path: root/arch/frv
2014-04-30lib: Add missing arch generic-y entries for asm-generic/hash.hDavid S. Miller
Conflicts: arch/avr32/include/asm/Kbuild arch/c6x/include/asm/Kbuild arch/cris/include/asm/Kbuild arch/ia64/include/asm/Kbuild arch/mips/include/asm/Kbuild arch/openrisc/include/asm/Kbuild arch/powerpc/include/asm/Kbuild arch/score/include/asm/Kbuild Change-Id: I6800e3f03dbc40e94de1495459dec4b29df4474e Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> (cherry picked from commit e3fec2f74f7f90d2149a24243a4d040caabe6f30) Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-04-30sched, arch: Create asm/preempt.hPeter Zijlstra
In order to prepare to per-arch implementations of preempt_count move the required bits into an asm-generic header and use this for all archs. (cherry picked from commit a787870924dbd6f321661e06d4ec1c7a408c9ccf) Conflicts: arch/c6x/include/asm/Kbuild arch/cris/include/asm/Kbuild arch/h8300/include/asm/Kbuild arch/ia64/include/asm/Kbuild arch/mips/include/asm/Kbuild arch/openrisc/include/asm/Kbuild arch/powerpc/include/asm/Kbuild arch/score/include/asm/Kbuild include/linux/preempt.h Change-Id: I544914d3c23cc50da658296a34f9f2796854e259 Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2013-09-14UPSTREAM arch: mm: pass userspace fault flag to generic fault handlerPrashant Gaikwad
Unlike global OOM handling, memory cgroup code will invoke the OOM killer in any OOM situation because it has no way of telling faults occuring in kernel context - which could be handled more gracefully - from user-triggered faults. Pass a flag that identifies faults originating in user space from the architecture-specific fault handlers to generic code so that memcg OOM handling can be improved. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> (cherry picked from commit 407c454cb0ac6e68ca66974da787a71118cfef84) Conflicts: arch/arc/mm/fault.c arch/arm64/mm/fault.c arch/metag/mm/fault.c arch/parisc/mm/fault.c Change-Id: Iee53942737627be8dd8e2e325b5ba87fe85d6814 Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Reviewed-on: http://git-master/r/266410 GVS: Gerrit_Virtual_Submit Reviewed-by: Sachin Nikam <snikam@nvidia.com>
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-29mm/FRV: use free_highmem_page() to free highmem pages into buddy systemJiang Liu
Use helper function free_highmem_page() to free highmem pages into the buddy system. Also fix a bug that totalhigh_pages should be increased when freeing a highmem page into the buddy system. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm/FRV: use common help functions to free reserved pagesJiang Liu
Use common help functions to free reserved pages. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-17idle: Remove GENERIC_IDLE_LOOP config switchThomas Gleixner
All archs are converted over. Remove the config switch and the fallback code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-08frv: Use generic idle loopThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/20130321215234.217235264@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-03-31net: add option to enable error queue packets waking selectKeller, Jacob E
Currently, when a socket receives something on the error queue it only wakes up the socket on select if it is in the "read" list, that is the socket has something to read. It is useful also to wake the socket if it is in the error list, which would enable software to wait on error queue packets without waking up for regular data on the socket. The main use case is for receiving timestamped transmit packets which return the timestamp to the socket via the error queue. This enables an application to select on the socket for the error queue only instead of for the regular traffic. -v2- * Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file * Modified every socket poll function that checks error queue Signed-off-by: Jacob Keller <jacob.e.keller@intel.com> Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Matthew Vick <matthew.vick@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-12Select VIRT_TO_BUS directly where neededStephen Rothwell
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS") I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where needed. I am not sure what I was thinking. Instead, just directly select VIRT_TO_BUS where it is needed. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03consolidate cond_syscall and SYSCALL_ALIAS declarationsAl Viro
take them to asm/linkage.h, with default in linux/linkage.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-27arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUSStephen Rothwell
