signal had
been noticed from timer interrupt that came when %r4 happened to contain
-514 is not nice at all.
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela,
ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version
into asm-generic/module.h for all arches bar MIPS.
Also, use the generic definition mod_arch_specific where possible.
To this end, I've defined three new config bools:
(*) HAVE_MOD_ARCH_SPECIFIC
Arches define this if they don't want to use the empty generic
mod_arch_specific struct.
(*) MODULES_USE_ELF_RELA
Arches define this if their modules can contain RELA records. This causes
the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be
defined by the arch rather than have the core emit an error message.
Arches define this if their modules can contain REL records. This causes
the Elf_Rel mapping to be emitted and allows apply_relocate() to be
Note that it is possible to allow both REL and RELA records: m68k and mips are
two arches that do this.
With this, some arch asm/module.h files can be deleted entirely and replaced
with a generic-y marker in the arch Kbuild file.
Additionally, I have removed the bits from m32r and score that handle the
unsupported type of relocation record as that's now handled centrally.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
