Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
commit 9b97173e785a54c5df0aa23d1e1f680f61e36e43 upstream.
Several of the ioremap functions use unsigned long in places
resulting in truncation if physical addresses greater than
4G are passed in. Change the types of the functions and the
callers accordingly.
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Cc: Wang Nan <wangnan0@huawei.com>
Nothing about the sched_clock implementation in the ARM port is
specific to the architecture. Generalize the code so that other
architectures can use it by selecting GENERIC_SCHED_CLOCK.
Bug 1399318
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[jstultz: Merge minor collisions with other patches in my tree]
Signed-off-by: John Stultz <john.stultz@linaro.org>
(cherry picked from commit 38ff87f77af0b5a93fc8581cff1d6e5692ab8970)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
Change-Id: Iaac325635344ef4adee8fa0f9ca11aee089bce0f
This reverts commit 4c3ffffdbca2e6f6f5125fa7b149d87a13f92c94.
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
This reverts commit bca7a5a04933700a8bde4ea5798119607a8b0436.
arch/arm/mach-msm/last_radio_log.c: In function 'msm_init_last_radio_log':
arch/arm/mach-msm/last_radio_log.c:69:7: error: dereferencing pointer to incomplete type
arch/cris/kernel/profile.c: In function 'init_cris_profile':
arch/cris/kernel/profile.c:79:8: error: dereferencing pointer to incomplete type
Use proc_set_size(), cfr. commit 271a15eabe094538d958dc68ccfc9c36b699247a
("proc: Supply PDE attribute setting accessor functions")
Pull ARM updates from Russell King:
"The major items included in here are:
- MCPM, multi-cluster power management, part of the infrastructure
required for ARMs big.LITTLE support.
- A rework of the ARM KVM code to allow re-use by ARM64.
- Error handling cleanups of the IS_ERR_OR_NULL() madness and fixes
of that stuff for arch/arm
- Preparatory patches for Cortex-M3 support from Uwe Kleine-König.
There is also a set of three patches in here from Hugh/Catalin to
address freeing of inappropriate page tables on LPAE. You already
have these from akpm, but they were already part of my tree at the
time he sent them, so unfortunately they'll end up with duplicate
commits"
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (77 commits)
ARM: EXYNOS: remove unnecessary use of IS_ERR_VALUE()
ARM: IMX: remove unnecessary use of IS_ERR_VALUE()
ARM: OMAP: use consistent error checking
ARM: cleanup: OMAP hwmod error checking
ARM: 7709/1: mcpm: Add explicit AFLAGS to support v6/v7 multiplatform kernels
ARM: 7700/2: Make cpu_init() notrace
ARM: 7702/1: Set the page table freeing ceiling to TASK_SIZE
ARM: 7701/1: mm: Allow arch code to control the user page table ceiling
ARM: 7703/1: Disable preemption in broadcast_tlb*_a15_erratum()
ARM: mcpm: provide an interface to set the SMP ops at run time
ARM: mcpm: generic SMP secondary bringup and hotplug support
ARM: mcpm_head.S: vlock-based first man election
ARM: mcpm: Add baremetal voting mutexes
ARM: mcpm: introduce helpers for platform coherency exit/setup
ARM: mcpm: introduce the CPU/cluster power API
ARM: multi-cluster PM: secondary kernel entry code
ARM: cacheflush: add synchronization helpers for mixed cache state accesses
ARM: cpu hotplug: remove majority of cache flushing from platforms
ARM: smp: flush L1 cache in cpu_die()
ARM: tegra: remove tegra specific cpu_disable()
Pull ARM SoC multiplatform updates from Olof Johansson:
"More multiplatform enablement for ARM platforms. The ones converted
in this branch are:
- bcm2835
- cns3xxx
- sirf
- nomadik
- msx
- spear
- tegra
- ux500
We're getting close to having most of them converted!
