path: root/arch/arm/mach-orion5x
2013-05-13ARM: Orion: Remove redundant init_dma_coherent_pool_size()Andrew Lunn
The patch: 387870f mm: dmapool: use provided gfp flags for all dma_alloc_coherent() calls makes these calls on Kirkwood and Orion5x redundant. The drivers are not making atomic requests for coherent memory and hence the default pool size is now sufficient. Jason Cooper added mach-mvebu/ hunk, and corrected minor typos in commit message. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-07Merge tag 'soc-for-linus-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates (part 3) from Arnd Bergmann: "This is the third and smallest of the SoC specific updates. Changes include: - SMP support for the Xilinx zynq platform - Smaller imx changes - LPAE support for mvebu - Moving the orion5x, kirkwood, dove and mvebu platforms to a common "mbus" driver for their internal devices. It would be good to get feedback on the location of the "mbus" driver. Since this is used on multiple platforms may potentially get shared with other architectures (powerpc and arm64), it was moved to drivers/bus/. We expect other similar drivers to get moved to the same place in order to avoid creating more top-level directories under drivers/ or cluttering up the messy drivers/misc/ even more." * tag 'soc-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits) ARM: imx: reset_controller may be disabled ARM: mvebu: Align the internal registers virtual base to support LPAE ARM: mvebu: Limit the DMA zone when LPAE is selected arm: plat-orion: remove addr-map code arm: mach-mv78xx0: convert to use the mvebu-mbus driver arm: mach-orion5x: convert to use mvebu-mbus driver arm: mach-dove: convert to use mvebu-mbus driver arm: mach-kirkwood: convert to use mvebu-mbus driver arm: mach-mvebu: convert to use mvebu-mbus driver ARM i.MX53: set CLK_SET_RATE_PARENT flag on the tve_ext_sel clock ARM i.MX53: tve_di clock is not part of the CCM, but of TVE ARM i.MX53: make tve_ext_sel propagate rate change to PLL ARM i.MX53: Remove unused tve_gate clkdev entry ARM i.MX5: Remove tve_sel clock from i.MX53 clock tree ARM: i.MX5: Add PATA and SRTC clocks ARM: imx: do not bring up unavailable cores ARM: imx: add initial imx6dl support ARM: imx1: mm: add call to mxc_device_init ARM: imx_v4_v5_defconfig: Add CONFIG_GPIO_SYSFS ARM: imx_v6_v7_defconfig: Select CONFIG_PERF_EVENTS ...
2013-05-02Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanup from Olof Johansson: "Here is a collection of cleanup patches. Among the pieces that stand out are: - The deletion of h720x platforms - Split of at91 non-dt platforms to their own Kconfig file to keep them separate - General cleanups and refactoring of i.MX and MXS platforms - Some restructuring of clock tables for OMAP - Convertion of PMC driver for Tegra to dt-only - Some renames of sunxi -> sun4i (Allwinner A10) - ... plus a bunch of other stuff that I haven't mentioned" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: i.MX: remove unused ARCH_* configs ARM i.MX53: remove platform ahci support ARM: sunxi: Rework the restart code irqchip: sunxi: Rename sunxi to sun4i irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro clocksource: sunxi: Rename sunxi to sun4i clocksource: sunxi: make use of CLKSRC_OF clocksource: sunxi: Cleanup the timer code ARM: at91: remove trailing semicolon from macros ARM: at91/setup: fix trivial typos ARM: EXYNOS: remove "config EXYNOS_DEV_DRM" ARM: EXYNOS: change the name of USB ohci header ARM: SAMSUNG: Remove unnecessary code for dma ARM: S3C24XX: Remove unused GPIO drive strength register definitions ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412 ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410 ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC" ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI" ...
2013-05-02Merge tag 'fixes-nc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC non-critical fixes from Olof Johansson: "Here is a collection of fixes (and some intermixed cleanups) that were considered less important and thus not included in the later parts of the 3.9-rc cycle. It's a bit all over the map, contents wise. A series of ux500 fixes and cleanups, a bunch of various fixes for OMAP and tegra, and some for Freescale i.MX and even Qualcomm MSM. Note that there's also a patch on this branch to globally turn off -Wmaybe-uninitialized when building with -Os. It's been posted several times by Arnd and no dissent was raised, but nobody seemed interested to pick it up. So here it is, as the topmost patch." * tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits) Turn off -Wmaybe-uninitialized when building with -Os ARM: orion5x: include linux/cpu.h ARM: tegra: call cpu_do_idle from C code ARM: u300: fix ages old copy/paste bug ARM: OMAP2+: add dependencies on ARCH_MULTI_V6/V7 ARM: tegra: solve adr range issue with THUMB2_KERNEL enabled ARM: tegra: fix relocation truncated error when THUMB2_KERNEL enabled ARM: tegra: fix build error when THUMB2_KERNEL enabled ARM: msm: Fix uncompess.h tx underrun check ARM: vexpress: Remove A9 PMU compatible values for non-A9 platforms ARM: cpuimx27 and mbimx27: prepend CONFIG_ to Kconfig macro ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS" ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD" ARM: mach-imx: mach-imx6q: Fix sparse warnings ARM: mach-imx: src: Include "common.h ARM: mach-imx: gpc: Include "common.h" ARM: mach-imx: avic: Staticize *avic_base ARM: mach-imx: tzic: Staticize *tzic_base ARM: mach-imx: clk: Include "clk.h" ARM: mach-imx: clk-busy: Staticize clk_busy_mux_ops ...
