path: root/arch/arm/mach-clps711x
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-21ARM: clps711x: Rename board files to match functionalityAlexander Shiyan
Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21ARM: clps711x: edb7211: Add support for NOR-FlashAlexander Shiyan
2012-11-21ARM: clps711x: Moving backlight controls of framebuffer driver to the boardAlexander Shiyan
This patch moves the backlight controls for clps711x-framebuffer driver to the board code. To control we use "generic-bl" driver. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> [olof: fixed space/tab whitespace in drivers/video/clps711xfb.c] Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21ARM: clps711x: p720t: Special driver for handling NAND memory is removedAlexander Shiyan
This patch provide migration to using "gpio-nand" driver instead of using special driver for handling NAND memory. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21ARM: clps711x: Moving power management of framebuffer driver to the boardAlexander Shiyan
This patch moves the power management for clps711x-framebuffer driver to the board code. To control we use "platform-lcd" driver. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21ARM: clps711x: autcpu12: Special driver for handling NAND memory is removedAlexander Shiyan
This patch provide migration to using "gpio-nand" and "basic-mmio-gpio" drivers instead of using special driver for handling NAND memory. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21ARM: clps711x: Unused empty "ACK" calls for IRQ-chips removedAlexander Shiyan
2012-11-21ARM: clps711x: Add FIQ interrupt handlingAlexander Shiyan
CLPS711X-target CPU can have a several FIQ interrupts. With this patch we adds handling for a one which will be used for ALSA PCM later. Since FIQ have a separate handler we only add "mask" and "unmask" calls which will used for enable/disable_irq functions. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21ARM: clps711x: Implement usage "MULTI_IRQ_HANDLER" kernel option for a platformAlexander Shiyan
2012-11-21ARM: clps711x: Implement usage "SPARSE_IRQ" kernel option for a platformAlexander Shiyan
2012-11-21ARM: clps711x: cdb89712: Special driver for handling memory is removedAlexander Shiyan
This patch provide migration to using "physmap-flash" and "mtd-ram" drivers instead of using special driver for handling memory. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21ARM: clps711x: Always select AUTO_ZRELADDR for a platformAlexander Shiyan
2012-11-20ARM: clps711x: Transform clps711x-framebuffer to platform driver and use itAlexander Shiyan
clps711x-framebuffer driver needs to be updated and this is a first step to make driver better. With this patch we are convert clps711x-framebuffer to platform device and load this driver from board code. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-20ARM: clps711x: p720t: Using "leds-gpio" driver for LED controlAlexander Shiyan
Instead of manually create LED class device, we will use "leds-gpio" driver for LED control. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-20ARM: clps711x: Using platform_driver for ethernet deviceAlexander Shiyan
This patch removes static mappings for ethernet devices. Now we will use platform_driver for ethernet devices. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-10-25ARM: clps711x: merge files related to EDB7211-board into oneAlexander Shiyan
Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-25ARM: clps711x: make all virtual addresses definition via one macroAlexander Shiyan
This patch make all virtual addresses definition via one macro. This modification allows to avoid warning "BUG: mapping for 0x80000000 at 0xff000000 out of vmalloc space". Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-25ARM: clps711x: added missing definitionsAlexander Shiyan
2012-10-25ARM: clps711x: rework IRQ sybsustem initializationAlexander Shiyan
