path: root/arch/arm/mach-dove
2013-04-15arm: mach-dove: convert to use mvebu-mbus driverThomas Petazzoni
This commit migrates the mach-dove platforms to use the mvebu-mbus driver and therefore removes the Dove-specific addr-map code. The dove_init_early() function now initializes the mvebu-mbus driver by calling mvebu_mbus_init(). The address decoding windows are now registered in the dove_setup_cpu_wins() function. It is worth noting that the four PCIe address decoding windows will ultimately no longer have to be registered here: it will be done automatically by the PCIe driver once Dove has been migrated to use the upcoming mvebu PCIe driver. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28Merge tag 'late-mvebu-rebased' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC mvebu platform changes from Olof Johansson: "This series contains changes for the Marvell EBU platforms (mvebu, orion, kirkwood, dove) that were not part of the first set of pull requests because of dependencies on the MMC tree, and being submitted a little late. Notable changes are: - More devices get moved out of board files into device tree descriptions. The remaining devices listed in there have patches that will get sent for 3.10, after which we can remove a lot of the board files entirely. We are doing the pinctrl and mmc drivers here, ethernet and PCI still remain. - SMP support for mvebu is improved with support for the local interrupt controller. - The Guruplug board file gets replaced with a DT description. Unfortunately, the dependency on the MMC tree turned out to be a much larger problem than expected, when the MMC maintainer rebased the patches in his tree that all of the patches in this branch are based on, which caused merge conflicts between the new and old versions of those patches. To work around the merge conflicts, this branch rebases all patches on top of the respective MMC patches that did get merged into 3.9. The patches are all identical to the versions that were part of linux-next, but have a new commit date." * tag 'late-mvebu-rebased' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (90 commits) arm: mvebu: enable the SD card slot on Armada 370 Reference Design board ARM: kirkwood: topkick: init mvsdio via DT ARM: kirkwood: nsa310: convert to pinctrl ARM: Kirkwood: topkick: Enable i2c bus. ARM: kirkwood: topkick: convert to pinctrl ARM: dove: convert serial DT nodes to clocks property arm: mvebu: Add SPI flash on Armada 370 DB board arm: mvebu: Add SPI flash on Armada XP-DB board arm: mvebu: Add SPI flash on Armada XP-GP board arm: mvebu: Add support for SPI controller in Armada 370/XP clocksource: update and move armada-370-xp-timer documentation to timer directory arm: mvebu: update DT to support local timers ARM: Dove: convert usb host controller to DT arm: mvebu: Enable USB controllers on Armada 370/XP boards arm: mvebu: Add support for USB host controllers in Armada 370/XP arm: mvebu: add button for OpenBlocks AX3-4 ARM: Kirkwood: Convert NS2 to gpio-poweroff. ARM: Kirkwood: Convert NSA310 I2C to device tree ARM: Kirkwood: Convert NSA310 to use gpio-poweroff driver ARM: Kirkwood: Convert NSA310 to DT based regulators. ...
2013-02-28ARM: Dove: convert usb host controller to DTSebastian Hesselbarth
With DT support for orion-ehci also convert Dove to it and remove the legacy calls and clock aliases. This patch is based on "ARM: Dove: split legacy and DT setup" applied to mvebu/boards recently. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28ARM: Dove: add fixed regulator for CuBox USB powerSebastian Hesselbarth
CuBox needs to enable USB power on a gpio pin. Add a fixed regulator to always enable usb power on boot. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28ARM: Dove: split legacy and DT setupArnd Bergmann
In the beginning of DT for Dove it was reasonable to have it close to non-DT code. With improved DT support, it became more and more difficult to not break non-DT while changing DT code. This patch splits up DT board setup and introduces a DOVE_LEGACY config to allow to remove legacy code for DT-only kernels. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28Merge branch 'timer/cleanup' into late/mvebu2Arnd Bergmann
Basing the mvebu patches on top of the timer cleanup avoids some nasty merges. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-31Merge tag 'tags/cleanup_for_v3.9_round2' into mvebu/boardsJason Cooper
cleanup for v3.9 round2 - remove unneeded #includes for mach-dove - remove unneeded #includes and code for the nsa310
2013-01-31ARM: dove: cleanup includesSebastian Hesselbarth