2013-04-29ARM: orion5x: include linux/cpu.hArnd Bergmann
The linux/cpu.h header is no longer implictly included in this file, so we need to an #include statement to avoid this build warning: arch/arm/mach-orion5x/common.c:339:3: error: implicit declaration of function 'cpu_idle_poll_ctrl' [-Werror=implicit-function-declaration] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch>
2013-04-15arm: mach-orion5x: convert to use mvebu-mbus driverThomas Petazzoni
This commit migrates the mach-orion5x platforms to use the mvebu-mbus driver and therefore removes the Orion5x-specific addr-map code. The dove_init_early() function now initializes the mvebu-mbus driver by calling mvebu_mbus_init(). We also convert a number of orion5x_setup_xyz_win() calls to the appropriate mvebu_mbus_add_window() calls, as each board was doing its own setup for the NOR window or other devices. Ultimately, those devices will be probed from the DT. The common address decoding windows are now registered in the orion5x_setup_wins() function. It is worth noting that the four PCIe address decoding windows will ultimately no longer have to be registered here: it will be done automatically by the PCIe driver once Dove has been migrated to use the upcoming mvebu PCIe driver. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-08arm: Use generic idle loopThomas Gleixner
Use the generic idle loop and replace enable/disable_hlt with the respective core functions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Tested-by: Kevin Hilman <khilman@linaro.org> # OMAP Link: http://lkml.kernel.org/r/20130321215233.826238797@linutronix.de
2013-03-17arm: mach-orion5x: use mv_mbus_dram_info() in PCI codeThomas Petazzoni
The PCI code was directly accessing the orion_mbus_dram_info structure to get access to a description of the SDRAM chip selects in order to configure the PCIe -> SDRAM address decoding windows. However, with the introduction of the mvebu-mbus driver, we are going to remove this global structure and instead leave only the exported mv_mbus_dram_info() function to access this description of the SDRAM chip selects. Therefore, we simply switch to using this API. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-14Merge branch 'clocksource/cleanup' into next/cleanupOlof Johansson
Clockevent cleanup series from Shawn Guo. Resolved move/change conflict in mach-pxa/time.c due to the sys_timer cleanup. * clocksource/cleanup: clocksource: use clockevents_config_and_register() where possible ARM: use clockevents_config_and_register() where possible clockevents: export clockevents_config_and_register for module use + sync to Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-pxa/time.c
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2013-01-03ARM: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-21arm: orion5x: convert 'LaCie Ethernet Disk mini v2' to Device TreeThomas Petazzoni
This commit converts the 'LaCie Ethernet Disk mini v2' board to the Device Tree. All devices that have existing Device Tree bindings are converted over to the Device Tree, the other devices remain instantiated in the old way, until the respective drivers get the needed Device Tree bindings. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested by: Maxime Hadjinlian <mhadjinlian@lacie.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21arm: orion5x: basic Device Tree supportThomas Petazzoni
This commit adds basic DT support for the Orion5x SoC family. It adds an orion5x.dtsi description of the Orion5x SoC as well as the needed DT_MACHINE structure to support boards converted to DT in the future. So far, the Device Tree contains the interrupt controller, the GPIO bank, the UART controllers, the SPI controller, the watchdog, the SATA controller, the I2C controller and the cryptographic engine. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested by: Maxime Hadjinlian <mhadjinlian@lacie.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-10-07Merge tag 'soc-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull late ARM soc platform updates from Olof Johansson: "This branch contains updates to OMAP and Marvell platforms (kirkwood, dove, mvebu) that came in after we had done the big multiplatform merges, so they were kept separate from the rest, and not separated into the traditional topics of cleanup/driver/platform features. For OMAP, the updates are: - Runtime PM conversions for the GPMC and RNG IP blocks - Preparation patches for the OMAP common clock framework conversion - clkdev alias additions required by other drivers - Performance Monitoring Unit (PMU) support for OMAP2, 3, and non-4430 OMAP4 - OMAP hwmod code and data improvements - Preparation patches for the IOMMU runtime PM conversion - Preparation patches for OMAP4 full-chip retention support For Kirkwood/Dove/mvebu: - New driver for "address decoder controller" for mvebu, which is a piece of hardware that configures addressable devices and peripherals. First user is the boot rom aperture on armada XP since it is needed for SMP support. - New device tree bindings for peripherals such as gpio-fan, iconnect nand, mv_cesa and the above address decoder controller. - Some defconfig updates, mostly to enable new DT boards and a few drivers. - New drivers using the pincontrol subsystem for dove, kirkwood and mvebu - New clean gpio driver for mvebu" * tag 'soc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (98 commits) ARM: mvebu: fix build breaks from multi-platform conversion ARM: OMAP4460/4470: PMU: Enable PMU for OMAP4460/70 ARM: OMAP2+: PMU: Add runtime PM support ARM: OMAP4430: PMU: prepare to create PMU device via HWMOD ARM: OMAP2+: PMU: Convert OMAP2/3 devices to use HWMOD ARM: OMAP3: hwmod data: Add debugss HWMOD data ARM: OMAP2+: clockdomain/hwmod: add workaround for EMU clockdomain idle problems ARM: OMAP: Add a timer attribute for timers that can interrupt the DSP hwrng: OMAP: remove SoC restrictions from driver registration ARM: OMAP: split OMAP1, OMAP2+ RNG device registration hwrng: OMAP: convert to use runtime PM hwrng: OMAP: store per-device data in per-device variables, not file statics ARM: OMAP2xxx: hwmod/CM: add RNG integration data ARM: OMAP2+: gpmc: minimal driver support ARM: OMAP2+: gpmc: Adapt to HWMOD ARM: OMAP2/3: hwmod data: add gpmc ARM: OMAP4: hwmod data: add mmu hwmod for ipu and dsp ARM: OMAP3: hwmod data: add mmu data for iva and isp ARM: OMAP: iommu: fix including iommu.h without IOMMU_API selected ARM: OMAP4: hwmod data: add missing HWMOD_NO_IDLEST flags to some PRCM IP blocks ...