Reworked IRQ subsystem to be able to use some interrupts with "End of interrupt" handler. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-25ARM: clps711x: p720t: remove missing #includeAlexander Shiyan
2012-10-25ARM: clps711x: convert to clockeventsAlexander Shiyan
This patch converts CLPS711X-platform to use modern clockevent API. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-13ARM: config: sort select statements alphanumericallyRussell King
As suggested by Andrew Morton: This is a pet peeve of mine. Any time there's a long list of items (header file inclusions, kconfig entries, array initalisers, etc) and someone wants to add a new item, they *always* go and stick it at the end of the list. Guys, don't do this. Either put the new item into a randomly-chosen position or, probably better, alphanumerically sort the list. lets sort all our select statements alphanumerically. This commit was created by the following perl: while (<>) { while (/\\\s*$/) { $_ .= <>; } undef %selects if /^\s*config\s+/; if (/^\s+select\s+(\w+).*/) { if (defined($selects{$1})) { if ($selects{$1} eq $_) { print STDERR "Warning: removing duplicated $1 entry\n"; } else { print STDERR "Error: $1 differently selected\n". "\tOld: $selects{$1}\n". "\tNew: $_\n"; exit 1; } } $selects{$1} = $_; next; } if (%selects and (/^\s*$/ or /^\s+help/ or /^\s+---help---/ or /^endif/ or /^endchoice/)) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } undef %selects; } print; } if (%selects) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } } It found two duplicates: Warning: removing duplicated S5P_SETUP_MIPIPHY entry Warning: removing duplicated HARDIRQS_SW_RESEND entry and they are identical duplicates, hence the shrinkage in the diffstat of two lines. We have four testers reporting success of this change (Tony, Stephen, Linus and Sekhar.) Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-10-09Merge tag 'disintegrate-mtd-20121009' of ↵David Woodhouse
git://git.infradead.org/users/dhowells/linux-headers UAPI Disintegration 2012-10-09 Conflicts: MAINTAINERS arch/arm/configs/bcmring_defconfig arch/arm/mach-imx/clk-imx51-imx53.c drivers/mtd/nand/Kconfig drivers/mtd/nand/bcm_umi_nand.c drivers/mtd/nand/nand_bcm_umi.h drivers/mtd/nand/orion_nand.c
2012-10-01Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc driver specific changes from Olof Johansson: - A long-coming conversion of various platforms to a common LED infrastructure - AT91 is moved over to use the newer MCI driver for MMC - Pincontrol conversions for samsung platforms - DT bindings for gscaler on samsung - i2c driver fixes for tegra, acked by i2c maintainer Fix up conflicts as per Olof. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) drivers: bus: omap_l3: use resources instead of hardcoded irqs pinctrl: exynos: Fix wakeup IRQ domain registration check pinctrl: samsung: Uninline samsung_pinctrl_get_soc_data pinctrl: exynos: Correct the detection of wakeup-eint node pinctrl: exynos: Mark exynos_irq_demux_eint as inline pinctrl: exynos: Handle only unmasked wakeup interrupts pinctrl: exynos: Fix typos in gpio/wkup _irq_mask pinctrl: exynos: Set pin function to EINT in irq_set_type of GPIO EINTa drivers: bus: Move the OMAP interconnect driver to drivers/bus/ i2c: tegra: dynamically control fast clk i2c: tegra: I2_M_NOSTART functionality not supported in Tegra20 ARM: tegra: clock: remove unused clock entry for i2c ARM: tegra: clock: add connection name in i2c clock entry i2c: tegra: pass proper name for getting clock ARM: tegra: clock: add i2c fast clock entry in clock table ARM: EXYNOS: Adds G-Scaler device from Device Tree ARM: EXYNOS: Add clock support for G-Scaler ARM: EXYNOS: Enable pinctrl driver support for EXYNOS4 device tree enabled platform ARM: dts: Add pinctrl node entries for SAMSUNG EXYNOS4210 SoC ARM: EXYNOS: skip wakeup interrupt setup if pinctrl driver is used ...