One of the larger platforms remaining is Samsung Exynos, and there are
a bunch of supporting patches in this merge window for it. There was
a patch in this branch to a early version of multiplatform conversion,
but it ended up being reverted due to need of more bake time. The
revert commit is part of the branch since it would have required
rebasing multiple dependent branches and they were stable by then"
* tag 'multiplatform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits)
mmc: sdhci-s3c: Fix operation on non-single image Samsung platforms
clocksource: nomadik-mtu: fix up clocksource/timer
Revert "ARM: exynos: enable multiplatform support"
ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ"
rtc: s3c: make header file local
mtd: onenand/samsung: make regs-onenand.h file local
thermal/exynos: remove unnecessary header inclusions
mmc: sdhci-s3c: remove platform dependencies
ARM: samsung: move mfc device definition to s5p-dev-mfc.c
ARM: exynos: move debug-macro.S to include/debug/
ARM: exynos: prepare for sparse IRQ
ARM: exynos: introduce EXYNOS_ATAGS symbol
ARM: tegra: build assembly files with -march=armv7-a
ARM: Push selects for TWD/SCU into machine entries
ARM: ux500: build hotplug.o for ARMv7-a
ARM: ux500: move to multiplatform
ARM: ux500: make remaining headers local
ARM: ux500: make irqs.h local to platform
ARM: ux500: get rid of <mach/[hardware|db8500-regs].h>
Pull ARM SoC platform updates from Olof Johansson:
"This branch contains part 1 of the platform updates for 3.10. Among
the highlights:
- Support for the new Atmel Cortex-A5 based platforms (SAMA5D3)
- New support for CSR SiRFatlas6 SoCs
- A handful of updates for NVidia T114 (a.k.a. Tegra 4)
- A bunch of updates for the shmobile platforms
- A handful of updates for davinci
- A few updates for Qualcomm MSM
- Plus a handful of other patches, defconfig updates, etc."
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (135 commits)
ARM: tegra: pm: fix build error w/o PM_SLEEP
ARM: davinci: ensure global variables are declared
ARM: davinci: sram.c: fix incorrect type in assignment
ARM: davinci: da8xx dt: make file local symbols static
ARM: davinci: da8xx: add remoteproc support
ARM: socfpga: Upgrade clk driver for socfpga to make use of dts clock entries
ARM: socfpga: Add clock entries into device tree
ARM: socfpga: Enable soft reset
ARM: EXYNOS: replace cpumask by the corresponding macro
ARM: EXYNOS: handle properly the return values
ARM: EXYNOS: factor out the idle states
ARM: OMAP4: Enable fix for Cortex-A9 erratas
ARM: OMAP2+: Export SoC information to userspace
ARM: OMAP2+: SoC name and revision unification
ARM: OMAP2+: Move common part of late init into common function
ARM: tegra: pm: remove duplicated include from pm.c
ARM: davinci: da850: override mmc DT node device name
ARM: davinci: da850: add mmc DT entries
mmc: davinci_mmc: add DT support
ARM: SAMSUNG: check processor type before cache restoration in resume
Pull ARM SoC cleanup from Olof Johansson:
"Here is a collection of cleanup patches. Among the pieces that stand
out are:
- The deletion of h720x platforms
- Split of at91 non-dt platforms to their own Kconfig file to keep
them separate
- General cleanups and refactoring of i.MX and MXS platforms
- Some restructuring of clock tables for OMAP
- Convertion of PMC driver for Tegra to dt-only
- Some renames of sunxi -> sun4i (Allwinner A10)
- ... plus a bunch of other stuff that I haven't mentioned"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits)
ARM: i.MX: remove unused ARCH_* configs
ARM i.MX53: remove platform ahci support
ARM: sunxi: Rework the restart code
irqchip: sunxi: Rename sunxi to sun4i
irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro
clocksource: sunxi: Rename sunxi to sun4i
clocksource: sunxi: make use of CLKSRC_OF
clocksource: sunxi: Cleanup the timer code
ARM: at91: remove trailing semicolon from macros
ARM: at91/setup: fix trivial typos
ARM: EXYNOS: remove "config EXYNOS_DEV_DRM"
ARM: EXYNOS: change the name of USB ohci header
ARM: SAMSUNG: Remove unnecessary code for dma
ARM: S3C24XX: Remove unused GPIO drive strength register definitions
ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410
ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards
ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC"
ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI"
Pull ARM SoC non-critical fixes from Olof Johansson:
"Here is a collection of fixes (and some intermixed cleanups) that were
considered less important and thus not included in the later parts of
the 3.9-rc cycle.
It's a bit all over the map, contents wise. A series of ux500 fixes
and cleanups, a bunch of various fixes for OMAP and tegra, and some
for Freescale i.MX and even Qualcomm MSM.
Note that there's also a patch on this branch to globally turn off
-Wmaybe-uninitialized when building with -Os. It's been posted
several times by Arnd and no dissent was raised, but nobody seemed
interested to pick it up. So here it is, as the topmost patch."
* tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits)
Turn off -Wmaybe-uninitialized when building with -Os
ARM: orion5x: include linux/cpu.h
ARM: tegra: call cpu_do_idle from C code
ARM: u300: fix ages old copy/paste bug
ARM: OMAP2+: add dependencies on ARCH_MULTI_V6/V7
ARM: tegra: solve adr range issue with THUMB2_KERNEL enabled
ARM: tegra: fix relocation truncated error when THUMB2_KERNEL enabled
ARM: tegra: fix build error when THUMB2_KERNEL enabled
ARM: msm: Fix uncompess.h tx underrun check
ARM: vexpress: Remove A9 PMU compatible values for non-A9 platforms
ARM: cpuimx27 and mbimx27: prepend CONFIG_ to Kconfig macro
ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS"
ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD"
ARM: mach-imx: mach-imx6q: Fix sparse warnings
ARM: mach-imx: src: Include "common.h
ARM: mach-imx: gpc: Include "common.h"
ARM: mach-imx: avic: Staticize *avic_base
ARM: mach-imx: tzic: Staticize *tzic_base
ARM: mach-imx: clk: Include "clk.h"
ARM: mach-imx: clk-busy: Staticize clk_busy_mux_ops
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Merge in the gic cleanup since it has a handful of annoying internal conflicts
with soc development branches. All of them are delete/delete conflicts.
* gic/cleanup:
irqchip: vic: add include of linux/irq.h
irqchip: gic: Perform the gic_secondary_init() call via CPU notifier
irqchip: gic: Call handle_bad_irq() directly
arm: Move chained_irq_(enter|exit) to a generic file
arm: Move the set_handle_irq and handle_arch_irq declarations to asm/irq.h
arch/arm/mach-shmobile/smp-emev2.c
arch/arm/mach-shmobile/smp-r8a7779.c
arch/arm/mach-shmobile/smp-sh73a0.c
arch/arm/mach-socfpga/platsmp.c
Merging in fixes since there's a conflict in the omap4 clock tables caused by
it.
* fixes: (245 commits)
ARM: highbank: fix cache flush ordering for cpu hotplug
ARM: OMAP4: hwmod data: make 'ocp2scp_usb_phy_phy_48m" as the main clock
arm: mvebu: Fix the irq map function in SMP mode
Fix GE0/GE1 init on ix2-200 as GE0 has no PHY
ARM: S3C24XX: Fix interrupt pending register offset of the EINT controller
ARM: S3C24XX: Correct NR_IRQS definition for s3c2440
ARM i.MX6: Fix ldb_di clock selection
ARM: imx: provide twd clock lookup from device tree
ARM: imx35 Bugfix admux clock
ARM: clk-imx35: Bugfix iomux clock
+ Linux 3.9-rc6
arch/arm/mach-omap2/cclock44xx_data.c
Remove the majority of cache flushing calls from the individual platform
files. This is now handled by the core code.
git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm into next/soc
From David Brown:
Patches for MSM core
These patches are changes to the MSM timer code that will be for
upcoming targets, including a generalization of the binding and
preventing a missing timer interrupt.
* tag 'msm-core-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm:
ARM: msm: Wait for timer clear to complete
ARM: msm: Rework timer binding to be more general
git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm into next/cleanup
From David Brown:
Cleanups for MSM for 3.10
These are some patches for various parts of MSM that gradually bring
us closer to being part of single zimage.
* tag 'msm-cleanup-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm:
ARM: msm: Remove unused cpu.h header file
gpio: Make gpio-msm-v1 into a platform driver
mmc: msm_sdcc: Remove unnecessary include
ARM: msm: Move dma.h #defines that are private to dma.c
Bit 3 of the SR register is set if there is a tx underrun. If
this bit isn't set, we should loop on the tx ready bit until we
can transmit again. Otherwise we should skip the loop and
transmit immediately. The code is doing the opposite though,
checking for an underrun and then looping on the tx ready bit
causing us to never loop on the tx read bit when the tx buffer
may not be ready.
This doesn't seem to affect my 8960 device too often, but in some
cases I see a lost character or two from the decompressor prints.
This also matches what we do in the assembly in debug-macro.S.
Signed-off-by: David Brown <davidb@codeaurora.org>
The TWD and SCU configs are selected by default as long as
MSM_SCORPIONMP is false and/or MCT is false. Implementing the
logic this way certainly saves lines in the Kconfig but it
precludes those machines which select MSM_SCORPIONMP or MCT from
participating in the single zImage effort because when those
machines are combined with other SMP capable machines the TWD and
SCU are no longer selected by default.
Push the select out to the machine entries so that we can compile
these machines together and still select the appropriate configs.
Cc: Barry Song <baohua.song@csr.com>
Acked-by: David Brown <davidb@codeaurora.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Pawel Moll <pawel.moll@arm.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Acked-by: Simon Horman <horms@verge.net.au>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Tony Lindgren <tony@atomide.com>
Acked-by: Viresh Kumar <viresh.linux@gmail.com>
All the calls to gic_secondary_init() pass 0 as the first argument.