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures that already provide virt_to_bus(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: H Hartley Sweeten <hartleys@visionengravers.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27mm: use vm_unmapped_area() on frv architectureMichel Lespinasse
Update the frv arch_get_unmapped_area function to make use of vm_unmapped_area() instead of implementing a brute force search. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26default SET_PERSONALITY() in linux/elf.hAl Viro
2013-02-25Merge tag 'pci-v3.9-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug - Major overhaul of ACPI host bridge add/start (Rafael Wysocki, Yinghai Lu) - Major overhaul of PCI/ACPI binding (Rafael Wysocki, Yinghai Lu) - Split out ACPI host bridge and ACPI PCI device hotplug (Yinghai Lu) - Stop caching _PRT and make independent of bus numbers (Yinghai Lu) PCI device hotplug - Clean up cpqphp dead code (Sasha Levin) - Disable ARI unless device and upstream bridge support it (Yijing Wang) - Initialize all hot-added devices (not functions 0-7) (Yijing Wang) Power management - Don't touch ASPM if disabled (Joe Lawrence) - Fix ASPM link state management (Myron Stowe) Miscellaneous - Fix PCI_EXP_FLAGS accessor (Alex Williamson) - Disable Bus Master in pci_device_shutdown (Konstantin Khlebnikov) - Document hotplug resource and MPS parameters (Yijing Wang) - Add accessor for PCIe capabilities (Myron Stowe) - Drop pciehp suspend/resume messages (Paul Bolle) - Make pci_slot built-in only (not a module) (Jiang Liu) - Remove unused PCI/ACPI bind ops (Jiang Liu) - Removed used pci_root_bus (Bjorn Helgaas)" * tag 'pci-v3.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits) PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbers PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGS ACPI / PCI: Make pci_slot built-in only, not a module PCI/PM: Clear state_saved during suspend PCI: Use atomic_inc_return() rather than atomic_add_return() PCI: Catch attempts to disable already-disabled devices PCI: Disable Bus Master unconditionally in pci_device_shutdown() PCI: acpiphp: Remove dead code for PCI host bridge hotplug PCI: acpiphp: Create companion ACPI devices before creating PCI devices PCI: Remove unused "rc" in virtfn_add_bus() PCI: pciehp: Drop suspend/resume ENTRY messages PCI/ASPM: Don't touch ASPM if forcibly disabled PCI/ASPM: Deallocate upstream link state even if device is not PCIe PCI: Document MPS parameters pci=pcie_bus_safe, pci=pcie_bus_perf, etc PCI: Document hpiosize= and hpmemsize= resource reservation parameters PCI: Use PCI Express Capability accessor PCI: Introduce accessor to retrieve PCIe Capabilities Register PCI: Put pci_dev in device tree as early as possible PCI: Skip attaching driver in device_add() PCI: acpiphp: Keep driver loaded even if no slots found ...
2013-02-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "This is the first pile; another one will come a bit later and will contain SYSCALL_DEFINE-related patches. - a bunch of signal-related syscalls (both native and compat) unified. - a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE (fixing several potential problems with missing argument validation, while we are at it) - a lot of now-pointless wrappers killed - a couple of architectures (cris and hexagon) forgot to save altstack settings into sigframe, even though they used the (uninitialized) values in sigreturn; fixed. - microblaze fixes for delivery of multiple signals arriving at once - saner set of helpers for signal delivery introduced, several architectures switched to using those." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits) x86: convert to ksignal sparc: convert to ksignal arm: switch to struct ksignal * passing alpha: pass k_sigaction and siginfo_t using ksignal pointer burying unused conditionals make do_sigaltstack() static arm64: switch to generic old sigaction() (compat-only) arm64: switch to generic compat rt_sigaction() arm64: switch compat to generic old sigsuspend arm64: switch to generic compat rt_sigqueueinfo() arm64: switch to generic compat rt_sigpending() arm64: switch to generic compat rt_sigprocmask() arm64: switch to generic sigaltstack sparc: switch to generic old sigsuspend sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE sparc: kill sign-extending wrappers for native syscalls kill sparc32_open() sparc: switch to use of generic old sigaction sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE mips: switch to generic sys_fork() and sys_clone() ...