2012-09-29mtd: autcpu12-nvram: Convert driver to platform_deviceAlexander Shiyan
Because we can have a single kernel to support multiple machines, we need to make loading specific drivers for the target platform only. For this, driver is converted to the platform driver. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-09-28ARM: clps711x: Remove board support for CEIVAAlexander Shiyan
The current kernel does not fit in the CEIVA ROM. Also, some functional has already been removed due migrate from 2.6 to 3.0, and it seems that no one uses this platform. So, remove support for this board and modules specific only to this board. Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
2012-09-28ARM: clps711x: Fix register definitionsAlexander Shiyan
This patch contain some fixes: - Fixes the address of register PORTE. - Corrects name for DAIDR0 register. - Removes unused definition for SYNCIO_CFGLEN. - Fixes definition SYNCIO_FRMLEN. Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
2012-09-28ARM: clps711x: Fix lowlevel debug-macroAlexander Shiyan
CTS signal can not be used for the port and tied to any logic state. In this case we have an infinite loop waiting for the signal. For fix this problem, checking CTS removed, waiting for the signal "busy" was postponed after the byte write to the port. Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
2012-09-28ARM: clps711x: Added simple clock frameworkAlexander Shiyan
Modern CPUs from CLPS711X-line can operate at frequencies other than 73 MHz. This patch adds simple clock framework for handling all possible CPU rates. Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
2012-08-13Merge branch 'for-arm-soc' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds into next/drivers From Bryan Wu <bryan.wu@canonical.com>: Based on Linus Walleij's ARM LED consolidation work, this patchset introduce a new generic led trigger for CPU not only for ARM but also for others. For enabling CPU idle event, CPU arch code should call ledtrig_cpu() stub to trigger idle start or idle end event. These patches convert old style LED driver in arch/arm to gpio_led or new led driver interface. Against 3.5 release and build successfully for all the machines. Test ledtrig-cpu driver on OMAP4 Panda board. v9 --> v10 * fix compiling issue on versatile_defconfig reported by Russell King * rebase to 3.5 kernel and move patches to new git tree v8 --> v9: * use mutex to replace rw_sema pointed out by Tim Gardner * add a new struct led_trigger_cpu * add lock_is_inited to record mutex lock initialization v6 --> v7: * add a patch to unify the led-trigger name * fix some typo pointed * use BUG_ON to detect CPU numbers during building stage v5 --> v6: * replace __get_cpu_var() to per_cpu() * remove smp_processor_id() which is wrong with for_each_possible_cpu() * test on real OMAP4 Panda board * add comments about CPU hotplug in the CPU LED trigger driver v4 --> v5: * rebase all the patches on top of latest linux-next * replace on_each_cpu() with for_each_possible_cpu() * add some description of ledtrig_cpu() API * remove old leds code from driver nwflash.c, which should use a new led trigger then * this trigger driver can be built as module now v3 --> v4: * fix a typo pointed by Jochen Friedrich * fix some building errors * add Reviewed-by and Tested-by into patch log v2 --> v3: * almost rewrote the whole ledtrig-cpu driver, which is more simple * every CPU will have a per-CPU trigger * cpu trigger can be assigned to any leds * fix a lockdep issue in led-trigger common code * other fix according to review v1 --> v2: * remove select operations in Kconfig of every machines * add back supporting of led in core module of mach-integrator * solidate name scheme in ledtrig-cpu.c * add comments of CPU_LED_* cpu led events * fold patches of RealView and Versatile together * add machine_is_ check during assabet led driver init * add some Acked-by in patch logs * remove code for simpad machine in machine-sa11000, since Jochen Friedrich introduced gpiolib and gpio-led driver for simpad * on Assabet and Netwinder machine, LED operations is reversed like: setting bit means turn off leds clearing bit means turn on leds * add a new function to read CM_CTRL register for led driver * 'for-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: ARM: use new LEDS CPU trigger stub to replace old one ARM: mach-sa1100: retire custom LED code ARM: mach-omap1: retire custom LED code ARM: mach-pnx4008: remove including old leds event API header file ARM: plat-samsung: remove including old leds event API header file ARM: mach-pxa: retire custom LED code char: nwflash: remove old led event code ARM: mach-footbridge: retire custom LED code ARM: mach-ebsa110: retire custom LED code ARM: mach-clps711x: retire custom LED code of P720T machine ARM: mach-integrator: retire custom LED code ARM: mach-integrator: move CM_CTRL to header file for accessing by other functions ARM: mach-orion5x: convert custom LED code to gpio_led and LED CPU trigger ARM: mach-shark: retire custom LED code ARM: mach-ks8695: remove leds driver, since nobody use it ARM: mach-realview and mach-versatile: retire custom LED code ARM: at91: convert old leds drivers to gpio_led and led_trigger drivers led-triggers: create a trigger for CPU activity Conflicts: arch/arm/mach-clps711x/p720t.c arch/arm/mach-sa1100/leds-cerf.c arch/arm/mach-sa1100/leds-lart.c Let's hope this is the last time we pull this and it doesn't cause more trouble. I have verified that version 10 causes no build warnings or errors any more, and the patches still look good. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-01ARM: mach-clps711x: retire custom LED code of P720T machineBryan Wu
Add tigger based LED driver into board file of P720T. Remove old LED driver file. Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-17ARM: clps711x: Remove the setting of the timeAlexander Shiyan
This patch fixes "bug: interrupts were enabled early" due to do_settimeofday() which used in common code for clps711x-platform. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-17ARM: clps711x: Removed superfluous transform virt_to_bus and related functionsAlexander Shiyan
This override does not allow support for multiple machines in a single core. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-17ARM: clps711x/p720t: Replace __initcall by .init_early callAlexander Shiyan
Since we are trying to do to support multiple machines in a single kernel, we need to eliminate the use of __initcall to be used for all machines. Using .init_early call solves this problem. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-15ARM: clps711x: Cleanup IRQ handlingAlexander Shiyan
This patch contains two changes: - Removed unused definitions from mach/irqs.h - Do not mask interrupts in ack procedure, because we have separate intX_mask procedure for do it and actually these 2 functions are called sequentially Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-14ARM clps711x: Removed unused header mach/time.hAlexander Shiyan
All functions from this header already provided by common.c Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-14ARM: clps711x: Added missing register definitionsAlexander Shiyan
This allows us to keep everything in a single place. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-14ARM: clps711x: Used own subarch directory for store header fileAlexander Shiyan
There is no reason to have the clps7111.h header in a globally visible location, so move it to a place that is only visible when building for mach-clps711x. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-13ARM: clps711x: Combine header files into one for clps711x-targetsAlexander Shiyan
Current ARM7 Cirrus Logic product line contains only 3 cpu. EP7312 - Fully functional. EP7309 - Missing SDRAM interface. EP7311 - Missing DAI. It makes no sense to separate the header files to identify these differences, it is only necessary to keep in mind the presence or lack of any features of a specific CPU when writing code. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-11ARM: clps711x: Using a single definition for the PHYS and VIRT registers offsetAlexander Shiyan
Using a single definition for the physical and virtual address register for all variants boards clps711x. This patch also includes the use of a single function clps_read/write in some units. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-30Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull a few more ARM platform fixes from Olof Johansson: "Apologies for back-to-back fixes pull requests, but one of the patches below are the kind we'll see posted over and over if we don't send it in. I hadn't done the full sanity-check of defconfig builds by the time I sent up the other fixes yesterday or I would have included it then. Two patches, one dealing with the system.h fallout, the other is a missing linux/bug.h in a place where ARRAY_SIZE() is used." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: clps711x: fix missing include file ARM: fix builds due to missing <asm/system_misc.h> includes
2012-03-30ARM: clps711x: fix missing include fileOlof Johansson
linux/bug.h is needed due to an ARRAY_SIZE being used: arch/arm/mach-clps711x/edb7211-mm.c: In function 'edb7211_map_io': arch/arm/mach-clps711x/edb7211-mm.c:79:9: error: implicit declaration of function 'BUILD_BUG_ON_ZERO' Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-03-06ARM: remove bunch of now unused mach/io.h filesRob Herring
Now that many platforms don't need mach/io.h, remove the unused ones. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-03-06ARM: clps711x: remove unneeded include of mach/io.hRob Herring
In preparation to remove mach/io.h, remove an unneeded include of it. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