This patch cleans unneccessary includes and reorders the remaining includes in common dove code. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-29Merge tag 'cleanup_for_v3.9_round2' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into next/cleanup From Jason Cooper: cleanup for v3.9 round2 - remove unneeded #includes for mach-dove - remove unneeded #includes and code for the nsa310 * tag 'cleanup_for_v3.9_round2' of git://git.infradead.org/users/jcooper/linux: ARM: dove: cleanup includes ARM: kirkwood: nsa310: cleanup includes and unneeded code
2013-01-29ARM: dove: cleanup includesSebastian Hesselbarth
2013-01-14Merge branch 'clocksource/cleanup' into next/cleanupOlof Johansson
Clockevent cleanup series from Shawn Guo. Resolved move/change conflict in mach-pxa/time.c due to the sys_timer cleanup. * clocksource/cleanup: clocksource: use clockevents_config_and_register() where possible ARM: use clockevents_config_and_register() where possible clockevents: export clockevents_config_and_register for module use + sync to Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-pxa/time.c
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2013-01-03ARM: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-14Merge tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates for Marvell mvebu/kirkwood from Olof Johansson: "This is a branch with updates for Marvell's mvebu/kirkwood platforms. They came in late-ish, and were heavily interdependent such that it didn't make sense to split them up across the cross-platform topic branches. So here they are (for the second release in a row) in a branch on their own." * tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (88 commits) arm: l2x0: add aurora related properties to OF binding arm: mvebu: add Aurora L2 Cache Controller to the DT arm: mvebu: add L2 cache support dma: mv_xor: fix error handling path dma: mv_xor: fix error checking of irq_of_parse_and_map() dma: mv_xor: use request_irq() instead of devm_request_irq() dma: mv_xor: clear the window override control registers arm: mvebu: fix address decoding armada_cfg_base() function ARM: mvebu: update defconfig with I2C and RTC support ARM: mvebu: Add SATA support for OpenBlocks AX3-4 ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4 ARM: mvebu: Add support for I2C on OpenBlocks AX3-4 ARM: mvebu: Add support for I2C controllers in Armada 370/XP arm: mvebu: Add hardware I/O Coherency support arm: plat-orion: Add coherency attribute when setup mbus target arm: dma mapping: Export a dma ops function arm_dma_set_mask arm: mvebu: Add SMP support for Armada XP arm: mm: Add support for PJ4B cpu and init routines arm: mvebu: Add IPI support via doorbells arm: mvebu: Add initial support for power managmement service unit ...
2012-11-21Dove: Fix irq_to_pmu()Russell King - ARM Linux
PMU interrupts start at IRQ_DOVE_PMU_START, not IRQ_DOVE_PMU_START + 1. Fix the condition. (It may have been less likely to occur had the code been written "if (irq >= IRQ_DOVE_PMU_START" which imho is the easier to understand notation, and matches the normal way of thinking about these things.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21Dove: Attempt to fix PMU/RTC interruptsRussell King - ARM Linux
Fix the acknowledgement of PMU interrupts on Dove: some Dove hardware has not been sensibly designed so that interrupts can be handled in a race free manner. The PMU is one such instance. The pending (aka 'cause') register is a bunch of RW bits, meaning that these bits can be both cleared and set by software (confirmed on the Armada-510 on the cubox.) Hardware sets the appropriate bit when an interrupt is asserted, and software is required to clear the bits which are to be processed. If we write ~(1 << bit), then we end up asserting every other interrupt except the one we're processing. So, we need to do a read-modify-write cycle to clear the asserted bit. However, any interrupts which occur in the middle of this cycle will also be written back as zero, which will also clear the new interrupts. The upshot of this is: there is _no_ way to safely clear down interrupts in this register (and other similarly behaving interrupt pending registers on this device.) The patch below at least stops us creating new interrupts. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-20arm: dove: Convert Dove to DT XOR DMA engineSebastian Hesselbarth
With DT support for Marvell XOR DMA engine, make use of it on Dove. Also remove the now redundant code in DT board init for xor engines. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20dma: mv_xor: change the driver name to 'mv_xor'Thomas Petazzoni
Since we got rid of the per-XOR channel 'mv_xor' driver, now the per-XOR engine driver that used to be called 'mv_xor_shared' can simply be named 'mv_xor'. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20ARM: dove: switch to DT clock providersSebastian Hesselbarth