2012-10-01Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM soc multiplatform enablement from Olof Johansson: "This is a pretty significant branch. It's the introduction of the first multiplatform support on ARM, and with this (and the later branch) merged, it is now possible to build one kernel that contains support for highbank, vexpress, mvebu, socfpga, and picoxcell. More platforms will be convered over in the next few releases. Two critical last things had to be done for this to be practical and possible: * Today each platform has its own include directory under mach-<mach>/include/mach/*, and traditionally that is where a lot of driver/platform shared definitions have gone, such as platform data structures. They now need to move out to a common location instead, and this branch moves a large number of those out to include/linux/platform_data. * Each platform used to list the device trees to compile for its boards in mach-<mach>/Makefile.boot. Both of the above changes will mean that there are some merge conflicts to come (and some to resolve here). It's a one-time move and once it settles in, we should be good for quite a while. Sorry for the overhead." Fix conflicts as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits) ARM: add v7 multi-platform defconfig ARM: msm: Move core.h contents into common.h ARM: highbank: call highbank_pm_init from .init_machine ARM: dtb: move all dtb targets to common Makefile ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ...
2012-10-01Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc driver specific changes from Olof Johansson: - A long-coming conversion of various platforms to a common LED infrastructure - AT91 is moved over to use the newer MCI driver for MMC - Pincontrol conversions for samsung platforms - DT bindings for gscaler on samsung - i2c driver fixes for tegra, acked by i2c maintainer Fix up conflicts as per Olof. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) drivers: bus: omap_l3: use resources instead of hardcoded irqs pinctrl: exynos: Fix wakeup IRQ domain registration check pinctrl: samsung: Uninline samsung_pinctrl_get_soc_data pinctrl: exynos: Correct the detection of wakeup-eint node pinctrl: exynos: Mark exynos_irq_demux_eint as inline pinctrl: exynos: Handle only unmasked wakeup interrupts pinctrl: exynos: Fix typos in gpio/wkup _irq_mask pinctrl: exynos: Set pin function to EINT in irq_set_type of GPIO EINTa drivers: bus: Move the OMAP interconnect driver to drivers/bus/ i2c: tegra: dynamically control fast clk i2c: tegra: I2_M_NOSTART functionality not supported in Tegra20 ARM: tegra: clock: remove unused clock entry for i2c ARM: tegra: clock: add connection name in i2c clock entry i2c: tegra: pass proper name for getting clock ARM: tegra: clock: add i2c fast clock entry in clock table ARM: EXYNOS: Adds G-Scaler device from Device Tree ARM: EXYNOS: Add clock support for G-Scaler ARM: EXYNOS: Enable pinctrl driver support for EXYNOS4 device tree enabled platform ARM: dts: Add pinctrl node entries for SAMSUNG EXYNOS4210 SoC ARM: EXYNOS: skip wakeup interrupt setup if pinctrl driver is used ...
2012-10-01Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM soc cleanups, part 2 from Olof Johansson: "A shorter cleanup branch submitted separately due to dependencies with some of the previous topics. Major thing here is that the Broadcom bcmring platform is removed. It's an SoC that's used on some stationary VoIP platforms, and is in desperate need of some cleanup. Broadcom came back and suggested that we just deprecate the platform for now, since they aren't going to spend the resources needed on cleaning it up, and there are no users of the platform directly from mainline." Fix some conflicts due to BCM2835 getting added next to the removed BCMRING, and removal of tegra files that had been converted to devicetree. * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: Orion5x: ts78xx: Add IOMEM for virtual addresses. ARM: ux500: use __iomem pointers for MMIO ARM: Remove mach-bcmring ARM: clps711x: Remove board support for CEIVA ARM: clps711x: Fix register definitions ARM: clps711x: Fix lowlevel debug-macro ARM: clps711x: Added simple clock framework pinctrl: tegra: move pinconf-tegra.h content into drivers/pinctrl ARM: tegra: delete unused headers ARM: tegra: remove useless includes of <mach/*.h> ARM: tegra: remove dead code
2012-10-01Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc general cleanups from Olof Johansson: "This is a large branch that contains a handful of different cleanups: - Fixing up the I/O space remapping on PCI on ARM. This is a series from Rob Herring that restructures how all pci devices allocate I/O space, and it's part of the work to allow multiplatform kernels. - A number of cleanup series for OMAP, moving and removing some headers, sparse irq rework and in general preparation for multiplatform. - Final removal of all non-DT boards for Tegra, it is now device-tree-only! - Removal of a stale platform, nxp4008. It's an old mobile chipset that is no longer in use, and was very likely never really used with a mainline kernel. We have not been able to find anyone interested in keeping it around in the kernel. - Removal of the legacy dmaengine driver on tegra + A handful of other things that I haven't described above." Fix up some conflicts with the staging tree (and because nxp4008 was removed) * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (184 commits) ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6 ARM: OMAP4: twl-common: Support for additional devices on i2c1 bus ARM: mmp: using for_each_set_bit to simplify the code ARM: tegra: harmony: fix ldo7 regulator-name ARM: OMAP2+: Make omap4-keypad.h local ARM: OMAP2+: Make l4_3xxx.h local ARM: OMAP2+: Make l4_2xxx.h local ARM: OMAP2+: Make l3_3xxx.h local ARM: OMAP2+: Make l3_2xxx.h local ARM: OMAP1: Move irda.h from plat to mach ARM: OMAP2+: Make hdq1w.h local ARM: OMAP2+: Make gpmc-smsc911x.h local ARM: OMAP2+: Make gpmc-smc91x.h local ARM: OMAP1: Move flash.h from plat to mach ARM: OMAP2+: Make debug-devices.h local ARM: OMAP1: Move board-voiceblue.h from plat to mach ARM: OMAP1: Move board-sx1.h from plat to mach ARM: OMAP2+: Make omap-wakeupgen.h local ARM: OMAP2+: Make omap-secure.h local ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local ...