Since this function is called on each CPU when starting, it can be done
in a platform-independent way via a CPU notifier registered by the GIC
code.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Tested-by: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Magnus Damm <magnus.damm@gmail.com>
Without looping on the status bit, there is no way to guarantee
that a clear of the timer has actually completed. This can cause
us to enable the timer before the count has cleared and miss a
timer interrupt. To simplify this patch, remove the timer
register setup done during timer init, since it's duplicate work
that is eventually done in the set_next_event() callback.
The msm timer binding I wrote is bad. First off, the clock
frequency in the binding for the dgt is wrong. Software divides
down the input rate by 4 to achieve the rate listed in the
binding. We also treat each individual timer as a separate
hardware component, when in reality there is one timer block
(that may be duplicated per cpu) with multiple timers within it.
Depending on the version of the hardware there can be one or two
general purpose timers, status and divider control registers, and
an entirely different register layout.
In the next patch we'll need to know about the different register
layouts so that we can properly check the status register after
clearing the count. The current binding makes this complicated
because the general purpose timer's reg property doesn't indicate
where that status register is, and in fact it is beyond the size
of the reg property.
Clean all this up by just having one node for the timer hardware,
and describe all the interrupts and clock frequencies supported
while having one reg property that covers the entire timer
register region. We'll use the compatible field in the future to
determine different register layouts and if we should read the
status registers, etc.
If the clockevent is forcibly reprogrammed to have a different
match value we mistakenly assume the timer is not ticking and
program a new match value while the timer is running. Although we
clear the timer before programming a new match, it's better to
stop the timer before clearing it so that we're sure the proper
amount of ticks are counted. Failure to do so can lead to missed
ticks and system hangs.
This header file is no longer used now that the msm timer.c and
the gpio driver have been made more runtime aware. Remove the
header file so no future users pop-up.
Doing this removes the dependence of this driver on the
msm_iomap.h and cpu.h mach include headers provied by MSM. This
is necessary to support single zImage work in the future and
allows us to remove cpu.h entirely and brings us closer to
removing msm_iomap.h.
Cc: Grant Likely <grant.likely@secretlab.ca>
Tested-by: Rohit Vaswani <rvaswani@codeaurora.org>
Acked-by: Rohit Vaswani <rvaswani@codeaurora.org>
These #defines are only used by the dma.c file within mach-msm.
Don't put them into a global mach include that any driver can use
to muck with registers within the dma controller. This also
prevents random people from getting access to msm_iomap.h
(a file that will soon be private to mach-msm).
Pull ARM SoC cleanups from Arnd Bergmann:
"A large number of cleanups, all over the platforms. This is dominated
largely by the Samsung platforms (s3c, s5p, exynos) and a few of the
others moving code out of arch/arm into more appropriate subsystems.
The clocksource and irqchip drivers are now abstracted to the point
where platforms that are already cleaned up do not need to even
specify the driver they use, it can all get configured from the device
tree as we do for normal device drivers. The clocksource changes
basically touch every single platform in the process.
We further clean up the use of platform specific header files here,
with the goal of turning more of the platforms over to being
"multiplatform" enabled, which implies that they cannot expose their
headers to architecture independent code any more.
It is expected that no functional changes are part of the cleanup.
The overall reduction in total code lines is mostly the result of
removing broken and obsolete code."
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits)
ARM: mvebu: correct gated clock documentation
ARM: kirkwood: add missing include for nsa310
ARM: exynos: move exynos4210-combiner to drivers/irqchip
mfd: db8500-prcmu: update resource passing
drivers/db8500-cpufreq: delete dangling include
ARM: at91: remove NEOCORE 926 board
sunxi: Cleanup the reset code and add meaningful registers defines
ARM: S3C24XX: header mach/regs-mem.h local
ARM: S3C24XX: header mach/regs-power.h local
ARM: S3C24XX: header mach/regs-s3c2412-mem.h local
ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/
ARM: S3C24XX: transform s3c2443 subirqs into new structure
ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs
ARM: S3C24XX: move s3c2443 irq code to irq.c
ARM: S3C24XX: transform s3c2416 irqs into new structure
ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs
ARM: S3C24XX: move s3c2416 irq init to common irq code
ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property
ARM: S3C24XX: Move irq syscore-ops to irq-pm
clocksource: always define CLOCKSOURCE_OF_DECLARE
msm_smd_probe is a driver probe function and may get
called after the __init time, so it must not call
any __init function, as the link-time warning reports.