With true DT clock providers available switch Dove clock setup in DT- enabled boards. While AUXDATA can be removed completely from bus probing, some devices still don't know about DT at all. Therefore, some clock aliases are created until the devices also move to DT. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2012-10-17ARM: dove: Add crypto engine to DTSebastian Hesselbarth
Make use of DT support for the crypto engine on dove and remove the obsolete init call. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-10-17ARM: dove: Fix clock names of sata and gbeSebastian Hesselbarth
This patch fixes wrong clock names of lately added clock gates for sata and gbe (mv64xx_eth). Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-10-17ARM: dove: Fix tauros2 device tree initSebastian Hesselbarth
During the review process of dove DT patches, Tauros2 cache init call was changed and DT support added. This patch fixes the call to Tauros2 init and adds a DT node. Moreover, plat/irq.h include was missing from mach-dove/common.c. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-10-17ARM: dove: Add pcie clock supportSebastian Hesselbarth
As dove now has clock gating control ensure pcie ports grab their clocks. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-22ARM: kirkwood: move new dtbs to common MakefileOlof Johansson
This moves a few of the newly introduced dtb targets to the common dts/Makefile instead of the per-platform file. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-22Merge branch 'kirkwood/addr_decode' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into late/kirkwood * 'kirkwood/addr_decode' of git://git.infradead.org/users/jcooper/linux: arm: mvebu: add address decoding controller to the DT arm: mvebu: add basic address decoding support to Armada 370/XP arm: plat-orion: make bridge_virt_base non-const to support DT use case arm: plat-orion: introduce PLAT_ORION_LEGACY hidden config option arm: plat-orion: use void __iomem pointers for addr-map functions arm: plat-orion: use void __iomem pointers for time functions arm: plat-orion: use void __iomem pointers for MPP functions arm: plat-orion: use void __iomem pointers for UART registration functions arm: mach-mvebu: use IOMEM() for base address definitions arm: mach-orion5x: use IOMEM() for base address definitions arm: mach-mv78xx0: use IOMEM() for base address definitions arm: mach-kirkwood: use IOMEM() for base address definitions arm: mach-dove: use IOMEM() for base address definitions arm: mach-orion5x: use plus instead of or for address definitions arm: mach-mv78xx0: use plus instead of or for address definitions arm: mach-kirkwood: use plus instead of or for address definitions arm: mach-dove: use plus instead of or for address definitions This branch had quite a few conflicts, in particular with the PCI static map rework from Rob Herring, and a few other context conflicts due to changes in Kconfig, etc. I fixed up conflicts in: arch/arm/Kconfig arch/arm/mach-dove/common.c arch/arm/mach-dove/include/mach/dove.h arch/arm/mach-kirkwood/common.c arch/arm/mach-kirkwood/include/mach/kirkwood.h arch/arm/mach-mv78xx0/common.c arch/arm/mach-mv78xx0/include/mach/mv78xx0.h arch/arm/mach-orion5x/common.c arch/arm/mach-orion5x/include/mach/orion5x.h Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-22Merge branch 'kirkwood/boards' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into late/kirkwood * 'kirkwood/boards' of git://git.infradead.org/users/jcooper/linux: ARM: Dove: allow PCI to be disabled ARM: dove: SolidRun CuBox DT ARM: dove: add device tree descriptors ARM: dove: add device tree based machine descriptor ARM: dove: add crypto engine ARM: dove: add clock gating control ARM: dove: unify clock setup ARM: initial DTS support for km_kirkwood arm: add documentation describing Marvell families of SoC ARM: kirkwood: DT descriptor for Seagate FreeAgent Dockstar ARM: kirkwood: DT board setup for Seagate FreeAgent Dockstar ARM: Kirkwood: Iomega ix2-200 DT support Context conflicts in arch/arm/Kconfig and arch/arm/mach-dove/common.c. The new device trees added to arch/arm/mach-kirkwood/Makefile.boot are kept and dealt with in a separate changeset, since moving them out to the new Makefile in this merge commit doesn't work well. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-22Merge branch 'multiplatform/platform-data' into next/multiplatformOlof Johansson