2012-09-28ARM: Orion5x: ts78xx: Add IOMEM for virtual addresses.Andrew Lunn
Also convert logical or to + for register offsets from base addresses. This fixes a number of warnings currently seen in linux-next: warning: passing argument 2 of '__raw_writeb' makes pointer from interger without cast. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-09-26ARM: Orion5x: Fix too small coherent pool.Andrew Lunn
Some Orion5x devices allocate their coherent buffers from atomic context. Increase size of atomic coherent pool to make sure such the allocations won't fail during boot. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-22Merge branch 'kirkwood/addr_decode' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into late/kirkwood * 'kirkwood/addr_decode' of git://git.infradead.org/users/jcooper/linux: arm: mvebu: add address decoding controller to the DT arm: mvebu: add basic address decoding support to Armada 370/XP arm: plat-orion: make bridge_virt_base non-const to support DT use case arm: plat-orion: introduce PLAT_ORION_LEGACY hidden config option arm: plat-orion: use void __iomem pointers for addr-map functions arm: plat-orion: use void __iomem pointers for time functions arm: plat-orion: use void __iomem pointers for MPP functions arm: plat-orion: use void __iomem pointers for UART registration functions arm: mach-mvebu: use IOMEM() for base address definitions arm: mach-orion5x: use IOMEM() for base address definitions arm: mach-mv78xx0: use IOMEM() for base address definitions arm: mach-kirkwood: use IOMEM() for base address definitions arm: mach-dove: use IOMEM() for base address definitions arm: mach-orion5x: use plus instead of or for address definitions arm: mach-mv78xx0: use plus instead of or for address definitions arm: mach-kirkwood: use plus instead of or for address definitions arm: mach-dove: use plus instead of or for address definitions This branch had quite a few conflicts, in particular with the PCI static map rework from Rob Herring, and a few other context conflicts due to changes in Kconfig, etc. I fixed up conflicts in: arch/arm/Kconfig arch/arm/mach-dove/common.c arch/arm/mach-dove/include/mach/dove.h arch/arm/mach-kirkwood/common.c arch/arm/mach-kirkwood/include/mach/kirkwood.h arch/arm/mach-mv78xx0/common.c arch/arm/mach-mv78xx0/include/mach/mv78xx0.h arch/arm/mach-orion5x/common.c arch/arm/mach-orion5x/include/mach/orion5x.h Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-22Merge branch 'multiplatform/platform-data' into next/multiplatformOlof Johansson
* multiplatform/platform-data: ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: nomadik: move platform_data definitions ARM: w90x900: move platform_data definitions ARM: vt8500: move platform_data definitions ARM: tegra: move sdhci platform_data definition ARM: sa1100: move platform_data definitions ARM: pxa: move platform_data definitions ARM: netx: move platform_data definitions ARM: msm: move platform_data definitions ARM: imx: move platform_data definitions ARM: ep93xx: move platform_data definitions ARM: davinci: move platform_data definitions ARM: at91: move platform_data definitions Conflicts due to removed files: arch/arm/mach-tegra/board-harmony.c arch/arm/mach-tegra/board-trimslice.c Conflicts due to code removal: arch/arm/mach-tegra/board-paz00.c Context conflicts in: drivers/mmc/host/sdhci-tegra.c drivers/net/irda/pxaficp_ir.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-21arm: plat-orion: use void __iomem pointers for addr-map functionsThomas Petazzoni
The functions for address mapping management now take void __iomem pointers, so we remove the temporary "unsigned long" casts from the mach-*/common.c files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: plat-orion: use void __iomem pointers for time functionsThomas Petazzoni
The functions for time management now take void __iomem pointers, so we remove the temporary "unsigned long" casts from the mach-*/common.c files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: plat-orion: use void __iomem pointers for MPP functionsThomas Petazzoni
The registration function for MPP now takes void __iomem pointers, so we remove the temporary "unsigned long" casts from the mach-*/mpp.c files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: plat-orion: use void __iomem pointers for UART registration functionsThomas Petazzoni
The registration functions for UARTs now take void __iomem pointers, so we remove the temporary "unsigned long" casts from the mach-*/common.c files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: mach-orion5x: use IOMEM() for base address definitionsThomas Petazzoni
We now define all virtual base address constants using IOMEM() so that those are naturally typed as void __iomem pointers, and we do the necessary adjustements in the mach-orion5x code. Note that we introduce a few temporary additional "unsigned long" casts when calling into plat-orion functions. Those are removed by followup patches converting plat-orion functions to void __iomem pointers as well. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: mach-orion5x: use plus instead of or for address definitionsThomas Petazzoni