2013-02-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking update from David Miller: 1) Checkpoint/restarted TCP sockets now can properly propagate the TCP timestamp offset. From Andrey Vagin. 2) VMWARE VM VSOCK layer, from Andy King. 3) Much improved support for virtual functions and SR-IOV in bnx2x, from Ariel ELior. 4) All protocols on ipv4 and ipv6 are now network namespace aware, and all the compatability checks for initial-namespace-only protocols is removed. Thanks to Tom Parkin for helping deal with the last major holdout, L2TP. 5) IPV6 support in netpoll and network namespace support in pktgen, from Cong Wang. 6) Multiple Registration Protocol (MRP) and Multiple VLAN Registration Protocol (MVRP) support, from David Ward. 7) Compute packet lengths more accurately in the packet scheduler, from Eric Dumazet. 8) Use per-task page fragment allocator in skb_append_datato_frags(), also from Eric Dumazet. 9) Add support for connection tracking labels in netfilter, from Florian Westphal. 10) Fix default multicast group joining on ipv6, and add anti-spoofing checks to 6to4 and 6rd. From Hannes Frederic Sowa. 11) Make ipv4/ipv6 fragmentation memory limits more reasonable in modern times, rearrange inet frag datastructures for better cacheline locality, and move more operations outside of locking. From Jesper Dangaard Brouer. 12) Instead of strict master <--> slave relationships, allow arbitrary scenerios with "upper device lists". From Jiri Pirko. 13) Improve rate limiting accuracy in TBF and act_police, also from Jiri Pirko. 14) Add a BPF filter netfilter match target, from Willem de Bruijn. 15) Orphan and delete a bunch of pre-historic networking drivers from Paul Gortmaker. 16) Add TSO support for GRE tunnels, from Pravin B SHelar. Although this still needs some minor bug fixing before it's %100 correct in all cases. 17) Handle unresolved IPSEC states like ARP, with a resolution packet queue. From Steffen Klassert. 18) Remove TCP Appropriate Byte Count support (ABC), from Stephen Hemminger. This was long overdue. 19) Support SO_REUSEPORT, from Tom Herbert. 20) Allow locking a socket BPF filter, so that it cannot change after a process drops capabilities. 21) Add VLAN filtering to bridge, from Vlad Yasevich. 22) Bring ipv6 on-par with ipv4 and do not cache neighbour entries in the ipv6 routes, from YOSHIFUJI Hideaki. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1538 commits) ipv6: fix race condition regarding dst->expires and dst->from. net: fix a wrong assignment in skb_split() ip_gre: remove an extra dst_release() ppp: set qdisc_tx_busylock to avoid LOCKDEP splat atl1c: restore buffer state net: fix a build failure when !CONFIG_PROC_FS net: ipv4: fix waring -Wunused-variable net: proc: fix build failed when procfs is not configured Revert "xen: netback: remove redundant xenvif_put" net: move procfs code to net/core/net-procfs.c qmi_wwan, cdc-ether: add ADU960S bonding: set sysfs device_type to 'bond' bonding: fix bond_release_all inconsistencies b44: use netdev_alloc_skb_ip_align() xen: netback: remove redundant xenvif_put net: fec: Do a sanity check on the gpio number ip_gre: propogate target device GSO capability to the tunnel device ip_gre: allow CSUM capable devices to handle packets bonding: Fix initialize after use for 3ad machine state spinlock bonding: Fix race condition between bond_enslave() and bond_3ad_update_lacp_rate() ...
2013-02-19Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq core changes from Ingo Molnar: "The biggest changes are the IRQ-work and printk changes from Frederic Weisbecker, which prepare the code for 'full dynticks' (the ability to stop or slow down the periodic tick arbitrarily, not just in idle time as today): - Don't stop tick with irq works pending. This fix is generally useful and concerns archs that can't raise self IPIs. - Flush irq works before CPU offlining. - Introduce "lazy" irq works that can wait for the next tick to be executed, unless it's stopped. - Implement klogd wake up using irq work. This removes the ad-hoc printk_tick()/printk_needs_cpu() hooks and make it working even in dynticks mode. - Cleanups and fixes." * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Export enable/disable_percpu_irq() arch Kconfig: Remove references to IRQ_PER_CPU irq_work: Remove return value from the irq_work_queue() function genirq: Avoid deadlock in spurious handling printk: Wake up klogd using irq_work irq_work: Make self-IPIs optable irq_work: Warn if there's still work on cpu_down irq_work: Flush work on CPU_DYING irq_work: Don't stop the tick with pending works nohz: Add API to check tick state irq_work: Remove CONFIG_HAVE_IRQ_WORK irq_work: Fix racy check on work pending flag irq_work: Fix racy IRQ_WORK_BUSY flag setting
2013-02-14burying unused conditionalsAl Viro
__ARCH_WANT_SYS_RT_SIGACTION, __ARCH_WANT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} - can be assumed always set.
