Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Related to: #40373
Set vddio_sdmmc, vqmmc, vmmc regulators for eMMC.
Related to: #40373
If the OTG port is configured for USB 3.0 operation
using usb_port_owner_info kernel cmd line argument
operate in host mode only.
Causes build failures with gcc 8.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Previously, lvds-drive-strength was located in a wrong node and
there was no control of the 5th lane.
Align with mainline Atmel MXT driver.
Building kernels before linux-4.7 with gcc-8 results in many build failures
when gcc triggers a check that was meant to catch broken compilers:
/tmp/ccCGMQmS.s:648: Error: .err encountered
According to the discussion in the gcc bugzilla, a local "register
asm()" variable is still supposed to be the correct way to force an
inline assembly to use a particular register, but marking it 'const'
lets the compiler do optimizations that break that, i.e the compiler is
free to treat the variable as either 'const' or 'register' in that case.
Upstream commit 9f73bd8bb445 ("ARM: uaccess: remove put_user() code
duplication") fixed this problem in linux-4.8 as part of a larger change,
but seems a little too big to be backported to 4.4.
Let's take the simplest fix and change only the one broken line in the
same way as newer kernels.
Suggested-by: Bernd Edlinger <bernd.edlinger@hotmail.de>
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=85745
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=86673
(cherry picked from commit 0ca85fc310e8c24cba10ed241a0188795e177683)
/tmp/ccmcXtfu.s: Assembler messages:
/tmp/ccmcXtfu.s:1441: Error: .err encountered
arch/arm/include/asm/uaccess.h
Hardcoded value was used before. This allows setting
drive strength values in the devicetree.
Build SELinux support in kernel, but keep it disabled.
This commit adds support for the 2nd CSI Camera Module 5MP OV5640 with
SCCB_ID of 0x3d connected to Apalis TK1 Mezzanine V2.0A on X7 aka
CSI_3_CSI-2/4x.
Port retains dual function capability.
Peripheral mode supports only USB 2.0.
Now device trees for revision <1.2 and 1.2 use the same rcv-sel
on i2c3 (in NVIDIA's documentation known as i2c4).
Disable Tegra SE crypto dev as done in NVIDIA L4T R21.7.
Similar to commit a7e55a39cdd1 ("CRYPTO: disable crypto dev fot t124").
Currently building fails as follows due to an erroneous + sign in front
of an #endif in arch/arm/mm/fsr-3level.c:
In file included from /home/user/linux-3.10/arch/arm/mm/fault.c:554:0:
/home/user/linux-3.10/arch/arm/mm/fsr-3level.c:68:0:
error: unterminated #else
make[2]: *** [/home/user/linux-3.10/scripts/Makefile.build:308:
arch/arm/mm/fault.o] Error 1
This fixes commit de3110548b04 ("arm: Invalidate BTB on prefetch abort
outside of user mapping on Cortex A8, A9, A12 and A17").
Merge NVIDIA's latest Linux for Tegra aka L4T R21.7 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
e78bb38b883c42edf81766a1d557aed74458e08f
Conflicts involved missing 24-bit LVDS support and a single whitespace
aka tab difference in drivers/video/tegra/dc/sor.c.
** Not yet queued for inclusion in mainline **
In order to avoid aliasing attacks against the branch predictor,
some implementations require to invalidate the BTB when switching
from one user context to another.
For this, we reuse the existing implementation for Cortex-A8, and
apply it to A9, A12 and A17.
Change-Id: Ibbd99465a5dcf5eda6a29dd23a55f9b21b280e65
Reviewed-on: https://git-master.nvidia.com/r/1704129
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Bibek Basu <bbasu@nvidia.com>
In order to prevent aliasing attacks on the branch predictor,
invalidate the icache on Cortex-A15, which has the side effect
of invalidating the BTB. This requires ACTLR[0] to be set to 1
(secure operation).
Change-Id: I4bb8e3ec05853d739bebd8fb3c61657e252808c0
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1698400
A9, A12 and A17
invalidate the BTB on CPUs that are known to be affected when taking
a prefetch abort on a address that is outside of a user task limit.