Since we are going to use IOMEM() to define many base virtual addresses, we can no longer use binary or to define the individual register addresses ("binary or" arithmetic on pointers is not allowed). Instead, use the more conventional plus operator to do so. The binary or operators were actually not useful because the low-order bits of the base address were always zero, so the usage of the binary or operators was effectively identical to a plus operator. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-20Merge tag 'multi-platform-for-3.7' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/multiplatform Enable initial ARM multi-platform support for highbank, mvebu, socfpga, picoxcell, and vexpress. Multi-platform support is dependent on mach/gpio.h removal and restructuring of DEBUG_LL and dtb build rules included in this branch. This has been built for all defconfigs, and booted on highbank with all 5 platforms enabled. By Rob Herring (18) and Arnd Bergmann (1) via Rob Herring * tag 'multi-platform-for-3.7' of git://sources.calxeda.com/kernel/linux: ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ARM: orion: move custom gpio functions to orion-gpio.h ARM: shmobile: move custom gpio functions to sh-gpio.h ARM: pxa: use gpio_to_irq for sharppm_sl net: pxaficp_ir: add irq resources usb: pxa27x_udc: remove IRQ_USB define staging: ste_rmi4: remove gpio.h include Conflicts due to addition of bcm2835 and removal of pnx4008 in: arch/arm/Kconfig arch/arm/Makefile Conflicts due to new dtb targets, moved to arch/arm/boot/dts/Makefile in: arch/arm/mach-imx/Makefile.boot arch/arm/mach-mxs/Makefile.boot arch/arm/mach-tegra/Makefile.boot Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-19ARM: orion: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the orion include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <djbw@fb.com> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Liam Girdwood <lrg@ti.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de>
2012-09-16Merge tag 'tegra-for-3.7-drivers-i2c' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into next/drivers From Stephen Warren: ARM: tegra: i2c driver enhancements mostly related to clocking This branch contains a number of fixes and cleanups to the Tegra I2C driver related to clocks. These are based on the common clock conversion in order to avoid duplicating the clock driver changes before and after the conversion. Finally, a bug-fix related to I2C_M_NOSTART is included. This branch is based on previous pull request tegra-for-3.7-common-clk. * tag 'tegra-for-3.7-drivers-i2c' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra: i2c: tegra: dynamically control fast clk i2c: tegra: I2_M_NOSTART functionality not supported in Tegra20 ARM: tegra: clock: remove unused clock entry for i2c ARM: tegra: clock: add connection name in i2c clock entry i2c: tegra: pass proper name for getting clock ARM: tegra: clock: add i2c fast clock entry in clock table ARM: Tegra: Add smp_twd clock for Tegra20 ARM: tegra: cpu-tegra: explicitly manage re-parenting ARM: tegra: fix overflow in tegra20_pll_clk_round_rate() ARM: tegra: Fix data type for io address ARM: tegra: remove tegra_timer from tegra_list_clks ARM: tegra30: clocks: fix the wrong tegra_audio_sync_clk_ops name ARM: tegra: clocks: separate tegra_clk_32k_ops from Tegra20 and Tegra30 ARM: tegra: Remove duplicate code ARM: tegra: Port tegra to generic clock framework ARM: tegra: Add clk_tegra structure and helper functions ARM: tegra: Rename tegra20 clock file ARM: tegra20: Separate out clk ops and clk data ARM: tegra30: Separate out clk ops and clk data ARM: tegra: fix U16 divider range check ... + sync to v3.6-rc4 Resolved remove/modify conflict in arch/arm/mach-sa1100/leds-hackkit.c caused by the sync with v3.6-rc4. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-14ARM: make mach/gpio.h headers optionalRob Herring
Most platforms don't need mach/gpio.h and it prevents multi-platform kernel images. Add CONFIG_NEED_MACH_GPIO_H and make platforns select it if they need gpio.h. This is platforms that define __GPIOLIB_COMPLEX or have lots of implicit includes pulled in by mach/gpio.h. at91 and omap have gpio clean-up pending and can drop CONFIG_NEED_MACH_GPIO_H once that is in. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-14ARM: orion: move custom gpio functions to orion-gpio.hRob Herring
Move custom orion platforms gpio code to orion-gpio to remove the dependency on mach/gpio.h. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch>
2012-09-12Merge branch 'clk' of git://github.com/hzhuang1/linux into next/cleanupOlof Johansson
* 'clk' of git://github.com/hzhuang1/linux: ARM: mmp: remove unused definition in APBC and APMU ARM: mmp: move mmp2 clock definition to separated file arm: mmp: move pxa910 clock definition to separated file arm: mmp: move pxa168 clock definition to separated file arm: mmp: make private clock definition exclude from common clock + Linux 3.6-rc4
2012-08-15ARM: Orion: Set eth packet size csum offload limitArnaud Patard (Rtp)
The mv643xx ethernet controller limits the packet size for the TX checksum offloading. This patch sets this limits for Kirkwood and Dove which have smaller limits that the default. As a side note, this patch is an updated version of a patch sent some years ago: http://lists.infradead.org/pipermail/linux-arm-kernel/2010-June/017320.html which seems to have been lost. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Cc: <stable@vger.kernel.org>
2012-08-13Merge branch 'cleanup/io-pci' into next/cleanupsArnd Bergmann