* multiplatform/platform-data: ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: nomadik: move platform_data definitions ARM: w90x900: move platform_data definitions ARM: vt8500: move platform_data definitions ARM: tegra: move sdhci platform_data definition ARM: sa1100: move platform_data definitions ARM: pxa: move platform_data definitions ARM: netx: move platform_data definitions ARM: msm: move platform_data definitions ARM: imx: move platform_data definitions ARM: ep93xx: move platform_data definitions ARM: davinci: move platform_data definitions ARM: at91: move platform_data definitions Conflicts due to removed files: arch/arm/mach-tegra/board-harmony.c arch/arm/mach-tegra/board-trimslice.c Conflicts due to code removal: arch/arm/mach-tegra/board-paz00.c Context conflicts in: drivers/mmc/host/sdhci-tegra.c drivers/net/irda/pxaficp_ir.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-21arm: plat-orion: use void __iomem pointers for addr-map functionsThomas Petazzoni
The functions for address mapping management now take void __iomem pointers, so we remove the temporary "unsigned long" casts from the mach-*/common.c files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: plat-orion: use void __iomem pointers for time functionsThomas Petazzoni
The functions for time management now take void __iomem pointers, so we remove the temporary "unsigned long" casts from the mach-*/common.c files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: plat-orion: use void __iomem pointers for MPP functionsThomas Petazzoni
The registration function for MPP now takes void __iomem pointers, so we remove the temporary "unsigned long" casts from the mach-*/mpp.c files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: plat-orion: use void __iomem pointers for UART registration functionsThomas Petazzoni
The registration functions for UARTs now take void __iomem pointers, so we remove the temporary "unsigned long" casts from the mach-*/common.c files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: mach-dove: use IOMEM() for base address definitionsThomas Petazzoni
We now define all virtual base address constants using IOMEM() so that those are naturally typed as void __iomem pointers, and we do the necessary adjustements in the mach-dove code. Note that we introduce a few temporary additional "unsigned long" casts when calling into plat-orion functions. Those are removed by followup patches converting plat-orion functions to void __iomem pointers as well. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21arm: mach-dove: use plus instead of or for address definitionsThomas Petazzoni
Since we are going to use IOMEM() to define many base virtual addresses, we can no longer use binary or to define the individual register addresses ("binary or" arithmetic on pointers is not allowed). Instead, use the more conventional plus operator to do so. The binary or operators were actually not useful because the low-order bits of the base address were always zero, so the usage of the binary or operators was effectively identical to a plus operator. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21ARM: Dove: allow PCI to be disabledRussell King
Allow PCI support for Dove to be disabled. Some platforms do not have anything connected to the PCIe ports, so requiring PCI support to be built into the kernel just wastes space, and presents a lot more config options than are necessary. However, select USB_ARCH_HAS_EHCI so that we can still have EHCI support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21ARM: dove: SolidRun CuBox DTSebastian Hesselbarth
This patch adds basic support for the SolidRun CuBox to DT based mach-dove. There are still some issues related to ongoing orion/mvebu development, e.g. gpio-led will not work as there is no DT pinctrl for dove yet and we don't have board specific setup code. Nevertheless, the DT description is already introduced here. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21ARM: dove: add device tree descriptorsSebastian Hesselbarth
This patch adds device tree decriptors for dove SoC and currently supported boards. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21ARM: dove: add device tree based machine descriptorSebastian Hesselbarth
This adds a generic DT_MACHINE for mach-dove. As with other orion based SoCs there still is some glue code required to make all internal devices work, i.e. auxdata is provided to pass clocks to corresponding device drivers. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21ARM: dove: add crypto engineSebastian Hesselbarth
This patch adds a dove specific setup function for the Marvell CESA crypto engine available on orion based SoCs. Dove setup was just missing a function to call orion_crypto_init with dove specific setup. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21ARM: dove: add clock gating controlSebastian Hesselbarth
This patch adds clock gates from the clock gating control register available on dove. All clock gates are hooked up to tclk, except for gigabit ethernet controller (ge) which is a child of gephy to allow both enabled/disabled at the same time. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-21ARM: dove: unify clock setupSebastian Hesselbarth