Take away the __init annotation on proc_comm_boot_wait
to fix this.
Without this patch, building msm_defconfig results in:
WARNING: vmlinux.o(.text+0xb048): Section mismatch in reference from the function msm_smd_probe() to the function .init.text:proc_comm_boot_wait()
The function msm_smd_probe() references
the function __init proc_comm_boot_wait().
This is often because msm_smd_probe lacks a __init
annotation or the annotation of proc_comm_boot_wait is wrong.
Cc: Daniel Walker <c_dwalke@quicinc.com>
Cc: linux-arm-msm@vger.kernel.org
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup
From Shawn Guo:
The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which
are unused on ARM architecure. Samsung has some code setting up wdog
in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined
nowhere, it will not run. Otherwise, system can not boot at all when
wdog is set up but no one pats it.
* tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6:
ARM: samsung: remove unused arch_decomp_wdog() code
ARM: remove unused arch_decomp_wdog()
ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG
into next/cleanup
From Rob Herring:
Initial irqchip init infrastructure and GIC and VIC clean-ups
This creates irqchip initialization infrastructure from Thomas
Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips
and adapted to use the new infrastructure. All DT enabled platforms
using GIC and VIC are converted over to use the new irqchip_init.
* tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux:
irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h
ARM: picoxcell: use common irqchip_init function
ARM: spear: use common irqchip_init function
irqchip: Move ARM VIC to drivers/irqchip
ARM: samsung: remove unused tick.h
ARM: remove unneeded vic.h includes
ARM: remove mach .handle_irq for VIC users
ARM: VIC: set handle_arch_irq in VIC initialization
ARM: VIC: shrink down vic.h
irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h
ARM: use common irqchip_init for GIC init
irqchip: Move ARM GIC to drivers/irqchip
ARM: remove mach .handle_irq for GIC users
ARM: GIC: set handle_arch_irq in GIC initialization
ARM: GIC: remove direct use of gic_raise_softirq
ARM: GIC: remove assembly ifdefs from gic.h
ARM: mach-ux500: use SGI0 to wake up the other core
arm: add set_handle_irq() to register the parent IRQ controller handler function
irqchip: add basic infrastructure
irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS
Fixed up massive merge conflicts with the timer cleanup due to adjacent changes:
arch/arm/mach-bcm/board_bcm.c
arch/arm/mach-cns3xxx/cns3420vb.c
arch/arm/mach-ep93xx/adssphere.c
arch/arm/mach-ep93xx/edb93xx.c
arch/arm/mach-ep93xx/gesbc9312.c
arch/arm/mach-ep93xx/micro9.c
arch/arm/mach-ep93xx/simone.c
arch/arm/mach-ep93xx/snappercl15.c
arch/arm/mach-ep93xx/ts72xx.c
arch/arm/mach-ep93xx/vision_ep9307.c
arch/arm/mach-highbank/highbank.c
arch/arm/mach-imx/mach-imx6q.c
arch/arm/mach-msm/board-dt-8960.c
arch/arm/mach-netx/nxdb500.c
arch/arm/mach-netx/nxdkn.c
arch/arm/mach-netx/nxeb500hmi.c
arch/arm/mach-nomadik/board-nhk8815.c
arch/arm/mach-picoxcell/common.c
arch/arm/mach-realview/realview_eb.c
arch/arm/mach-realview/realview_pb1176.c
arch/arm/mach-realview/realview_pb11mp.c
arch/arm/mach-realview/realview_pba8.c
arch/arm/mach-realview/realview_pbx.c
arch/arm/mach-socfpga/socfpga.c
arch/arm/mach-spear13xx/spear1310.c
arch/arm/mach-spear13xx/spear1340.c
arch/arm/mach-spear13xx/spear13xx.c
arch/arm/mach-spear3xx/spear300.c
arch/arm/mach-spear3xx/spear310.c
arch/arm/mach-spear3xx/spear320.c
arch/arm/mach-spear3xx/spear3xx.c
arch/arm/mach-spear6xx/spear6xx.c
arch/arm/mach-tegra/board-dt-tegra20.c
arch/arm/mach-tegra/board-dt-tegra30.c
arch/arm/mach-u300/core.c
arch/arm/mach-ux500/board-mop500.c
arch/arm/mach-ux500/cpu-db8500.c
arch/arm/mach-versatile/versatile_ab.c
arch/arm/mach-versatile/versatile_dt.c
arch/arm/mach-versatile/versatile_pb.c
arch/arm/mach-vexpress/v2m.c
include/asm-generic/vmlinux.lds.h
Clockevent cleanup series from Shawn Guo.