From Rob Herring <robherring2@gmail.com>: This is the 2nd part of mach/io.h removals. This series removes io.h on platforms with PCI by creating a fixed virtual I/O mapping and a common __io() macro. This version has changed a bit to accommodate Tegra converting its PCIe host to a platform driver. Now the virtual space is only reserved during early boot before .map_io() is called. The mapping is not created until calling pci_ioremap_io which can be done at any point after vmalloc is initialized. I've gone back to fixed 64K windows for each PCI bus. This allows removing all the i/o resource setup from the individually platforms and placing it within the common ARM PCI code. I've only tested versatilepb under qemu (with the model hacked up to actually enable i/o space), so any testing is appreciated. iop3xx and mv78xx0 have some risk of breaking as the PCI bus addresses are moved to 0 from matching the cpu host bus addesss. * cleanup/io-pci: ARM: iop3xx: use fixed PCI i/o mapping ARM: mv78xx0: use fixed pci i/o mapping ARM: iop13xx: use fixed PCI i/o mapping iop13xx: use more regular PCI I/O space handling ARM: orion5x: use fixed PCI i/o mapping ARM: kirkwood: use fixed PCI i/o mapping ARM: dove: use fixed PCI i/o mapping ARM: footbridge: use fixed PCI i/o mapping ARM: shark: use fixed PCI i/o mapping ARM: integrator: remove trailing whitespace on pci_v3.c ARM: integrator: use fixed PCI i/o mapping ARM: tegra: use fixed PCI i/o mapping ARM: versatile: use fixed PCI i/o mapping ARM: move PCI i/o resource setup into common code ARM: Add fixed PCI i/o mapping i2c: iop3xx: use standard gpiolib functions i2c: iop3xx: clean-up trailing whitespace Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-13Merge branch 'for-arm-soc' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds into next/drivers From Bryan Wu <bryan.wu@canonical.com>: Based on Linus Walleij's ARM LED consolidation work, this patchset introduce a new generic led trigger for CPU not only for ARM but also for others. For enabling CPU idle event, CPU arch code should call ledtrig_cpu() stub to trigger idle start or idle end event. These patches convert old style LED driver in arch/arm to gpio_led or new led driver interface. Against 3.5 release and build successfully for all the machines. Test ledtrig-cpu driver on OMAP4 Panda board. v9 --> v10 * fix compiling issue on versatile_defconfig reported by Russell King * rebase to 3.5 kernel and move patches to new git tree v8 --> v9: * use mutex to replace rw_sema pointed out by Tim Gardner * add a new struct led_trigger_cpu * add lock_is_inited to record mutex lock initialization v6 --> v7: * add a patch to unify the led-trigger name * fix some typo pointed * use BUG_ON to detect CPU numbers during building stage v5 --> v6: * replace __get_cpu_var() to per_cpu() * remove smp_processor_id() which is wrong with for_each_possible_cpu() * test on real OMAP4 Panda board * add comments about CPU hotplug in the CPU LED trigger driver v4 --> v5: * rebase all the patches on top of latest linux-next * replace on_each_cpu() with for_each_possible_cpu() * add some description of ledtrig_cpu() API * remove old leds code from driver nwflash.c, which should use a new led trigger then * this trigger driver can be built as module now v3 --> v4: * fix a typo pointed by Jochen Friedrich * fix some building errors * add Reviewed-by and Tested-by into patch log v2 --> v3: * almost rewrote the whole ledtrig-cpu driver, which is more simple * every CPU will have a per-CPU trigger * cpu trigger can be assigned to any leds * fix a lockdep issue in led-trigger common code * other fix according to review v1 --> v2: * remove select operations in Kconfig of every machines * add back supporting of led in core module of mach-integrator * solidate name scheme in ledtrig-cpu.c * add comments of CPU_LED_* cpu led events * fold patches of RealView and Versatile together * add machine_is_ check during assabet led driver init * add some Acked-by in patch logs * remove code for simpad machine in machine-sa11000, since Jochen Friedrich introduced gpiolib and gpio-led driver for simpad * on Assabet and Netwinder machine, LED operations is reversed like: setting bit means turn off leds clearing bit means turn on leds * add a new function to read CM_CTRL register for led driver * 'for-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: ARM: use new LEDS CPU trigger stub to replace old one ARM: mach-sa1100: retire custom LED code ARM: mach-omap1: retire custom LED code ARM: mach-pnx4008: remove including old leds event API header file ARM: plat-samsung: remove including old leds event API header file ARM: mach-pxa: retire custom LED code char: nwflash: remove old led event code ARM: mach-footbridge: retire custom LED code ARM: mach-ebsa110: retire custom LED code ARM: mach-clps711x: retire custom LED code of P720T machine ARM: mach-integrator: retire custom LED code ARM: mach-integrator: move CM_CTRL to header file for accessing by other functions ARM: mach-orion5x: convert custom LED code to gpio_led and LED CPU trigger ARM: mach-shark: retire custom LED code ARM: mach-ks8695: remove leds driver, since nobody use it ARM: mach-realview and mach-versatile: retire custom LED code ARM: at91: convert old leds drivers to gpio_led and led_trigger drivers led-triggers: create a trigger for CPU activity Conflicts: arch/arm/mach-clps711x/p720t.c arch/arm/mach-sa1100/leds-cerf.c arch/arm/mach-sa1100/leds-lart.c Let's hope this is the last time we pull this and it doesn't cause more trouble. I have verified that version 10 causes no build warnings or errors any more, and the patches still look good. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-01ARM: mach-orion5x: convert custom LED code to gpio_led and LED CPU triggerBryan Wu