2013-02-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Synchronize with 'net' in order to sort out some l2tp, wireless, and ipv6 GRE fixes that will be built on top of in 'net-next'. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-03frv: switch to generic old sigaction()Al Viro
2013-02-03frv: switch to generic old sigsuspendAl Viro
2013-02-03frv: switch to generic sigaltstackAl Viro
2013-01-29frv: Provide dummy dma_mmap_coherent() and dma_get_sgtable()Geert Uytterhoeven
frv/allmodconfig: drivers/media/v4l2-core/videobuf2-dma-contig.c: In function ‘vb2_dc_mmap’: drivers/media/v4l2-core/videobuf2-dma-contig.c:204: error: implicit declaration of function ‘dma_mmap_coherent’ drivers/media/v4l2-core/videobuf2-dma-contig.c: In function ‘vb2_dc_get_base_sgt’: drivers/media/v4l2-core/videobuf2-dma-contig.c:387: error: implicit declaration of function ‘dma_get_sgtable’ For architectures using dma_map_ops, dma_mmap_coherent() and dma_get_sgtable() are provided in <asm-generic/dma-mapping-common.h>. Frv does not use dma_map_ops, hence it should implement them itself. For now, use dummy implementations that just return -EINVAL, until the API has been finalized. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2013-01-24Merge branch 'core/irq_work' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into irq/core irq_work fixes and cleanups, in preparation for full dyntics support. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-23soreuseport: infrastructureTom Herbert
Definitions and macros for implementing soreusport. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-17sk-filter: Add ability to lock a socket filter programVincent Bernat
While a privileged program can open a raw socket, attach some restrictive filter and drop its privileges (or send the socket to an unprivileged program through some Unix socket), the filter can still be removed or modified by the unprivileged program. This commit adds a socket option to lock the filter (SO_LOCK_FILTER) preventing any modification of a socket filter program. This is similar to OpenBSD BIOCLOCK ioctl on bpf sockets, except even root is not allowed change/drop the filter. The state of the lock can be read with getsockopt(). No error is triggered if the state is not changed. -EPERM is returned when a user tries to remove the lock or to change/remove the filter while the lock is active. The check is done directly in sk_attach_filter() and sk_detach_filter() and does not affect only setsockopt() syscall. Signed-off-by: Vincent Bernat <bernat@luffy.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-04frv/PCI: Remove unused pci_root_busBjorn Helgaas
pci_root_bus is unused, so remove all references to it. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-01-03ARCH: drivers remove __dev* attributes.Greg Kroah-Hartman
This fixes up all of the smaller arches that had __dev* markings for their platform-specific drivers. CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Bob Liu <lliubbo@gmail.com> Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Myron Stowe <myron.stowe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Cc: Mark Salter <msalter@redhat.com> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Jan Glauber <jang@linux.vnet.ibm.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-19Bury the conditionals from kernel_thread/kernel_execve seriesAl Viro
All architectures have CONFIG_GENERIC_KERNEL_THREAD CONFIG_GENERIC_KERNEL_EXECVE __ARCH_WANT_SYS_EXECVE None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers of kernel_execve() (which is a trivial wrapper for do_execve() now) left. Kill the conditionals and make both callers use do_execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-17frv: properly use the declarations provided by <asm/sections.h>Geert Uytterhoeven
- Remove the superfluous address-of ('&') operators, - Remove the unneeded casts, use %p to format pointers instead. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17frv: fix use of extinct _sbss and _ebss in debug codeGeert Uytterhoeven