Resolved move/change conflict in mach-pxa/time.c due to the sys_timer
cleanup.
* clocksource/cleanup:
clocksource: use clockevents_config_and_register() where possible
ARM: use clockevents_config_and_register() where possible
clockevents: export clockevents_config_and_register for module use
+ sync to Linux 3.8-rc3
arch/arm/mach-pxa/time.c
The clockevent core is able to figure out the best mult and shift,
calculate min_delta_ns and max_delta_ns, with the necessary info passed
into clockevents_config_and_register(). Use this combined configure
and register function where possible to make the codes less error prone
and gain some positive diff stat.
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Jason Cooper <jason@lakedaemon.net>
Tested-by: Roland Stigge <stigge@antcom.de>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Barry Song <baohua.song@csr.com>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Now that we have GIC moved to drivers/irqchip and all GIC DT init for
platforms using irqchip_init, move gic.h and update the remaining
includes.
Cc: Anton Vorontsov <avorontsov@mvista.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Convert all GIC DT initialization over to use common irqchip_init
function.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Cc: Dinh Nguyen <dinguyen@altera.com>
Now that the GIC initialization sets up the handle_arch_irq pointer, we
can remove it for all machines and make it static.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Olof Johansson <olof@lixom.net>
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c,
all the arch_decomp_wdog() definition at platform level is unneeded.
Remmove it.
In preparation of moving gic code to drivers/irqchip, remove the direct
platform dependencies on gic_raise_softirq. Move the setup of
smp_cross_call into the gic code and use arch_send_wakeup_ipi_mask
function to trigger wake-up IPIs.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
As suggested by Andrew Morton:
This is a pet peeve of mine. Any time there's a long list of items
(header file inclusions, kconfig entries, array initalisers, etc) and
someone wants to add a new item, they *always* go and stick it at the
end of the list.
Guys, don't do this. Either put the new item into a randomly-chosen
position or, probably better, alphanumerically sort the list.
lets sort all our select statements alphanumerically. This commit was
created by the following perl:
while (<>) {
while (/\\\s*$/) {
$_ .= <>;
undef %selects if /^\s*config\s+/;
if (/^\s+select\s+(\w+).*/) {
if (defined($selects{$1})) {
if ($selects{$1} eq $_) {
print STDERR "Warning: removing duplicated $1 entry\n";
} else {
print STDERR "Error: $1 differently selected\n".
"\tOld: $selects{$1}\n".
"\tNew: $_\n";
exit 1;
$selects{$1} = $_;
next;
if (%selects and (/^\s*$/ or /^\s+help/ or /^\s+---help---/ or
/^endif/ or /^endchoice/)) {
foreach $k (sort (keys %selects)) {
print "$selects{$k}";
undef %selects;
print;
if (%selects) {
It found two duplicates:
Warning: removing duplicated S5P_SETUP_MIPIPHY entry
Warning: removing duplicated HARDIRQS_SW_RESEND entry
and they are identical duplicates, hence the shrinkage in the diffstat
of two lines.
We have four testers reporting success of this change (Tony, Stephen,
Linus and Sekhar.)
Acked-by: Sekhar Nori <nsekhar@ti.com>
Pull ARM soc multiplatform enablement from Olof Johansson:
"This is a pretty significant branch. It's the introduction of the
first multiplatform support on ARM, and with this (and the later
branch) merged, it is now possible to build one kernel that contains
support for highbank, vexpress, mvebu, socfpga, and picoxcell. More
platforms will be convered over in the next few releases.
Two critical last things had to be done for this to be practical and
possible:
* Today each platform has its own include directory under
mach-<mach>/include/mach/*, and traditionally that is where a lot
of driver/platform shared definitions have gone, such as platform
data structures. They now need to move out to a common location
instead, and this branch moves a large number of those out to
include/linux/platform_data.
* Each platform used to list the device trees to compile for its
boards in mach-<mach>/Makefile.boot.
Both of the above changes will mean that there are some merge
conflicts to come (and some to resolve here). It's a one-time move
and once it settles in, we should be good for quite a while. Sorry
for the overhead."
Fix conflicts as per Olof.
* tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits)
ARM: add v7 multi-platform defconfig
ARM: msm: Move core.h contents into common.h
ARM: highbank: call highbank_pm_init from .init_machine
ARM: dtb: move all dtb targets to common Makefile
ARM: spear: move platform_data definitions
ARM: samsung: move platform_data definitions
ARM: orion: move platform_data definitions
ARM: vexpress: convert to multi-platform
ARM: initial multiplatform support
ARM: mvebu: move armada-370-xp.h in mach dir
ARM: vexpress: remove dependency on mach/* headers
ARM: picoxcell: remove dependency on mach/* headers
ARM: move all dtb targets out of Makefile.boot
ARM: picoxcell: move debug macros to include/debug
ARM: socfpga: move debug macros to include/debug
ARM: mvebu: move debug macros to include/debug
ARM: vexpress: move debug macros to include/debug
ARM: highbank: move debug macros to include/debug
ARM: move debug macros to common location
ARM: make mach/gpio.h headers optional
Pull ARM soc board specific updates from Olof Johansson:
"Misc board updates:
- Greg added a handful of boards to KS8695 (since he has stepped up
to maintain it).
- Qualcomm has added DT-only board support for a couple of their
newer SoCs.
- misc other updates for Samsung and Freescale boards."
Fix up trivial conflict in arch/arm/mach-shmobile/board-armadillo800eva.c
due to gpio device data being added next to hdmi device data that got moved.
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: msm: Allow 8960 and 8660 to compile together
ARM: msm: Allow msm_iomap-8x60 and msm_iomap-8960 to coexist
ARM: EXYNOS: Add generic PWM lookup support for SMDKV310
ARM: EXYNOS: Add generic PWM lookup support for SMDK4X12
ARM: EXYNOS: Use generic pwm driver in Origen board
ARM: shmobile: armadillo800eva: Add support RTC
ARM: ks8695: add board support for the OpenGear boards based on the KS8695
ARM: ks8695: add board support for the SnapGear boards based on the KS8695
ARM: dts: Add heartbeat gpio-leds support to Origen
ARM: dts: Use active low flag for gpio-keys on Origen
ARM: shmobile: marzen: enable thermal sensor
ARM: shmobile: marzen: fixup regulator id for smsc911x
ARM: shmobile: marzen: add SDHI0 support
ARM: mmp: enable debug uart port in defconfig
ARM: mmp: implement DEBUG_LL port choice
ARM: S3C64XX: Register audio platform devices for Bells on Cragganmore
ARM: S3C64XX: Update configuration for WM5102 module on Cragganmore
ARM: mx27pdk: Add audio support
ARM: ttc_dkb: add nand support
Pull ARM soc device tree updates from Olof Johansson:
"Device tree conversion and enablement branch. Mostly a bunch of new
bindings and setup for various platforms, but the Via/Winchip VT8500
platform is also converted over from being 100% legacy to now use
device tree for probing. More of that will come for 3.8."
Trivial conflicts due to removal of vt8500 files, and one documentation
file that was added with slightly different contents both here and in
the USb tree.
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (212 commits)
arm: vt8500: Fixup for missing gpio.h
ARM: LPC32xx: LED fix in PHY3250 DTS file
ARM: dt: mmp-dma: add binding file
arm: vt8500: Update arch-vt8500 to devicetree support.
arm: vt8500: gpio: Devicetree support for arch-vt8500
arm: vt8500: doc: Add device tree bindings for arch-vt8500 devices
arm: vt8500: clk: Add Common Clock Framework support
video: vt8500: Add devicetree support for vt8500-fb and wm8505-fb
serial: vt8500: Add devicetree support for vt8500-serial
rtc: vt8500: Add devicetree support for vt8500-rtc
arm: vt8500: Add device tree files for VIA/Wondermedia SoC's
ARM: tegra: Add Avionic Design Tamonten Evaluation Carrier support
ARM: tegra: Add Avionic Design Medcom-Wide support
ARM: tegra: Add Avionic Design Plutux support
ARM: tegra: Add Avionic Design Tamonten support
ARM: tegra: dts: Add pwm label
ARM: ux500: Fix SSP register address format
ARM: ux500: Apply tc3589x's GPIO/IRQ properties to HREF's DT
ARM: ux500: Remove redundant #gpio-cell properties from Snowball DT
ARM: ux500: Add all encompassing sound node to the HREF Device Tree
Pull ARM soc general cleanups from Olof Johansson:
"This is a large branch that contains a handful of different cleanups:
- Fixing up the I/O space remapping on PCI on ARM. This is a series
from Rob Herring that restructures how all pci devices allocate I/O
space, and it's part of the work to allow multiplatform kernels.
- A number of cleanup series for OMAP, moving and removing some
headers, sparse irq rework and in general preparation for
multiplatform.
- Final removal of all non-DT boards for Tegra, it is now
device-tree-only!
- Removal of a stale platform, nxp4008. It's an old mobile chipset
that is no longer in use, and was very likely never really used
with a mainline kernel. We have not been able to find anyone
interested in keeping it around in the kernel.