Signed-off-by: Bryan Wu <bryan.wu@canonical.com> Acked-by: Nicolas Pitre <nico@fluxnic.net>
2012-07-27ARM: Orion: DT support for IRQ and GPIO ControllersAndrew Lunn
Both IRQ and GPIO controllers can now be represented in DT. The IRQ controllers are setup first, and then the GPIO controllers. Interrupts for GPIO lines are placed directly after the main interrupts in the interrupt space. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@googlemail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Josh Coombs <josh.coombs@gmail.com> Tested-by: Simon Baatz <gmbnomis@gmail.com>
2012-07-26ARM: orion5x: use fixed PCI i/o mappingRob Herring
Move orion5x PCI to fixed i/o mapping and remove io.h. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Acked-by: Nicolas Pitre <nico@linaro.org> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2012-06-23ARM: Orion: Fix Virtual/Physical mixup with watchdogAndrew Lunn
The orion watchdog is expecting to be passed the physcial address of the hardware, and will ioremap() it to give a virtual address it will use as the base address for the hardware. However, when creating the platform resource record, a virtual address was being used. Add the necassary #define's so we can pass the physical address as expected. Tested on Kirkwood and Orion5x. Cc: stable <stable@vger.kernel.org> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-06-23ARM: Orion5x - Restore parts of io.h, with reworkAndrew Lunn
Commit 4d5fc58dbe34b78157c05b319669bb3e064ba8bd (ARM: remove bunch of now unused mach/io.h files) removed the orion5x io.h. Unfortunately, this is still needed for the definition of IO_SPACE_LIMIT which overrides the default 64K. All Orion based systems have 1Mbyte of IO space per PCI[e] bus, and try to request_resource() this size. Orion5x has two such PCI buses. It is likely that the original, removed version, was broken. This version might be less broken. However, it has not been tested on hardware with a PCI card, let alone hardware with a PCI card with IO capabilities. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-06-01Merge tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull mtd update from David Woodhouse: - More robust parsing especially of xattr data in JFFS2 - Updates to mxc_nand and gpmi drivers to support new boards and device tree - Improve consistency of information about ECC strength in NAND devices - Clean up partition handling of plat_nand - Support NAND drivers without dedicated access to OOB area - BCH hardware ECC support for OMAP - Other fixes and cleanups, and a few new device IDs Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to added include files next to each other. * tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits) mtd: mxc_nand: move ecc strengh setup before nand_scan_tail mtd: block2mtd: fix recursive call of mtd_writev mtd: gpmi-nand: define ecc.strength mtd: of_parts: fix breakage in Kconfig mtd: nand: fix scan_read_raw_oob mtd: docg3 fix in-middle of blocks reads mtd: cfi_cmdset_0002: Slight cleanup of fixup messages mtd: add fixup for S29NS512P NOR flash. jffs2: allow to complete xattr integrity check on first GC scan jffs2: allow to discriminate between recoverable and non-recoverable errors mtd: nand: omap: add support for hardware BCH ecc ARM: OMAP3: gpmc: add BCH ecc api and modes mtd: nand: check the return code of 'read_oob/read_oob_raw' mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw' mtd: m25p80: Add support for Winbond W25Q80BW jffs2: get rid of jffs2_sync_super jffs2: remove unnecessary GC pass on sync jffs2: remove unnecessary GC pass on umount jffs2: remove lock_super mtd: gpmi: add gpmi support for mx6q ...
2012-05-26Merge tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc clock driver changes from Olof Johansson: "The new clock subsystem was merged in linux-3.4 without any users, this now moves the first three platforms over to it: imx, mxs and spear. The series also contains the changes for the clock subsystem itself, since Mike preferred to have it together with the platforms that require these changes, in order to avoid interdependencies and conflicts." Fix up trivial conflicts in arch/arm/mach-kirkwood/common.c (code removed in one branch, added OF support in another) and drivers/dma/imx-sdma.c (independent changes next to each other). * tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits) clk: Fix CLK_SET_RATE_GATE flag validation in clk_set_rate(). clk: Provide dummy clk_unregister() SPEAr: Update defconfigs SPEAr: Add SMI NOR partition info in dts files SPEAr: Switch to common clock framework SPEAr: Call clk_prepare() before calling clk_enable SPEAr: clk: Add General Purpose Timer Synthesizer clock SPEAr: clk: Add Fractional Synthesizer clock SPEAr: clk: Add Auxiliary Synthesizer clock SPEAr: clk: Add VCO-PLL Synthesizer clock SPEAr: Add DT bindings for SPEAr's timer ARM i.MX: remove now unused clock files ARM: i.MX6: implement clocks using common clock framework ARM i.MX35: implement clocks using common clock framework ARM i.MX5: implement clocks using common clock framework ARM: Kirkwood: Replace clock gating ARM: Orion: Audio: Add clk/clkdev support ARM: Orion: PCIE: Add support for clk ARM: Orion: XOR: Add support for clk ARM: Orion: CESA: Add support for clk ...