__ACCESS_CP15 and __ACCESS_CP15_64 added from below link:
https://patchwork.kernel.org/patch/9234399/
Change-Id: Ib8c9807f5e787437e66b83ea0305d75cce4bbbdf
Reviewed-on: https://git-master.nvidia.com/r/1698399
Cortex-A15 require to invalidate the BTB when switching
from one user context to another. The only way to do so on this
CPU is to perform an ICIALLU, having set ACTLR[0] to 1 from secure
mode.
Change-Id: Ib0083803d75a4399b8225193349a4b490d1776a1
Reviewed-on: https://git-master.nvidia.com/r/1698398
The instruction sequency "dsb sy" followed by "isb" functions as
a speculation barrier, which prevents the instructions after that
from being speculatively executed.
bug 2039126
Change-Id: I898aab771ff82b26b08214a06814d2e6e78969a7
Signed-off-by: Bo Yan <byan@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1618222
Signed-off-by: James Huang <jamehuang@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1650093
(cherry picked from commit f125c60045878513902cac4a084fde9a516eb3e2)
Reviewed-on: https://git-master.nvidia.com/r/1660771
This reverts commit 95730406a0e3bbd7f862718782924a3c367845a1.
DC initialization now relays only on device-tree entry.
Add ability to switch between 24.1 and 24.0 lvds modes.
Mode description can be found in "Using 24-bpp LVDS Panels with
Intel® Mobile Chipsets for Embedded Applications".
This change also modifies SPI clock for ezPort mode.
Increased SPI speed for transfers and peripheral speed.
Switch to cleaning IRQ flags on read, instead of separate write.
Switched to zero-copy on SPI reads.
disabling tegra SE crypto dev for
t124 platform.
Bug 1927682
Change-Id: I16a24009e8f528df4be40ec65aa621b4ac779e41
Signed-off-by: Konduri Praveen <kondurip@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1582395
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Bug 1946430
Change-Id: I9a66aabc34b687996fb971e01bb0ef30a3d4de7d
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
[wt: backport to 4.4: adjust context ; drop ppc hugetlb_radix changes]
Signed-off-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1509390
Let the kernel print some debug messages when a user program
crashes due to an exception.
Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes
b271e8fa67a6d9c4600274a25636cfe00fdd1b68
DDC/EDID detection was failing on Apalis TK1 V1.2A on Ixora.
We moved HDMI DDC configuration to the device-tree.
If DDC config is missing from the device-tree
we default to v1.2 config.
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Update model and compatibility nodes to be more in-line with mainline.
This automatically selects options for zone DMA and 64 bit DMA addresses
when LPAE is enabled on ARM Tegra platforms. These options are required
for proper operation with LPAE enabled.
The ZONE_DMA option is required to ensure that drivers that allocate DMA
memory get buffers from the first 4 GiB. This is necessary because a lot
of the controllers only support addressing 32 bits.
As for ARCH_DMA_ADDR_T_64BIT, there are situations where devices that do
support addresses of more than 32 bits (such as the display controller
or the GPU) can run without translating addresses through an IOMMU on a
device with more than 4 GiB of system memory.
Note that both of these options are stop-gap solutions required only
until the IOMMU can be properly integrated with the DMA mapping API and
drivers use that properly and consistently.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
[treding@nvidia.com: specify rationale for options]
Signed-off-by: Thierry Reding <treding@nvidia.com>
(backported from commit 6aa26c5d66595494e810c791602d87a572c78808)
With gcc 7 the following compile time error occurs:
| arch/arm/mach-tegra/tegra11_soctherm.c:2978:40: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses]
| s->sensor_enable = s->sensor_enable ?: therm->zone_enable;
| arch/arm/mach-tegra/powergate-t12x.c:814:10: error: statement will never be executed [-Werror=switch-unreachable]
| return true;
Activate PWM pin muxing for Apalis PWM3. Note that the same PWM3 is
already active on pu6 being Apalis BKL1_PWM as well. Therefore exporting
that one for raw sysfs access will fail and one has to revert to using
the pwm backlight.
Enable support for the Large Physical Address Extension aka LPAE.
It turns out that the current PCIe reset implementation is not quite
working reliably due to some Intel i210 errata. Fix this by making sure
the i210's +V3.3_ETH rail is properly disabled during its reset
sequence.
Also further improve on the bringing up the PCIe switch as found on the
Apalis Evaluation board.