- Removal of the legacy dmaengine driver on tegra
+ A handful of other things that I haven't described above."
Fix up some conflicts with the staging tree (and because nxp4008 was
removed)
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (184 commits)
ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6
ARM: OMAP4: twl-common: Support for additional devices on i2c1 bus
ARM: mmp: using for_each_set_bit to simplify the code
ARM: tegra: harmony: fix ldo7 regulator-name
ARM: OMAP2+: Make omap4-keypad.h local
ARM: OMAP2+: Make l4_3xxx.h local
ARM: OMAP2+: Make l4_2xxx.h local
ARM: OMAP2+: Make l3_3xxx.h local
ARM: OMAP2+: Make l3_2xxx.h local
ARM: OMAP1: Move irda.h from plat to mach
ARM: OMAP2+: Make hdq1w.h local
ARM: OMAP2+: Make gpmc-smsc911x.h local
ARM: OMAP2+: Make gpmc-smc91x.h local
ARM: OMAP1: Move flash.h from plat to mach
ARM: OMAP2+: Make debug-devices.h local
ARM: OMAP1: Move board-voiceblue.h from plat to mach
ARM: OMAP1: Move board-sx1.h from plat to mach
ARM: OMAP2+: Make omap-wakeupgen.h local
ARM: OMAP2+: Make omap-secure.h local
ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local
__iomem annotation cleanup branch from Arnd.
* cleanup/__iomem: (21 commits)
net: seeq: use __iomem pointers for MMIO
video: da8xx-fb: use __iomem pointers for MMIO
scsi: eesox: use __iomem pointers for MMIO
serial: ks8695: use __iomem pointers for MMIO
input: rpcmouse: use __iomem pointers for MMIO
ARM: samsung: use __iomem pointers for MMIO
ARM: spear13xx: use __iomem pointers for MMIO
ARM: sa1100: use __iomem pointers for MMIO
ARM: prima2: use __iomem pointers for MMIO
ARM: nomadik: use __iomem pointers for MMIO
ARM: msm: use __iomem pointers for MMIO
ARM: lpc32xx: use __iomem pointers for MMIO
ARM: ks8695: use __iomem pointers for MMIO
ARM: ixp4xx: use __iomem pointers for MMIO
ARM: iop32x: use __iomem pointers for MMIO
ARM: iop13xx: use __iomem pointers for MMIO
ARM: integrator: use __iomem pointers for MMIO
ARM: imx: use __iomem pointers for MMIO
ARM: ebsa110: use __iomem pointers for MMIO
ARM: at91: use __iomem pointers for MMIO
* multiplatform/platform-data:
ARM: nomadik: move platform_data definitions
ARM: w90x900: move platform_data definitions
ARM: vt8500: move platform_data definitions
ARM: tegra: move sdhci platform_data definition
ARM: sa1100: move platform_data definitions
ARM: pxa: move platform_data definitions
ARM: netx: move platform_data definitions
ARM: msm: move platform_data definitions
ARM: imx: move platform_data definitions
ARM: ep93xx: move platform_data definitions
ARM: davinci: move platform_data definitions
ARM: at91: move platform_data definitions
Conflicts due to removed files:
arch/arm/mach-tegra/board-harmony.c
arch/arm/mach-tegra/board-trimslice.c
Conflicts due to code removal:
arch/arm/mach-tegra/board-paz00.c
Context conflicts in:
drivers/mmc/host/sdhci-tegra.c
drivers/net/irda/pxaficp_ir.c
No real need to have a separate core.h from the common.h file. Fold
these two prototypes into the common header file.
* multiplatform/smp_ops:
ARM: consolidate pen_release instead of having per platform definitions
ARM: smp: Make SMP operations mandatory
ARM: SoC: convert spear13xx to SMP operations
ARM: SoC: convert imx6q to SMP operations
ARM: SoC: convert highbank to SMP operations
ARM: SoC: convert shmobile SMP to SMP operations
ARM: SoC: convert ux500 to SMP operations
ARM: SoC: convert MSM to SMP operations
ARM: SoC: convert Exynos4 to SMP operations
ARM: SoC: convert Tegra to SMP operations
ARM: SoC: convert OMAP4 to SMP operations
ARM: SoC: convert VExpress/RealView to SMP operations
ARM: SoC: add per-platform SMP operations
Conflicts due to file moves or removals in:
arch/arm/mach-msm/board-msm8960.c
arch/arm/mach-msm/board-msm8x60.c
Conflicts due to board file cleanup:
Conflicts due to cpu hotplug addition:
arch/arm/mach-tegra/hotplug.c
