path: root/arch/arm/lib/memset.S
2008-11-27[ARM] remove memzero()Russell King
As suggested by Andrew Morton, remove memzero() - it's not supported on other architectures so use of it is a potential build breaking bug. Since the compiler optimizes memset(x,0,n) to __memzero() perfectly well, we don't miss out on the underlying benefits of memzero(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-22[ARM] cache align memset and memzeroNicolas Pitre
This is a natural extension following the previous patch. Non Feroceon based targets are unchanged. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2006-06-25[ARM] Remove LOADREGS macroRussell King
As for RETINSTR, LOADREGS is a left-over from the 26-bit days. Remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove RETINSTR macroRussell King
RETINSTR is a left-over from the days when we had 26-bit and 32-bit CPU support integrated into the same tree. Since this is no longer the case, we can now remove RETINSTR. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