This patch synchronizes the clock setup of dove with other orion-based platforms. In dove_find_tclk there was a note about DOVE_SAMPLE_HI/LO register to detect tclk. While it might be possible to set a different tclk frequency with reset strapping the Dove datasheets don't tell anything about tclk frequency here. Therefore, I removed that comment. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-09-20Merge tag 'multi-platform-for-3.7' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/multiplatform Enable initial ARM multi-platform support for highbank, mvebu, socfpga, picoxcell, and vexpress. Multi-platform support is dependent on mach/gpio.h removal and restructuring of DEBUG_LL and dtb build rules included in this branch. This has been built for all defconfigs, and booted on highbank with all 5 platforms enabled. By Rob Herring (18) and Arnd Bergmann (1) via Rob Herring * tag 'multi-platform-for-3.7' of git://sources.calxeda.com/kernel/linux: ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ARM: orion: move custom gpio functions to orion-gpio.h ARM: shmobile: move custom gpio functions to sh-gpio.h ARM: pxa: use gpio_to_irq for sharppm_sl net: pxaficp_ir: add irq resources usb: pxa27x_udc: remove IRQ_USB define staging: ste_rmi4: remove gpio.h include Conflicts due to addition of bcm2835 and removal of pnx4008 in: arch/arm/Kconfig arch/arm/Makefile Conflicts due to new dtb targets, moved to arch/arm/boot/dts/Makefile in: arch/arm/mach-imx/Makefile.boot arch/arm/mach-mxs/Makefile.boot arch/arm/mach-tegra/Makefile.boot Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-20Merge branch 'next/dt' into next/multiplatformOlof Johansson
* next/dt: (182 commits) ARM: tegra: Add Avionic Design Tamonten Evaluation Carrier support ARM: tegra: Add Avionic Design Medcom-Wide support ARM: tegra: Add Avionic Design Plutux support ARM: tegra: Add Avionic Design Tamonten support ARM: tegra: dts: Add pwm label ARM: dt: tegra: whistler: configure power off ARM: mxs: m28evk: Disable OCOTP OUI loading ARM: imx6q: use pll2_pfd2_396m as the enfc_sel's parent ARM: dts: imx6q-sabrelite: add usbotg pinctrl support ARM: dts: imx23-olinuxino: Add USB host support ARM: dts: imx6q-sabrelite: add usbmisc device ARM: dts: mx23: Add USB resources ARM: dts: mxs: Add ethernetX to macX aliases ARM: msm: Remove non-DT targets from 8960 ARM: msm: Add DT support for 8960 ARM: msm: Move io mapping prototypes to common.h ARM: msm: Rename board-msm8x60 to signify its DT only status ARM: msm: Make 8660 a DT only target ARM: msm: Move 8660 to DT timer ARM: msm: Add DT support to msm_timer ...
2012-09-19ARM: orion: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the orion include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <djbw@fb.com> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Liam Girdwood <lrg@ti.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de>
2012-09-14ARM: make mach/gpio.h headers optionalRob Herring
Most platforms don't need mach/gpio.h and it prevents multi-platform kernel images. Add CONFIG_NEED_MACH_GPIO_H and make platforns select it if they need gpio.h. This is platforms that define __GPIOLIB_COMPLEX or have lots of implicit includes pulled in by mach/gpio.h. at91 and omap have gpio clean-up pending and can drop CONFIG_NEED_MACH_GPIO_H once that is in. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-14ARM: orion: move custom gpio functions to orion-gpio.hRob Herring
Move custom orion platforms gpio code to orion-gpio to remove the dependency on mach/gpio.h. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch>
2012-09-12Merge branch 'clk' of git://github.com/hzhuang1/linux into next/cleanupOlof Johansson
* 'clk' of git://github.com/hzhuang1/linux: ARM: mmp: remove unused definition in APBC and APMU ARM: mmp: move mmp2 clock definition to separated file arm: mmp: move pxa910 clock definition to separated file arm: mmp: move pxa168 clock definition to separated file arm: mmp: make private clock definition exclude from common clock + Linux 3.6-rc4
2012-09-05Merge branch 'pinmux-dt' of ↵Olof Johansson
git://gitorious.org/sirfprima2-kernel/sirfprima2-kernel into next/dt This branch enables device tree bindings for the CSR Prima pin control subsystem. All patches acked by Linus W (pinctrl maintainer). * 'pinmux-dt' of git://gitorious.org/sirfprima2-kernel/sirfprima2-kernel: pinctrl: sirf: add DT-binding pinmux mapping support ARM: PRIMA2: rename prima2-cb.dts to prima2.dtsi as it only has SoC features ARM: PRIMA2: add missing interrupts property for pinctrl node + sync to Linux 3.6-rc4
2012-08-16ARM: mmp&dove: modify tauros2_init callChao Xie
The tauros2_init has argument, change the calling of tauros2_init to support argument. Signed-off-by: Chao Xie <xiechao.mail@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