2012-05-22Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc board specific changes from Olof Johansson: "While we generally attempt to get rid of board specific files and replace them with device tree based descriptions, a lot of platforms have not come that far: In shmobile, we add two new board files because their recently started effort to add DT support has not proceeded enough to use it for all of the important hardware. In Kirkwood, we are adding support for new boards with a combination of DT and board file contents in multiple cases. pxa/mmp and imx are extending support for existing board files but not adding new ones." Fix up trivial conflicts in arch/arm/mach-{mmp/ttc_dkb.c,shmobile/{Kconfig,Makefile}} * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: shmobile: fix smp build ARM: kirkwood: Add support for RaidSonic IB-NAS6210/6220 using devicetree kirkwood: Add iconnect support orion/kirkwood: create a generic function for gpio led blinking kirkwood/orion: fix orion_gpio_set_blink ARM: kirkwood: Define DNS-320/DNS-325 NAND in fdt kirkwood: Allow nand to be configured via. devicetree mtd: Add orion_nand devicetree bindings ARM: kirkwood: Basic support for DNS-320 and DNS-325 ARM: mach-shmobile: Use DT_MACHINE for armadillo 800 eva ARM: mach-shmobile: Use DT_MACHINE for KZM9G ARM: pxa: hx4700: Add Synaptics NavPoint touchpad ARM: pxa: Use REGULATOR_SUPPLY macro ARM: mach-shmobile: kzm9g: enable SMP boot ARM: mach-shmobile: kzm9g: defconfig update ARM: mach-shmobile: kzm9g: add PCF8757 gpio-key ARM: mach-shmobile: kzm9g: add SDHI support ARM: mach-shmobile: kzm9g: add MMCIF support ARM: mach-shmobile: kzm9g: correct screen direction ARM: mach-shmobile: sh73a0.h: add GPIO_NR ...
2012-05-22Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull first batch of arm-soc cleanups from Olof Johansson: "These cleanups are basically all over the place. The idea is to collect changes with minimal impact but large number of changes so we can avoid them from distracting in the diffstat in the other series. A significant number of lines get removed here, in particular because the ixp2000 and ixp23xx platforms get removed. These have never been extremely popular and have fallen into disuse over time with no active maintainer taking care of them. The u5500 soc never made it into a product, so we are removing it from the ux500 platform. Many good cleanups also went into the at91 and omap platforms, as has been the case for a number of releases." Trivial modify-delete conflicts in arch/arm/mach-{ixp2000,ixp23xx} * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (152 commits) ARM: clps711x: Cleanup IRQ handling ARM clps711x: Removed unused header mach/time.h ARM: clps711x: Added note about support EP731x CPU to Kconfig ARM: clps711x: Added missing register definitions ARM: clps711x: Used own subarch directory for store header file Dove: Fix Section mismatch warnings ARM: orion5x: ts78xx debugging changes ARM: orion5x: remove PM dependency from ts78xx ARM: orion5x: ts78xx fix NAND resource off by one ARM: orion5x: ts78xx whitespace cleanups Orion5x: Fix Section mismatch warnings Orion5x: Fix warning: struct pci_dev declared inside paramter list ARM: clps711x: Combine header files into one for clps711x-targets ARM: S3C24XX: Use common macro to define resources on mach-qt2410.c ARM: S3C24XX: Use common macro to define resources on mach-osiris.c ARM: EXYNOS: Adapt to cpuidle core time keeping and irq enable ARM: S5PV210: Use common macro to define resources on mach-smdkv210.c ARM: S5PV210: Use common macro to define resources on dev-audio.c ARM: S5PC100: Use common macro to define resources on dev-audio.c ARM: S5P64X0: Use common macro to define resources on dev-audio.c ...
2012-05-21Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull core ARM updates from Russell King: "This is the bulk of the core ARM updates for this merge window. Included in here is a different way to handle the VIVT cache flushing on context switch, which should allow scheduler folk to remove a special case in their core code. We have architectured timer support here, which is a set of timers specified by the ARM architecture for future SoCs. So we should see less variability in timer design going forward. The last big thing here is my cleanup to the way we handle PCI across ARM, fixing some oddities in some platforms which hadn't realised there was a way to deal with their private data already built in to our PCI backend. I've also removed support for the ARMv3 architecture; it hasn't worked properly for years so it seems pointless to keep it around." * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (47 commits) ARM: PCI: remove per-pci_hw list of buses ARM: PCI: dove/kirkwood/mv78xx0: use sys->private_data ARM: PCI: provide a default bus scan implementation ARM: PCI: get rid of pci_std_swizzle() ARM: PCI: versatile: fix PCI interrupt setup ARM: PCI: integrator: use common PCI swizzle ARM: 7416/1: LPAE: Remove unused L_PTE_(BUFFERABLE|CACHEABLE) macros ARM: 7415/1: vfp: convert printk's to pr_*'s ARM: decompressor: avoid speculative prefetch from non-RAM areas ARM: Remove ARMv3 support from decompressor ARM: 7413/1: move read_{boot,persistent}_clock to the architecture level ARM: Remove support for ARMv3 ARM610 and ARM710 CPUs ARM: 7363/1: DEBUG_LL: limit early mapping to the minimum ARM: 7391/1: versatile: add some auxdata for device trees ARM: 7389/2: plat-versatile: modernize FPGA IRQ controller AMBA: get rid of last two uses of NO_IRQ ARM: 7408/1: cacheflush: return error to userspace when flushing syscall fails ARM: 7409/1: Do not call flush_cache_user_range with mmap_sem held ARM: 7404/1: cmpxchg64: use atomic64 and local64 routines for cmpxchg64 ARM: 7347/1: SCU: use cpu_logical_map for per-CPU low power mode ...
2012-05-15orion/kirkwood: create a generic function for gpio led blinkingArnaud Patard (Rtp)
dns323 and (at least) iconnect platforms are using hw led blinking, so, instead of having 2 identicals .gpio_blink_set gpio-led hooks, move dns323 code into gpio.c Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Tested-By: Adam Baker <linux@baker-net.org.uk> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