Nowadays it should probably use __bss_start and __bss_stop Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull big execve/kernel_thread/fork unification series from Al Viro: "All architectures are converted to new model. Quite a bit of that stuff is actually shared with architecture trees; in such cases it's literally shared branch pulled by both, not a cherry-pick. A lot of ugliness and black magic is gone (-3KLoC total in this one): - kernel_thread()/kernel_execve()/sys_execve() redesign. We don't do syscalls from kernel anymore for either kernel_thread() or kernel_execve(): kernel_thread() is essentially clone(2) with callback run before we return to userland, the callbacks either never return or do successful do_execve() before returning. kernel_execve() is a wrapper for do_execve() - it doesn't need to do transition to user mode anymore. As a result kernel_thread() and kernel_execve() are arch-independent now - they live in kernel/fork.c and fs/exec.c resp. sys_execve() is also in fs/exec.c and it's completely architecture-independent. - daemonize() is gone, along with its parts in fs/*.c - struct pt_regs * is no longer passed to do_fork/copy_process/ copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump. - sys_fork()/sys_vfork()/sys_clone() unified; some architectures still need wrappers (ones with callee-saved registers not saved in pt_regs on syscall entry), but the main part of those suckers is in kernel/fork.c now." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits) do_coredump(): get rid of pt_regs argument print_fatal_signal(): get rid of pt_regs argument ptrace_signal(): get rid of unused arguments get rid of ptrace_signal_deliver() arguments new helper: signal_pt_regs() unify default ptrace_signal_deliver flagday: kill pt_regs argument of do_fork() death to idle_regs() don't pass regs to copy_process() flagday: don't pass regs to copy_thread() bfin: switch to generic vfork, get rid of pointless wrappers xtensa: switch to generic clone() openrisc: switch to use of generic fork and clone unicore32: switch to generic clone(2) score: switch to generic fork/vfork/clone c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone() take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h mn10300: switch to generic fork/vfork/clone h8300: switch to generic fork/vfork/clone tile: switch to generic clone() ... Conflicts: arch/microblaze/include/asm/Kbuild
2012-12-08Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/core Pull ftrace updates from Steve Rostedt. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-06propagate name change to comments in kernel sourceNadia Yvette Chambers
I've legally changed my name with New York State, the US Social Security Administration, et al. This patch propagates the name change and change in initials and login to comments in the kernel source as well. Signed-off-by: Nadia Yvette Chambers <nyc@holomorphy.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-28flagday: don't pass regs to copy_thread()Al Viro
2012-11-28frv: switch to generic fork/vfork/cloneAl Viro
2012-11-17irq_work: Remove CONFIG_HAVE_IRQ_WORKFrederic Weisbecker
irq work can run on any arch even without IPI support because of the hook on update_process_times(). So lets remove HAVE_IRQ_WORK because it doesn't reflect any backend requirement. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-11-13tracing,x86: Add a TSC trace_clockDavid Sharp
In order to promote interoperability between userspace tracers and ftrace, add a trace_clock that reports raw TSC values which will then be recorded in the ring buffer. Userspace tracers that also record TSCs are then on exactly the same time base as the kernel and events can be unambiguously interlaced. Tested: Enabled a tracepoint and the "tsc" trace_clock and saw very large timestamp values. v2: Move arch-specific bits out of generic code. v3: Rename "x86-tsc", cleanups v7: Generic arch bits in Kbuild. Google-Bug-Id: 6980623 Link: http://lkml.kernel.org/r/1352837903-32191-1-git-send-email-dhsharp@google.com Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Signed-off-by: David Sharp <dhsharp@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-11-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c Minor conflict between the BCM_CNIC define removal in net-next and a bug fix added to net. Based upon a conflict resolution patch posted by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-02frv: fix the broken preemptAl Viro
Just get %icc2 into the state we would have after local_irq_disable() and physical IRQ having happened since then. Then we can simply use preempt_schedule_irq() and be done with the whole mess. Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-02frv: switch to saner kernel_execve() semanticsAl Viro
